03 Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10003 Layer 2 - LAN Switching Command Reference
15-Cut-through forwarding commands
15-Cut-through forwarding commands 38.07 KB
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to restore the default.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled switch forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the switch and enhances forwarding performance.
# Enable cut-through forwarding on the switch.
[Sysname] cut-through enable
