03 Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10003 Layer 2 - LAN Switching Command Reference
04-MAC address table commands
04-MAC address table commands 155.3 KB
This document covers the configuration of unicast MAC address entries, including static, dynamic, blackhole, and multiport unicast MAC address entries. For more information about configuring static multicast MAC address entries, see IP Multicast Configuration Guide. For more information about MAC address table configuration in VPLS, see MPLS Configuration Guide.
display mac-address
Use display mac-address to display MAC address entries.
mac-address: Specifies a MAC address in the format of H-H-H. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
dynamic: Displays dynamic MAC address entries.
static: Displays static MAC address entries.
blackhole: Displays blackhole MAC address entries.
multiport: Displays multiport unicast MAC address entries.
count: Displays only the number of MAC address entries that match all entry attributes you specify in the command. Detailed information about MAC address entries is not displayed. For example, you can use the display mac-address vlan 20 dynamic count command to display the number of dynamic entries for VLAN 20. If you do not specify an entry attribute, the command displays the number of entries in the MAC address table. If you do not specify this keyword, the command displays detailed information about the specified MAC address entries.
A MAC address entry includes a destination MAC address, an outgoing interface, and a VLAN ID.
If you do not specify any parameters, the command displays all MAC address entries.
This command displays dynamic MAC address entries for an aggregate interface only when the aggregate interface has at least one Selected member port.
# Display MAC address entries for VLAN 100.
<Sysname> display mac-address vlan 100
MAC Address      VLAN ID    State            Port/NickName            Aging
0001-0101-0101   100        Multiport        FGE1/1/1                   N
                                             FGE1/1/2
0033-0033-0033   100        Blackhole        N/A                        N
0000-0000-0002   100        Static           FGE1/1/3                   N
00e0-fc00-5829   100        Learned          FGE1/1/4                   Y
# Display the number of MAC address entries.
<Sysname> display mac-address count
1 mac address(es) found.
VLAN ID
ID of the VLAN to which the outgoing interface of the MAC address entry belongs.
MAC address entry state:
·     StaticStatic MAC address entry.
·     LearnedDynamic MAC address entry. Dynamic entries can be learned or manually configured.
·     BlackholeBlackhole MAC address entry.
·     MultiportMultiport unicast MAC address entry.
Port/NickName
When the field displays an interface name, the field indicates the outgoing interface for packets that are destined for the MAC address. This field displays N/A for a blackhole MAC address entry.
When the field displays a 16-bit number Nickname in hexadecimal format (for example, 0x12ab), it indicates the RB through which the packets leave the TRILL network. For information about RBs and TRILL, see TRILL Configuration Guide.
Aging
Whether the entry can age out:
·     Y—The entry can age out.
·     N—The entry never ages out.
n mac address(es) found
Number of matching MAC address entries.
·     mac-address
·     mac-address timer
display mac-address nickname
Use display mac-address nickname to display the MAC address information of the egress RB specified by its nickname.
display mac-address nickname nickname
nickname nickname: Specifies an egress RB by its nickname. The value range for the nickname argument is 0x1 to 0xFFFE in hexadecimal format.
# Display the MAC address entries of the egress RB with the nickname 0x8c81.
<Sysname> display mac-address nickname 8c81
MAC Address     VLAN    IDState    Port/NickName    Aging
0000-3300-0001  10      Learned    0x8c81           Y
0000-3300-0002  10      Learned    0x8c81           Y
0000-3300-0003  10      Learned    0x8c81           Y
0000-3300-0004  10      Learned    0x8c81           Y
display mac-address aging-time
Use display mac-address aging-time to display the aging timer for dynamic MAC address entries.
# Display the aging timer for dynamic MAC address entries.
<Sysname> display mac-address aging-time
MAC address aging time: 300s.
mac-address timer
display mac-address mac-learning
Use display mac-address mac-learning to display the global MAC address learning status and the MAC learning status of the specified interface or all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays the global MAC address learning status and the MAC address learning status of all interfaces.
# Display the global MAC address learning status and the MAC learning status of all interfaces.
<Sysname> display mac-address mac-learning
Global MAC address learning status: Enabled.
Port                          Learning Status
FGE1/1/1                      Enabled
FGE1/1/2                      Enabled
FGE1/1/3                      Enabled
FGE1/1/4                      Enabled
·     Enabled.
·     Disabled.
Port
Interface name.
Learning Status
MAC address learning status of an interface:
·     Enabled.
·     Disabled.
mac-address mac-learning enable
display mac-address mac-move
Use display mac-address mac-move to display the MAC address move records after the device is started.
display mac-address mac-move [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays MAC address move records of all IRF member devices.
When MAC address moves for a MAC address always occur between the specified two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
·     In the MAC address move records, records with the same MAC address, VLAN, source port, and current port are considered as to be one record.
·     An IRF member device can save a maximum of 20 MAC address move records. When the number of MAC address move records exceeds 20, the most recent record will override the oldest record based on the last MAC address move time.
# Display the MAC address move records on the IRF member device 2.
<Sysname> display mac-address mac-move slot 2
MAC address    VLAN  Current port   Source port      Last time           Times
0000-0001-002c 1     FGE1/1/1        FGE1/1/2        2013-05-20 13:40:52 1
0000-0001-002c 1     FGE1/1/2        FGE1/1/1        2013-05-20 13:41:30 1
---  2 MAC address moving records found  ---
MAC address
MAC address.
VLAN
VLAN that the outgoing interface of the MAC address entry belongs.
Current port
Interface to which the MAC address was moved.
Source port
Interface from which the MAC address was moved.
Last time
Last time when the MAC address was moved.
Times
Number of MAC address moves after the device is started. For a MAC address record, the number of MAC address moves is increased by 1 when a new MAC address move has the same MAC address, VLAN, Current Port, and Source Port fields as the MAC address record.
mac-address notification mac-move
display mac-address statistics
Use display mac-address statistics to display MAC address table statistics.
This command displays the number of MAC address entries per type and the maximum number of MAC address entries allowed for each type.
# Display MAC address table statistics.
<Sysname> display mac-address statistics
MAC Address Count:
Dynamic Unicast Address (Learned) Count:                         0
Dynamic Unicast Address (Security-service-defined) Count:        0
Static Unicast Address (User-defined) Count:                     2
Static Unicast Address (System-defined) Count:                   3
Total Unicast MAC Addresses In Use:                              5
Total Unicast MAC Addresses Available:                           294912
Multicast and Multiport MAC Address Count:                       1
Static Multicast and Multiport MAC Address (User-defined) Count: 1
Total Multicast and Multiport MAC Addresses Available:           256
Number of dynamic unicast MAC address entries triggered by packets.
Number of dynamic unicast MAC address entries triggered by the security service.
Number of static unicast MAC address entries added by users.
Number of static unicast MAC address entries added by the system.
Number of unicast MAC address entries.
Maximum number of unicast MAC address entries allowed.
Number of multicast and multiport unicast MAC address entries.
Number of static multicast and multiport unicast MAC address entries added by users.
Maximum number of multicast and multiport unicast MAC address entries allowed.
mac-address (interface view)
Use mac-address to add or modify a MAC address entry on an interface.
Use undo mac-address to delete a MAC address entry on an interface.
Layer 2 Ethernet interface view and Layer 2 aggregate interface view:
mac-address { dynamic | multiport | static } mac-address vlan vlan-id
undo mac-address { dynamic | multiport | static } mac-address vlan vlan-id
S-channel interface view:
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
An interface is not configured with MAC address entries.
Layer 2 Ethernet interface, Layer 2 aggregate interface view, S-channel interface view
dynamic: Specifies dynamic MAC address entries.
static: Specifies static MAC address entries.
multiport: Specifies multiport unicast MAC address entries. A frame whose destination MAC address matches a multiport unicast MAC address entry is sent out of multiple ports.
mac-address: Specifies a MAC address in the format of H-H-H, excluding multicast and all-zero MAC addresses. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies an existing VLAN to which the specified interface belongs. The value range for the vlan-id argument is 1 to 4094.
Typically, the device automatically builds the MAC address table by learning the source MAC addresses of incoming frames on each interface. However, you can manually configure static MAC address entries. For a MAC address, a manually configured static entry takes precedence over a dynamically learned entry. To improve the security for the user device connected to an interface, manually configure a static entry to bind the user device to the interface. Then, the frames destined for the user device (for example, Host A) are always sent out of the interface. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
The MAC address entry configuration cannot survive a reboot unless you save it. The dynamic MAC address entries, however, are lost upon reboot whether or not you save the configuration.
# Add a static entry for MAC address 000f-e201-0101 on interface FortyGigE 1/1/1 that belongs to VLAN 2.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] mac-address static 000f-e201-0101 vlan 2
# Add a static entry for MAC address 000f-e201-0101 on Layer 2 aggregate interface Bridge-Aggregation 1 that belongs to VLAN 1.
[Sysname-Bridge-Aggregation1] mac-address static 000f-e201-0102 vlan 1
# Add a static entry for MAC address 000f-e201-0102 on interface S-Channel 1/1/1:10 that belongs to VLAN 1.
[Sysname] interface s-channel 1/1/1:10
[Sysname-S-Channel1/1/1:10] mac-address static 000f-e201-0102 vlan 1
# Add a multiport unicast MAC address entry for MAC address 0001-0001-0101 on FortyGigE 1/1/1 and FortyGigE 1/1/2 that belong to VLAN 2.
[Sysname-FortyGigE1/1/1] mac-address multiport 0001-0001-0101 vlan 2
[Sysname-FortyGigE1/1/1] quit
[Sysname] interface fortygige 1/1/2
[Sysname-FortyGigE1/1/2] mac-address multiport 0001-0001-0101 vlan 2
·     display mac-address
·     mac-address (system view)
Use mac-address to add or modify a MAC address entry.
Use undo mac-address to delete one or all MAC address entries.
undo mac-address [ [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
undo mac-address multiport mac-address interface interface-list vlan vlan-id
undo mac-address [ multiport ] [ [ mac-address ] vlan vlan-id ]
undo mac-address nickname nickname
undo mac-address mac-address nickname nickname vlan vlan-id
The system is not configured with MAC address entries.
blackhole: Specifies blackhole MAC address entries. Packets whose source or destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Specifies an existing VLAN to which the interface belongs. The value range for the vlan-id argument is 1 to 4094.
interface interface-type interface-number: Specifies an outgoing interface by its type and number.
interface interface-list: Specifies interfaces in the format of { interface-type interface-number [ to interface-type interface-number ] } &<1-n>. The interface can only be a Layer 2 Ethernet interface or Layer 2 aggregate interface. &<1-4> specifies that you can configure a maximum of 4 interfaces or interface ranges.
nickname nickname: Specifies an RB (through which the packets leave the TRILL network) by its nickname. The nickname is a hexadecimal number in the range of 0x1 to 0xFFFE.
To drop frames with the specified source MAC addresses or destination MAC addresses, you can configure blackhole MAC address entries.
To send frames with a specific destination MAC address out of multiple ports, configure a multiport unicast MAC address entry. When you execute this command for the first time, the command adds a MAC address entry. When you execute the command again with the same MAC address and VLAN but with different interfaces, this command adds the specified interfaces for this entry.
A static or blackhole MAC address entry can overwrite a dynamic MAC address entry, but not vice versa.
If you execute the undo mac-address command without specifying any parameters, this command deletes all unicast MAC address entries and static multicast MAC address entries.
You can delete all the MAC address entries (including unicast MAC address entries and static multicast MAC address entries) of a specified VLAN. You can also delete only one type (dynamic, static, blackhole, or multiport unicast) of MAC address entries. You can single out an interface and delete the corresponding unicast MAC address entries, but not the corresponding static multicast MAC address entries. You can single out an RB through which the packets leave the TRILL network and delete the corresponding unicast MAC address entries.
# Add a static entry for MAC address 000f-e201-0101. Then, all frames that are destined for this MAC address are sent out of interface FortyGigE 1/1/1, which belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface fortygige 1/1/1 vlan 2
# Add a multiport unicast MAC address entry for MAC address 000f-e201-0101. Then, all frames that are destined for this MAC address are sent out of FortyGigE 1/1/1 through FortyGigE 1/1/3, which belong to VLAN 2.
[Sysname] mac-address multiport 000f-e201-0101 interface fortygige 1/1/1 to fortygige 1/1/3 vlan 2
·     mac-address (interface view)
Use mac-address mac-learning enable to enable MAC address learning globally, on an interface, or on a VLAN.
Use undo mac-address mac-learning enable to disable MAC address learning globally, on an interface, or on a VLAN.
MAC address learning is enabled.
VLAN view
To prevent the MAC address table from becoming saturated, you can disable MAC address learning.
For example, a number of packets with different source MAC addresses reaching a device can affect the MAC address table update. To avoid such attacks, you can disable MAC address learning by following these guidelines:
·     You can disable MAC address learning on a per-interface basis. If you disable MAC address learning globally, MAC address learning is disabled for all interfaces. The device then stops learning MAC addresses and cannot dynamically update the MAC address table.
·     Because disabling MAC address learning can result in broadcast storms, enable broadcast storm suppression after you disable MAC address learning on an interface. For more information about broadcast storm suppression, see Layer 2—LAN Switching Configuration Guide.
·     With MAC address learning enabled globally, you can disable MAC address learning for an interface or VLAN.
This command does not take effect in a TRILL network, in a VPLS VSI, or for an S-channel. For information about TRILL, see TRILL Configuration Guide. For information about VSIs, see MPLS Configuration Guide. For information about S-channels, see EVB Configuration Guide.
When MAC address learning is disabled, the device immediately deletes the existing dynamic MAC address entries.
# Disable MAC address learning globally.
[Sysname] undo mac-address mac-learning enable
# Disable MAC address learning for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] undo mac-address mac-learning enable
# Disable MAC address learning on interface FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] undo mac-address mac-learning enable
# Disable MAC address learning on interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo mac-address mac-learning enable
# Disable MAC address learning on interface S-Channel 1/1/1:10.
[Sysname-S-Channel1/1/1:10] undo mac-address mac-learning enable
mac-address mac-learning priority
Use mac-address mac-learning priority to assign MAC learning priority to an interface.
Use undo mac-address mac-learning priority to restore the default.
mac-address mac-learning priority { high | low }
Low MAC address learning priority is used.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
high: Assigns high MAC learning priority.
low: Assigns low MAC learning priority.
The MAC address learning priority values can be high and low. An interface with high MAC address learning priority can learn any MAC address. An interface with low MAC address learning priority can learn only the MAC addresses that have not been learned by high-priority interfaces.
The MAC learning priority mechanism can help defend your network against MAC address spoofing attacks. To prevent the downlink interface from learning the MAC address of an upper layer device (for example, the gateway), you can perform the following tasks:
·     Assign high MAC learning priority to an uplink interface.
·     Assign low MAC learning priority to a downlink interface .
# Assign high MAC learning priority to interface FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] mac-address mac-learning priority high
# Assign high MAC learning priority to interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] mac-address mac-learning priority high
mac-address mac-roaming enable
Use mac-address mac-roaming enable to enable MAC address synchronization.
Use undo mac-address mac-roaming enable to restore the default.
MAC address synchronization is disabled.
If ports on different IRF member devices are Selected ports from the same aggregation group, MAC address entries are synchronized among these IRF member devices. They are synchronized whether or not MAC address synchronization is enabled for the IRF fabric. For more information about aggregation groups, see Layer 2—LAN Switching Configuration Guide.
The MAC address table size might vary by IRF member device. With MAC address synchronization enabled, MAC address entries exceeding the table size of an IRF member device cannot be synchronized to the MAC address table.
# Enable MAC address synchronization.
[Sysname] mac-address mac-roaming enable
mac-address max-mac-count
Use mac-address max-mac-count to set the MAC learning limit on an interface.
Use undo mac-address max-mac-count to restore the default.
The maximum number of MAC addresses that can be learned on an interface is not set.
count: Sets the maximum number of MAC addresses that can be learned on an interface. The value range is 0 to 4096. When the argument is set to 0, the interface is not allowed to learn MAC addresses.
When the number of MAC address entries learned by an interface reaches the limit, the interface stops learning MAC address entries.
# Configure interface FortyGigE 1/1/1 to learn a maximum of 600 MAC address entries.
[Sysname-FortyGigE1/1/1] mac-address max-mac-count 600
·     mac-address
·     mac-address max-mac-count enable-forwarding
Use mac-address max-mac-count enable-forwarding to enable the device to forward unknown frames received on an interface after the MAC learning limit on the interface is reached.
Use undo mac-address max-mac-count enable-forwarding to disable the device from forwarding unknown frames received on an interface after the MAC learning limit on the interface is reached.
When the MAC learning limit on an interface is reached, the device can forward unknown frames received on the interface.
In this document, unknown frames refer to frames whose source MAC addresses are not in the MAC address table.
# Configure FortyGigE 1/1/1 to learn a maximum of 600 MAC address entries.
# Disable the device from forwarding unknown frames received on FortyGigE 1/1/1 after the MAC learning limit on FortyGigE 1/1/1 is reached.
[Sysname-FortyGigE1/1/1] undo mac-address max-mac-count enable-forwarding
·     mac-address
mac-address mac-move fast-update
Use mac-address mac-move fast-update to enable ARP fast update for MAC address moves.
Use undo mac-address mac-move fast-update to restore the default.
ARP fast update is disabled for MAC address moves.
# Enable ARP fast update for MAC address moves.
[Sysname] mac-address mac-move fast-update
Use mac-address notification mac-move to enable MAC address move notifications and optionally specify a MAC move detection interval.
Use undo mac-address notification mac-move to restore the default.
mac-address notification mac-move [ interval interval-value ]
MAC address move notifications are disabled, and the MAC move detection interval for MAC address moves is 1 minute.
interval interval-value: Sets a detection interval for MAC address moves, in the range of 1 to 60 minutes. If you do not specify this option, the default setting of 1 minute is used.
With MAC address move notifications enabled, the system displays the MAC address move logs when it detects MAC address moves. Each record of the MAC address move logs contains the following information:
·     MAC address.
·     VLAN ID of the MAC address entry.
·     Current port and source port of the MAC address moves.
·     Number of MAC address moves within a MAC move detection interval.
After you execute this command:
·     If the snmp-agent trap enable mac-address command is also executed, the system sends SNMP information to the SNMP module of the device.
·     If the snmp-agent trap enable mac-address command is not executed, the system sends syslog messages to the information center module.
Within a detection interval, an IRF member device can display a maximum of 20 MAC address move records. The latest record will override the oldest one.
# Enable MAC address move notifications.
[Sysname] mac-address notification mac-move
[Sysname]
%May 14 17:16:45:688 2013 H3C MAC/4/MAC_FLAPPING: MAC address 0000-0012-0034 in VLAN 500 has moved from port FGE1/1/1 to port FGE1/1/2 for 1 times
The output shows that:
·     The VLAN ID of which MAC address 0000-0012-0034 is VLAN 500.
·     The MAC address moved from port FortyGigE 1/1/1 to port FortyGigE 1/1/2.
·     The MAC address has moved once within the last 1 minute (the default interval).
mac-address notification mac-move suppression
Use mac-address notification mac-move suppression to enable MAC address move suppression.
Use undo mac-address notification mac-move suppression to restore the default.
MAC address moves are not suppressed.
This feature shuts an interface down when a MAC address has been moved from the interface more than the specified suppression threshold within a MAC move detection interval. You can use the shutdown command and then the undo shutdown command to bring up the interface. Also, the interface can automatically come up after a suppression interval.
# Enable MAC address move suppression on FortyGigE 1/1/1.
[Sysname- FortyGigE1/1/1] mac-address notification mac-move suppression
mac-address notification mac-move suppression interval
Use mac-address notification mac-move suppression interval to set a suppression interval for MAC address moves.
Use undo mac-address notification mac-move suppression interval to restore the default.
mac-address notification mac-move suppression interval interval-value
The suppression interval for MAC address moves is 30 seconds.
interval interval-value: Sets the MAC address move suppression interval in the range of 30 to 86400 seconds. If you do not specify this option, the default suppression interval of 30 seconds is used.
# Set the suppression interval to 100 seconds for MAC address moves.
[Sysname] mac-address notification mac-move suppression interval 100
mac-address notification mac-move suppression threshold
Use mac-address notification mac-move suppression threshold to set a threshold for MAC address moves sourced from an interface within a detection interval.
Use undo mac-address notification mac-move suppression threshold to restore the default.
mac-address notification mac-move suppression threshold threshold-value
The threshold is 3.
threshold-value: Sets the threshold for MAC address moves sourced from an interface within a detection interval. The value range for this argument is 0 to 1024.
The system shuts down the interface when the following conditions exist:
·     The interface is enabled with MAC address move suppression.
·     The number of MAC address moves from the interface within a detection interval exceeds the threshold.
After the suppression interval elapses, the interface comes up automatically. You can also use the undo shutdown command to manually bring up the interface.
If the threshold is set to 0, the system shuts down an interface if a MAC address moves from the interface.
# Set the threshold to 1 for MAC address moves sourced from an interface within a detection interval.
[Sysname] mac-address notification mac-move suppression threshold 1
mac-address static source-check enable
Use mac-address static source-check enable to enable the static source check feature.
Use undo mac-address static source-check enable to disable the static source check feature.
The static source check feature is enabled.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface/subinterface view
Layer 2 aggregate interface view, Layer 3 aggregate interface /subinterface view
# Disable the static source check feature.
[Sysname-FortyGigE1/1/1] undo mac-address static source-check enable
mac-address timer
Use mac-address timer to set the aging timer for dynamic MAC address entries.
Use undo mac-address timer to restore the default.
The aging timer is 300 seconds for dynamic MAC address entries.
aging seconds: Sets an aging timer (in seconds) for dynamic MAC address entries, in the range of 10 to 1000000 seconds.
no-aging: Configures dynamic MAC address entries not to age.
To set the aging timer appropriately, follow these guidelines:
·     A long aging interval causes the MAC address table to retain outdated entries and fail to accommodate the most recent network changes.
·     A short aging interval results in removal of valid entries. Then, unnecessary broadcasts packets appear and affect device performance.
# Set the aging time to 500 seconds for dynamic MAC address entries.
Use snmp-agent trap enable mac-address to enable SNMP notifications for the MAC address table.
Use undo snmp-agent trap enable mac-address to disable SNMP notifications for the MAC address table.
snmp-agent trap enable mac-address [ mac-move ]
undo snmp-agent trap enable mac-address [ mac-move ]
SNMP notifications for the MAC address table are enabled.
mac-move: Enables SNMP notifications about the MAC address moves for the MAC address table. If you do not specify this keyword, the command enables all types of SNMP notifications for the MAC address table.
When SNMP notifications are disabled for the MAC address table, MAC address moves are reported in syslog messages.
The MAC address table supports only SNMP notifications about MAC address moves. When you enable or disable SNMP notifications about MAC address moves, you enable or disable all types of SNMP notifications for the MAC address table.
# Disable SNMP notifications about MAC address moves for the MAC address table.
[Sysname] undo snmp-agent trap enable mac-address mac-move
mac-address information enable (interface view)
Use mac-address information enable to enable MAC Information on an interface.
Use undo mac-address information enable to disable MAC Information on an interface.
undo mac-address information enable { added | deleted }
MAC Information is disabled on an interface.
Layer 2 Ethernet interface view, S-channel interface view
added: Enables the device to record MAC change information when a new MAC address is learned on an interface.
deleted: Enables the device to record MAC change information when an existing MAC address is deleted.
Before you enable MAC Information on an interface, enable MAC Information globally.
# Enable MAC Information on FortyGigE 1/1/1 to enable the interface to record MAC change information when learning a new MAC address.
[Sysname-FortyGigE1/1/1] mac-address information enable added
# Enable MAC Information on S-Channel 1/1/1:10 to the interface to record MAC change information when learning a new MAC address.
[Sysname-S-Channel1/1/1:10] mac-address information enable added
mac-address information enable (system view)
Use mac-address information enable to enable MAC Information globally.
Use undo mac-address information enable to disable MAC Information globally.
MAC Information is disabled globally.
# Enable MAC Information globally.
[Sysname] mac-address information enable
mac-address information interval
Use mac-address information interval to set the MAC change notification interval.
Use undo mac-address information interval to restore the default.
mac-address information interval interval-time
The MAC change notification interval is 1 second.
interval-time: Sets the MAC change notification interval in the range of 1 to 20000 seconds.
To prevent syslog messages or SNMP notifications from being sent too frequently, set the MAC change notification interval to a larger value.
# Set the MAC change notification interval to 200 seconds.
[Sysname] mac-address information interval 200
mac-address information mode
Use mac-address information mode to set the MAC Information mode. The MAC Information mode specifies the type of messages (syslog messages or SNMP notifications) used to notify MAC changes.
Use undo mac-address information mode to restore the default.
SNMP notifications are sent to notify MAC changes.
syslog: Specifies that the device sends syslog messages to notify MAC changes.
trap: Specifies that the device sends SNMP notifications to notify MAC changes.
# Set the MAC Information mode to trap.
[Sysname] mac-address information mode trap
mac-address information queue-length
Use mac-address information queue-length to set the MAC Information queue length.
Use undo mac-address information queue-length to restore the default.
The MAC Information queue length is 50.
value: Sets the MAC Information queue length in the range of 0 to 1000. The MAC Information queue length indicates the number of MAC change messages.
If the MAC Information queue length is 0, the device sends a syslog message or SNMP notification immediately after learning or deleting a MAC address.
If the MAC Information queue length is not 0, the device stores MAC changes in the queue:
·     The device overwrites the oldest MAC change written into the queue with the most recent MAC change when the following conditions exist:
¡     The MAC change notification interval does not expire.
¡     The queue has been exhausted.
·     The device sends syslog messages or SNMP notifications only if the MAC change notification interval expires.
# Set the MAC Information queue length to 600.
[Sysname] mac-address information queue-length 600
