03 Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10003 Layer 2 - LAN Switching Command Reference
13-LLDP commands
13-LLDP commands 200.94 KB
LLDP commands
You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
dcbx version
Use dcbx version to configure the DCBX version.
Use undo dcbx version to restore the default.
dcbx version { rev100 | rev101 | standard }
undo dcbx version
The DCBX version is autonegotiated by two interfaces, with the standard version as the initial version for negotiation at the local end.
rev100: Specifies DCBX Rev 1.00.
rev101: Specifies DCBX Rev 1.01.
standard: Specifies the IEEE Std 802.1Qaz-2011.
For DCBX to work correctly, configure the same DCBX version that is supported on both ends. H3C recommends that you configure the highest version supported on both ends. IEEE Std 802.1Qaz-2011, DCBX Rev 1.01, and DCBX Rev 1.00 are in descending order.
After this command is configured, an interface includes the configured DCBX version in its outgoing LLDP frames and does not negotiate the DCBX version with the peer interface.
# Configure the DCBX version as DCBX Rev 1.01 on interface FortyGigE 1/1/1.
[Sysname] interface fortygige1/1/1
[Sysname-FortyGigE1/1/1] dcbx version rev101
display lldp local-information
Use display lldp local-information to display local LLDP information, which will be contained in the advertisable LLDP TLVs and sent to neighboring devices.
global: Displays the global local LLDP information.
interface interface-type interface-number: Specifies a port by its type and number.
If no keyword or argument is specified, this command displays all local LLDP information, which includes the following:
·     The global LLDP information.
·     The LLDP information about the LLDP-enabled ports in up state.
# Display all local LLDP information.
<Sysname> display lldp local-information
 Chassis ID          : 00e0-fc11-1998
 System name         : sysname
 System description  : H3C Comware Platform Software, Software Version 7.1.045,
                       Test 2410001
                       H3C S7502E-XS
                       Copyright (c) 2004-1-14 Hangzhou H3C Tech. Co., Ltd. All
                       rights reserved.
 System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
 System capabilities enabled   : Bridge, Router, Customer Bridge
 MED information:
 Device class               : Connectivity device
 MED inventory information of master board:
 HardwareRev                : Ver.A
 FirmwareRev                : 208
 SoftwareRev                : 7.1.045 Test 2410001
 SerialNum                  : 210235A1AE0000001234
 Manufacturer name          : H3C
 Model name                 : H3C S7502E-XS
 Asset tracking identifier  : Unknown
LLDP local-information of port 1[FortyGigE1/1/1]:
 Port ID type        : Interface name
 Port ID             : FortyGigE1/1/1
 Port description    : FortyGigE1/1/1 Interface
 LLDP agent nearest-bridge management address:
 Management address type           : All802
 Management address                : 00e0-fc11-1a21
 Management address interface ID   : Unknown
 Management address OID            : 0
 LLDP agent nearest-nontpmr management address:
 LLDP agent nearest-customer management address:
 DCBX Control info:
  Oper version       : Standard
 DCBX ETS configuration info:
  CBS                : False
  Max TCs            : 8
  CoS     Local Priority      Percentage        TSA
   0            2                 6             ETS
   1            0                 2             ETS
   2            1                 4             ETS
   3            5                 19            ETS
   4            4                 11            ETS
   5            5                 19            ETS
   6            6                 27            ETS
   7            7                 31            ETS
 DCBX ETS recommendation info:
   0            2                 6             ETS
   1            0                 2             ETS
   2            1                 4             ETS
   3            5                 19            ETS
   4            4                 11            ETS
   5            5                 19            ETS
   6            6                 27            ETS
   7            7                 31            ETS
 DCBX PFC info:
  P0-0     P1-0     P2-0     P3-0     P4-0     P5-1     P6-0     P7-0
  Number of traffic classes supported: 8
  Value of MBC: 0
 DCBX APP info:
  Selected Field  Protocol ID  Priority
  Ethertype       0x8906       0x3
  Ethertype       0x8914       0x3
 Port VLAN ID(PVID)  : 1
 Port and protocol VLAN ID(PPVID)  : 0
 Port and protocol VLAN supported  : No
 Port and protocol VLAN enabled    : No
 VLAN name of VLAN 1        : VLAN 0001
 Management VLAN ID  : 0
 Link aggregation enabled   : No
 Aggregation port ID        : 0
 Auto-negotiation enabled   : Yes
 OperMau                    : Speed(40000)/Duplex(Full)
 Power port class           : PSE
 PSE power supported        : No
 PSE power enabled          : No
 PSE pairs control ability  : No
 Power pairs                : Signal
 Port power classification  : Class 0
 Maximum frame size         : 10000
Chassis ID
Bridge MAC address of the device.
Supported capabilities:
·     Bridge—Switching is supported.
·     Router—Routing is supported.
·     DocsisCableDeviceThe local device can serve as a DOCSIS-compliant cable device.
·     StationOnlyThe local device can serve as a station only.
·     Customer BridgeThe customer bridge function is supported.
·     Service BridgeThe service bridge function is supported.
·     TPMRThe two-port MAC relay (TPMR) function is supported.
·     OtherFunctions other than those listed above are supported.
Enabled capabilities:
·     Bridge—Switching is enabled.
·     Router—Routing is enabled.
·     DocsisCableDeviceThe local device is serving as a DOCSIS-compliant cable device.
·     StationOnlyThe local device is serving as a station only.
·     Customer BridgeThe customer bridge function is enabled.
·     Service BridgeThe service bridge function is enabled.
·     TPMRThe TPMR function is enabled.
·     OtherFunctions other than those listed above are enabled.
Device class
MED device class:
·     Connectivity device—Network device.
·     Class I—Normal terminal device. It requires the basic LLDP discovery services.
·     Class II—Media terminal device. It supports media streams, and can also function as a normal terminal device.
·     Class III—Communication terminal device. It supports the IP communication systems of end users, and can also function as a normal terminal device or media terminal device.
MED inventory information of the master board on the IRF device.
HardwareRev
Hardware version.
FirmwareRev
Firmware version.
SoftwareRev
Software version.
SerialNum
Serial number.
Manufacturer name
Device manufacturer.
Model name
Device model.
Port ID type
Port ID type:
·     MAC address.
·     Interface name.
Port ID
Port ID, the value of which varies with port ID type.
Numbering type of the interface identified by the management address.
Index of the interface identified by the management address.
Management address object ID.
DCBX control info
Displayed as version information in IEEE Std 802.1Qaz-2011.
Oper version
DCBX version number.
Sequence number
Number of DCBX TLV content changes.
Acknowledge number
Times of synchronizing configurations by the peer device.
DCBX ETS info
CoS-to-local priority mapping and bandwidth allocation.
Percentage
Percentage of bandwidth allocated.
P0-   P1-   P2-   P3-   P4-   P5-   P6-   P7-
Number of supported priorities configured by using the priority-flow-control no-drop dot1p dot1p-list command at the local end.
Capability set supported by PFC (displayed only in Rev 1.01).
Priority
802.1p priority.
Protocol ID
Application protocol number.
CoS map
Application protocol-to-CoS mapping.
CBS
Indicates whether the token bucket mechanism is supported on the port:
·     False—The token bucket mechanism is not supported.
·     True—The token bucket mechanism is supported.
Max TCs
Maximum number of priorities supported.
TSA
Transmission selection algorithm.
Value of MBC
MBC indicates the ability of packets to bypass MACsec. It is 1-bit long.
·     0—Packets can bypass MACsec when MACsec is disabled.
·     1—Packets cannot bypass MACsec when MACsec is disabled.
Indicates whether link aggregation is supported on the port.
Indicates whether link aggregation is enabled on the port.
Aggregation port ID
Member port ID, which is 0 when link aggregation is disabled.
Indicates whether autonegotiation is supported on the port.
Indicates whether autonegotiation is enabled on the port.
OperMau
Speed and duplex state of the port.
Power port class
PoE port class:
·     PSE—Power sourcing equipment.
·     PD—Powered device.
PSE power supported
Indicates whether the device can operate as a PSE.
PSE power enabled
Indicates whether the device is operating as a PSE.
Indicates whether the PSE-PD pair control is available.
Power pairs
Power supply mode:
·     SignalUses data pairs to supply power.
·     SpareUses spare pairs to supply power.
Port power classification of the PD:
·     Class 0.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
Media policy type
Media policy type:
·     unknown.
·     voice.
·     voiceSignaling.
·     guestVoice.
·     guestVoiceSignaling.
·     softPhoneVoice.
·     videoconferencing.
·     streamingVideo.
·     videoSignaling.
Unknown policy
Indicates whether the media policy is unknown.
VLAN tagged
Indicates whether packets of the media VLAN are tagged.
Media policy VLAN ID
ID of the media VLAN.
Media policy L2 priority
Layer 2 priority.
Media policy DSCP
DSCP value.
display lldp neighbor-information
Use display lldp neighbor-information to display the LLDP information carried in LLDP TLVs that the local device receives from the neighboring devices.
interface interface-type interface-number: Specifies a port by its type and number. If this option is not specified, this command displays the LLDP information that all ports receive from the neighboring devices.
agent: Specifies an agent by its type and number. If no agent type is specified, the command displays the LLDP information that all LLDP agents receive from the neighboring devices.
nearest-bridge: Specifies nearest bridge agents.
nearest-customer: Specifies nearest customer bridge agents.
nearest-nontpmr: Specifies nearest non-TPMR bridge agents.
verbose: Displays the detailed LLDP information that the local device receives from the neighboring devices. If this keyword is not specified, this command displays the brief LLDP information that the local device receives from the neighboring devices.
list: Displays the LLDP information that the local device receives from the neighboring devices in the form of a list.
system-name system-name: Displays the LLDP information that the local device receives from a neighboring device specified by its system name. The system-name argument is a string of 1 to 255 characters. If this option is not specified, this command displays the LLDP information that the local device receives from all neighboring devices in a list.
# Display the detailed LLDP information that the nearest bridge agents on all ports received from the neighboring devices. (DCBX is IEEE Std 802.1Qaz-2011.)
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[FortyGigE1/1/1]:
LLDP agent nearest-bridge:
 LLDP Neighbor index : 1
 Update time         : 0 days, 0 hours, 1 minutes, 1 seconds
 Chassis type        : MAC address
 Chassis ID          : 000f-0055-0002
 Time to live        : 120
 System name         : Sysname
 Management address type           : IPv4
 Management address                : 192.168.1.55
 DCBX Control info:
  CBS                : False
  Max TCs            : 8
  CoS     Local priority      Percentage        TSA
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
 DCBX PFC info:
  P0-0     P1-1     P2-1     P3-1     P4-0     P5-0     P6-0     P7-0
  Value of MBC: 0
 DCBX APP info:
  UDP/DCCP                   100         0x3
  TCP/SCTP                    200         0x3
  Ethertype                   0x1234      0x3
 Port VLAN ID(PVID): 1
 VLAN name of VLAN 12: VLAN 0012
 Management VLAN ID  : 5
 OperMau                    : Speed(1000)/Duplex(Full)
 Power port class           : PD
 PSE power supported        : Yes
 PSE power enabled          : Yes
 PSE pairs control ability  : Yes
 Link aggregation enabled   : Yes
 Aggregation port ID        : 52
 Maximum frame size         : 1500
# Display the detailed LLDP information that all LLDP agents on all ports received from the neighboring devices. (DCBX is IEEE Std 802.1Qaz-2011.)
<Sysname> display lldp neighbor-information verbose
 Time to live        : 121
 DCBX control info:
  CBS                : False
  Max TCs            : 8
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
   0            0                 15            ETS
   1            1                 0             SP
   2            2                 15            ETS
   3            3                 14            ETS
   4            4                 14            ETS
   5            5                 14            ETS
   6            6                 14            ETS
   7            7                 14            ETS
 DCBX PFC info:
  Value of MBC: 0
 DCBX APP info:
  UDP/DCCP        100          0x3
  TCP/SCTP        200          0x3
LLDP agent nearest-nontpmr:
 Time to live        : 121
 Port and protocol VLAN ID(PPVID) : 12
 Port and protocol VLAN supported : Yes
 Port and protocol VLAN enabled   : Yes
# Display the brief LLDP information that all LLDP agents on all ports received from the neighboring devices.
LLDP neighbor-information of port 52[FortyGigE1/1/3]:
 LLDP neighbor index : 3
 ChassisID/subtype   : 0011-2233-4400/MAC address
 PortID/subtype      : 000c-29f5-c71f/MAC address
 Capabilities        : Bridge, Router, Customer Bridge
 LLDP neighbor index : 6
 PortID/subtype      : 000c-29f5-c715/MAC address
 Capabilities        : None
CDP neighbor-information of port 52[FortyGigE1/1/3]:
 CDP neighbor index  : 4
 Chassis ID          : SEP00260B5C0548
 Port ID             : Port 1
 CDP neighbor index  : 5
 Chassis ID          : 0011-2233-4400
 Port ID             : FortyGigE1/1/4
 Capabilities        : None
# Display the brief LLDP information that all LLDP agents received from all neighboring devices in a list.
Chassis ID : * -- --Nearest nontpmr bridge neighbor
             # -- --Nearest customer bridge neighbor
             Default -- -- Nearest bridge neighbor
System Name          Local Interface     Chassis ID        Port ID
System1              FGE1/1/1            000f-e25d-ee91    FortyGigE1/1/5
System2              FGE1/1/2            000f-e25d-ee92*   FortyGigE1/1/6
System3              FGE1/1/3            000f-e25d-ee93#   FortyGigE1/1/7
LLDP information received through port 1.
Update time
Time when LLDP information about a neighboring device was last updated.
Chassis type
Chassis ID type:
·     Chassis component.
·     Interface alias.
·     Port component.
·     MAC address.
·     Network address (ipv4).
·     Interface name.
·     Locally assignedLocally-defined chassis type other than those listed above.
Chassis ID
ID that identifies the LLDP sending device, which can be a MAC address, a network address, an interface, or some other value, depending on the chassis type of the neighboring device.
Port ID type
Port ID type:
·     Interface alias.
·     Port component.
·     MAC address.
·     Interface name.
·     Agent circuit ID.
·     Locally assignedLocally-defined port ID type other than those listed above.
Port ID
Value of the type of the port ID.
System name
System name of the neighboring device.
System description
System description of the neighboring device.
Capabilities supported on the neighboring device:
·     Repeater—Signal repeating is supported.
·     WlanAccessPointThe neighboring device can serve as a wireless AP.
·     TelephoneThe neighboring device can serve as a telephone.
·     DocsisCableDeviceThe neighboring device can serve as a DOCSIS-compliant cable device.
·     StationOnlyThe neighboring device can serve as a station only.
Capabilities enabled on the neighboring device:
·     Repeater—Signal repeating is enabled.
·     WlanAccessPointThe neighboring device is serving as a wireless AP.
·     TelephoneThe neighboring device is serving as a telephone.
·     DocsisCableDeviceThe neighboring device is serving as a DOCSIS-compliant cable device.
·     StationOnlyThe neighboring device is serving as a station only.
DCBX control info
Oper version
Sequence number
Acknowledge number
DCBX ETS info
Percentage
Number of supported priorities configured by using the priority-flow-control no-drop dot1p dot1p-list command on the neighbor.
Capability set supported by PFC (displayed only in Rev 1.01 and IEEE Std 802.1Qaz-2011).
CoS map
CBS
Max TCs
TSA
Value of MBC
Port protocol VLAN ID.
Indicates whether protocol VLAN is supported on the port.
Indicates whether protocol VLAN is enabled on the port.
Name of VLAN 12.
OperMau
Speed and duplex state on the port.
Power port class
PoE port class:
PSE power supported
PSE power enabled
Indicates whether the pair selection ability is available.
Power pairs
Power supply mode:
Power class of the PD:
·     Class 0.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
Indicates whether link aggregation is supported.
Indicates whether link aggregation is enabled.
TLV type
Unknown basic TLV type.
TLV information
Information contained in the unknown basic TLV type.
Unknown organizationally-defined TLV
Unknown organizationally specific TLV.
TLV OUI
OUI of the unknown organizationally specific TLV.
TLV subtype
Unknown organizationally specific TLV subtype.
Index
Unknown organization index.
Capabilities
·     NoneThe neighboring device does not advertise this TLV.
Local Interface
Local port that receives the LLDP information.
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
                    #-- -- Nearest customer bridge neighbor
Chassis ID flag:
·     An asterisk (*) indicates the nearest non-TPMR bridge neighbor.
·     A pound sign (#) indicates the nearest customer bridge neighbor.
display lldp statistics
Use display lldp statistics to display the global LLDP statistics or the LLDP statistics of a port.
global: Displays the global LLDP statistics.
agent: Specifies an LLDP agent type. If no agent type is specified, the command displays the statistics for all LLDP agents.
If no keyword or argument is specified, this command displays the global LLDP statistics and the LLDP statistics of all ports.
# Display the global LLDP statistics and the LLDP statistics of all ports.
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics information of port 1 [FortyGigE1/1/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
LLDP agent nearest-customer:
# Display the LLDP statistics for the nearest customer bridge agents on FortyGigE 1/1/1.
<Sysname> display lldp statistics interface FortyGigE1/1/1 agent nearest-customer
Global LLDP statistics.
Time when the neighbor information was last updated.
Number of times neighbor information was added.
Number of times neighbor information was removed.
Number of times neighbor information was dropped due to lack of available memory space.
display lldp status
Use display lldp status to display LLDP status.
agent: Specifies an LLDP agent type. If no agent type is specified, the command displays the status information for all LLDP agents.
If no port is specified, this command displays the global LLDP status and the LLDP status of each port.
# Display the global LLDP status and the LLDP status of each port.
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
Transmit interval              : 30s
Fast transmit interval         : 1s
Transmit max credit            : 5
Hold multiplier                : 4
Reinit delay                   : 2s
Trap interval                  : 5s
Fast start times               : 3
LLDP status information of port 1 [FortyGigE1/1/1]:
Port status of LLDP            : Enable
Admin status                   : Tx_Rx
Trap flag                      : No
MED trap flag                  : No
Polling interval               : 0s
Number of LLDP neighbors       : 5
Number of MED neighbors        : 2
Number of CDP neighbors        : 0
Number of sent optional TLV    : 12
Trap flag                      : No
Trap flag                      : No
Bridge mode of LLDP
LLDP bridge mode: service-bridge or customer-bridge.
Indicates whether LLDP is globally enabled.
Transmit interval
LLDP frame transmission interval.
Hold multiplier
TTL multiplier.
Reinit delay
LLDP reinitialization delay.
Transmit max credit
Token bucket size for sending LLDP frames.
Trap interval
Trap transmission interval.
Fast start times
Number of LLDP frames sent each time fast LLDP frame transmission is triggered.
Port 1
LLDP status of port 1.
Port status of LLDP
Indicates whether LLDP is enabled on the port.
Admin status
LLDP operating mode of the port:
·     Tx_Rx—The port can send and receive LLDP frames.
·     Rx_Only—The port can only receive LLDP frames.
·     Tx_Only—The port can only send LLDP frames.
·     Disable—The port cannot send or receive LLDP frames.
Trap Flag
Indicates whether trapping is enabled.
Polling interval
LLDP polling interval, which is 0 when LLDP polling is disabled.
Number of neighbors
Number of LLDP neighbors connecting to the port.
Number of MED neighbors connecting to the port.
Number of CDP neighbors connecting to the port.
Number of optional TLVs contained in an LLDP frame sent through the port.
Number of unknown TLVs contained in a received LLDP frame.
display lldp tlv-config
Use display lldp tlv-config to display the types of advertisable optional LLDP TLVs of a port.
agent: Specifies an LLDP agent type. If no agent type is specified, the command displays the types of advertisable optional LLDP TLVs for all LLDP agents.
If no port is specified, this command displays the types of advertisable optional TLVs of all ports.
# Display the types of advertisable optional LLDP TLVs of interface FortyGigE 1/1/1.
<Sysname> display lldp tlv-config interface fortygige 1/1/1
LLDP tlv-config of port 1[FortyGigE1/1/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       YES
 System Name TLV                  YES       YES
 System Description TLV           YES       YES
 System Capabilities TLV          YES       YES
 Management Address TLV           YES       YES
IEEE 802.1 extend TLV:
 Port VLAN ID TLV                 YES       YES
 Port And Protocol VLAN ID TLV    YES       YES
 VLAN Name TLV                    YES       YES
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
 Link Aggregation TLV             YES       YES
 Management VID TLV               YES       YES
 Congestion notification TLV      NO        NO
 IEEE 802.3 extend TLV:
 MAC-Physic TLV                   YES       YES
 Power via MDI TLV                YES       YES
 Maximum Frame Size TLV           YES       YES
LLDP-MED extend TLV:
 Network Policy TLV               YES        YES
 Location Identification TLV      NO         NO
 Extended Power via MDI TLV       YES        YES
 Inventory TLV                    YES        YES
NAME                              STATUS    DEFAULT
Basic optional TLV:
 Port Description TLV             YES       NO
 System Name TLV                  YES       NO
 System Description TLV           YES       NO
 System Capabilities TLV          YES       NO
 Management Address TLV           YES       NO
 Port VLAN ID TLV                 YES       NO
 Port And Protocol VLAN ID TLV    YES       NO
 VLAN Name TLV                    YES       NO
 DCBX TLV                         NO        NO
 EVB TLV                          YES       YES
 Link Aggregation TLV             YES       NO
 Management VID TLV               NO        NO
 MAC-Physic TLV                   YES       NO
 Power via MDI TLV                YES       NO
 Maximum Frame Size TLV           YES       NO
 Network Policy TLV               YES        NO
 Extended Power via MDI TLV       YES        NO
 Inventory TLV                    YES        NO
NAME                              STATUS    DEFAULT
Basic optional TLV:
 DCBX TLV                         NO        NO
 EVB TLV                          NO        NO
Table 5 Command output
Advertisable optional TLVs of port 1.
NAME
TLV type.
STATUS
Indicates whether the type of TLV is sent through a port.
DEFAULT
Indicates whether the type of TLV is sent through a port by default.
Basic optional TLV
Basic optional TLVs:
·     Port description TLV.
·     System name TLV.
·     System description TLV.
·     System capabilities TLV.
·     Management address TLV.
IEEE 802.1 extended TLV
IEEE 802.1 organizationally specific TLVs:
·     Port VLAN ID TLV.
·     Port and protocol VLAN ID TLV.
·     VLAN name TLV.
·     DCBX TLV..
·     EVB TLV.
·     Management VID TLV.
·     Congestion notification TLV.
IEEE 802.3 extended TLV
IEEE 802.3 organizationally specific TLVs:
·     MAC-Physic TLV.
·     Power via MDI TLV.
·     Link aggregation TLV.
·     Maximum frame size TLV.
LLDP-MED extend TLV
LLDP-MED TLVs:
·     Capabilities TLV.
·     Network Policy TLV.
·     Extended Power-via-MDI TLV.
·     Location Identification TLV.
·     Inventory TLV.
Inventory TLV
Inventory TLVs:
·     Hardware Revision TLV.
·     Firmware Revision TLV.
·     Software Revision TLV.
·     Serial Number TLV.
·     Manufacturer Name TLV.
·     Model name TLV.
·     Asset ID TLV.
lldp admin-status
Use lldp admin-status to specify the LLDP operating mode.
Use undo lldp admin-status to restore the default.
In Layer 2/Layer 3 Ethernet interface view or management Ethernet interface view:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
In Layer 2/Layer 3 aggregate interface view:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
In IRF physical interface view:
lldp admin-status { disable | rx | tx | txrx }
The nearest bridge agent operates in txrx mode, and the nearest customer bridge agent and nearest non-TPMR bridge agent operate in disable mode.
Management Ethernet interface view
agent: Specifies an LLDP agent type. If no agent type is specified in Ethernet interface view, the command configures the operating mode for nearest bridge agents.
disable: Specifies the Disable mode. A port in this mode cannot send or receive LLDP frames.
rx: Specifies the Rx mode. A port in this mode can only receive LLDP frames.
tx: Specifies the Tx mode. A port in this mode can only send LLDP frames.
txrx: Specifies the TxRx mode. A port in this mode can send and receive LLDP frames.
# Configure the LLDP operating mode as Rx for the nearest customer bridge agents on FortyGigE 1/1/1.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] lldp agent nearest-customer admin-status rx
lldp check-change-interval
Use lldp check-change-interval to enable LLDP polling and set the polling interval.
Use undo lldp check-change-interval to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
lldp check-change-interval interval
agent: Specifies an LLDP agent type. If no agent type is specified in Ethernet interface view, the command enables LLDP polling and sets the polling interval for nearest bridge agents.
interval: Sets the LLDP polling interval in the range of 1 to 30 seconds.
# Enable LLDP polling and set the polling interval to 30 seconds for the nearest customer bridge agents on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] lldp agent nearest-customer check-change-interval 30
lldp compliance admin-status cdp
Use lldp compliance admin-status cdp to configure the operating mode of CDP-compatible LLDP.
Use undo lldp compliance admin-status cdp to restore the default.
lldp compliance admin-status cdp { disable | txrx }
CDP-compatible LLDP operates in disable mode.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, management Ethernet interface view
disable: Specifies the disable mode. CDP-compatible LLDP in this mode cannot receive or transmit CDP packets.
txrx: Specifies the TxRx mode. CDP-compatible LLDP in this mode can send and receive CDP packets.
For your device to work with Cisco IP phones, you must perform the following tasks:
·     Enable CDP-compatible LLDP globally.
·     Configure CDP-compatible LLDP to operate in TxRx mode on the specified ports.
# Enable CDP-compatible LLDP globally and configure CDP-compatible LLDP to operate in TxRx mode on FortyGigE 1/1/1.
[Sysname] lldp compliance cdp
[Sysname-FortyGigE1/1/1] lldp compliance admin-status cdp txrx
lldp compliance cdp
lldp compliance cdp
Use lldp compliance cdp to enable CDP compatibility globally.
Use undo lldp compliance cdp to restore the default.
lldp compliance cdp
CDP compatibility is globally disabled.
The maximum TTL that CDP allows is 255 seconds. To make CDP-compatible LLDP work correctly with Cisco IP phones, configure the LLDP frame transmission interval to be no more than 1/3 of the TTL value.
# Enable CDP compatibility globally.
·     lldp hold-multiplier
·     lldp timer tx-interval
lldp enable
Use lldp enable to enable LLDP on a port.
Use undo lldp enable to disable LLDP on a port.
lldp enable
undo lldp enable
LLDP is enabled on a port.
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
# Disable LLDP on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] undo lldp enable
lldp global enable
lldp encapsulation snap
Use lldp encapsulation snap to configure the encapsulation format for LLDP frames as SNAP.
Use undo lldp encapsulation to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
The encapsulation format for LLDP frames is Ethernet II.
agent: Specifies an LLDP agent type. If no agent type is specified in Ethernet interface view, the command configures the LLDP frame encapsulation format for nearest bridge agents.
LLDP-CDP packets use only SNAP encapsulation.
LLDP frames carrying the EVB module TLVs cannot be encapsulated in SNAP format.
# Configure the encapsulation format for LLDP frames as SNAP on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] lldp encapsulation snap
lldp fast-count
Use lldp fast-count to set the number of LLDP frames sent each time fast LLDP frame transmission is triggered.
Use undo lldp fast-count to restore the default.
lldp fast-count count
The number is 4.
count: Sets the number of LLDP frames sent each time fast LLDP frame transmission is triggered. The value range is 1 to 8.
# Configure the device to send five LLDP frames each time fast LLDP frame transmission is triggered.
[Sysname] lldp fast-count 5
lldp global enable
Use lldp global enable to enable LLDP globally.
Use undo lldp global enable to disable LLDP globally.
lldp global enable
If the switch starts up with empty configuration, LLDP is disabled globally (initial setting).
If the switch starts up with the default configuration file, LLDP is enabled globally (factory default).
For more information about empty configuration and the default configuration file, see Fundamentals Configuration Guide.
# Disable LLDP globally.
[Sysname] undo lldp global enable
lldp enable
Use lldp hold-multiplier to set the TTL multiplier.
Use undo lldp hold-multiplier to restore the default.
lldp hold-multiplier value
The TTL multiplier is 4.
value: Sets the TTL multiplier in the range of 2 to 10.
The TTL TLV carried in an LLDPDU determines how long the device information carried in the LLDPDU can be saved on a recipient device.
By setting the TTL multiplier, you can configure the TTL of locally sent LLDPDUs, which determines how long information about the local device can be saved on a neighboring device. The TTL is expressed by using the following formula:
TTL = Min (65535, (TTL multiplier × LLDP frame transmission interval + 1))
As the expression shows, the TTL can be up to 65535 seconds.
# Set the TTL multiplier to 6.
lldp ignore-pvid-inconsistency
Use lldp ignore-pvid-inconsistency to disable PVID inconsistency check.
Use undo lldp ignore-pvid-inconsistency to restore the default.
PVID inconsistency check is enabled.
By default, the device requires that the PVID for both ends of a link must be identical. If the PVID in a received packet is different from the local PVID, the device generates logs to inform you of PVID inconsistency.
You can disable PVID inconsistency check if different PVIDs are required on a link.
# Disable PVID inconsistency check.
[Sysname] lldp ignore-pvid-inconsistency
lldp management-address-format string
Use lldp management-address-format string to configure the encoding format of the management address as string.
Use undo lldp management-address-format to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
The encoding format of the management address is numeric.
agent: Specifies an LLDP agent type. If no agent type is specified in Ethernet interface view, the command configures the encoding format of the management address for nearest bridge agents.
LLDP neighbors must use the same encoding format for the management address.
# Configure the encoding format of the management address as string for the nearest customer bridge agents on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] lldp agent nearest-customer management-address-format string
lldp max-credit
Use lldp max-credit to set the token bucket size for sending LLDP frames.
Use undo lldp max-credit to restore the default.
lldp max-credit credit-value
The token bucket size for sending LLDP frames is 5.
credit-value: Specifies the token bucket size for sending LLDP frames, in the range of 1 to 100.
# Set the token bucket size for sending LLDP frames to 10.
[Sysname] lldp max-credit 10
lldp mode
Use lldp mode to configure LLDP to operate in service bridge mode.
Use undo lldp mode to restore the default.
lldp mode service-bridge
undo lldp mode
LLDP operates in customer bridge mode.
service-bridge: Specifies the service bridge mode.
The LLDP agent types supported by LLDP depend on the LLDP bridge mode:
·     Service bridge mode—LLDP supports nearest bridge agents and nearest non-TPMR bridge agents. LLDP processes the LLDP frames with destination MAC addresses for these agents and transparently transmits the LLDP frames with other destination MAC addresses in the VLAN.
·     Customer bridge mode—LLDP supports nearest bridge agents, nearest non-TPMR bridge agents, and nearest customer bridge agents. LLDP processes the LLDP frames with destination MAC addresses for these agents and transparently transmits the LLDP frames with other destination MAC addresses in the VLAN.
The bridge mode configuration takes effect only when LLDP is enabled globally. If LLDP is disabled globally, LLDP can only operate in customer bridge mode.
# Configure LLDP to operate in service bridge mode.
[Sysname] lldp mode service-bridge
lldp global enable
lldp notification med-topology-change enable
Use lldp notification med-topology-change enable to enable LLDP-MED trapping.
Use undo lldp notification med-topology-change enable to disable LLDP-MED trapping.
LLDP-MED trapping is disabled on ports.
# Enable LLDP-MED trapping for FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] lldp notification med-topology-change enable
lldp notification remote-change enable
Use lldp notification remote-change enable to enable LLDP trapping.
Use undo lldp notification remote-change enable to disable LLDP trapping.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP trapping is disabled on ports.
agent: Specifies an LLDP agent type. If no agent type is specified in Ethernet interface view, the command enables LLDP trapping for nearest bridge agents.
# Enable LLDP trapping for the nearest customer bridge agents on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] lldp agent nearest-customer notification remote-change enable
lldp timer fast-interval
Use lldp timer fast-interval to set the interval for fast LLDP frame transmission.
Use undo lldp timer fast-interval to restore the default.
The interval for fast LLDP frame transmission is 1 second.
interval: Sets an interval for fast LLDP frame transmission, in the range of 1 to 3600 seconds.
# Set the interval for fast LLDP frame transmission to 2 seconds.
[Sysname] lldp timer fast-interval 2
lldp timer notification-interval
Use lldp timer notification-interval to set the LLDP trap and LLDP-MED trap transmission interval.
Use undo lldp timer notification-interval to restore the default.
The LLDP trap and LLDP-MED trap transmission interval is 30 seconds.
interval: Sets the LLDP trap and LLDP-MED trap transmission interval in the range of 5 to 3600 seconds.
# Set both the LLDP trap and LLDP-MED trap transmission interval to 8 seconds.
lldp timer reinit-delay
Use lldp timer reinit-delay to set the LLDP reinitialization delay.
Use undo lldp timer reinit-delay to restore the default.
lldp timer reinit-delay delay
The LLDP reinitialization delay is 2 seconds.
delay: Sets the LLDP reinitialization delay in the range of 1 to 10 seconds.
# Set the LLDP reinitialization delay to 4 seconds.
Use lldp timer tx-interval to set the LLDP frame transmission interval.
Use undo lldp timer tx-interval to restore the default.
The LLDP frame transmission interval is 30 seconds.
interval: Sets the LLDP frame transmission interval in the range of 5 to 32768 seconds.
# Set the LLDP frame transmission interval to 20 seconds.
lldp tlv-enable
Use lldp tlv-enable to configure the types of advertisable TLVs.
Use undo lldp tlv-enable to disable the advertising of the specified types of TLVs.
In Layer 2 Ethernet interface view:
·     For nearest bridge agents:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation | dcbx | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation | dcbx | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy | power-over-ethernet | location-id } }
·     For nearest non-TPMR bridge agents:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | congestion-notification | evb | port-vlan-id | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | congestion-notification | evb | port-vlan-id | link-aggregation } }
·     For nearest customer bridge agents:
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation } }
In Layer 3 Ethernet interface view or management Ethernet interface view:
·     lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
·     lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } }
·     undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
·     undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } }
In Layer 2 aggregate interface view:
·     lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | evb | port-vlan-id } }
·     lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
·     lldp tlv-enable dot1-tlv { protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] }
·     undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | evb | port-vlan-id } }
·     undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
·     undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
In Layer 3 aggregate interface view:
·     lldp agent { nearest-nontpmr | nearest-customer } tlv-enable basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name }
·     undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name }
·     lldp tlv-enable basic-tlv { port-description | system-capability | system-description | system-name }
·     undo lldp tlv-enable basic-tlv { port-description | system-capability | system-description | system-name }
On Layer 2 Ethernet interfaces:
·     Nearest bridge agents can advertise all types of LLDP TLVs except the following types:
¡     DCBX TLVs.
¡     Location identification TLVs.
¡     Port and protocol VLAN ID TLVs.
¡     VLAN name TLVs.
¡     Management VLAN ID TLVs.
·     Nearest non-TPMR bridge agents can advertise only EVB TLVs.
·     Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs.
On Layer 3 Ethernet interfaces or the management Ethernet interface:
·     Nearest bridge agents can advertise all types of LLDP TLVs (only link aggregation TLV in 802.1 organizationally specific TLVs) except network policy TLVs.
·     Nearest non-TPMR bridge agents advertise no TLVs.
·     Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs (only link aggregation TLV).
On Layer 2 aggregate interfaces:
·     Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs (only port and protocol VLAN ID TLV, VLAN name TLV, and management VLAN ID TLV).
On Layer 3 aggregate interfaces:
·     Nearest customer bridge agents can advertise only basic TLVs.
On IRF physical interfaces, an agent can advertise all supported TLVs.
agent: Specifies an LLDP agent type. If no agent type is specified in Ethernet interface view, the command configures the types of advertisable TLVs for nearest bridge agents.
all: Advertises all TLVs of the specified type.
·     Enables the interface to advertise the following TLVs:
¡     All basic LLDP TLVs if the all keyword is specified for basic-tlv.
¡     All IEEE 802.1 organizationally specific LLDP TLVs if the all keyword is specified for dot1-tlv.
¡     All IEEE 802.3 organizationally specific LLDP TLVs if the all keyword is specified for dot3-tlv.
·     Enables the interface to advertise all LLDP-MED TLVs except location identification TLVs if the all keyword is specified for med-tlv.
basic-tlv: Advertises basic LLDP TLVs.
management-address-tlv [ ip-address ]: Advertises management address TLVs. ip-address specifies the management address to be advertised. By default:
·     For a Layer 2 Ethernet or aggregate interface, the management address is the primary IP address of the VLAN interface meeting the following requirements:
¡     In up state.
¡     The corresponding VLAN ID is the lowest among the VLANs permitted on the port.
If none of the VLAN interfaces of the permitted VLANs is assigned an IP address or all VLAN interfaces are down, the MAC address of the port will be advertised.
·     For a Layer 3 Ethernet interface, management Ethernet interface, or Layer 3 aggregate interface, the management address is its own IP address. If no IP address is configured for the Layer 3 Ethernet interface, management Ethernet interface, or Layer 3 aggregate interface, the MAC address of the port will be advertised.
When you execute the undo command:
·     If you specify the ip-address argument, the command disable the advertisement of the specified IP addresses.
·     If you do not specify the ip-address argument, the command disable the advertisement of management address TLVs.
port-description: Advertises port description TLVs.
system-capability: Advertises system capabilities TLVs.
system-description: Advertises system description TLVs.
system-name: Advertises system name TLVs.
dot1-tlv: Advertises IEEE 802.1 organizationally specific LLDP TLVs.
congestion-notification: Advertises the QCN module TLV. The device does not support QCN.
dcbx: Advertises the DCBX TLV.
evb: Advertises the EVB module TLVs.
port-vlan-id: Advertises port VLAN ID TLVs.
protocol-vlan-id [ vlan-id ]: Advertises port and protocol VLAN ID TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised. The VLAN ID is in the range of 1 to 4094, and the default is the lowest VLAN ID on the port.
vlan-name [ vlan-id ]: Advertises VLAN name TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised. The VLAN ID is in the range of 1 to 4094, and the default is the lowest VLAN ID on the port.
management-vid [ mvlan-id ]: Advertises the management VLAN ID TLV. The mvlan-id argument specifies a management VLAN ID in the TLVs to be advertised. The management VLAN ID is in the range of 1 to 4094. If no management VLAN ID is specified, the value 0 is advertised, which means that the LLDP agent is not configured with a management VLAN ID.
dot3-tlv: Advertises IEEE 802.3 organizationally specific LLDP TLVs.
link-aggregation: Advertises link aggregation TLVs.
mac-physic: Advertises MAC/PHY configuration/status TLVs.
max-frame-size: Advertises maximum frame size TLVs.
power: Advertises power in MDI TLVs and power stateful control TLVs.
med-tlv: Advertises LLDP-MED TLVs.
capability: Advertises LLDP-MED capabilities TLVs.
inventory: Advertises the following TLVs: hardware revision, firmware revision, software revision, serial number, manufacturer name, model name, and asset ID.
location-id: Advertises location identification TLVs.
civic-address: Inserts the typical address information about the network device in location identification TLVs .
device-type: Sets a device type value in the range of 0 to 2:
·     Value 0 specifies a DHCP server.
·     Value 1 specifies a switch.
·     Value 2 specifies an LLDP-MED endpoint.
country-code: Sets a country code defined in ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information. ca-type represents the address information type in the range of 0 to 255. ca-value represents address information, a string of 1 to 250 characters. &<1-10> indicates that you can specify up to 10 ca-type ca-value pairs.
elin-address: Inserts telephone numbers for emergencies in location identification TLVs.
tel-number: Sets the telephone number for emergencies, a string of 10 to 25 characters.
network-policy [ vlan-id ]: Advertises network policy TLVs. The vlan-id argument specifies the voice VLAN ID sent to voice terminals, in the range of 1 to 4094. If you do not specify this argument, the command advertises information about the VLAN assigned by the authentication server or the voice VLAN ID configured on the interface. For more information, see "Configuring VLANs."
power-over-ethernet: Advertises extended power-via-MDI TLVs.
Nearest bridge agents are not supported on aggregate interfaces.
You can enable the device to advertise multiple types of TLVs by using this command without the all keyword specified.
If the MAC/PHY configuration/status TLV is not advertisable, none of the LLDP-MED TLVs will be advertised whether they are advertisable. If the LLDP-MED capabilities TLV is not advertisable, the other LLDP-MED TLVs will not be advertised regardless of whether they are advertisable.
The port and protocol VLAN ID TLV, VLAN name TLV, and management VLAN ID TLV in IEEE 802.1 organizationally specific LLDP TLVs can be configured only for nearest bridge agents. The configuration can be inherited by nearest customer bridge agents and nearest non-TPMR bridge agents.
# Enable the nearest customer bridge agents on FortyGigE 1/1/1 to advertise link aggregation TLVs of the IEEE 802.1 organizationally specific TLVs on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
