03 Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10003 Layer 2 - LAN Switching Command Reference
14-Service loopback group commands
14-Service loopback group commands 59.67 KB
display service-loopback group
Use display service-loopback group to display information about service loopback groups.
display service-loopback group [ number ]
number: Specifies a service loopback group ID. The value range for the number argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Service Group ID: 5       Service Type: Tunnel
Member:
 FortyGigE1/1/1
 FortyGigE1/1/2
Service Group ID
Service loopback group ID.
Service Type
Service type of the service loopback group:
·     Multicast-tunnel—Supports multicast tunnel traffic.
·     Tunnel—Supports unicast tunnel traffic.
·     Multiport—Supports multiport ARP traffic.
Member
Member ports of the service loopback group.
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group number
A service loopback group does not contain ports.
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
You can assign a maximum of 32 ports to a service loopback group. A port can belong to only one service loopback group.
When you assign a port to a service loopback group, the system removes the configuration on the port. For correct traffic processing, make sure the service loopback group has a minimum of one member port when it is being used by a feature.
# Assign FortyGigE 1/1/1 to service loopback group 5.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group number type { { multicast-tunnel | tunnel } *| multiport }
undo service-loopback group number
number: Specifies a service loopback group ID in the range of 1 to 1024.
type: Specifies the service type of the service loopback group.
multicast-tunnel: Specifies the multicast tunnel service.
tunnel: Specifies the unicast tunnel service.
multiport: Specifies the multiport ARP service.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
You must create the service loopback group before you can use it with a feature.
You can configure only one service loopback group for a service type. You cannot change the service type of the service loopback group.
For correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify the unicast tunnel service for the group.
[Sysname] service-loopback group 5 type tunnel
