H3C S3600 Operation Manual-Release 1602(V1.02)
HomeSupportSwitchesH3C S3600 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3600 Operation Manual-Release 1602(V1.02)
00-2Product Overview
00-2Product Overview 205.29 KB
Hangzhou H3C Technologies Co., Ltd. (hereafter referred to as H3C) provides various ways for you to obtain product documents and new feature releases in a convenient and timely manner. The documentations are available with:
l          CD-ROMs shipped with the devices
l          H3C website
l          Software release notes
CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete set of electronic documents of the product, including operation manuals and command manuals. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
H3C Website
Perform the following steps to query and download the product documentation from the H3C website.
Table 1-1 Acquire product documentation from the H3C website
How to apply for an account
Access the homepage of H3C at http:// www.h3c.com and click the Registration link at the top right. In the displayed page, provide your information and click Submit.
How to get documentation
Approach 1:
In the homepage of H3C at http:// www.h3c.com, select Technical Support & Document > Technical Documents from the navigation menu at the top. Then select a product for its documents.
Approach 2:
In the homepage of H3C at http:// www.h3c.com, select Support > Technical Documents. Then select a product for its documents.
Software Release Notes
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Software Version
H3C S3600 Series Ethernet Switches Operation Manual-Release 1602 and H3C S3600 Series Ethernet Switches Command Manual-Release 1602 are for the software version of Release1602 of the S3600 series products.
l          Compared with Release 1510, many new features are added in Release 1602. For details, refer to Table 2-1.
l          Compared with Release 1510, a feature is removed from Release 1602. For details, refer to Table 2-2.
l          Compared with Release 1510, three features are modified in Release 1602. For details, refer to Table 2-3.
Table 2-1 Added features in Release 1602
Added feature in Release 1602
Manual
Specifying the authentication mode for user level switching
01-CLI
Adopting HWTACACS authentication for user level switching
Copyright information is displayed when a Telnet user logs in
02-Login
Banner information is displayed when a user logs in through Web
Auto-negotiation rate configuration for the current port
08-Port Basic Configuration
The port up/down log output function is removed
Packet traffic threshold configuration for ports
Display of the statistics of discarded packets on ports
Configuration of the delay time of sending state-change traps for the current port
Inter-device port isolation
10-Port Isolation
New port security modes: macAddressAndUserLoginSecure and macAddressAndUserLoginSecureExt
11-Port Security-Port Binding
Destination MAC address update
13-MAC Address Table Management
Configuring the MAC address of an Ethernet port
STP maintainability
15-MSTP
802.1d-compliant traps
Configuration of the Type-7 LSAs converter features in an NSSA zone
16-Routing Protocol
Support of unicasting protocol messages in a P2MP network
Multicast data packet cache mechanism
17-Multicast Protocol
Support of multicast source lifetime configuration
Support of IGMPv3 Snooping
Support of IGMPv3 Snooping simulated joining
Support of suppressing flooding of unknown multicast traffic in the VLAN
Support of static member port configuration
Support of static router port configuration
Support of VLAN tag configuration for query messages
Online user handshake
18-802.1x and System-Guard
Support of 802.1x re-authentication configuration
Support of 802.1x re-authentication timeout configuration
Quick deployment of EAD
Support of domain delimiter configuration
19-AAA
Support of HWTACACS scheme configuration for ISP domain user level switching
Setting of MAC address format of the Calling-Station-Id (Type 31) field in RADIUS packets
Web authentication
20-Web Authentication
Support of fixed password configuration when a MAC address is used as a user name
21-MAC Address Authentication
Enhanced MAC authentication functions
Display of detailed backup group information
22-VRRP
ARP attack detection
23-ARP
ARP packet rate limiting
Support of sending gratuitous ARP packets periodically
Proxy ARP
Configuration of the TFTP server address and bootfile name for DHCP clients that support auto-configuration
24-DHCP
Support of Option 82 in DHCP Snooping
IP filtering
DHCP packet rate limiting
Applying ACLs to VLANs
25-ACL
Configuration of inner VLAN information for Layer 2 ACLs
VLAN mapping
26-QoS-QoS Profile
Configuration of burst traffic for port rate limiting and traffic policing
Configuration of priority remarking in VLANs
Redirecting traffic to an aggregation port group and removing the outer VLAN tag after the traffic is redirected to the uplink port or the aggregation port group
Burst function
Configuration of IRF automatic fabric
29-IRF Fabric
Online upgrade of PSE processing software
31-PoE-PoE Profile
Creating a MIB view with the mask of a MIB subtree
33-SNMP-RMON
Encrypting a plain-text password
Adding interface description and interface type in linkUp/linkDown Trap message
Support of the DSA asymmetric key algorithm
35-SSH
Banner information of the FTP server
37-FTP-SFTP-TFTP
Displaying timestamp with the UTC time zone
38-Information Center
Configuration of real-time monitoring of system running status
39-System Maintenance and Debugging
Hot patching
Viewing and diagnosing hot-pluggable transceivers
Selective QinQ
40-VLAN-VPN
Support of multiple types of protocol packets for BPDU Tunneling
Customizing tunnel packet MAC addresses
Eight test types are added in HWPing, including DHCP test, FTP test, HTTP test, DNS test, SNMP test, Jitter test, TCP test, and UDP test
41-HWping
Maximum number of history records that can be saved
IPv6 management
42-IPv6 Management
Smart Link
44-Smart Link-Monitor Link
Monitor Link
Table 2-2 Deleted feature from Release 1602
Deleted feature
Manual
CLI language mode setting
Table 2-3 Modified features in Release 1602
Modified feature
Manual
Support of up to 128 characters in a domain name, compared with the original 24 characters
19-AAA
Sequence of selecting Web files
36-File System Management
Keywords of five commands
22-VRRP
Manual List
Manual name
H3C S3600 Series Ethernet Switches Installation Manual
Preface
H3C S3600 Series Ethernet Switches are Ethernet equipment capable of multilayer switching. They come in two series: S3600-SI and S3600-EI. In addition to the basic service features, S3600 Series Ethernet switches support abundant Layer 3 features and enhanced extended functions.
l          S3600-SI series switches support basic routing functions, DHCP, basic IRF functions and IGMP-Snooping.
l          S3600-EI series switches support advanced routing functions, DHCP, enhanced IRF functions, and enhanced multicast functions (including PIM-DM and PIM-SM).
Switch Models
Table 3-1 lists the S3600 series Ethernet Switches models.
Table 3-1 Models in the S3600 series
Model
Power supply unit (PSU)
Number of service ports
Number of 100 Mbps ports
Number of 1,000 Mbps uplink ports
Console port
H3C S3600-28P-SI
AC-input
28
24 10/100 Mbps ports (electrical)
4 Gigabit (SFP) ports
1
H3C S3600-28P-PWR-SI
AC-/DC-input
28
1
H3C S3600-28TP-SI
AC-input
28
24 10/100 Mbps (electrical)
2 Gigabit (SFP) ports
2 x 10/100/1,000 Mbps ports (electrical)
1
H3C S3600-52P-SI
AC-input
52
48 10/100 Mbps (electrical)
1
H3C S3600-28P-EI
AC-/DC-input
28
1
H3C S3600-28F-EI
AC-/DC-input
28
24 100 Mbps (SFP) ports
2 10/100/1,000 Mbps ports (electrical)
1
H3C S3600-28P-PWR-EI
AC-/DC-input
28
1
H3C S3600-52P-EI
AC-/DC-input
52
48 10/100 Mbps ports (electrical)
4 Gigabit ports (SFP)
1
H3C S3600-52P-PWR-EI
AC-/DC-input
52
1
H3C S3600-52P-PWR-SI
AC-/DC-input
52
1
Software Features
S3600 Series Ethernet Switches have abundant software features and can meet the requirements of different applications. Table 3-2 summarizes the features provided by each module.
Table 3-2 Service features of the S3600 series
Part
Features
1 CLI
l      CLI
l      Hierarchically grouped commands
l      CLI online help
2 Login
l      Logging into a switch through the Console port
l      Logging into a switch through an Ethernet port by using Telnet or SSH
l      Logging into a switch through the Console port by using modem
l      Logging into a switch through Web or NMS
l      Controlling user login using ACL
3 Configuration File Management
l      Saving, restoring, and deleting the configuration file
4 VLAN
l      IEEE 802.1Q-compliant VLAN
l      Port-based VLAN
l      Protocol-based VLAN
5 IP Address and Performance Configuration
l      Configuring an IP address for a switch
l      Configuring the TCP attributes for a switch
l      Enabling/disabling the switch to receive directed broadcasts
l      Enabling/disabling the switch to send ICMP error messages
6 Voice VLAN
l      Voice VLAN
7 GVRP
l      GARP VLAN registration protocol (GVRP)
8 Port Basic Configuration
l      Configuring port auto-negotiation rate
l      Limiting traffic on a port
l      Setting broadcast storm suppression globally
l      Loopback detection supported
l      Cable test
9 Link Aggregation
l      Link aggregation control protocol (LACP)
10 Port Isolation
l      Port isolation group
11 Port Security-Port Binding
l      Multiple security modes
l      MAC address-to-IP address-to-port binding
12 DLDP
l      Device link detection protocol (DLDP)
13 MAC Address Table
l      Manually configuring dynamic, static, and black hole MAC addresses
l      Configuring the aging time for MAC addresses
l      MAC address learning limit
14 Auto Detect
l      Auto detect
l      Auto detect applications in static routing, VRRP, and VLAN interface backup (only S3600-EI supports auto detect in VRRP)
15 MSTP
l      STP/RSTP/MSTP
l      The following guard functions are available on an MSTP-enabled switch: BPDU guard, root guard, loop guard, TC-BPDU attack guard, and BPDU drop
l      Digest snooping
l      Rapid transition
l      VLAN-VPN TUNNEL
l       H3C-proprietary MSTP path cost standard
16 Routing Protocols.
l      Static route
l      Routing information protocol (RIP) v1/v2
l      Open shortest path first (OSPF) (S3600-EI series switches only)
l      Routing policy
l      Route capacity limiting (S3600-EI series switches only)
17 Multicast
l      Internet group management protocol snooping (IGMP Snooping)
l      Internet group management protocol (IGMP) (S3600-EI series switches only)
l      Protocol-independent multicast-dense mode (PIM-DM) (S3600-EI series switches only)
l      Protocol-independent multicast-sparse mode (PIM-SM) (S3600-EI series switches only)
l      MSDP (S3600-EI series switches only)
18 802.1x and System Guard
l      802.1X authentication
l      Guest VLAN
l      Quick deployment of EAD
l      Huawei authentication bypass protocol (HABP)
l      System guard
19 AAA
l      Authentication, authorization, and accounting (AAA)
l      Remote authentication dial-In user service (RADIUS)
l      Huawei terminal access controller access control system (HWTACACS)
l      Endpoint admission defense (EAD)
20 Web Authentication
l      Web authentication
21 MAC Address Authentication
l      MAC address authentication
l      Enhanced MAC address authentication
22 VRRP
l      Virtual router redundancy protocol (VRRP) (S3600-EI series switches only)
23 ARP
l      Gratuitous ARP
l      Sending gratuitous ARP packets periodically
l      Manually configuring ARP entries
l      ARP attack detection
l      ARP packet rate limiting
l      Proxy ARP
l      Resilient ARP
24 DHCP
l      DHCP client/BOOTP client
l      DHCP server (S3600-EI series switches only)
l      DHCP relay
l      DHCP Snooping
l      DHCP accounting
l      Using Option184 in DHCP server (S3600-EI series switches only)
l      Using Option82 in DHCP relay and DHCP Snooping
l      DHCP packet rate limitation
25 ACL
l      Basic ACLs
l      Advanced ACLs
l      Layer 2 ACLs
l      User-defined ACLs
l      Applying ACLs on ports
l      Applying ACLs to VLANs
26 QoS-QoS Profile
l      Quality of Service (QoS)
l      QoS profile
27 Web Cache Redirection
l      (Supported by S3600-EI series only)
28 Mirroring
l      Traffic mirroring
l      Local port mirroring
l      Remote port mirroring (S3600-EI series switches only)
29 IRF Fabric
l      IRF Fabric
l      Stack port optional
l      Peer end detection for stack ports
30 Cluster
l      Huawei group management protocol (HGMP) v2
l      Neighbor discovery protocol (NDP)
l      Neighbor topology discovery protocol (NTDP)
31 PoE-PoE Profile
l      Power over Ethernet (PoE)
l       PoE profile
32 UDP Helper
l      Forwarding UDP broadcast packets by using UDP Helper
33 SNMP-RMON
l      Simple network management protocol (SNMP) v3, compatible with SNMP v1/v2
l      Support of Trap parameters configuration
l      Remote monitoring (RMON)
34 NTP
l      Network time protocol (NTP)
35 SSH Terminal Service
Secure shell (SSH) v2.0, compatible with SSHv1.5
36 File System Management
l      File system configuration
l      File attribute configuration
l      Configuration file backup and restoration
37 FTP-SFTP-TFTP
l      Operating as an FTP server/FTP client
l      Operating as an SFTP server/SFTP client
l      Operating as a TFTP client
38 Information Center
l      System logs
l      Hierarchical alarms
l      Debugging information output
39 System Maintenance and Debugging
l      Loading Boot ROM and software in multiple ways
l      Basic system configuration and debugging
l      Network connectivity test
l      Device management
40 VLAN-VPN
l      VLAN VPN (QinQ)
l      Selective QinQ
l      BPDU Tunnel
l      Configuring VLAN VPN interior-layer priority replication
l      Configuring TPID value
41 HWPing
l      Operating as a HWPing server/HWPing client
l      Nine test types, including ICMP test, DHCP test, FTP test, HTTP test, DNS test, SNMP test, jitter test, TCP test, and UDP test
42 IPv6 Management
l      IPv6 management
l      IPv6 static route
l      IPv6 DNS
43 DNS
l      IPv4 Domain Name System (DNS)
44 Smart Link-Monitor Link
l      Smart Link
l      Monitor Link
45 Access Management
Configuring the access IP address pool based on the physical port
You can deploy S3600 series on many types of networks, such as enterprise networks and broadband access networks. Following are several typical networking applications.
Broadband Ethernet Access for Residential Communities
On the broadband access network of a residential community, an S3600 series switch is located in the center. It is downlinked to S3100 series switches to reach the Ethernet users and uplinked to a core Layer 3 switch through a GE extension module to connect to the MAN backbone.
Figure 4-1 Connecting community Ethernet to MAN using S3600 series
Application for Connecting Branches or Small- to Medium-Sized Enterprises
For small-to medium-sized enterprises or branches of a large enterprise, S3600 series switches can server as the backbone switches on their networks and can be connected to the headquarters or other branches through routers. As the enterprise size increases, the network also can expand by subtending the S3600 series.
Figure 4-2 S3600 series switches application in branch network of midsize/large enterprise
Application in Large Enterprise and Campus Networks
In a large enterprise or campus network, the S3600 series switches can operate on the convergence layer. They are downlinked to layer 2 switches, S3100 Series for example; and uplinked to a layer 3 switch through GE expansion modules. These switches together provide a network-wide intranet solution that covers Gigabit-to-backbone and 100 Mbps-to-desktop.
Figure 4-3 S3600 series application in large enterprise and campus network
