H3C S9500 Operation Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesH3C S9500 Series SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-07 Security Volume
09-Traffic Accounting Configuration
09-Traffic Accounting Configuration 77.4 KB
Chapter 1  Traffic Accounting Configuration
&  Note:
The traffic accounting board referred in this chapter is Netstream service processing board (that is, LSB1NAMB0).
When performing traffic accounting configuration, go to these sections for information you are interested in:
l           Traffic Accounting Introduction
l           Configuring Traffic Accounting
l           Displaying and Maintaining Traffic Accounting
l           Traffic Accounting Configuration Example
1.1  Traffic Accounting Introduction
Some accounting servers, such as CAMS, can perform the accounting on the users who have passed the 802.1X or Portal authentication by time or traffic. Traffic accounting is to account the traffic generated by the authenticated online users in their switches, and send the traffic accounting statistics to the accounting servers to charge the internet users.
1.1.1  Related Concepts of Traffic Accounting
l           Traffic group: a mechanism to classify the object network by accounting attributes. The accounting attributes of a traffic group include charge/no charge and charge rate.
l           Accounting address of traffic group: some network segment addresses are configured in the traffic group to account the traffic of the destination address in these network segment addresses.
l           Traffic collection ports: ports that connect internet users or external networks. The traffic of accessing to external networks passes in and out through these ports.
l           Traffic accounting board: the board which provides analysis, calculation and statistics of the traffic.
l           Traffic collection: a process of sending the traffic which passes the traffic collection port to the traffic accounting board by setting port mirror.
l           Traffic statistics: a process of the traffic accounting board analyzing and calculating the traffic collected from the traffic collection ports. Traffic statistics bases on the internet users’ IP addresses and the traffic group which the accessed network belongs to.
1.1.2  Implementation Process of the Traffic Accounting
The implementation of traffic accounting is shown in Figure 1-1 in the H3C S9500 series switches.
Figure 1-1 Implementation process of the traffic accounting
Detailed implementation procedure:
1)         The user uses 802.1X or PORTAL authentication client to access to the network.
2)         The equipment acquires the user name and password and requests authentication from CAMS. The equipment and CAMS use the Radius protocol to communicate.
3)         Authentication succeeds. The equipment acquires the IP address and MAC address for the user to access to the network.
4)         The user normally accesses to the network and traffic is generated.
5)         The port of the switch collects the traffic and mirrors the traffic to the traffic accounting board.
6)         Traffic accounting board is in charge of the traffic statistics.
7)         The main control board collects the user’s traffic from the traffic accounting board periodically.
8)         The switch sends the updated message which carries the acquired user’s traffic to CAMS periodically. The traffic is accumulated.
9)         The user requests to be offline.
10)     The main control board collects the user’s traffic for the last time.
11)     The switch sends an accounting finish message which carries all the user’s traffic information this time.
12)     The user is offline and this process of accessing to the network is over.
1.2  Configuring Traffic Accounting
1.2.1  Prerequisites
l           Traffic accounting board is plugged into the switch.
l           802.1X or Portal is enabled in the switch.
l           CAMS server finishes the configuration.
&  Note:
This article is to introduce the configuration of traffic statistics. The configuration of 802.1X or Portal or CAMS server is not covered here.
1.2.2  Configuring Traffic Accounting
Follow these steps to configure traffic accounting:
To do…
Use the command…
Remarks
Enter system view
Configure the port mirror group of traffic collection
mirroring-group groupid { inbound | outbound } mirroring-port-list mirrored-to monitor-port
Required
Refer to QoS Commands in the QoS ACL Volume for more information.
Configure the slot for traffic statistics
traffic-accounting accounting-slot slot-num
Required
l      Specify the traffic accounting slot where the traffic accounting board resides in.
l      Enter traffic statistics view automatically after successful configuration.
Enable the traffic statistics function
accounting enable
Required
This command is configured in the traffic statistic view.
Configure the traffic group
traffic-accounting traffic-group group-name
Required
Enter traffic group view automatically after successful configuration.
Display the configured traffic group information
display traffic-accounting traffic-group [ group-name ]
Optional
Configure the traffic group address
network ip-address { mask | masklen }
Required
This command is configured in the traffic group view.
Enter ISP domain view
domain domain-name
Specify the accounting mode as traffic accounting
accounting-mode traffic
Required
Configure the domain-applied traffic group
traffic-group group-name rate idnum
Required
&  Note:
l      There are two choices for traffic collection port. One is to choose the port on the network’s side as the traffic collection port. The other is to choose the port on the user's side as the traffic collection port. Ports on the network’s side are the ports connecting the Internet. The advantage of choosing ports on the network’s side as the traffic collection ports is that the mirrored streams are all for accounting, and include no internal traffic. But these ports do not support NAT. Ports on the user’s side are the ports connecting the users. They support NAT but process limited traffic for there are too many ports. Choose one kind of the ports according to the actual demands. Do not use the two kinds of ports simultaneously.
l      Configure both of the inbound and outbound mirrors when configuring the traffic collection port.
l      Only support single rate currently. Multi-rate is not supported at the moment.
1.3  Displaying and Maintaining Traffic Accounting
To do…
Use the command…
Display the information of traffic group
Display the configuration information of traffic statistics
display traffic-accounting accounting-slot [ slot-num ]
Display the traffic statistics of the current online users
display traffic-accounting statistics [ ip-address ]
1.4  Traffic Accounting Configuration Example
I. Network requirements
l           The user accesses to the network by a switch and uses 802.1X or Portal authentication client. The user can access to the external network after passing the authentication. The accounting mode is traffic accounting. When the user accesses to network segment 11.127.1.0/24 and 12.127.1.0/24, accounting server CAMS charges the user according to his network traffic. When the user accesses to other network segment, CAMS does not accounts.
l           Perform traffic collection on the user’s side.
II. Network diagram
Figure 1-2  Network diagram for traffic accounting configuration
III. Configuration procedure.
# Configure the traffic accounting group somegroup.
<H3C> system-view
[H3C] traffic-accounting traffic-group somegroup
# Configure the destination network segment address of the traffic accounting group.
[H3C-traffic-group-somegroup] network 11.127.1.0 24
[H3C-traffic-group-somegroup] network 12.127.1.0 24
# Configure the domain aaa for traffic accounting users, set the accounting mode as traffic accounting, and specify the traffic accounting group to be used.
[H3C] domain aaa
[H3C-isp-aaa] accounting-mode traffic
[H3C-isp-aaa] traffic-group somegroup rate 1
# Configure the traffic collection port, and mirror the traffic collection port to the traffic accounting board.
[H3C] mirroring-group 1 inbound Ethernet 2/1/1 mirrored-to slot 3
[H3C] mirroring-group 2 outbound Ethernet 2/1/1 mirrored-to slot 3
# Configure the traffic accounting board to enable the traffic accounting function.
[H3C] traffic-accounting accounting-slot 3
[H3C-accounting-slot-3] accounting enable
