H3C S9500 Operation Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesH3C S9500 Series SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-07 Security Volume
03-AAA RADIUS HWTACACS Configuration
03-AAA RADIUS HWTACACS Configuration 370.66 KB
Table of Contents
Chapter 1 AAA, RADIUS and HWTACACS Protocol Configuration. 1-1
1.1 AAA, RADIUS and HWTACACS Protocol Overview. 1-1
1.1.1 AAA Overview. 1-1
1.1.2 RADIUS Protocol Overview. 1-1
1.1.3 HWTACACS Protocol Overview. 1-3
1.1.4 Implementing AAA/RADIUS on a Switch. 1-5
1.2 AAA Configuration. 1-6
1.2.1 Creating/Deleting an ISP Domain. 1-6
1.2.2 Configuring Relevant Attributes of an ISP Domain. 1-7
1.2.3 Configuring Self-Service Server URL. 1-9
1.2.4 Creating/Deleting a Local User 1-9
1.2.5 Setting the Attributes of a Local User 1-10
1.2.6 Disconnecting a User by Force. 1-12
1.2.7 Configuring Dynamic VLAN Delivering. 1-12
1.3 RADIUS Protocol Configuration. 1-14
1.3.1 Creating/Deleting a RADIUS scheme. 1-15
1.3.2 Setting IP Address and Port Number of a RADIUS Server 1-15
1.3.3 Setting the RADIUS Packet Encryption Key. 1-17
1.3.4 Configuring VPN of RADIUS Server 1-18
1.3.5 Setting the Port State of the Local RADIUS Server 1-18
1.3.6 Setting the Maximum Retry Times for RADIUS Request Packets. 1-19
1.3.7 Setting RADIUS Server Response Timeout Timer 1-19
1.3.8 Setting Quiet Time of RADIUS Server 1-20
1.3.9 Setting the Retransmission Times of RADIUS Request Packets. 1-20
1.3.10 Enabling the Selection of Radius Accounting Option. 1-21
1.3.11 Setting a Real-time Accounting Interval 1-21
1.3.12 Setting the Maximum Times of Real-time Accounting Request Failing to be Responded  1-22
1.3.13 Enabling/Disabling Stop-Accounting Request Buffer 1-22
1.3.14 Setting the Maximum Retransmitting Times of Stop-Accounting Request 1-23
1.3.15 Setting the Supported Type of RADIUS Server 1-23
1.3.16 Setting RADIUS Server State. 1-24
1.3.17 Setting the Username Format Transmitted to RADIUS Server 1-24
1.3.18 Setting the Unit of Data Flow that Transmitted to RADIUS Server 1-25
1.3.19 Configuring the Source Address Used by NAS in RADIUS Packets. 1-25
1.3.20 Setting the Port State of RADIUS Client 1-26
1.3.21 Specifying the Security Policy Servers. 1-27
1.3.22 Configuring a Local RADIUS Authentication Server 1-27
1.4 HWTACACS Protocol Configuration. 1-28
1.4.1 Creating a HWTACACS Scheme. 1-29
1.4.2 Configuring HWTACACS Authentication Servers. 1-29
1.4.3 Configuring HWTACACS Authorization Servers. 1-30
1.4.4 Configuring HWTACACS Accounting Servers and the Related Attributes. 1-30
1.4.5 Configuring the Source Address for HWTACACS Packets Sent by NAS. 1-31
1.4.6 Setting a Key for Securing the Communication with TACACS Server 1-32
1.4.7 Setting the Username Format Acceptable to the TACACS Server 1-32
1.4.8 Setting the Unit of Data Flows Destined for the TACACS Server 1-33
1.4.9 Setting Timers Regarding TACACS Server 1-33
1.5 Displaying and Maintaining AAA and RADIUS Protocol 1-34
1.6 AAA, RADIUS, and HWTACACS Protocol Configuration Examples. 1-36
1.6.1 Configuring Authentication at Remote RADIUS Server 1-37
1.6.2 Configuring Authentication at Local RADIUS Authentication Server 1-38
1.6.3 Configuring Authentication at Remote TACACS Server 1-39
1.7 Troubleshooting AAA, RADIUS, and HWTACACS. 1-40
When configuring AAA, RADIUS and HWTACACS, go to these sections for information you are interested in:
l           AAA, RADIUS and HWTACACS Protocol Overview
l           AAA Configuration
l           RADIUS Protocol Configuration
l           HWTACACS Protocol Configuration
l           Displaying and Maintaining AAA and RADIUS Protocol
l           AAA, RADIUS, and HWTACACS Protocol Configuration Examples
l           Troubleshooting AAA, RADIUS, and HWTACACS
1.1.1  AAA Overview
Authentication, Authorization and Accounting (AAA) provide a uniform framework used for configuring these three security functions to implement the network security management.
The network security mentioned here refers to access control and it includes:
l           Which user can access the network servers?
l           Which services can the authorized user enjoy?
l           How to charge the user who is using network resources?
Accordingly, AAA shall provide the following services:
l           Authentication: authenticates if the user can access the network server.
l           Authorization: authorizes the user with specified services.
l           Accounting: traces network resources consumed by the user.
Generally, AAA adopts Client/Server architecture, with its client running at the managed side and its server centralizes and stores the user information. Therefore AAA framework takes good scalability, and is easy to realize the control and centralized management of user information.
As mentioned above, AAA is a management framework, so it can be implemented by some protocols. RADIUS is such a protocol frequently used.
I. What is RADIUS
Remote Authentication Dial-In User Service, RADIUS for short, is a kind of distributed information switching protocol in Client/Server architecture. RADIUS can prevent the network from interruption of unauthorized access and it is often used in the network environments requiring both high security and remote user access. For example, it is often used for managing a large number of scattering dial-in users who use serial ports and modems. RADIUS system is the important auxiliary part of Network Access Server (NAS).
After RADIUS system is started, if the user wants to have right to access other network or consume some network resources through connection to NAS (dial-in access server in PSTN environment or Ethernet switch with access function in Ethernet environment), NAS, namely RADIUS client end, will transmit user AAA request to the RADIUS server. RADIUS server has a user database recording all the information of user authentication and network service access. When receiving user’s request from NAS, RADIUS server performs AAA through user database query and update and returns the configuration information and accounting data to NAS. Here, NAS controls supplicant and corresponding connections, while RADIUS protocol regulates how to transmit configuration and accounting information between NAS and RADIUS.
NAS and RADIUS exchange the information with UDP packets. During the interaction, both sides encrypt the packets with keys before uploading user configuration information (like password etc.) to avoid being intercepted or stolen.
&  Note:
The authentication and authorization of a RADIUS scheme cannot be performed separately.
II. RADIUS operation
RADIUS server generally uses proxy function of the devices like access server to perform user authentication. The operation process is as follows: First, the user send request message (the client username and encrypted password is included in the message) to RADIUS server. Second, the user will receive from RADIUS server various kinds of response messages in which the ACCEPT message indicates that the user has passed the authentication, and the REJECT message indicates that the user has not passed the authentication and needs to input username and password again, otherwise access will be rejected.
I. HWTACACS characteristics
HWTACACS is an enhanced security protocol based on TACACS (RFC1492). Similar to the RADIUS protocol, it implements AAA for different types of users through communications with TACACS servers in the Server/Client model. HWTACACS can be used for the authentication, authorization and accounting of PPP and VPDN access users and Login users.
Compared with RADIUS, HWTACACS provides more reliable transmission and encryption, and therefore is more suitable for security control. The following table lists the primary differences between HWTACACS and RADIUS protocols:
Table 1-1 HWTACACS vs. RADIUS
HWTACACS
RADIUS
Adopts TCP, providing more reliable network transmission.
Adopts UDP.
Encrypts the entire packet except for the standard HWTACACS header.
Encrypts only the password field in authentication packets.
Separates authentication from authorization. For example, you can use RADIUS to authenticate but HWTACACS to authorize.
Binds authentication with authorization.
Suitable for security control.
Suitable for accounting.
Supports the authorization of different users to use the configuration commands of the routing module of the switch.
Not support.
Working as a client of HWTACACS, the switch sends the username and password to the TACACS server for authentication, as shown in the following figure:
Figure 1-1 Network diagram for HWTACACS
II. Basic message exchange procedures in HWTACACS
For example, use HWTACACS to implement authentication, authorization, and accounting for a telnet user. The basic message exchange procedures are as follows:
l           A user requests access to the switch; the TACACS client sends a start-authentication packet to TACACS server upon receiving the request.
l           The TACACS server sends back an authentication response requesting for the username; the TACACS client asks the user for the username upon receiving the response.
l           The TACACS client sends an authentication continuance packet carrying the username after receiving the username from the user.
l           The TACACS server sends back an authentication response, requesting for the login password. Upon receiving the response, the TACACS client requests the user for the login password.
l           After receiving the login password, the TACACS client sends an authentication continuance packet carrying the login password to the TACACS server.
l           The TACACS server sends back an authentication response indicating that the user has passed the authentication.
l           The TACACS client sends the user authorization packet to the TACACS server.
l           The TACACS server sends back the authorization response, indicating that the user has passed the authorization.
l           Upon receipt of the response indicating an authorization success, the TACACS client pushes the configuration interface of the switch to the user.
l           The TACACS client sends a start-accounting request to the TACACS server.
l           The TACACS server sends back an accounting response, indicating that it has received the start-accounting request.
l           The user logs off; the TACACS client sends a stop-accounting request to the TACACS server.
l           The TACACS server sends a stop-accounting response to the client, which indicates it has received the stop-accounting request packet.
The following figure illustrates the basic message exchange procedures:
Figure 1-2 illustrates the basic message exchange procedures.
Figure 1-2 Basic message exchange procedures
By now, we understand that in the above-mentioned AAA/RADIUS framework, H3C Series Switches, serving as the user access device (NAS), is the client end of RADIUS. In other words, the AAA/RADIUS concerning client-end is implemented on H3C Series Switches. Figure 1-3 illustrates the RADIUS authentication network including H3C Series Switches.
Figure 1-3 Network diagram for using RADIUS authentication
The following sections describe AAA configuration tasks.
l           Creating/Deleting an ISP Domain
l           Configuring Relevant Attributes of an ISP Domain
l           Configuring Self-Service Server URL
l           Creating/Deleting a Local User
l           Setting the Attributes of a Local User
l           Disconnecting a User by Force
l           Configuring Dynamic VLAN Delivering
Among the above configuration tasks, creating ISP domain is compulsory; otherwise the supplicant attributes cannot be distinguished. The other tasks are optional. You can configure them at requirements.
What is Internet Service Provider (ISP) domain? To make it simple, ISP domain is a group of users belonging to the same ISP. Generally, for a username in the userid@isp-name format, taking [email protected] as an example, the isp-name (that is, H3C163.net) following the @ is the ISP domain name. When H3C Series Switches control user access, as for an ISP user whose username is in userid@isp-name format, the system will take userid part as username for identification and take isp-name part as domain name.
The purpose of introducing ISP domain settings is to support the multi-ISP application environment. In such environment, one access device might access users of different ISP. Because the attributes of ISP users, such as username and password formats, etc, may be different, it is necessary to differentiate them through setting ISP domain. In H3C Series Switches ISP domain view, you can configure a complete set of exclusive ISP domain attributes on a per-ISP domain basis, which includes AAA policy (RADIUS scheme applied etc.)
For H3C Series Switches, each supplicant belongs to an ISP domain. Up to 16 domains can be configured in the system. If a user has not reported its ISP domain name, the system will put it into the default domain.
Perform the following operations in system view to create/delete an ISP domain:
To do...
Use the command...
Create ISP domain or enter the view of a specified domain
domain isp-name
Remove a specified ISP domain
undo domain isp-name
Enable the default ISP domain specified by isp-name
domain default enable isp-name
Restore the default ISP domain to system
domain default disable
By default, a domain named system has been created in the system. The attributes of system are all default values.
The relevant attributes of ISP domain include the adopted AAA scheme, ISP domain state, maximum number of supplicants, accounting optional enable/disable state, address pool definition, IP address assignment for PPP domain users, and user idle-cut enable/disable state where:
l           The adopted AAA scheme is the one used by all the users in the ISP domain. If Local or None is configured as the first scheme, only the Local or None scheme will be adopted, neither RADIUS nor HWTACACS scheme will be adopted. When Local scheme is adopted, only authentication and authorization will be performed, accounting will not be performed. The usernames used for Local authentication carry no domain name, so if the Local scheme is configured, pay attention not to add domain name to the username when you configure a Local user.
l           Every ISP domain has two states: Active and Block. If an ISP domain is in Active state, the users in it are allowed to request network services, while in Block state, its users are inhibit from requesting any network service, which will not affect the users already online. An ISP is in Active state once it is created. That is, at that time, all the users in the domain are allowed to request network services.
l           Maximum number of supplicants specifies how many supplicants can be contained in the ISP. For any ISP domain, there is no limit to the number of supplicants by default.
l           The idle cut function means: If the traffic from a certain connection is lower than the defined traffic, cut off this connection.
l           The PPP access users can obtain IP addresses through the PPP address negotiation function.
Perform the following operations in ISP domain view to configure relevant attributes of an ISP domain:
To do...
Use the command...
Configure the AAA scheme used by an ISP domain
scheme { radius-scheme radius-scheme-name [ local ] | hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none }
Restore the default AAA scheme used by an ISP domain
undo scheme { radius-scheme | hwtacacs-scheme | none }
Configure the RADIUS scheme used by an ISP domain
Delete the specified RADIUS scheme
undo radius scheme radius-server-name
Set the state of ISP domain
state { primary | secondary } { accounting | authentication } { block | active }
Set a limit to the amount of supplicants
access-limit { disable | enable max-user-number }
Restore the limit to the default setting
undo access-limit
Enable accounting to be optional
accounting optional
Disable accounting to be optional
undo accounting optional
Set the Idle-cut
idle-cut { disable | enable minute flow }
Define an address pool to assign IP addresses to users
ip pool pool-number low-ip-address [ high-ip-address ]
Delete the specified address pool
undo ip pool pool-number
Both the radius-scheme and scheme radius-scheme commands can be used to specify the RADIUS scheme for an ISP domain with the same effect, and the system adopts the last configuration.
By default, Local is adopted as the AAA scheme, an ISP domain is in Active state once it is created, no limit is set to the amount of supplicants, accounting optional is disabled, idle-cut is disabled, and no IP address pool is defined.
The self-service-url enable command must be incorporated with a RADIUS server that supports self-service, such as comprehensive access management server (CAMS). Self-service means that users can manage their accounts and card numbers by themselves. And a server with the self-service software is called a self-service server.
Once this function is enabled on the switch, users can locate the self-service server through the following operations:
l           Select "Change user password" on the 802.1x client.
l           After the client opens the default explorer (IE or Netscape), locate the specified URL page used to change the user password on the self-service server.
l           Change user password on this page.
Perform the following operations in ISP domain view to configure the self-service server URL:
To do...
Use the command...
Configure self-service server URL and configure the URL address used to change the user password on the self-service server
self-service-url enable url-string
Remove the configuration of self-service server URL
self-service-url disable
By default, self-service server URL is not configured on the switch.
Note that, if "?" is contained in the URL, you must replace it with "|" when inputting the URL in the command line.
The "Change user password" option is available only when the user passes the authentication; otherwise, this option is in grey and unavailable.
A local user is a group of users set on NAS. The username is the unique identifier of a user. A supplicant requesting network service may use local authentication only if its corresponding local user has been added onto NAS.
Perform the following operations in system view to create/delete local user:
To do...
Use the command...
Add a local user
local-user { username | password-display-mode { auto | cipher-force } }
Delete all the local users
undo local-user all
Delete a local user by specifying its type
undo local-user { username | all [ service-type { ftp | lan-access | telnet | ppp | ssh | terminal } ] | password-display-mode }
By default, the user database of the system is empty. If the client user wants to access the FTP Server (S9500 devices) through FTP, the configuration is required.
The attributes of a local user include its password display mode, state, service type and some other settings.
I. Setting the password display mode
Perform the following operations in system view to configure the mode that a local user uses to display password:
To do...
Use the command...
Set the mode that a local user uses to display password
local-user password-display-mode { cipher-force | auto }
Cancel the mode that the local user uses to display password
undo local-user password-display-mode
Where, auto means that the password display mode will be the one specified by the user at the time of configuring password (see the password command in the following table for reference), and cipher-force means that the password display mode of all the accessing users must be in cipher text.
II. Setting/Removing the attributes of a local user
Perform the following operations in local user view to set/remove the attributes concerned with a specified user:
To do...
Use the command...
Set a password for a specified user
password { simple | cipher } password
Remove the password set for the specified user
undo password
Set the state of the specified user
state { active | block }
Set a service type for the specified user
service-type { ftp [ ftp-directory directory ] | lan-access | ppp [ call-number call-number | callback-nocheck | callback-number callback-number ] | ssh [ level level | telnet | terminal ] | telnet [ level level | ssh | terminal ] | terminal [ level level | ssh | telnet ] }
Cancel the service type of the specified user
undo service-type { ftp [ ftp-directory directory ] | lan-access | ppp [call-number call-number | callback-nocheck | callback-number callback-number ] | ssh [ level level | telnet | terminal ] | telnet [ level level  | ssh | terminal ] | terminal [ level level | ssh | telnet ] }
Set the priority of the specified user
level level
Restore the default priority of the specified user
undo level
Configure the attributes of Lan-access users
attribute { ip ip-address | mac mac-address | idle-cut second | access-limit max-user-number | vlan vlanid | location { nas-ip ip-address port portnum | port portnum }*
Remove the attributes defined for the lan-access users
undo attribute { ip | mac | idle-cut | access-limit | vlan | location }*
&  Note:
l      Among the attribute options in local user view, only access-limit is applicable to telnet and ssh terminal users. Other attributes, such as port binding, VLAN binding, and IP binding, are applicable to only LAN users.
l      When you bind a port to a user, this setting takes effect only when the slot number, the subslot number and the port number exist.
l      When you configure service types telnet, ssh, and terminal, later configuration will overwrite the previous one. In this case, to configure the two or three of them at the same time, you must specify the desired service types in one command at one time.
l      When you configure login path for an FTP user, ensure that the path is available in the standby board. Otherwise, the user may not be able to log in after an active/standby switchover.
By default, users are not authorized to any service, all their priorities are 0.
Sometimes it is necessary to disconnect a user or a category of users by force. The system provides the following command to serve for this purpose.
Perform the following operations in system view to disconnect a user by force:
To do...
Use the command...
Disconnect a user by force
cut connection { all | access-type { dot1x | gcm | mac-authentication } | domain domain-name | interface interface-type interface-number | ip ip-address | mac mac-address | radius-scheme radius-scheme-name | vlan vlanid | ucibindex ucib-index | user-name user-name }
Dynamic VLAN delivering aims to control the network resources available to a user. With this function enabled, a switch adds the ports connecting to authenticated users to specified VLANs according to the attribute values delivered by the RADIUS server. In actual use, ports are usually set to operate in port-based mode in order to work together with Guest VLAN. A port operating in MAC address-based mode can only have one host connected to it.
Currently, the VLAN IDs delivered by RADIUS servers can be of integer or string type.
l           As for a VLAN ID that is of integer type, a switch adds the port to the corresponding VLAN according to the VLAN ID delivered by the RADIUS server. If the VLAN does not exist, the switch creates the VLAN first and then adds ports to the VLAN.
l           As for a VLAN ID that is of string type, a switch compares the VLAN ID delivered by the RADIUS server with the names of the VLANs existing on the switch. If a matching entry is found, the switch adds the port to the corresponding VLAN. Otherwise, the delivery fails and the user fails to pass the authentication.
&  Note:
l      When configuring a VLAN delivering mode, keep the mode configured on the switch consistent with the mode configured on the Radius Server.
l      For the string delivery mode, the value range of the VLAN name supported by the switch is 1-32 characters. If the name configured on the Radius Server exceeds 32 characters, the delivery will fail.
l      For the string delivery mode, a string that contains numerals only is first interpreted as a number. That is, if the VLAN name delivered by the RADIUS server contains only numerals (such as “1024”), and the equivalent integer is within the range 1 to 4,094, the switch takes the VLAN name as an integer and add the authenticated port to the VLAN identified by the integer (In this case, the switch will add the port to VLAN 1024). If the equivalent integer is not within the range 1 to 4,094 (such as string “12345”), the RADIUS server fails to deliver the VLAN name; if the all-numeral string contains space, such as “   12    345”, the first block of non-spaced numbers in the string will be converted into its equivalent integer, namely, integer 12 in this example.
l      Hybrid ports and Trunk ports do not support VLAN delivering; only Access ports support VLAN delivering.
l      If HGMP is enabled in the system, you cannot specify VLAN 2047 as a dynamically delivered VLAN.
Dynamic VLAN delivering configuration includes:
l           Configuring VLAN delivery mode (integer or string)
l           Configuring the name of the delivered VLAN
I. Configuring VLAN delivery mode
Perform the following operations in ISP domain view to configure VLAN delivery mode:
To do...
Use the command...
Configure the VLAN delivery mode to be integer
vlan-assignment-mode integer
Configure the VLAN delivery mode to be string
vlan-assignment-mode string
By default, the integer mode is used. That is, the switch supports the RADIUS server delivering VLAN IDs in integer form.
II. Configuring name of a delivered VLAN
Perform the following operations in VLAN view to configure the name of a delivered VLAN:
To do...
Use the command...
Configure the name of a delivered VLAN
name string
Remove the configured VLAN name and restore it to the default name
undo name
By default, the delivered VLAN does not have a name.
For the H3C Series Switches, the RADIUS protocol is configured on the per RADIUS scheme basis. In real networking environment, a RADIUS scheme can be an independent RADIUS server or a set of primary/secondary RADIUS servers with the same configuration but two different IP addresses. Accordingly, attributes of every RADIUS scheme include IP addresses of primary and secondary servers, shared key and RADIUS server type etc.
Actually, RADIUS protocol configuration only defines some necessary parameters using for information interaction between NAS and RADIUS Server. To make these parameters take effect on an ISP domain, you must configure the ISP domain to use the RADIUS scheme configured with these parameters in ISP domain view. For more about the configuration commands, refer to AAA Configuration.
The following sections describe RADIUS protocol configuration tasks.
l           Creating/Deleting a RADIUS scheme
l           Setting IP Address and Port Number of a RADIUS Server
l           Setting the RADIUS Packet Encryption Key
l           Configuring VPN of RADIUS Server
l           Setting the Port State of the Local RADIUS Server
l           Setting the Maximum Retry Times for RADIUS Request Packets
l           Setting RADIUS Server Response Timeout Timer
l           Setting Quiet Time of RADIUS Server
l           Setting the Retransmission Times of RADIUS Request Packets
l           Enabling the Selection of Radius Accounting Option
l           Setting a Real-time Accounting Interval
l           Setting the Maximum Times of Real-time Accounting Request Failing to be Responded
l           Enabling/Disabling Stop-Accounting Request Buffer
l           Setting the Maximum Retransmitting Times of Stop-Accounting Request
l           Setting the Supported Type of RADIUS Server
l           Setting RADIUS Server State
l           Setting the Username Format Transmitted to RADIUS Server
l           Setting the Unit of Data Flow that Transmitted to RADIUS Server
l           Configuring the Source Address Used by NAS in RADIUS Packets
l           Setting the Port State of RADIUS Client
l           Specifying the Security Policy Servers
l           Configuring a Local RADIUS Authentication Server
Among the above tasks, creating RADIUS scheme and setting IP address of RADIUS server are required, while other takes are optional and can be performed as your requirements.
As mentioned above, RADIUS protocol configurations are performed on the per RADIUS scheme basis. Therefore, before performing other RADIUS protocol configurations, it is compulsory to create the RADIUS scheme and enter its view.
You can use the following commands to create/delete a RADIUS scheme.
Perform the following operations in system view to create/delete RADIUS server group:
To do...
Use the command...
Create a RADIUS server group and enter its view
Delete a RADIUS server group
Several ISP domains can use a RADIUS server group at the same time. You can configure up to 16 RADIUS schemes, including the default server group named as System.
By default, the system has a RADIUS scheme named system whose attributes are all default values.
After creating a RADIUS scheme, you need to set IP addresses and UDP port numbers for the RADIUS servers, including primary/secondary authentication/authorization servers and accounting servers. So you can configure up to 4 groups of IP addresses and UDP port numbers. However, at least you have to set one group of IP address and UDP port number for each pair of primary/secondary servers to ensure the normal AAA operation.
You can use the following commands to configure the IP address and port number for RADIUS schemes.
Perform the following operations in RADIUS scheme view to configure the IP address and port number of RADIUS server:
To do...
Use the command...
Set IP address and port number of primary RADIUS authentication/authorization or accounting server.
primary { accountig | authenticaiton } ip-address [ port-number ]
Restore IP address and port number of primary RADIUS authentication/authorization or accounting server to the default values.
undo primary { accounting | authentication }
Set IP address and port number of secondary RADIUS authentication/authorization or accounting server.
secondary { accounting | authentication } ip-address [ port-number ]
Restore IP address and port number of secondary RADIUS authentication/authorization or accounting server to the default values.
undo secondary { accounting | authentication }
&  Note:
When a user logs into the H3C S9500 routing switch that is directly connected with the user PC, the switch can obtain the valid VLAN of the user (that is, VLAN the user belongs to). But when the user logs into a H3C S9500 routing switch that is not directly connected with the user PC (to perform cross-device management, for example), the switch cannot obtain the valid VLAN information of the user, and thus the switch uses the default VLAN ID (VLAN 1) to interact with the authentication server for authentication.
As for the default RADIUS scheme system:
l           The IP address of the primary authentication server is 127.0.0.1, and the UDP port number is 1645.
l           The IP address of the secondary authentication server is 0.0.0.0, and the UDP port number is 1812.
l           The IP address of the primary accounting server is 127.0.0.1, and the UDP port number is 1646
l           The IP address of the secondary accounting server is 0.0.0.0, and the UDP port number is 1813;
As for the newly created RADIUS scheme:
l           The IP address of the primary/secondary authentication server is 0.0.0.0, and the UDP port number of this server is 1812;
l           The IP address of the primary/secondary accounting server is 0.0.0.0, and the UDP port number of this server is 1813;
In real networking environments, the above parameters shall be set according to the specific requirements. For example, you may specify 4 groups of different data to map 4 RADIUS servers, or specify one of the two servers as primary authentication/authorization server and secondary accounting server and the other one as secondary authentication/authorization server and primary accounting server, or you may also set 4 groups of exactly same data so that every server serves as a primary and secondary AAA server.
To guarantee the normal interaction between NAS and RADIUS server, make sure a route is available between RADIUS/HWTACACS server and NAS before setting IP address and UDP port of the RADIUS server and IP address and TCP port of the HWTACACS server. In addition, because RADIUS/HWTACACS protocol uses different ports to receive/transmit authentication/authorization and accounting packets, you shall set two different ports accordingly. Suggested by RFC2138/2139, authentication/authorization port number is 1812 and accounting port number is 1813. However, you may use values other than the suggested ones. (Especially for some earlier RADIUS/HWTACACS Servers, authentication/authorization port number is often set to 1645 and accounting port number is 1646.)
The RADIUS/HWTACACS service port settings on H3C series switches are supposed to be consistent with the port settings on RADIUS server. Normally, RADIUS accounting service port is 1813 and the authentication/authorization service port is 1812.
&  Note:
For an S9500 routing switch, the default RADIUS scheme authentication/authorization port is 1645, the accounting port is 1646. And port 1812 and 1813 are for other schemes.
RADIUS client (switch system) and RADIUS server use MD5 algorithm to encrypt the exchanged packets. The two ends verify the packet through setting the encryption key. Only when the keys are identical can both ends to accept the packets from each other end and give response.
You can use the following commands to set the encryption key for RADIUS packets.
Perform the following operations in RADIUS scheme view to configure RADIUS packet encryption key:
To do...
Use the command...
Set RADIUS authentication/authorization packet encryption key
key authentication string
Restore the default RADIUS authentication/authorization packet encryption key
undo key authentication
Set RADIUS accounting packet encryption key
key accounting string
Restore the default RADIUS accounting packet encryption key
undo key accounting
By default, the encryption keys of RADIUS authentication/authorization and accounting packets are all null.
The default address of the RADIUS Server is the address of the public network. If the RADIUS Server is built under a private network, you must specify the VPN to which the RADIUS Server belongs when configuring the RADIUS Server.
Use the following commands to configure the VPN of the RADIUS Server.
Perform the following operations in RADIUS scheme view to configure the VPN of RADIUS server:
To do...
Use the command...
Set the VPN that the RADIUS Server belongs to
vpn-instance vpn-name
Restore the VPN attribute of RADIUS Server to the default value
undo vpn-instance
The RADIUS Server does not belong to any VPN by default.
The local RADIUS server uses the switch itself as the RADIUS server, with port 1645 as authentication port and port 1646 as accounting port. The two ports are enabled in the initial state, without any corresponding command lines to enable/disable them. Considering the policy of maximum security, certain measures are taken to control the ports to eliminate potential security troubles.
Perform the following operations in system view to enable/disable the port of the local RADIUS server:
To do...
Use the command...
Enable the port of the local RADIUS server
local-server enable
Disable the port of the local RADIUS server
undo local-server
By default, the local RADIUS server is enabled, and port 1645 and port 1646 are enabled.
Because RADIUS Protocol carries data through UDP packets, its communication process is not reliable. If the RADIUS Server does not respond to the NAS within the time specified by the response timeout timer, it is necessary for the NAS to retry sending the RADIUS request packets to the RADIUS Server. If the number of retry times exceeds maximum retry times while the RADIUS Server still does not respond, the NAS will assume its communication with the current RADIUS Server to have been cut off and will send request packets to another RADIUS Server.
Use the following commands to set the maximum retry times of sending RADIUS request packets.
Perform the following operations in RADIUS scheme view to configure the maximum retry times of sending RADIUS request packets:
To do...
Use the command...
Set the maximum retry times of sending RADIUS request packets
retry retry-times
Restore the maximum retry times of sending RADIUS request packets to the default value
undo retry
By default, the maximum retry times of sending RADIUS request packets is 3.
If the NAS fails to receive the response from RADIUS server a certain period of time after it sends a RADIUS request packet (authentication/authorization request or accounting request), it should retransmit the RADIUS request packet to ensure the RADIUS service for the user.
You can use the following command to set the response timeout timer of the RADIUS server.
Perform the following operations in RADIUS scheme view to configure response timeout timer of RADIUS server:
To do...
Use the command...
Set the response timeout timer of RADIUS server
timer response-timeout seconds
Restore the default value of the response timeout timer of RADIUS server
undo timer response-timeout
The default value of the response timeout timer of a RADIUS server is 3 seconds.
&  Note:
When a RADIUS server (such as CAMS) uses extended RADIUS protocol to dynamically assign upstream rate to each user, you must use self-defined flow template with the SMAC field on the access ports of users. Otherwise, traffic limit cannot be performed properly for each user.
When the communication between the switch and the RADIUS Server is interrupted, the switch will stop processing request packets from the users, and will send user request packets to the RADIUS Server after it has waited for a certain period of time.
Use the following command to set the quiet time of the RADIUS Server.
Perform the following operations in RADIUS scheme view to configure quiet time of RADIUS server:
To do...
Use the command...
Set quiet time of RADIUS Server
timer quiet minutes
Restore quiet time of RADIUS Server to the default value
undo timer quiet
By default, the quiet time of the primary server is 5 minutes.
Since RADIUS protocol uses UDP packet to carry the data, the communication process is not reliable. If the RADIUS server has not responded NAS before timeout, NAS has to retransmit RADIUS request packet. If it transmits more than the specified retry-times, NAS considers the communication with the current RADIUS server has been disconnected, and turn to send request packet to other RADIUS server.
You can use the following command to set retransmission times of RADIUS request packet.
Perform the following operations in RADIUS scheme view to configure the retransmission times of RADIUS request packets:
To do...
Use the command...
Set retransmission times of RADIUS request packet
retry retry-times
Restore the default value of retransmission times
undo retry
By default, RADIUS request packet will be retransmitted up to three times.
If no RADIUS server is available or if RADIUS accounting server fails when the accounting optional is configured, the user can still use the network resource, otherwise, the user will be disconnected.
Perform the following operations in RADIUS scheme view to enable/disable the selection of RADIUS accounting option:
To do...
Use the command...
Enable the selection of RADIUS accounting option
accounting optional
Disable the selection of RADIUS accounting option
By default, selection of RADIUS accounting option is disabled.
To implement real-time accounting, it is necessary to set a real-time accounting interval. After the attribute is set, NAS will transmit the accounting information of online users to the RADIUS server regularly.
Perform the following operations in RADIUS scheme view to configure a real-time accounting interval:
To do...
Use the command...
Set a real-time accounting interval
timer realtime-accounting minute
Restore the default value of the interval
undo timer realtime-accounting
minute specifies the real-time accounting interval in minutes. The value shall be a multiple of 3.
The value of minute is related to the performance of NAS and RADIUS server. The smaller the value is, the higher the performances of NAS and RADIUS are required. When there are a large amount of users (more than 1000, inclusive), we suggest a larger value. The following table recommends the ratio of minute value to the number of users.
Table 1-2 Recommended real-time accounting intervals for different number of users
Number of users
Real-time accounting interval in minutes
1 to 99
3
100 to 499
6
500 to 999
12
1000
15
By default, minute is set to 12 minutes.
RADIUS server usually checks if a user is online with timeout timer. If the RADIUS server has not received the real-time accounting packet from NAS for long, it will consider that there is device failure and stop accounting. Accordingly, it is necessary to disconnect the user at NAS end and on RADIUS server synchronously when some unpredictable failure exists. H3C Series Switches support to set maximum times of real-time accounting request failing to be responded. NAS will disconnect the user if it has not received real-time accounting response from RADIUS server for some specified times.
You can use the following command to set the maximum times of real-time accounting request failing to be responded.
Perform the following operations in RADIUS scheme view to configure the maximum times of real-time accounting request failing to be responded
To do...
Use the command...
Set maximum times of real-time accounting request failing to be responded
retry realtime-accounting retry-times
Restore the maximum times to the default value
undo retry realtime-accounting
How to calculate the value of retry-times? Suppose that RADIUS server connection will timeout in T and the real-time accounting interval of NAS is t, then the integer part of the result from dividing T by t is the value of count. Therefore, when applied, T is suggested the numbers which can be divided exactly by t.
By default, the real-time accounting request can fail to be responded no more than 5 times.
Because the stop-accounting request concerns account balance and will affect the amount of charge, which is very important for both the subscribers and the ISP, NAS shall make its best effort to send the request to RADIUS accounting server. Accordingly, if the request from H3C Series Switches to RADIUS accounting server has not been responded, switch shall save it in the local buffer and retransmit it until the server responds or discards the messages after transmitting for specified times. You can use the following command to set whether or not to save the stop-accounting requests.
Perform the following operations in RADIUS scheme view to enable/disable stop-accounting request buffer:
To do...
Use the command...
Enable stop-accounting request buffer
stop-accounting-buffer enable
Disable stop-accounting request buffer
undo stop-accounting-buffer enable
By default, the stop-accounting request will be saved in the buffer.
Because the stop-accounting request concerns account balance and will affect the amount of charge, which is very important for both the subscribers and the ISP, NAS shall make its best effort to send the message to RADIUS accounting server. Accordingly, if the request from H3C Series Switch to RADIUS accounting server has not been responded, switch shall save it in the local buffer and retransmit it until the server responds or discards the messages after transmitting for specified times. Use the following command to set the maximum retransmission times.
Perform the following operations in RADIUS scheme view to configure the maximum times of retransmitting stop-accounting requests:
To do...
Use the command...
Set the maximum times of retransmitting stop-accounting request
retry stop-accounting retry-times
Restore the maximum times of retransmitting stop-accounting request to the default value
undo retry stop-accounting
By default, the stop-accounting request can be retransmitted for up to 500 times.
H3C Series Switches support the standard RADIUS protocol and the extended RADIUS service platforms, such as IP Hotel, 201+ and Portal developed by Huawei.
You can use the following command to set the supported types of RADIUS servers.
Perform the following operations in RADIUS scheme view to configure the supported type of RADIUS scheme:
To do...
Use the command...
Set the Supported Type of RADIUS Server
server-type { extended | standard }
Restore the Supported Type of RADIUS Server to the default setting
undo server-type
By default, the newly created RADIUS scheme supports the server of standard type, while the default RADIUS scheme system supports the server of extended type
For the primary and secondary servers (no matter it is an authentication/authorization server or accounting server), if the primary is disconnected to NAS for some fault, NAS will automatically turn to exchange packets with the secondary server. However, after the primary one recovers, NAS will not resume the communication with it at once, instead, it continues communicating with the secondary one. When the secondary one fails to communicate, NAS will turn to the primary one again. The following commands can be used to set the primary server to be active manually, in order that NAS can communicate with it right after the troubleshooting.
When both the primary and secondary servers are active or block, NAS will send packets to the primary server firstly. If NAS fails to connect the primary server, it will send the packets to the secondary server.
Perform the following operations in RADIUS scheme view to configure the state of RADIUS server:
To do...
Use the command...
Set the state of primary RADIUS authentication/authorization server
state primary authentication { block | active }
Set the state of primary RADIUS accounting server
state primary accounting { block | active }
Set the state of secondary RADIUS authentication/authorization server
state secondary authentication { block | active }
Set the state of secondary RADIUS accounting server
state secondary accounting { block | active }
By default, the state of each server in RADIUS scheme server group is active.
As mentioned above, the supplicants are generally named in userid@isp-name format. The part following “@” is the ISP domain name. H3C Series Switches will put the users into different ISP domains according to the domain names. However, some earlier RADIUS servers reject the username including ISP domain name. In this case, you have to remove the domain name before sending the username to the RADIUS server. The following command of switch decides whether the username to be sent to RADIUS server carries ISP domain name or not.
Perform the following operations in RADIUS scheme view to configure the username format transmitted to RADIUS server:
To do...
Use the command...
Set Username Format Transmitted to RADIUS Server
user-name-format { with-domain | without-domain }
&  Note:
If a RADIUS scheme is configured not to allow usernames including ISP domain names, the RADIUS scheme shall not be simultaneously used in more than one ISP domain. Otherwise, the RADIUS server will regard two users in different ISP domains as the same user by mistake, if they have the same username (excluding their respective domain names.)
By default, as for the newly created RADIUS scheme, the username sent to RADIUS servers includes an ISP domain name; as for the default RADIUS scheme system, the username sent to RADIUS servers excludes the ISP domain name.
The following command defines the unit of the data flow sent to RADIUS server.
Perform the following operations in RADIUS scheme view to configure the unit of data flow transmitted to RADIUS server:
To do...
Use the command...
Set the unit of data flow transmitted to RADIUS server
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } } | { packet { giga-packet | kilo-packet | mega-packet | one-packet } }
Restore the unit to the default setting
undo data-flow-format
By default, the default data unit is byte and the default data packet unit is one packet.
Perform the following operations in the corresponding view to configure the source address used by the NAS in RADIUS packets:
To do...
Use the command...
Configure the source address used by the NAS in RADIUS packets (RADIUS scheme view)
nas-ip ip-address
Cancel the configured source address used by the NAS in RADIUS packets (RADIUS scheme view)
undo nas-ip
Configure the source address used by the NAS in RADIUS packets (System view)
radius nas-ip ip-address [ vpn-instance vpn-instance-name ]
Cancel the configured source address used by the NAS in RADIUS packets (System view)
undo radius nas-ip [ vpn-instance vpn-instance-name ]
The effect of the two commands is the same. However, the configuration done in RADIUS scheme view has a higher priority than the configuration done in system view.
By default, no source address is specified, that is to say, the interface from which a packet is sent is regarded as the source address of the packet.
According to RFC2138/2139 protocol, Radius service generally adopts port 1812 as authentication packet port and port 1813 as accounting packet port. However, the source port of both authentication packets and accounting packets is port 1812 on H3C S9500 series switches. If such packets are sent, the destination port of the response packets is port 1812. So RADIUS service can be controlled on the switch by controlling the inbound UDP packets whose destination port is 1812.
H3C series switches provide the following command to set the state of port 1812 of the RADIUS client.
Perform the following operations in system view to configure the port state of RADIUS client:
To do...
Use the command...
Enable the port 1812 of the RADIUS client
radius client enable
Disable the port 1812 of the RADIUS client
undo radius client
The port 1812 of the RADIUS client is enabled by default.
If the port 1812 is disabled, all the UDP packets whose destination port is port 1812 will be dropped, so the remote RADIUS service cannot be used.
To cooperate with the extended portal function, a security policy server is necessary for security check of users accessing the network through the device. The security policy server determines whether a user can access the intended network resources.
For details about portal, refer to Portal Configuration in the Security Volume.
Follow these steps to specify a security policy server:
To do...
Use the command...
Specify a security policy server
security-policy-server ip-address
Remove one or all security policy servers
undo security-policy-server { ip-address | all }
By default, no security policy server is specified.
  Caution:
l      If more than one VLAN interface of an access device is enabled with portal, the interfaces may use different security policy servers. You can specify up to eight security policy servers for a RADIUS scheme.
l      If the RADIUS server and the security policy server reside on the same physical device, you do not need to configure the IP address of the security policy server.
l      The specified security policy server must be a security policy server or RADIUS server that is correctly configured and working normally. Otherwise, the device will regard it as an illegal server.
H3C S9500 series switches not only support the traditional RADIUS client service mentioned above, that is, adopting authentication, authorization and accounting servers to authenticate and administrate users, but also provides simple local RADIUS server function (including authentication and authorization), which is also known as local RADIUS authentication server function. A S9500 switch supports up to 16 local RADIUS servers.
Perform the following operations in system view to create/delete local RADIUS authentication server:
To do...
Use the command...
Create a local RADIUS authentication server
local-server nas-ip ip-address key password
Delete a local RADIUS authentication server
undo local-server nas-ip ip-address
By default, the IP address of local RADIUS authentication server group is 127.0.0.1 and the password is null.
When using local RADIUS server function, note that,
l           The number of UDP port used for authentication/authorization is 1645 and that for accounting is 1646.
l           The password configured by local-server command must be the same as that of the RADIUS authentication/authorization packet configured by the command key authentication in radius scheme view.
l           S9500 series serving as local RADIUS authentication servers currently only support the CHAP and PAP authentication modes; they do not support the EAP mode.
The following sections describe HWTACACS configuration tasks.
l           Creating a HWTACACS Scheme
l           Configuring HWTACACS Authentication Servers
l           Configuring HWTACACS Authorization Servers
l           Configuring HWTACACS Accounting Servers and the Related Attributes
l           Configuring the Source Address for HWTACACS Packets Sent by NAS
l           Setting a Key for Securing the Communication with TACACS Server
l           Setting the Username Format Acceptable to the TACACS Server
l           Setting the Unit of Data Flows Destined for the TACACS Server
l           Setting Timers Regarding TACACS Server
&  Note:
Pay attention to the following when configuring a TACACS server:
l      HWTACACS server does not check whether a scheme is being used by users when changing most of HWTACACS attributes, unless you delete the scheme.
l      By default, the TACACS server has no key.
In the above configuration tasks, creating HWTACACS scheme and configuring TACACS authentication/authorization server are required; all other tasks are optional and you can determine whether to perform these configurations as needed.
As aforementioned, HWTACACS protocol is configured scheme by scheme. Therefore, you must create a HWTACACS scheme and enter HWTACACS view before you perform other configuration tasks.
Perform the following operations in system view to create/delete HWTACACS scheme:
To do...
Use the command...
Create a HWTACACS scheme and enter HWTACACS view
hwtacacs scheme hwtacacs-scheme-name
Delete a HWTACACS scheme
undo hwtacacs scheme hwtacacs-scheme-name
By default, no HWTACACS scheme exists.
If the HWTACACS scheme you specify does not exist, the system creates it and enters HWTACACS view. In HWTACACS view, you can configure the HWTACACS scheme specifically.
The system supports up to 16 HWTACACS schemes. You can only delete the schemes that are not being used.
Perform the following operations in HWTACACS view to configure HWTACACS authentication servers:
To do...
Use the command...
Configure the HWTACACS primary authentication server
primary authentication ip-address [ port-number ]
Delete the HWTACACS primary authentication server
undo primary authentication
Configure the HWTACACS secondary authentication server
secondary authentication ip-address [ port-number ]
Delete the HWTACACS secondary authentication server
undo secondary authentication
The primary and secondary authentication servers cannot use the same IP address. The default port number is 49.
If you execute this command repeatedly, the new settings will replace the old settings.
A TACACS scheme authentication server can be deleted only when no Active TCP connection used to send authentication packets is using the server.
Perform the following operations in HWTACACS view to configure HWTACACS authorization servers:
To do...
Use the command...
Configure the primary HWTACACS authorization server
primary authorization ip-address [ port-number ]
Delete the primary HWTACACS authorization server
undo primary authorization
Configure the secondary HWTACACS authorization server
secondary authorization ip-address [ port-number ]
Delete the secondary HWTACACS authorization server
undo secondary authorization
&  Note:
If only authentication and accounting servers are configured and no authorization server is configured, both authentication and accounting can be performed normally for the FTP, Telnet, and SSH users, but the priority of these users is 0 (that is, the lowest privilege level) by default,
The primary and secondary authorization servers cannot use the same IP address. The default port number is 49.
I. Configuring HWTACACS accounting servers
Perform the following operations in HWTACACS view to configure HWTACACS accounting servers:
To do...
Use the command...
Configure the primary TACACS accounting server
primary accounting ip-address [ port-number ]
Delete the primary TACACS accounting server
undo primary accounting
Configure the secondary TACACS accounting server
secondary accounting ip-address [ port-number ]
Delete the secondary TACACS accounting server
undo secondary accounting
Do not configure the same IP address for the primary accounting server and the secondary accounting server. Otherwise, an error occurs.
By default, a TACACS accounting server uses an all-zero IP address and port 49.
If you execute the primary accounting or secondary accounting command repeatedly, the newly configured settings overwrite the corresponding existing settings.
You can delete a TACACS scheme only when no Active TCP connection used to send authentication packets uses the server.
II. Enabling stop-accounting packet retransmission
Perform the following operations in HWTACACS view to configure stop-accounting packet retransmission:
To do...
Use the command...
Enable stop-accounting packet retransmission and set the allowed maximum number of transmission attempts
Disable stop-accounting packet retransmission
Clear the stop-accounting request packets that have no response
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
By default, stop-accounting packet retransmission is enabled, and the maximum number of transmission attempts is 300.
Perform the following operations in the corresponding view to configure the source address for HWTACACS packets sent by the NAS:
To do...
Use the command...
Configure the source address for HWTACACS packets sent from the NAS (HWTACACS view)
nas-ip ip-address
Delete the configured source address for HWTACACS packets sent from the NAS (HWTACACS view)
undo nas-ip
Configure the source address for HWTACACS packets sent from the NAS (System view)
hwtacacs nas-ip ip-address
Cancel the configured source address for HWTACACS packets sent from the NAS (System view)
undo hwtacacs nas-ip
The HWTACACS view takes precedence over the system view when configuring the source address for HWTACACS packets sent from the NAS.
By default, the source address is not specified, and the virtual interface of the VLAN that contains the port to which the server connects for packet sending is used as the source address.
When using a TACACS server as an AAA server, you can set a key to improve the communication security between the switch and the TACACS server.
Perform the following operations in HWTACACS view to set/cancel a key for securing the communication with the HWTACACS server:
To do...
Use the command...
Configure a key for securing the communication with the accounting, authorization or authentication server
key { accounting | authorization | authentication } string
Delete the configuration
undo key { accounting | authorization | authentication }
No key is configured by default.
Username is usually in the “userid@isp-name” format, with the domain name following “@”.
If a TACACS server does not accept the username with domain name, you can remove the domain name and resend it to the TACACS server.
Perform the following operations in HWTACACS view to configure the username format acceptable to the TACACS server:
To do...
Use the command...
Send username with domain name
user-name-format with-domain
Send username without domain name
user-name-format without-domain
By default, each username sent to a TACACS server contains a domain name.
Perform the following operations in HWTACACS view to configure the unit of data flows destined for the TACACS server:
To do...
Use the command...
Set the unit of data flows destined for the TACACS server
data-flow-format data { byte | giga-byte | kilo-byte | mega-byte }
data-flow-format packet { giga-packet | kilo-packet | mega-packet | one-packet }
Restore the default unit of data flows destined for the TACACS server
undo data-flow-format { data | packet }
The default data flow unit is byte.
I. Setting the response timeout timer
Since HWTACACS is implemented on the basis of TCP, server response timeout or TCP timeout may terminate the connection to the TACACS server.
Perform the following operations in HWTACACS view to configure the response timeout timer:
To do...
Use the command...
Restore the default setting
The default response timeout timer is set to 5 seconds.
II. Setting the quiet timer for the primary TACACS server
Perform the following operations in HWTACACS view to configure the quiet timer for the primary TACACS server:
To do...
Use the command...
Set the quiet timer for the primary TACACS server
timer quiet minutes
undo timer quiet
The timer quiet command is used to make the switch ignore users' requests for server within the time configured in this command in case the communication between the switch and the server is terminated. In that case, the switch can send users' requests to the server only after it has waited a time no less than the time configured with this command for the communication to be resumed.
By default, the primary TACACS server must wait five minutes before it can resume the active state. The time ranges from 1 to 255.
III. Setting a realtime accounting interval
The setting of real-time accounting interval is necessary to real-time accounting. After an interval value is set, the NAS transmits the accounting information of online users to the TACACS accounting server periodically.
Perform the following operations in HWTACACS view to configure a real-time accounting interval:
To do...
Use the command...
Restore the default real-time accounting interval
The interval is in minutes and must be a multiple of 3.
The setting of real-time accounting interval somewhat depends on the performance of the NAS and the TACACS server: a shorter interval requires higher device performance. You are therefore recommended to adopt a longer interval when there are a large number of users (more than 1000, inclusive). The following table lists the numbers of users and the recommended intervals.
Table 1-3 Numbers of users and the recommended intervals
Number of users
Real-time accounting interval (in minutes)
1 to 99
3
100 to 499
6
500 to 999
12
¦1000
¦15
The real-time accounting interval defaults to 12 minutes.
To do...
Use the command...
Remarks
Display the configuration information of the specified or all the ISP domains
display domain [ isp-name ]
Available in any view
Display related information of user’s connection
display connection [ access-type { dot1x | gcm } | domain domain-name | hwtacacs-scheme hwtacacs-scheme-name | interface interface-type interface-number | ip ip-address | mac mac-address | radius-scheme radius-scheme-name | vlan vlanid | ucibindex ucib-index | user-name user-name ]
Display related information of the local user
display local-user [ domain isp-name | idle-cut { disable | enable } | service-type { ftp | lan-access | ppp | ssh | telnet | terminal } | state { active | block } | user-name user-name | vlan vlanid ]
Display the statistics of local RADIUS server group
display local-server { statistics | nas-ip }
Display the configuration information of all the RADIUS server groups or a specified one
display radius [ radius-server-name ]
Display all global NAS-IP information configured in system view
display radius nas-ip
Display the statistics of RADIUS packets
display radius statistics
Display the stop-accounting requests saved in buffer without response
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
Reset the statistics of RADIUS server
reset radius statistics
Available in user view
Display the specified or all the HWTACACS schemes
display hwtacacs [ hwtacacs-scheme-name ]
Display the HWTACACS stop-accounting requests saved in buffer without response
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
Delete the stop-accounting requests saved in buffer without response
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
Delete the HWTACACS stop-accounting requests saved in buffer without response
Reset the statistics of HWTACACS server
reset hwtacacs statistics { accounting | authentication | authorization | all }
Enable RADIUS packet debugging
debugging radius packet
Disable RADIUS packet debugging
undo debugging radius packet
Enable debugging of local RADIUS authentication server
debugging local-server { all | error | event | packet }
Disable debugging of local RADIUS authentication server
undo debugging local-server { all | error | event | packet }
Enable HWTACACS debugging
debugging hwtacacs { all | error | event | message | receive-packet | send-packet }
Disable HWTACACS debugging
undo debugging hwtacacs { all | error | event | message | receive-packet | send-packet }
1.6  AAA, RADIUS, and HWTACACS Protocol Configuration Examples
For the hybrid configuration example of AAA/RADIUS/HWTACACS protocol and 802.1x protocol, refer to the 802.1x Configuration module.
Perform the following operations in system view.
Table 1-4 Enable/disable the anti-attack function of packets
To do...
Use the command...
anti-attack { arp | dot1x | ip } { disable | enable }
The anti-attack function of IP packets is enabled while the anti-attack function of ARP packets and dot1x packets are disabled by default.
1.6.1  Configuring Authentication at Remote RADIUS Server
&  Note:
Configuring Telnet user authentication at the remote server is similar to configuring FTP users. The following description is based on Telnet users.
I. Network requirements
In the environment as illustrated in the following figure, it is required to achieve through proper configuration that the RADIUS server authenticates the Telnet users to be registered.
l           One RADIUS server (as authentication server) is connected to the switch and the server IP address is 10.110.91.164.
l           The password for exchanging messages between the switch and the authentication server is expert. The switch removes domain name from username and sends the left part to the RADIUS server and uses the local RADIUS scheme as the backup authentication scheme.
II. Network diagram
Figure 1-4 Network diagram for the remote RADIUS authentication of Telnet users
III. Configuration procedure
# Configure remote authentication mode for Telnet users, i.e. Scheme mode.
<H3C> system-view
[H3C] user-interface vty 0 4
[H3C-ui-vty0-4] authentication-mode scheme
[H3C-ui-vty0-4] quit
# Configure a domain.
[H3C] domain cams
# Configure a RADIUS scheme.
[H3C-radius-cams] primary authentication 10.110.91.164
[H3C-radius-cams] primary accounting 10.110.91.164
[H3C-radius-cams] secondary authentication 127.0.0.1 1645
[H3C-radius-cams] secondary accounting 127.0.0.1 1646
# Configure both the authentication and accounting keys as expert.
[H3C-radius-cams] key authentication expert
[H3C-radius-cams] key accounting expert
# Configure the system to remove the domain name from a username before it sends the username to the RADIUS server.
[H3C-radius-cams] user-name-format without-domain
[H3C-radius-cams] accounting optional
# Associate domain cams with the RADIUS scheme.
[H3C-radius-cams] quit
[H3C] domain cams
[H3C-isp-cams] radius-scheme cams
# Configure the local server.
[H3C] local-server nas-ip 127.0.0.1 key expert
# Add a local Telnet user.
[H3C] local-user telnet
[H3C-luser-localuser] service-type telnet
[H3C-luser-localuser] password simple telnet
&  Note:
If RADIUS authentication is adopted for FTP user, you need to set server-type to extended in the corresponding RADIUS scheme so that the extended RADIUS protocol is used. Otherwise, user directory attributes cannot be obtained correctly.
1.6.2  Configuring Authentication at Local RADIUS Authentication Server
Local RADIUS authentication of Telnet/FTP users is similar to the remote RADIUS authentication described in Configuring Authentication at Remote RADIUS Server. But you should modify the server IP address in Figure 1-4 in that section to 127.0.0.1, authentication password to null, the UDP port number of the authentication server to 1645.
&  Note:
For details about local RADIUS authentication of Telnet/FTP users, refer to Setting the Port State of RADIUS Client.
1.6.3  Configuring Authentication at Remote TACACS Server
Configure the switch to use a TACACS server to provide authentication and authorization services to login users (see the following figure).
Connect the switch to one TACACS server (which acting as an AAA server) with the IP address 10.110.91.164. On the switch, set the shared key for AAA packet encryption to expert. Configure the switch to send usernames to the TACACS server with isp-name removed.
On the TACACS server, set the shared key for encrypting the packets exchanged with the switch to expert .
II. Network diagram
Figure 1-5 Network diagram for TACACS authentication
# Configure remote authentication mode for Telnet users, that is, the Scheme mode.
<H3C> system-view
[H3C] domain hwtacacs
# Configure a HWTACACS scheme.
[H3C] hwtacacs scheme hwtac
[H3C-hwtacacs-hwtac] primary authentication 10.110.91.164
[H3C-hwtacacs-hwtac] primary authorization 10.110.91.164
# Configure the authentication, authorization, and accounting keys to expert.
[H3C-hwtacacs-hwtac] key authentication expert
[H3C-hwtacacs-hwtac] key authorization expert
[H3C-hwtacacs-hwtac] key accounting expert
# Configure the system to remove the domain name from a username before it send the username to the TACACS server.
[H3C-hwtacacs-hwtac] user-name-format without-domain
[H3C-hwtacacs-hwtac] quit
# Associate the domain hwtacacs with the HWTACACS scheme.
[H3C-isp-hwtacacs] scheme hwtacacs-scheme hwtac
1.7  Troubleshooting AAA, RADIUS, and HWTACACS
RADIUS/HWTACACS protocol is located on the application layer of TCP/IP protocol suite. It mainly specifies how to exchange user information between NAS and RADIUS/HWTACACS server of ISP. So it is very likely to be invalid.
I. Symptom: User authentication/authorization always fails
Solution:
l           The username may not be in the userid@isp-name format or NAS has not been configured with a default ISP domain. Please use the username in proper format and configure the default ISP domain on NAS.
l           The user may have not been configured in the RADIUS/HWTACACS server database. Check the database and make sure that the configuration information of the user does exist in the database.
l           The user may have input a wrong password. So please make sure that the supplicant inputs the correct password.
l           The encryption keys of RADIUS/HWTACACS server and NAS may be different. Please check carefully and make sure that they are identical.
l           There might be some communication fault between NAS and RADIUS/HWTACACS server, which can be discovered through pinging RADIUS/HWTACACS server from NAS. So please ensure the normal communication between NAS and RADIUS/HWTACACS server.
II. Symptom: RADIUS/HWTACACS packet cannot be transmitted to RADIUS/HWTACACS server.
Solution:
l           The communication lines (on physical layer or link layer) connecting NAS and RADIUS/HWTACACS server may not work well. So please ensure the lines work well.
l           The IP address of the corresponding RADIUS/HWTACACS server may not have been set on NAS. Please set a proper IP address for RADIUS/HWTACACS server.
l           Ports of authentication/authorization and accounting services may not be set properly. So make sure they are consistent with the ports provided by RADIUS/HWTACACS server.
III. Symptom: After being authenticated and authorized, the user cannot send charging bill to the RADIUS/HWTACACS server.
Solution:
l           The accounting port number may be set improperly. Please set a proper number.
l           The accounting service and authentication/authorization service are provided on different servers, but NAS requires the services to be provided on one server (by specifying the same IP address). So please make sure the server settings on the NAS are consistent with the actual conditions.
