H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesH3C S7500 Switch SeriesReference GuidesCommand ReferencesH3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
43-Appendix
43-Appendix 89 KB
Appendix A  Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
abr-summary
Routing Protocol Commands
3-1
access-limit
AAA-RADIUS-HWTACACS-EAD Commands
1-1
accounting enable
Traffic Accounting Commands
1-1
accounting optional
1-25
accounting-mode traffic
1-2
accounting-on enable
1-23
acl
Login Commands
2-1
acl
ACL Commands
1-1
acl mode
ACL Commands
1-2
acl order
ACL Commands
1-3
active region-configuration
MSTP Commands
1-1
add-member
Cluster Commands
1-14
address-check
DHCP Commands
2-1
address-check dhcp-relay
DHCP Commands
2-1
address-check no-matched
DHCP Commands
2-2
administrator-address
Cluster Commands
1-15
aggregate
5-1
am user-bind
Port Binding Commands
1-2
am user-bind interface
1-1
apply as-path
6-1
apply community
6-2
apply cost
6-3
apply cost-type
6-3
apply ip next-hop
6-4
apply isis
6-5
apply local-preference
6-6
apply origin
6-6
apply tag
6-7
area
3-2
area-authentication-mode
4-1
arp check enable
ARP Commands
1-1
arp gratuitous-updating enable
ARP Commands
1-1
arp mac-arp-map limit
ARP Commands
1-2
arp max-dynamic-entry
ARP Commands
1-4
arp max-entry
ARP Commands
1-3
arp proxy enable
ARP Commands
1-4
arp proxy source-vlan enable
ARP Commands
1-5
arp source-suppression limit
ARP Commands
1-6
arp static
ARP Commands
1-7
arp timer aging
ARP Commands
1-8
arp timer gratuitous-updating
ARP Commands
1-8
asbr-summary
3-3
ascii
FTP and TFTP Commands
1-4
attack-protection
Telnet Protection Commands
1-1
attack-protection disable-defaultroute
1-2
attack-protection icmp
1-2
attack-protection snmp
1-3
attack-protection telnet
1-4
attribute
1-2
authentication-mode
Login Commands
1-1
authentication-mode
3-4
auto-build
Cluster Commands
1-16
auto-execute command
Login Commands
1-2
B
balance
5-3
bgp
5-3
binary
1-5
boot boot-loader
System Maintenance and Debugging Commands
3-1
boot boot-loader primary
Hardware-Dependent Software Configuration Commands
1-2
boot bootrom
3-2
boot bootrom default
3-2
1-1
boot bootrom file-url
1-1
bootrom-update security-check enable
3-3
bridgemactocpu
MAC Address Table Commands
1-1
broadcast-suppression
VLAN Commands
1-1
Port Basic Configuration Commands
1-1
bsr-policy
Multicast Commands
6-1
build
Cluster Commands
1-17
bye
SSH Terminal Service Commands
1-26
bye
1-5
C
c-bsr
Multicast Commands
6-2
cd
1-27
cd
File System Management Commands
1-1
cd
1-6
cdup
1-28
cdup
1-7
check region-configuration
MSTP Commands
1-2
checkzero
2-1
clock datetime
1-1
clock summer-time
1-1
clock timezone
1-3
close
1-8
cluster
Cluster Commands
1-18
cluster enable
Cluster Commands
1-19
cluster switch-to
Cluster Commands
1-20
command-privilege level
CLI Commands
1-1
compare-different-as-med
5-4
confederation id
5-5
confederation nonstandard
5-6
confederation peer-as
5-7
control-vlan
RRPP Commands
1-1
copy
1-2
copy configuration
1-2
cost-style
4-2
count
HWPing Commands
1-1
c-rp
Multicast Commands
6-3
crp-policy
Multicast Commands
6-4
cut connection
1-3
D
dampening
5-7
databits
Login Commands
1-3
data-flow-format
1-26
data-flow-format
1-53
debugging
1-9
debugging
1-10
debugging traffic-accounting event
1-2
default cost
2-2
default cost
3-5
default interval
3-5
default limit
3-6
default local-preference
5-9
default med
5-9
default tag
3-7
default type
3-8
default-cost
3-8
default-route-advertise
3-9
4-3
delete
1-28
delete
1-3
delete
1-9
delete static-routes all
1-14
delete-member
Cluster Commands
1-21
description
VLAN Commands
1-2
description
1-3
description
Port Isolation Commands
1-1
destination-ip
HWPing Commands
1-1
dhcp enable
DHCP Commands
1-1
dhcp relay information enable
DHCP Commands
2-3
dhcp relay information strategy
DHCP Commands
2-4
dhcp select global
DHCP Commands
1-1
dhcp select interface
DHCP Commands
1-2
dhcp server detect
DHCP Commands
1-3
dhcp server dns-list
DHCP Commands
1-4
dhcp server domain-name
DHCP Commands
1-5
dhcp server expired
DHCP Commands
1-6
dhcp server forbidden-ip
DHCP Commands
1-7
dhcp server ip-pool
DHCP Commands
1-8
dhcp server nbns-list
DHCP Commands
1-9
dhcp server netbios-type
DHCP Commands
1-10
dhcp server option
DHCP Commands
1-11
dhcp server ping
DHCP Commands
1-12
dhcp server static-bind
DHCP Commands
1-13
dhcp-security static
DHCP Commands
2-4
dhcp-server
Extended VLAN Application Commands
3-1
dhcp-server
DHCP Commands
2-5
dhcp-server ip
DHCP Commands
2-6
dhcp-snooping
DHCP Commands
3-1
dhcp-snooping information enable
DHCP Commands
3-2
dhcp-snooping trust
DHCP Commands
3-1
dir
1-29
dir
1-4
dir
1-10
disconnect
1-12
display acl config
ACL Commands
1-4
display acl config statistics
ACL Commands
1-5
display acl mode
ACL Commands
1-5
display acl order
ACL Commands
1-6
display acl remaining entry
ACL Commands
1-6
display acl running-packet-filter
ACL Commands
1-8
display am user-bind
1-3
display arp
ARP Commands
1-9
display arp |
ARP Commands
1-10
display arp attack-list
ARP Commands
1-11
display arp entry-limit
ARP Commands
1-12
display arp interface
ARP Commands
1-13
display arp proxy
ARP Commands
1-13
display arp slot
ARP Commands
1-14
display arp source-suppression
ARP Commands
1-14
display arp timer aging
ARP Commands
1-15
display arp vlan
ARP Commands
1-15
display bgp group
5-10
display bgp network
5-11
display bgp paths
5-12
display bgp peer
5-13
display bgp routing-table
5-14
display bgp routing-table as-path-acl
5-16
display bgp routing-table cidr
5-17
display bgp routing-table community
5-18
display bgp routing-table community-list
5-19
display bgp routing-table dampened
5-20
display bgp routing-table different-origin-as
5-21
display bgp routing-table flap-info
5-22
display bgp routing-table peer
5-24
display bgp routing-table regular-expression
5-25
display bgp routing-table statistic
5-25
display boot-loader
3-3
display brief interface
1-4
display channel
Information Center Commands
1-1
display clock
1-7
display cluster
Cluster Commands
1-21
display cluster candidates
Cluster Commands
1-23
display cluster members
Cluster Commands
1-24
display connection
1-4
display cpu
3-4
display current-configuration
Configuration File Management Commands
1-1
display debugging
1-7
display device
3-5
display dhcp server conflict
DHCP Commands
1-14
display dhcp server expired
DHCP Commands
1-15
display dhcp server free-ip
DHCP Commands
1-16
display dhcp server ip-in-use
DHCP Commands
1-17
display dhcp server statistics
DHCP Commands
1-18
display dhcp server tree
DHCP Commands
1-20
display dhcp-security
DHCP Commands
2-7
display dhcp-server
DHCP Commands
2-7
display dhcp-server interface
DHCP Commands
2-9
display dhcp-snooping
DHCP Commands
3-3
display dhcp-snooping count
DHCP Commands
3-4
display dhcp-snooping trust
DHCP Commands
3-4
display dhcp-snooping vlan
DHCP Commands
3-5
display diagnostic-information
1-11
display dldp
DLDP Commands
1-1
display dns domain
DNS Commands
1-1
display dns dynamic-host
DNS Commands
1-1
display dns server
DNS Commands
1-2
display domain
1-5
display dot1x
802.1x Commands
1-1
display environment
3-6
display fan
3-6
display fib
IP Address-IP Performance-IPX Commands
2-1
display ftp-server
1-1
display ftp-user
1-2
display garp statistics
GVRP Commands
1-1
display garp timer
GVRP Commands
1-2
display gmrp statistics
Multicast Commands
1-1
display gmrp status
Multicast Commands
1-2
display gvrp statistics
GVRP Commands
1-6
display gvrp status
GVRP Commands
1-7
display habp
802.1x Commands
2-1
display habp table
802.1x Commands
2-2
display habp traffic
802.1x Commands
2-2
display history-command
CLI Commands
1-2
display hwping
HWPing Commands
1-2
display hwtacacs
1-54
display icmp statistics
2-3
display igmp group
Multicast Commands
5-1
display igmp interface
Multicast Commands
5-2
display igmp-snooping configuration
Multicast Commands
2-1
display igmp-snooping group
Multicast Commands
2-2
display igmp-snooping statistics
Multicast Commands
2-3
display info-center
1-1
display interface
1-5
display interface Vlan-interface
VLAN Commands
1-3
display ip host
DNS Commands
1-3
display ip interface
1-1
display ip ip-prefix
6-8
display ip netstream cache
NAT-Netstream-Policy Routing Commands
2-1
display ip netstream export
2-2
display ip routing-table
1-1
display ip routing-table acl
1-2
display ip routing-table ip-address
1-5
display ip routing-table ip-address1 ip-address2
1-7
display ip routing-table ip-prefix
1-8
display ip routing-table protocol
1-9
display ip routing-table radix
1-11
display ip routing-table statistics
1-12
display ip routing-table verbose
1-13
display ip socket
2-4
display ip statistics
2-6
display ip userlog export
1-21
display ipx interface
3-1
display ipx routing-table
3-3
display ipx service-table
3-5
display ipx statistics
3-7
display isis brief
4-4
display isis interface
4-5
display isis lsdb
4-6
display isis mesh-group
4-6
display isis peer
4-7
display isis route
4-8
display isis spf-log
4-9
display isolate port
1-1
display isolate-user-vlan
2-1
display lacp system-id
Link Aggregation Commands
1-1
display link-aggregation interface
1-1
display link-aggregation summary
1-3
display link-aggregation verbose
1-4
display local-server statistics
1-27
display local-user
1-7
display logbuffer
1-3
display logbuffer summary
1-5
display loopback-detection
1-8
display mac-address
1-2
display mac-address aging-time
1-2
display mac-address multicast
Multicast Commands
4-1
display memory
7-1
display memory
3-7
display memory limit
7-2
display mirroring-group
Mirroring Commands
1-1
display mpm forwarding-table
Multicast Commands
3-1
display mpm group
Multicast Commands
3-2
display multicast forwarding-table
Multicast Commands
3-4
display multicast routing-table
Multicast Commands
3-5
display multicast-source-deny
Multicast Commands
3-7
display multicast-vlan
Multicast Commands
2-4
display nat address-group
1-1
display nat aging-time
1-1
display nat all
1-2
display nat blacklist
1-3
display nat outbound
1-4
display nat server
1-5
display nat statistics
1-6
display ndp
Cluster Commands
1-1
display ntdp
Cluster Commands
1-6
display ntdp device-list
Cluster Commands
1-7
display ntp-service sessions
NTP Commands
1-1
display ntp-service status
NTP Commands
1-2
display ntp-service trace
NTP Commands
1-3
display ospf abr-asbr
3-10
display ospf asbr-summary
3-11
display ospf brief
3-13
display ospf cumulative
3-14
display ospf error
3-16
display ospf interface
3-19
display ospf lsdb
3-20
display ospf nexthop
3-23
display ospf peer
3-24
display ospf request-queue
3-26
display ospf retrans-queue
3-27
display ospf routing
3-28
display ospf vlink
3-29
display pim bsr-info
Multicast Commands
6-5
display pim interface
Multicast Commands
6-6
display pim neighbor
Multicast Commands
6-7
display pim routing-table
Multicast Commands
6-8
display pim rp-info
Multicast Commands
6-10
display poe interface
PoE Commands
1-1
display poe interface power
PoE Commands
1-3
display poe powersupply
PoE Commands
1-5
display poe pse
PoE Commands
1-6
display poe-power ac-input state
PoE Commands
2-1
display poe-power alarm
PoE Commands
2-2
display poe-power dc-output state
PoE Commands
2-3
display poe-power dc-output value
PoE Commands
2-4
display poe-power switch state
PoE Commands
2-5
display port
1-9
display port vlan-vpn
QinQ Commands
1-1
display power
3-8
display priority-trust
QoS Commands
1-1
display protocol-vlan interface
VLAN Commands
1-14
display protocol-vlan slot
VLAN Commands
1-15
display protocol-vlan vlan
VLAN Commands
1-16
display qos cos-local-precedence-map
QoS Commands
1-2
display qos-interface all
QoS Commands
1-2
display qos-interface line-rate
QoS Commands
1-3
display qos-interface mirrored-to
Mirroring Commands
1-2
display qos-interface queue-scheduler
QoS Commands
1-4
display qos-interface traffic-bandwidth
QoS Commands
1-5
display qos-interface traffic-limit
QoS Commands
1-6
display qos-interface traffic-priority
QoS Commands
1-7
display qos-interface traffic-red
QoS Commands
1-7
display qos-interface traffic-redirect
QoS Commands
1-8
display qos-interface traffic-remark-vlanid
QoS Commands
1-8
display qos-interface traffic-statistic
QoS Commands
1-9
display qos-vlan traffic-redirect
3-1
display radius
1-27
display radius statistics
1-29
display rip
2-2
display rip routing
2-3
display rmon alarm
SNMP-RMON Commands
2-1
display rmon event
SNMP-RMON Commands
2-2
display rmon eventlog
SNMP-RMON Commands
2-3
display rmon history
SNMP-RMON Commands
2-4
display rmon prialarm
SNMP-RMON Commands
2-6
display rmon statistics
SNMP-RMON Commands
2-7
display route-policy
6-9
display rrpp brief
RRPP Commands
1-2
display rrpp statistics
RRPP Commands
1-3
display rrpp verbose
RRPP Commands
1-4
display rsa local-key-pair public
1-1
display rsa peer-public-key
1-2
display saved-configuration
1-6
display schedule reboot
3-9
display snmp-agent
SNMP-RMON Commands
1-1
display snmp-agent community
SNMP-RMON Commands
1-1
display snmp-agent group
SNMP-RMON Commands
1-2
display snmp-agent mib-view
SNMP-RMON Commands
1-3
display snmp-agent statistics
SNMP-RMON Commands
1-5
display snmp-agent sys-info
SNMP-RMON Commands
1-6
display snmp-agent usm-user
SNMP-RMON Commands
1-7
display ssh server
1-3
display ssh server-info
1-18
display ssh user-information
1-5
display startup
1-9
display stop-accounting-buffer
1-30
1-55
display stp
MSTP Commands
1-3
display stp region-configuration
MSTP Commands
1-5
display supervision-module information
PoE Commands
2-5
display supervlan
3-1
display switchover state
VRRP-HA Commands
2-1
display tcp statistics
2-7
display tcp status
2-10
display this
1-8
display time-range
ACL Commands
1-8
display traffic-accounting accounting-slot
1-3
display traffic-accounting statistics
1-4
display traffic-accounting traffic-group
1-4
display transceiver-information interface
1-9
display trapbuffer
1-5
display udp statistics
2-11
display udp-helper server
UDP-Helper Commands
1-1
display uplink monitor
3-9
display user-interface
Login Commands
1-3
display users
Login Commands
1-5
display users
1-8
display version
1-9
display vlan
VLAN Commands
1-4
display vlan
1-3
display voice vlan oui
1-1
display voice vlan status
1-1
display vrrp
VRRP-HA Commands
1-1
dldp
DLDP Commands
1-2
dldp authentication-mode
DLDP Commands
1-3
dldp delaydown-timer
DLDP Commands
1-7
dldp interval
DLDP Commands
1-4
dldp reset
DLDP Commands
1-5
dldp unidirectional-shutdown
DLDP Commands
1-6
dldp work-mode
DLDP Commands
1-7
dns domain
DNS Commands
1-4
dns resolve
DNS Commands
1-5
dns server
DNS Commands
1-6
dns-list
DHCP Commands
1-22
domain
1-9
domain-authentication-mode
4-10
domain-name
DHCP Commands
1-23
dot1x
802.1x Commands
1-4
dot1x authentication-method
802.1x Commands
1-6
dot1x dhcp-launch
802.1x Commands
1-7
dot1x guest-vlan
802.1x Commands
1-7
dot1x max-user
802.1x Commands
1-9
dot1x port-control
802.1x Commands
1-10
dot1x port-method
802.1x Commands
1-11
dot1x quiet-period
802.1x Commands
1-12
dot1x re-authenticate
802.1x Commands
1-13
dot1x retry
802.1x Commands
1-14
dot1x retry-version-max
802.1x Commands
1-14
dot1x supp-proxy-check
802.1x Commands
1-15
dot1x timer
802.1x Commands
1-17
dot1x version-check
802.1x Commands
1-19
duplex
1-10
E
enable
2-3
enable snmp trap updown
SNMP-RMON Commands
1-8
execute
1-5
exit
1-30
expired
DHCP Commands
1-23
F
file prompt
1-6
filter-policy export
2-5
3-30
4-11
5-26
filter-policy import
2-6
3-31
4-12
5-27
fixdisk
1-7
flow interval
1-13
flow-control
Login Commands
1-6
flow-control
1-11
flow-control enable
1-12
format
1-7
free user-interface
Login Commands
1-7
frequency
HWPing Commands
1-5
ftp
1-12
ftp cluster
Cluster Commands
1-27
ftp server enable
1-2
ftp timeout
1-3
ftp-server
Cluster Commands
1-28
G
garp timer
GVRP Commands
1-2
garp timer leaveall
GVRP Commands
1-4
gateway-list
DHCP Commands
1-24
get
1-30
get
1-13
gmrp
Multicast Commands
1-2
gratuitous-arp-learning enable
ARP Commands
1-16
group
5-28
gvrp
GVRP Commands
1-7
gvrp registration
GVRP Commands
1-8
H
habp enable
802.1x Commands
2-3
habp server vlan
802.1x Commands
2-4
habp timer
802.1x Commands
2-5
hardspeedup
1-13
header
Login Commands
1-8
help
1-31
history-command max-size
Login Commands
1-10
holdtime
Cluster Commands
1-28
host-route
2-7
hwping
HWPing Commands
1-6
hwping-agent enable
HWPing Commands
1-7
hwtacacs nas-ip
1-56
hwtacacs scheme
1-57
I
idle-cut
1-10
idle-timeout
Login Commands
1-11
if-match { acl | ip-prefix }
6-10
if-match as-path
6-10
if-match community
6-11
if-match cost
6-12
if-match interface
6-13
if-match ip next-hop
6-14
if-match tag
6-15
igmp enable
Multicast Commands
5-3
igmp group-limit
Multicast Commands
5-4
igmp group-policy
Multicast Commands
5-5
igmp group-policy vlan
Multicast Commands
5-6
igmp host-join port
Multicast Commands
5-7
igmp host-join vlan
Multicast Commands
5-8
igmp lastmember-queryinterval
Multicast Commands
5-9
igmp max-response-time
Multicast Commands
5-10
igmp proxy
Multicast Commands
5-11
igmp report-aggregation
Multicast Commands
5-12
igmp robust-count
Multicast Commands
5-13
igmp timer other-querier-present
Multicast Commands
5-14
igmp timer query
Multicast Commands
5-15
igmp version
Multicast Commands
5-16
igmp-snooping
Multicast Commands
2-4
igmp-snooping fast-leave
Multicast Commands
2-5
igmp-snooping group-limit
Multicast Commands
2-6
igmp-snooping group-policy
Multicast Commands
2-7
igmp-snooping host-aging-time
Multicast Commands
2-9
igmp-snooping max-response-time
Multicast Commands
2-10
igmp-snooping report-aggregation
Multicast Commands
2-10
igmp-snooping router-aging-time
Multicast Commands
2-11
ignore-lsp-checksum-error
4-13
import-route
2-8
import-route
3-32
import-route
4-14
import-route
5-29
import-route isis level-2 into level-1
4-15
inboundcar
QoS Commands
1-10
info-center channel
1-6
info-center console channel
1-7
info-center enable
1-8
info-center logbuffer
1-9
info-center loghost
1-10
info-center loghost source
1-11
info-center monitor channel
1-12
info-center snmp channel
1-12
info-center source
1-13
info-center timestamp
1-19
info-center trapbuffer
1-20
instance
MSTP Commands
1-6
interface
1-14
VLAN Commands
1-6
ip
2-12
ip address
1-3
ip address
Cluster Commands
1-29
ip as-path-acl
6-15
ip community-list
6-16
ip forward-broadcast
2-13
ip host
DNS Commands
1-6
ip ip-prefix
6-17
ip netstream aggregation
2-4
ip netstream export dscp
2-5
ip netstream export host
2-6
ip netstream export source
2-7
ip netstream export version
2-7
ip netstream inbound source
2-8
ip netstream outbound source
2-9
ip netstream template refresh
2-10
ip netstream template timeout
2-10
ip netstream timeout active
2-11
ip netstream timeout inactive
2-12
ip route-static
1-15
ip route-static default-preference
1-16
ip userlog nat active-time
1-23
ip userlog nat export host
1-23
ip userlog nat export source-ip
1-24
ip userlog nat export version
1-25
ip userlog nat mode flow-begin
1-26
ip userlog nat slot
1-22
ip-pool
Cluster Commands
1-30
ipx enable
3-9
ipx encapsulation
3-10
ipx netbios-propagation
3-10
ipx network
3-11
ipx rip import-route static
3-12
ipx rip mtu
3-12
ipx rip multiplier
3-13
ipx rip timer update
3-14
ipx route load-balance-path
3-14
ipx route max-reserve-path
3-15
ipx route-static
3-16
ipx sap disable
3-17
ipx sap gns-disable-reply
3-17
ipx sap gns-load-balance
3-18
ipx sap max-reserve-servers
3-19
ipx sap mtu
3-19
ipx sap multiplier
3-20
ipx sap timer update
3-21
ipx service
3-21
ipx split-horizon
3-23
ipx tick
3-23
ipx update-change-only
3-24
isis
4-16
isis authentication-mode
4-17
isis circuit-level
4-18
isis cost
4-19
isis dis-priority
4-20
isis enable
4-20
isis mesh-group
4-21
isis timer csnp
4-22
isis timer hello
4-23
isis timer holding-multiplier
4-24
isis timer lsp
4-25
isis timer retransmit
4-26
is-level
4-26
isolate-user-vlan
2-2
isolate-user-vlan enable
2-3
J
jumboframe enable
1-15
K
key
1-32
key
1-58
L
lacp enable
1-6
lacp port-priority
1-6
lacp system-priority
1-7
language-mode
1-4
lcd
1-14
level
1-11
line-rate
QoS Commands
1-11
link-aggregation
1-7
link-aggregation group description
1-8
link-aggregation group mode
1-9
loadsharing enable
3-10
local-server
1-33
local-user
1-12
local-user password-display-mode
1-13
lock
Login Commands
1-12
logging-host
Cluster Commands
1-31
log-peer-change
4-27
loopback-detection enable
1-16
loopback-detection interval-time
1-17
ls
1-31
ls
1-15
M
mac-address
1-4
mac-address learning synchronization
1-6
mac-address mac-learning disable
1-6
mac-address max-mac-count
1-7
mac-address multicast interface
Multicast Commands
4-1
mac-address timer
1-8
md5-compatible
4-28
mdi
1-17
memory { safety | limit }*
7-5
memory auto-establish disable
7-3
memory auto-establish enable
7-4
messenger
1-14
mirrored-to
Mirroring Commands
1-3
mirroring-group
Mirroring Commands
1-6
mirroring-group (only for Recovery)
Mirroring Commands
1-6
mirroring-group mirroring-port
Mirroring Commands
1-7
mirroring-group monitor-port
Mirroring Commands
1-8
mirroring-group reflector-port
Mirroring Commands
1-9
mirroring-group remote-probe vlan
Mirroring Commands
1-10
mkdir
1-32
mkdir
1-8
mkdir
1-16
modem
Login Commands
1-12
modem auto-answer
Login Commands
1-13
modem timer answer
Login Commands
1-14
monitor inner-channel
1-3
1-4
monitor slot
1-5
more
1-8
move
1-9
multicast route-limit
Multicast Commands
3-8
multicast routing-enable
Multicast Commands
3-9
multicast static-router-port
Multicast Commands
3-9
multicast static-router-port vlan
Multicast Commands
3-10
multicast wrongif-holdtime
Multicast Commands
3-11
Multicast Commands
3-12
multicast-suppression
1-18
multicast-vlan enable
Multicast Commands
2-12
multicast-vlan subvlan
Multicast Commands
2-13
N
name
VLAN Commands
1-6
name
1-15
nas-ip
1-34
nas-ip
1-59
nat address-group
1-6
nat aging-time
1-7
nat blacklist limit amount
1-10
nat blacklist limit rate
1-11
nat blacklist limit rate source
1-13
nat blacklist mode
1-8
nat blacklist start
1-8
nat ftp server
1-20
nat outbound
1-14
nat server
1-16
nbns-list
DHCP Commands
1-25
ndp enable
Cluster Commands
1-3
ndp timer aging
Cluster Commands
1-4
ndp timer hello
Cluster Commands
1-5
netbios-type
DHCP Commands
1-26
network
2-9
network
3-34
network
5-30
network
1-5
network
DHCP Commands
1-27
network-entity
4-29
nssa
3-35
ntdp enable
Cluster Commands
1-9
ntdp explore
Cluster Commands
1-10
ntdp hop
Cluster Commands
1-11
ntdp timer
Cluster Commands
1-12
ntdp timer hop-delay
Cluster Commands
1-13
ntdp timer port-delay
Cluster Commands
1-13
ntp-service access
NTP Commands
1-4
ntp-service authentication enable
NTP Commands
1-5
ntp-service authentication-keyid
NTP Commands
1-5
ntp-service broadcast-client
NTP Commands
1-6
ntp-service broadcast-server
NTP Commands
1-7
ntp-service disable
NTP Commands
1-8
ntp-service in-interface disable
NTP Commands
1-8
ntp-service max-dynamic-sessions
NTP Commands
1-9
ntp-service multicast-client
NTP Commands
1-10
ntp-service multicast-server
NTP Commands
1-10
ntp-service refclock-master
NTP Commands
1-11
ntp-service reliable authentication-keyid
NTP Commands
1-12
ntp-service source-interface
NTP Commands
1-13
ntp-service unicast-peer
NTP Commands
1-14
ntp-service unicast-server
NTP Commands
1-15
O
open
1-17
option
DHCP Commands
1-27
ospf
3-36
ospf authentication-mode
3-37
ospf cost
3-38
ospf dr-priority
3-38
ospf mib-binding
3-39
ospf mtu-enable
3-40
ospf network-type
3-40
ospf timer dead
3-42
ospf timer hello
3-43
ospf timer poll
3-43
ospf timer retransmit
3-44
ospf trans-delay
3-45
P
packet-filter
ACL Commands
1-10
parity
Login Commands
1-14
passive
1-18
password
1-15
pause-protection
3-11
peer
2-10
peer
3-45
peer advertise-community
5-30
peer allow-as-loop
5-31
peer as-number
5-32
peer as-path-acl export
5-32
peer as-path-acl import
5-33
peer connect-interface
5-34
peer default-route-advertise
5-35
peer description
5-35
peer ebgp-max-hop
5-36
peer enable
5-37
peer filter-policy export
5-38
peer filter-policy import
5-39
peer group
5-39
peer ip-prefix export
5-40
peer ip-prefix import
5-41
peer next-hop-local
5-42
peer password
5-42
peer public-as-only
5-43
peer reflect-client
5-44
peer route-policy export
5-45
peer route-policy import
5-46
peer route-update-interval
5-46
peer timer
5-47
peer-public-key end
1-5
pim
Multicast Commands
6-11
pim bsr-boundary
Multicast Commands
6-11
pim dm
Multicast Commands
6-12
pim neighbor-limit
Multicast Commands
6-13
pim neighbor-policy
Multicast Commands
6-14
pim sm
Multicast Commands
6-14
pim timer hello
Multicast Commands
6-15
ping
2-1
poe enable
PoE Commands
1-7
poe enable slot
PoE Commands
1-8
poe legacy enable slot
PoE Commands
1-9
poe max-power
PoE Commands
1-10
poe max-power slot
PoE Commands
1-10
poe mode
PoE Commands
1-11
poe power max-value
PoE Commands
1-12
poe power-management
PoE Commands
1-12
poe priority
PoE Commands
1-13
poe upgrade
PoE Commands
1-14
poe-power input-thresh lower
PoE Commands
2-7
poe-power input-thresh upper
PoE Commands
2-7
poe-power output-thresh lower
PoE Commands
2-8
poe-power output-thresh upper
PoE Commands
2-9
port
VLAN Commands
1-9
port
1-2
port access vlan
VLAN Commands
1-10
port hybrid protocol-vlan vlan
VLAN Commands
1-17
port hybrid pvid vlan
VLAN Commands
1-10
port hybrid vlan
VLAN Commands
1-11
port isolate group
1-3
port link-aggregation group
1-10
port link-type
VLAN Commands
1-12
port trunk permit vlan
VLAN Commands
1-13
port trunk pvid vlan
VLAN Commands
1-14
port-isolate group
1-4
preference
2-11
preference
3-46
preference
4-30
preference
5-48
primary accounting
1-35
primary accounting
1-60
primary authentication
1-36
1-60
primary authorization
1-61
priority
QoS Commands
1-12
priority trust
QoS Commands
1-12
protocol inbound
Login Commands
1-15
protocol inbound
1-6
protocol multicast-mac enable
3-47
protocol-vlan
VLAN Commands
1-19
protocol-vlan vlan slot
VLAN Commands
1-18
public-key-code begin
1-7
1-19
public-key-code end
1-8
public-key-code end
1-20
put
1-33
put
1-19
pwd
1-33
pwd
1-10
pwd
1-20
Q
qe monitor
3-12
qe monitor errpkt
3-12
qe monitor errpkt check-time
3-13
qe monitor overflow-threshold
3-14
qos
QoS Commands
1-14
QoS Commands
1-16
queue-scheduler
QoS Commands
1-18
1-20
1-34
1-20
1-4
R
radius nas-ip
1-37
radius scheme
1-38
radius-scheme
1-16
raw-vlan-id inbound
QinQ Commands
2-1
rdram
3-14
reboot
3-15
reboot member
Cluster Commands
1-32
reflect between-clients
5-49
reflector cluster-id
5-49
refresh bgp
5-50
region-name
MSTP Commands
1-7
register-policy
Multicast Commands
6-16
remotehelp
1-21
remote-probe vlan
Mirroring Commands
1-10
remove
1-34
rename
1-35
rename
1-11
reset
2-12
reset acl counter
ACL Commands
1-12
reset arp
ARP Commands
1-17
reset arp attack-list
ARP Commands
1-17
reset bgp
5-51
reset bgp dampening
5-52
reset bgp flap-info
5-52
reset bgp group
5-53
reset counters interface
1-20
reset dhcp server conflict
DHCP Commands
1-28
reset dhcp server ip-in-use
DHCP Commands
1-29
reset dhcp server statistics
DHCP Commands
1-30
reset dhcp-server
DHCP Commands
2-10
reset dhcp-snooping
DHCP Commands
3-5
reset dns dynamic-host
DNS Commands
1-7
reset dot1x statistics
802.1x Commands
1-20
reset garp statistics
GVRP Commands
1-5
reset hwtacacs statistics
1-62
reset igmp group
Multicast Commands
5-16
reset igmp-snooping statistics
Multicast Commands
2-14
reset ip netstream statistics
2-13
reset ip statistics
2-13
reset ipx routing-table statistics protocol
3-24
reset ipx statistics
3-25
reset isis all
4-30
reset isis peer
4-31
reset lacp statistics
1-10
reset logbuffer
1-21
reset multicast forwarding-table
Multicast Commands
3-13
reset multicast routing-table
Multicast Commands
3-14
reset nat
1-19
reset ndp statistics
Cluster Commands
1-6
reset ospf
3-48
reset pim neighbor
Multicast Commands
6-17
reset pim routing-table
Multicast Commands
6-17
reset radius statistics
1-39
reset recycle-bin
1-12
reset rrpp statistics
RRPP Commands
1-6
reset saved-configuration
1-10
reset stop-accounting-buffer
1-39
1-63
reset stp
MSTP Commands
1-7
reset tcp statistics
2-14
reset traffic-statistic
QoS Commands
1-19
reset trapbuffer
1-21
reset udp statistics
2-14
reset udp-helper packet
UDP-Helper Commands
1-1
reset vrrp statistics
VRRP-HA Commands
1-3
retry
1-41
retry realtime-accounting
1-42
retry stop-accounting
1-43
1-64
return
1-5
revision-level
MSTP Commands
1-8
ring
RRPP Commands
1-6
ring enable
RRPP Commands
1-9
rip
2-12
rip authentication-mode
2-13
rip input
2-14
rip metricin
2-15
rip metricout
2-16
rip output
2-17
rip split-horizon
2-17
rip version
2-18
rip work
2-19
rmdir
1-35
rmdir
1-13
rmdir
1-22
rmon alarm
SNMP-RMON Commands
2-9
rmon event
SNMP-RMON Commands
2-11
rmon history
SNMP-RMON Commands
2-12
rmon prialarm
SNMP-RMON Commands
2-13
rmon statistics
SNMP-RMON Commands
2-15
route-policy
6-18
router id
3-49
router id
5-53
rrpp domain
RRPP Commands
1-10
rrpp enable
RRPP Commands
1-11
rsa local-key-pair create
1-9
rsa local-key-pair destroy
1-10
rsa peer-public-key
1-11
rsa peer-public-key
1-21
rule (Advanced ACL)
ACL Commands
1-15
rule (Basic ACL)
ACL Commands
1-13
rule (Layer 2 ACL)
ACL Commands
1-21
rule (user-defined ACL)
ACL Commands
1-24
S
save
1-11
schedule reboot at
3-15
schedule reboot delay
3-17
scheme
1-17
screen-length
Login Commands
1-16
secondary accounting
1-44
1-65
secondary authentication
1-45
1-65
secondary authorization
1-66
security-policy-server
2-1
self-service-url
1-18
send
Login Commands
1-16
server-type
1-45
service-type
Login Commands
1-17
service-type
1-19
set authentication password
Login Commands
1-19
set inlink
1-2
set-overload
4-31
sftp
1-36
sftp server enable
1-25
shell
Login Commands
1-20
shutdown
VLAN Commands
1-7
shutdown
1-20
silent-interface
3-49
silent-interface
4-32
slave auto-update config
VRRP-HA Commands
2-1
slave restart
VRRP-HA Commands
2-2
slave switchover
VRRP-HA Commands
2-2
slave update configuration
VRRP-HA Commands
2-3
snmp-agent
SNMP-RMON Commands
1-9
Login Commands
2-1
SNMP-RMON Commands
1-10
snmp-agent group
Login Commands
2-2
snmp-agent group
SNMP-RMON Commands
1-11
snmp-agent local-engineid
SNMP-RMON Commands
1-12
snmp-agent mib-view
SNMP-RMON Commands
1-12
snmp-agent packet max-size
SNMP-RMON Commands
1-13
snmp-agent sys-info
SNMP-RMON Commands
1-14
snmp-agent target-host
SNMP-RMON Commands
1-15
snmp-agent trap enable
SNMP-RMON Commands
1-16
snmp-agent trap enable ospf
3-50
snmp-agent trap life
SNMP-RMON Commands
1-18
snmp-agent trap queue-size
SNMP-RMON Commands
1-18
snmp-agent trap source
SNMP-RMON Commands
1-19
snmp-agent usm-user
Login Commands
2-4
snmp-agent usm-user
SNMP-RMON Commands
1-20
snmp-host
Cluster Commands
1-32
source-policy
Multicast Commands
6-19
speed
Login Commands
1-21
speed
1-21
speedup
1-22
spf-delay-interval
4-33
spf-schedule-interval
3-51
spf-slice-size
4-34
ssh authentication-type default
1-11
ssh client assign rsa-key
1-22
ssh client first-time enable
1-22
ssh server authentication-retries
1-12
ssh server compatible-ssh1x enable
1-13
ssh server rekey-interval
1-14
ssh server timeout
1-15
ssh user
1-15
ssh user assign rsa-key
1-16
ssh user authentication-type
1-17
ssh user service-type
1-26
ssh2
1-23
startup saved-configuration
1-12
state
1-20
state
1-46
static-bind ip-address
DHCP Commands
1-30
static-bind mac-address
DHCP Commands
1-31
static-rp
Multicast Commands
6-20
stop-accounting-buffer enable
1-47
1-67
stopbits
Login Commands
1-21
stp
MSTP Commands
1-9
stp bpdu-protection
MSTP Commands
1-10
stp bridge-diameter
MSTP Commands
1-11
stp config-digest-snooping
MSTP Commands
1-12
stp cost
MSTP Commands
1-13
stp edged-port
MSTP Commands
1-14
stp interface
MSTP Commands
1-15
stp interface config-digest-snooping
MSTP Commands
1-16
stp interface cost
MSTP Commands
1-18
stp interface edged-port
MSTP Commands
1-19
stp interface loop-protection
MSTP Commands
1-20
stp interface mcheck
MSTP Commands
1-21
stp interface no-agreement-check
MSTP Commands
1-22
stp interface point-to-point
MSTP Commands
1-23
stp interface port priority
MSTP Commands
1-24
stp interface root-protection
MSTP Commands
1-25
stp interface transmit-limit
MSTP Commands
1-27
stp loop-protection
MSTP Commands
1-27
stp max-hops
MSTP Commands
1-28
stp mcheck
MSTP Commands
1-29
stp mode
MSTP Commands
1-30
stp no-agreement-check
MSTP Commands
1-31
stp pathcost-standard
MSTP Commands
1-32
stp point-to-point
MSTP Commands
1-34
stp port priority
MSTP Commands
1-35
stp priority
MSTP Commands
1-36
MSTP Commands
1-37
stp root primary
MSTP Commands
1-38
stp root secondary
MSTP Commands
1-39
stp root-protection
MSTP Commands
1-40
stp tc-protection
MSTP Commands
1-41
stp timer forward-delay
MSTP Commands
1-42
stp timer hello
MSTP Commands
1-43
stp timer max-age
MSTP Commands
1-44
stp timer-factor
MSTP Commands
1-45
stp transmit-limit
MSTP Commands
1-46
stub
3-52
subvlan
3-3
summary
2-20
summary
4-34
summary
5-54
super
CLI Commands
1-2
super password
CLI Commands
1-3
supervlan
3-4
sysname
Login Commands
1-22
sysname
1-5
1-6
T
tcp timer fin-timeout
2-15
tcp timer syn-timeout
2-15
tcp window
2-16
telnet
Login Commands
1-23
temperature-limit
3-18
terminal debugging
1-21
terminal debugging
1-12
terminal logging
1-22
terminal monitor
1-23
terminal trapping
1-23
test-enable
HWPing Commands
1-8
test-type
HWPing Commands
1-7
tftp get
Cluster Commands
1-33
tftp get
1-25
tftp put
Cluster Commands
1-34
tftp put
1-25
tftp-server
Cluster Commands
1-35
tftp-server acl
1-26
timeout
HWPing Commands
1-8
timer
5-54
timer
1-48
timer
Cluster Commands
1-35
timer
RRPP Commands
1-11
timer lsp-max-age
4-35
timer lsp-refresh
4-36
timer quiet
1-49
timer quiet
1-68
timer realtime-accounting
1-50
1-69
timer response-timeout
1-51
1-70
timer spf
4-37
time-range
ACL Commands
1-26
timers
2-21
tracert
2-3
1-6
1-7
traffic-bandwidth
QoS Commands
1-22
traffic-group
1-8
traffic-limit
QoS Commands
1-24
traffic-priority
QoS Commands
1-26
traffic-red
QoS Commands
1-30
traffic-redirect
QoS Commands
1-31
traffic-redirect inbound ip-group
3-2
traffic-redirect outbound ip-group
3-4
QoS Commands
1-33
traffic-share-across-interface
2-22
traffic-slot
1-8
traffic-statistic
QoS Commands
1-36
U
udp-helper enable
UDP-Helper Commands
1-2
udp-helper port
UDP-Helper Commands
1-2
udp-helper server
UDP-Helper Commands
1-4
umount
1-14
undelete
1-14
undo synchronization
5-55
uplink monitor
3-19
user
1-23
user privilege level
Login Commands
1-24
user-interface
Login Commands
1-24
user-name-format
1-52
user-name-format
1-71
V
verbose
1-24
virtual-cable-test
1-22
vlan
VLAN Commands
1-8
vlan-assignment-mode
1-21
vlan-mapping modulo
MSTP Commands
1-46
vlan-vpn enable
QinQ Commands
1-1
vlan-vpn tunnel
MSTP Commands
1-47
vlan-vpn vid
QinQ Commands
2-2
vlink-peer
3-52
voice vlan
1-4
voice vlan aging
1-5
voice vlan enable
1-5
voice vlan mac-address
1-6
voice vlan mode
1-7
voice vlan security enable
1-8
vrrp authentication-mode
VRRP-HA Commands
1-3
vrrp method
VRRP-HA Commands
1-4
vrrp ping-enable
VRRP-HA Commands
1-5
vrrp vrid preempt-mode
VRRP-HA Commands
1-6
vrrp vrid priority
VRRP-HA Commands
1-7
vrrp vrid timer advertise
VRRP-HA Commands
1-8
vrrp vrid track
VRRP-HA Commands
1-9
vrrp vrid virtual-ip
VRRP-HA Commands
1-10
W
X
Y
Z
