H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesH3C S7500 Switch SeriesReference GuidesCommand ReferencesH3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
11-Port Isolation Commands
11-Port Isolation Commands 41 KB
Chapter 1  Port Isolation Configuration Commands
1.1  Port Isolation Configuration Commands
1.1.1  description
View
Isolation group view
text: Description string for an isolation group, comprising 1 to 80 characters.
Use the description command to specify the description string for the current isolation group.
Use the undo description command to remove the description string for the current isolation group.
By default, no description string is specified for the isolation group.
# Specify home as the description string of isolation group 1.
<H3C> system-view
[H3C] port-isolate group 1
[H3C-port-isolate-group1] description home
1.1.2  display isolate port
display isolate port [ group group-id ]
View
group-id: ID of an isolation group, in the range 1 to 64.
Use the display isolate port command to display the configuration of a created isolation group, including:
l           ID of the isolation group
l           Description string for the isolation group
l           Ports that the isolation group contains
# Display the configuration of isolation group 1.
<H3C> display isolate port group 1
 Isolate group ID: 1
 Description: home
 Isolated port(s) in group 1:
             Ethernet2/0/2  Ethernet2/0/3  Ethernet2/0/4
1.1.3  port
port interface-list
undo port interface-list
View
interface-list: List of destination ports, expressed in the form of interface-list = interface-type interface-number [ to interface-type interface-number ] &<1-10>., where:
l           The interface-type argument represents the type of the bound port;
l           The interface-number argument represents the number of the bound port;
l           The to keyword specifies a group of contiguous ports. The port number after the to keyword must be not smaller than that before the to keyword.
l           &<1-10> means that you can provide up to 10 port indices/port index lists for this argument.
Use the port command to add the specified ports to an isolation group.
Use the undo port command to remove the specified ports from an isolation group.
By default, an isolation group contains no Ethernet port.
This command functions the same as the port isolate group command except that Ethernet ports must be specified in this command.
# Add Ethernet 2/0/1 to isolation group 1.
<H3C> system-view
[H3C-port-isolate-group1] port Ethernet 2/0/1
1.1.4  port isolate group
port isolate group group-id
undo port isolate
View
Ethernet port view
Use the port isolate group command to add the current Ethernet port to a created isolation group.
Use the undo port isolate command to remove the current Ethernet port from an isolation group.
This command functions the same as the port command except that Ethernet ports need not be specified in this command.
&  Note:
l      An Ethernet port belongs to only one port isolation group. If you add an Ethernet port to different isolation groups, the port belongs to only the latest isolation group to which the port is added.
l      Currently, cards of Type A (LS81FT48A, LS81FM24A, LS81FS24A, LS81GB8UA, and LS81GT8UA) do not support the Port Isolation feature.
# Add GigabitEthernet 1/0/1 port to isolation group 1.
<H3C> system-view
[H3C] interface gigabitethernet1/0/1
[H3C-GigabitEthernet1/0/1] port isolate group 1
1.1.5  port-isolate group
port-isolate group group-id
undo port-isolate group group-id
View
Use the port-isolate group command to create an isolation group.
Use the undo port-isolate command to remove the specified isolation group.
By default, an isolation group contains no Ethernet ports.
# Create isolation group 1.
<H3C> system-view
