H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesH3C S7500 Switch SeriesReference GuidesCommand ReferencesH3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
10-Link Aggregation Commands
10-Link Aggregation Commands 74 KB
Chapter 1  Link Aggregation Configuration Commands
1.1  Link Aggregation Configuration Commands
1.1.1  display lacp system-id
View
None
Use the display lacp system-id command to display the device ID of the local system, including the system priority and the MAC address.
# Display the device ID of the local system.
<H3C> display lacp system-id
 Actor System ID: 0x8000, 000f-e20f-0100
Table 1-1 Description on the fields of the display lacp system-id command
Actor System ID
Device ID of the local system, including the system priority and the system MAC address
1.1.2  display link-aggregation interface
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
interface interface-type interface-number [ to interface-type interface-number ]: Specifies a port or port range.
l           If the to keyword is not specified, only one port is specified;
l           If the to keyword is specified, multiple contiguous ports are specified;
l           The interface-type argument represents the port type and the interface-number argument represents the port number.
Use the display link-aggregation interface command to display the link aggregation details about a specified port or port range, including:
l           Link aggregation group ID of the specified port or port range
l           Port priority, operation key and LACP status flag of the local end,
l           Device ID, port number, port priority, operation key and protocol status flag and LACP packet statistics of the remote end
Note that, for a manual aggregation group, value 0 is displayed for all the above items of the remote end (which does not indicate the real information of the remote end), since information about the remote end cannot be obtained by a manual aggregation group.
# Display the link aggregation details on the specified port.
<H3C> display link-aggregation interface ethernet2/0/1
Ethernet2/0/1:
   Attached AggID: 20
   Local:
     Port-Priority: 32768, Oper key: 2, Flag: 0x3d
   Remote:
     System ID: 0x8000, 000e-84a6-fb00
     Port Number: 2, Port-Priority: 32768 , Oper-key: 10, Flag: 0x3d
   Received LACP Packets: 8 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 9 packet(s)
Table 1-2 Description on the fields of the display link-aggregation interface command
Attached AggID
ID of the aggregation group to which the specified port belongs
Local:
     Port-Priority: 32768, Oper key: 1, Flag: 0x00
Remote:
     System ID: 0x0, 0000-0000-0000
     Port Number: 0, Port-Priority: 0, Oper-key: 0, Flag: 0x00
Device ID, port number, port priority, operation key and LACP status flag of the remote end
Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 0 packet(s)
Statistics about LACP packets, including: the number of received LACP packets, the number of illegal LACP packets and the number of sent LACP packets
1.1.3  display link-aggregation summary
View
None
Use the display link-aggregation summary command to display summary information of all aggregation groups, including device ID of the local end, aggregation group ID, aggregation group type, device ID of the remote end, number of the selected ports, number of the standby ports, load sharing type and master port number.
# Display summary information of all aggregation groups.
<H3C> display link-aggregation summary
 Aggregation Group Type: D -- Dynamic, S -- Static, M -- Manual
Loadsharing Type: Shar – Loadsharing, NonS – Non-Loadsharing
Actor ID: 0x8000, 000f-e20f-ff04
  AL AL Partner ID           Select    Standby Share   Master
  ID Type                     Ports Ports   Type        Port
  1  D  0x8000,000f-e20f-ff01 1        0       NonS        Ethernet4/0/1
  10 M  none                  1        0       NonS        Ethernet4/0/2
  20 S  0x8000,000f-e20f-ff01 1        0       NonS        Ethernet4/0/3
Table 1-3 Description on the fields of the display link-aggregation summary command
Actor ID
Local device ID
AL ID
Aggregation group ID
AL Type
Aggregation group type: D (dynamic), S (static), or M (manual)
Partner ID
ID of the remote device
Select Ports
Number of the selected ports
Standby Ports
Number of standby ports
Share Type
Load sharing type: Shar (load-sharing), or NonS (non-load-sharing)
Master Port
Master port number
1.1.4  display link-aggregation verbose
display link-aggregation verbose [ agg-id ]
View
agg-id: ID of the aggregation group to be displayed, which must be the ID of an existing aggregation group, in the range of 1 to 384.
Use the display link-aggregation verbose command to display the details about a specified aggregation group, including:
l           Aggregation group ID, aggregation group type, load sharing type, aggregation group description string;
l           Local end details: device ID, port number, port status, port priority, LACP flag, operation key and connection status;
l           Remote end details: local port, remote port index, remote port priority, operation key, and device ID.
# Display the details about aggregation group 1.
<H3C> display link-aggregation verbose 1
Aggregation ID: 1,  AggregationType: Static,   Loadsharing Type: NonS
Aggregation Description:
System ID: 0x8000, 000f-e218-d0d0
Port Status: S -- Selected,  T -- sTandby
Local:
    Port                    Status  Priority Flag Oper-Key Link-Status
    GigabitEthernet3/0/1    S       32768    0x7d 1       Up
    GigabitEthernet3/0/2    T       32768    0x45 2       Down
Remote:
    Actor                   Partner Priority Flag Oper-Key SystemID
    GigabitEthernet3/0/1    0       32768    0x38 0        0x8000,0000-0000-0000
    GigabitEthernet3/0/2    0       32768    0x30 0        0x8000,0000-0000-0000
Table 1-4 Description on the fields of the display link-aggregation verbose command
Aggregation ID
AggregationType
Aggregation group type, including dynamic aggregation, static aggregation and manual aggregation
Loadsharing Type
Loadsharing type, including Loadsharing and Non-Loadsharing
Aggregation group description string
System ID
Local device ID
Port state
Port state
Local
Other information about the local end, including port number, port state, port priority, LACP flag, operation key and connection status
Remote
Detailed information about the remote end, including: local port number, remote port index, port priority, flag bit, operation key and device ID
1.1.5  lacp enable
lacp enable
undo lacp enable
View
Ethernet port view
None
Use the lacp enable command to enable the LACP protocol.
Use the undo lacp enable command to disable the LACP protocol.
# Enable the LACP protocol on Ethernet 2/0/1.
<H3C> system-view
[H3C] interface Ethernet2/0/1
[H3C-Ethernet2/0/1] lacp enable
1.1.6  lacp port-priority
lacp port-priority port-priority-value
undo lacp port-priority
View
Ethernet port view
port-priority-value: Port priority, ranging from 0 to 65,535 and defaulting to 32,768.
Use the lacp port-priority command to set the priority of the current port.
Use the undo lacp port-priority command to restore the default port priority.
# Set the priority of port Ethernet 2/0/1 to 64.
<H3C> system-view
[H3C-Ethernet2/0/1] lacp port-priority 64
1.1.7  lacp system-priority
lacp system-priority system-priority-value
undo lacp system-priority
View
system-priority-value: System priority, ranging from 0 to 65,535 and defaulting to 32,768.
Use the lacp system-priority command to set the system priority.
Use the undo lacp system-priority command to restore the default system priority.
# Set the system priority to 64.
<H3C> system-view
[H3C] lacp system-priority 64
1.1.8  link-aggregation
link-aggregation interface-type interface-number to interface-type interface-number [ both ]
View
interface-type: Port type.
interface-number: Port number.
to: Specifies a series of contiguous ports.
both: Performs load sharing for both inbound traffic and outbound traffic on all the member ports in the aggregation group.
Use the link-aggregation command to add a series of ports to a new manual aggregation group, to which the system assigns a group number automatically. The link-aggregation group agg-id mode command and the port link-aggregation group command can be used together to implement the function of the link-aggregation command.
By default:
l           For IP packets, the system performs load sharing based on IP addresses;
l           For non-IP packets, the system performs load sharing based on MAC addresses.
# Set up an aggregation group with Ethernet 2/0/1 to Ethernet 2/0/4 and perform load sharing for both inbound and outbound traffic of the aggregation group.
<H3C> system-view
[H3C] link-aggregation ethernet2/0/1 to ethernet2/0/4 both
1.1.9  link-aggregation group description
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
agg-id: Aggregation group ID, in the range of 1 to 384.
agg-name: Aggregation group name, a string of 1 to 32 characters.
Use the link-aggregation group description command to set a description for an aggregation group.
Use the undo link-aggregation group description command to remove the description of the aggregation group.
# Set the description office for aggregation group 22.
<H3C> system-view
[H3C] link-aggregation group 22 description office
1.1.10  link-aggregation group mode
link-aggregation group agg-id mode { manual | static }
View
manual: Creates a manual aggregation group.
static: Creates a static aggregation group.
Use the link-aggregation group mode command to create a manual or static aggregation group.
Use the undo link-aggregation group command to remove an aggregation group.
# Create manual aggregation group 22
<H3C> system-view
[H3C] link-aggregation group 22 mode manual
1.1.11  port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
Ethernet port view
Use the port link-aggregation group command to add the current Ethernet port to a manual or static aggregation group.
Use the undo port link-aggregation group command to remove the current Ethernet port from the aggregation group.
# Add Ethernet 2/0/1 to aggregation group 22.
<H3C> system-view
[H3C-Ethernet2/0/1] port link-aggregation group 22
1.1.12  reset lacp statistics
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
interface interface-type interface-number [ to  interface-type interface-number ]: Specifies a port or a port range.
Use the reset lacp statistics command to clear LACP statistics on specified port(s), or on all ports if no port is specified.
# Clear LACP statistics on all Ethernet ports.
<H3C> reset lacp statistics
