H3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
HomeSupportSwitchesH3C S7500 Switch SeriesReference GuidesCommand ReferencesH3C S7500 Series Command Manual(Release 3100 Series)-(V1.04)
38-HWPing Commands
38-HWPing Commands 62 KB
Chapter 1  HWPing Commands
1.1  HWPing Commands
1.1.1  count
count times
undo count
View
HWPing test group view
times: Number of the test packets to be transmitted. It is in the range 1 to 15 and defaults to 1.
Use the count command to configure the number of packets to be sent for each test.
Use the undo count command to restore the default value.
A test timer is started when the system sends the first test packet. In the event that the times argument is greater than one, the system continues to send the second one upon receipt of the reply to the first one. If receiving no reply until the timer times out, the system sends the second and all the remaining packets likewise.
Related commands: frequency.
# Set the number of packets that test group administrator-icmp sends to ten.
<H3C> system-view
[H3C] hwping administrator icmp
[H3C-hwping-administrator-icmp] count 10
1.1.2  destination-ip
destination-ip ip-address
undo destination-ip
View
ip-address: Destination IP address in a test.
Use the destination-ip command to configure the destination IP address in the test.
Use the undo destination-ip command to delete the configured destination IP address.
By default, no destination IP address is configured for any test.
&  Note:
The H3C S7500 Series Ethernet Switches support up to five test groups simultaneously.
# Configure the destination IP address in the test of test group administrator-icmp as 1.1.1.99.
<H3C> system-view
[H3C-hwping-administrator-icmp] destination-ip 1.1.1.99
1.1.3  display hwping
display hwping { results | history } [ administrator-name operation-tag ]
View
results: Displays the test results.
history: Displays the test history.
administrator-name: Name of the administrator that creates the test.
operation-tag: Test operation tag.
Use the display hwping command to display test result(s).
If a test group is specified using the arguments of administrator-name and operation-tag, the system displays only the test result of the group; if not, it displays the test results of all the test groups.
Related commands: test-enable.
# Use the display hwping results command to display the test result of the test group whose administrator name is administrator and operation tag is icmp.
<H3C> display hwping result administrator icmp
  HWPing entry(admin administrator, tag icmp) test result:
      Destination ip address:1.1.1.99
      Send operation times: 10              Receive response times: 10
      Min/Max/Average Round Trip Time: 2/5/2
      Square-Sum of Round Trip Time: 66
      Last complete test time: 2000-4-2 7:59:54.7
  Extend result:
      SD Maximal delay: 0                    DS Maximal delay: 0
      Packet lost in test: 0%
      Disconnect operation number: 0        Operation timeout number: 0
      System busy operation number: 0       Connection fail number: 0
      Operation sequence errors: 0          Drop operation number: 0
      Other operation errors: 0
Table 1-1 Description on the fields of the display hwping result command
Number of times the operation is sent
Number of times of successful test operations
Minimum/maximum/average round-trip time
The square sum of round trip time
Time of the last successful test
SD Maximal delay
Maximal delay from the source to the destination
DS Maximal delay
Maximal delay from the destination to the source
Packet lost in test
Packet lost ratio in the test
Number of times of disconnections by the opposite side
Number of times of timeouts in the test operation
Number of times the test fails because the system is busy
Number of connection failures
Number of received sequence error packets
Number of system resource allocation errors
Number of other errors
# Use the display hwping history command to display test results.
<H3C> display hwping history administrator icmp
  HWPing entry(admin administrator, tag icmp) history record:
    Index     Response    Status      LastRC       Time
        1            1         1           0    2004-11-25 16:28:55.0
        2            1         1           0    2004-11-25 16:28:55.0
        3            1         1           0    2004-11-25 16:28:55.0
        4            1         1           0    2004-11-25 16:28:55.0
        5            1         1           0    2004-11-25 16:28:55.0
        6            2         1           0    2004-11-25 16:28:55.0
        7            1         1           0    2004-11-25 16:28:55.0
        8            1         1           0    2004-11-25 16:28:55.0
        9            1         1           0    2004-11-25 16:28:55.9
       10            1         1           0    2004-11-25 16:28:55.9
Table 1-2 Description on the fields of the display hwping history command
Index
Index of the displayed information
Response
Round trip test time, in milliseconds, or the timeout time. 0 means the test fails.
Status
Value of the test result. See the following detailed description:
1: responceReceived. It means response is received.
2: unknown. It means an unknown error.
3: internalError. It means a system internal error.
4: requestTimeOut. It means the response times out.
5: unknownDestinationAddress. It means the destination address is unknown.
6: noRouteToTarget. It means there is no route to the destination address.
7: interfaceInactiveToTarget. It means the interface of destination address is not activated.
8: arpFailure. It means ARP operation fails.
9: maxConcurrentLimitReached. It means the maximum limit of concurrent accesses is reached.
10: unableToResolveDnsName. It means it is unable to resolve the DNS field.
11: invalidHostAddress. It means the invalid host address.
LastRC
Receive the last response code based on the implementation ways. With ICMP echo enabled, if the system receives ICMP response which includes ICMP_ECHOREPLY(0), the probe has succeeded. ICMP response is often defined in the file including ip_icmp.
Time
Test time
1.1.4  frequency
frequency interval
undo frequency
View
interval: Automatic test interval. It ranges from 0 to 65,535 seconds and defaults to 0. The default value means that no automatic test is performed.
Use the frequency command to configure an automatic test interval.
Use the undo frequency command to disable an automatic test.
The system automatically tests at intervals specified by this command, where the argument interval is greater than 0.
Related commands: count.
# Set the automatic test interval of test group administrator-icmp to 10 seconds.
<H3C> system-view
[H3C-hwping-administrator-icmp] frequency 10
1.1.5  hwping
hwping administrator-name operation-tag
undo hwping administrator-name operation-tag
View
administrator-name: Name of the administrator creating a HWPing test group, a string of 1 to 32 characters.
operation-tag: Test operation tag, a string of 1 to 32 characters.
Use the hwping command to create a HWPing test group and enter HWPing test group view.
Use the undo hwping command to delete this test group.
# Create a HWPing test group, setting the administrator name to administrator and the test operation tag to icmp.
<H3C> system-view
1.1.6  hwping-agent enable
hwping-agent enable
undo hwping-agent enable
View
None
Use the hwping-agent enable command to enable the HWPing client function.
Use the undo hwping-agent enable command to disable the HWPing client function.
Before you can perform a test, you must enable the HWPing client function. By default, HWPing client function is enabled.
# Enable HWPing client.
<H3C> system-view
[H3C] hwping-agent enable
1.1.7  test-type
test-type type
View
type: Test type.
Use the test-type command to configure the type of the test.
Currently the system only supports ICMP test.
# Configure the test type of test group administrator-icmp as ICMP.
<H3C> system-view
[H3C-hwping-administrator-icmp] test-type icmp
1.1.8  test-enable
test-enable
undo test-enable
View
None
Use the test-enable command to execute a HWPing test.
Use the undo test-enable command to disable a HWPing test.
&  Note:
After you execute the test-enable command, the system does not display the test result. You need to view the test result information by executing the display hwping command.
Related commands: display hwping.
# Execute the HWPing test defined by test group administrator-icmp.
<H3C> system-view
[H3C-hwping-administrator-icmp] test-enable
1.1.9  timeout
timeout time
undo timeout
View
time: Timeout time. It is in the range of 1 to 60 seconds and defaults to 3 seconds.
Use the timeout command to configure a timeout time for a test.
Use the undo timeout command to restore the default value.
# Set the timeout time of test group administrator-icmp to 10 seconds.
<H3C> system-view
[H3C-hwping-administrator-icmp] timeout 10
