09-附录A 设备硬件规格
本章节下载: 09-附录A 设备硬件规格 (143.14 KB)
S7508E-X交换机采用了可插拔设计,交换机整机重量与所插的可插拔部件的类型及数量有关。具体计算公式为:设备最终重量=机箱重量+单板总重量+电源总重量+可插拔接口模块总重量+其它可插拔部件总重量。
表A-1 S7508E-X交换机重量及尺寸列表
机型 |
整机重量 |
尺寸 |
高(H) |
宽(W) |
深(D) |
S7508E-X |
<125kg |
620mm(14RU) |
440mm |
660mm |
· RU(Rack Unit)是表示机柜高度的度量单位,1RU=44.45mm(1.75inch)。
· 表A-2中的单板型号指的是单板上的丝印。如果单板丝印为LSQ*,则该单板的对外型号为LSQM*,比如单板丝印为LSQ1SUPA0,则该单板的对外型号为LSQM1SUPA0。
表A-2 S7508E-X交换机单板重量及尺寸列表
单板型号 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
LSQ1SUPA0 |
2.83kg |
40mm |
399mm |
352mm |
LSQ1FP48SA0 |
3.05kg |
40mm |
399mm |
352mm |
LSQ2FP48SA0 |
2.93kg |
40mm |
399mm |
352mm |
LSQ2FT48SA0 |
2.74kg |
40mm |
399mm |
352mm |
LSQ1FV48SA0 |
2.89kg |
40mm |
399mm |
352mm |
LSQ1GP24TSA0 |
2.77kg |
40mm |
399mm |
352mm |
LSQ1GV24PSA0 |
2.8kg |
40mm |
399mm |
352mm |
LSQ1GV48SA0 |
3.09kg |
40mm |
399mm |
352mm |
LSQ1GP12SC0 |
2.66kg |
40mm |
399mm |
352mm |
LSQ1GP24SC0 |
2.78kg |
40mm |
399mm |
352mm |
LSQ1GP48SC0 |
3.04kg |
40mm |
399mm |
352mm |
LSQ1GT24SC0 |
2.72kg |
40mm |
399mm |
352mm |
LSQ1GP24TSC0 |
2.77kg |
40mm |
399mm |
352mm |
LSQ1GV48SC0 |
3.09kg |
40mm |
399mm |
352mm |
LSQ1TGS8SC0 |
3.11kg |
40mm |
399mm |
352mm |
LSQ1TGS16SC0 |
3.03kg |
40mm |
399mm |
352mm |
LSQ1TGX2SC0 |
2.95kg |
40mm |
399mm |
352mm |
LSQ1GV24PSC0 |
2.8kg |
40mm |
399mm |
352mm |
LSQ1P24XGSC0 |
2.95kg |
40mm |
399mm |
352mm |
LSQ1T24XGSC0 |
2.92kg |
40mm |
399mm |
352mm |
LSQ1GV40PSC0 |
3.02kg |
40mm |
399mm |
352mm |
LSQ1PT4PSC0 |
2.64kg |
40mm |
399mm |
352mm |
LSQ1PT8PSC0 |
2.7kg |
40mm |
399mm |
352mm |
LSQ1PT16PSC0 |
2.82kg |
40mm |
399mm |
352mm |
LSQ4PT4PSC0 |
2.64kg |
40mm |
399mm |
352mm |
LSQ4PT8PSC0 |
2.7kg |
40mm |
399mm |
352mm |
LSQ4PT16PSC0 |
2.82kg |
40mm |
399mm |
352mm |
LSQ1QGS4SC0 |
3.12 kg |
40mm |
399mm |
352mm |
LSQ1QGC4SC0 |
3.46 kg |
40mm |
399mm |
352mm |
LSQ1GP24TSD0 |
3.01kg |
40mm |
399mm |
352mm |
LSQ1GP24TXSD0 |
3.08kg |
40mm |
399mm |
352mm |
LSQ1GP48SD0 |
3.25kg |
40mm |
399mm |
352mm |
LSQ1GV48SD0 |
3.31kg |
40mm |
399mm |
352mm |
LSQ1TGX2SD0 |
2.93kg |
40mm |
399mm |
352mm |
LSQ1TGX4SD0 |
2.93kg |
40mm |
399mm |
352mm |
LSQ1TGX8SD0 |
3.23kg |
40mm |
399mm |
352mm |
LSQ1GP24TEB0 |
3.04kg |
40mm |
399mm |
352mm |
LSQ1GP48EB0 |
3.25kg |
40mm |
399mm |
352mm |
LSQ1TGX2EB0 |
2.93kg |
40mm |
399mm |
352mm |
LSQ1TGX4EB0 |
2.93kg |
40mm |
399mm |
352mm |
LSQ1FAB08A0 |
2.53kg |
40mm |
426mm |
298mm |
LSQ1FAB08B0 |
2.5 kg |
40mm |
426mm |
298mm |
S7508E-X交换机的单板尺寸以高(H)×宽(W)×深(D)形式表示。其中各项含义见以下说明:
· 高(H):指单板前面板的高度。
· 宽(W):指单板前面板的宽度。
· 深(D):指单板由前面板到连接器的深度。
表A-3 S7508E-X交换机电源模块重量及尺寸列表
电源型号 |
净重 |
尺寸 |
高(H) |
宽(W) |
深(D) |
LSUM1AC2500 |
2.5kg |
41mm |
102mm |
410mm |
表A-4 S7508E-X交换机风扇框重量及尺寸列表
风扇框 |
净重 |
尺寸(风扇框平放到桌面上) |
高(H) |
宽(W) |
深(D) |
S7508E-X风扇框 |
6.95kg |
112mm |
425mm |
645mm |
S7508E-X交换机支持的单板种类丰富,不同单板的功耗有所不同,而且同一块单板在不同状态下的功耗也存在差异,具体型号单板的功耗请参见表A-5。
· 单板静态功耗是指单板已上电运行、所有端口均处于DOWN状态且单板的光接口上无可插拔接口模块的情况下,单板所产生的功耗。
· 单板动态功耗是指单板所有端口满配,广播风暴情况下所产生的功耗。
S7508E-X交换机的风扇框中均采用了具有自动调速功能的风扇(风扇的转速会随着设备散热需要进行自动调节)。在不同风扇速率下,风扇框产生的功耗有所不同,风扇框的具体功耗请参见表A-6。
交换机整机功耗是指交换机所有在位运行的单板功耗及风扇框功耗的和。S7508E-X交换机整机功耗与所插的单板类型及数量、风扇框功耗有关,具体计算方式为:
· 交换机整机最小功耗=单板静态总功耗+风扇框最小功耗(例如,有一台S7508E-X交换机插有2块LSQ1SUPA0(LSQM1SUPA0)主控板、2块LSQ1TGX4EB0(LSQM1TGX4EB0)业务板、2块LSQ1FAB08A0(LSQM1FAB08A0)网板和1个S7508E-X风扇框,那么该交换机当前的最小功耗为2×38+2×53+2×68+11=329W)。
· 交换机整机最大功耗=单板动态总功耗+风扇框最大功耗(例如,有一台S7508E-X交换机插有2块LSQ1SUPA0(LSQM1SUPA0)主控板、2块LSQ1TGX4EB0(LSQM1TGX4EB0)业务板、2块LSQ1FAB08A0(LSQM1FAB08A0)网板和1个S7508E-X风扇框,那么该交换机当前的最大功耗为2×50+2×80+2×85+234=664W)。
表A-5中的单板型号指的是单板上的丝印。如果单板丝印为LSQ*,则该单板的对外型号为LSQM*,比如单板丝印为LSQ1SUPA0,则该单板的对外型号为LSQM1SUPA0。
单板型号 |
单板静态功耗 min |
单板动态功耗 max |
LSQ1SUPA0 |
38W |
50W |
LSQ1FP48SA0 |
34W |
85W |
LSQ2FP48SA0 |
30W |
75W |
LSQ2FT48SA0 |
24W |
30W |
LSQ1FV48SA0 |
30W |
35W |
LSQ1GP24TSA0 |
25W |
45W |
LSQ1GV24PSA0 |
30W |
60W |
LSQ1GV48SA0 |
60W |
80W |
LSQ1GP12SC0 |
26W |
35W |
LSQ1GP24SC0 |
38W |
55W |
LSQ1GP48SC0 |
43W |
85W |
LSQ1GP24TSC0 |
25W |
45W |
LSQ1GT24SC0 |
42W |
50W |
LSQ1GV48SC0 |
60W |
90W |
LSQ1TGS8SC0 |
75W |
95W |
LSQ1TGS16SC0 |
84W |
115W |
LSQ1TGX2SC0 |
30W |
40W |
LSQ1GV24PSC0 |
30W |
60W |
LSQ1P24XGSC0 |
40W |
55W |
LSQ1T24XGSC0 |
50W |
75W |
LSQ1GV40PSC0 |
41W |
95W |
LSQ1PT4PSC0 |
33W |
40W |
LSQ1PT8PSC0 |
38W |
45W |
LSQ1PT16PSC0 |
55W |
65W |
LSQ4PT4PSC0 |
33W |
40W |
LSQ4PT8PSC0 |
38W |
45W |
LSQ4PT16PSC0 |
55W |
65W |
LSQ1QGS4SC0 |
70W |
90W |
LSQ1QGC4SC0 |
52W |
85W |
LSQ1GP24TSD0 |
47W |
75W |
LSQ1GP24TXSD0 |
54W |
95W |
LSQ1GP48SD0 |
44W |
95W |
LSQ1GV48SD0 |
67W |
95W |
LSQ1TGX2SD0 |
43W |
55W |
LSQ1TGX4SD0 |
53W |
80W |
LSQ1TGX8SD0 |
73W |
120W |
LSQ1GP24TEB0 |
50W |
90W |
LSQ1GP48EB0 |
43W |
110W |
LSQ1TGX2EB0 |
46W |
65W |
LSQ1TGX4EB0 |
53W |
80W |
LSQ1FAB08A0 |
68W |
85W |
LSQ1FAB08B0 |
44W |
60W |
表A-6 机箱风扇框功耗列表
风扇框 |
风扇框功耗 min |
风扇框功耗 max |
S7508E-X风扇框 |
11W |
234W |
设备的发热量和设备功耗密切相关。计算S7508E-X交换机发热量时,一般假定:90%的功耗转换成热量,电源的转换效率为90%。因此S7508E-X交换机每小时散热量的计算公式为:交换机每小时散热量=0.9*(单板总功耗+风扇框功耗)/0.9*3.4121。
· S7508E-X交换机各型号单板及风扇框的功耗请参见“A.2 模块功耗列表及整机功耗计算方式”。
· 热量单位一般为BTU/h,1瓦=3.4121BTU/h。
表A-7 S7508E-X交换机环境适应性指标列表
指标 |
工作 |
非工作 |
温度 |
0℃~45℃ |
-40℃~70℃ |
相对湿度 |
10%~95%,无冷凝 |
5%~95%,无冷凝 |
S7508E-X交换机的风扇框中采用了具有自动调速功能的风扇(风扇的转速会随着设备散热需要进行自动调节)。在不同风扇速率下,设备的噪声值有所不同,具体请参见表A-8。
表A-8 S7508E-X交换机噪声级别列表
常温下风扇调速设备噪声值 |
风扇全速设备噪声 |
S7508E-X |
63dBA |
75.8dBA |
