10-扩展OAM命令
本章节下载: 10-扩展OAM命令 (224.74 KB)
1.1.1 display epon-oam interface
1.2.2 alarm bit-error-rate enable
1.2.3 alarm device-fatal-error
1.2.5 alarm frame-error-rate enable
1.2.6 alarm llid-mismatch enable
1.2.7 alarm llid-mismatch threshold
1.2.9 alarm oam critical-event
1.2.11 alarm oam error-symbol-period
1.2.12 alarm oam error-symbol-period enable
1.2.13 alarm oam error-frame-period
1.2.14 alarm oam error-frame-period enable
1.2.16 alarm oam error-frame enable
1.2.17 alarm oam error-frame-seconds-summary
1.2.18 alarm oam error-frame-seconds-summary enable
1.2.19 alarm oam local-link-fault
1.2.20 alarm oam-vendor-specific
1.2.21 alarm onu-over-limitation
1.2.22 alarm port bit-error-rate
1.2.23 alarm registration-error
display epon-oam interface interface-type interface-number
【缺省级别】
2:系统级
interface-type:端口类型,取值为ONU。
interface-number:ONU端口号。
【描述】
display epon-oam interface命令是用于显示ONU的扩展OAM信息。
仅当ONU在线时,才能显示ONU的OAM信息。
# 显示ONU的OAM信息。
<Sysname> display epon-oam interface onu 1/0/1:1
OAM information:
Multiplexer action: forwarding non-OAM PDUs to the lower sublayer
Parser action : forwarding non-OAM PDUs to higher layer
Organization specific information TLVs: support
Organization specific events : support
Organization specific OAM PDUs : support
Sending variable response OAM PDUs : support
Interpreting link events : not support
OAM mode : passive
Unidirectional support: disable
Loopback support : enable
Maximal PDU size(byte): 1518
Enterprise number : 1111
Device identifier : 6301
Version identifier : 0
Board vendor code : 0
Board model identifier: 0
表1-1 display epon-oam interface命令显示信息描述表
OAM version |
OAM版本 |
Multiplexer action: forwarding non-OAM PDUs to the lower sublayer |
多路复用器动作:向底层发送非OAM PDU |
Parser action : forwarding non-OAM PDUs to higher layer |
解析器动作:向高层发送非OAM PDU |
Organization specific information TLVs |
企业特定信息TLV格式 |
Organization specific events |
企业特定事件 |
Organization specific OAM PDUs |
企业特定OAM PDU |
Sending variable response OAM PDUs |
在响应OAM PDU报文中发送变量 |
Interpreting link events |
解释连接事件 |
OAM mode |
OAM模式 |
Unidirectional support |
单向支持模式 |
Loopback support |
环回支持模式 |
Maximal PDU size(byte) |
最大PDU长度,单位为字节 |
Enterprise number |
企业标识 |
Device identifier |
设备标识 |
Version identifier |
版本标识 |
Board vendor code |
板卡供应商代码 |
Board model identifier |
板卡标识 |
epon-parameter ouilist { oui oui-value oam-version version-value } &<1-9> slot slot-number
undo epon-parameter ouilist slot slot-number
FTTH视图
【缺省级别】
2:系统级
oui-value:ONU的OUI(Organizationally Unique Identifier,全球统一标识),取值范围为1~FFFFFF。
version-value :ONU的OAM(Operation、Administration and Maintenance,操作、管理和维护)版本号,取值范围为1~255。
&<1-9>:表示前面的参数最多可以输入9次。
slot-number:Olt端口所在槽位号,值为1。
【描述】
epon-parameter ouilist命令用来配置ONU的OUI及扩展OAM版本号列表。undo epon-parameter ouilist命令用来取消指定槽位的EPON业务板上用户配置的OUI和扩展OAM版本号列表,缺省配置不能取消。
缺省情况下,每个EPON业务板启动后都有一个ONU的OUI和扩展OAM版本号分别为111111和1。这样,当OLT下挂H3C的ONU时,只需绑定ONU到指定的ONU端口,ONU即可上线(H3C的ONU对应的OUI和扩展OAM版本号分别为111111和1)。
l 不能配置OUI和扩展OAM版本号都完全相同的两条记录。
l 当设备的OUI和OAM版本号列表有变动(新增或取消用户配置的列表)时,该设备下的所有ONU会重新注册。
相关命令可参考display epon-parameter。
# 配置设备接入的ONU对应的OUI及扩展OAM版本号列表。
[Sysname] ftth
[Sysname-ftth] epon-parameter ouilist oui 111111 oam-version 2 slot 1
oam-discovery-timeout value slot slot-number
undo oam-discovery-timeout slot slot-number
FTTH视图
【缺省级别】
2:系统级
value:超时时间,以100ms为单位,取值范围为0~2550,缺省值为30。
【描述】
oam-discovery-timeout命令用来配置扩展OAM发现过程中OLT与ONU之间交互的扩展OAM消息的超时时间。undo oam-discovery-timeout命令用来恢复扩展OAM发现过程中OLT与ONU之间交互的扩展OAM消息的超时时间为缺省值。
l 一般情况下,不建议用户直接进行此项配置,保持缺省情况即可。
l 如果ONU已经连接到OLT且邦定到ONU端口后还一直处于DOWN状态,可以尝试修改扩展OAM发现超时时间为更大一点的数值。
# 配置1号槽位上OLT与ONU之间交互的扩展OAM消息的超时时间为60(即6s)。
[Sysname] ftth
[Sysname-ftth] oam-discovery-timeout 60 slot 1
l 如果告警命令可在FTTH视图下执行,则表示对系统中所有的OLT端口或该端口下所有的ONU生效;
l 如果可在OLT端口视图下执行,则表示对本端口或其下所有的ONU生效;
l 如果在ONU端口视图下执行,则仅对本端口所对应的ONU生效。
alarm bit-error-rate { direction { uplink | downlink | up-down-link } | threshold threshold } *
undo alarm bit-error-rate { direction | threshold } *
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
uplink:监控方向,只对ONU向OLT转发的上行通信数据进行监控。
downlink:监控方向,只对OLT向ONU转发的下行通信数据进行监控。
up-down-link:监控方向,对OLT和ONU之间的上下行通信数据进行监控。
threshold threshold:bit error rate告警阈值,取值范围为1~109,缺省值为10(单位为10-9)。
【描述】
alarm bit-error-rate命令用来配置监控方向和bit error rate告警阈值。undo alarm bit-error-rate命令用来恢复监控方向和bit error rate告警阈值的缺省值。
当OLT和ONU之间转发数据时的错误比特总数或比特错误率超过了告警阈值,则产生bit error rate告警。
缺省情况下,对OLT和ONU之间的上下行通信数据都进行监控。
相关命令可参考alarm bit-error-rate enable。
# 配置端口OLT1/0/1只对ONU向OLT转发的上行通信数据进行监控,并且配置bit error rate告警阈值为20。
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] alarm bit-error-rate direction uplink threshold 20
undo alarm bit-error-rate enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
【描述】
alarm bit-error-rate enable命令用来开启bit error rate告警功能。undo alarm bit-error-rate enable用于关闭bit error rate告警功能。
缺省情况下,bit error rate告警功能开启。
# 开启端口OLT1/0/1的bit error rate告警功能。
[Sysname-Olt1/0/1] alarm bit-error-rate enable
alarm device-fatal-error enable
undo alarm device-fatal-error enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm device-fatal-error命令用来开启device fatal error告警功能。undo alarm device-fatal-error命令用来关闭device fatal error告警功能。
缺省情况下,device fatal error告警功能开启。
当设备上发生了一系列的致命错误时,就会引起device fatal error告警,若设备在持续两分钟内没有检测到同样的错误,将产生device fatal error恢复告警。
# 开启端口OLT1/0/1的device fatal error告警功能。
[Sysname-Olt1/0/1] alarm device-fatal-error enable
alarm frame-error-rate { direction { uplink | downlink | up-down-link} | threshold threshold } *
undo alarm frame-error-rate { direction | threshold } *
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
threshold threshold:frame error rate告警阈值,取值范围为1~109,缺省值为1(单位为10-9)。
【描述】
alarm frame-error-rate命令用来配置监控方向和frame error rate告警阈值。undo alarm frame-error-rate命令用来恢复监控方向和frame error rate告警阈值的缺省值。
当OLT和ONU之间转发数据时的帧误码总数和帧误码率都超过了告警阈值,则产生frame error rate告警。
相关命令可参考alarm frame-error-rate enable。
# 配置端口OLT1/0/1对OLT和ONU之间的上下行通信数据进行监控,并且配置frame error rate告警阈值为20。
[Sysname-Olt1/0/1] alarm frame-error-rate direction up-down-link threshold 20
undo alarm frame-error-rate enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
【描述】
alarm frame-error-rate enable命令用来开启frame error rate告警功能。undo alarm frame-error-rate enable用于关闭frame error rate告警功能。
缺省情况下,frame error rate告警功能开启。
# 开启端口OLT1/0/1的frame error rate告警功能。
[Sysname-Olt1/0/1] alarm frame-error-rate enable
undo alarm llid-mismatch enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm llid-mismatch enable命令用来开启LLID匹配错误帧告警功能。undo alarm llid-mismatch enable命令用来关闭LLID匹配错误帧告警功能。
缺省情况下,LLID匹配错误帧告警功能关闭。
# 开启端口OLT1/0/1的LLID匹配错误帧告警功能。
[Sysname-Olt1/0/1] alarm llid-mismatch enable
alarm llid-mismatch threshold threshold
undo alarm llid-mismatch threshold
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
threshold threshold:LLID匹配错误帧,单位为帧,取值范围为1000~109,缺省值为5000帧。
【描述】
alarm llid-mismatch threshold命令用来配置LLID匹配错误帧阈值。undo alarm llid-mismatch threshold命令用来恢复LLID匹配错误帧阈值为缺省值。
当时隙错乱导致ONU不在自己的时隙内转发数据时,就会引起LLID匹配错误帧告警。
相关命令可参考alarm llid-mismatch enable。
# 配置端口OLT1/0/1的LLID匹配错误帧阈值为6000帧。
[Sysname-Olt1/0/1] alarm llid-mismatch threshold 6000
alarm local-stable enable
undo alarm local-stable enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm local-stable enable命令用来开启local stable告警功能。undo alarm local-stable enable用于关闭local stable告警功能。
local stable告警指OLT侧产生的告警。当系统中有ONU误用时,比如把OAM2.0的ONU与OAM3.3的ONU混用时(因为同一系统下的ONU必须采用同一OAM版本),就会引起local stable告警。
local stable告警与remote stable告警的区别如下:
l local stable告警是OLT侧产生的告警;
l remote stable告警是ONU侧产生的告警,并且将其告警反馈给OLT。
缺省情况下,local stable告警功能开启。
remote stable告警命令可参见“1.2.24 alarm remote-stable”。
# 开启端口OLT1/0/1的local stable告警功能。
[Sysname-Olt1/0/1] alarm local-stable enable
alarm oam critical-event enable
undo alarm oam critical-event enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm oam critical-event enable命令用来开启critical event告警功能。undo alarm oam critical-event enable命令用来关闭critical event告警功能。
缺省情况下,critical event告警功能开启。
critical event包含local link fault与dying gasp两种事件,当其中一个事件发生时,就会引起critical event告警。
# 开启端口OLT1/0/1的critical event告警功能。
[Sysname-Olt1/0/1] alarm oam critical-event enable
alarm oam dying-gasp enable
undo alarm oam dying-gasp enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm oam dying-gasp enable命令用来开启dying gasp告警功能。undo alarm oam dying-gasp enable命令用来关闭dying gasp告警功能。
缺省情况下,dying gasp告警功能开启。
当遇到系统出错,数据加载错误或者其它无法恢复的错误时,就会引起dying gasp告警。
# 开启端口OLT1/0/1的dying gasp告警功能。
[Sysname-Olt1/0/1] alarm oam dying-gasp enable
alarm oam error-symbol-period { window-high windowhigh | window-low windowlow | threshold-high thresholdhigh | threshold-low thresholdlow } *
undo alarm oam error-symbol-period { window-high | window-low | threshold-high | threshold-low } *
OLT端口视图、ONU端口视图、FTTH视图
【缺省级别】
2:系统级
window-high windowhigh:窗口高位大小,取值范围为0~4294967295(232-1),缺省值为0。
window-low windowlow:窗口低位大小,取值范围为0~4294967295(232-1),缺省值为1。
threshold-high thresholdhigh:阈值高位大小,取值范围为0~4294967295(232-1),缺省值为0。
threshold-low thresholdlow:阈值低位大小,取值范围为0~4294967295(232-1),缺省值为20。
l 该命令中窗口大小与阈值大小都是由16位的高位与16位的低位所组成。
l 窗口的单位为秒,即缺省值为1秒;阈值的单位为字节,即缺省值为20字节。
【描述】
alarm oam error-symbol-period命令用来配置窗口和阈值大小。undo alarm oam error-symbol-period命令用来恢复窗口和阈值大小的缺省值。
在一个给定的时间段内(即窗口大小),如果发生的字节错误数超过了预先设定的门限阈值,就会引起error symbol period告警。
相关命令可参考alarm oam error-symbol-period enable。
l 当此告警的阈值高位和低位都设置成0时,就会马上产生大量的告警,而告警事件是承载在OAM报文里的,所以会有大量的OAM报文产生,此时可能会导致OAM报文丢失。
l 此命令只对OAM 2.0及以上版本有效。
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error symbol period告警功能的窗口高位和低位分别为1和3 ,阈值高位和低位分别为10 和30。
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] alarm oam error-symbol-period window-high 1 window-low 3 threshold-high 10 threshold-low 30
undo alarm oam error-symbol-period enable
【缺省级别】
2:系统级
无
【描述】
alarm oam error-symbol-period enable命令用来开启error symbol period告警功能。undo alarm oam error-symbol-period enable命令用来关闭error symbol period告警功能。
缺省情况下,error symbol period告警功能开启。
# 开启ONU端口ONU1/0/1:1 对应ONU的error symbol period告警功能。
[Sysname-Onu1/0/1:1] alarm oam error-symbol-period enable
alarm oam error-frame-period { window window | threshold threshold } *
undo alarm oam error-frame-period { window | threshold } *
【缺省级别】
2:系统级
window window:窗口大小,单位为秒,取值范围为0~4294967295(232-1),缺省值为1秒。
threshold threshold:阈值大小,单位为帧,取值范围为0~4294967295(232-1),缺省值为20帧。
【描述】
alarm oam error-frame-period命令用来配置窗口和阈值大小。undo alarm oam error-frame-period命令用来恢复窗口和阈值大小的缺省值。
在一个给定的周期内(即窗口大小),如果发生的错误帧数超过了预先设定的门限阈值,就会引起error frame period告警。
相关命令可参考alarm oam error-frame-period enable。
l 当此告警的阈值设置成0时,就会马上产生大量的告警,而告警事件是承载在OAM报文里的,所以会有大量的OAM报文产生,此时可能会导致OAM报文丢失。
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error frame period告警功能的窗口大小为2秒,阈值大小为30帧。
[Sysname-Onu1/0/1:1] alarm oam error-frame-period window 2 threshold 30
undo alarm oam error-frame-period enable
【缺省级别】
2:系统级
无
【描述】
alarm oam error-frame-period enable命令用来开启error frame period告警功能。undo alarm oam error-frame-period enable命令用来关闭error frame period告警功能。
缺省情况下,error frame period告警功能开启。
# 开启ONU端口ONU1/0/1:1 对应ONU的error frame period告警功能。
[Sysname-Onu1/0/1:1] alarm oam error-frame-period enable
alarm oam error-frame { window window | threshold threshold } *
undo alarm oam error-frame { window | threshold } *
【缺省级别】
2:系统级
window window:窗口大小,单位为秒,取值范围为0~65535,缺省值为10秒。
【描述】
alarm oam error-frame命令用来配置窗口和阈值大小。undo alarm oam error-frame命令用来恢复窗口和阈值大小的缺省值。
在给定时间段内(即窗口大小),如果错误帧的数目超过了预先设定的门限阈值,就会引起error frame告警。
相关命令可参考alarm oam error-frame enable。
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error frame告警功能的窗口大小为20秒,阈值大小为30帧。
[Sysname-Onu1/0/1:1] alarm oam error-frame window 20 threshold 30
undo alarm oam error-frame enable
【缺省级别】
2:系统级
无
【描述】
alarm oam error-frame enable命令用来开启error frame告警功能。undo alarm oam error-frame enable命令用来关闭error frame告警功能。
缺省情况下,error frame告警功能开启。
# 开启ONU端口ONU1/0/1:1 对应ONU的error frame告警功能。
[Sysname-Onu1/0/1:1] alarm oam error-frame enable
alarm oam error-frame-seconds-summary { window window | threshold threshold } *
undo alarm oam error-frame-seconds-summary { window | threshold } *
【缺省级别】
2:系统级
window window:窗口大小,单位为100毫秒,取值范围为100~9000,缺省值为600。
threshold threshold:阈值大小,单位为秒,取值范围为1~900,缺省值为1秒。
【描述】
alarm oam error-frame-seconds-summary命令用来配置窗口和阈值大小。undo alarm oam error-frame-seconds-summary命令用来恢复窗口和阈值大小的缺省值。
在特定时间段(比如1分钟)内,如果检测到的错误帧秒个数(错误帧秒是指在1秒的间隔内,至少有一个错误帧出现)的值大于预先设定的门限阈值,就会引起error frame seconds summary告警。
相关命令可参考alarm oam error-frame-seconds-summary enable。
# 配置ONU端口ONU1/0/1:1 对应ONU设备上error frame seconds summary 告警功能的窗口大小为800,阈值大小为2秒。
[Sysname-Onu1/0/1:1] alarm oam error-frame-seconds-summary window 800 threshold 2
undo alarm oam error-frame-seconds-summary enable
【缺省级别】
2:系统级
无
【描述】
alarm oam error-frame-seconds-summary enable命令用来开启error frame seconds summary 告警功能。undo alarm oam error-frame-seconds-summary enable命令用来关闭error frame seconds summary告警功能。
缺省情况下,error frame seconds summary告警功能开启。
# 开启ONU端口ONU1/0/1:1 对应ONU的error frame seconds summary 告警功能。
[Sysname-Onu1/0/1:1] alarm oam error-frame-seconds-summary enable
alarm oam local-link-fault enable
undo alarm oam local-link-fault enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm oam local-link-fault enable命令用来开启local link fault告警功能。undo alarm oam local-link-fault enable命令用来关闭local link fault告警功能。
缺省情况下,local link fault告警功能开启
当本地数据终端设备的接收方向出现故障时,就会引起local link fault告警。
# 开启端口OLT1/0/1的local link fault告警功能。
[Sysname-Olt1/0/1] alarm oam local-link-fault enable
alarm oam-vendor-specific enable
undo alarm oam-vendor-specific enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm oam-vendor-specific enable用于开启oam vendor specific告警功能。undo alarm oam-vendor-specific enable用于关闭oam vendor specific告警功能。
此告警属于厂商自定义的告警。
缺省情况下,oam vendor specific告警功能开启。
# 开启端口OLT1/0/1的oam vendor specific告警功能。
[Sysname-Olt1/0/1] alarm oam-vendor-specific enable
alarm onu-over-limitation enable
undo alarm onu-over-limitation enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm onu-over-limitation enable命令用来开启onu over limitation告警功能。undo alarm onu-over-limitation enable命令用来关闭onu over limitation告警功能。
当OLT下所挂的ONU总数超过系统所支持的规格,就会引起onu over limitation告警。
缺省情况下,onu over limitation告警功能开启。
# 开启端口OLT1/0/1的onu over limitation告警功能。
[Sysname-Olt1/0/1] alarm onu-over-limitation enable
alarm port bit-error-rate enable
undo alarm port bit-error-rate enable
ONU端口视图、OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm port bit-error-rate enable用于开启port bit error rate告警功能。undo alarm port bit-error-rate enable用于关闭port bit error rate告警功能。
当OLT和ONU之间转发数据时的比特错误总数和比特错误率都超过了告警阈值,则产生port bit error rate告警。
port bit error rate告警阈值的设置与bit error rate告警一样,相关命令请参见“1.2.1 alarm bit-error-rate”。
缺省情况下,port bit error rate告警功能开启。
# 开启端口OLT1/0/1的port bit error rate告警功能。
[Sysname] interface olt1/0/1
[Sysname-Olt1/0/1] alarm port bit-error-rate enable
alarm registration-error enable
undo alarm registration-error enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm registration-error enable命令用来开启registration error告警功能。undo alarm registration-error enable命令用来关闭registration error告警功能。
当ONU在注册过程中发生错误时,就会引起registration error告警。
缺省情况下,registration error告警功能开启。
# 开启端口OLT1/0/1的registration error告警功能。
[Sysname-Olt1/0/1] alarm registration-error enable
alarm remote-stable enable
undo alarm remote-stable enable
OLT端口视图、FTTH视图
【缺省级别】
2:系统级
无
alarm remote-stable enable命令用来开启remote stable告警功能。undo alarm remote-stable enable命令用来关闭remote stable告警功能。
当系统中有ONU误用时,比如把OAM2.0的ONU与OAM3.3的ONU混用时(因为同一系统下的ONU必须采用同一OAM版本),就会引起remote stable告警。
l remote stable告警是ONU侧产生的告警,并且将其反馈给OLT。
缺省情况下,remote stable告警功能开启。
local stable告警命令可以参见“1.2.8 alarm local-stable”。
# 开启端口OLT1/0/1的remote stable告警功能。
[Sysname-Olt1/0/1] alarm remote-stable enable
alarm software-error enable
undo alarm software-error enable
FTTH视图
【缺省级别】
2:系统级
无
alarm software-error enable命令用来开启系统的software error告警功能。undo alarm software-error enable命令用来关闭系统的software error告警功能。
当信号量错误、DA异常(数据访问异常)或者内存分配失败时,就会产生software error告警。
缺省情况下,software error告警功能开启。
# 开启EPON系统software error告警功能。
[Sysname] ftth
[Sysname-ftth] alarm software-error enable
monitor enable
undo monitor enable
FTTH视图
【缺省级别】
2:系统级
无
monitor enable命令用来开启EPON系统的告警监视功能。undo monitor enable命令用来关闭EPON系统的告警监视功能。
缺省情况下,EPON系统的告警监视功能开启。
# 开启EPON系统的告警监视功能。
[Sysname] ftth
[Sysname-ftth] monitor enable
sample enable
undo sample enable
FTTH视图
【缺省级别】
2:系统级
无
sample enable命令用来开启系统的统计采样功能。undo sample enable命令用来关闭系统的统计采样功能。
缺省情况下,系统的统计采样功能打开。
# 开启EPON系统的统计采样功能。
[Sysname] ftth
[Sysname-ftth] sample enable
timer monitor seconds
undo timer monitor
FTTH视图
【缺省级别】
2:系统级
seconds:告警监视周期,单位为秒,取值范围为1~3600,缺省值为80秒。
timer monitor命令用来配置系统的告警监视周期。undo timer monitor命令用来恢复系统告警监视周期的缺省值。
# 配置EPON系统的告警监视周期为100秒。
[Sysname] ftth
[Sysname-ftth] timer monitor 100
timer sample seconds
undo timer sample
FTTH视图
【缺省级别】
2:系统级
seconds:统计采样周期,单位为秒,取值范围为1~3600,缺省值为4秒。
timer sample命令用来配置系统的统计采样周期。undo timer sample命令用来恢复系统统计采样周期为缺省值。
# 配置EPON系统的统计采样周期为10秒。
[Sysname] ftth
[Sysname-ftth] timer sample 10
