13-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS12500G-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release7634Pxx-6W10113-Network Management and Monitoring Configuration Guide
12-Mirroring configuration
12-Mirroring configuration 520.00 KB
Configuring port mirroring· 1
About port mirroring· 1
Terminology· 1
Port mirroring classification· 2
Local port mirroring (SPAN) 2
Layer 2 remote port mirroring (RSPAN) 2
Layer 3 remote port mirroring (ERSPAN) 4
Restrictions and guidelines: Port mirroring configuration· 6
Configuring local port mirroring (SPAN) 6
Restrictions and guidelines for local port mirroring configuration· 6
Local port mirroring tasks at a glance· 6
Creating a local mirroring group· 7
Configuring mirroring sources· 7
Configuring the monitor port 8
Configuring Layer 2 remote port mirroring (RSPAN) 8
Restrictions and guidelines for Layer 2 remote port mirroring configuration· 8
Layer 2 remote port mirroring with configurable reflector port configuration task list 9
Layer 2 remote port mirroring with egress port configuration task list 9
Creating a remote destination group· 10
Configuring the monitor port 10
Configuring the remote probe VLAN· 10
Assigning the monitor port to the remote probe VLAN· 11
Creating a remote source group· 11
Configuring mirroring sources· 11
Configuring the reflector port 12
Configuring the egress port 13
Configuring Layer 3 remote port mirroring· 14
Restrictions and guidelines for Layer 3 remote port mirroring configuration· 14
Layer 3 remote port mirroring tasks at a glance· 14
Prerequisites for Layer 3 remote port mirroring· 15
Configuring local mirroring groups· 15
Configuring mirroring sources· 15
Configuring the monitor port 16
Display and maintenance commands for port mirroring· 17
Port mirroring configuration examples· 17
Example: Configuring local port mirroring (SPAN in source port mode) 17
Example: Configuring local port mirroring (SPAN in source CPU mode) 18
Example: Configuring Layer 2 remote port mirroring (RSPAN with reflector port configurable) 19
Example: Configuring Layer 2 remote port mirroring (RSPAN with egress port) 21
Example: Configuring Layer 3 remote port mirroring (ERSPAN in tunnel mode) 24
Configuring flow mirroring· 27
About flow mirroring· 27
Types of flow-mirroring traffic to an interface· 27
Flow mirroring SPAN or RSPAN· 27
Flow mirroring ERSPAN· 28
Restrictions and guidelines: Flow mirroring configuration· 30
Flow mirroring tasks at a glance· 30
Configuring a traffic class· 31
Configuring a traffic behavior 31
Configuring a QoS policy· 32
Applying a QoS policy· 33
Applying a QoS policy to an interface· 33
Applying a QoS policy to a VLAN· 34
Applying a QoS policy globally· 34
Applying a QoS policy to the control plane· 34
Flow mirroring configuration examples· 35
Example: Configuring flow mirroring· 35
Port mirroring copies the packets passing through a port or CPU to a port that connects to a data monitoring device for packet analysis.
Terminology
The following terms are used in port mirroring configuration.
Mirroring source
The mirroring sources can be one or more monitored ports (called source ports) or CPUs (called source CPUs).
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Source device
The device where the mirroring sources reside is called a source device.
Mirroring destination
The mirroring destination connects to a data monitoring device and is the destination port (also known as the monitor port) of mirrored packets. Mirrored packets are sent out of the monitor port to the data monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port A when the following conditions exist:
·     Port A is monitoring bidirectional traffic of Port B and Port C on the same device.
·     The packet travels from Port B to Port C.
Destination device
The device where the monitor port resides is called the destination device.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
·     Inbound—Copies packets received.
·     Outbound—Copies packets sent.
·     Bidirectional—Copies packets received and sent.
Mirroring group
Port mirroring is implemented through mirroring groups. Mirroring groups can be classified into local mirroring groups, remote source groups, and remote destination groups.
Reflector port, egress port, and remote probe VLAN
Reflector ports, remote probe VLANs, and egress ports are used for Layer 2 remote port mirroring. The remote probe VLAN is a dedicated VLAN for transmitting mirrored packets to the destination device. Both the reflector port and egress port reside on a source device and send mirrored packets to the remote probe VLAN.
On port mirroring devices, all ports except source, destination, reflector, and egress ports are called common ports.
Port mirroring includes the following types:
·     Local port mirroringAlso known as Switch Port Analyzer (SPAN). In local port mirroring, the source device is directly connected to a data monitoring device. The source device acts as the destination device to forward mirrored packets to the data monitoring device.
·     Remote port mirroring—In remote port mirroring, the source device is not directly connected to a data monitoring device. The source device copies mirrored packets to the destination device, which forwards them to the data monitoring device. Depending on how the source device and the destination device are connected, remote port mirroring includes the following types:
¡     Layer 2 remote port mirroring—Also known as Remote SPAN (RSPAN). The source device and destination device are connected through a Layer 2 network.
¡     Layer 3 remote port mirroring—Also known as Encapsulated Remote SPAN (ERSPAN). The source device and destination device are connected through a Layer 3 network.
Figure 1 Local port mirroring implementation
As shown in Figure 1, the source port (Port A) and the monitor port (Port B) reside on the same device. Packets received on Port A are copied to Port B. Port B then forwards the packets to the data monitoring device for analysis.
In Layer 2 remote port mirroring, the mirroring sources and destination reside on different devices and are in different mirroring groups.
A remote source group is a mirroring group that contains the mirroring sources. A remote destination group is a mirroring group that contains the mirroring destination. Intermediate devices are the devices between the source device and the destination device.
Layer 2 remote port mirroring can be implemented through the reflector port method or the egress port method.
Reflector port method
In Layer 2 remote port mirroring that uses the reflector port method, packets are mirrored as follows:
1.     The source device copies packets received on the mirroring sources to the reflector port.
2.     The reflector port broadcasts the mirrored packets in the remote probe VLAN.
3.     The intermediate devices transmit the mirrored packets to the destination device through the remote probe VLAN.
4.     Upon receiving the mirrored packets, the destination device determines whether the ID of the mirrored packets is the same as the remote probe VLAN ID. If the two VLAN IDs match, the destination device forwards the mirrored packets to the data monitoring device through the monitor port.
Figure 2 Layer 2 remote port mirroring implementation through the reflector port method
Egress port method
In Layer 2 remote port mirroring that uses the egress port method, packets are mirrored as follows:
1.     The source device copies packets received on the mirroring sources to the egress port.
2.     The egress port forwards the mirrored packets to the intermediate devices.
3.     The intermediate devices flood the mirrored packets in the remote probe VLAN and transmit the mirrored packets to the destination device.
Figure 3 Layer 2 remote port mirroring implementation through the egress port method
Layer 3 remote port mirroring encapsulates mirrored packets in GRE packets with a protocol number of 0x88BE and routes the packets to the remote monitoring device.
Layer 3 remote port mirroring can be implemented in tunnel mode and encapsulation parameter mode. In the current software version, only the tunnel mode is supported.
Layer 3 remote port mirroring in tunnel mode
Configure the mirroring sources and destination for the local mirroring groups on the source device and destination device as follows:
·     On the source device:
¡     Configure the ports to be monitored as source ports.
¡     Configure the CPUs to be monitored as source CPUs.
¡     Configure the tunnel interface through which mirrored packets are forwarded to the destination device as the monitor port.
·     On the destination device:
¡     Configure the physical port corresponding to the tunnel interface as the source port.
¡     Configure the port that connects to the data monitoring device as the monitor port.
For example, in a network as shown in Figure 4, Layer 3 remote port mirroring in tunnel mode works as follows:
1.     The source device sends one copy of a packet received on the source port (Port A) to the tunnel interface.
The tunnel interface acts as the monitor port in the local mirroring group created on the source device.
2.     The tunnel interface on the source device forwards the mirrored packet to the tunnel interface on the destination device through the GRE tunnel.
3.     The destination device receives the mirrored packet from the physical interface of the tunnel interface.
The tunnel interface acts as the source port in the local mirroring group created on the destination device.
4.     The physical interface of the tunnel interface sends one copy of the packet to the monitor port (Port B).
5.     The monitor port (Port B) forwards the packet to the data monitoring device.
For more information about GRE tunnels and tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Figure 4 Layer 3 remote port mirroring in tunnel mode
Layer 3 remote port mirroring in encapsulation parameter mode
To implement Layer 3 remote port mirroring in encapsulation parameter mode, perform the following tasks:
1.     On the source device, create a local mirroring group and configure the mirroring sources, the monitor port, and the encapsulation parameters for mirrored packets.
2.     On all devices from source to destination, configure a unicast routing protocol to ensure Layer 3 reachability between the devices.
Create a local mirroring group on the source device, and specify the source ports and monitor port for the local mirroring group. When configuring the monitor port, specify the following encapsulation parameters for mirrored packets:
·     Monitoring device IP address as destination IP address.
·     Monitor port IP address as source IP address.
As shown in Figure 5, Layer 3 remote port mirroring in encapsulation parameter mode works as follows:
1.     The source device copies a packet passing through a source port.
2.     The source device encapsulates the copied packet with the specified encapsulation parameters, monitoring device IP as destination IP and monitor port IP as source IP.
3.     The encapsulated packet is routed to the monitoring device through the IP network.
4.     The monitoring device decapsulates the packet and analyzes the packet contents.
The packet sent to the monitoring device through Layer 3 remote port mirroring in encapsulation parameter mode is encapsulated. In this mode, make sure the monitoring device supports decapsulating packets.
Figure 5 Layer 3 remote port mirroring in encapsulation parameter mode
The reflector port method for Layer 2 remote port mirroring can be used to implement local port mirroring with multiple data monitoring devices.
In the reflector port method, the reflector port broadcasts mirrored packets in the remote probe VLAN. By assigning the ports that connect to data monitoring devices to the remote probe VLAN, you can implement local port mirroring to mirror packets to multiple data monitoring devices. The egress port method cannot implement local port mirroring in this way.
An aggregate interface cannot be configured as a mirroring source port, and an aggregation member port can be configured as a mirroring source port.
In a mirroring group, if an aggregation member port is configured as a source port, and an aggregate interface or aggregation member port is configured as the monitor port, make sure one of the corresponding aggregation groups operate in static aggregation mode. For more about the static aggregation mode, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide.
A port cannot be used by multiple mirroring groups at the same time.
A local mirroring group takes effect only after it is configured with the monitor port and mirroring sources.
To configure local port mirroring, perform the following tasks:
1.     Configuring mirroring sources
¡     Configuring source ports
¡     Configuring source CPUs
2.     Configuring the monitor port
2.     Create a local mirroring group.
mirroring-group group-id local
Restrictions and guidelines for mirroring source configuration
When you configure source ports for a local mirroring group, follow these restrictions and guidelines:
·     A mirroring group can contain multiple source ports.
·     A port can act as a source port for multiple mirroring groups.
·     A source port cannot be configured as a reflector port, egress port, or monitor port.
·     A VLAN interface cannot be configured as a source port.
A local mirroring group can contain multiple source CPUs.
·     Configure source ports in system view:
a.     Enter system view.
b.     Configure source ports for a local mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
By default, no source port is configured for a local mirroring group.
·     Configure source ports in interface view:
b.     Enter interface view.
c.     Configure the port as a source port for a local mirroring group.
mirroring-group group-id mirroring-port { both | inbound | outbound }
By default, a port does not act as a source port for any local mirroring groups.
2.     Configure source CPUs for a local mirroring group.
In standalone mode:
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
In IRF mode:
mirroring-group group-id mirroring-cpu chassis chassis-number slot slot-number-list { both | inbound | outbound }
By default, no source CPU is configured for a local mirroring group.
Do not enable the spanning tree feature on the monitor port.
Only one monitor port can be specified for a local mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not configure its member ports as source ports of the mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
·     Configure the monitor port in system view:
b.     Configure the monitor port for a local mirroring group.
mirroring-group group-id monitor-port interface-list
By default, no monitor port is configured for a local mirroring group.
·     Configure the monitor port in interface view:
c.     Configure the port as the monitor port for a mirroring group.
By default, a port does not act as the monitor port for any local mirroring groups.
To ensure successful traffic mirroring, configure devices in the order of the destination device, the intermediate devices, and the source device.
If intermediate devices exist, configure the intermediate devices to allow the remote probe VLAN to pass through.
For a mirrored packet to successfully arrive at the remote destination device, make sure its VLAN ID is not removed or changed.
Do not configure both MVRP and Layer 2 remote port mirroring. Otherwise, MVRP might register the remote probe VLAN with incorrect ports, which would cause the monitor port to receive undesired copies. For more information about MVRP, see Layer 2—LAN Switching Configuration Guide.
To monitor the bidirectional traffic of a source port, disable MAC address learning for the remote probe VLAN on the source, intermediate, and destination devices. For more information about MAC address learning, see Layer 2—LAN Switching Configuration Guide.
Configuring the destination device
1.     Creating a remote destination group
3.     Configuring the remote probe VLAN
4.     Assigning the monitor port to the remote probe VLAN
Configuring the source device
1.     Creating a remote source group
2.     Configuring mirroring sources
3.     Configuring the reflector port
4.     Configuring the remote probe VLAN
3.     Configuring the egress port
Perform this task on the destination device only.
2.     Create a remote destination group.
mirroring-group group-id remote-destination
Restrictions and guidelines for monitor port configuration
A monitor port can belong to only one mirroring group.
Only one monitor port can be specified for a remote destination group.
Configuring the monitor port in system view
2.     Configure the monitor port for a remote destination group.
By default, no monitor port is configured for a remote destination group.
Configuring the monitor port in interface view
2.     Enter interface view.
3.     Configure the port as the monitor port for a remote destination group.
By default, a port does not act as the monitor port for any remote destination groups.
This task is required on the both the source and destination devices.
Only an existing static VLAN can be configured as a remote probe VLAN.
When a VLAN is configured as a remote probe VLAN, use the remote probe VLAN for port mirroring exclusively.
Configure the same remote probe VLAN for the remote source group and the remote destination group.
2.     Configure the remote probe VLAN for the remote source or destination group.
mirroring-group group-id remote-probe vlan vlan-id
By default, no remote probe VLAN is configured for a remote source or destination group.
2.     Enter the interface view of the monitor port.
3.     Assign the port to the remote probe VLAN.
¡     Assign an access port to the remote probe VLAN.
port access vlan vlan-id
¡     Assign a trunk port to the remote probe VLAN.
port trunk permit vlan vlan-id
¡     Assign a hybrid port to the remote probe VLAN.
port hybrid vlan vlan-id { tagged | untagged }
For more information about the port access vlan, port trunk permit vlan, and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference.
Perform this task on the source device only.
2.     Create a remote source group.
mirroring-group group-id remote-source
When you configure source ports for a remote source group, follow these restrictions and guidelines:
·     Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
·     A source port cannot be configured as a reflector port, monitor port, or egress port.
A mirroring group can contain multiple source CPUs.
b.     Configure source ports for a remote source group.
By default, no source port is configured for a remote source group.
c.     Configure the port as a source port for a remote source group.
By default, a port does not act as a source port for any remote source groups.
2.     Configure source CPUs for a remote source group.
In standalone mode:
In IRF mode:
By default, no source CPU is configured for a remote source group.
Restrictions and guidelines for reflector port configuration
A remote source group supports only one reflector port.
A port can be configured as a reflector port only when it is operating with the default setting of the following parameters:
·     Duplex mode.
·     Speed.
·     MDI settings.
Configuring the reflector port in system view
2.     Configure the reflector port for a remote source group.
mirroring-group group-id reflector-port interface-type interface-number
CAUTION
CAUTION:
·     The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
·     When a port is configured as a reflector port, the default settings of the port are automatically restored. You cannot configure other features on the reflector port.
·     If an IRF port is bound to only one physical interface, do not configure the physical interface as a reflector port. Otherwise, the IRF might split.
By default, no reflector port is configured for a remote source group.
Configuring the reflector port in interface view
CAUTION
CAUTION:
3.     Configure the port as the reflector port for a remote source group.
By default, a port does not act as the reflector port for any remote source groups.
Restrictions and guidelines for egress port configuration
Disable the following features on the egress port:
·     Spanning tree.
·     802.1X.
·     IGMP snooping.
·     Static ARP.
·     MAC address learning.
A port of an existing mirroring group cannot be configured as an egress port.
A mirroring group supports only one egress port.
Configuring the egress port in system view
2.     Configure the egress port for a remote source group.
mirroring-group group-id monitor-egress interface-type interface-number
By default, no egress port is configured for a remote source group.
3.     Enter the egress port view.
4.     Assign the egress port to the remote probe VLAN.
For more information about the port trunk permit vlan and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference.
Configuring the egress port in interface view
3.     Configure the port as the egress port for a remote source group.
By default, a port does not act as the egress port for any remote source groups.
To implement Layer 3 remote port mirroring, you must configure a unicast routing protocol on the intermediate devices to ensure Layer 3 reachability between the source and destination devices.
1.     Configuring local mirroring groups
3.     Configuring the monitor port
Before configuring Layer 3 remote mirroring in tunnel mode, complete the following tasks:
·     Create a tunnel interface and a GRE tunnel.
·     Configure the source and destination addresses of the tunnel interface as the IP addresses of the physical interfaces on the source and destination devices, respectively.
For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Configure a local mirroring group on both the source device and the destination device.
By default, no local mirroring group exists.
·     On the source device, configure the ports you want to monitor as the source ports. On the destination device, configure the physical interface corresponding to the tunnel interface as the source port.
When you configure source CPUs for a local mirroring group, follow these restrictions and guidelines:
·     Perform this task on the source device only.
·     A mirroring group can contain multiple source CPUs.
In standalone mode:
In IRF mode:
On the source device, configure a tunnel interface as a monitor port. On the destination device, configure the port that connects to a data monitoring device as a monitor port.
On the destination device, do not enable the spanning tree feature on the monitor port.
c.     Configure the port as the monitor port for a local mirroring group.
Display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
As shown in Figure 6, configure local port mirroring in source port mode to enable the server to monitor the bidirectional traffic of the two departments.
Figure 6 Network diagram
# Create local mirroring group 1.
[Device] mirroring-group 1 local
# Configure HundredGigE 3/0/1 and HundredGigE 3/0/2 as source ports for local mirroring group 1.
[Device] mirroring-group 1 mirroring-port hundredgige 3/0/1 hundredgige 3/0/2 both
# Configure HundredGigE 3/0/3 as the monitor port for local mirroring group 1.
[Device] mirroring-group 1 monitor-port hundredgige 3/0/3
# Disable the spanning tree feature on the monitor port (HundredGigE 3/0/3).
[Device] interface hundredgige 3/0/3
[Device-HundredGigE3/0/3] undo stp enable
[Device-HundredGigE3/0/3] quit
# Verify the mirroring group configuration.
[Device] display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        HundredGigE3/0/1  Both
        HundredGigE3/0/2  Both
    Monitor port: HundredGigE3/0/3
As shown in Figure 7, HundredGigE 3/0/1 and HundredGigE 3/0/2 are located on the card in slot 1.
Configure local port mirroring in source CPU mode to enable the server to monitor all packets matching the following criteria:
·     Received and sent by the Marketing Department and the Technical Department.
·     Processed by the CPU in slot 1 of the device.
Figure 7 Network diagram
# Configure the CPU in slot 1 of the device as a source CPU for local mirroring group 1.
[Device] mirroring-group 1 mirroring-cpu slot 1 both
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring CPU:
        Slot 1  Both
As shown in Figure 8, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 8 Network diagram
1.     Configure Device C (the destination device):
# Configure HundredGigE 3/0/1 as a trunk port, and assign the port to VLAN 2.
<DeviceC> system-view
[DeviceC] interface hundredgige 3/0/1
[DeviceC-HundredGigE3/0/1] port link-type trunk
[DeviceC-HundredGigE3/0/1] port trunk permit vlan 2
[DeviceC-HundredGigE3/0/1] quit
# Create a remote destination group.
[DeviceC] mirroring-group 2 remote-destination
# Create VLAN 2.
[DeviceC] vlan 2
# Disable MAC address learning for VLAN 2.
[DeviceC-vlan2] undo mac-address mac-learning enable
[DeviceC-vlan2] quit
# Configure VLAN 2 as the remote probe VLAN for the mirroring group.
[DeviceC] mirroring-group 2 remote-probe vlan 2
# Configure HundredGigE 3/0/2 as the monitor port for the mirroring group.
[DeviceC] interface hundredgige 3/0/2
[DeviceC-HundredGigE3/0/2] mirroring-group 2 monitor-port
# Disable the spanning tree feature on HundredGigE 3/0/2.
[DeviceC-HundredGigE3/0/2] undo stp enable
# Assign HundredGigE 3/0/2 to VLAN 2.
[DeviceC-HundredGigE3/0/2] port access vlan 2
[DeviceC-HundredGigE3/0/2] quit
2.     Configure Device B (the intermediate device):
# Create VLAN 2.
[DeviceB] vlan 2
[DeviceB-vlan2] undo mac-address mac-learning enable
[DeviceB-vlan2] quit
[DeviceB] interface hundredgige 3/0/1
[DeviceB-HundredGigE3/0/1] port link-type trunk
[DeviceB-HundredGigE3/0/1] port trunk permit vlan 2
[DeviceB-HundredGigE3/0/1] quit
# Configure HundredGigE 3/0/2 as a trunk port, and assign the port to VLAN 2.
[DeviceB] interface hundredgige 3/0/2
[DeviceB-HundredGigE3/0/2] port link-type trunk
[DeviceB-HundredGigE3/0/2] port trunk permit vlan 2
[DeviceB-HundredGigE3/0/2] quit
3.     Configure Device A (the source device):
# Create a remote source group.
[DeviceA] mirroring-group 1 remote-source
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] undo mac-address mac-learning enable
[DeviceA-vlan2] quit
[DeviceA] mirroring-group 1 remote-probe vlan 2
# Configure HundredGigE 3/0/1 as a source port for the mirroring group.
[DeviceA] mirroring-group 1 mirroring-port hundredgige 3/0/1 both
# Configure HundredGigE 3/0/3 as the reflector port for the mirroring group.
[DeviceA] mirroring-group 1 reflector-port hundredgige 3/0/3
[DeviceA] interface hundredgige 3/0/2
[DeviceA-HundredGigE3/0/2] port link-type trunk
[DeviceA-HundredGigE3/0/2] port trunk permit vlan 2
[DeviceA-HundredGigE3/0/2] quit
# Verify the mirroring group configuration on Device C.
[DeviceC] display mirroring-group all
Mirroring group 2:
    Type: Remote destination
    Status: Active
    Monitor port: HundredGigE3/0/2
    Remote probe VLAN: 2
# Verify the mirroring group configuration on Device A.
[DeviceA] display mirroring-group all
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
    Reflector port: HundredGigE3/0/3
On the Layer 2 network shown in Figure 9, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 9 Network diagram
# Create VLAN 2.
[DeviceC] vlan 2
# Assign HundredGigE 3/0/2 to VLAN 2 as an access port.
# Create VLAN 2.
[DeviceB] vlan 2
# Create VLAN 2.
[DeviceA] vlan 2
# Configure VLAN 2 as the remote probe VLAN of the mirroring group.
# Configure HundredGigE 3/0/2 as the egress port for the mirroring group.
[DeviceA] mirroring-group 1 monitor-egress hundredgige 3/0/2
# Disable the spanning tree feature on the port.
[DeviceA-HundredGigE3/0/2] undo stp enable
Mirroring group 2:
    Status: Active
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
    Monitor egress port: HundredGigE3/0/2
On a Layer 3 network shown in Figure 10, configure Layer 3 remote port mirroring in tunnel mode to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 10 Network diagram
1.     Configure IP addresses for the tunnel interfaces and related ports on the devices. (Details not shown.)
2.     Configure Device A (the source device):
# Create service loopback group 1 and specify the unicast tunnel service for the group.
[DeviceA] service-loopback group 1 type tunnel
# Assign HundredGigE 3/0/3 to service loopback group 1.
[DeviceA] interface hundredgige 3/0/3
[DeviceA-HundredGigE3/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y
[DeviceA-HundredGigE3/0/3] quit
# Create tunnel interface Tunnel 1 that operates in GRE mode, and configure an IP address and subnet mask for the interface.
[DeviceA] interface tunnel 1 mode gre
[DeviceA-Tunnel1] ip address 50.1.1.1 24
# Configure source and destination IP addresses for Tunnel 1.
[DeviceA-Tunnel1] source 20.1.1.1
[DeviceA-Tunnel1] destination 30.1.1.2
[DeviceA-Tunnel1] quit
# Enable the OSPF protocol.
[DeviceA] ospf 1
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
[DeviceA] mirroring-group 1 local
# Configure HundredGigE 3/0/1 as a source port and Tunnel 1 as the monitor port of local mirroring group 1.
[DeviceA] mirroring-group 1 monitor-port tunnel 1
3.     Enable the OSPF protocol on Device B (the intermediate device).
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
4.     Configure Device C (the destination device):
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface hundredgige 3/0/3
[DeviceC-HundredGigE3/0/3] port service-loopback group 1
[DeviceC-HundredGigE3/0/3] quit
[DeviceC] interface tunnel 1 mode gre
[DeviceC-Tunnel1] ip address 50.1.1.2 24
[DeviceC-Tunnel1] source 30.1.1.2
[DeviceC-Tunnel1] destination 20.1.1.1
[DeviceC-Tunnel1] quit
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] mirroring-group 1 local
# Configure HundredGigE 3/0/1 as a source port for local mirroring group 1.
[DeviceC] mirroring-group 1 mirroring-port hundredgige 3/0/1 inbound
# Configure HundredGigE 3/0/2 as the monitor port for local mirroring group 1.
[DeviceC] mirroring-group 1 monitor-port hundredgige 3/0/2
# To prevent GRE-encapsulated packets from being used for any other purposes on Device C, configure an ACL to filter such packets.
[DeviceC] acl number 3900
[DeviceC-acl-ipv4-adv-3900] rule 0 deny gre source 50.1.1.1 0 destination 50.1.1.2 0
[DeviceC-HundredGigE3/0/1] packet-filter 3900 inbound
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
    Monitor port: Tunnel1
# Display information about all mirroring groups on Device C.
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        HundredGigE3/0/1  Inbound
Flow mirroring copies packets matching a class to a destination for packet analyzing and monitoring. It is implemented through QoS.
To implement flow mirroring through QoS, perform the following tasks:
·     Define traffic classes and configure match criteria to classify packets to be mirrored. Flow mirroring allows you to flexibly classify packets to be analyzed by defining match criteria.
·     Configure traffic behaviors to mirror the matching packets to the specified destination.
You can configure an action to mirror the matching packets to one of the following destinations:
·     Interface—The matching packets are copied to an interface and then forwarded to a data monitoring device for analysis.
·     CPU—The matching packets are copied to the CPU of an IRF member device. The CPU analyzes the packets or delivers them to upper layers.
·     (In standalone mode.) (In IRF mode.) CPU—The matching packets are copied to the CPU of the card where they are received. The CPU analyzes the packets or delivers them to upper layers.
·     In-band network telemetry (INT) processor—The matching packets are copied to the INT processor.
For more information about QoS policies, traffic classes, and traffic behaviors, see ACL and QoS Configuration Guide.
Depending on whether the mirroring source and mirroring destination are on the same device, flow-mirroring traffic to an interface includes the following types:
·     Flow mirroring SPAN—Flow-mirrors traffic to a local interface.
·     Flow mirroring RSPAN—Flow-mirrors traffic to an interface, and then forwards traffic to a remote Layer 2 interface based on the VLAN of the mirrored traffic or through QoS traffic redirecting.
·     Flow mirroring ERSPAN—Encapsulates traffic in GRE packets with protocol number 0x88BE and routes the traffic to a remote monitoring device at Layer 3.
For flow mirroring SPAN, configure a QoS policy on the source device. Configure the QoS policy as follows:
1.     Configure a traffic class to match packets.
2.     Configure a traffic behavior to flow-mirror traffic to an interfacewithout specifying the destination-ip or source-ip keyword.
3.     Associate the traffic class with the traffic behavior.
When the device receives a matching packet, the device sends one copy of the packet to the interface specified by the traffic behavior. The interface forwards the mirrored packet to the monitoring device.
Figure 11 Flow mirroring SPAN
To implement RSPAN, forward the mirrored packet to a remote Layer 2 interface based on the VLAN of the mirrored packet or through QoS traffic redirecting.
Flow mirroring ERSPAN can be implemented in loopback mode and encapsulation parameter mode.
In the current software version, the device supports only flow mirroring ERSPAN in encapsulation parameter mode. The information about flow mirroring ERSPAN in loopback mode is for your information only.
Loopback mode
As shown in Figure 12, configure flow mirroring ERSPAN in loopback mode as follows:
1.     On the source device, apply a QoS policy to the source interface as follows:
a.     Configure a traffic class to match packets.
b.     Configure a traffic behavior to mirror packets to Port B and specify the loopback keyword.
c.     Create a QoS policy, and associate the traffic class with the traffic behavior.
d.     Apply the QoS policy to the source interface.
2.     On the source device, apply a QoS policy to Port B as follows:
b.     Configure a traffic behavior to redirect packets to a tunnel interface.
d.     Apply the QoS policy to Port B.
3.     The destination device receives mirrored packets on the tunnel interface and decapsulates the packets. Then, the destination device forwards the packets based on the destination IP address of the original packets.
Make sure the destination device has the route and ARP entry to the destination IP address.
Figure 12 Flow mirroring ERSPAN in loopback mode
Encapsulation parameter mode
In this mode, configure a QoS policy on the source device. Configure the QoS policy as follows:
2.     Configure a traffic behavior to flow-mirror traffic to an interface.
You can configure flow-mirroring traffic to an interface in one of the following modes:
·     Directly specifying an outgoing interface—In this mode, specify both the outgoing interface and encapsulation parameters. The device encapsulates packets with the specified parameters and then forwards packets out of the specified interface.
·     Specifying an outgoing interface through route lookup—In this mode, specify only encapsulation parameters without specifying an outgoing interface. The device looks up a route for the encapsulated mirrored packets based on the source IP address and destination IP address of the encapsulated packets. The outgoing interface of the route is a destination interface of the mirrored packets.
In this mode, you can use the load sharing function of a routing protocol to forward mirrored packets to multiple destination interfaces.
As shown in Figure 13, flow mirroring ERSPAN in encapsulation parameter mode works as follows:
1.     The source device copies a matching packet.
2.     The source device encapsulates the packet with the specified ERSPAN encapsulation parameters.
3.     The source device forwards the packet in either of the following methods:
¡     Forwards the mirrored packets out of the specified outgoing interface.
¡     Looks up a route for the encapsulated mirrored packet based on the source IP address and destination IP address of the encapsulated packet.
4.     The encapsulated packet is routed to the monitoring device.
5.     The monitoring device decapsulates the packet and analyzes the packet contents.
The packet sent to the monitoring device through flow mirroring in this mode is encapsulated. In this mode, make sure the monitoring device supports decapsulating packets.
Figure 13 Flow mirroring ERSPAN in encapsulation parameter mode
For information about the configuration commands except the mirror-to command, see ACL and QoS Command Reference.
When a QoS policy configured with packet truncation is applied to the outbound direction of an interface, as a best practice, do not configure the source IP and destination IP encapsulated for mirrored packets on multiple cards.
When a QoS policy is applied to the outbound direction of an aggregation group, the flow mirroring action cannot be applied. A QoS policy can be applied to the outbound direction of Layer 2 aggregate interfaces, Layer 3 aggregate interfaces, and Layer 3 aggregate subinterfaces. A QoS policy can be applied to the outbound direction of up to 31 aggregate interfaces.
To configure flow mirroring, perform the following tasks:
1.     Configuring a traffic class
A traffic class defines the criteria that filters the traffic to be mirrored.
2.     Configuring a traffic behavior
A traffic behavior specifies mirroring destinations.
3.     Configuring a QoS policy
4.     Applying a QoS policy
¡     Applying a QoS policy to an interface
¡     Applying a QoS policy to a VLAN
¡     Applying a QoS policy globally
¡     Applying a QoS policy to the control plane
2.     Create a class and enter class view.
3.     Configure match criteria.
if-match match-criteria
By default, no match criterion is configured in a traffic class.
4.     (Optional.) Display traffic class information.
In standalone mode:
In IRF mode:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
For more information about this command, see ACL and QoS Command Reference.
2.     Create a traffic behavior and enter traffic behavior view.
3.     Configure mirroring destinations for the traffic behavior. Choose one option as needed:
¡     Mirror traffic to interfaces.
Syntax I:
mirror-to interface interface-type interface-number [ backup-interface interface-type interface-number ] [ sampler sampler-name ] [ truncation ] [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ vxlan vxlan-id [ destination-port destination-port-value | source-port source-port-value ] * ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * ] [ destination-mac mac-address ]
Syntax II:
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ vxlan vxlan-id [ destination-port destination-port-value | source-port source-port-value ] * ] [ sampler sampler-name ][ truncation ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
When you use syntax I or syntax II to configure flow-mirroring traffic to an interface, the destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address option must be deployed together with the vxlan vxlan-id [ destination-port destination-port-value | source-port source-port-value ] * option to take effect.
Syntax III:
mirror-to interface interface-type interface-number reflector-port interface-type interface-number strip-vlan vlan-id
When you use syntax III, the specified mirroring destination interface and reflector port must be assigned to a mirroring-type service loopback group. For more information about service loopback groups, see service loopback group configuration in Layer 2—LAN Switching Configuration Guide.
By default, no mirroring actions exist to mirror traffic to interfaces.
When you specify the vxlan parameter, you must also set the destination-port destination-port-value parameter to the default value 4789 for the VXLAN encapsulation to take effect.
When a QoS policy is applied to the outbound direction for flow mirroring ERSPAN, you cannot specify the vxlan parameter.
When the outgoing interface corresponding to the destination IP encapsulated for mirrored packets is a Layer 3 Ethernet subinterface, the VLAN to which the Layer 3 Ethernet subinterface belongs must be the same as the VLAN of mirrored packets.
Only flow mirroring ERSPAN supports the sampler and truncation parameters, and does not support the fixed sampling mode. In a QoS policy applied to the same interface, only one sampler can be referenced in traffic behaviors.
When a QoS policy is applied to the outbound direction for flow mirroring ERSPAN, you cannot specify the sampler parameter.
¡     Mirror traffic to the CPU.
mirror-to cpu
By default, no mirroring actions exist to mirror traffic to the CPU.
¡     Mirror traffic to the INT processor.
mirror-to ifa-processor [ sampler sampler-name ] [ vxlan ]
By default, no mirroring actions exist to mirror traffic to the INT processor.
For more information about the INT processor, see INT configuration in Telemetry Configuration Guide.
4.     (Optional.) Display traffic behavior configuration.
In standalone mode:
In IRF mode:
2.     Create a QoS policy and enter QoS policy view.
qos [ mirroring ] policy policy-name
3.     Associate a class with a traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, no traffic behavior is associated with a class.
4.     (Optional.) Display QoS policy configuration.
In standalone mode:
display qos policy user-defined mirroring [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
In IRF mode:
display qos policy user-defined mirroring [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
You can apply a QoS policy to an interface to mirror the traffic of the interface.
A policy can be applied to multiple interfaces.
In one traffic direction of an interface, only one QoS policy can be applied.
A QoS policy can be applied only to the outbound direction, and the QoS policy cannot be configured with both a flow-mirroring action and other actions.
3.     Apply a policy to the interface.
qos apply [ mirroring ] policy policy-name { inbound | outbound }
4.     (Optional.) Display the QoS policy applied to the interface.
In standalone mode:
display qos [ mirroring ] policy interface [ interface-type interface-number [ inbound | outbound ] [ slot slot-number ]
In IRF mode:
display qos [ mirroring ] policy interface [ interface-type interface-number [ inbound | outbound ] [ chassis chassis-number slot slot-number ]
You can apply a QoS policy to a VLAN to mirror the traffic on all ports in the VLAN.
A QoS policy cannot be applied in the outbound direction.
2.     Apply a QoS policy to a VLAN.
qos vlan-policy policy-name vlan vlan-id-list inbound
3.     (Optional.) Display the QoS policy applied to the VLAN.
In standalone mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] }inbound [ slot slot-number ]
In IRF mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } inbound [ chassis chassis-number slot slot-number ]
You can apply a QoS policy globally to mirror the traffic on all ports.
2.     Apply a QoS policy globally.
qos apply [ mirroring ] policy policy-name global inbound
3.     (Optional.) Display global QoS policies.
In standalone mode:
display qos [ mirroring ] policy global inbound [ slot slot-number ]
In IRF mode:
display qos [ mirroring ] policy global  inbound [ chassis chassis-number slot slot-number ]
You can apply a QoS policy to the control plane to mirror the traffic of all ports on the control plane.
2.     Enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
3.     Apply a QoS policy to the control plane.
qos apply [ mirroring ] policy policy-name inbound
4.     (Optional.) Display QoS policies applied to the control plane
In standalone mode:
display qos policy control-plane [ slot slot-number ]
In IRF mode:
display qos policy control-plane [ chassis chassis-number slot slot-number ]
As shown in Figure 14, configure flow mirroring so that the server can monitor the following traffic:
·     All traffic that the Technical Department sends to access the Internet.
·     IP traffic that the Technical Department sends to the Marketing Department during working hours (8:00 to 18:00) on weekdays.
Figure 14 Network diagram
# Create working hour range work, in which working hours are from 8:00 to 18:00 on weekdays.
[Device] time-range work 8:00 to 18:00 working-day
# Create IPv4 advanced ACL 3000 to allow packets from the Technical Department to access the Internet and the Marketing Department during working hours.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule permit tcp source 192.168.2.0 0.0.0.255 destination-port eq www
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255 time-range work
# Create traffic class tech_c, and configure the match criterion as ACL 3000.
[Device] traffic classifier tech_c
[Device-classifier-tech_c] if-match acl 3000
[Device-classifier-tech_c] quit
# Create traffic behavior tech_b, configure the action of mirroring traffic to HundredGigE 3/0/3.
[Device] traffic behavior tech_b
[Device-behavior-tech_b] mirror-to interface hundredgige 3/0/3
[Device-behavior-tech_b] quit
# Create QoS policy tech_p, and associate traffic class tech_c with traffic behavior tech_b in the QoS policy.
[Device] qos policy tech_p
[Device-qospolicy-tech_p] classifier tech_c behavior tech_b
[Device-qospolicy-tech_p] quit
# Apply QoS policy tech_p to the incoming packets of HundredGigE 3/0/4.
[Device] interface hundredgige 3/0/4
[Device-HundredGigE3/0/4] qos apply policy tech_p inbound
[Device-HundredGigE3/0/4] quit
# Verify that the server can monitor the following traffic:
·     All traffic sent by the Technical Department to access the Internet.
·     IP traffic that the Technical Department sends to the Marketing Department during working hours on weekdays.
