10-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS9820 SeriesConfigure & DeployConfiguration GuidesH3C S9820-8C Switch Configuration Guides-Release 6715-6W10010-Network Management and Monitoring Configuration Guide
16-Process monitoring and maintenance configuration
Monitoring and maintaining processes
About monitoring and maintaining processes
The system software of the device is a full-featured, modular, and scalable network operating system based on the Linux kernel. The system software features run the following types of independent processes:
·     User process—Runs in user space. Most system software features run user processes. Each process runs in an independent space so the failure of a process does not affect other processes. The system automatically monitors user processes. The system supports preemptive multithreading. A process can run multiple threads to support multiple activities. Whether a process supports multithreading depends on the software implementation.
·     Kernel thread—Runs in kernel space. A kernel thread executes kernel code. It has a higher security level than a user process. If a kernel thread fails, the system breaks down. You can monitor the running status of kernel threads.
Process monitoring and maintenance tasks at a glance
To monitor and maintain processes, perform the following tasks:
·     (Optional.) Starting or stopping a third-party process
¡     Starting a third-party process
¡     Stopping a third-party process
·     Monitoring and maintaining user processes
¡     Monitoring and maintaining processes
The commands in this section apply to both user processes and kernel threads.
¡     Monitoring and maintaining user processes
The commands in this section apply only to user processes.
·     Monitoring and maintaining kernel threads
¡     Monitoring and maintaining kernel threads
The commands in this section apply only to kernel threads.
About third-party processes
Third-party processes do not start up automatically. Use this feature to start or stop a third-party process, such as Puppet or Chef.
If you execute the third-part-process start command multiple times but specify the same process name, whether the command can be executed successfully depends on the process. You can use the display current-configuration | include third-part-process command to view the result.
2.     Start a third-party process.
third-part-process start name process-name [ arg args ]
1.     Display the IDs of third party processes.
display process all
This command is available in any view. "Y" in the THIRD field from the output indicates a third-party process, and the PID field indicates the ID of the process.
2.     Enter system view.
3.     Stop a third-party process.
third-part-process stop pid pid&<1-10>
This command can be used to stop only processes started by the third-part-process start command.
The commands in this section apply to both user processes and kernel threads. You can use the commands for the following purposes:
·     Display the overall memory usage.
·     Display the running processes and their memory and CPU usage.
·     Locate abnormal processes.
If a process consumes excessive memory or CPU resources, the system identifies the process as an abnormal process.
·     If an abnormal process is a user process, troubleshoot the process as described in "Monitoring and maintaining user processes."
·     If an abnormal process is a kernel thread, troubleshoot the process as described in "Monitoring and maintaining kernel threads."
Execute the following commands in any view.
Display memory usage.
Display process state information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
Display CPU usage for all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
Monitor process running state.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
Monitor thread running state.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
For more information about the display memory command, see Fundamentals Command Reference.
About monitoring and maintaining user processes
Use this feature to monitor abnormal user processes and locate problems.
Configuring core dump
The core dump feature enables the system to generate a core dump file each time a process crashes until the maximum number of core dump files is reached. A core dump file stores information about the process. You can send the core dump files to H3C Support to troubleshoot the problems.
Core dump files consume storage resources. Enable core dump only for processes that might have problems.
Execute the following commands in user view:
1.     (Optional.) Specify the directory for saving core dump files.
exception filepath directory
By default, the directory for saving core dump files is the root directory of the default file system. For more information about the default file system, see file system management in Fundamentals Configuration Guide.
2.     Enable core dump for a process and specify the maximum number of core dump files, or disable core dump for a process.
process core { maxcore value | off } { job job-id | name process-name }
By default, a process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
Display and maintenance commands for user processes
Execute display commands in any view and other commands in user view.
Display context information for process exceptions.
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
Display the core dump file directory.
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
Display log information for all user processes.
display process log [ slot slot-number [ cpu cpu-number ] ]
Display memory usage for all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
Display heap memory usage for a user process.
display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display information about used memory blocks for a user process.
display process memory fragment free job job-id [ slot slot-number [ cpu cpu-number ] ]
display process memory fragment used used-block job job-id [ slot slot-number [ cpu cpu-number ] ]
Display memory content starting from a specified memory block for a user process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
Display the addresses of memory blocks with a specified size used by a user process.
display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
Clear context information for process exceptions.
reset exception context [ slot slot-number [ cpu cpu-number ] ]
Configuring kernel thread deadloop detection
Kernel threads share resources. If a kernel thread monopolizes the CPU, other threads cannot run, resulting in a deadloop.
This feature enables the device to detect deadloops. If a thread occupies the CPU for a specific interval, the device determines that a deadloop has occurred and generates a deadloop message.
CAUTION
CAUTION:
Change kernel thread deadloop detection settings only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
2.     Enable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
By default, kernel thread deadloop detection is enabled.
3.     (Optional.) Set the threshold for identifying a kernel thread deadloop.
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
By default, the threshold for identifying a kernel thread deadloop is 22 seconds.
4.     (Optional.) Exclude a kernel thread from kernel thread deadloop detection.
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
When enabled, kernel thread deadloop detection monitors all kernel threads by default.
5.     (Optional.) Specify the action to be taken in response to a kernel thread deadloop.
monitor kernel deadloop action { reboot | record-only } [ slot slot-number [ cpu cpu-number ] ]
The default action is reboot.
Configuring kernel thread starvation detection
Starvation occurs when a thread is unable to access shared resources.
Kernel thread starvation detection enables the system to detect and report thread starvation. If a thread is not executed within a specific interval, the system determines that a starvation has occurred and generates a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
CAUTION
CAUTION:
Configure kernel thread starvation detection only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
2.     Enable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
By default, kernel thread starvation detection is disabled.
3.     (Optional.) Set the threshold for identifying a kernel thread starvation.
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
By default, the threshold for identifying a kernel thread starvation is 120 seconds.
4.     (Optional.) Exclude a kernel thread from kernel thread starvation detection.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
When enabled, kernel thread starvation detection monitors all kernel threads by default.
Configuring kernel-mode interrupt monitoring
Background
In an operating system, kernel mode is a permission execution mode of the CPU where the code can directly access all hardware resources and memory. In contrast, user mode is a restricted permission execution mode where regular applications run and cannot directly perform hardware operations.
An interrupt is a mechanism that temporarily suspends a task due to an external event (such as a hardware device request or an exception) during program execution by the CPU. The interrupt enables the operating system to immediately respond to various events.
A kernel-mode interrupt occurs when the CPU running in kernel mode receives an interrupt request. Such an interrupt typically handles critical system-level tasks, such as input/output (I/O) operations for hardware devices, memory management exceptions, and system calls. These operations require relatively high permissions to access hardware resources and can only be performed in kernel mode.
An interrupt is typically processed as follows:
1.     When an interrupt occurs, the CPU immediately completes the execution of the current instruction.
2.     Typically, the CPU protects the current environment by saving the register state to the stack.
3.     The CPU obtains the entry to the corresponding interrupt handler based on the interrupt vector table to execute the program.
4.     The CPU executes the interrupt handler and completes processing the interrupt event.
5.     After the interrupt handler execution is completed, the system restores the previously saved register state and returns to the interrupted program to resume execution.
Kernel-mode interrupt handling is critical for the performance and stability of an operating system. It requires meticulous design to ensure the response performance and resource usage efficiency of the system.
To avoid interrupting execution of critical code blocks, the operating system kernel can disable interrupts to temporarily prevent occurrences of interrupts. This is because interrupts can introduce race conditions or data inconsistencies when processing certain critical data structures or performing operations that must be completed consecutively.
When interrupts are disabled in kernel mode, the operating system either ignores most interrupt requests or handles them until interrupts are enabled again. This ensures the atomicity of the code block, which means the code block will either be completely executed or not be executed at all without interruption. This method also has its risks and disadvantages:
·     Reduced responsiveness—When interrupts are disabled, system response to interrupts might be delayed, which might affect the real-time performance of the system.
·     Deadlock risks—The system might enter a deadlock if it performs an operation for a long time when interrupts are disabled, or if a code error prevents interrupts from being enabled again.
·     Security risks—Disabling interrupts for a long time might result in missed critical hardware notifications, such as power failure, because interrupts are a key mechanism for interactions between the hardware and system.
Operating system designers are required to minimize the duration for disabling interrupts. They need to disable them for the shortest possible time when necessary.
Configure the interrupt disabling feature under the guidance of professional personnel.
Application scenarios
To ensure code block atomicity (the code block will either be completely executed or not be executed at all without interruption), some kernel threads might temporarily disable CPU interrupts automatically as needed. As a result, requests from other services might not be processed, causing the services to operate incorrectly. You can enable the kernel-mode interrupt monitoring feature to determine whether interrupts are disabled and to obtain disabled interrupt information for fault location.
Operating mechanism
After you enable the kernel-mode interrupt monitoring feature, the system monitors the duration for disabling CPU interrupts. If this duration reaches the specified threshold, a monitoring action is triggered. This monitoring action logs the interrupt information to a file in the /proc/ path. The file contains service process and duration information to facilitate fault location.
To view information about interrupts, use the display kernel monitor disable-interrupt info command.
Enabling the kernel-mode interrupt monitoring feature consumes additional CPU resources. When CPU resources are insufficient, other services on the device might be affected.
2.     Enable kernel-mode interrupt monitoring.
monitor kernel disable-interrupt [ threshold threshold ] [ slot slot-number [ cpu cpu-number ] ]
By default, kernel-mode interrupt monitoring is disabled.
Display and maintenance commands for kernel threads
Display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread exception information.
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel-mode interrupt monitoring information.
display kernel monitor disable-interrupt info [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread reboot information.
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread deadloop information.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread exception information.
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread reboot information.
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread starvation information.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
