04-Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10104-Network Configuration
02-Basic Network Access (DHCP-Based IP Address Acquisition) Configuration Examples (CLI)
Introduction
This document provides an example of configuring basic network access (DHCP-based IP address acquisition) through the CLI of a router.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of DHCP and NAT.
Example: Configuring basic network access
As shown in Figure 1, the device acts as the egress router on the enterprise network and uses a single DHCP-enabled interface to provide the PC with access to the Internet.
Figure 1 Network diagram
The address range in the address pool configured on the LAN interface cannot belong to the same network segment as the IP address of the WAN interface on the device.
Procedures
Configuring WAN interface settings
# Enable interface WAN1 (GE0/1) to use DHCP for IP address acquisition.
<Router> system-view
[Router] interface gigabitethernet 0/1
[Router-GigabitEthernet0/1] ip address dhcp-alloc
# Enable outbound dynamic NAT on interface WAN1 (GE0/1).
[Router-GigabitEthernet0/1] nat outbound
[Router-GigabitEthernet0/1] quit
Configuring LAN interface settings
# Configure interface GE0/2 as the gateway of the internal network.
[Router] interface gigabitethernet 0/2
[Router-GigabitEthernet0/2] ip address 192.168.10.1 24
[Router-GigabitEthernet0/2] quit
Configuring the device as an DHCP server
# Create DHCP address pool 1 and enter its view.
[Router] dhcp server ip-pool 1
# Specify network segment 192.168.10.0/24 for dynamic address allocation in DHCP address pool 1.
[Router-dhcp-pool-1] network 192.168.10.0 mask 255.255.255.0
# Specify gateway address 192.168.10.1 in DHCP address pool 1.
[Router-dhcp-pool-1] gateway-list 192.168.10.1
# Specify DNS server addresses 114.114.114.114 and 8.8.8.8 in DHCP address pool 1.
[Router-dhcp-pool-1] dns-list 114.114.114.114 8.8.8.8
# Set the lease duration to 10 days and 12 hours for IP addresses in DHCP address pool 1.
[Router-dhcp-pool-1] expired day 10 hour 12
[Router-dhcp-pool-1] quit
[Router] ip pool 1
[Router-ip-pool-1] network 192.168.10.0 mask 255.255.255.0
[Router-ip-pool-1] gateway-list 192.168.10.1
[Router-ip-pool-1] dns-list 114.114.114.114 8.8.8.8
[Router-ip-pool-1] expired day 10 hour 12
[Router-ip-pool-1] quit
# Enable interface GE0/2 to operate as a DHCP server and assign IP address to DHCP clients in the internal network.
[Router-GigabitEthernet0/2] dhcp select server
The PC can access the Internet.
