04-Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10104-Network Configuration
01-Access Public and Dedicated Networks Through Multiple WAN Interfaces (CLI)
Introduction
The following information describes how to use CLI to configure access to both a dedicated network and the public network through multiple WAN interfaces.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of DHCP and NAT.
Example: Configuring access to both a dedicated network and the public network through multiple WAN interfaces
As shown in Figure 1, the device acts as the egress router of the enterprise network. Interface WAN1 (GE0/1) accesses the public network through DHCP, and interface WAN2 (GE0/2) accesses a dedicated network through a private line. Configure the following settings for the PC to access both the public and dedicated networks:
·     Configure the public network segment as 10.10.10.0/24 and the private network segment as 10.10.20.0/24.
·     Configure the LAN segment as 192.168.10.0/24, and configure the device to act as the DHCP server to allocate IP addresses to clients.
Figure 1 Network diagram
Make sure the address pool specified on the LAN interface does not overlap with the WAN interface IP address range specified on the device.
Procedures
Configuring external network access settings
Configuring interface WAN1
# Configure interface WAN1 (GE0/1) to obtain public network addresses through DHCP.
<Router> system-view
[Router] interface gigabitethernet 0/1
[Router-GigabitEthernet0/1] ip address dhcp-alloc
# Configure outbound dynamic NAT.
[Router-GigabitEthernet0/1] nat outbound
[Router-GigabitEthernet0/1] quit
Configuring the LAN interface
# Configure interface GE0/3 as the LAN gateway.
[Router] interface gigabitethernet 0/3
[Router-GigabitEthernet0/3] ip address 192.168.10.1 24
[Router-GigabitEthernet0/3] quit
Configuring the device as the DHCP server
# Create DHCP address pool 1 and enter its view.
[Router] dhcp server ip-pool 1
# Specify subnet 192.168.10.0/24 for dynamic allocation in the address pool.
[Router-dhcp-pool-1] network 192.168.10.0 mask 255.255.255.0
# Specify gateway address 192.168.10.1 in the address pool.
[Router-dhcp-pool-1] gateway-list 192.168.10.1
# Configure 114.114.114.114 and 8.8.8.8 as the DNS server addresses.
[Router-dhcp-pool-1] dns-list 114.114.114.114 8.8.8.8
# Set the address lease to 10 days and 12 hours.
[Router-dhcp-pool-1] expired day 10 hour 12
[Router-dhcp-pool-1] quit
[Router] ip pool 1
[Router-ip-pool-1] network 192.168.10.0 mask 255.255.255.0
[Router-ip-pool-1] gateway-list 192.168.10.1
[Router-ip-pool-1] dns-list 114.114.114.114 8.8.8.8
[Router-ip-pool-1] expired day 10 hour 12
[Router-ip-pool-1] quit
# Configure interface GE0/3 as the DHCP server to allocate IP addresses to clients.
[Router-GigabitEthernet0/3] dhcp select server
Configuring dedicated network settings
# Configure interface WAN2 (GE0/2) to use a fixed address for network access.
[Router] interface gigabitethernet 0/2
[Router-GigabitEthernet0/2] ip address 10.10.10.2 24
[Router-GigabitEthernet0/2] nat outbound
[Router-GigabitEthernet0/2] quit
# Configure a static route.
[Router] ip route-static 10.10.20.0 255.255.255.0 10.10.10.1
Verify that the PC can access the Internet and IP dedicated network successfully. (Details not shown.)
