05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10005-Layer 2 - LAN Switching
11-HH3C-LswVLAN-MIB
11-HH3C-LswVLAN-MIB 121.00 KB
HH3C-LswVLAN-MIB
About this MIB
Use this MIB to configure basic VLAN settings and obtain basic VLAN information.
MIB file name
hh3c-splat-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswVlan(2)
Scalar objects
hh3cVLANMibGarpLeaveAllTime
Object (OID)
Access
Value range
Implementation
hh3cVLANMibGarpLeaveAllTime (1.3.6.1.4.1.25506.8.35.2.2.14)
read-write
Time-Interval
Standard MIB values.
GARP timer, in centiseconds.
Not supported
hh3cVLANMibSwitchGMRPRXPkt
Object (OID)
Access
Value range
Implementation
hh3cVLANMibSwitchGMRPRXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.1)
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGVRPRXPkt
Object (OID)
Access
Value range
Implementation
hh3cVLANMibSwitchGVRPRXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.2)
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGMRPTXPkt
Object (OID)
Access
Value range
Implementation
hh3cVLANMibSwitchGMRPTXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.3)
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGVRPTXPkt
Object (OID)
Access
Value range
Implementation
hh3cVLANMibSwitchGVRPTXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.4)
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchDiscardedPkt
Object (OID)
Access
Value range
Implementation
hh3cVLANMibSwitchDiscardedPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.5)
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGarpStatClear
Object (OID)
Access
Value range
Implementation
hh3cVLANMibSwitchGarpStatClear (1.3.6.1.4.1.25506.8.35.2.2.15.1.6)
read-write
INTEGER
Traffic switch.
Not supported
hh3cVLANMibHoldTime
Object (OID)
Access
Value range
Implementation
hh3cVLANMibHoldTime (1.3.6.1.4.1.25506.8.35.2.2.16.1.1)
read-write
INTEGER
INTEGER (10..32765)
Interface holdtime.
Not supported
Tabular objects
hh3cdot1qVlanMIBTable
About this table
Use this table to manage and monitor VLANs, create and delete VLANs, and configure and obtain the proprietary VLAN data.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cdot1qVlanIndex, which specifies a VLAN ID. Use this table to create and delete VLANs, configure VLAN attributes, and obtain VLAN data.
The leaf objects in the table include configuration objects and query objects. The configuration objects can be written and read, and the query objects can only be read.
The following objects are configuration objects, and the other objects are query objects:
·     hh3cdot1qVlanName
·     hh3cdot1qVlanPorts
·     hh3cdot1qVlanType
·     hh3cdot1qVlanPriority
·     hh3cdot1qVlanRowStatus
·     hh3cdot1qVlanBroadcastSuppression
·     hh3cdot1qVlanBcastSuppressionPPS
·     hh3cdot1qVlanMulticast  (not supported)
hh3cdot1qVlanMIBTable configuration guidelines:
This table supports creating a row, namely, creating a VLAN. When creating a row, as a best practice, first traverse through the table, and use a VLAN ID that does not exist in the table. Available values are active(1), createAndGo(4), and destroy(6). This table involves the following two types of operation:
·     hh3cdot1qVlanRowStatus (createAndGo(4)): Create a VLAN and configure the following attribute objects:
¡     hh3cdot1qVlanName
¡     hh3cdot1qVlanPorts
¡     hh3cdot1qVlanType
¡     hh3cdot1qVlanPriority
¡     hh3cdot1qVlanBroadcastSuppression
¡     hh3cdot1qVlanBcastSuppressionPPS
¡     hh3cdot1qVlanMulticast (Not support)
First check the input string for hh3cdot1qVlanName. Continue to create the VLAN after the check passes. After the VLAN is successfully created, configure the leaf objects listed above. The operation will fail if the configuration of any leaf object has errors. For example:
¡     hh3cdot1qVlanPorts: This object can only add an access port to or remove an access port from a VLAN. If a configured port is not an access port, the configuration for this object fails.
¡     hh3cdot1qVlanType: The MIB does not support sub-vlan(3). When the hh3cdot1qVlanRowStatus(createAndGo(4)) and hh3cdot1qVlanType(sub-vlan(3)) are executed in pairs, the operation fails.
As a best practice to avoid such errors, use the hh3cdot1qVlanRowStatus(createAndGo(4)) to create a VLAN and configure the other attribute objects separately.
·     When a VLAN already exists, configure the following attribute objects:
¡     hh3cdot1qVlanName      Enter a string of up to 32 bytes.
¡     hh3cdot1qVlanPorts       First obtain the local object data, and then modify the bit corresponding to the interface in the data. Use the modified value as the configured value.
¡     hh3cdot1qVlanType       This MIB does not support the sub-vlan(3) or secondary-vlan(5) type.
¡     hh3cdot1qVlanMulticast  (not supported)
Configuration examples
·     Configuration success: Use a VLAN ID that does not exist as an index, input vlantest for the hh3cdot1qVlanName object, and operate the row state object hh3cdot1qVlanRowStatus(createAndGo(4)) to create a VLAN. This operation successfully creates a VLAN and specifies a name for the VLAN.
·     Configuration failure: A trunk interface cannot be assigned to a VLAN. Use the hh3cdot1qVlanPorts object to specify the trunk ports, and operate the row state object hh3cdot1qVlanRowStatus(createAndGo(4)) to create a VLAN. This operation fails.
Object (OID)
Access
Value range
Implementation
hh3cdot1qVlanIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.1)
read-only
Hh3cVlanIndex
Integer32 (0..2147483647)
VLAN index.
As per the MIB.
hh3cdot1qVlanName (1.3.6.1.4.1.25506.8.35.2.1.1.1.2)
read-write
SnmpAdminString
OCTET STRING (0..80)
VLAN name.
If the VLAN name input starts or ends with spaces, the spaces will be automatically trimmed.
The string cannot contain only spaces. If you enter an empty string, the default VLAN description is used.
hh3cdot1qVlanPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.3)
read-write
PortList
OCTET STRING (0..65535)
List of ports in a VLAN.
This object can only assign access ports to and remove access ports from VLANs.
hh3cdot1qVlanType (1.3.6.1.4.1.25506.8.35.2.1.1.1.4)
read-write
Integer
superVlan(1)
common-vlan(2)
sub-vlan(3)
isolate-user-vlan(4)
secondary-vlan(5)
primaryVlan(6)
VLAN type.
Not supported
hh3cdot1qVlanMacFilter (1.3.6.1.4.1.25506.8.35.2.1.1.1.5)
read-only
TruthValue
true(1),
false(2)
MAC VLAN filtering
Not supported. The default false(2) is displayed.
hh3cdot1qVlanMcastUnknownProtos (1.3.6.1.4.1.25506.8.35.2.1.1.1.6)
read-only
TruthValue
true(1),
false(2)
Whether to broadcast packets.
hh3cExistInterface (1.3.6.1.4.1.25506.8.35.2.1.1.1.7)
read-only
TruthValue
true(1),
false(2)
Whether the VLAN has a VLAN interface.
As per the MIB.
hh3cVlanInterfaceIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.8)
read-only
Integer
Integer
(1..4094)
Index of the VLAN interface.
As per the MIB.
hh3cdot1qVlanMacLearn (1.3.6.1.4.1.25506.8.35.2.1.1.1.9)
read-only
TruthValue
true(1),
false(2)
Whether MAC address learning is supported.
hh3cdot1qVlanStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.10)
read-only
Integer
other(1),
static(2),
dynamic(3)
VLAN state.
As per the MIB.
hh3cdot1qVlanCreationTime (1.3.6.1.4.1.25506.8.35.2.1.1.1.11)
read-only
TimeTicks
TimeTicks (0..4294967295)
Time when the VLAN was created.
As per the MIB.
hh3cdot1qVlanPriority (1.3.6.1.4.1.25506.8.35.2.1.1.1.12)
read-write
Integer
Integer
(0..7)
VLAN priority.
The actual access is read-only. The default is 0.
hh3cdot1qVlanRowStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.13)
read-create
Row-Status
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
VLAN row state.
Only the following operations are supported:
hh3cdot1qVlanBroadcastSuppression (1.3.6.1.4.1.25506.8.35.2.1.1.1.14)
read-write
Integer
Integer
(0..100)
VLAN broadcast suppression.
The object can only be read.
(1.3.6.1.4.1.25506.8.35.2.1.1.1.15)
read-write
Integer
Integer
(0..148800)
VLAN broadcast suppression in pps.
Not supported
(1.3.6.1.4.1.25506.8.35.2.1.1.1.16)
read-write
Integer
disable(0),
enable(1)
Multicast VLAN.
Not supported
hh3cdot1qVlanTaggedPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.17)
read-only
PortList
Tagged ports of a VLAN.
As per the MIB.
hh3cdot1qVlanUntaggedPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.18)
read-only
PortList
Untagged ports of a VLAN.
As per the MIB.
hh3cdot1qVlanPortIndexs (1.3.6.1.4.1.25506.8.35.2.1.1.1.19)
read-write
OCTET STRING
Port index list.
As per the MIB.
hh3cVlanInterfaceTable
About this table
Use this table to configure and obtain VLAN interface information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cdot1qVlanID.
You must specify the hh3cdot1qVlanIpAddress and hh3cdot1qVlanIpAddressMask objects in pairs.
Object (OID)
Access
Value range
Implementation
hh3cVlanInterfaceID (1.3.6.1.4.1.25506.8.35.2.1.2.1.1)
read-only
Integer
Index.
As per the MIB.
hh3cdot1qVlanID (1.3.6.1.4.1.25506.8.35.2.1.2.1.2)
read-only
Hh3cVlanIndex
VLAN ID
As per the MIB.
hh3cdot1qVlanIpAddress (1.3.6.1.4.1.25506.8.35.2.1.2.1.3)
read-write
IpAddress
IP address.
As per the MIB.
hh3cdot1qVlanIpAddressMask (1.3.6.1.4.1.25506.8.35.2.1.2.1.4)
read-write
IpAddress
IP address and its mask.
As per the MIB.
hh3cVlanInterfaceAdminStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.5)
read-write
Integer
up(1),
down(2)
VLAN interface state.
As per the MIB.
hh3cVlanInterfaceFrameType (1.3.6.1.4.1.25506.8.35.2.1.2.1.6)
read-only
Integer
ethernet-ii(1),
ethernet-snap(2),
ethernet-8022(3),
ethernet-8023(4)
Frame type.
As per the MIB.
hh3cInterfaceRowStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface row state.
Available values are active(1), createAndgo(4), and destroy(6).
When the row is created together with configuring other attribute objects, the VLAN interface is first created, and then other attribute objects are configured.
If an object fails to be configured, this operation fails.
As a best practice, use the hh3cInterfaceRowStatus (createAndGo(4)) to create a VLAN interface and configure other attribute objects separately.
When the row state is active, the createAndGo operation succeeds.
hh3cVlanInterfaceIpMethod (1.3.6.1.4.1.25506.8.35.2.1.2.1.8)
read-write
Integer
assigned-ip(1),
dhcp-ip(2),
bootp-ip(3)
VLAN interface IP address assignment method.
hh3cVlanInterfaceIfIndex (1.3.6.1.4.1.25506.8.35.2.1.2.1.9)
read-only
Integer
As per the MIB.
hh3cifIsolateMappingTable (not supported)
About this table
Use this table to configure the isolate VLAN feature and configure and obtain the isolate VLAN-to-secondary VLAN mappings. Implementation varies by product.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cifIsolatePrimaryVlanID.
You must specify the hh3cifIsolateSecondaryVlanlistLow and hh3cifIsolateSecondaryVlanlistHigh objects in pairs.
Object (OID)
Access
Value range
Implementation
hh3cifIsolatePrimaryVlanID (1.3.6.1.4.1.25506.8.35.2.1.4.1.1)
read-only
Hh3cVlanIndex
Primary VLAN
hh3cifIsolateSecondaryVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.4.1.2)
read-write
OCTET STRING
OCTET STRING (0..256)
Low bit in the secondary VLAN bitmap.
hh3cifIsolateSecondaryVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.4.1.3)
read-write
OCTET STRING
High bit in the secondary VLAN bitmap.
hh3cVlanInterfaceAddrTable
About this table
Use this table to configure and obtain VLAN interface IP addresses.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cVlanInterfaceIpIfIndex and hh3cVlanInterfaceIpAddr.
When the hh3cVlanInterfaceIpRowStatus (createAndgo(4)) operation is executed, you must specify the hh3cVlanInterfaceIpAddr and hh3cVlanInterfaceIpMask objects in pairs. When the hh3cVlanInterfaceIpRowStatus (destroy(6)) operation is executed, you must specify the hh3cVlanInterfaceIpAddr and hh3cVlanInterfaceIpType objects in pairs.
Object (OID)
Access
Value range
Implementation
hh3cVlanInterfaceIpIfIndex (1.3.6.1.4.1.25506.8.35.2.1.5.1.1)
read-only
Integer
As per the MIB.
hh3cVlanInterfaceIpAddr (1.3.6.1.4.1.25506.8.35.2.1.5.1.2)
read-only
IpAddress
OCTET STRING (4)
VLAN interface IP address.
As per the MIB.
hh3cVlanInterfaceIpMask (1.3.6.1.4.1.25506.8.35.2.1.5.1.3)
read-create
IpAddress
OCTET STRING (4)
VLAN Interface IP address mask.
As per the MIB.
hh3cVlanInterfaceIpType (1.3.6.1.4.1.25506.8.35.2.1.5.1.4)
read-create
Integer
primary(1),
sub(2),
cluster(3),
vrrp(4)
VLAN interface IP type.
As per the MIB.
Available values are primary(1) and sub(2).
hh3cVlanInterfaceIpRowStatus (1.3.6.1.4.1.25506.8.35.2.1.5.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface IP address row state.
hh3cDot1qVlanBatchMIBTable
About this table
Use this table to bulk configure VLANs.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cdot1qVlanBatchStartIndex, hh3cdot1qVlanBatchEndIndex, and hh3cdot1qVlanBatchSetOperate.
To bulk create VLANs, set the hh3cdot1qVlanBatchSetOperate object to 1.
For example, to create VLANs 2 through 4, enter the following values for objects:
 hh3cdot1qVlanBatchStartIndex 2,
 hh3cdot1qVlanBatchEndIndex 4,
 hh3cdot1qVlanBatchSetOperate create(1),
 hh3cdot1qVlanBatchRowStatus createAndGo(4).
To bulk delete VLANs, set the hh3cdot1qVlanBatchSetOperate object to 2.
For example, to delete VLANs 10 through 20, enter the following values for objects:
 hh3cdot1qVlanBatchStartIndex 10,
 hh3cdot1qVlanBatchEndIndex 20,
 hh3cdot1qVlanBatchSetOperate delete(2),
Object (OID)
Access
Value range
Implementation
hh3cdot1qVlanBatchOperIndex (1.3.6.1.4.1.25506.8.35.2.1.6.1.1)
read-only
Integer32
Operation index.
Not supported
hh3cdot1qVlanBatchStartIndex (1.3.6.1.4.1.25506.8.35.2.1.6.1.2)
read-write
Hh3cVlanIndex
Start VLAN ID.
Not supported
hh3cdot1qVlanBatchEndIndex (1.3.6.1.4.1.25506.8.35.2.1.6.1.3)
read-write
Hh3cVlanIndex
End VLAN ID.
Not supported
hh3cdot1qVlanBatchOperStatus
(1.3.6.1.4.1.25506.8.35.2.1.6.1.4)
read-only
Integer
Operation state.
Not supported
(1.3.6.1.4.1.25506.8.35.2.1.6.1.5)
read-create
Row-Status
Row status.
Not supported
(1.3.6.1.4.1.25506.8.35.2.1.6.1.6)
read-create
Integer
Set the operation type.
Not supported
hh3cifSuperVlanMappingTable
About this table
Use this table to configure the super VLAN feature and configure and obtain the super VLAN-to-sub VLAN mappings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cifSuperVlanID.
When setting super VLAN, you must specify the hh3cifSubVlanlistLow and hh3cifSubVlanlistHigh objects in pairs.
Object (OID)
Access
Value range
Implementation
hh3cifSuperVlanID (1.3.6.1.4.1.25506.8.35.2.1.7.1.1)
read-only
Hh3cVlanIndex
Super VLAN index.
Not supported
hh3cifSubVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.7.1.2)
read-write
OCTET STRING
Low bit in the sub VLAN bitmap.
Not supported
hh3cifSubVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.7.1.3)
read-write
OCTET STRING
High bit in the sub VLAN bitmap.
Not supported
hh3cPrivateVlanMappingTable
About this table
Use this table to configure the private VLAN feature and configure and obtain the primary VLAN-to-secondary VLAN mappings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cPrimaryVlanID.
When setting private VLAN, you must specify the hh3cSecondaryVlanlistLow and hh3cSecondaryVlanlistHigh objects in pairs.
Object (OID)
Access
Value range
Implementation
hh3cPrimaryVlanID (1.3.6.1.4.1.25506.8.35.2.1.8.1.1)
read-only
Hh3cVlanIndex
Primary VLAN index.
As per the MIB.
hh3cSecondaryVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.8.1.2)
read-write
OCTET STRING
As per the MIB.
hh3cSecondaryVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.8.1.3)
read-write
OCTET STRING
As per the MIB.
