05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10005-Layer 2 - LAN Switching
07-HH3C-MAC-INFORMATION-MIB
07-HH3C-MAC-INFORMATION-MIB 83.70 KB
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACInformation(87)
Scalar objects
hh3cMACInformationEnabled
Object (OID)
Access
Value range
Implementation
hh3cMACInformationEnabled (1.3.6.1.4.1.25506.2.87.1.1.1)
read-write
INTEGER
enabled(1)
disabled(2)
Status of the MAC Information feature.
As per the MIB.
hh3cMACInformationcSendInterval
Object (OID)
Access
Value range
Implementation
hh3cMACInformationcSendInterval(1.3.6.1.4.1.25506.2.87.1.1.2)
read-write
Integer32
Integer32 (1..20000)
MAC change notification interval.
As per the MIB.
hh3cMACInformationLearntMACNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationLearntMACNum(1.3.6.1.4.1.25506.2.87.1.1.3)
read-only
Counter32
Standard MIB values.
Total number of the MAC addresses learned since MAC information is enabled.
As per the MIB.
hh3cMACInformationRemovedMACNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationRemovedMACNum (1.3.6.1.4.1.25506.2.87.1.1.4)
read-only
Counter32
Total number of the MAC addresses deleted or aged since MAC information is enabled.
As per the MIB.
hh3cMACInformationTrapSendNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationTrapSendNum (1.3.6.1.4.1.25506.2.87.1.1.5)
read-only
Counter32
Number of sent SNMP notifications.
As per the MIB.
hh3cMACInformationSyslogSendNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationSyslogSendNum (1.3.6.1.4.1.25506.2.87.1.1.6)
read-write
Counter32
Number of sent syslog messages.
As per the MIB.
hh3cMACInformationCacheLen
Object (OID)
Access
Value range
Implementation
hh3cMACInformationCacheLen (1.3.6.1.4.1.25506.2.87.1.1.7)
read-write
Integer32
Integer32 (0..1000)
MAC Information queue length.
As per the MIB.
hh3cMACInfomationWorkMode
Object (OID)
Access
Value range
Implementation
hh3cMACInfomationWorkMode (1.3.6.1.4.1.25506.2.87.1.1.8)
read-write
Hh3cMACInfoWorkMode
trap(1)
syslog(2)
MAC Information mode
As per the MIB.
hh3cMACInfoTrapVerExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapVerExt (1.3.6.1.4.1.25506.2.87.1.4.2.1)
accessible-for-notify
Integer32
SNMP version.
As per the MIB.
hh3cMACInfoTrapIndexExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapIndexExt (1.3.6.1.4.1.25506.2.87.1.4.2.2)
Integer32
Integer32 (0..4294967295)
Notification index.
As per the MIB.
hh3cMACInfoTrapCountExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapCountExt (1.3.6.1.4.1.25506.2.87.1.4.2.3)
Integer32
Notification count.
As per the MIB.
hh3cMACInfoTrapMsgExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgExt (1.3.6.1.4.1.25506.2.87.1.4.2.4)
OCTET STRING
OCTET STRING (0..255)
Notification contents.
As per the MIB.
Tabular objects
hh3cMACInfomationIfTable
About this table
Use this table to configure MAC Information on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cMACLearntEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.1)
read-write
INTEGER
enabled(1)
disabled(2)
MAC learning event reporting.
As per the MIB.
hh3cMACRemovedEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.2)
read-write
INTEGER
enabled(1)
disabled(2)
MAC aging or deletion event reporting.
As per the MIB.
Notifications
This table contains notifications output by HH3C-MAC-INFORMATION-MIB.
hh3cMACInformationChangedTrapExt
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.1
MAC changes.
Informational
ON
This notification is generated when MAC addresses change.
If the number of cached MAC notifications reaches the limit set with hh3cMACInformationCacheLen while the amount of time that has elapsed since last notification transmission is shorter than the interval set with hh3cMACInformationcSendInterval, the device uses a new MAC notification to overwrite the oldest one. If the elapsed time is longer than the interval and at least one cached MAC address has been learned or deleted, the device sends notifications.
Status control
This notification cannot be disabled.
Objects
OID (Object name)
Index
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.1 (hh3cMACInfoTrapVerExt)
SNMP version.
N
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.2 (hh3cMACInfoTrapIndexExt)
Notification index.
N
Unsigned32
Unsigned32 (1..2147483647)
1.3.6.1.4.1.25506.2.87.1.4.2.3 (hh3cMACInfoTrapCountExt)
Notification count.
N
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.4 (hh3cMACInfoTrapMsgExt)
N
OCTET STRING
OCTET STRING (1..254)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
