05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10005-Layer 2 - LAN Switching
05-HH3C-LswMAM-MIB
05-HH3C-LswMAM-MIB 57.95 KB
HH3C-LswMAM-MIB
About this MIB
Use this MIB to configure unicast MAC address entries.
MIB file name
hh3c-splat-mam.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswMAM(3)
Tabular objects
hh3cdot1qTpFdbSetTable
About this table
Use this table to configure unicast MAC address entries.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cdot1qVlanIndex and hh3cdot1qTpFdbSetAddress.
Object (OID)
Access
Value range
Implementation
hh3cdot1qTpFdbSetAddress (1.3.6.1.4.1.25506.8.35.3.2.1.1)
not-accessible
MacAddress
Standard MIB values.
Unicast MAC address entry.
As per the MIB.
hh3cdot1qTpFdbSetPort (1.3.6.1.4.1.25506.8.35.3.2.1.2)
read-write
InterfaceIndex
Index of the interface corresponding to the MAC address entry.
The object value is 0 when the state of the MAC address entry is blackhole.
hh3cdot1qTpFdbSetStatus (1.3.6.1.4.1.25506.8.35.3.2.1.3)
read-write
INTEGER
other(1),
learned(3),
static(6),
dynamic(7),
blackhole(9),
security(11)
MAC address entry state.
A MAC address entry configured with the dynamic type will be added to the learned MAC address entry list.
hh3cdot1qTpFdbSetOperate (1.3.6.1.4.1.25506.8.35.3.2.1.4)
read-write
INTEGER
add(1),
delete(2)
Add or delete a MAC address entry.
The object can only be written.
