H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration ExamplesH3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
54-Attack Protection Configuration Examples
54-Attack Protection Configuration Examples 357.38 KB
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples of link layer attack protection, ARP attack protection, network layer attack protection, and transport layer attack protection, as defined in Table 1.
Table 1 Attack protection types
Link layer attack protection
MAC address attack protection
Prevents the attack of packets with different source MAC addresses or VLANs by configuring the maximum number of MAC addresses that an interface can learn.
STP packet attack protection
Provides protection measures such as BPDU guard, root guard, loop guard, and TC-BPDU guard.
ARP source suppression
Prevents IP attack packets from fixed sources.
ARP black hole routing
Prevents IP attack packets from sources that are not fixed.
ARP active acknowledgement
Prevents user spoofing.
Source MAC-based ARP attack detection
Prevents ARP packet attacks from the same source MAC.
ARP packet source MAC consistency check
Prevents attacks from ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
Network layer attack protection
uRPF check
Protects a network against source spoofing attacks.
TTL attack protection
Prevents an attack by disabling sending ICMP time exceeded messages.
Transport layer attack protection
SYN flood attack protection
Enables the server to return a SYN ACK message when it receives a TCP connection request, without establishing a half-open TCP connection.
This document assumes that you have basic knowledge of attack protection.
Example: Configuring link layer attack protection
As shown in Figure 1, Device A, Device B, and Device C run MSTP. Device B acts as the root bridge, and Ten-GigabitEthernet 1/0/1 on Device C is blocked.
Configure the following features to prevent link layer attacks:
·     Configure root guard on Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/2 of Device B for Device B to act as the root bridge.
·     Configure loop guard on Ten-GigabitEthernet 2/0/2 of Device C to prevent temporary loops. The loop guard feature keeps the port in Discarding state in all MSTIs when it receives no BPDU.
·     Configure BPDU guard on ports at the access side of Device A and Device C. The BPDU guard feature prevents the ports from performing spanning tree calculations when it receives forged BPDUs with a higher priority.
·     Enable TC-BPDU guard on Device A, Device B, and Device C. The TC-BPDU guard feature prevents a large number of TC-BPDUs from affecting the network in a short time.
·     Set the maximum number of MAC addresses that can be learned by ports at the access side of Device A and Device C. This configuration protects the devices from a large number of attack packets that have different source MAC addresses. The attack packets might cause a large MAC table and low forwarding performance.
·     Configure broadcast and multicast suppression on the designated ports of Device B and all ports on Device A and Device C. When incoming broadcast or multicast traffic exceeds the threshold (6400 pps), an interface discards broadcast or multicast packets until the traffic drops below the threshold.
Figure 1 Network diagram
Analysis
For the ports at the access side of Device A and Device C to rapidly transit to the forwarding state, use the stp edged-port command to configure these ports as edge ports.
This example uses Ten-GigabitEthernet 2/0/3 to illustrate the configuration on the ports at the access side on Device A and Device C.
Software versions used
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product
Software version
S12500X-CMW710-R2712
S9800 Switch Series
S9800-CMW710-R2712
When you configure link layer attack protection, follow these restrictions and guidelines:
·     On a port, the loop guard feature is mutually exclusive with the root guard feature or the edge port setting.
·     Do not configure the loop guard feature on ports at the access side. Otherwise, the ports stay in Discarding state in all MSTIs because they cannot receive BPDUs.
·     By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Device B
# Specify IP addresses for interfaces. (Details not shown.)
# Configure root guard on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[DeviceB] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[DeviceB-if-range] stp root-protection
[DeviceB-if-range] quit
# Configure TC-BPDU guard.
[DeviceB] stp tc-protection
[DeviceB] stp tc-protection threshold 10
# Configure broadcast and multicast suppression on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[DeviceB-if-range] broadcast-suppression pps 6400
[DeviceB-if-range] multicast-suppression pps 6400
Configuring Device A
# Configure STP BPDU guard.
[DeviceA] stp bpdu-protection
# Configure Ten-GigabitEthernet 1/0/3 as an edge port.
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] stp edged-port
[DeviceA-Ten-GigabitEthernet1/0/3] quit
[DeviceA] stp tc-protection
[DeviceA] stp tc-protection threshold 10
# Set the maximum number of MAC addresses that Ten-GigabitEthernet 1/0/3 can learn.
[DeviceA-Ten-GigabitEthernet1/0/3] mac-address max-mac-count 1024
# Configure broadcast and multicast suppression on all ports.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] broadcast-suppression pps 6400
[DeviceA-if-range] multicast-suppression pps 6400
[DeviceA-if-range] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] stp bpdu-protection
[DeviceC] interface ten-gigabitethernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] stp edged-port
[DeviceC-Ten-GigabitEthernet1/0/3] quit
# Configure root guard on Ten-GigabitEthernet 1/0/1.
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] stp root-protection
[DeviceC-Ten-GigabitEthernet1/0/1] quit
# Configure loop guard on Ten-GigabitEthernet 1/0/2.
[DeviceC] interface ten-gigabitethernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] stp loop-protection
[DeviceC-Ten-GigabitEthernet1/0/2] quit
[DeviceC] stp tc-protection
[DeviceC] stp tc-protection threshold 10
[DeviceC-Ten-GigabitEthernet1/0/3] mac-address max-mac-count 1024
[DeviceC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceC-if-range] broadcast-suppression pps 6400
[DeviceC-if-range] multicast-suppression pps 6400
[DeviceC-if-range] quit
# Verify that the edge ports go down after they receives STP BPDUs. (Details not shown.)
# Bring the edge ports up by using the undo shutdown command. (Details not shown.)
# Verify that the root ports do not change and that the STP topology remains stable after STP BPDUs with higher priority are sent to the designated ports. (Details not shown.)
# Verify that the devices do not refresh the FIB table frequently and that no serious packet loss occurs after a large number of TC BPDUs are sent to the devices. (Details not shown.)
# Verify that the uplink ports are not flooded after a large number of broadcasts are sent to the edge ports on device A and Device C. (Details not shown.)
Configuration files
·     Device A:
stp bpdu-protection
interface Ten-GigabitEthernet 1/0/1
 port link-mode bridge
interface Ten-GigabitEthernet 1/0/2
interface Ten-GigabitEthernet 1/0/3
 stp edged-port
·     Device B:
 stp root-protection
 stp root-protection
·     Device C:
stp bpdu-protection
 stp root-protection
 stp loop-protection
 stp edged-port
Example: Configuring ARP attack protection
As shown in Figure 2, the device is the gateway for the internal network. Configure ARP attack protection on the device to prevent ARP attacks.
Figure 2 Network diagram
Table 3 shows the software versions used in this configuration example.
Table 3 Product and software version compatibility
Product
Software version
S9800 Switch Series
S9800-CMW710-R2712
Procedures
# Enable ARP source suppression.
[Device] arp source-suppression enable
# Configure the device to accept a maximum of 8 unresolvable packets per source IP address in 5 seconds.
[Device] arp source-suppression limit 8
# Enable ARP black hole routing to prevent unresolvable IP packet attacks.
[Device] arp resolving-route enable
# Enable ARP active acknowledgment to prevent user spoofing.
[Device] arp active-ack enable
# Configure source MAC-based ARP attack detection to prevent ARP packet attacks from the same source MAC.
[Device] arp source-mac filter
[Device] arp source-mac threshold 25
# Enable ARP packet source MAC address consistency check to prevent attacks from ARP packets with different source MAC addresses in the Ethernet header and in the message body.
[Device] arp valid-check enable
1.     Verify that ARP attack protection functions on the device:
# Send ARP attack packets to the device. (Details not shown.)
# Verify that the CPU usage does not surge. (Details not shown.)
2.     Verify that each ARP attack protection feature functions on the device (this example uses the ARP source suppression feature):
# Send the device 20 forged packets with the same source IP address and unresolvable destination IP addresses. (Details not shown.)
# Verify that the device stops resolving the packets after receiving 8 forged packets within 5 seconds. (Details not shown.)
# Verify the ARP source suppression configuration.
[Device] display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 8
 Current cache length: 16
Configuration files
Example: Configuring network layer attack protection
As shown in Figure 3, Device A is the gateway for the internal network. To protect Device A against IP packet attacks from internal and external networks, configure the following network layer attack protection features:
·     Configure strict uRPF check to prevent source address spoofing attacks.
·     Disabling sending ICMP time exceeded messages. The device will not be flooded by ICMP time exceeded messages when receiving a large number of packets with TTL set to 1.
Figure 3 Network diagram
Table 4 shows the software versions used in this configuration example.
Table 4 Product and software version compatibility
Product
Software version
S9800 Switch Series
S9800-CMW710-R2712
When you configure network layer attack protection, follow these restrictions and guidelines:
·     After you disable sending ICMP time exceeded messages, the tracert feature will not be available.
·     Enabling the uRPF check feature halves the route capacity of the switch.
·     The uRPF check feature cannot be enabled if the number of existing routes exceeds half of the route capacity on the switch. This mechanism prevents route loss, which can cause packet loss.
Procedures
# Enable strict uRPF check.
[DeviceA] ip urpf strict
# Disable sending ICMP time exceeded messages. Sending ICMP time exceeded messages is disabled by default.
[DeviceA] undo ip ttl-expires enable
1.     Verify that Device A can prevent source address spoofing attacks:
# Verify that Device A can filter out packets with forged source IP addresses. (Details not shown.)
# Verify the uRPF configuration.
[DeviceA] display ip urpf
Global uRPF configuration information:
   Check type: strict
   Allow default route
2.     Verify that TTL attack protection functions on Device A:
# Enable ICMP debugging by executing the debugging ip icmp command on Device A. (Details not shown.)
# Use a PC to send packets in which the TTL is 1 to Device A. (Details not shown.)
# Verify that Device A does not display any debugging information and that the PC does not receive any ICMP time exceeded messages. (Details not shown.)
# Enable sending ICMP time exceeded messages and send packets in which the TTL is 1 to Device A. (Details not shown.)
# Verify that Device A responds with ICMP time exceeded messages.
<DeviceA> *Aug 14 16:43:31:068 2016 NM-3 SOCKET/7/ICMP: Slot=2;
Time(s):1371221011  ICMP Output:
 ICMP Packet: src = 6.0.0.1, dst = 202.101.0.2
              type = 11, code = 0 (ttl-exceeded)
 Original IP: src = 202.101.0.2, dst = 192.168.0.2
              proto = 253, first 8 bytes = 00000000 00000000
Configuration files
ip urpf strict
Example: Configuring transport layer attack protection
As shown in Figure 4, the device is the gateway for the internal network. Configure SYN Cookie protection on the device to protect against SYN flood attacks. With this feature enabled, the device responds to a SYN packet with a SYN ACK packet without establishing a TCP semi-connection. The device establishes a TCP connection only when it receives an ACK packet from the sender.
Figure 4 Network diagram
Table 5 shows the software versions used in this configuration example.
Table 5 Product and software version compatibility
Product
Software version
S9800 Switch Series
S9800-CMW710-R2712
Procedures
# Enable SYN Cookie.
[Device] tcp syn-cookie enable
# Verify that the device does not have any TCP semi-connections. The state "SYN_RECEIVED" represents semi-connections.
[Device] display tcp
 *: TCP connection with authentication
 Local Addr:port       Foreign Addr:port     State       Slot  PCB
 0.0.0.0:21            0.0.0.0:0             LISTEN      1     0xffffffffffffff9
d
 0.0.0.0:23            0.0.0.0:0             LISTEN      1     0xffffffffffffff9
f
 192.168.2.88:23       192.168.2.79:2197     ESTABLISHED 1     0xffffffffffffffa
3
 192.168.2.88:23       192.168.2.89:2710     ESTABLISHED 1     0xffffffffffffffa
2
 192.168.2.88:23       192.168.2.110:50199   ESTABLISHED 1     0xffffffffffffffa
5
Configuration files
Related documentation
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 2LAN Switching Command Reference (Release 27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 2LAN Switching Configuration Guide (Release 27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3IP Services Command Reference (Release 27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3IP Services Configuration Guide (Release 27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Security Command Reference (Release 27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Security Configuration Guide (Release 27xx)
