H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration ExamplesH3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
50-IP Unnumbered Configuration Examples
50-IP Unnumbered Configuration Examples 84.12 KB
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides IP unnumbered configuration examples.
This feature enables an interface to borrow an IP address from another interface on the device when the borrowing interface does not have any IP addresses. The borrowing interface is called IP unnumbered interface.
This document assumes that you have basic knowledge of IP unnumbered.
When you configure IP unnumbered, follow these restrictions and guidelines:
·     Loopback interfaces cannot borrow IP addresses of other interfaces.
·     An interface cannot borrow an IP address from an unnumbered interface.
·     If an interface has multiple manually configured IP addresses, only the manually configured primary IP address can be borrowed.
Example: Configuring IP unnumbered
As shown in Figure 1, Group A and Group B are two private IPv4 networks. Device A and Device C will establish a GRE tunnel to interconnect Group 1 and Group 2.
To save IP address space, configure tunnel interface Tunnel 1 to borrow an IP address from the loopback interface loopback 0.
Figure 1 Network diagram
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product
Software version
S12500X-CMW710-R2712
S9800 Switch Series
S9800-CMW710-R2712
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Device A
1.     Assign IP addresses to the interfaces:
# Assign IP addresses to Ten-GigabitEthernet 1/0/1 and loopback 0.
[DeviceA-Ten-GigabitEthernet1/0/1] ip address 12.12.12.1 24
[DeviceA] interface loopback 0
[DeviceA-LoopBack0] ip address 8.8.8.8 32
[DeviceA-LoopBack0] quit
# Assign IP addresses to other interfaces in the same way an IP address is assigned to Ten-GigabitEthernet 1/0/1. (Details not shown.)
2.     Configure OSPF:
# Enable OSPF process 1.
[DeviceA] ospf 1
# Create Area 0 and specify Ten-GigabitEthernet 1/0/1 whose IP address is on network 12.12.12.0/24 to run OSPF in Area 0.
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
3.     Configure a GRE tunnel:
# Create service loopback group 1 and specify the unicast tunnel service for the group.
[DeviceA] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/3 to the service loopback group.
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet1/0/3] quit
# Create a tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Specify 12.12.12.1 as the source address of interface Tunnel 1.
[DeviceA-Tunnel1] source 12.12.12.1
# Specify 23.23.23.3 as the destination address of interface Tunnel 1.
[DeviceA-Tunnel1] destination 23.23.23.3
# Configure interface Tunnel 1 to borrow an IP address from loopback 0.
[DeviceA-Tunnel1] ip address unnumbered interface loopback 0
[DeviceA-Tunnel1] quit
# Configure a static route from Device A through the tunnel interface to Group B.
[DeviceA] ip route-static 10.2.1.0 255.255.255.0 tunnel 1
Configuring Device B
# Assign an IP address to Ten-GigabitEthernet 1/0/1.
[DeviceB-Ten-GigabitEthernet1/0/1] ip address 12.12.12.2 24
# Assign an IP address to Ten-GigabitEthernet 1/0/2 in the same way an IP address is assigned to Ten-GigabitEthernet 1/0/1. (Details not shown.)
2.     Configure OSPF:
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
# Create Area 0 and specify Ten-GigabitEthernet 1/0/2 whose IP address is on network 23.23.23.0/24 to run OSPF in Area 0.
[DeviceB-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] ip address 23.23.23.3 24
[DeviceC-Ten-GigabitEthernet1/0/1] quit
[DeviceC] interface loopback 0
[DeviceC-LoopBack0] ip address 9.9.9.9 32
[DeviceC-LoopBack0] quit
2.     Configure OSPF:
[DeviceC] ospf 1
# Create Area 0 and specify Ten-GigabitEthernet 1/0/1 whose IP address is on network 23.23.23.0/24 to run OSPF in Area 0.
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface ten-gigabitethernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-Ten-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 1 mode gre
# Specify 23.23.23.3 as the source address of interface Tunnel 1.
[DeviceC-Tunnel1] source 23.23.23.3
# Specify 12.12.12.1 as the destination address of interface Tunnel 1.
[DeviceC-Tunnel1] destination 12.12.12.1
[DeviceC-Tunnel1] ip address unnumbered interface loopback 0
[DeviceC-Tunnel1] quit
# Configure a static route from Device C through the tunnel interface to Group A.
[DeviceC] ip route-static 10.1.1.0 255.255.255.0 tunnel 1
This example uses Device A to verify the configuration.
# Verify that the interface Tunnel 1 has borrowed the IP address 8.8.8.8/32 from loopback 0.
[DeviceA] display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1476
Internet Address: 8.8.8.8/32 (Unnumbered)
Tunnel source 12.12.12.1, destination 23.23.23.3
Tunnel keepalive disabled
Tunnel TTL 255
Tunnel protocol/transport GRE/IP
    GRE key disabled
    Checksumming of GRE packets disabled
Input: 11 packets, 924 bytes, 0 drops
Output: 10 packets, 840 bytes, 0 drops
# Verify that Ten-GigabitEthernet 1/0/2 on Device A can ping the IP address of Ten-GigabitEthernet 1/0/2 on Device C.
# Verify that VLAN-interface 10 on Device A can ping the IP address of VLAN-interface 10 on Device C.
[DeviceA] ping -a 10.1.1.1 10.2.1.1
Ping 10.2.1.1 (10.2.1.1) from 10.1.1.1: 56 data bytes, press CTRL_C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=255 time=32.641 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=255 time=4.881 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=255 time=4.816 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=255 time=26.393 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=255 time=43.003 ms
--- Ping statistics for 10.2.1.1 ---
round-trip min/avg/max/std-dev = 4.816/22.347/43.003/15.241 ms
Configuration files
·     Device A:
ospf 1
 area 0.0.0.0
vlan 10
vlan 12
interface LoopBack0
 ip address 8.8.8.8 255.255.255.255
interface Vlan-interface10
interface Vlan-interface12
 ip address 12.12.12.1 255.255.255.0
 port link-mode route
 port link-mode bridge
interface Tunnel1 mode gre
 ip address unnumbered interface LoopBack0
 source 12.12.12.1
 ip route-static 10.2.1.0 24 Tunnel1
·     Device B:
ospf 1
 area 0.0.0.0
vlan 12
vlan 23
 ip address 12.12.12.2 255.255.255.0
interface Vlan-interface23
 ip address 23.23.23.3 255.255.255.0
 ip address 23.23.23.2 255.255.255.0
·     Device C:
ospf 1
 area 0.0.0.0
vlan 10
vlan 23
interface LoopBack0
 ip address 9.9.9.9 255.255.255.255
 ip address 10.2.1.1 255.255.255.0
 source 23.23.23.3
 ip route-static 10.1.1.0 24 Tunnel1
Related documentation
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3IP Services Command Reference (Release 27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3IP Services Configuration Guide (Release 27xx)
