H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration ExamplesH3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
Table of Contents
Related Documents
38-DLDP Configuration Examples
38-DLDP Configuration Examples 141.70 KB
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides DLDP configuration examples.
The Device Link Detection Protocol (DLDP) detects the status of fiber links or twisted-pair links. When DLDP detects unidirectional links, it can automatically shut down the faulty port to avoid network problems. Alternatively, a user can manually shut down the faulty port.
This document assumes that you have basic knowledge of DLDP.
Example: Configuring the auto port shutdown mode
As shown in Figure 1, Device A and Device B are connected through two fiber pairs.
Configure DLDP on the devices so each device performs the following tasks:
·     Detects unidirectional links caused by cross-connected fibers or a disconnected fiber.
·     Automatically shuts down the faulty interface when detecting a unidirectional link.
·     Automatically brings up the interface after the administrator clears the fault.
Figure 1 Network diagram
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product
Software version
S12500X-CMW710-R2712
S9800 Switch Series
S9800-CMW710-R2712
When you configure DLDP, follow these restrictions and guidelines:
·     For DLDP to operate correctly, configure the full duplex mode for the interfaces at the two ends of the link, and configure the same speed for the two interfaces.
·     For DLDP to operate correctly, enable DLDP on both sides and make sure the following settings are consistent:
¡     Interval to send Advertisement packets.
¡     DLDP authentication mode.
¡     Password.
·     By default, interfaces on the switch are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
1.     Configure Device A:
# Enable DLDP globally.
[DeviceA] dldp global enable
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to operate in full duplex mode at 10000 Mbps, and enable DLDP on the interfaces.
[DeviceA-Ten-GigabitEthernet1/0/1] duplex full
[DeviceA-Ten-GigabitEthernet1/0/1] speed 10000
[DeviceA-Ten-GigabitEthernet1/0/1] dldp enable
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] duplex full
[DeviceA-Ten-GigabitEthernet1/0/2] speed 10000
[DeviceA-Ten-GigabitEthernet1/0/2] dldp enable
[DeviceA-Ten-GigabitEthernet1/0/2] quit
# Set the interval for sending Advertisement packets to 5 seconds (default interval).
[DeviceA] dldp interval 5
# Configure the plain text authentication mode and set the password to abc.
[DeviceA] dldp authentication-mode simple
[DeviceA] dldp authentication-password simple abc
# Set the interface shutdown mode to auto (default mode).
[DeviceA] dldp unidirectional-shutdown auto
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display global and interface-specific DLDP configuration for Device A.
[DeviceA] display dldp
 DLDP global status: Enabled
 DLDP advertisement interval: 5s
 DLDP authentication-mode: Simple
 DLDP authentication-password: ******
 DLDP unidirectional-shutdown mode: Auto
 DLDP delaydown-timer value: 1s
 Number of enabled ports: 2
Interface Ten-GigabitEthernet1/0/1
 DLDP port state: Bidirectional
 Number of the port’s neighbors: 1
  Neighbor MAC address: 0023-8956-3600
  Neighbor port index: 1
  Neighbor state: Confirmed
  Neighbor aged time: 11s
Interface Ten-GigabitEthernet1/0/2
  Neighbor port index: 2
  Neighbor aged time: 12s
The output shows that the DLDP port status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 is Bidirectional.
# Enable the monitoring of logs on the current terminal for Device A, and set the lowest level of the logs that can be output to the monitor terminal to 6.
[DeviceA] quit
<DeviceA> terminal monitor
<DeviceA> terminal logging level 6
As shown in Figure 2, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 2 Cross-connected fibers
The following log information is displayed on Device A:
<DeviceA>%Jul 11 17:40:31:089 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 11 17:40:31:091 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 11 17:40:31:677 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jul 11 17:40:31:678 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jul 11 17:40:38:544 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 11 17:40:38:836 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to up.
The output shows that the physical status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 is down and then up. The link status of both interfaces is down.
# Display information about interface Ten-GigabitEthernet 1/0/1 on Device A.
[DeviceA]display interface ten-gigabitethernet 1/0/1
Current state: UP
Line protocol state: DOWN(DLDP)
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-5929
Description: Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 10000000kbps
Loopback is not set
Media type is optical fiber, Port hardware type is 10G_BASE_SR_SFP
10Gbps-speed mode, full-duplex mode
Link speed type is force link, link duplex type is force link
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
Mdi type: automdix
Port link-type: Access
 Tagged Vlan:   none
 UnTagged Vlan: 1
Port priority: 0
Last link flapping: 0 hours 11 minutes 9 seconds
 Peak input rate: 141 bytes/sec, at 2018-01-01 01:37:08
 Peak output rate: 84 bytes/sec, at 2018-01-01 05:39:56
 Last 300 second input:  0 packets/sec 99 bytes/sec 0%
 Last 300 second output:  0 packets/sec 63 bytes/sec 0%
 Input (total):  26470 packets, 2469445 bytes
          0 unicasts, 1 broadcasts, 26469 multicasts, 0 pauses
 Input (normal):  26470 packets, - bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 16962 packets, 1165236 bytes
          0 unicasts, 0 broadcasts, 16962 multicasts, 0 pauses
 Output (normal): 16962 packets, - bytes
          0 lost carrier, - no carrier
The output shows that the physical status of Ten-GigabitEthernet 1/0/1 is up, but DLDP automatically shuts down the interface. The output for interface Ten-GigabitEthernet 1/0/2 is similar to Ten-GigabitEthernet 1/0/1. (Details not shown.)
<DeviceA> display dldp
 DLDP port state: Unidirectional
 Number of the port’s neighbors: 0 (Maximum number ever detected: 1)
The output shows that the DLDP port status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces.
# Correct the fiber connections. As a result, the ports shut down by DLDP automatically recover, and Device A displays the following log information:
<DeviceA>%Jul 11 17:42:57:709 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 11 17:42:58:603 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jul 11 17:43:02:342 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 11 17:43:02:343 2018 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet1/0/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 1.
%Jul 11 17:43:02:344 2018 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet1/0/1.
%Jul 11 17:43:02:353 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 11 17:43:02:357 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to up.
%Jul 11 17:43:02:362 2018 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet1/0/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 2.
%Jul 11 17:43:02:362 2018 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet1/0/2.
%Jul 11 17:43:02:368 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to up.
The output shows that the physical status and link status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 are up and their DLDP neighbors are determined. The links become bidirectional.
Configuration files
·     Device A:
 dldp global enable
 dldp authentication-password cipher $c$3$wHDzwD/AZNW+q+otXapfZ/tUB/Wgbg==
 port link-mode bridge
 speed 10000
 duplex full
 dldp enable
 speed 10000
 duplex full
 dldp enable
·     The configuration file for Device B is the same as Device A. (Details not shown.)
Example: Configuring the manual port shutdown mode
As shown in Figure 3, Device A and Device B are connected through two fiber pairs.
Configure DLDP on the devices to meet the following requirements:
·     Each device can detect unidirectional links caused by cross-connected fibers or a disconnected fiber.
·     When a unidirectional link is detected, the administrator can manually shut down the faulty port based on the connection status of the link.
·     The interface recovers from failure after the administrator clears the fault and manually brings up the port.
Figure 3 Network diagram
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product
Software version
S9800 Switch Series
S9800-CMW710-R2712
¡     Password.
Procedures
# Set the interface shutdown mode to manual.
[DeviceA] dldp unidirectional-shutdown manual
 DLDP unidirectional-shutdown mode: Manual
[DeviceA] quit
As shown in Figure 4, the two pairs of fibers between Device A and Device B are cross-connected.
Figure 4 Cross-connected fibers
<DeviceA>%Jul 12 08:29:17:786 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 12 08:29:17:787 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 12 08:29:17:800 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jul 12 08:29:17:800 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jul 12 08:29:25:004 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 12 08:29:25:005 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 12 08:29:25:893 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to up.
%Jul 12 08:29:25:894 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to up.
The output shows that the physical status and link status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 are down and then up.
Current state: UP
Line protocol state: UP
Loopback is not set
PVID: 1
Mdi type: automdix
 Tagged Vlan:   none
 UnTagged Vlan: 1
Port priority: 0
 Peak output rate: 104 bytes/sec, at 2018-01-01 06:40:58
 Last 300 second input:  0 packets/sec 27 bytes/sec 0%
 Last 300 second output:  1 packets/sec 101 bytes/sec 0%
 Input (total):  27226 packets, 2547709 bytes
          0 unicasts, 1 broadcasts, 27225 multicasts, 0 pauses
 Input (normal):  27226 packets, - bytes
 Output (total): 17991 packets, 1260564 bytes
          0 unicasts, 0 broadcasts, 17991 multicasts, 0 pauses
 Output (normal): 17991 packets, - bytes
The output shows that the physical status and link status of Ten-GigabitEthernet 1/0/1 are up. DLDP does not shut down the interface. The output for interface Ten-GigabitEthernet 1/0/2 is similar to Ten-GigabitEthernet 1/0/1. (Details not shown.)
The output shows that the DLDP port status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 is Unidirectional. DLDP has detected a unidirectional link on both interfaces but does not shut them down.
# Shut down Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] shutdown
[DeviceA-Ten-GigabitEthernet1/0/1]%Jul 12 08:34:23:717 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 12 08:34:23:718 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul 12 08:34:23:778 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jul 12 08:34:23:779 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to down.
The output shows that the physical status and link status of Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 are down.
# Shut down Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] shutdown
# Correct the fiber connections, and bring up Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/2]%Jul 12 08:46:17:677 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to up.
%Jul 12 08:46:17:678 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to up.
%Jul 12 08:46:17:959 2018 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet1/0/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 2.
%Jul 12 08:46:17:959 2018 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet1/0/2.
The output shows that the physical status and link status of Ten-GigabitEthernet 1/0/2 are up and its DLDP neighbor is determined. The links become bidirectional.
# Bring up Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/1]%Jul 12 08:48:25:952 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 12 08:48:25:952 2018 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet1/0/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 1.
%Jul 12 08:48:25:953 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jul 12 08:48:25:953 2018 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet1/0/1.
The output shows that the physical status and link status of Ten-GigabitEthernet 1/0/1 are up and its DLDP neighbor is determined. The links become bidirectional.
Configuration files
·     Device A:
 dldp global enable
 speed 10000
 duplex full
 dldp enable
 speed 10000
 duplex full
 dldp enable
Example: Configuring the hybrid port shutdown mode
As shown in Figure 5, Device A and Device B are connected through two fiber pairs.
Configure DLDP to detect unidirectional links. When a unidirectional link is detected, DLDP automatically shuts down the unidirectional port. The administrator needs to bring up the port after clearing the fault.
Figure 5 Network diagram
Table 3 shows the software versions used in this configuration example.
Table 3 Product and software version compatibility
Product
Software version
S9800 Switch Series
S9800-CMW710-R2712
¡     Password.
Procedures
[DeviceA] dldp enable
# Configure Ten-GigabitEthernet 1/0/1 to operate in full duplex mode and at 10000 Mbps, and enable DLDP on the port.
# Configure Ten-GigabitEthernet 1/0/2 to operate in full duplex mode and at 10000 Mbps, and enable DLDP on the port.
# Set the interval for sending Advertisement packets to 5 seconds, configure the DLDP authentication mode as simple, and configure the password for DLDP authentication as abc.
# Set the port shutdown mode to hybrid.
[DeviceA] dldp unidirectional-shutdown hybrid
# Display global and interface-specific DLDP configuration on Device A.
 DLDP unidirectional-shutdown mode: Hybrid
The output shows that both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 are in bidirectional state, which means both links are bidirectional.
# Enable the monitoring of logs on the current terminal on Device A. Set the lowest level of the logs that can be output to the current terminal to 6.
[DeviceA] quit
As shown in Figure 6, the two pairs of fibers between Device A and Device B are cross-connected..
Figure 6 Cross-connected fibers
<DeviceA>%Jan  4 07:16:06:556 2018 DeviceA DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface
Ten-GigabitEthernet1/0/1 was deleted because the neighbor was aged. The neighbor's system MAC is 0023-8956-3600, and the port index is 162.
%Jan  4 07:16:06:560 2018 DeviceA DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface
Ten-GigabitEthernet1/0/2 was deleted because the neighbor was aged. The neighbor's system MAC is 0023-8956-3600, and the port index is 165.
%Jan  4 07:16:06:724 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jan  4 07:16:06:730 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jan  4 07:16:06:736 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jan  4 07:16:06:738 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to down.
%Jan  4 07:16:07:152 2018 DeviceA DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ten-GigabitEthernet1/0/1. DLDP automatically shut down the interface. Please manually bring up the interface.
%Jan  4 07:16:07:156 2018 DeviceA DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ten-GigabitEthernet1/0/2. DLDP automatically shut down the interface. Please manually bring up the interface.
The output shows that the port status and link status of both Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 are down.
Current state: DOWN
Loopback is not set
PVID: 1
Mdi type: automdix
 Tagged Vlan:   none
 UnTagged Vlan: 1
Port priority: 0
The output shows that the physical status and link status of Ten-GigabitEthernet 1/0/1 are down. The output for interface Ten-GigabitEthernet 1/0/2 is similar to Ten-GigabitEthernet 1/0/1. (Details not shown.)
# Correct the fiber connections, and bring up Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1]%Jan  4 07:33:26:574 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jan  4 07:33:57:562 2018 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet1/0/1. The neighbor's system MAC is 0023-8956-3600, and the port index is 162.
%Jan  4 07:33:57:563 2018 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet1/0/1.
%Jan  4 07:33:57:590 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to up.
%Jan  4 07:33:57:609 2018 DeviceA STP/6/STP_DETECTED_TC: Instance 0's port Ten-GigabitEthernet1/0/1 detected a topology change.
The output shows that the port status and link status of Ten-GigabitEthernet 1/0/1 are now up and its DLDP neighbors are determined. The links become bidirectional.
# Bring up Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2]%Jan  4 07:35:26:574 2018 DeviceA IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/2 changed to up.
%Jan  4 07:35:57:562 2018 DeviceA DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ten-GigabitEthernet1/0/2. The neighbor's system MAC is 0023-8956-3600, and the port index is 162.
%Jan  4 07:35:57:563 2018 DeviceA DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ten-GigabitEthernet1/0/2.
%Jan  4 07:35:57:590 2018 DeviceA IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/2 changed to up.
%Jan  4 07:35:57:609 2018 DeviceA STP/6/STP_DETECTED_TC: Instance 0's port Ten-GigabitEthernet1/0/2 detected a topology change.
The output shows that the port status and link status of Ten-GigabitEthernet 1/0/2 are now up and its DLDP neighbors are determined. The links become bidirectional.
Configuration files
·     Device A:
 dldp global enable
 speed 10000
 duplex full
 dldp enable
 speed 10000
 duplex full
 dldp enable
Related documentation
·     H3C S12500X-AF & S12500-X & S9800 Switch Series High Availability Command Reference (R27xx)
·     H3C S12500X-AF & S12500-X & S9800 Switch Series High Availability Configuration Guide (R27xx)
