- 03-Layer 2 Configuration Guide
- 01-Ethernet Interface Configuration
- 02-Loopback and Null Interface Configuration
- 03-MAC Address Table Configuration
- 04-Spanning Tree Configuration
- 05-Loopback Detection Configuration
- 06-VLAN Configuration
- 07-Layer 2 Forwarding Configuration
- 08-PPP Configuration
- 09-Ethernet Link Aggregation Configuration
- 10-DCC Configuration
10-DCC Configuration | 76.36 KB |
Configuring dial authentication for RS-DCC
Configuring DCC timers and buffer queue length
Displaying and maintaining DCC
Overview
Dial Control Center (DCC) is a routing technology used when devices interconnect through a public switched network, such as a PSTN or an ISDN. It can provide the dial-on-demand service where any two devices dial to set up a connection when data needs transferring instead of setting up a connection before that. When the link becomes idle, DCC automatically disconnects it.
DCC configuration task list
Task |
Remarks |
Required. |
Optional. |
Configuring RS-DCC
In the RS-DCC approach, physical interface configuration is separated from logical configuration for calls and they can be combined dynamically for each call.
When you configure RS-DCC for on-demand dial, configure RS-DCC sets. Each RS-DCC set is an attribute collection containing a dialer interface, dialer interface attributes, and a dialer bundle.
· For each dialer interface, you can define only one dial string. As this dial string has its own dial attribute set, all calls placed using this dial string use the same DCC attribute parameters (such as dial rate).
· Each dialer interface can use only one dialer bundle. Each dialer bundle may contain multiple physical interfaces with different priorities, but each of these interfaces can belong to multiple dialer bundles.
Complete these tasks to configure RS-DCC for on-demand calling:
Task |
Remarks |
Required. |
Required. |
Enabling RS-DCC
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Set the condition for a DCC call to be placed for a dialer access group either by directly configuring a rule or by referencing an ACL. |
dialer-rule group-number { protocol-name { deny | permit } | acl { acl-number | name acl-name } } |
By default, no condition is set for a DCC call to be placed for a dialer access group. |
1. Create a dialer interface and enter dialer interface view. |
interface dialer number |
By default, no dialer interface is created. |
2. Set the remote username. |
dialer user username |
By default, no remote username is set. |
3. Enable RS-DCC by creating a dialer bundle for the dialer interface. |
dialer bundle number |
By default, a dialer interface is not associated with any dialer bundle in RS-DCC. |
4. Assign the interface to a dialer access group. |
dialer-group group-number |
By default, an interface is not assigned to any dialer access group. |
In RS-DCC, associations between physical interfaces and dialer interfaces are rather flexible. To allow a called party to identify calling parties, configure authentication, either PAP or CHAP.
When you configure dial authentication for RS-DCC, follow these guidelines:
· H3C recommends configuring either PAP or CHAP authentication on both physical and dialer interfaces at both sending and receiving ends.
· When PPP encapsulation is enabled on a dialer interface, configure a remote username with the dialer user command for the dialer interface. When DCC decides which dialer interface is used for receiving a call, it compares the remote username gained through PPP negotiation against those assigned to dialer interfaces for a match.
To configure dial authentication for RS-DCC:
Step |
Command |
system-view |
2. Enter dialer interface view. |
3. Configure the remote username. |
4. Configure PPP encapsulation and PPP authentication (PAP or CHAP). |
See "Configuring PPP." |
C-DCC and RS-DCC are available with some optional parameters. Configure them appropriately to improve on-demand dial efficiency.
You can configure the following parameters on a dialup interface:
· Link idle-timeout timer—A link idle-timeout timer starts upon setup of a link. When the timer expires, DCC disconnects the link.
· Holddown timer—A holddown timer starts upon disconnection of a link. The call attempt to bring up this link can be made only after the timer expires, preventing a remote PBX from being overloaded.
· Wait-carrier timer—Sometimes, the time DCC waits for a connection to be established may vary call by call. To handle this situation, use a wait-carrier timer. A wait-carrier timer starts when a call is placed. If the connection is not established upon expiration of the timer, DCC terminates the call.
· Buffer queue length—If no connection is available when a dialup interface without a buffer queue receives a packet, it will drop the packet. Configured with a buffer queue, the dialup interface will buffer the packet until a connection is available for packet sending.
Configuration procedure
To configure DCC timers and buffer queue length on a dialup interface:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter dialup interface (physical or dialer interface) view. |
N/A |
3. Set the link idle-timeout timer. |
dialer timer idle seconds |
Optional. The default setting is 120 seconds. |
4. Set the holddown timer. |
dialer timer enable seconds |
Optional. The default setting is 5 seconds. |
5. Set the wait-carrier timer. |
dialer timer wait-carrier seconds |
Optional. The default setting is 60 seconds. |
6. Set the buffer queue length. |
dialer queue-length packets |
Optional. By default, packets are not buffered. |
7. Set the intended bandwidth. |
bandwidth bandwidth-value |
Optional. |
Task |
Command |
Remarks |
Display information about a specified or all dialup interfaces. |
display dialer [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Display information about a dialer interface. |
display interface dialer number [ brief ] [ | { begin | exclude | include } regular-expression ] display interface [ dialer ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] |
Tear down a dialup link. |
dialer disconnect [ interface interface-type interface-number ] |
Clear the statistics on a dialer interface. |
reset counters interface [ dialer [ number ] ] |
Available in user view. |
Troubleshooting
Symptom 1
DCC dialup connection cannot be set up because the modem does not dial when the device forwards data.
Solution
Check that:
· The modem and phone cable connections are correct, and the modem initialization process is correct.
· DCC is enabled on the dialup interface.
· A dialer number command is available for the packets.
Symptom 2
The remote end cannot be pinged after the modem is connected.
Solution
Check that:
· The same link layer encapsulation is used at the two ends, and correct PPP parameters are configured for authentication. Use the debugging ppp all command to verify that.
· A correct IP address is assigned to the dialup interface (physical or dialer interface).
· The correct dialer-group and dialer-rule commands are configured and associated to make sure that the packets can pass.
· Use the debugging dialer event and debugging dialer packet commands to locate the problem.
