- 06-Layer 3 - IP Routing Configuration Guide
- 01-IP routing basics
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 IS-IS configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
04-OSPF configuration | 724.28 KB |
Configuring OSPF network types
Configuring the broadcast network type for an interface
Configuring the NBMA network type for an interface
Configuring the P2MP network type for an interface
Configuring the P2P network type for an interface
Configuring OSPF route control
Configuring OSPF route summarization
Configuring inbound OSPF route filtering
Configuring Type-3 LSA filtering
Configuring an OSPF cost for an interface
Specifying the maximum number of OSPF routes
Configuring the maximum number of ECMP routes
Configuring OSPF route redistribution
Tuning and optimizing OSPF networks
Specifying LSA transmission delay
Specifying SPF calculation interval
Specifying the LSA arrival interval
Specifying the LSA generation interval
Disabling interfaces from sending and receiving OSPF packets
Configuring OSPF authentication
Adding the interface MTU into DD packets
Configuring the maximum number of external LSAs in LSDB
Configuring OSPF exit overflow interval
Enabling compatibility with RFC 1583
Logging neighbor state changes
Configuring OSPF network management
Configuring the LSU transmit rate
Configuring OSPF Graceful Restart
Configuring the OSPF GR Restarter
Triggering OSPF Graceful Restart
Configuring bidirectional control detection
Configuring single-hop echo detection
Configuring OSPF FRR to calculate a backup next hop using the LFA algorithm
Configuring OSPF FRR to specify a backup next hop using a routing policy
Displaying and maintaining OSPF
Configuring OSPF to advertise a summary route
Configuring OSPF virtual links
Troubleshooting OSPF configuration
No OSPF neighbor relationship established
Open Shortest Path First (OSPF) is a link-state IGP developed by the OSPF working group of the IETF. OSPF version 2 is used for IPv4. OSPF refers to OSPFv2 throughout this chapter.
Overview
OSPF offers the following features:
· Wide scope—Supports various network sizes and up to several hundred routers in an OSPF routing domain.
· Fast convergence—Advertises routing updates instantly upon network topology changes.
· Loop free—Computes routes with the SPF algorithm to avoid routing loops.
· Area-based network partition—Splits an AS into multiple areas to facilitate management. This feature reduces the LSDB size on routers to save memory and CPU resources, and reduces route updates transmitted between areas to save bandwidth.
· ECMP routing—Supports multiple equal-cost routes to a destination.
· Routing hierarchy—Supports a 4-level routing hierarchy that prioritizes routes into intra-area, inter-area, external Type-1, and external Type-2 routes.
· Authentication—Supports area- and interface-based packet authentication to ensure secure packet exchange.
· Support for multicasting—Multicasts protocol packets on some types of links to avoid impacting other devices.
OSPF packets
OSPF messages are carried directly over IP. The protocol number is 89.
OSPF uses the following packet types:
· Hello—Periodically sent to find and maintain neighbors, containing timer values, information about the DR, BDR, and known neighbors.
· Database description (DD)—Describes the digest of each LSA in the LSDB, exchanged between two routers for data synchronization.
· Link state request (LSR)—Requests needed LSAs from a neighbor. After exchanging the DD packets, the two routers know which LSAs of the neighbor are missing from their LSDBs. They then exchange LSR packets requesting the missing LSAs. The LSA packet contains the digest of the missing LSAs.
· Link state update (LSU)—Transmits the requested LSAs to the neighbor.
· Link state acknowledgment (LSAck)—Acknowledges received LSU packets. It contains the headers of received LSAs (an LSAck packet can acknowledge multiple LSAs).
LSA types
OSPF advertises routing information in Link State Advertisements (LSAs). The following LSAs are commonly used:
· Router LSA—Type-1 LSA, originated by all routers and flooded throughout a single area only. This LSA describes the collected states of the router's interfaces to an area.
· Network LSA—Type-2 LSA, originated for broadcast and NBMA networks by the designated router, and flooded throughout a single area only. This LSA contains the list of routers connected to the network.
· Network Summary LSA—Type-3 LSA, originated by Area Border Routers (ABRs), and flooded throughout the LSA's associated area. Each summary-LSA describes a route to a destination outside the area, yet still inside the AS (an inter-area route).
· ASBR Summary LSA—Type-4 LSA, originated by ABRs and flooded throughout the LSA's associated area. Type 4 summary-LSAs describe routes to Autonomous System Boundary Router (ASBR).
· AS External LSA—Type-5 LSA, originated by ASBRs, and flooded throughout the AS (except stub and NSSA areas). Each AS-external-LSA describes a route to another AS.
· NSSA LSA—Type-7 LSA, as defined in RFC 1587, originated by ASBRs in NSSAs and flooded throughout a single NSSA. NSSA LSAs describe routes to other ASs.
· Opaque LSA—A proposed type of LSA. Its format consists of a standard LSA header and application specific information. Opaque LSAs are used by the OSPF protocol or by some applications to distribute information into the OSPF routing domain. The opaque LSA includes Type 9, Type 10, and Type 11. The Type 9 opaque LSA is flooded into the local subnet, the Type 10 is flooded into the local area, and the Type 11 is flooded throughout the AS.
OSPF areas
In large OSPF routing domains, SPF route computations consume too many storage and CPU resources, and enormous OSPF packets generated for route synchronization occupy excessive bandwidth.
To resolve these issues, OSPF splits an AS into multiple areas. Each area is identified by an area ID. The boundaries between areas are routers rather than links. A network segment (or a link) can only reside in one area as shown in Figure 1.
You can configure route summarization on ABRs to reduce the number of LSAs advertised to other areas and minimize the effect of topology changes.
Figure 1 Area-based OSPF network partition
Backbone area and virtual links
Each AS has a backbone area that distributes routing information between non-backbone areas. Routing information between non-backbone areas must be forwarded by the backbone area. OSPF includes the following requirements:
· All non-backbone areas must maintain connectivity to the backbone area.
· The backbone area must maintain connectivity within itself.
In practice, these requirements might not be satisfied due to lack of physical links. OSPF virtual links can resolve this issue.
A virtual link is established between two ABRs through a non-backbone area. It must be configured on both ABRs to take effect. The non-backbone area is called a transit area.
In Figure 2, Area 2 has no direct physical link to the backbone area 0. You can configure a virtual link between the two ABRs to connect Area 2 to the backbone area.
Figure 2 Virtual link application 1
Virtual links can also be used to provide redundant links. If the backbone area cannot maintain internal connectivity due to the failure of a physical link, you can configure a virtual link to replace the failed physical link, as shown in Figure 3.
Figure 3 Virtual link application 2
The virtual link between the two ABRs acts as a point-to-point connection. You can configure interface parameters, such as hello interval, on the virtual link as they are configured on a physical interface.
The two ABRs on the virtual link unicast OSPF packets to each other, and the OSPF routers in between convey these OSPF packets as normal IP packets.
Stub area and totally stub area
A stub area does not distribute Type-5 LSAs to reduce the routing table size and LSAs advertised within the area. The ABR of the stub area advertises a default route in a Type-3 LSA so that the routers in the area can reach external networks through the default route.
To further reduce the routing table size and advertised LSAs, you can configure the stub area as a totally stub area. The ABR of a totally stub area does no advertise inter-area routes or external routes. It advertises a default route in a Type-3 LSA so that the routers in the area can reach external networks through the default route.
NSSA area and totally NSSA area
An NSSA area does not import AS external LSAs (Type-5 LSAs) but can import Type-7 LSAs generated by the NSSA ASBR. The NSSA ABR translates Type-7 LSAs into Type-5 LSAs and advertises the Type-5 LSAs to other areas.
In Figure 4, the OSPF AS contains Area 1, Area 2, and Area 0. The other two ASs run RIP. Area 1 is an NSSA area where the ASBR redistributes RIP routes in Type-7 LSAs into Area 1. Upon receiving the Type-7 LSAs, the NSSA ABR translates them to Type-5 LSAs, and advertises the Type-5 LSAs to Area 0.
The ASBR of Area 2 redistributes RIP routes in Type-5 LSAs into the OSPF routing domain. However, Area 1 does not receive Type-5 LSAs because it is an NSSA area.
Router types
OSPF routers are classified into the following types based on their positions in the AS:
· Internal router—All interfaces on an internal router belong to one OSPF area.
· ABR—Belongs to more than two areas, one of which must be the backbone area. ABR connects the backbone area to a non-backbone area. An ABR and the backbone area can be connected through a physical or logical link.
· Backbone router—At least one interface of a backbone router must reside in the backbone area. All ABRs and internal routers in area 0 are backbone routers.
· ASBR—Exchanges routing information with another AS is an ASBR. An ASBR might not reside on the border of the AS. It can be an internal router or an ABR.
Figure 5 OSPF router types
Route types
OSPF prioritizes routes into the following route levels:
· Intra-area route
· Inter-area route
· Type-1 external route
· Type-2 external route
The intra-area and inter-area routes describe the network topology of the AS. The external routes describe routes to external ASs.
A Type-1 external route has high credibility. The cost from a router to the destination of a Type-1 external route = the cost from the router to the corresponding ASBR + the cost from the ASBR to the destination of the external route.
A Type-2 external route has low credibility. OSPF considers the cost from the ASBR to the destination of a Type-2 external route is much greater than the cost from the ASBR to an OSPF internal router. The cost from the internal router to the destination of the Type-2 external route = the cost from the ASBR to the destination of the Type-2 external route. If two Type-2 routes to the same destination have the same cost, OSPF takes the cost from the router to the ASBR into consideration to determine the best route.
Route calculation
OSPF computes routes in an area as follows:
· Each router generates LSAs based on the network topology around itself, and sends them to other routers in update packets.
· Each OSPF router collects LSAs from other routers to compose an LSDB. An LSA describes the network topology around a router, and the LSDB describes the entire network topology of the area.
· Each router transforms the LSDB to a weighted directed graph that shows the topology of the area. All the routers within the area have the same graph.
· Each router uses the SPF algorithm to compute a shortest path tree that shows the routes to the nodes in the area. The router itself is the root of the tree.
OSPF network types
OSPF classifies networks into the following types, depending on different link layer protocols:
· Broadcast—If the link layer protocol is Ethernet or FDDI, OSPF considers the network type as broadcast by default. On a broadcast network, hello, LSU, and LSAck packets are multicast to 224.0.0.5 that identifies all OSPF routers or to 224.0.0.6 that identifies the DR; DD packets and LSR packets are unicast.
· NBMA—OSPF packets are unicast on a NBMA network.
· P2MP—No link is P2MP type by default. P2MP must be a conversion from other network types such as NBMA. On a P2MP network, OSPF packets are multicast to 224.0.0.5.
· P2P—If the link layer protocol is PPP or HDLC, OSPF considers the network type as P2P. On a P2P network, OSPF packets are multicast to 224.0.0.5.
The following are the differences between NBMA and P2MP networks:
· NBMA networks are fully meshed. P2MP networks are not required to be fully meshed.
· NBMA networks require DR and BDR election. P2MP networks do not have DR or BDR.
· On a NBMA network, OSPF packets are unicast, and neighbors are manually configured. On a P2MP network, OSPF packets are multicast by default, and you can configure OSPF to unicast protocol packets.
DR and BDR
On a broadcast or NBMA network, any two routers must establish an adjacency to exchange routing information with each other. If n routers are present on the network, n(n-1)/2 adjacencies are established. Any topology change on the network results in an increase in traffic for route synchronization, consuming many system and bandwidth resources.
The DR and BDR mechanisms can solve this problem.
· DR—Elected to advertise routing information among other routers. If the DR fails, routers on the network must elect another DR and synchronize information with the new DR. Using this mechanism alone is time-consuming and prone to route calculation errors.
· BDR—Elected along with the DR to establish adjacencies with all other routers. If the DR fails, the BDR immediately becomes the new DR, and other routers elect a new BDR.
Routers other than the DR and BDR are called "DROthers." They do not establish adjacencies with one another, so the number of adjacencies is reduced.
The role of a router is subnet (or interface) specific. It might be a DR on one interface and a BDR or DROther on another interface.
In Figure 6, solid lines are Ethernet physical links, and dashed lines represent OSPF adjacencies. With the DR and BDR, only seven adjacencies are established.
Figure 6 DR and BDR in a network
NOTE: In OSPF, "neighbor" and "adjacency" are different concepts. After startup, OSPF sends a hello packet on each OSPF interface. A receiving router checks parameters in the packet. If the parameters match its own, the receiving router considers the sending router an OSPF neighbor. Two OSPF neighbors establish an adjacency relationship after they synchronize their LSDBs through exchange of DD packets and LSAs. |
DR and BDR election
DR election is performed on broadcast or NBMA networks but not on P2P and P2MP networks.
Routers in a broadcast or NBMA network elect the DR and BDR by router priority and ID. Routers with a router priority value higher than 0 are candidates for DR and BDR election.
The election votes are hello packets. Each router sends the DR elected by itself in a hello packet to all the other routers. If two routers on the network declare themselves as the DR, the router with the higher router priority wins. If router priorities are the same, the router with the higher router ID wins.
If a router with a higher router priority is added to the network after DR and BDR election, the router cannot become the DR or BDR immediately as no DR election is performed for it. Therefore, the DR of a network might not be the router with the highest priority, and the BDR might not be the router with the second highest priority.
Protocols and standards
· RFC 1765, OSPF Database Overflow
· RFC 2328, OSPF Version 2
· RFC 3101, OSPF Not-So-Stubby Area (NSSA) Option
· RFC 3137, OSPF Stub Router Advertisement
· RFC 4811, OSPF Out-of-Band LSDB Resynchronization
· RFC 4812, OSPF Restart Signaling
· RFC 4813, OSPF Link-Local Signaling
OSPF configuration task list
To run OSPF, you must first enable OSPF on the router. Make a proper configuration plan to avoid incorrect settings that can result in route blocking and routing loops.
To configure OSPF, perform the following tasks:
Enabling OSPF
Enable OSPF before you perform other OSPF configuration tasks.
Configuration prerequisites
Configure the link layer protocol and IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
Configuration guidelines
Complete the following tasks to enable an interface to run an OSPF process in an area:
· Enable the OSPF process.
· Create the area for the OSPF process.
· Add the network segment where the interface resides to the area. The OSPF process advertises the direct route of the interface.
· Specify a router ID, the unique identifier of the router in the AS.
You can also specify a router ID when you create an OSPF process.
· If you specify a router ID when you create an OSPF process, any two routers in an AS must have different router IDs. A common practice is to specify the IP address of an interface as the router ID.
· If you specify no router ID when you create the OSPF process, the global router ID is used. H3C recommends specifying a router ID when you create the OSPF process.
OSPF can run multiple processes and supports VPNs:
· To run multiple OSPF processes, you must specify an ID for each process. The process IDs take effect locally and has no influence on packet exchange between routers. Two routers with different process IDs can exchange packets.
· VPN support enables an OSPF process to run in a specified VPN. For more information about VPN, see MPLS Configuration Guide.
Configuration procedure
To enable OSPF:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable an OSPF process and enter OSPF view. |
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] * |
By default, no OSPF process is enabled. |
3. (Optional.) Configure a description for the OSPF process. |
description description |
By default, no description is configured for the OSPF process. H3C recommends configuring a description for each OSPF process. |
4. Create an OSPF area and enter OSPF area view. |
area area-id |
By default, no OSPF area is created. |
5. (Optional.) Configure a description for the area. |
By default, no description is configured for the area. H3C recommends configuring a description for each OSPF area. |
6. Specify a network to enable the interface attached to the network to run the OSPF process in the area. |
network ip-address wildcard-mask |
By default, no network is specified. A network can be added to only one area. |
Configuring OSPF areas
Before you configure an OSPF area, complete the following tasks:
· Configure IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
· Enable OSPF.
Configuring a stub area
You can configure a non-backbone area at an AS edge as a stub area. To do so, issue the stub command on all routers attached to the area. The routing table size is reduced because Type-5 LSAs will not be flooded within the stub area. The ABR generates a default route into the stub area so all packets destined outside of the AS are sent through the default route.
To further reduce the routing table size and routing information exchanged in the stub area, configure a totally stub area by using the stub [ no-summary ] command on the ABR. AS external routes and inter-area routes will not be distributed into the area. All the packets destined outside of the AS or area will be sent to the ABR for forwarding.
A stub or totally stub area cannot have an ASBR because external routes cannot be distributed into the area.
To configure an OSPF stub area:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter OSPF view. |
N/A |
3. Enter area view. |
area area-id |
N/A |
4. Configure the area as a stub area. |
stub [ default-route-advertise | no-summary ] * |
By default, no stub area is configured. |
5. (Optional.) Specify a cost for the default route advertised to the stub area. |
default-cost cost |
The default setting is 1. The default-cost cost command takes effect only on the ABR of a stub area or totally stub area. |
Configuring an NSSA area
A stub area cannot import external routes, but an NSSA area can import external routes into the OSPF routing domain while retaining other stub area characteristics.
Do not configure the backbone area as an NSSA area or totally NSSA area.
To configure an NSSA area, configure the nssa command on all the routers attached to the area.
To configure a totally NSSA area, configure the nssa command on all the routers attached to the area and configure the nssa no-summary command on the ABR. The ABR of a totally NSSA area does not advertise inter-area routes into the area.
To configure an NSSA area:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure the area as an NSSA area. |
nssa [ default-route-advertise | no-import-route | no-summary | translate-always | translator-stability-interval value ] * |
By default, no area is configured as an NSSA area. |
5. (Optional.) Specify a cost for the default route advertised to the NSSA area. |
default-cost cost |
The default setting is 1. This command takes effect only on the ABR/ASBR of an NSSA or totally NSSA area. |
Configuring a virtual link
Virtual links are configured for connecting backbone area routers that have no direct physical links.
To configure a virtual link:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure a virtual link. |
vlink-peer router-id [ dead seconds | hello seconds | { hmac-md5 | md5 } key-id { cipher cipher-string | plain plain-string } | retransmit seconds | simple { cipher cipher-string | plain plain-string } | trans-delay seconds ] * |
By default, no virtual link is configured. Configure this command on both ends of a virtual link, and the hello and dead intervals must be identical on both ends of the virtual link. The authentication mode (MD5 or simple) of the virtual link is determined by the authentication mode configured for the backbone area. |
OSPF classifies networks into the following types based on the link layer protocol:
· Broadcast—When the link layer protocol is Ethernet, OSPF classifies the network type as broadcast by default.
· NBMA—When the link layer protocol is Frame Relay, OSPF classifies the network type as NBMA by default.
· P2P—When the link layer protocol is PPP or HDLC, OSPF classifies the network type as P2P by default.
When you change the network type of an interface, follow these guidelines:
· When an NBMA network becomes fully meshed, change the network type to broadcast to avoid manual configuration of neighbors.
· If any routers in a broadcast network do not support multicasting, change the network type to NBMA.
· An NBMA network must be fully meshed. OSPF requires that an NBMA network be fully meshed. If a network is partially meshed, change the network type to P2MP.
· If a router on an NBMA network has only one neighbor, you can change the network type to P2P to save costs.
Two broadcast-, NBMA-, and P2MP-interfaces can establish a neighbor relationship only when they are on the same network segment.
Before you configure OSPF network types, complete the following tasks:
· Enable OSPF.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure the OSPF network type for the interface as broadcast. |
ospf network-type broadcast |
By default, the network type of an interface depends on the link layer protocol. |
4. (Optional.) Configure a router priority for the interface. |
ospf dr-priority priority |
The default router priority is 1. |
After you configure the network type as NBMA, you must specify neighbors and their router priorities because NBMA interfaces cannot find neighbors by broadcasting hello packets.
To configure the NBMA network type for an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the OSPF network type for the interface as NBMA. |
ospf network-type nbma |
The default setting is 1. The router priority configured with this command is for DR election. |
5. Return to system view. |
quit |
N/A |
6. Enter OSPF view. |
N/A |
7. Specify a neighbor and its router priority. |
peer ip-address [ cost value | dr-priority dr-priority ] |
By default, no neighbor is specified. The priority configured with this command indicates whether a neighbor has the election right or not. If you configure the router priority for a neighbor as 0, the local router determines the neighbor has no election right, and does not send hello packets to this neighbor. However, if the local router is the DR or BDR, it still sends hello packets to the neighbor for neighbor relationship establishment. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the OSPF network type for the interface as P2MP. |
ospf network-type p2mp [ unicast ] |
By default, the network type of an interface depends on the link layer protocol. After you configure the OSPF network type for an interface as P2MP unicast, all packets are unicast over the interface. The interface cannot broadcast hello packets to discover neighbors, so you must manually specify the neighbors. |
4. Exit to system view. |
quit |
N/A |
5. Enter OSPF view. |
N/A |
6. (Optional.) Specify a neighbor and its router priority. |
By default, no neighbor is specified. This step must be performed if the network type is P2MP unicast, and is optional if the network type is P2MP. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the OSPF network type for the interface as P2P. |
ospf network-type p2p |
This section describes how to control the advertisement and reception of OSPF routing information, as well as route redistribution from other protocols.
Before you configure OSPF route control, complete the following tasks:
· Enable OSPF.
· Configure filters if routing information filtering is needed.
Configure route summarization on an ABR or ASBR to summarize contiguous networks into a single network and distribute it to other areas.
Route summarization reduces the routing information exchanged between areas and the size of routing tables, and improves routing performance. For example, three internal networks 19.1.1.0/24, 19.1.2.0/24, and 19.1.3.0/24 are available within an area. You can summarize the three networks into network 19.1.0.0/16, and advertise the summary network to other areas.
Configuring route summarization on an ABR
After you configure a summary route on an ABR, the ABR generates a summary LSA instead of more specific LSAs so that the scale of LSDBs on routers in other areas and the influence of topology changes are reduced.
To configure route summarization on an ABR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enter OSPF area view. |
area area-id |
N/A |
4. Configure ABR route summarization. |
abr-summary ip-address { mask | mask-length } [ advertise | not-advertise ] [ cost cost ] |
By default, no route summarization is configured. The command takes effect only on an ABR. |
Configuring route summarization when redistributing routes into OSPF on an ASBR
Without route summarization, an ASBR advertises each redistributed route in a separate ASE LSA. After you configure a summary route, the ASBR advertises only the summary route in an ASE LSA instead of more specific routes, reducing the number of LSAs in the LSDB.
The ASBR summarizes redistributed Type-5 LSAs that fall into the specified address range. If the ASBR is in an NSSA area, it also summarizes Type-7 LSAs that fall into the specified address range. If the ASBR is also the ABR, it summarizes Type-5 LSAs translated from Type-7 LSAs.
To configure route summarization when redistributing routes into OSPF on an ASBR:
Step |
Command |
Remarks |
system-view |
N/A |
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ]* |
N/A |
asbr-summary ip-address { mask | mask-length } [ tag tag | not-advertise | cost cost ] * |
By default, no ASBR route summarization is configured. The command takes effect only on an ASBR. |
Perform this task to filter routes calculated using received LSAs.
The following filtering methods are available:
· Use an ACL or IP prefix list to filter routing information by destination address.
· Use the gateway keyword to filter routing information by next hop.
· Use an ACL or IP prefix list to filter routing information by destination address and at the same time use the gateway keyword to filter routing information by next hop.
· Use a routing policy to filter routing information.
To configure OSPF to filter routes calculated using received LSAs:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure OSPF to filter routes calculated using received LSAs. |
filter-policy { acl-number [ gateway ip-prefix-name ] | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] | route-policy route-policy-name } import |
By default, OSPF accepts all routes calculated using received LSAs. |
Perform this task to filter Type-3 LSAs advertised to an area on an ABR.
To configure Type-3 LSA filtering:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure Type-3 LSA filtering. |
filter { acl-number | ip-prefix ip-prefix-name } { import | export } |
By default, the ABR does not filter Type-3 LSAs. |
Configure an OSPF cost for an interface by using either of the following methods:
· Configure the cost value in interface view.
· Configure a bandwidth reference value for the interface. OSPF computes the cost with this formula: Interface OSPF cost = Bandwidth reference value (100 Mbps)/Interface bandwidth (Mbps). If the calculated cost is greater than 65535, the value of 65535 is used. If the calculated cost is less than 1, the value of 1 is used. If no cost or bandwidth reference value is configured for an interface, OSPF computes the interface cost based on the interface bandwidth and default bandwidth reference value.
To configure an OSPF cost for an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure an OSPF cost for the interface. |
ospf cost value |
By default, the OSPF cost is calculated according to the interface bandwidth. For a loopback interface, the OSPF cost is 0 by default. |
To configure a bandwidth reference value:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a bandwidth reference value. |
bandwidth-reference value |
The default setting is 100 Mbps. |
Step |
Command |
Remarks |
system-view |
N/A |
ospf [ process-id | router-id router-id | vpn-instance instance-name ] * |
N/A |
3. Specify the maximum number of OSPF routes. |
maximum-routes number |
By default, the maximum number of OSPF routes is 4294967295. |
Perform this task to implement load sharing over ECMP routes.
To configure the maximum number of ECMP routes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the maximum number of ECMP routes. |
maximum load-balancing maximum |
By default, the maximum number of ECMP routes is 32. |
Configuring OSPF preference
A router can run multiple routing protocols, and each protocol is assigned a preference. If multiple routes are available to the same destination, the one with the highest protocol preference is selected as the best route.
To configure OSPF preference:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a preference for OSPF. |
preference [ ase ] [ route-policy route-policy-name ] value |
By default, the preference of OSPF internal routes is 10 and the preference of OSPF external routes is 150. |
On a router running OSPF and other routing protocols, you can configure OSPF to redistribute routes from other protocols, such as RIP, IS-IS, BGP, static, and direct, and advertise them in Type-5 LSAs or Type-7 LSAs. In addition, you can configure OSPF to filter redistributed routes so that OSPF advertises only permitted routes.
IMPORTANT: The import-route bgp command redistributes only EBGP routes. Because the import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes, and might cause routing loops, use it with caution. |
Configuring OSPF to redistribute routes from another routing protocol
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure OSPF to redistribute routes from another routing protocol. |
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | route-policy route-policy-name | tag tag | type type ] * |
By default, no route redistribution is configured. This command redistributes only active routes. To view information about active routes, use the display ip routing-table protocol command. |
4. (Optional.) Configure OSPF to filter redistributed routes. |
filter-policy { acl-number | prefix-list ip-prefix-name } export [ protocol [ process-id ] ] |
By default, OSPF accepts all redistributed routes. |
Configuring OSPF to redistribute a default route
The import-route command cannot redistribute a default external route. Perform this task to redistribute a default route.
To redistribute a default route:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Redistribute a default route. |
default-route-advertise [ [ [ always | permit-calculate-other ] | cost cost | route-policy route-policy-name | type type ] * | summary cost cost ] |
By default, no default route is redistributed. This command is applicable only to VPNs. The PE router advertises a default route in a Type-3 LSA to a CE router. |
Configuring default parameters for redistributed routes
Perform this task to configure default parameters for redistributed routes, including cost, tag, and type. Tags indicate information about protocols. For example, when redistributing BGP routes, OSPF uses tags to identify AS IDs.
To configure the default parameters for redistributed routes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the default parameters for redistributed routes (cost, upper limit, tag, and type). |
default { cost cost | tag tag | type type } * |
By default, the cost is 1, the tag is 1, and the type is Type-2. |
Advertising a host route
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Advertise a host route. |
host-advertise ip-address cost |
By default, no host route is advertised. |
You can use one of the following methods to optimize an OSPF network:
· Change OSPF packet timers to adjust the convergence speed and network load. On low-speed links, consider the delay time for sending LSAs.
· Change the SPF calculation interval to reduce resource consumption caused by frequent network changes.
· Configure OSPF authentication to improve security.
Before you configure OSPF network optimization, complete the following tasks:
· Enable OSPF.
Configuring OSPF timers
An OSPF interface includes the following timers:
· Hello timer—Interval for sending hello packets. It must be identical on OSPF neighbors.
· Poll timer—Interval for sending hello packets to a neighbor that is down on the NBMA network.
· Dead timer—Interval within which if the interface receives no hello packet from the neighbor, it declares the neighbor is down.
· LSA retransmission timer—Interval within which if the interface receives no acknowledgement packets after sending a LSA to the neighbor, it retransmits the LSA.
To configure OSPF timers:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify the hello interval. |
ospf timer hello seconds |
By default: · The hello interval on P2P and broadcast interfaces is 10 seconds. The hello interval on P2MP and NBMA interfaces is 30 seconds. The default hello interval is restored when the network type for an interface is changed. |
4. Specify the poll interval. |
ospf timer poll seconds |
The default setting is 120 seconds. The poll interval is at least four times the hello interval. |
5. Specify the dead interval. |
ospf timer dead seconds |
By default: · The dead interval on P2P and broadcast interfaces is 40 seconds. · The dead interval on P2MP and NBMA interfaces is 120 seconds. The dead interval must be at least four times the hello interval on an interface. The default dead interval is restored when the network type for an interface is changed. |
6. Specify the retransmission interval. |
ospf timer retransmit interval |
The default setting is 5 seconds. A retransmission interval setting that is too small can cause unnecessary LSA retransmissions. This interval is typically set bigger than the round-trip time of a packet between two neighbors. |
To avoid LSAs from aging out during transmission, set an LSA retransmission delay especially for low speed links.
To specify the LSA transmission delay on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify the LSA transmission delay. |
ospf trans-delay seconds |
The default setting is 1 second. |
LSDB changes result in SPF calculations. When the topology changes frequently, a large amount of network and router resources are occupied by SPF calculation. You can adjust the SPF calculation interval to reduce the impact.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval is incremented by incremental-interval × 2n-2 (n is the number of calculation times) each time a calculation occurs until the maximum-interval is reached.
To configure the SPF calculation interval:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify the SPF calculation interval. |
spf-schedule-interval maximum-interval [ minimum-interval [ incremental-interval ] ] |
By default: · The maximum interval is 5 seconds. · The minimum interval is 50 milliseconds. · The incremental interval is 200 milliseconds. |
If OSPF receives an LSA that has the same LSA type, LS ID, and router ID as the previously received LSA within the LSA arrival interval, OSPF discards the LSA to save bandwidth and route resources.
To configure the LSA arrival interval:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the LSA arrival interval. |
lsa-arrival-interval interval |
The default setting is 1000 milliseconds. Make sure this interval is smaller than or equal to the interval set with the lsa-generation-interval command. |
Adjust the LSA generation interval to protect network resources and routers from being overwhelmed by LSAs at the time of frequent network changes.
When network changes are not frequent, LSAs are generated at the minimum-interval. If network changes become frequent, the LSA generation interval is incremented by incremental-interval × 2n-2 (n is the number of generation times) each time a LSA generation occurs until the maximum-interval is reached.
To configure the LSA generation interval:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the LSA generation interval. |
lsa-generation-interval maximum-interval [ minimum-interval [ incremental-interval ] ] |
By default: · The maximum interval is 5 seconds. · The minimum interval is 0 milliseconds. · The incremental interval is 0 milliseconds. |
To enhance OSPF adaptability and reduce resource consumption, you can set an OSPF interface to "silent." A silent OSPF interface blocks OSPF packets and cannot establish any OSPF neighbor relationship. However, other interfaces on the router can still advertise direct routes of the interface in Router LSAs.
To disable interfaces from sending and receiving routing information:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable interfaces from sending and receiving OSPF packets. |
silent-interface { interface-type interface-number | all } |
By default, an OSPF interface can send and receive OSPF packets. The silent-interface command disables only the interfaces associated with the current process rather than other processes. Multiple OSPF processes can disable the same interface from sending and receiving OSPF packets. |
Configuring stub routers
A stub router is used for traffic control. It reports its status as a stub router to neighboring OSPF routers. The neighboring routers do not use the stub router to forward data although they have a route to it.
Router LSAs from the stub router might contain different link type values. A value of 3 means a link to a stub network, and the cost of the link will not be changed. A value of 1, 2 or 4 means a point-to-point link, a link to a transit network, or a virtual link. On such links, a maximum cost value of 65535 is used. Neighbors do not send packets to the stub router as long as they have a route with a smaller cost.
To configure a router as a stub router:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the router as a stub router. |
stub-router |
By default, the router is not configured as a stub router. A stub router has no associations with a stub area. |
Configure OSPF packet authentication to ensure the packet exchange security.
After authentication is configured, OSPF only receives packets that pass authentication. Failed packets cannot establish neighboring relationships.
You must configure the same area authentication mode on all the routers in an area. In addition, the authentication mode and password for all interfaces attached to the same area must be identical.
To configure OSPF authentication:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure area authentication mode. |
authentication-mode { md5 | simple } |
By default, no authentication is configured. |
5. Return to OSPF view. |
quit |
N/A |
6. Return to system view. |
quit |
N/A |
7. Enter interface view. |
N/A |
8. Configure interface authentication mode. |
Configure simple authentication: ·
Configure MD5 authentication: |
Use either approach. By default, no interface authentication is configured. |
By default, an OSPF interface adds a value of 0 into the interface MTU field of a DD packet rather than the actual interface MTU. You can enable an interface to add its MTU into DD packets.
To add the interface MTU into DD packets:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the interface to add its MTU into DD packets. |
ospf mtu-enable |
By default, the interface adds an MTU value of 0 into DD packets. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify the maximum number of external LSAs in the LSDB. |
lsdb-overflow-limit number |
By default, the maximum number of external LSAs in the LSDB is not limited. |
When the number of LSAs in the LSDB exceeds the upper limit, the LSDB is in an overflow state. To save resources, OSPF does not receive any external LSAs and deletes the external LSAs generated by itself when in this state.
Perform this task to configure the interval that OSPF exits overflow state.
To configure the OSPF exit overflow interval:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the OSPF exit overflow interval. |
lsdb-overflow-interval interval |
The default setting is 300 seconds. The value of 0 indicates that OSPF does not exit overflow state. |
RFC 1583 specifies a different method than RFC 2328 for selecting an external route from multiple LSAs. This task enables RFC 2328 to be compatible with RFC 1583 so that the intra-area route in the backbone area is preferred. If they are not compatible, the intra-area route in a non-backbone area is preferred to reduce the burden of the backbone area.
To avoid routing loops, H3C recommends enabling or disabling RFC 1583-compatibility on all routers in a routing domain.
To enable compatibility with RFC 1583:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable compatibility with RFC 1583. |
rfc1583 compatible |
By default, this feature is enabled. |
Perform this task to enable output of log information to the terminal upon neighbor state changes.
To enable the logging of neighbor state changes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the logging of neighbor state changes. |
log-peer-change |
OSPF network management allows you to save system resources by enabling trap generation to report important events and configuring the maximum number of output traps for a specific time period.
To configure OSPF network management:
Command |
Remarks |
system-view |
N/A |
2. Bind OSPF MIB to an OSPF process. |
ospf mib-binding process-id |
By defaut, OSPF MIB is bound to the process with the smallest process ID. |
3. Enable OSPF trap generation. |
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] * |
By default, OSPF trap sending is enabled. |
4. Configure the number of output traps in a specific time. |
snmp trap rate-limit interval trap-interval count trap-number |
By default, OSPF outputs seven traps in 10 seconds. |
Sending large numbers of LSU packets affects router performance and consumes too much network bandwidth. You can configure the router to send LSU packets at a proper interval and limit the maximum number of LSU packets sent out of an OSPF interface each time.
To configure the LSU transmit rate:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the LSU transmit rate. |
transmit-pacing interval interval count count |
By default, an OSPF interface sends up to three LSU packets every 20 milliseconds. |
Enabling OSPF ISPF
When the topology changes, Incremental Shortest Path First (ISPF) computes only the affected part of the SPT, instead of the entire SPT.
To enable OSPF ISPF:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable OSPF ISPF. |
ispf enable |
By default, OSPF ISPF is enabled. |
GR ensures the continuity of packet forwarding when a routing protocol restarts or an active/standby switchover occurs.
· GR Restarter—Graceful restarting router. It must have GR capability.
· GR Helper—A neighbor of the GR Restarter. It helps the GR Restarter to complete the GR process.
OSPF GR has the following types:
· IETF GR—Uses Opaque LSAs to implement GR.
· Non-IETF GR—Uses link local signaling (LLS) to advertise GR capability and uses out of band synchronization to synchronize the LSDB.
A device can act as a GR Restarter and GR Helper at the same time.
You can configure the IETF or non IETF OSPF GR Restarter.
Configuring the IETF OSPF GR Restarter
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable OSPF and enter its view. |
N/A |
3. Enable opaque LSA reception and advertisement capability. |
opaque-capability enable |
By default, opaque LSA reception and advertisement capability is enabled. |
4. Enable the IETF GR. |
graceful-restart ietf [ global | planned-only ] * |
By default, the IETF GR capability is disabled. |
5. (Optional.) Configure GR interval. |
graceful-restart interval interval-value |
The default setting is 120 seconds. |
Configuring the non-IETF OSPF GR Restarter
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the link-local signaling capability. |
enable link-local-signaling |
By default, the link-local signaling capability is disabled. |
4. Enable the out-of-band re-synchronization capability. |
enable out-of-band-resynchronization |
By default, the out-of-band re-synchronization capability is disabled. |
5. Enable non-IETF GR. |
graceful-restart [ nonstandard ] [ global | planned-only ] * |
By default, non-IETF GR capability is disabled. |
6. (Optional.) Configure GR interval. |
The default setting is 120. |
Configuring OSPF GR Helper
You can configure the IETF or non IETF OSPF GR Helper.
Configuring the IETF OSPF GR Helper
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
4. (Optional.) Enable GR Helper capability. |
graceful-restart helper enable [ planned-only ] |
By default, GR Helper capability is enabled. |
5. (Optional.) Enable strict LSA checking for the GR Helper. |
graceful-restart helper strict-lsa-checking |
By default, strict LSA checking for the GR Helper is disabled. |
Configuring the non-IETF OSPF GR Helper
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
5. (Optional.) Enable GR Helper. |
graceful-restart helper enable |
By default, GR Helper is enabled. |
6. (Optional.) Enable strict LSA checking for the GR Helper. |
Performing an active/standby switchover on a device, or performing the following configuration on an OSPF router, triggers OSPF Graceful Restart.
To trigger OSPF Graceful Restart, perform the following command in user view:
Task |
Command |
Trigger OSPF Graceful Restart. |
reset ospf [ process-id ] process graceful-restart |
Configuring BFD for OSPF
OSPF supports the following BFD detection modes:
· Bidirectional control detection—Requires BFD configuration to be made on both OSPF routers on the link.
· Single-hop echo detection—Requires BFD configuration to be made on one OSPF router on the link.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable BFD bidirectional control detection. |
ospf bfd enable |
By default, BFD bidirectional control detection is disabled. Both ends of a BFD session must be on the same network segment and in the same area. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the source address of echo packets. |
bfd echo-source-ip ip-address |
By default, the source address of echo packets is not configured. |
3. Enter interface view. |
N/A |
4. Enable BFD single-hop echo detection. |
ospf bfd enable echo |
By default, BFD single-hop echo detection is disabled. |
A link or router failure on a path can cause packet loss and even routing loop until OSPF completes routing convergence based on the new network topology. FRR enables fast rerouting to minimize the impact of link or node failures.
Figure 7 Network diagram for OSPF FRR
In Figure 7, configure FRR on Router B by using a routing policy to specify a backup next hop. When the primary link fails, OSPF directs packets to the backup next hop. At the same time, OSPF calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
You can configure OSPF FRR to calculate a backup next hop by using the loop free alternate (LFA) algorithm, or specify a backup next hop by using a routing policy.
Before you configure OSPF FRR, complete the following tasks:
· Enable OSPF.
· Do not use FRR and BFD at the same time. Otherwise, FRR might fail to take effect.
· Do not use the fast-reroute lfa command together with the vlink-peer command.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
4. Enable LFA calculation on an interface. |
ospf fast-reroute lfa-backup |
By default, the interface on which LFA calculation is enabled can be selected as a backup interface. |
quit |
N/A |
N/A |
7. Enable OSPF FRR to calculate a backup next hop by using the LFA algorithm. |
fast-reroute lfa [ abr-only ] |
By default, OSPF FRR is not configured. If abr-only is specified, the route to the ABR is selected as the backup path. |
Before you configure this task, use the apply fast-reroute backup-interface command to specify a backup next hop in the routing policy to be referenced. For more information about the apply fast-reroute backup-interface command and routing policy configuration, see "Configuring routing policies."
To configure OSPF FRR to specify a backup next hop using a routing policy:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enter OSPF view. |
N/A |
4. Enable OSPF FRR to specify a backup next hop by using a routing policy. |
fast-reroute route-policy route-policy-name |
By default, OSPF FRR is not configured. |
Task |
Command |
Display OSPF brief information. |
display ospf [ process-id ] brief |
Display OSPF statistics. |
display ospf [ process-id ] cumulative |
Display GR status of the specified OSPF process. |
display ospf [ process-id ] graceful-restart [ verbose ] |
Display Link State Database information. |
display ospf [ process-id ] lsdb [ brief | [ { ase | router | network | summary | asbr | nssa | opaque-link | opaque-area | opaque-as } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ] |
Display OSPF neighbor information. |
display ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ] |
Display neighbor statistics of OSPF areas. |
display ospf [ process-id ] peer statistics |
Display routing table information. |
display ospf [ process-id ] routing [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ] |
Display virtual link information. |
display ospf [ process-id ] vlink |
Display OSPF request queue information. |
display ospf [ process-id ] request-queue [ interface-type interface-number ] [ neighbor-id ] |
Display OSPF retransmission queue information. |
display ospf [ process-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ] |
Display OSPF ABR and ASBR information. |
display ospf [ process-id ] abr-asbr |
Display OSPF interface information. |
display ospf [ process-id ] interface [ all | interface-type interface-number ] |
Display OSPF error information. |
display ospf [ process-id ] error |
Display OSPF ASBR route summarization information. |
display ospf [ process-id ] asbr-summary [ ip-address { mask | mask-length } ] |
Display the global route ID. |
display router id |
Clear OSPF statistics. |
reset ospf [ process-id ] counters |
Reset an OSPF process. |
reset ospf [ process-id ] process [ graceful-restart ] |
Re-enable OSPF route redistribution. |
reset ospf [ process-id ] redistribution |
OSPF configuration examples
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure such an interface, bring the interface up by executing the undo shutdown command.
Configuring basic OSPF
Network requirements
· Enable OSPF on all switches, and split the AS into three areas.
· Configure Switch A and Switch B as ABRs.
1. Configure IP addresses for interfaces. (Details not shown.)
2. Enable OSPF:
# Configure Switch A.
[SwitchA] router id 10.2.1.1
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1] area 1
[SwitchA-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.1] quit
[SwitchA-ospf-1] quit
# Configure Switch B.
[SwitchB] router id 10.3.1.1
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] area 2
[SwitchB-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.2] quit
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] router id 10.4.1.1
[SwitchC] ospf
[SwitchC-ospf-1] area 1
[SwitchC-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.1] quit
[SwitchC-ospf-1] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] router id 10.5.1.1
[SwitchD] ospf
[SwitchD-ospf-1] area 2
[SwitchD-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.2] network 10.5.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.2] quit
[SwitchD-ospf-1] quit
# Display information about neighbors on Switch A.
[SwitchA] display ospf peer verbose
OSPF Process 1 with Router ID 10.2.1.1
Neighbors
Area 0.0.0.0 interface 10.1.1.1(Vlan-interface100)'s neighbors
Router ID: 10.3.1.1 Address: 10.1.1.2 GR State: Normal
State: Full Mode: Nbr is Master Priority: 1
DR: 10.1.1.1 BDR: 10.1.1.2 MTU: 0
Dead timer due in 37 sec
Neighbor is up for 06:03:59
Neighbor state change count: 5
Neighbors
Area 0.0.0.1 interface 10.2.1.1(Vlan-interface200)'s neighbors
Router ID: 10.4.1.1 Address: 10.2.1.2 GR State: Normal
DR: 10.2.1.1 BDR: 10.2.1.2 MTU: 0
Dead timer due in 32 sec
Neighbor is up for 06:03:12
# Display OSPF routing information on Switch A.
[SwitchA] display ospf routing
Routing Tables
Routing for Network
Destination Cost Type NextHop AdvRouter Area
10.2.1.0/24 1 Transit 10.2.1.1 10.2.1.1 0.0.0.1
10.3.1.0/24 2 Inter 10.1.1.2 10.3.1.1 0.0.0.0
10.4.1.0/24 2 Stub 10.2.1.2 10.4.1.1 0.0.0.1
10.5.1.0/24 3 Inter 10.1.1.2 10.3.1.1 0.0.0.0
10.1.1.0/24 1 Transit 10.1.1.1 10.2.1.1 0.0.0.0
Total Nets: 5
Intra Area: 3 Inter Area: 2 ASE: 0 NSSA: 0
# Display OSPF routing information on Switch D.
[SwitchD] display ospf routing
OSPF Process 1 with Router ID 10.5.1.1
Routing Tables
Routing for Network
10.2.1.0/24 3 Inter 10.3.1.1 10.3.1.1 0.0.0.2
10.3.1.0/24 1 Transit 10.3.1.2 10.3.1.1 0.0.0.2
10.4.1.0/24 4 Inter 10.3.1.1 10.3.1.1 0.0.0.2
10.5.1.0/24 1 Stub 10.5.1.1 10.5.1.1 0.0.0.2
10.1.1.0/24 2 Inter 10.3.1.1 10.3.1.1 0.0.0.2
Total Nets: 5
Intra Area: 2 Inter Area: 3 ASE: 0 NSSA: 0
# On Switch D, ping the IP address 10.4.1.1 to test reachability.
[SwitchD] ping 10.4.1.1
PING 10.4.1.1: 56 data bytes, press CTRL_C to break
Reply from 10.4.1.1: bytes=56 Sequence=2 ttl=253 time=2 ms
Reply from 10.4.1.1: bytes=56 Sequence=2 ttl=253 time=1 ms
Reply from 10.4.1.1: bytes=56 Sequence=3 ttl=253 time=1 ms
Reply from 10.4.1.1: bytes=56 Sequence=4 ttl=253 time=1 ms
Reply from 10.4.1.1: bytes=56 Sequence=5 ttl=253 time=1 ms
--- 10.4.1.1 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 1/1/2 ms
· Enable OSPF on all the switches
· Split the AS into three areas
· Configure Switch A and Router B as ABRs
· Configure Switch C as an ASBR to redistribute external routes (static routes).
2. Enable OSPF (see "Configuring basic OSPF").
3. Configure OSPF to redistribute routes:
# On Switch C, configure a static route destined for network 3.1.2.0/24.
[SwitchC] ip route-static 3.1.2.1 24 10.4.1.2
# On Switch C, configure OSPF to redistribute static routes.
[SwitchC] ospf 1
[SwitchC-ospf-1] import-route static
# Display the ABR/ASBR information of Switch D.
<SwitchD> display ospf abr-asbr
Routing Table to ABR and ASBR
Type Destination Area Cost Nexthop RtType
Intra 10.3.1.1 0.0.0.2 10 10.3.1.1 ABR
Inter 10.4.1.1 0.0.0.2 22 10.3.1.1 ASBR
# Display the OSPF routing table on Switch D.
<SwitchD> display ospf routing
Routing Tables
Routing for Network
10.2.1.0/24 22 Inter 10.3.1.1 10.3.1.1 0.0.0.2
10.3.1.0/24 10 Transit 10.3.1.2 10.3.1.1 0.0.0.2
10.4.1.0/24 25 Inter 10.3.1.1 10.3.1.1 0.0.0.2
10.5.1.0/24 10 Stub 10.5.1.1 10.5.1.1 0.0.0.2
10.1.1.0/24 12 Inter 10.3.1.1 10.3.1.1 0.0.0.2
Routing for ASEs
Destination Cost Type Tag NextHop AdvRouter
3.1.2.0/24 1 Type2 1 10.3.1.1 10.4.1.1
Total Nets: 6
Intra Area: 2 Inter Area: 3 ASE: 1 NSSA: 0
· Configure OSPF on Switch A and Switch B in AS 200.
· Configure OSPF on Switch C, Switch D, and Switch E in AS 100.
· Configure an eBGP connection between Switch B and Switch C. Configure Switch B and Switch C to redistribute OSPF routes and direct routes into BGP and BGP routes into OSPF.
· Configure Switch B to advertise only summary route 10.0.0.0/8 to Switch A.
2. Enable OSPF:
[SwitchA] router id 11.2.1.2
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[SwitchB] router id 11.2.1.1
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[SwitchC] router id 11.1.1.2
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchD] router id 10.3.1.1
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 10.3.1.0 0.0.0.255
# Configure Switch E.
<SwitchE> system-view
[SwitchE] router id 10.4.1.1
[SwitchE] ospf
[SwitchE-ospf-1] area 0
[SwitchE-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE-ospf-1] quit
3. Configure BGP to redistribute OSPF routes and direct routes:
[SwitchB] bgp 200
[SwitchB-bgp] peer 11.1.1.2 as 100
[SwitchB-bgp] ipv4-family unicast
[SwitchB-bgp-ipv4] import-route ospf
[SwitchB-bgp-ipv4] import-route direct
[SwitchB-bgp ipv4] quit
[SwitchB-bgp] quit
[SwitchC] bgp 100
[SwitchC-bgp] peer 11.1.1.1 as 200
[SwitchC-bgp] ipv4-family unicast
[SwitchC-bgp-ipv4] import-route ospf
[SwitchC-bgp-ipv4]import-route direct
[SwitchC-bgp-ipv4] quit
[SwitchC-bgp] quit
4. Configure Switch B and Switch C to redistribute BGP routes into OSPF:
# Configure OSPF to redistribute routes from BGP on Switch B.
[SwitchB] ospf
# Configure OSPF to redistribute routes from BGP on Switch C.
[SwitchC] ospf
[SwitchC-ospf-1] import-route bgp
# Display the OSPF routing table on Switch A.
Destinations : 16 Routes : 16
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 OSPF 150 1 11.2.1.1 Vlan100
10.2.1.0/24 OSPF 150 1 11.2.1.1 Vlan100
10.3.1.0/24 OSPF 150 1 11.2.1.1 Vlan100
10.4.1.0/24 OSPF 150 1 11.2.1.1 Vlan100
11.2.1.0/24 Direct 0 0 11.2.1.2 Vlan100
11.2.1.0/32 Direct 0 0 11.2.1.2 Vlan100
11.2.1.2/32 Direct 0 0 127.0.0.1 InLoop0
11.2.1.255/32 Direct 0 0 11.2.1.2 Vlan100
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
5. Configure route summarization:
# Configure route summarization on Switch B to advertise a summary route 10.0.0.0/8.
[SwitchB-ospf-1] asbr-summary 10.0.0.0 8
# Display the IP routing table on Switch A.
Destinations : 13 Routes : 13
10.0.0.0/8 OSPF 150 2 11.2.1.1 Vlan100
The output shows that routes 10.1.1.0/24, 10.2.1.0/24, 10.3.1.0/24 and 10.4.1.0/24 are summarized into a single route 10.0.0.0/8.
Configuring an OSPF stub area
· Configure Switch A and Switch B as ABRs to forward routing information between areas.
· Configure Switch D as the ASBR to redistribute static routes.
· Configure Area 1 as a stub area to reduce advertised LSAs without influencing reachability.
3. Configure route redistribution:
# Configure Switch D to redistribute static routes.
[SwitchD] ip route-static 3.1.2.1 24 10.5.1.2
[SwitchD] ospf
[SwitchD-ospf-1] import-route static
# Display ABR/ASBR information on Switch C.
<SwitchC> display ospf abr-asbr
OSPF Process 1 with Router ID 10.4.1.1
Intra 10.2.1.1 0.0.0.1 3 10.2.1.1 ABR
Inter 10.5.1.1 0.0.0.1 7 10.2.1.1 ASBR
# Display OSPF routing table on Switch C.
<SwitchC> display ospf routing
Routing Tables
Routing for Network
10.2.1.0/24 3 Transit 10.2.1.2 10.2.1.1 0.0.0.1
10.3.1.0/24 7 Inter 10.2.1.1 10.2.1.1 0.0.0.1
10.4.1.0/24 3 Stub 10.4.1.1 10.4.1.1 0.0.0.1
10.5.1.0/24 17 Inter 10.2.1.1 10.2.1.1 0.0.0.1
10.1.1.0/24 5 Inter 10.2.1.1 10.2.1.1 0.0.0.1
Routing for ASEs
3.1.2.0/24 1 Type2 1 10.2.1.1 10.5.1.1
Total Nets: 6
Because Switch C resides in a normal OSPF area, its routing table contains an AS external route.
4. Configure Area 1 as a stub area:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] stub
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.1] stub
# Display OSPF routing information on Switch C
Routing Tables
Routing for Network
0.0.0.0/0 4 Inter 10.2.1.1 10.2.1.1 0.0.0.1
Total Nets: 6
Intra Area: 2 Inter Area: 4 ASE: 0 NSSA: 0
After the area where Switch C resides is configured as a stub area, a default route takes the place of the AS external route.
# Configure the area as a totally stub area by filtering Type-3 LSAs out of the stub area.
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] stub no-summary
# Display OSPF routing information on Switch C.
Routing Tables
Routing for Network
10.2.1.0/24 3 Transit 10.2.1.2 10.4.1.1 0.0.0.1
Total Nets: 3
Intra Area: 2 Inter Area: 1 ASE: 0 NSSA: 0
After this configuration, inter-area routes are removed, and only one external route (a default route) exists.
Configuring an OSPF NSSA area
· Configure OSPF on all switches and split AS into three areas.
· Configure Area 1 as an NSSA area and configure Switch C as an ASBR to redistribute static routes into the AS.
3. Configure Area 1 as an NSSA area:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] nssa default-route-advertise no-summary
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.1] nssa
NOTE: · To allow Switch C in the NSSA area to reach other areas within the AS, you must provide the keyword default-route-advertise for the nssa command issued on Switch A (the ABR) so that Switch C can obtain a default route. · Configuring the nssa command with the keyword no-summary on Switch A can reduce the routing table size on NSSA Switches. On other NSSA Switches, you only need to configure the nssa command. |
Routing Tables
Routing for Network
0.0.0.0/0 65536 Inter 10.2.1.1 10.2.1.1 0.0.0.1
10.2.1.0/24 65535 Transit 10.2.1.2 10.4.1.1 0.0.0.1
Total Nets: 3
4. Configure route redistribution:
# Configure Switch C to redistribute static routes.
[SwitchC] ip route-static 3.1.3.1 24 10.4.1.2
[SwitchC] ospf
Routing Tables
Routing for Network
Routing for ASEs
3.1.3.0/24 1 Type2 1 10.3.1.1 10.2.1.1
Total Nets: 6
The output shows an external route imported from the NSSA area exists on Switch D.
Configuring OSPF DR election
· Enable OSPF on Switches A, B, C, and D on the same network.
· Configure Switch A as the DR, and configure Switch C as the BDR.
2. Enable OSPF:
[SwitchA] router id 1.1.1.1
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchB] router id 2.2.2.2
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchC] router id 3.3.3.3
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchD] router id 4.4.4.4
[SwitchD] ospf
[SwitchD-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchD-ospf-1] return
# Display OSPF neighbor information of Switch A.
Neighbors
Area 0.0.0.0 interface 192.168.1.1(Vlan-interface1)'s neighbors
Router ID: 2.2.2.2 Address: 192.168.1.2 GR State: Normal
State: 2-Way Mode: None Priority: 1
DR: 192.168.1.4 BDR: 192.168.1.3 MTU: 0
Dead timer due in 38 sec
Neighbor is up for 00:01:31
Router ID: 3.3.3.3 Address: 192.168.1.3 GR State: Normal
Dead timer due in 31 sec
Neighbor is up for 00:01:28
Router ID: 4.4.4.4 Address: 192.168.1.4 GR State: Normal
The output shows that Switch D is the DR and Switch C is the BDR.
3. Configure router priorities on interfaces:
[SwitchA-Vlan-interface1] ospf dr-priority 100
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] ospf dr-priority 0
[SwitchB-Vlan-interface1] quit
[SwitchC] interface vlan-interface 1
[SwitchC-Vlan-interface1] ospf dr-priority 2
[SwitchC-Vlan-interface1] quit
# Display neighbor information of Switch D.
<SwitchD> display ospf peer verbose
OSPF Process 1 with Router ID 4.4.4.4
Neighbors
Area 0.0.0.0 interface 192.168.1.4(Vlan-interface1)'s neighbors
Router ID: 1.1.1.1 Address: 192.168.1.1 GR State: Normal
State: Full Mode:Nbr is Slave Priority: 100
Neighbor is up for 00:11:17
State: Full Mode:Nbr is Slave Priority: 0
Dead timer due in 35 sec
Neighbor is up for 00:11:19
State: Full Mode:Nbr is Slave Priority: 2
Dead timer due in 33 sec
Neighbor is up for 00:11:15
The output shows that the DR and BDR are not changed, because the priority settings do not take effect immediately.
4. Restart OSPF process:
# Restart the OSPF process of Switch D.
<SwitchD> reset ospf 1 process
Warning : Reset OSPF process? [Y/N]:y
Neighbors
State: Full Mode: Nbr is Slave Priority: 100
DR: 192.168.1.1 BDR: 192.168.1.3 MTU: 0
Dead timer due in 39 sec
Neighbor is up for 00:01:40
State: 2-Way Mode: None Priority: 0
Neighbor is up for 00:01:44
State: Full Mode: Nbr is Slave Priority: 2
Neighbor is up for 00:01:41
If the neighbor state is full, Switch D has established an adjacency with the neighbor. If the neighbor state is 2-way, the two switches are not the DR or the BDR, and they do not exchange LSAs.
# Display OSPF interface information.
[SwitchA] display ospf interface
Interfaces
Area: 0.0.0.0
IP Address Type State Cost Pri DR BDR
192.168.1.1 Broadcast DR 1 100 192.168.1.1 192.168.1.3
[SwitchB] display ospf interface
Interfaces
Area: 0.0.0.0
192.168.1.2 Broadcast DROther 1 0 192.168.1.1 192.168.1.3
The interface state DROther means the interface is not the DR or BDR.
Configuring OSPF virtual links
Configure a virtual link between Switch B and Switch C to connect Area 2 to the backbone area. After configuration, Switch B can learn routes to Area 2.
2. Enable OSPF:
[SwitchA] ospf 1 router-id 1.1.1.1
[SwitchB] ospf 1 router-id 2.2.2.2
[SwitchB-ospf-1] area 1
[SwitchB–ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchB–ospf-1-area-0.0.0.1] quit
[SwitchC] ospf 1 router-id 3.3.3.3
[SwitchC-ospf-1] area 2
[SwitchC–ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchC–ospf-1-area-0.0.0.2] quit
[SwitchD] ospf 1 router-id 4.4.4.4
# Display the OSPF routing table of Switch B.
[SwitchB] display ospf routing
Routing Tables
Routing for Network
10.2.1.0/24 2 Transit 10.2.1.1 3.3.3.3 0.0.0.1
10.1.1.0/24 2 Transit 10.1.1.2 2.2.2.2 0.0.0.0
Total Nets: 2
Intra Area: 2 Inter Area: 0 ASE: 0 NSSA: 0
Area 0 has no direct connection to Area 2, so the routing table of Switch B has no route to Area 2.
3. Configure a virtual link:
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.1] vlink-peer 3.3.3.3
[SwitchB-ospf-1-area-0.0.0.1] quit
[SwitchC] ospf 1
[SwitchC-ospf-1-area-0.0.0.1] vlink-peer 2.2.2.2
# Display the OSPF routing table on Switch B.
Routing Tables
Routing for Network
10.3.1.0/24 5 Inter 10.2.1.2 3.3.3.3 0.0.0.0
Total Nets: 3
The output shows that Switch B has learned the route 10.3.1.0/24 to Area 2.
Configuring OSPF Graceful Restart
· As shown in Figure 15, Switch A, Switch B, and Switch C that belong to the same AS and the same OSPF routing domain are GR capable.
· Switch A acts as the non-IETF GR Restarter; Switch B and Switch C are the GR Helpers and re-synchronize their LSDB with Switch A through OOB communication of GR.
2. Enable OSPF:
[SwitchA] ospf 100
[SwitchA-ospf-100] area 0
[SwitchA-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[SwitchA-ospf-100-area-0.0.0.0] quit
[SwitchB] ospf 100
[SwitchB-ospf-100] area 0
[SwitchB-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[SwitchB-ospf-100-area-0.0.0.0] quit
[SwitchC] ospf 100
[SwitchC-ospf-100] area 0
[SwitchC-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[SwitchC-ospf-100-area-0.0.0.0] quit
3. Configure OSPF GR:
# Configure Switch A as the non-IETF OSPF GR Restarter: enable the link-local signaling capability, the out-of-band re-synchronization capability, and non-IETF Graceful Restart capability for OSPF process 100.
[SwitchA-ospf-100] enable link-local-signaling
[SwitchA-ospf-100] enable out-of-band-resynchronization
[SwitchA-ospf-100] graceful-restart
[SwitchA-ospf-100] return
# Configure Switch B as the GR Helper: enable the link-local signaling capability and the out-of-band re-synchronization capability for OSPF process 100.
[SwitchB-ospf-100] enable link-local-signaling
[SwitchB-ospf-100] enable out-of-band-resynchronization
# Configure Switch C as the GR Helper: enable the link-local signaling capability and the out-of-band re-synchronization capability for OSPF process 100.
[SwitchC-ospf-100] enable link-local-signaling
[SwitchC-ospf-100] enable out-of-band-resynchronization
# After the configurations on Switch A, Switch B, and Switch C are complete and the switches are running steadily, enable OSPF Graceful Restart event debugging and then restart the OSPF process using GR on Switch A.
<SwitchA> debugging ospf event graceful-restart
<SwitchA> terminal monitor
<SwitchA> terminal logging level 7
<SwitchA> reset ospf 100 process graceful-restart
%Oct 21 15:29:28:727 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Full to Down.
%Oct 21 15:29:28:729 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Full to Down.
*Oct 21 15:29:28:735 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF 100 nonstandard GR Started for OSPF Router
OSPF 100 created GR wait timer,timeout interval is 40(s).
OSPF 100 created GR Interval timer,timeout interval is 120(s).
*Oct 21 15:29:28:758 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF 100 created OOB Progress timer for neighbor 192.1.1.3.
*Oct 21 15:29:28:766 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF 100 created OOB Progress timer for neighbor 192.1.1.2.
%Oct 21 15:29:29:902 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Loading to Full.
*Oct 21 15:29:29:902 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF 100 deleted OOB Progress timer for neighbor 192.1.1.2.
%Oct 21 15:29:30:897 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Loading to Full.
*Oct 21 15:29:30:897 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF 100 deleted OOB Progress timer for neighbor 192.1.1.3.
*Oct 21 15:29:30:911 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF GR: Process 100 Exit Restart,Reason : DR or BDR change,for neighbor : 192.1.1.3.
OSPF 100 deleted GR Interval timer.
*Oct 21 15:29:30:912 2011 SwitchA OSPF/7/DEBUG: -MDC=1;
OSPF 100 deleted GR wait timer.
%Oct 21 15:29:30:920 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Full to Down.
%Oct 21 15:29:30:921 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Full to Down.
%Oct 21 15:29:33:815 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Loading to Full.
%Oct 21 15:29:35:578 2011 SwitchA OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Loading to Full.
The output shows that Switch A completes GR.
As shown in Figure 16, run OSPF on Switch A, Switch B, and Switch C so that they are reachable to each other at the network layer. When the link over which Switch A and Switch B communicate through a Layer 2 switch fails, BFD can quickly detect the failure and notify OSPF of the failure. Switch A and Switch B then communicate through Switch C.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int10 |
192.168.0.102/24 |
Switch B |
Vlan-int10 |
192.168.0.100/24 |
Vlan-int11 |
10.1.1.102/24 |
Vlan-int13 |
13.1.1.1/24 |
Switch C |
Vlan-int11 |
10.1.1.100/24 |
Vlan-int13 |
13.1.1.2/24 |
2. Enable OSPF:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0] network 121.1.1.0 0.0.0.255
[SwitchA] interface vlan 11
[SwitchA-Vlan-interface11] ospf cost 2
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 120.1.1.0 0.0.0.255
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] ospf cost 2
[SwitchA-Vlan-interface13] quit
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
3. Configure BFD:
# Enable BFD on Switch A and configure BFD parameters.
[SwitchA-Vlan-interface10] ospf bfd enable
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
[SwitchA] quit
# Enable BFD on Switch B and configure BFD parameters.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] ospf bfd enable
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 6
# Display the BFD information on Switch A.
<SwitchA> display bfd session
Total Session Num: 1 Up Session Num: 1 Init Mode: Active
3/1 192.168.0.102 192.168.0.100 Up 1700ms Vlan10
# Display routes destined for 120.1.1.0/24 on Switch A.
<SwitchA> display ip routing-table 120.1.1.0 verbose
Summary Count : 1
Destination: 120.1.1.0/24
Protocol: OSPF Process ID: 1
SubProtID: 0x1 Age: 04h20m37s
Cost: 2 Preference: 10
Tag: 0 State: Active Adv
TableID: 0x2 OrigAs: 0
NBRID: 0x26000002 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1008c OrigNextHop: 192.168.0.100
Label: NULL RealNextHop: 192.168.0.100
BkLabel: NULL BkNextHop: N/A
Tunnel ID: Invalid Interface: Vlan-interface10
BkTunnel ID: Invalid BkInterface: N/A
The output shows that Switch A communicates with Switch B through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
Cost: 4 Preference: 10
Flags: 0x1008c OrigNextHop: 10.1.1.100
Label: NULL RealNextHop: 10.1.1.100
Tunnel ID: Invalid Interface: Vlan-interface11
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
Configuring OSPF FRR
As shown in Figure 17, Switch S, Switch A, and Switch D reside in the same OSPF domain. Configure OSPF FRR so that when the link between Switch S and Switch D fails, traffic is immediately switched to Link B.
Configuration procedure
1. Configure IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2. Configure OSPF on the switches to make sure Switch S, Switch A, and Switch D can communicate with each other at the network layer. (Details not shown.)
3. Configure OSPF FRR to automatically calculate the backup next hop:
You can enable OSPF FRR to either calculate a backup next hop by using the LFA algorithm, or specify a backup next hop by using a routing policy.
¡ (Method 1.) Enable OSPF FRR to calculate the backup next hop by using the LFA algorithm:
# Configure Switch S.
<SwitchS> system-view
[SwitchS] bfd echo-source-ip 1.1.1.1
[SwitchS] ospf 1
[SwitchS-ospf-1] fast-reroute lfa
[SwitchS-ospf-1] quit
[SwitchD] bfd echo-source-ip 4.4.4.4
[SwitchD] ospf 1
[SwitchD-ospf-1] fast-reroute lfa
¡ (Method 2.) Enable OSPF FRR to designate a backup next hop by using a routing policy.
[SwitchS] ip prefix-list abc index 10 permit 4.4.4.4 32
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchS-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy-frr-10] quit
[SwitchS] ospf 1
[SwitchS-ospf-1] fast-reroute route-policy frr
[SwitchD] ip prefix-list abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchD-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy-frr-10] quit
[SwitchD] ospf 1
[SwitchD-ospf-1] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch S to view the backup next hop information.
[SwitchS] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
Cost: 1 Preference: 10
Flags: 0x1008c OrigNextHop: 13.13.13.2
Label: NULL RealNextHop: 13.13.13.2
BkLabel: NULL BkNextHop: 12.12.12.2
Tunnel ID: Invalid Interface: Vlan-interface200
BkTunnel ID: Invalid BkInterface: Vlan-interface100
# Display route 1.1.1.1/32 on Switch D to view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
Flags: 0x1008c OrigNextHop: 13.13.13.1
Label: NULL RealNextHop: 13.13.13.1
BkLabel: NULL BkNextHop: 24.24.24.2
BkTunnel ID: Invalid BkInterface: Vlan-interface101
Troubleshooting OSPF configuration
No OSPF neighbor relationship established
Symptom
No OSPF neighbor relationship can be established.
Analysis
If the physical link and lower layer protocols work well, verify OSPF parameters configured on interfaces. Two neighbors must have the same parameters, such as the area ID, network segment, and mask (a P2P or virtual link can have different network segments and masks).
Solution
1. Use the display ospf peer command to verify OSPF neighbor information.
2. Use the display ospf interface command to verify OSPF interface information.
3. Ping the neighbor router's IP address to verify that the connectivity is normal.
4. Verify OSPF timers. The dead interval on an interface must be at least four times the hello interval.
5. On an NBMA network, use the peer ip-address command to manually specify the neighbor.
6. At least one interface must have a router priority higher than 0 on an NBMA or a broadcast network.
Incorrect routing information
Symptom
OSPF cannot find routes to other areas.
Analysis
The backbone area must maintain connectivity to all other areas. If a router connects to more than one area, at least one area must be connected to the backbone. The backbone cannot be configured as a stub area.
In a stub area, all routers cannot receive external routes, and all interfaces connected to the stub area must belong to the stub area.
Solution
1. Use the display ospf peer command to verify neighbor information.
3. Use the display ospf lsdb command to verify the LSDB.
4. Use the display current-configuration configuration ospf command to verify area configuration. If more than two areas are configured, at least one area is connected to the backbone.
5. In a stub area, all routers attached are configured with the stub command. In an NSSA area, all routers attached are configured with the nssa command.
6. If a virtual link is configured, use the display ospf vlink command to verify the state of the virtual link.
