H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
46-Appendix
46-Appendix 87.91 KB
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
abr-summary
16-Routing Protocol Command
4-1
access-limit
19-AAA Command
1-1
accounting
19-AAA Command
1-2
accounting domain
24-DHCP Command
1-1
accounting optional
19-AAA Command
1-3
accounting optional
19-AAA Command
1-27
accounting-on enable
19-AAA Command
1-27
acl
02-Login Command
2-1
acl
25-ACL Command
1-1
active region-configuration
15-MSTP Command
1-1
add-member
30-Cluster Command
1-12
address-check
24-DHCP Command
2-1
administrator-address
30-Cluster Command
1-13
am enable
45-Access Management Command
1-1
am ip-pool
1-1
am trap enable
1-2
am user-bind
11-Port Security-Port Binding Command
2-1
apply cost
5-1
apply poe-profile
31-PoE-PoE Profile Command
2-1
apply qos-profile
26-QoS-QoS Profile Command
2-1
apply tag
5-2
area
4-2
arp check enable
23-ARP Command
1-1
arp detection enable
23-ARP Command
1-2
arp detection trust
23-ARP Command
1-2
arp protective-down recover enable
23-ARP Command
1-3
arp protective-down recover interval
23-ARP Command
1-4
arp proxy enable
23-ARP Command
2-1
arp rate-limit
23-ARP Command
1-4
arp rate-limit enable
23-ARP Command
1-5
23-ARP Command
1-6
arp send-gratuitous enable vrrp
23-ARP Command
1-6
arp static
23-ARP Command
1-7
arp timer aging
23-ARP Command
1-8
asbr-summary
4-2
ascii
37-FTP-SFTP-TFTP Command
1-7
attribute
19-AAA Command
1-3
authentication
19-AAA Command
1-4
authentication super
19-AAA Command
1-6
authentication-mode
02-Login Command
1-1
authentication-mode
4-3
authorization
19-AAA Command
1-7
authorization vlan
19-AAA Command
1-7
auto-build
30-Cluster Command
1-14
auto-execute command
02-Login Command
1-3
B
backup current-configuration
36-File System Management Command
1-22
bims-server
24-DHCP Command
1-2
binary
1-8
black-list
30-Cluster Command
1-38
boot attribute-switch
1-17
boot boot-loader
1-18
boot boot-loader
39-System Maintenance and Debugging Command
3-1
boot boot-loader backup-attribute
1-18
boot bootrom
3-1
boot web-package
1-19
bootfile-name
24-DHCP Command
1-3
bpdu-drop any
15-MSTP Command
1-2
bpdu-tunnel
40-VLAN-VPN Command
3-1
bpdu-tunnel tunnel-dmac
40-VLAN-VPN Command
3-2
broadcast-suppression
08-Port Basic Configuration Command
1-1
bsr-policy
17-Multicast Command
3-1
build
30-Cluster Command
1-16
burst-mode enable
1-1
bye
1-8
bye
1-26
C
cache-sa-enable
4-1
calling-station-id mode
19-AAA Command
1-29
c-bsr
3-1
cd
1-1
cd
1-9
cd
1-26
cdup
1-9
cdup
1-27
change self-unit
29-IRF Fabric Command
1-1
change unit-id
1-2
check region-configuration
15-MSTP Command
1-2
checkzero
3-1
clock datetime
1-1
clock summer-time
1-2
clock timezone
1-3
close
1-10
cluster
30-Cluster Command
1-18
cluster enable
30-Cluster Command
1-18
cluster switch-to
30-Cluster Command
1-19
cluster-mac
30-Cluster Command
1-20
cluster-mac syn-interval
30-Cluster Command
1-21
command-privilege level
01-CLI Command
1-1
copy
1-2
copy configuration
1-2
copyright-info enable
02-Login Command
1-4
count
41-HWPing Command
1-1
c-rp
3-2
crp-policy
3-3
cut connection
19-AAA Command
1-8
D
databits
02-Login Command
1-4
data-flow-format
19-AAA Command
1-30
data-flow-format
19-AAA Command
1-55
datasize
41-HWPing Command
1-2
debugging
1-8
default
4-4
default cost
3-2
default-cost
4-5
default-route-advertise
4-6
delete
1-3
delete
1-10
delete
1-27
delete static-routes all
2-1
delete-member
30-Cluster Command
1-21
description
04-VLAN Command
1-1
description
1-4
description
25-ACL Command
1-2
destination-ip
41-HWPing Command
1-2
destination-port
41-HWPing Command
1-3
detect-group
14-Auto Detect Command
1-1
detect-list
1-2
dhcp enable
24-DHCP Command
1-3
dhcp protective-down recover enable
24-DHCP Command
4-1
dhcp protective-down recover interval
24-DHCP Command
4-1
dhcp rate-limit
24-DHCP Command
4-2
dhcp rate-limit enable
24-DHCP Command
4-3
dhcp relay information enable
24-DHCP Command
2-2
dhcp relay information strategy
24-DHCP Command
2-3
dhcp select global
24-DHCP Command
1-4
dhcp select interface
24-DHCP Command
1-5
dhcp server bims-server
24-DHCP Command
1-7
dhcp server bootfile-name
24-DHCP Command
1-7
dhcp server detect
24-DHCP Command
1-8
dhcp server dns-list
24-DHCP Command
1-9
dhcp server domain-name
24-DHCP Command
1-10
dhcp server expired
24-DHCP Command
1-11
dhcp server forbidden-ip
24-DHCP Command
1-12
dhcp server ip-pool
24-DHCP Command
1-13
dhcp server nbns-list
24-DHCP Command
1-14
dhcp server netbios-type
24-DHCP Command
1-16
dhcp server option
24-DHCP Command
1-17
dhcp server ping
24-DHCP Command
1-18
dhcp server relay information enable
24-DHCP Command
1-19
dhcp server static-bind
24-DHCP Command
1-19
dhcp server tftp-server domain-name
24-DHCP Command
1-20
dhcp server tftp-server ip-address
24-DHCP Command
1-21
dhcp server voice-config
24-DHCP Command
1-22
dhcp-relay hand
24-DHCP Command
2-1
dhcp-security static
24-DHCP Command
2-4
dhcp-security tracker
24-DHCP Command
2-4
dhcp-server
24-DHCP Command
2-5
dhcp-server detect
24-DHCP Command
2-6
dhcp-server ip
24-DHCP Command
2-7
dhcp-snooping
24-DHCP Command
3-1
dhcp-snooping information enable
24-DHCP Command
3-1
dhcp-snooping information format
24-DHCP Command
3-2
dhcp-snooping information packet-format
24-DHCP Command
3-3
dhcp-snooping information remote-id
24-DHCP Command
3-3
dhcp-snooping information strategy
24-DHCP Command
3-4
dhcp-snooping information vlan circuit-id
24-DHCP Command
3-5
dhcp-snooping information vlan remote-id
24-DHCP Command
3-6
dhcp-snooping trust
24-DHCP Command
3-7
dir
1-4
dir
1-11
dir
1-28
disconnect
1-12
display acl
25-ACL Command
1-3
display am
1-3
display am user-bind
2-2
display arp
23-ARP Command
1-8
display arp |
23-ARP Command
1-9
display arp count
23-ARP Command
1-10
display arp detection statistics interface
23-ARP Command
1-11
display arp proxy
23-ARP Command
2-1
display arp timer aging
23-ARP Command
1-12
display boot-loader
1-20
display boot-loader
3-2
display bootp client
24-DHCP Command
5-3
display bpdu-tunnel
40-VLAN-VPN Command
3-3
display brief interface
1-5
display channel
38-Information Center Command
1-1
display clock
1-6
display cluster
30-Cluster Command
1-22
display cluster base-members
30-Cluster Command
1-39
display cluster base-topology
30-Cluster Command
1-40
display cluster black-list
30-Cluster Command
1-41
display cluster candidates
30-Cluster Command
1-24
display cluster current-topology
30-Cluster Command
1-42
display cluster members
30-Cluster Command
1-26
display connection
19-AAA Command
1-9
display cpu
3-3
display current-configuration
03-Configuration File Management Command
1-1
display current-configuration vlan
1-6
display debugging
1-6
display detect-group
1-2
display device
3-3
display dhcp client
24-DHCP Command
5-1
display dhcp server conflict
24-DHCP Command
1-23
display dhcp server expired
24-DHCP Command
1-24
display dhcp server free-ip
24-DHCP Command
1-25
display dhcp server ip-in-use
24-DHCP Command
1-26
display dhcp server statistics
24-DHCP Command
1-27
display dhcp server tree
24-DHCP Command
1-28
display dhcp-security
24-DHCP Command
2-7
display dhcp-server
24-DHCP Command
2-8
display dhcp-server interface
24-DHCP Command
2-10
display dhcp-snooping
24-DHCP Command
3-7
display dhcp-snooping trust
24-DHCP Command
3-8
display diagnostic-information
1-9
display dldp
12-DLDP Command
1-1
display dns domain
43-DNS Command
1-1
display dns dynamic-host
43-DNS Command
1-1
display dns ipv6 dynamic-host
42-IPv6 Management Command
1-1
display dns server
43-DNS Command
1-2
display domain
19-AAA Command
1-10
display dot1x
18-802.1x and System Guard Command
1-1
display drv qacl_resource
25-ACL Command
1-4
display fan
3-4
display fib
05-IP Address and Performance Command
2-1
display fib |
2-4
display fib acl
2-3
display fib ip-address
2-2
display fib ip-prefix
2-5
display fib statistics
2-5
display ftm
1-4
display ftp source-ip
1-12
display ftp-server
1-1
display ftp-server source-ip
1-2
display ftp-user
1-2
display garp statistics
07-GVRP Command
1-1
display garp timer
07-GVRP Command
1-2
display gvrp statistics
07-GVRP Command
1-6
display gvrp status
07-GVRP Command
1-7
display habp
3-1
display habp table
3-2
display habp traffic
3-2
display history-command
01-CLI Command
1-3
display hwping
41-HWPing Command
1-4
display hwtacacs
19-AAA Command
1-56
display icmp statistics
2-6
display igmp group
2-1
display igmp interface
2-2
display igmp-snooping configuration
5-1
display igmp-snooping group
5-2
display igmp-snooping statistics
5-3
display info-center
1-1
display interface
1-7
display interface Vlan-interface
04-VLAN Command
1-2
display ip host
43-DNS Command
1-3
display ip interface
1-1
display ip interface brief
1-2
display ip ip-prefix
5-2
display ip routing-table
1-1
display ip routing-table acl
1-3
display ip routing-table ip-address
1-5
display ip routing-table ip-address1 ip-address2
1-7
display ip routing-table ip-prefix
1-7
display ip routing-table protocol
1-8
display ip routing-table radix
1-9
display ip routing-table statistics
1-10
display ip routing-table verbose
1-11
display ip socket
2-7
display ip source static binding
24-DHCP Command
3-9
display ip statistics
2-8
display ipv6 fib
1-2
display ipv6 host
1-3
display ipv6 interface
1-4
display ipv6 neighbors
1-6
display ipv6 neighbors count
1-8
display ipv6 route-table
1-8
display ipv6 socket
1-10
display ipv6 statistics
1-11
display irf-fabric
1-7
display isolate port
10-Port Isolation Command
1-1
display lacp system-id
09-Link Aggregation Command
1-4
display link-aggregation interface
1-1
display link-aggregation summary
1-2
display link-aggregation verbose
1-3
display link-delay
1-11
display local-server statistics
19-AAA Command
1-30
display local-user
19-AAA Command
1-12
display logbuffer
1-3
display logbuffer summary
1-5
display loopback-detection
1-11
display mac-address
13-MAC Address Table Management Command
1-2
display mac-address aging-time
1-1
display mac-address multicast static
1-1
display mac-address security
1-1
display mac-authentication
21-MAC Address Authentication Command
1-1
display memory
6-1
display memory
3-5
display memory limit
6-2
display mirror
28-Mirroring Command
1-1
display mirroring-group
1-2
display monitor-link group
44-Smart Link-Monitor Link Command
2-1
display mpm forwarding-table
1-2
display mpm group
1-3
display msdp brief
4-1
display msdp peer-status
4-2
display msdp sa-cache
4-4
display msdp sa-count
4-6
display multicast forwarding-table
1-4
display multicast routing-table
1-6
display multicast-source-deny
1-7
display ndp
30-Cluster Command
1-1
display ntdp
30-Cluster Command
1-5
display ntdp device-list
30-Cluster Command
1-6
display ntdp single-device mac-address
30-Cluster Command
1-43
display ntp-service sessions
34-NTP Command
1-1
display ntp-service status
34-NTP Command
1-3
display ntp-service trace
34-NTP Command
1-4
display ospf abr-asbr
4-8
display ospf asbr-summary
4-9
display ospf brief
4-10
display ospf cumulative
4-13
display ospf error
4-14
display ospf interface
4-17
display ospf lsdb
4-18
display ospf nexthop
4-21
display ospf peer
4-22
display ospf request-queue
4-25
display ospf retrans-queue
4-26
display ospf routing
4-26
display ospf vlink
4-27
display packet-drop
1-12
display packet-filter
25-ACL Command
1-5
display patch-information
3-6
display pim bsr-info
3-4
display pim interface
3-4
display pim neighbor
3-5
display pim routing-table
3-6
display pim rp-info
3-8
display poe interface
1-1
display poe interface power
1-3
display poe powersupply
1-4
display poe temperature-protection
1-5
display poe-profile
2-2
display port
04-VLAN Command
1-9
display port vlan-vpn
40-VLAN-VPN Command
1-1
display port-mac
1-4
display port-security
1-3
display power
3-7
display protocol-priority
1-2
display protocol-vlan interface
04-VLAN Command
1-15
display protocol-vlan vlan
04-VLAN Command
1-16
display public-key local
35-SSH Command
1-1
display public-key peer
35-SSH Command
1-2
display qos cos-local-precedence-map
1-3
display qos-interface all
1-4
display qos-interface line-rate
1-6
display qos-interface mirrored-to
1-7
display qos-interface traffic-limit
1-7
display qos-interface traffic-priority
1-8
display qos-interface traffic-redirect
1-9
display qos-interface traffic-remark-vlanid
1-9
display qos-interface traffic-statistic
1-10
display qos-profile
2-2
display queue-scheduler
1-11
display radius scheme
19-AAA Command
1-31
display radius statistics
19-AAA Command
1-33
display resilient-arp
23-ARP Command
3-1
display rip
3-2
display rip interface
3-3
display rip routing
3-4
display rmon alarm
33-SNMP-RMON Command
2-1
display rmon event
2-2
display rmon eventlog
2-3
display rmon history
2-4
display rmon prialarm
2-5
display rmon statistics
2-7
display route-policy
5-3
display router id
4-7
display rsa local-key-pair public
35-SSH Command
1-4
display rsa peer-public-key
35-SSH Command
1-5
display saved-configuration
1-6
display schedule reboot
3-7
display sftp source-ip
1-29
display smart-link flush
1-1
display smart-link group
1-2
display snmp-agent
1-1
display snmp-agent community
1-2
display snmp-agent group
1-3
display snmp-agent mib-view
1-4
display snmp-agent statistics
1-5
display snmp-agent sys-info
1-8
display snmp-agent trap-list
1-9
display snmp-agent usm-user
1-10
display ssh server
35-SSH Command
1-6
display ssh server-info
35-SSH Command
1-7
display ssh user-information
35-SSH Command
1-8
display ssh2 source-ip
35-SSH Command
1-9
display ssh-server source-ip
35-SSH Command
1-9
display startup
1-9
display stop-accounting-buffer
19-AAA Command
1-34
19-AAA Command
1-57
display storm-constrain
1-13
display stp
15-MSTP Command
1-3
display stp abnormalport
15-MSTP Command
1-7
display stp portdown
15-MSTP Command
1-8
display stp region-configuration
15-MSTP Command
1-8
display stp root
15-MSTP Command
1-9
display system-guard ip state
4-1
display system-guard ip-record
4-2
display system-guard l3err state
4-2
display system-guard tcn state
4-3
display tcp ipv6 statistics
1-14
display tcp ipv6 status
1-16
display tcp statistics
2-10
display tcp status
2-12
display telnet source-ip
02-Login Command
1-6
display telnet-server source-ip
02-Login Command
1-5
display tftp source-ip
2-1
display this
1-10
display time-range
25-ACL Command
1-6
display transceiver alarm interface
3-8
display transceiver diagnosis interface
3-11
display transceiver interface
3-12
display transceiver manuinfo interface
3-13
display trapbuffer
1-5
display udp ipv6 statistics
1-17
display udp statistics
2-13
display udp-helper server
32-UDP Helper Command
1-1
display unit
1-14
display user-interface
02-Login Command
1-6
display users
02-Login Command
1-9
display version
1-7
display vlan
04-VLAN Command
1-3
display vlan
06-Voice VLAN Command
1-3
display voice vlan error-info
1-1
display voice vlan oui
1-1
display voice vlan status
1-2
display vrrp
22-VRRP Command
1-1
display vrrp statistics
22-VRRP Command
1-3
display web package
1-21
display web users
02-Login Command
1-9
display web-authentication configuration
20-Web Authentication Command
1-1
display web-authentication connection
1-2
display webcache
27-Web Cache Redirection Command
1-1
dldp
12-DLDP Command
1-2
dldp authentication-mode
12-DLDP Command
1-3
dldp delaydown-timer
12-DLDP Command
1-7
dldp interval
12-DLDP Command
1-4
dldp reset
12-DLDP Command
1-5
dldp unidirectional-shutdown
12-DLDP Command
1-5
dldp work-mode
12-DLDP Command
1-6
dns domain
43-DNS Command
1-4
dns resolve
43-DNS Command
1-5
dns resolve-target
41-HWPing Command
1-11
dns server
43-DNS Command
1-5
dns server ipv6
1-18
dns-list
24-DHCP Command
1-30
dns-server
41-HWPing Command
1-10
domain
19-AAA Command
1-13
domain delimiter
19-AAA Command
1-14
domain-name
24-DHCP Command
1-30
dot1x
1-4
dot1x authentication-method
1-5
dot1x dhcp-launch
1-6
dot1x free-ip
2-1
dot1x guest-vlan
1-7
dot1x handshake
1-8
dot1x handshake secure
1-9
dot1x max-user
1-10
dot1x port-control
1-11
dot1x port-method
1-12
dot1x quiet-period
1-13
dot1x re-authenticate
1-15
dot1x retry
1-13
dot1x retry-version-max
1-14
dot1x supp-proxy-check
1-16
dot1x timer
1-17
dot1x timer acl-timeout
2-2
dot1x timer reauth-period
1-19
dot1x url
2-2
dot1x version-check
1-20
duplex
1-15
E
enable log updown
1-16
enable snmp trap updown
1-11
execute
1-6
exit
1-29
expired
24-DHCP Command
1-31
F
fabric member-auto-update software enable
1-8
fabric save-unit-id
1-9
fabric-port enable
1-11
file prompt
1-7
filename
41-HWPing Command
1-11
filter-policy export
3-5
4-29
filter-policy import
3-6
4-30
fixdisk
1-8
flow interval
1-18
flow-control
1-17
flush enable control-vlan
1-3
format
1-9
free user-interface
02-Login Command
1-10
free web-users
02-Login Command
2-1
frequency
41-HWPing Command
1-12
ftm fabric-vlan
1-12
ftp
1-13
ftp { cluster | remote-server } source-interface
1-13
ftp { cluster | remote-server } source-ip
1-14
ftp cluster
30-Cluster Command
1-27
ftp disconnect
1-3
ftp server enable
1-4
ftp source-interface
1-15
ftp source-ip
1-15
ftp timeout
1-5
ftp-operation
41-HWPing Command
1-13
ftp-server
30-Cluster Command
1-28
ftp-server source-interface
1-6
1-6
G
garp timer
07-GVRP Command
1-3
garp timer leaveall
07-GVRP Command
1-4
gateway-list
24-DHCP Command
1-32
get
1-16
get
1-30
giant-frame statistics enable
1-18
gratuitous-arp period-resending enable
23-ARP Command
1-12
gratuitous-arp-learning enable
23-ARP Command
1-13
gvrp
07-GVRP Command
1-7
gvrp registration
07-GVRP Command
1-8
H
habp enable
3-3
habp server vlan
3-3
habp timer
3-4
header
02-Login Command
1-11
help
1-30
history-command max-size
02-Login Command
1-13
history-records
41-HWPing Command
1-14
holdtime
30-Cluster Command
1-29
host-route
3-7
http-operation
41-HWPing Command
1-14
http-string
41-HWPing Command
1-15
hwping
41-HWPing Command
1-16
hwping-agent enable
41-HWPing Command
1-16
hwping-server enable
41-HWPing Command
1-27
hwping-server tcpconnect
41-HWPing Command
1-28
hwping-server udpecho
41-HWPing Command
1-28
hwtacacs nas-ip
19-AAA Command
1-58
hwtacacs scheme
19-AAA Command
1-58
I
icmp redirect send
2-14
icmp unreach send
2-15
idle-cut
19-AAA Command
1-15
idle-timeout
02-Login Command
1-13
if-match { acl | ip-prefix }
5-4
if-match cost
5-4
if-match interface
5-5
if-match ip next-hop
5-6
if-match tag
5-6
igmp enable
2-3
igmp group-limit
2-4
igmp group-policy
2-5
igmp group-policy vlan
2-6
igmp host-join
5-16
igmp host-join port
2-7
igmp host-join port
5-15
igmp host-join vlan
2-8
igmp lastmember-queryinterval
2-8
igmp max-response-time
2-9
igmp proxy
2-9
igmp robust-count
2-10
igmp timer other-querier-present
2-11
igmp timer query
2-12
igmp version
2-12
igmp-snooping
5-4
igmp-snooping fast-leave
5-5
igmp-snooping general-query source-ip
5-6
igmp-snooping group-limit
5-7
igmp-snooping group-policy
5-8
igmp-snooping host-aging-time
5-10
igmp-snooping max-response-time
5-10
igmp-snooping nonflooding-enable
5-11
igmp-snooping querier
5-12
igmp-snooping query-interval
5-13
igmp-snooping router-aging-time
5-13
igmp-snooping version
5-14
igmp-snooping vlan-mapping
5-15
import-route
3-8
import-route
4-31
import-source
4-7
info-center channel name
1-6
info-center console channel
1-7
info-center enable
1-8
info-center logbuffer
1-8
info-center loghost
1-9
info-center loghost source
1-10
info-center monitor channel
1-10
info-center snmp channel
1-11
info-center source
1-12
info-center switch-on
1-15
info-center synchronous
1-14
info-center timestamp
1-16
info-center timestamp loghost
1-16
info-center timestamp utc
1-17
info-center trapbuffer
1-18
instance
15-MSTP Command
1-10
interface
1-19
04-VLAN Command
1-5
ip address
1-4
ip address bootp-alloc
24-DHCP Command
5-4
ip address dhcp-alloc
24-DHCP Command
5-2
ip check source ip-address
24-DHCP Command
3-9
ip forward-broadcast
2-15
ip host
43-DNS Command
1-6
ip http acl
02-Login Command
2-2
ip http shutdown
02-Login Command
1-14
ip ip-prefix
5-7
ip route-static
2-1
ip route-static detect-group
1-3
24-DHCP Command
3-10
ip-pool
30-Cluster Command
1-30
ipv6 address
1-19
ipv6 address auto link-local
1-19
ipv6 address eui-64
1-20
ipv6 address link-local
1-22
ipv6 host
1-22
ipv6 icmp-error
1-23
ipv6 nd dad attempts
1-24
ipv6 nd hop-limit
1-24
ipv6 nd ns retrans-timer
1-25
ipv6 nd nud reachable-time
1-25
ipv6 neighbor
1-26
ipv6 neighbors max-learning-num
1-27
ipv6 route-static
1-27
irf-fabric authentication-mode
1-12
J
jitter-interval
41-HWPing Command
1-17
jitter-packetnum
41-HWPing Command
1-17
jumboframe enable
1-20
K
key
19-AAA Command
1-35
key
19-AAA Command
1-59
L
lacp enable
1-5
lacp port-priority
1-5
lacp system-priority
1-6
lcd
1-17
level
19-AAA Command
1-16
line-rate
1-11
link-aggregation group
1-3
2-1
link-aggregation group description
1-6
link-aggregation group mode
1-7
link-delay
1-20
local-server
19-AAA Command
1-36
local-server nas-ip
19-AAA Command
1-37
local-user
19-AAA Command
1-17
local-user password-display-mode
19-AAA Command
1-18
lock
02-Login Command
1-15
logging-host
30-Cluster Command
1-31
log-peer-change
4-32
loopback
1-21
loopback-detection control enable
1-22
loopback-detection enable
1-23
loopback-detection interval-time
1-24
loopback-detection per-vlan enable
1-24
ls
1-17
ls
1-31
M
mac-address
1-4
mac-address aging destination-hit enable
1-5
mac-address max-mac-count
1-6
mac-address multicast interface
1-8
mac-address multicast vlan
1-9
1-5
mac-address timer
1-7
mac-address-mapping
40-VLAN-VPN Command
2-1
mac-authentication
1-4
mac-authentication authmode usernameasmacaddress
1-6
mac-authentication authmode usernamefixed
1-6
mac-authentication authpassword
1-7
mac-authentication authusername
1-8
mac-authentication domain
1-8
mac-authentication guest-vlan
1-10
mac-authentication interface
1-5
mac-authentication max-auth-num
1-11
mac-authentication timer
1-9
mac-authentication timer guest-vlan-reauth
1-12
management-vlan
30-Cluster Command
1-31
mdi
1-25
memory
6-3
memory auto-establish disable
6-4
memory auto-establish enable
6-4
messenger
19-AAA Command
1-18
mirrored-to
1-12
mirroring-group
1-4
mirroring-group mirroring-port
1-4
mirroring-group monitor-port
1-6
mirroring-group reflector-port
1-7
mirroring-group remote-probe vlan
1-8
mirroring-port
1-8
mkdir
1-9
mkdir
1-18
mkdir
1-31
monitor-link group
2-2
monitor-port
1-9
more
1-10
move
1-11
msdp
4-7
msdp-tracert
4-8
mtracert
1-9
multicast route-limit
1-11
multicast routing-enable
1-12
multicast static-group interface
5-17
multicast static-group vlan
5-18
multicast static-router-port
5-19
multicast static-router-port vlan
5-20
multicast storing-enable
1-12
multicast storing-packet
1-13
1-13
multicast-suppression
1-25
multi-path-number
4-32
N
name
04-VLAN Command
1-5
name
19-AAA Command
1-19
nas-ip
19-AAA Command
1-38
nas-ip
19-AAA Command
1-60
nbns-list
24-DHCP Command
1-33
ndp enable
30-Cluster Command
1-2
ndp timer aging
30-Cluster Command
1-3
ndp timer hello
30-Cluster Command
1-4
netbios-type
24-DHCP Command
1-33
network
3-9
network
4-33
network
24-DHCP Command
1-34
nm-interface Vlan-interface
30-Cluster Command
1-32
nslookup type
43-DNS Command
1-6
nssa
4-33
ntdp enable
30-Cluster Command
1-8
ntdp explore
30-Cluster Command
1-9
ntdp hop
30-Cluster Command
1-9
ntdp timer
30-Cluster Command
1-10
ntdp timer hop-delay
30-Cluster Command
1-11
ntdp timer port-delay
30-Cluster Command
1-12
ntp-service access
34-NTP Command
1-5
ntp-service authentication enable
34-NTP Command
1-6
ntp-service authentication-keyid
34-NTP Command
1-7
ntp-service broadcast-client
34-NTP Command
1-7
ntp-service broadcast-server
34-NTP Command
1-8
ntp-service in-interface disable
34-NTP Command
1-8
ntp-service max-dynamic-sessions
34-NTP Command
1-9
ntp-service multicast-client
34-NTP Command
1-10
ntp-service multicast-server
34-NTP Command
1-10
ntp-service reliable authentication-keyid
34-NTP Command
1-11
ntp-service source-interface
34-NTP Command
1-12
ntp-service unicast-peer
34-NTP Command
1-12
ntp-service unicast-server
34-NTP Command
1-13
O
open
1-19
option
1-4
option
24-DHCP Command
1-35
originating-rp
4-10
ospf
4-35
ospf authentication-mode
4-36
ospf cost
4-37
ospf dr-priority
4-37
ospf mib-binding
4-38
ospf mtu-enable
4-39
ospf network-type
4-39
ospf timer dead
4-41
ospf timer hello
4-41
ospf timer poll
4-42
ospf timer retransmit
4-43
ospf trans-delay
4-43
P
packet-filter
25-ACL Command
1-7
packet-filter
2-3
packet-filter vlan
25-ACL Command
1-8
parity
02-Login Command
1-16
passive
1-19
password
19-AAA Command
1-20
password
41-HWPing Command
1-18
patch activate
3-14
patch delete
3-14
patch load
3-15
patch run
3-16
peer
3-9
peer
4-44
peer connect-interface
4-10
peer description
4-11
peer mesh-group
4-12
peer minimum-ttl
4-12
peer request-sa-enable
4-13
peer sa-cache-maximum
4-13
peer sa-policy
4-14
peer sa-request-policy
4-15
peer-public-key end
35-SSH Command
1-10
pim
3-9
pim bsr-boundary
3-9
pim dm
3-10
pim neighbor-limit
3-11
pim neighbor-policy
3-11
pim sm
3-12
pim timer hello
3-13
ping
2-1
ping ipv6
2-1
poe enable
1-5
poe legacy enable
1-6
poe max-power
1-7
poe mode
1-7
poe power-management
1-8
poe priority
1-9
1-9
poe update
1-10
poe-profile
2-3
port
04-VLAN Command
1-9
port
1-4
port
2-3
port access vlan
04-VLAN Command
1-10
port hybrid protocol-vlan vlan
04-VLAN Command
1-17
port hybrid pvid vlan
04-VLAN Command
1-11
port hybrid vlan
04-VLAN Command
1-11
port isolate
1-1
port link-aggregation group
1-8
port link-type
04-VLAN Command
1-12
port link-type irf-fabric
1-13
port monitor-link group
2-4
port smart-link group
1-5
port trunk permit vlan
04-VLAN Command
1-13
port trunk pvid vlan
04-VLAN Command
1-14
port-mac
1-8
port-security authorization ignore
1-9
port-security enable
1-6
port-security intrusion-mode
1-7
port-security max-mac-count
1-10
port-security ntk-mode
1-11
port-security oui
1-12
port-security port-mode
1-13
port-security timer disableport
1-16
port-security trap
1-17
preference
3-10
preference
4-45
primary accounting
19-AAA Command
1-39
primary accounting
19-AAA Command
1-60
primary authentication
19-AAA Command
1-39
19-AAA Command
1-61
primary authorization
19-AAA Command
1-62
priority
1-14
priority trust
1-15
probe-failtimes
41-HWPing Command
1-19
protocol inbound
02-Login Command
1-16
protocol inbound
35-SSH Command
1-10
protocol-priority protocol-type
1-16
protocol-vlan
04-VLAN Command
1-18
public-key local create
35-SSH Command
1-11
public-key local destroy
35-SSH Command
1-13
public-key local export dsa
35-SSH Command
1-15
public-key local export rsa
35-SSH Command
1-14
public-key peer
35-SSH Command
1-17
public-key peer import sshkey
35-SSH Command
1-17
public-key-code begin
35-SSH Command
1-18
public-key-code end
35-SSH Command
1-19
put
1-20
put
1-32
pwd
1-11
pwd
1-21
pwd
1-32
Q
1-18
qos-profile
2-4
qos-profile port-based
2-5
queue-scheduler
1-19
1-21
1-33
1-3
R
radius client
19-AAA Command
1-40
radius nas-ip
19-AAA Command
1-41
radius scheme
19-AAA Command
1-42
radius trap
19-AAA Command
1-43
radius-scheme
19-AAA Command
1-21
raw-vlan-id inbound
40-VLAN-VPN Command
2-2
reboot
3-16
reboot member
30-Cluster Command
1-33
region-name
15-MSTP Command
1-11
register-policy
3-13
remotehelp
1-22
remote-probe vlan enable
1-10
remove
1-33
rename
1-12
rename
1-22
rename
1-34
reset
3-11
reset arp
23-ARP Command
1-13
reset counters interface
1-26
reset dhcp server conflict
24-DHCP Command
1-36
reset dhcp server ip-in-use
24-DHCP Command
1-36
reset dhcp server statistics
24-DHCP Command
1-37
reset dhcp-server
24-DHCP Command
2-10
reset dns dynamic-host
43-DNS Command
1-7
reset dns ipv6 dynamic-host
1-28
reset dot1x statistics
1-20
reset ftm statistics
1-14
reset garp statistics
07-GVRP Command
1-5
reset hwtacacs statistics
19-AAA Command
1-63
reset igmp group
2-13
reset igmp-snooping statistics
5-20
reset ip routing-table statistics protocol
1-12
reset ip statistics
2-16
reset ipv6 neighbors
1-29
reset ipv6 statistics
1-29
reset lacp statistics
1-8
reset logbuffer
1-19
reset mac-authentication
1-9
reset msdp peer
4-16
reset msdp sa-cache
4-16
reset msdp statistics
4-17
reset multicast forwarding-table
1-14
reset multicast routing-table
1-15
reset ndp statistics
30-Cluster Command
1-5
reset ospf
4-45
reset ospf statistics
4-46
reset packet-drop interface
1-27
reset pim neighbor
3-14
reset pim routing-table
3-15
reset radius statistics
19-AAA Command
1-44
reset recycle-bin
1-12
reset saved-configuration
1-11
reset smart-link packets counter
1-6
reset stop-accounting-buffer
19-AAA Command
1-44
19-AAA Command
1-63
reset stp
15-MSTP Command
1-11
reset tcp ipv6 statistics
1-30
reset tcp statistics
2-16
reset traffic-statistic
1-21
reset trapbuffer
1-19
reset udp ipv6 statistics
1-30
reset udp statistics
2-17
reset udp-helper packet
1-1
reset vrrp statistics
22-VRRP Command
1-5
resilient-arp enable
23-ARP Command
3-2
resilient-arp interface vlan-interface
23-ARP Command
3-2
restore startup-configuration
1-23
retry
1-5
retry
19-AAA Command
1-45
retry realtime-accounting
19-AAA Command
1-45
retry stop-accounting
19-AAA Command
1-47
19-AAA Command
1-64
return
1-4
revision-level
15-MSTP Command
1-12
rip
3-11
rip authentication-mode
3-12
rip input
3-13
rip metricin
3-14
rip metricout
3-14
rip output
3-15
rip split-horizon
3-15
rip version
3-16
rip work
3-17
rmdir
1-15
rmdir
1-23
rmdir
1-34
rmon alarm
2-8
rmon event
2-10
rmon history
2-11
rmon prialarm
2-12
rmon statistics
2-14
route-policy
5-8
router id
4-46
rsa local-key-pair create
35-SSH Command
1-20
rsa local-key-pair destroy
35-SSH Command
1-21
rsa peer-public-key
35-SSH Command
1-22
rsa peer-public-key import sshkey
35-SSH Command
1-23
rule (for Advanced ACLs)
25-ACL Command
1-11
rule (for Basic ACLs)
25-ACL Command
1-9
rule (for Layer 2 ACLs)
25-ACL Command
1-18
rule (for user-defined ACLs)
25-ACL Command
1-20
rule comment
25-ACL Command
1-23
S
save
1-12
schedule reboot at
3-17
schedule reboot delay
3-18
schedule reboot regularity
3-19
scheme
19-AAA Command
1-21
screen-length
02-Login Command
1-17
secondary accounting
19-AAA Command
1-47
19-AAA Command
1-64
secondary authentication
19-AAA Command
1-48
19-AAA Command
1-65
secondary authorization
19-AAA Command
1-66
security-policy-server
19-AAA Command
2-1
self-service-url
19-AAA Command
1-22
send
02-Login Command
1-18
send-trap
41-HWPing Command
1-20
server-type
19-AAA Command
1-49
service-type
02-Login Command
1-19
service-type
19-AAA Command
1-23
service-type multicast
5-21
set authentication password
02-Login Command
1-20
set unit name
1-14
sftp
1-35
sftp server enable
1-24
sftp source-interface
1-36
sftp source-ip
1-37
sftp timeout
1-25
shell
02-Login Command
1-21
shutdown
04-VLAN Command
1-6
shutdown
1-27
shutdown
4-17
silent-interface
4-47
smart-link flush enable
1-6
smart-link group
1-7
smart-link group
2-5
snmp-agent
1-12
snmp-agent calculate-password
1-12
02-Login Command
2-2
1-13
snmp-agent group
02-Login Command
2-3
snmp-agent group
1-14
snmp-agent local-engineid
1-16
snmp-agent log
1-17
snmp-agent mib-view
1-18
snmp-agent packet max-size
1-19
snmp-agent sys-info
1-20
snmp-agent target-host
1-21
snmp-agent trap enable
1-22
snmp-agent trap enable ospf
4-48
snmp-agent trap ifmib
1-23
snmp-agent trap life
1-24
snmp-agent trap queue-size
1-24
snmp-agent trap source
1-25
snmp-agent usm-user
02-Login Command
2-4
snmp-agent usm-user { v1 | v2c }
1-26
snmp-agent usm-user v3
1-27
snmp-host
30-Cluster Command
1-33
source-interface
41-HWPing Command
1-20
source-ip
41-HWPing Command
1-21
source-lifetime
3-17
source-policy
3-17
source-port
41-HWPing Command
1-22
speed
02-Login Command
1-22
speed
1-28
speed auto
1-29
spf-schedule-interval
4-49
spt-switch-threshold
3-15
ssh authentication-type default
35-SSH Command
1-24
ssh client assign
35-SSH Command
1-25
ssh client first-time enable
35-SSH Command
1-26
ssh server authentication-retries
35-SSH Command
1-27
ssh server compatible-ssh1x enable
35-SSH Command
1-27
ssh server rekey-interval
35-SSH Command
1-28
ssh server timeout
35-SSH Command
1-29
ssh user
35-SSH Command
1-29
ssh user assign
35-SSH Command
1-30
ssh user authentication-type
35-SSH Command
1-31
ssh user service-type
35-SSH Command
1-33
ssh2
35-SSH Command
1-33
ssh2 source-interface
35-SSH Command
1-35
ssh2 source-ip
35-SSH Command
1-35
ssh-server source-interface
35-SSH Command
1-36
35-SSH Command
1-37
standby detect-group
1-6
startup bootrom-access enable
1-21
startup saved-configuration
1-14
state
19-AAA Command
1-24
state
19-AAA Command
1-49
static-bind client-identifier
24-DHCP Command
1-37
static-bind ip-address
24-DHCP Command
1-38
static-bind mac-address
24-DHCP Command
1-39
static-rp
3-18
static-rpf-peer
4-18
stop-accounting-buffer enable
19-AAA Command
1-50
stopbits
02-Login Command
1-22
storm-constrain
1-30
storm-constrain control
1-31
storm-constrain enable
1-32
storm-constrain interval
1-32
stp
15-MSTP Command
1-13
stp bpdu-protection
15-MSTP Command
1-13
stp bridge-diameter
15-MSTP Command
1-14
stp compliance
15-MSTP Command
1-15
stp config-digest-snooping
15-MSTP Command
1-16
stp cost
15-MSTP Command
1-18
stp dot1d-trap
15-MSTP Command
1-19
stp edged-port
15-MSTP Command
1-19
stp interface
15-MSTP Command
1-20
stp interface compliance
15-MSTP Command
1-21
stp interface config-digest-snooping
15-MSTP Command
1-22
stp interface cost
15-MSTP Command
1-24
stp interface edged-port
15-MSTP Command
1-25
stp interface loop-protection
15-MSTP Command
1-26
stp interface mcheck
15-MSTP Command
1-27
stp interface no-agreement-check
15-MSTP Command
1-28
stp interface point-to-point
15-MSTP Command
1-29
stp interface port priority
15-MSTP Command
1-30
stp interface root-protection
15-MSTP Command
1-31
stp interface transmit-limit
15-MSTP Command
1-32
stp loop-protection
15-MSTP Command
1-32
stp max-hops
15-MSTP Command
1-33
stp mcheck
15-MSTP Command
1-34
stp mode
15-MSTP Command
1-35
stp no-agreement-check
15-MSTP Command
1-35
stp pathcost-standard
15-MSTP Command
1-36
stp point-to-point
15-MSTP Command
1-38
stp port priority
15-MSTP Command
1-39
stp portlog
15-MSTP Command
1-39
stp portlog all
15-MSTP Command
1-40
stp priority
15-MSTP Command
1-41
15-MSTP Command
1-41
stp root primary
15-MSTP Command
1-42
stp root secondary
15-MSTP Command
1-43
stp root-protection
15-MSTP Command
1-44
stp tc-protection
15-MSTP Command
1-45
stp tc-protection threshold
15-MSTP Command
1-45
stp timer forward-delay
15-MSTP Command
1-46
stp timer hello
15-MSTP Command
1-47
stp timer max-age
15-MSTP Command
1-48
stp timer-factor
15-MSTP Command
1-49
stp transmit-limit
15-MSTP Command
1-50
stub
4-49
summary
3-18
super
01-CLI Command
1-4
super authentication-mode
01-CLI Command
1-5
super password
01-CLI Command
1-5
sysname
1-15
sysname
1-5
system-guard ip detect-maxnum
4-3
system-guard ip detect-threshold
4-4
system-guard ip enable
4-5
system-guard l3err enable
4-6
system-guard tcn enable
4-7
system-guard tcn rate-threshold
4-7
system-monitor enable
3-20
1-5
T
tcp ipv6 timer fin-timeout
1-30
tcp ipv6 timer syn-timeout
1-31
tcp ipv6 window
1-31
tcp timer fin-timeout
2-17
tcp timer syn-timeout
2-18
tcp window
2-18
telnet
02-Login Command
1-23
telnet ipv6
02-Login Command
1-24
telnet ipv6
2-3
telnet source-interface
02-Login Command
1-25
telnet source-ip
02-Login Command
1-25
telnet-server source-interface
02-Login Command
1-26
02-Login Command
1-26
terminal debugging
1-20
terminal debugging
1-9
terminal logging
1-20
terminal monitor
1-21
terminal trapping
1-21
test-enable
41-HWPing Command
1-24
test-failtimes
41-HWPing Command
1-24
test-type
41-HWPing Command
1-23
tftp { ascii | binary }
2-1
tftp get
30-Cluster Command
1-34
tftp get
2-2
tftp ipv6
2-3
tftp put
30-Cluster Command
1-35
tftp put
2-3
tftp source-interface
2-5
tftp source-ip
2-6
tftp tftp-server source-interface
2-4
tftp tftp-server source-ip
2-5
tftp-server
30-Cluster Command
1-36
tftp-server acl
2-7
24-DHCP Command
1-40
24-DHCP Command
1-40
timeout
41-HWPing Command
1-25
timer
19-AAA Command
1-51
timer
30-Cluster Command
1-36
timer loop
1-7
timer quiet
19-AAA Command
1-52
timer quiet
19-AAA Command
1-67
timer realtime-accounting
19-AAA Command
1-53
19-AAA Command
1-67
timer response-timeout
19-AAA Command
1-54
19-AAA Command
1-68
timer retry
4-19
timer wait
1-7
time-range
25-ACL Command
1-24
timers
3-19
topology accept
30-Cluster Command
1-44
topology restore-from
30-Cluster Command
1-45
topology save-to
30-Cluster Command
1-46
tos
41-HWPing Command
1-25
tracemac
30-Cluster Command
1-37
tracert
2-3
tracert ipv6
2-4
traffic-limit
1-22
traffic-limit
2-5
traffic-priority
1-25
traffic-priority
2-7
traffic-priority vlan
1-27
traffic-redirect
1-28
1-29
traffic-share-across-interface
3-19
traffic-statistic
1-30
U
udp-helper enable
1-2
udp-helper port
1-3
udp-helper server
1-4
undelete
1-15
unicast-suppression
1-33
unknown-multicast drop enable
1-16
update fabric
1-11
update fabric
1-16
update fabric
3-21
user
1-23
user privilege level
02-Login Command
1-28
user-interface
02-Login Command
1-27
username
41-HWPing Command
1-26
user-name-format
19-AAA Command
1-54
user-name-format
19-AAA Command
1-69
V
verbose
1-24
virtual-cable-test
1-34
vlan
04-VLAN Command
1-7
vlan-assignment-mode
19-AAA Command
1-25
vlan-mapping modulo
15-MSTP Command
1-50
vlan-vpn enable
40-VLAN-VPN Command
1-2
vlan-vpn inner-cos-trust
40-VLAN-VPN Command
1-3
vlan-vpn priority
40-VLAN-VPN Command
1-3
vlan-vpn tpid
40-VLAN-VPN Command
1-5
vlan-vpn tunnel
15-MSTP Command
1-51
vlan-vpn vid
40-VLAN-VPN Command
2-3
vlink-peer
4-50
voice vlan
1-4
voice vlan aging
1-5
voice vlan enable
1-6
voice vlan legacy
1-6
voice vlan mac-address
1-7
voice vlan mode
1-8
voice vlan security enable
1-8
voice-config
24-DHCP Command
1-41
vrrp method
22-VRRP Command
1-5
vrrp ping-enable
22-VRRP Command
1-6
vrrp vlan-interface vrid track
22-VRRP Command
1-7
vrrp vrid authentication-mode
22-VRRP Command
1-8
vrrp vrid preempt-mode
22-VRRP Command
1-9
vrrp vrid priority
22-VRRP Command
1-10
vrrp vrid timer advertise
22-VRRP Command
1-10
vrrp vrid track detect-group
1-8
22-VRRP Command
1-12
vrrp vrid track interface
22-VRRP Command
1-11
vrrp vrid virtual-ip
22-VRRP Command
1-13
W
web-authentication cut connection
1-3
web-authentication enable
1-3
web-authentication free-ip
1-4
web-authentication free-user
1-5
web-authentication max-connection
1-6
web-authentication select method
1-6
web-authentication timer idle-cut
1-7
web-authentication web-server
1-8
webcache address
1-2
webcache redirect-vlan
1-4
wred
1-31
X
xmodem get
3-22
Y
Z
