H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
41-HWPing Command
41-HWPing Command 160.69 KB
l          The configuration of eight test types, including DHCP, FTP, HTTP, DNS, SNMP, Jitter, TCP and UDP tests is added. For the detailed configuration of these tests, refer to the introduction in this chapter.
l          The configuration of the maximum number of history records that can be saved in a test group is added. For the detailed configuration, refer to section history-records.
HWPing Client Commands
count
count times
undo count
View
HWPing test group view
times: Number of probes in each HWPing test. The times argument ranges from 1 to 15.
Use the count command to set the number of probes in each HWPing test.
Use the undo count command to restore the default.
For tests except jitter test, only one packet is sent in a probe. In a jitter test, you can use the jitter-packetnum command to set the number of packets to be sent in a probe.
By default, the number of probes in each test is 1.
Related commands: frequency.
# Set the number of probes made in an ICMP test to 10.
System View: return to User View with Ctrl+Z
[Sysname] hwping administrator icmp
[Sysname-hwping-administrator-icmp] test-type icmp
[Sysname-hwping-administrator-icmp] count 10
datasize
datasize size
undo datasize
View
size: Size of a test packet in bytes. The value range varies with the test types.
Table 1-1 Value range of the HWPing test packets
Test type
Value range (in bytes)
Default (in bytes)
Jitter
68 to 8100
68
ICMP
4 to 8100
56
Udpprivate
4 to 8100
100
Udppublic
4 to 8100
100
Use the datasize command to configure the size of a test packet in a test.
Use the undo datasize command to restore the default.
# Set the size of ICMP test packets to 50 bytes.
[Sysname-hwping-administrator-icmp] datasize 50
destination-ip
destination-ip ip-address
undo destination-ip
View
ip-address: Destination IP address of a HWPing (pronounced Hua’Wei Ping) test.
Use the destination-ip command to configure a destination IP address of an HWPing test.
Use the undo destination-ip command to remove the configured destination IP address.
By default, no destination IP address is configured for an HWPing test.
Related commands: destination-port.
The destination address can be an IP address or a host name in HTTP test, while in other types of tests, it must be an IP address.
# Set the destination IP address of an ICMP test to 169.254.10.3.
[Sysname-hwping-administrator-icmp] destination-ip 169.254.10.3
destination-port
destination-port port-number
undo destination-port
View
port-number: Destination port number for an HWPing test, in the range of 1 to 65535.
Use the destination-port command to configure a destination port number for an HWPing test.
Use the undo destination-port command to remove the configured destination port number.
By default, no destination port number is configured for a test.
Related commands: destination-ip.
l          The destination-port command has effect on jitter, TCP-Private, and UDP-Private tests only.
l          It is not recommended to perform a TCP, UDP, or jitter test on a well-known port (ports with a number ranging from 1 to 1023) or on a port with a port number greater than 50000. Otherwise, the HWPing test will fail or the corresponding service of the well-known port will become unavailable.
# Set the destination port number for a tcpprivate test to 9000.
[Sysname] hwping administrator tcp
[Sysname-hwping-administrator-tcp] test-type tcpprivate
[Sysname-hwping-administrator-tcp] destination-port 9000
display hwping
display hwping { results | history } [ administrator-name operation-tag ]
View
results: Displays results of the last test.
history: Displays the history records of tests.
administrator-name: Name of the administrator who created the HWPing test operation, a string of 1 to 32 characters.
operation-tag: Operation tag, a string of 1 to 32 characters.
Use the display hwping command to display the result of the last HWPing test or the history of HWPing tests.
Without administrator-name test-operation-tag specified, the command displays the results of all test groups; without administrator-name test-operation-tag specified, the command displays the results of the specified test group.
Related commands: test-enable.
# Display the test results of the test group with administrator name administrator, and operation tag icmp.
[Sysname-hwping-administrator-icmp] display hwping results administrator icmp
  HWPing entry(admin administrator, tag icmp) test result:
      Destinationip address:10.2.2.2
      Send operation times: 10             Receive response times: 10
      Min/Max/Average Round Trip Time: 1/2/1
      Square-Sum of Round Trip Time: 13
      Last succeeded test time: 2004-11-25 16:28:55.0
  Extend result:
      SD Maximal delay: 0                  DS Maximal delay: 0
      Packet lost in test: 0%
      Disconnect operation number:0        Operation timeout number:0
      System busy operation number:0       Connection fail number:0
      Operation sequence errors:0          Drop operation number:0
      Other operation errors:0
Table 1-2 Description on the fields of the display hwping result command
Filed
Destination ip address
Number of probes made
Number of received response packets
Minimum/maximum/average roundtrip time, in milliseconds
Square sum of roundtrip time
Completion time of the last successful test
SD Maximal delay
Maximum delay from the source to the destination
DS Maximal delay
Maximum delay from the destination to the source
Packet lost in test
Average packet loss ratio
Number of times the test was disconnected by the remote end
Number of times the test failed because the system was busy
Number of out-of-sequence packets received
Number of other errors
Number of time-out occurrences in a test
Number of failures to connect with the remote end
Number of system resource allocation failures
# Display the history records of HWPing tests.
[Sysname-hwping-administrator-icmp] display hwping history administrator icmp
  HWPing entry(admin administrator, tag icmp) history record:
    Index     Response    Status      LastRC      Time
        1            1         1           0    2004-11-25 16:28:55.0
        2            1         1           0    2004-11-25 16:28:55.0
        3            1         1           0    2004-11-25 16:28:55.0
        4            1         1           0    2004-11-25 16:28:55.0
        5            1         1           0    2004-11-25 16:28:55.0
        6            2         1           0    2004-11-25 16:28:55.0
        7            1         1           0    2004-11-25 16:28:55.0
        8            1         1           0    2004-11-25 16:28:55.0
        9            1         1           0    2004-11-25 16:28:55.9
       10            1         1           0    2004-11-25 16:28:55.9
Table 1-3 Description on the fields of the display hwping history command
Response
Roundtrip time in the case of a successful test, timeout time in the case of test timeout, or 0 in the case of a test failure (in milliseconds)
Status
Test result values, including:
1: responseReceived: Response received
2: unknown: Unknown error.
3: internalError: System internal error
4: requestTimeOut: Request timed out
5: unknownDestinationAddress: Unknown destination address
6: noRouteToTarget: Destination unreachable
7: interfaceInactiveToTarget: Interface to destination address inactive
8: arpFailure: ARP operation failed.
9: maxConcurrentLimitReached: Maximum limit of concurrent accesses reached
10: unableToResolveDnsName: Unable to resolve DNS domain name
11: invalidHostAddress: Invalid host address
LastRC
Response code in the last ICMP response packet received. (The device does not support this field at present, so this field is always displayed as 0.)
Time
Test completion time
# Display the test results of the test group with administrator name administrator, and operation tag http.
[Sysname-hwping-administrator-http] display hwping results administrator http
  HWPing entry(admin dns, tag 1) test result:
      Destination ip address:192.168.0.73
      Send operation times: 1               Receive response times: 1
      Min/Max/Average Round Trip Time: 27/27/27
      Square-Sum of Round Trip Time: 729
      Last succeeded test time: 2000-4-2 3:45:36.8
  Extend result:
      Disconnect operation number: 0        Operation timeout number: 0
      System busy operation number: 0       Connection fail number: 0
      Operation sequence errors: 0          Drop operation number: 0
      Other operation errors: 0
    Http result:
      DNS Resolve Time: 0                  HTTP Operation Time: 7
      DNS Resolve Min Time: 0              HTTP Test Total Time: 27
      DNS Resolve Max Time: 0          HTTP Transmission Successful Times: 1
      DNS Resolve Failed Times: 0          HTTP Transmission Failed Times: 0
      DNS Resolve Timeout Times: 0        HTTP Transmission Timeout Times: 0
      TCP Connect Time: 20                 HTTP Operation Min Time: 7
      TCP Connect Min Time: 20             HTTP Operation Max Time: 7
      TCP Connect Max Time: 20
      TCP Connect Timeout Times: 0
Table 1-4 Description on the fields of the display hwping result command
DNS Resolve Time
Time used for a DNS resolution
HTTP Operation Time
Total time used to establish an HTTP connection
Minimal time used for a DNS resolution
Total time used for an HTTP test
Maximum time used for a DNS resolution
Number of successful HTTP transmissions
Number of failed DNS resolutions
Number of failed HTTP transmissions
DNS resolution timeout times
HTTP transmission timeout times
TCP Connect Time
Total time used to establish a TCP connection
Minimum time used to establish an HTTP connection
Minimum time used to establish a TCP connection
Maximum time used to establish an HTTP connection
Maximum time used to establish a TCP connection
TCP connection timeout times
# Display the test results of the test group with administrator name administrator, and operation tag Jitter.
[Sysname-hwping-administrator-Jitter] display hwping results administrator Jitter
HWPing entry(admin administrator, tag Jitter) test result:
      Destination ip address:10.2.2.2
      Send operation times: 100             Receive response times: 100
      Min/Max/Average Round Trip Time: 9/21/13
      Square-Sum of Round Trip Time: 18623
      Last succeeded test time: 2000-4-2 8:14:58.2
  Extend result:
      SD Maximal delay: 10                  DS Maximal delay: 10
    Jitter result:
      RTT Number:100
      Min Positive SD:1                    Min Positive DS:1
      Max Positive SD:6                    Max Positive DS:8
      Positive SD Number:38                Positive DS Number:25
      Positive SD Sum:85                   Positive DS Sum:42
      Positive SD average:2                Positive DS average:1
      Positive SD Square Sum:267           Positive DS Square Sum:162
      Min Negative SD:1                    Min Negative DS:1
      Max Negative SD:6                    Max Negative DS:8
      Negative SD Number:30                Negative DS Number:24
      Negative SD Sum:64                   Negative DS Sum: 41
      Negative SD average:2                Negative DS average:1
      Negative SD Square Sum:200           Negative DS Square Sum:161
      SD lost packets number:0             DS lost packet number:0
      Unkown result lost packet number:0
Table 1-5 Description on the fields of the display hwping result command
RTT Number
Min Positive SD
Minimum positive jitter delay from the source to the destination
Min Positive DS
Minimum positive jitter delay from the destination to the source
Max Positive SD
Maximum positive jitter delay from the source to the destination
Max Positive DS
Maximum positive jitter delay from the destination to the source
Positive SD Number
Number of positive jitter delays from the source to the destination
Positive DS Number
Number of positive jitter delays from the destination to the source
Positive SD Sum
Sum of positive jitter delays from the source to the destination
Positive DS Sum
Sum of positive jitter delays from the destination to the source
Positive SD average
Average of positive jitter delays from the source to the destination
Positive DS average
Average of positive jitter delays from the destination to the source
Sum of the square of positive jitter delays from the source to the destination
Sum of the square of positive jitter delays from the destination to the source
Min Negative SD
Minimum absolute value of negative jitter delays from the source to the destination
Min Negative DS
Minimum absolute value of negative jitter delays from the destination to the source
Max Negative SD
Maximum absolute value of negative jitter delays from the source to the destination
Max Negative DS
Maximum absolute value of negative jitter delays from the destination to the source
Negative SD Number
Number of negative jitter delays from the source to the destination
Negative DS Number
Number of negative jitter delays from the destination to the source
Negative SD Sum
Sum of absolute values of negative jitter delays from the source to the destination
Negative DS Sum
Sum of absolute values of negative jitter delays from the destination to the source
Negative SD average
Average of negative jitter delays from the source to the destination
Negative DS average
Average of negative jitter delays from the destination to the source
Sum of the square of negative jitter delays from the source to the destination
Sum of the square of negative jitter delays from the destination to the source
Number of lost packets from the source to the destination
Number of lost packets from the destination to the source
Unknown result lost packet number
Number of lost packets for unknown reasons
# Display the test results of the test group with administrator name administrator, and operation tag dns.
[Sysname] display hwping results administrator dns
HWPing entry(admin administrator, tag dns) test result:
      Min/Max/Average Round Trip Time: 6/10/8
      Square-Sum of Round Trip Time: 756
      Last succeeded test time: 2006-11-28 11:50:40.9
  Extend result:
    Dns result:
      DNS Resolve Current Time: 10         DNS Resolve Min Time: 6
      DNS Resolve Times: 10                DNS Resolve Max Time: 10
      DNS Resolve Timeout Times: 0         DNS Resolve Failed Times: 0
Table 1-6 Description on the fields of the display hwping result command
Time used for the current DNS resolution
Minimum time used for a DNS resolution
DNS Resolve Times
Number of DNS resolutions
The description on a specific field is available for the test results of all types of tests, so that not the description on the output information of all types of tests is provided here.
dns-server
dns-server ip-address
undo dns-server
View
ip-address: IP address to be assigned to a domain name server (DNS).
Use the dns-server command to configure the IP address of a DNS server.
Use the undo dns-server command to remove the IP address of a DNS server.
By default, no DNS server IP address is configured.
l          This command applies to DNS and HTTP tests only.
l          For an HTTP test, if configuring the destination address as the host name, you must configure the IP address of the DNS server to resolve the host name into an IP address, which is the destination IP address of this HTTP test
# Set the IP address of the DNS server to 169.254.10.5.
[Sysname] hwping administrator dns
[Sysname-hwping-administrator-dns] test-type dns
[Sysname-hwping-administrator-dns] dns-server 169.254.10.5
dns resolve-target
dns resolve-target domain-name
undo dns resolve-target
View
domain-name: Domain name to be resolved, in the range of 1 to 60 characters.
Use the dns resolve-target command to configure a domain name to be resolved.
Use the undo resolve-target command to remove a domain name to be resolved.
By default, no dns resolve-target information is configured.
This command applies to DNS tests only.
# Configure the domain name to be resolved as www.test.com.
[Sysname-hwping-administrator-dns] dns resolve-target www.test.com
filename
filename file-name
undo filename
View
file-name: Name of the file to be downloaded/uploaded in FTP tests, a string of 1 to 255 characters.
Use the filename command to specify a file to be downloaded/uploaded in FTP tests.
Use the undo filename command to remove the configured file name.
By default, no file name is configured for FTP tests.
Related commands: username, password, ftp-operation.
The filename command applies to FTP tests only.
# Specify to transmit config.txt between HWPing client and FTP server in an FTP test.
[Sysname] hwping administrator ftp
[Sysname-hwping-administrator-ftp] test-type ftp
[Sysname-hwping-administrator-ftp] filename config.txt
frequency
frequency interval
undo frequency
View
interval: Automatic test interval in seconds. It ranges from 0 to 65,535.
Use the frequency command to configure the time interval of performing automatic tests.
Use the undo frequency command to restore the default.
If interval is configured greater than 0, the system performs automatic tests at this interval.
interval defaults to 0, which means no automatic test is performed by default.
Related commands: count.
l          The frequency command does not apply to DHCP tests.
l          The frequency command supports fabric only when the test type of this test group is ICMP. With fabric enabled, you are allowed to configure the frequency command and use the display command to check your configuration, but unless the test type is ICMP, your configuration does not take effect until fabric is disabled.
# Set the automatic test interval to 10 seconds in an ICMP test.
[Sysname-hwping-administrator-icmp] frequency 10
ftp-operation
ftp-operation { get | put }
View
get: Specifies the test operation as download from the FTP server.
put: Specifies the test operation as upload to the FTP server.
Use the ftp-operation command to configure the FTP operation mode, which can be get and put.
By default, the FTP operation mode is get.
Related commands: username, password.
The ftp-operation command applies to FTP tests only.
# Set the FTP operation mode to put in an FTP test.
[Sysname-hwping-administrator-ftp] ftp-operation put
history-records
history-records number
undo history-records
View
Number: Maximum number of history records that can be saved in a test group, in the range of 0 to 50, and 50 by default.
Use the history-records command to set the maximum number of history records that can be saved in a test group.
Use the undo history-records to restore the default.
By default, up to 50 records can be saved in a test group.
# Set the maximum number of history records that can be saved to 10.
[Sysname-hwping-administrator-icmp] history-records 10
http-operation
http-operation { get | post }
View
get: Specifies the test operation to be download from the HTTP server.
post: Specifies the test operation to be uploaded to the HTTP server.
Use the http-operation command to configure the HTTP operation mode.
By default, the HTTP operation mode is get.
The http-operation command applies to HTTP tests only.
# Set the HTTP operation mode to post in an HTTP test.
[Sysname] hwping administrator http
[Sysname-hwping-administrator-http] test-type http
[Sysname-hwping-administrator-http] http-operation post
http-string
http-string string version
undo http-string
View
string: HTTP operation string used to specify the webpage to be accessed. It can consist of 1 to 255 characters.
version: HTTP version, a string of 1 to 255 characters. At present, this argument can only be HTTP/1.0, where HTTP must be capitalized.
Use the http-string command to configure the HTTP operation string and HTTP version.
Use the undo http-string command to remove the configured HTTP operation string and version.
By default, no HTTP operation string and HTTP version are configured.
Note that the http-string command applies to HTTP tests only.
Related commands: http-operation.
# Configure the webpage to be accessed by an HTTP test as /index.htm and the HTTP version as HTTP/1.0.
[Sysname-hwping-administrator-http] http-string /index.htm HTTP/1.0
hwping
hwping administrator-name operation-tag
undo hwping administrator-name operation-tag
View
administrator-name: Name of the administrator to create a HWPing test group, a string of 1 to 32 characters.
Use the hwping command to create an HWPing test group and enter HWPing test group view. If the specified HWPing test group already exists, this command leads you to HWPing test group view directly.
Use the undo hwping command to delete an HWPing test group.
# Create an HWPing test group of which the administrator name is administrator and operation tag is icmp.
hwping-agent enable
hwping-agent enable
undo hwping-agent enable
View
None
Use the hwping-agent enable command to enable the HWPing client function.
Use the undo hwping-agent enable command to disable the HWPing client function.
By default, the HWPing client function is disabled.
You can perform tests only after you enable the HWPing client function.
Related commands: hwping-server enable.
# Enable HWPing client.
[Sysname] hwping-agent enable
jitter-interval
jitter-interval interval
undo jitter-interval
View
interval: Interval in milliseconds between jitter test packets. The value is in the range of 10 to 1000.
Use the jitter-interval command to configure the interval between sending jitter test packets.
Use the undo jitter-interval command to restore the default.
By default, the interval between sending jitter test packets is 20 milliseconds.
Related commands: jitter-packetnum.
The jitter-interval command applies to jitter tests only.
# Set the interval between sending jitter test packets to 30 milliseconds.
[Sysname] hwping administrator jitter
[Sysname-hwping-administrator-jitter] test-type jitter
[Sysname-hwping-administrator-jitter] jitter-interval 30
jitter-packetnum
jitter-packetnum number
undo jitter-packetnum
View
number: Number of packets to be transmitted in one probe for a jitter test, in the range of 10 to 100.
Use the jitter-packetnum command to configure the number of packets to be sent in one probe for a jitter test.
Use the undo jitter-packetnum command to restore the default.
By default, 10 packets are sent in a probe for a jitter test.
Related commands: jitter-interval.
This command applies to jitter tests only.
# Configure to send 30 packets in a probe for a jitter test.
[Sysname-hwping-administrator-jitter] jitter-packetnum 30
password
password password
undo password
View
password: Password for logging in to an FTP server, a string of 1 to 32 characters.
Use the password command to configure a password for logging in to the FTP server.
Use the undo password command to remove the configured password.
By default, the password for logging in to the FTP server is not configured.
Related commands: username, ftp-operation.
l          To perform an FTP test successfully, the configured password must be consistent with the FTP user password configured on the server.
l          This command applies to FTP tests only.
# Set the password for logging into the FTP server as hwping in an FTP test.
[Sysname-hwping-administrator-ftp] password hwping
probe-failtimes
probe-failtimes times
undo probe-failtimes
View
times: Number of consecutive failed probes, in the range of 1 to 15.
Use the probe-failtimes command to configure the number of consecutive times the probe fails before the switch sends out a trap message.
Use the undo probe-failtimes command to restore the default.
By default, the switch sends a trap about probe failure each time when a probe fails.
# Configure the switch to send a trap after the probe in an ICMP test fails for three consecutive times.
[Sysname-hwping-administrator-icmp] probe-failtimes 3
send-trap
send-trap { all | { probefailure | testcomplete | testfailure }* }
undo send-trap { all | { probefailure | testcomplete | testfailure }* }
View
probefailure: Sends a trap when a probe fails.
testcomplete: Sends a trap after a test is finished.
testfailure: Sends a trap when a test fails.
all: Sends a trap when any of the above-mentioned scenarios occurs.
Use the send-trap command to enable debugging for a trap.
Use the undo send-trap command to disable debugging for a trap.
By default, no trap is output.
# Send a trap message after an ICMP test is finished.
[Sysname-hwping-administrator-icmp] send-trap testcomplete
source-interface
source-interface interface-type interface-number
undo source-interface
View
interface-type interface-number: Interface type and interface number.
For ICMP tests, use the source-interface command to specify a source interface for sending ICMP requests. The corresponding IP address of the specified interface is used as the source IP address of ICMP requests. For DHCP tests, use the source-interface command to specify an interface for DHCP probes.
For ICMP tests, use the undo source-interface command to remove the specified source interface, and its corresponding IP address is no longer used as the source IP address of ICMP requests. For DHCP tests, use the undo source-interface command to remove the specified interface for DHCP probes.
By default, no source interface is specified for ICMP tests and no interface is configured for DHCP probes.
l          For DHCP tests, this command is required. For ICMP tests, this command is optional. This command does not apply to other tests.
l          For ICMP tests, if a source IP address has been configured with the source-ip command, the source-interface command cannot change the configured IP address.
l          For an ICMP test, if a source interface has been configured with the source-interface command, the test destination address should be configured as the address of the device directly connected to the interface. Otherwise, the test will fail.
l          The interface to be specified in this command can be only a VLAN interface.
l          The interface to be specified must be Up; otherwise the test will fail.
# Configure the source interface that sends test packets in DHCP tests as VLAN-interface 1.
[Sysname] hwping administrator dhcp
[Sysname-hwping-administrator-dhcp] test-type dhcp
[Sysname-hwping-administrator-dhcp] source-interface Vlan-interface 1
source-ip
source-ip ip-address
undo source-ip
View
ip-address: Source IP address for a test.
Use the source-ip command to configure the source IP address for the test.
Use the undo source-ip command to remove the configured source IP address.
By default, the IP address of the interface that sends test packets serves as the source IP address.
l          For FTP tests, this command is required. This command does not apply to DHCP tests. For other tests, this command is optional.
l          The specified source IP address by this command cannot be of an interface on a remote device, and the interface must be Up; otherwise the test will fail.
# Configure the source IP address as 169.254.10.2 for this ICMP test.
[Sysname-hwping-administrator-icmp] source-ip 169.254.10.2
source-port
source-port port-number
undo source-port
View
port-number: Protocol source port number, in the range of 1 to 65,535.
Use the source-port command to configure the protocol source port number for the current test.
Use the undo source-port command to remove the configured source port number.
This command does not apply to ICMP, DHCP, and DNS tests.
# Configure the source port number as 8000 for this HTTP test.
[Sysname-hwping-administrator-http] source-port 8000
test-type
test-type type
View
type: Test type. It can be any of the following keywords:
l          dhcp: Indicates a DHCP test.
l          dns: Indicates a DNS test.
l          ftp: Indicates an FTP test.
l          http: Indicates an HTTP test.
l          icmp: Indicates an ICMP test.
l          jitter: Analyzes the delay change of UDP packet transmission.
l          snmpquery: Indicates an SNMP test.
l          tcpprivate: Indicates a TCP test on a specified (unknown) port.
l          tcppublic: Indicates a TCP test on port 7.
l          udpprivate: Indicates a UDP test on a specified (unknown) port.
l          udppublic: Indicates a UDP test on port 7.
Use the test-type command to configure the test type.
The default test type is icmp.
If you modify the test type, the parameter configuration, test results and history records of the original test type will be cleared.
# Configure the test type as an FTP test.
test-enable
test-enable
undo test-enable
View
None
Use the test-enable command to enable a HWPing test.
Use the undo test-enable command to disable a HWPing test.
Related commands: display hwping.
The result of the HWPing test cannot be displayed automatically, and you need to use the display hwping command to display the test result.
# Perform a HWPing test on an ICMP test group with the administrator name and operation tag being administrator and icmp respectively.
[Sysname-hwping-administrator-icmp] test-enable
test-failtimes
test-failtimes times
undo test-failtimes
View
times: Number of times of consecutive test failure, in the range of 1 to 15.
Use the test-failtimes command to configure the number of consecutive times a HWPing test fails before the switch sends out a trap message.
Use the undo test-failtimes command to restore the default.
By default, the switch sends a trap about test failure each time when a test fails.
# Configure the switch to send out a trap message after an ICMP test fails for three consecutive times.
[Sysname-hwping-administrator-icmp] test-failtimes 3
timeout
timeout time
undo timeout
View
time: Timeout time for one probe, in the range of 1 to 60, in seconds.
Use the timeout command to set the timeout time for a probe.
Use the undo timeout command to restore the default value.
The HWPing client starts the probe timer after sending a test packet. If the HWPing client receives no response before the timer expires, it considers that the current probe has timed out.
By default, the probe timeout time is 3 seconds.
# Set the timeout time for one probe in an ICMP test to 10 seconds.
[Sysname-hwping-administrator-icmp] timeout 10
tos
tos value
undo tos
View
value: ToS value in a HWPing test packet header, in the range of 0 to 255.
Use the tos command to configure the ToS value in a HWPing test packet header.
Use the undo tos command to remove the ToS value in a HWPing test packet header.
By default, no ToS value is configured.
# Set the ToS value in the header of an ICMP test packet to 1.
[Sysname-hwping-administrator-icmp] tos 1
username
username name
undo username
View
name: Username for logging in to an FTP server, a string of 1 to 32 characters.
Use the username command to configure a username for logging in to the FTP server.
Use the undo username command to remove the configured username.
By default, no username for logging in to the FTP server is configured.
Related commands: password, ftp-operation.
l          To perform an FTP test successfully, the configured username must be consistent with the username configured on the FTP server.
# Configure the username for logging into the FTP server in an FTP test as administrator.
[Sysname-hwping-administrator-ftp] username administrator
HWPing Server Commands
l          A HWPing server is required for only jitter, TCP, and UDP tests.
l          You are not recommended to configure HWPing jitter/UDP/TCP servers on ports 1 through 1023 (well-known ports); otherwise, HWPing probes may fail or the services corresponding to these ports may be unavailable.
undo hwping-server enable
View
None
Use the hwping-server enable command to enable the HWPing server function.
Use the undo hwping-server enable command to disable the HWPing server function.
By default, the HWPing server function is disabled.
Related commands: hwping-agent enable, hwping-server tcpconnect, hwping-server udpecho.
# Enable a HWPing server.
[Sysname] hwping-server enable
hwping-server tcpconnect ip-address port-number
undo hwping-server tcpconnect ip-address port-number
View
ip-address: IP address specified for a TCP listening service on the HWPing server.
port-number: Port number specified for a TCP listening service on the HWPing server. The value ranges from 1 to 65535. It is not recommended to use the ports with a number greater than 50000 or some special ports (that is, those used for fixed functions, such as port 1701). Otherwise, the HWPing test may fail.
Use the hwping-server tcpconnect command to create a TCP listening service on the HWPing server.
Use the undo hwping-server tcpconnect command to remove the created TCP listening service.
When performing a TCP connection test on a specified port of a HWPing client, you must create a TCP listening on the HWPing server if the server is an H3C S3600 series Ethernet switch; otherwise, the TCP test may fail.
# Enable TCP listening, using 169.254.10.2 as the IP address and 9000 as the port number.
[Sysname] hwping-server tcpconnect 169.254.10.2 9000
hwping-server udpecho ip-address port-number
undo hwping-server udpecho ip-address port-number
View
ip-address: IP address from which a HWPing server performs UDP listening.
port-number: Port from which a HWPing server performs UDP listening. The value ranges from 1 to 65535. In is not recommended to use a port with a number greater than 50000 or some special ports (that is, those used for fixed functions, such as port 1701). Otherwise, the HWPing test may fail.
Use the hwping-server udpecho command to enable UDP listening on a HWPing server.
Use the undo hwping-server udpecho command to disable UDP listening.
When performing a jitter test or a UDP connection test on a specified port of a HWPing client, you must enable UDP listening on the server if an S3600 switch serves as a HWPing server; otherwise, the test may fail.
# Enable UDP listening, using 169.254.10.3 as the IP address and 9000 as the port number.
[Sysname] hwping-server udpecho 169.254.10.3 9000
