H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
29-IRF Fabric Command
29-IRF Fabric Command 77.2 KB
IRF Fabric Commands
change self-unit
change self-unit to { unit-id | auto-numbering }
View
unit-id: Changes the unit ID of the current switch to a specified value which is in the range of 1 to 8.
auto-numbering: Changes the numbering mode of unit ID on the current switch to automatic numbering mode.
Use the change self-unit command to change the unit ID of the current switch. If a user telnets to an IRF fabric, only the switch connecting with the network of the telnet user responds to the telnet request, and this switch is the current switch. You can use the display irf-fabric command to identify which device is the current device in an IRF fabric.
When you change the unit ID of the current switch, note the following:
l          If the modified unit ID is not used in the IRF fabric, the system sets its priority to 5 and saves it in the Flash memory of the current switch.
l          If the modified unit ID is being used, the system prompts you to confirm if you really want to change the unit ID. If you choose to change it, the existing unit ID is replaced and the priority is set to 5. The original device which uses this unit ID will be auto-numbered again. Then you can use the fabric save-unit-id command to save the modified unit ID into the Flash memory of the current switch.
l          If auto-numbering is selected, the system sets the unit priority to 10. You can use the fabric save-unit-id command to save the modified unit ID into the Flash memory of the current switch.
By default, the unit ID of a switch that belongs to no IRF fabric is 1. After a switch is added to an IRF fabric, it is automatically numbered through FTM function.
l          If you do not bring up the fabric port, you cannot change the unit ID of a switch.
l          After the unit ID of a device is changed, the unit ID-related information of this device in the configuration file of the fabric will be upgraded automatically. If the unit ID of a device changes from 2 to 4, the port description of this device in the configuration file automatically changes from 2/0/x to 4/0/x.
# Configure the unit ID of the current switch to be automatically numbered.
[Sysname] change self-unit to auto-numbering
change unit-id
change unit-id unit-id1 to { unit-id2 | auto-numbering }
View
unit-id1: Current unit ID.
unit-id2: New unit ID.
auto-numbering: Changes the numbering mode of unit ID on a specified switch (not the current switch) to automatic numbering mode.
Use the change unit-id command to configure the unit ID of a specified switch in an IRF fabric to a new value. By default, when a switch is added to an IRF fabric, it uses the automatically assigned unit ID.
When you change the unit ID of a switch in an IRF fabric, note the following:
l          If the modified unit ID of the switch is not used in the fabric, the system sets its priority to 5 and saves it in the Flash memory of the switch.
l          If the modified unit ID is being used, the system prompts you to confirm if you really want to change the unit ID. If you choose to change it, the existing unit ID is replaced and the priority is set to 5. The original device which uses this unit ID will be auto-numbered again. Then you can use the fabric save-unit-id command to save the modified unit ID into the Flash memory of the switch.
l          If auto-numbering is selected, the system reserves the unit ID and sets the unit priority to 10. You can use the fabric save-unit-id command to save the modified unit ID into the Flash memory of the switch.
l          Unit IDs in an IRF fabric are not always arranged in order of 1 to 8.
l          Unit IDs in an IRF fabric can be inconsecutive.
Related commands: fabric save-unit-id, display ftm.
# Display the unit ID information about each switch in an IRF fabric.
<Sysname> display ftm topology-database
Total number of units in fabric : 2, My CPU ID : 6
UID CPU-Mac        Priority Stack-Port Board-ID A/M
 1  000f-e20f-5002 10           /Right 1        A
 2  000f-e20f-5132 10       Left/      1        A
 3  000f-e20f-5252 10           /Right 1        A
 4  000f-e20f-8922 10       Left/      1        A
 5  000f-cbb7-2142 10           /Right 1        A
*6  000f-cbb7-3264 10       Left/      1        A
 7  000f-cbb7-2260 10           /Right 1        A
 8  000f-cbb7-2734 10       Left/      1        A
# Change the unit ID of the switch from 6 to 4.
[Sysname] change unit-id 6 to 4
The unit 4 already exists in fabric.
 Continue? [Y/N] y
%Apr  2 00:48:34:574 2000 Sysname FTM/3/DDPFLA:- 6 -Change unitid successful, un
it 4 saved UnitID(4) in flash!
# Display the unit ID information about each switch in the fabric.
[Sysname] display ftm topology-database
Total number of units in fabric : 2, My Unit ID : 4
*4  000f-cbb7-3264 5        Left/      1        M
 6  000f-e20f-8922 10       Left/      1        A
From the above example, you can see the original unit ID of the device with MAC address 000f-cbb7-3264 is 6. After the configuration, this unit ID changes to 4, and the priority of the device changes to 5.
display ftm
display ftm { information | topology-database }
View
information: Displays the FTM module information, including DDP status, unit ID, link status of the fabric, status of the fabric port, and DDP packet statistics.
topology-database: Displays the topology database information of the fabric.
 Use the display ftm command to display the protocol information or the topology database information of the current fabric.
# Display the FTM module information of the switch.
<Sysname> display ftm information
FTM State       : HB STATE
Unit ID         : 2 (FTM-Master)
Fabric Type     : Line
Fabric Auth     : NONE
Fabric Vlan ID  : 4093
Left Port       : Disable
Right Port      : Normal
Advertise       : Send = 5, Receive = 3
Advertise ACK   : Send = 0, Receive = 5
Heart Beat      : Send = 20, Receive = 0
Left Port       : Index = 255, IsEdge = 0
Right Port      : Index = 25, IsEdge = 0
Units Num Left  : 1
Units Num Right : 2
Units Num Backup: 2
Table 1-1 display ftm information command output description
FTM State
FTM State:
l      DISC STATE: In the topology discovery state.
l      LISTEN STATE: In the topology discovery state, and the FTM slave device is listening.
l      HB STATE: The fabric operates normally.
Unit ID
Unit ID:
l      FTM-Master
l      FTM-Slave
Fabric Type
Fabric topology structure:
l      Line
l      Ring
Fabric Auth
Authentication mode for an IRF fabric
You can use the irf-fabric authentication-mode command to configure the authentication mode and password for an IRF fabric.
Fabric Vlan ID
ID of the VLAN transmitting fabric synchronization information.
You can use the ftm fabric-vlan command to specify the VLAN used to form an IRF fabric.
Left Port
Right Port
Status of the two fabric ports on a device:
l      Link-Down
l      Isolated (temporary): The fabric is not in a normal state yet, and the fabric port is isolated temporarily.
l      Isolated (redundance port): Redundant link in a ring topology.
l      Isolated (reached max units)
l      Isolated (different system name): The fabric name of the device directly connected to the switch and the existing fabric name of the fabric are different.
l      Isolated (different version): The software version of the directly connected device and that of the current device are different.
l      Isolated (auth failure): The IRF fabric authentication modes configured for the local device and that of the fabric are not the same, or the password configured does not match.
l      Isolated (connection error): Fabric port connection error occurs.
l      Disable: Fabric is disabled on the port.
l      Normal
Refer to the Operation Manual for the status and solution of the problems.
Advertise       :
Advertise ACK   :
Heart Beat      :
Left Check      :
Right Check     :
Auto update     :
Numbers of various negotiation packets:
l      Advertise
l      Advertise ACK
l      Heart Beat: Heat beat packet, which is used to advertise topology connections to the units by the FTM-Master after convergence.
l      Left Check: Handshake packets between neighbors. They are sent from the left port and used to monitor the state of the neighbors periodically.
l      Right Check: Handshake packets between neighbors. They are sent from the right port and used to monitor the state of the neighbors periodically.
l      Auto update: Number of auto update packets sent and received
You can use the above numbers to analyze whether the transmission of data among fabric units is normal, and thus to judge whether the fabric operates normally.
Indexes of the left and right ports:
l      IsEdge: Whether the device is at either end of a bus topology IRF fabric in which the number of member devices has reached the upper limit.
l      0: No
l      1: Yes
Units Num Left  : 1
Units Num Right : 2
Number of units (both directly-connected and subtending units) connected to the port, including the device itself.
l      1: The left port has no connected unit
l      2: The right port connects to one unit
Units Num Backup: 2
Total number of units in a fabric
# Display the topology database information of the current fabric.
Total number of units in fabric : 8, My Unit ID : 4
UID CPU-Mac        Priority Fabric-Port Board-ID A/M
1  000f-e20f-5002 10       Left/Right  1        A
2  000f-e20f-5132 10       Left/Right  1        A
3  000f-e20f-5252 10       Left/Right  1        A
*4  000f-cbb7-3264 5       Left/Right  1        M
5  000f-cbb7-2142 10       Left/Right  1        A
6  000f-e20f-8922 10       Left/Right  1        A
7  000f-cbb7-2260 10       Left/Right  1        A
8  000f-cbb7-2734 10       Left/Right  1        A
Table 1-2 display ftm topology-database command output description
UID
Unit ID
Priority
Priority value:
l      10 means the switch adopts automatic numbering
l      5 means the switch adopts manual numbering
Manual numbering has a higher priority than automatic numbering.
Fabric-Port
Fabric port
l      In a ring topology structure, the left and right ports of all units are connected, and are displayed as Left/Right.
l      In a bus topology structure, the units at both ends of the bus have only one fabric port connected, displayed as Left/ or /Right.
A/M
Indicates that the switch adopts automatic numbering or manual numbering:
l      A for automatic
l      M for manual
display irf-fabric
display irf-fabric [ port | status ]
View
port: Displays the fabric port information.
status: Displays operation status of the current fabric, including fabric name and unit ID.
Use the display irf-fabric command to view the information of the entire fabric, including unit ID, unit name, and operation mode of the system. If the fabric information is displayed on the console port of a device, an asterisk (*) will be added to the unit ID of the current device.
# Display fabric information on the console port of unit 1.
<Sysname> display irf-fabric
Fabric name is Sysname, system mode is L3.
Unit Name                                 Unit ID
First                                     1(*)
Second                                    2
From the above example, you can see the following:
l          The name of the fabric is Sysname.
l          The system operation mode is Layer 3 forwarding.
l          The current device is 1 (marked by *)
l          The name of the current device is First (the name of a device can be configured by using the set unit name command)
l          The other unit in the fabric is numbered 2
# Display fabric operation status on the console port of unit 1.
<Sysname> display irf-fabric status
Unit Name                                 Unit ID               Status
First                                     1(*)                  Master
From the above example, you can see not only the information displayed by using the display irf-fabric command, but also the roles of the units in the fabric (master or slave).
# Display the fabric port of the current device.
<Sysname> display irf-fabric port
 GigabitEthernet1/1/1
 Fabric peer: Unknown
 Fabric Status:  Unknown
 Fabric mode: Unknown-speed mode, Unknown-duplex mode
 input:   0 packets, 0 bytes, 0 input errors
 output:  7343 packets, 2250406 bytes, 0 output errors
fabric member-auto-update software enable
undo fabric member-auto-update software enable
View
None
Use the fabric member-auto-update software enable command to enable the IRF automatic fabric function for a switch.
Use the undo fabric member-auto-update software enable command to disable the IRF automatic fabric function for a switch.
By default, the IRF automatic fabric function for a switch is disabled.
H3C S3600 series switches provide the IRF automatic fabric function, which enables a candidate switch to automatically download the software and change the fabric name in case that the software version and fabric name of the candidate device and that of the device in the fabric are different, thus reducing the manual maintenance workload.
l          You need to enable the IRF automatic fabric function on all the devices including the candidate switch in the fabric to enable the candidate switch to download software and discovery neighbors and thus be added to the fabric normally.
l          If the candidate switch is going to download software from a unit in an IRF fabric, you are recommended to set the ID of the unit to 1 to make the candidate switch download the software of correct version.
l          Before configuring the IRF automatic fabric function, make sure that the candidate switch has enough Flash space to download the software.
l          After you configure the IRF automatic fabric function on Slave, execute the save command to save the configurations as soon as possible. Otherwise, the device may synchronize the configurations from Master and restart repeatedly because the configurations on the device are lost after the device automatically downloads the software and restarts.
# Enable the IRF automatic fabric function for a switch.
[Sysname] fabric member-auto-update software enable
fabric save-unit-id
fabric save-unit-id
undo fabric save-unit-id
View
None
Use the fabric save-unit-id command to save the unit IDs of all the units in an IRF fabric into the unit Flash and set the unit priority to 5, that is, manual numbering.
Use the undo fabric save-unit-id command to remove the saved unit IDs and restore the unit priority to 10, that is, automatic numbering.
# Display the unit IDs of the current fabric.
Total number of units in fabric : 8, My Unit ID : 1
*1  000f-e20f-5002 10           /Right 1        A
# Save the unit IDs of all the units in an IRF fabric to the unit Flash memory.
<Sysname> fabric save-unit-id
 The unit ID will be saved to the device.
 Are you sure? [Y/N] y
%Apr  2 02:13:44:413 2000 3600 FTM/3/DDPFLA:- 4 -Save self unitid, unit 4 sav
 Unit 1 saved unit ID successfully.
 Unit 2 saved unit ID successfully.
 Unit 3 saved unit ID successfully.
 Unit 4 saved unit ID successfully.
 Unit 5 saved unit ID successfully.
 Unit 6 saved unit ID successfully.
 Unit 7 saved unit ID successfully.
 Unit 8 saved unit ID successfully.
# Display the saved unit IDs of the current fabric.
*1  000f-e20f-5002 5            /Right 1        M
 2  000f-e20f-5132 5        Left/      1        M
 3  000f-e20f-5252 5            /Right 1        M
 4  000f-e20f-8922 5        Left/      1        M
 5  000f-cbb7-2142 5            /Right 1        M
 6  000f-cbb7-3264 5        Left/      1        M
 7  000f-cbb7-2260 5            /Right 1        M
 8  000f-cbb7-2734 5        Left/      1        M
From the above example, you can see the priority of each unit changes from 10 to 5, and the numbering mode changes from A (automatic numbering) to M (manual numbering).
# Remove the saved unit ID of each unit.
<Sysname> undo fabric save-unit-id
 The saved unit ID will be erased.
 Unit 1 removed unit ID successfully.
%Apr  2 19:43:24:368 2000 Sysname FTM/3/FTMCHIDAUTO:- 1 -Change unitid to auto successful, unit 1 removed UnitID from flash!
 Unit 2 removed unit ID successfully.
 Unit 3 removed unit ID successfully.
 Unit 4 removed unit ID successfully.
 Unit 5 removed unit ID successfully.
 Unit 6 removed unit ID successfully.
 Unit 7 removed unit ID successfully.
 Unit 8 removed unit ID successfully.
From the above example, you can see the priority of each unit restores to 10 and the numbering mode changes from M (manual numbering) to A (automatic numbering).
fabric-port enable
fabric-port interface-type interface-number enable
undo fabric-port interface-type interface-number enable
View
interface-type interface-number: Type and port number of a fabric port. On an S3600 series Ethernet switch, only four GigabitEthernet ports can be configured as fabric ports: GigabitEthernet 1/1/1, GigabitEthernet 1/1/2, GigabitEthernet 1/1/3, and GigabitEthernet 1/1/4.
Use the fabric-port enable command to configure a specified port as a fabric port.
Use the undo fabric-port enable command to disable the fabric port function for a port. When the last fabric port on a switch is disabled, the fabric function is disabled globally.
The four ports on an S3600 series Ethernet switch fall into two groups according to their port numbers:
l          GigabitEthernet 1/1/1 and GigabitEthernet 1/1/2 form the first group.
l          GigabitEthernet 1/1/3 and GigabitEthernet 1/1/4 form the second group.
Only one group of ports can be configured as fabric ports at a time. Given a group, either GigabitEthernet 1/1/1 or GigabitEthernet 1/1/3 can be configured as the left fabric port, and either GigabitEthernet 1/1/2 or GigabitEthernet 1/1/4 can be configured as the right fabric port.
l          Establishing an IRF system requires a high consistency of the configuration of each device. Hence, before you bring up the fabric port, do not perform any configuration for the port, and do not enable some functions that affect the IRF (such as TACACS and VLAN-VPN) for other ports or globally. Otherwise, you cannot bring up the fabric port. For detailed restrictions, refer to the error information output by devices.
l          When you have brought up fabric port function for a fabric port group, if you need to change the fabric port group, you must disable the fabric function of the current fabric port group before you execute the enable command on another group. Otherwise, the system will prompt that the current fabric port group is in use, you cannot change the fabric port group.
# Set GigabitEthernet 1/1/3 port as a fabric port.
[Sysname] fabric-port GigabitEthernet1/1/3 enable
ftm fabric-vlan
ftm fabric-vlan vlan-id
undo ftm fabric-vlan
View
vlan-id: ID of the IRF fabric VLAN, in the range of 2 to 4094. The VLAN you specified must be the one that has not been created manually.
Use the ftm fabric-vlan command to specify the VLAN that the switch uses for IRF fabric.
Use the undo ftm fabric-vlan command to restore the default VLAN.
By default, the number of the IRF Fabric VLAN is 4093.
In an IRF fabric, the VLAN is used to synchronize configurations and transmit IRF data among devices, avoiding packets being sent to non fabric ports
You need to specify the IRF fabric VLAN before the IRF fabric is established. Because after the fabric is established, the VLAN cannot be modified.
# Specify VLAN 2 of the switch as an IRF fabric VLAN.
[Sysname] ftm fabric-vlan 2
irf-fabric authentication-mode { simple password | md5 key }
undo irf-fabric authentication-mode
View
simple: Uses simple authentication mode.
password: Password for fabric authentication, a string of 1 to 16 characters.
md5: Uses MD5 encryption authentication mode.
key: MD5 key, a string of 1 to 16 characters.
Use the irf-fabric authentication-mode command to configure the authentication mode and password for an IRF fabric.
Use the undo irf-fabric authentication-mode command to remove the IRF fabric authentication configuration.
By default, no authentication mode is configured on a switch.
IRF fabric authentication is used to ensure the security of the devices accessing it. Only the device configured with the same authentication mode and password with that of the fabric can access the current IRF fabric.
# Set the authentication mode of the IRF fabric to simple, with the password being hello.
[Sysname] irf-fabric authentication-mode simple hello
port link-type irf-fabric
View
Ethernet port view
None
Use the port link-type command to configure an Ethernet port as the fabric port. This command has the same function with the fabric-port enable command, and is available only in gigabit port view.
By default, no port is configured as the fabric port.
Note that:
After you use the port link-type irf-fabric command to specify a port as the fabric port, you cannot use the port link-type command to change the port to a port of other types. You need to use the undo fabric-port command first to disable the fabric port function of the port to change the port type.
# Set GigabitEthernet 1/1/1 port as a fabric port.
[Sysname] interface GigabitEthernet 1/1/1
[Sysname-GigabitEthernet1/1/1] port link-type irf-fabric
reset ftm statistics
View
None
Use the reset ftm statistics command to clear FTM statistics. You can use this command together with the display ftm command to view the packet statistics processed by FTM in a period of time, thus analyzing fabric operation status and locating problems.
Related commands: display ftm.
# Clear FTM statistics.
<Sysname> reset ftm statistics
set unit name
set unit unit-id name unit-name
View
unit-id: Unit ID of a device.
unit-name: Name of the specified unit, a string of 1 to 64 characters.
Use the set unit name command to set a name for a device. Device name visually identifies a device by showing its location, role in the fabric, and connected networks, thus facilitating configuration and maintenance.
# Set the name to hello for the device with unit ID 1.
Unit Name     Unit ID
First             1
Second          2(*)
[Sysname] set unit 1 name hello
[Sysname] display irf-fabric
Unit Name     Unit ID
hello            1
Second          2(*)
sysname
sysname sysname
undo sysname
View
sysname: Name of the specified fabric, a string of 1 to 30 characters.
Use the sysname command to set the name for the fabric where a device belongs. The modification will affect the prompt character in the command line interface. For example, if the fabric name of the Ethernet switch is H3C, the prompt character in user view is <H3C>.
Use the undo sysname command to restore the default fabric name.
Before a new device is added into a fabric, make sure that the fabric name of the device and the fabric name of the devices in the fabric are consistent. You can enable the IRF automatic fabric function by using the fabric member-auto-update software enable command to configure the device to synchronize the fabric name automatically.
By default, the fabric name of an S3600 Series Ethernet switch is H3C.
# Change the fabric name of the device to hello.
Unit Name     Unit ID
First             1
Second          2(*)
[Sysname] sysname hello
[hello] display irf-fabric
Fabric name is hello, system mode is L3.
Unit Name     Unit ID
First             1
Second          2(*)
