- H3C S9500 Series Routing Switches Command Manual-(V1.01)
- 00-1Cover
- 01-Getting Started Command
- 02-Port Command
- 03-VLAN-QinQ Command
- 04-Network Protocol Command
- 05-Routing Protocol Command
- 06-Multicast Protocol Command
- 07-QACL Command
- 08-MPLS Command
- 09-STP Command
- 10-Security Command
- 11-Reliability Command
- 12-System Management Command
- 13-PoE Command
- 14-NAT-URPF-VPLS Command
- 15-Integrated Management Command
- 16-Appendix
16-Appendix | 80 KB |
Appendix A Command Index
The command index includes all the commands in the VRP Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
abr-summary |
Routing Protocol |
3-1 |
access-limit |
Security |
2-1 |
accounting optional |
Security |
2-1 |
Security |
2-22 |
acl |
QoS/ACL |
1-1 |
acl |
QoS/ACL |
3-1 |
active region-configuration |
STP |
1-1 |
add addritem |
NAT-URPF-VPLS |
1-27 |
aggregate |
Routing Protocol |
5-1 |
aggregate |
Multicast Protocol |
7-1 |
aggregate |
MPLS |
2-1 |
anti-attack |
Security |
1-1 |
apply as-path |
Routing Protocol |
6-1 |
apply community |
Routing Protocol |
6-2 |
apply cost |
Routing Protocol |
6-3 |
apply cost-type |
Routing Protocol |
6-4 |
apply ip next-hop |
Routing Protocol |
6-4 |
apply isis |
Routing Protocol |
6-5 |
apply local-preference |
Routing Protocol |
6-6 |
apply mpls-label |
MPLS |
2-2 |
apply origin |
Routing Protocol |
6-6 |
apply tag |
Routing Protocol |
6-7 |
area |
Routing Protocol |
3-2 |
area-authentication-mode |
Routing Protocol |
4-1 |
arp enable size |
Network Protocol |
3-2 |
arp max-aggregation-entry |
Network Protocol |
3-2 |
arp max-entry |
Network Protocol |
3-1 |
arp proxy enable |
Network Protocol |
2-1 |
arp static |
Network Protocol |
2-1 |
arp static multi-port |
Network Protocol |
2-3 |
arp timer aging |
Network Protocol |
2-4 |
asbr-summary |
Routing Protocol |
3-2 |
ascii |
System Managment |
1-28 |
attribute |
Security |
2-2 |
Getting Started |
1-1 |
Routing Protocol |
3-3 |
auto config |
NAT-URPF-VPLS |
1-2 |
auto-execute command |
Getting Started |
1-2 |
backup lswconfig |
NAT-URPF-VPLS |
1-3 |
Balance |
Routing Protocol |
5-2 |
bandwidth |
NAT-URPF-VPLS |
3-1 |
bgp |
Routing Protocol |
5-3 |
binary |
System Managment |
1-29 |
boot boot-loader |
System Managment |
3-1 |
boot bootrom |
System Managment |
3-2 |
broadcast-restrain |
NAT-URPF-VPLS |
3-2 |
broadcast-suppression |
Port |
1-1 |
3-1 |
bsr-policy |
5-1 |
bye |
System Managment |
1-29 |
bye |
System Managment |
8-21 |
cache-sa-enable |
6-1 |
c-bsr |
5-2 |
ccc |
MPLS |
3-1 |
cd |
System Managment |
1-1 |
cd |
System Managment |
1-30 |
cd |
System Managment |
8-22 |
cdup |
System Managment |
1-30 |
cdup |
System Managment |
8-22 |
ce |
MPLS |
3-10 |
check region-configuration |
STP |
1-2 |
checkzero |
Routing Protocol |
2-1 |
clock |
Port |
3-1 |
clock |
System Managment |
4-5 |
clock datetime |
System Managment |
4-1 |
clock forcessm |
System Managment |
4-6 |
clock lpuport |
System Managment |
4-7 |
clock priority |
System Managment |
4-7 |
clock sa-bit |
System Managment |
4-8 |
clock ssm |
System Managment |
4-8 |
clock ssmcontrol |
System Managment |
4-10 |
clock stop warm-up |
System Managment |
4-10 |
clock summer-time |
System Managment |
4-1 |
clock timezone |
System Managment |
4-3 |
clock-source |
Port |
4-1 |
close |
System Managment |
1-31 |
close port |
NAT-URPF-VPLS |
1-4 |
command-privilege level |
Getting Started |
1-3 |
compare-different-as-med |
Routing Protocol |
5-4 |
7-2 |
confederation id |
Routing Protocol |
5-4 |
confederation nonstandard |
Routing Protocol |
5-5 |
confederation peer-as |
Routing Protocol |
5-6 |
connection |
MPLS |
3-11 |
copy |
System Managment |
1-2 |
copy configuration |
Port |
1-2 |
cost-style |
Routing Protocol |
4-2 |
crc |
Port |
3-1 |
c-rp |
5-3 |
crp-policy |
5-4 |
cut connection |
Security |
2-3 |
dampening |
Routing Protocol |
5-7 |
databits |
Getting Started |
1-4 |
data-flow-format |
Security |
2-23 |
data-flow-format |
Security |
2-50 |
debugging |
System Managment |
1-31 |
debugging |
System Managment |
4-27 |
debugging arp |
Network Protocol |
2-5 |
debugging bgp |
Routing Protocol |
5-8 |
debugging bgp |
MPLS |
2-3 |
debugging bgp mp-update |
7-3 |
debugging dhcp relay |
Network Protocol |
4-32 |
debugging dhcp server |
Network Protocol |
4-3 |
debugging dns |
Network Protocol |
6-2 |
debugging ha |
Reliability |
2-1 |
debugging hwtacacs |
Security |
2-51 |
debugging ids-acl |
Port |
5-2 |
debugging igmp |
4-1 |
debugging isis |
Routing Protocol |
4-3 |
debugging lacp packet |
Port |
2-1 |
debugging lacp state |
Port |
2-2 |
debugging link-aggregation error |
Port |
2-2 |
debugging link-aggregation event |
Port |
2-3 |
debugging mpls l2vpn |
MPLS |
3-2 |
NAT-URPF-VPLS |
3-3 |
debugging mpls ldp |
MPLS |
1-11 |
debugging mpls lspm |
MPLS |
1-1 |
debugging mpm |
1-1 |
debugging msdp |
6-2 |
debugging multicast forwarding |
3-2 |
debugging multicast kernel-routing |
3-3 |
debugging multicast status-forwarding |
3-3 |
debugging ntp-service |
System Managment |
7-1 |
debugging ospf |
Routing Protocol |
3-4 |
debugging pim common |
5-5 |
debugging pim dm |
5-6 |
debugging pim sm |
5-7 |
debugging ppp |
Port |
3-5 |
debugging radius |
Security |
2-24 |
debugging rpr |
Port |
4-1 |
debugging ssh server |
System Managment |
8-1 |
debugging stp |
STP |
1-3 |
debugging vrrp |
Reliability |
1-1 |
default cost |
Routing Protocol |
2-2 |
default cost |
Routing Protocol |
3-5 |
default interval |
Routing Protocol |
3-6 |
default limit |
Routing Protocol |
3-7 |
default local-preference |
Routing Protocol |
5-9 |
7-3 |
MPLS |
2-4 |
default med |
Routing Protocol |
5-9 |
default med |
7-4 |
default med |
MPLS |
2-5 |
default tag |
Routing Protocol |
3-7 |
default type |
Routing Protocol |
3-8 |
default-cost |
Routing Protocol |
3-9 |
default-route-advertise |
Routing Protocol |
3-9 |
Routing Protocol |
4-4 |
delete |
System Managment |
1-2 |
delete |
System Managment |
1-32 |
delete |
System Managment |
8-23 |
delete multicast |
NAT-URPF-VPLS |
1-28 |
delete static-routes all |
Routing Protocol |
1-16 |
delete uniaddr |
NAT-URPF-VPLS |
1-29 |
delete vpn-instance |
Routing Protocol |
1-17 |
description |
Port |
1-3 |
description |
Port |
3-2 |
description |
VLAN-QinQ |
1-1 |
description |
MPLS |
2-5 |
description |
NAT-URPF-VPLS |
3-2 |
dhcp enable |
Network Protocol |
4-1 |
dhcp relay information enable |
Network Protocol |
5-1 |
dhcp relay information strategy |
Network Protocol |
5-2 |
dhcp relay security |
Network Protocol |
4-33 |
dhcp relay security address-check |
Network Protocol |
4-34 |
dhcp select |
Network Protocol |
4-1 |
dhcp server detect |
Network Protocol |
4-3 |
dhcp server dns-list |
Network Protocol |
4-5 |
dhcp server domain-name |
Network Protocol |
4-6 |
dhcp server expired |
Network Protocol |
4-7 |
dhcp server forbidden-ip |
Network Protocol |
4-8 |
dhcp server ip-pool |
Network Protocol |
4-9 |
dhcp server nbns-list |
Network Protocol |
4-9 |
dhcp server netbios-type |
Network Protocol |
4-10 |
dhcp server option |
Network Protocol |
4-11 |
dhcp server ping |
Network Protocol |
4-13 |
dhcp server relay information enable |
Network Protocol |
5-2 |
dhcp server static-bind |
Network Protocol |
4-14 |
dhcp-server detect |
Network Protocol |
4-35 |
dir |
System Managment |
1-3 |
dir |
System Managment |
1-32 |
dir |
System Managment |
8-23 |
disconnect |
System Managment |
1-33 |
display acl config |
QoS/ACL |
1-3 |
display acl remaining entry |
QoS/ACL |
1-3 |
display acl running-packet-filter |
QoS/ACL |
1-4 |
display arp |
Network Protocol |
2-6 |
display arp max-entry |
Network Protocol |
3-3 |
display arp multi-port |
Network Protocol |
2-7 |
display arp proxy |
Network Protocol |
2-8 |
display arp timer aging |
Network Protocol |
2-9 |
display bgp group |
Routing Protocol |
5-10 |
display bgp l2vpn |
MPLS |
3-11 |
display bgp multicast group |
7-5 |
display bgp multicast network |
7-5 |
display bgp multicast peer |
7-6 |
display bgp multicast routing-table |
7-6 |
display bgp multicast routing-table as-path-acl |
7-7 |
display bgp multicast routing-table cidr |
7-7 |
display bgp multicast routing-table community |
7-8 |
display bgp multicast routing-table community-list |
7-8 |
display bgp multicast routing-table different-origin-as |
7-9 |
display bgp multicast routing-table peer |
7-9 |
display bgp multicast routing-table regular-expression |
7-10 |
display bgp network |
Routing Protocol |
5-11 |
display bgp paths |
Routing Protocol |
5-12 |
display bgp peer |
Routing Protocol |
5-13 |
display bgp routing-table |
Routing Protocol |
5-15 |
display bgp routing-table as-path-acl |
Routing Protocol |
5-16 |
display bgp routing-table cidr |
Routing Protocol |
5-18 |
display bgp routing-table community |
Routing Protocol |
5-19 |
display bgp routing-table community-list |
Routing Protocol |
5-19 |
display bgp routing-table dampened |
Routing Protocol |
5-20 |
display bgp routing-table different-origin-as |
Routing Protocol |
5-22 |
display bgp routing-table flap-info |
Routing Protocol |
5-23 |
display bgp routing-table label |
MPLS |
2-7 |
display bgp routing-table peer |
Routing Protocol |
5-24 |
display bgp routing-table regular-expression |
Routing Protocol |
5-25 |
display bgp routing-table statistic |
Routing Protocol |
5-26 |
display bgp vpnv4 |
MPLS |
2-6 |
display boot-loader |
System Managment |
3-2 |
display ccc |
MPLS |
3-3 |
display channel |
System Managment |
4-33 |
display clock |
System Managment |
4-20 |
display clock basephase |
System Managment |
4-13 |
display clock config |
System Managment |
4-19 |
display clock d/a |
System Managment |
4-13 |
display clock device |
System Managment |
4-11 |
display clock lpuport |
System Managment |
4-14 |
display clock phase-lock-state |
System Managment |
4-18 |
display clock priority |
System Managment |
4-16 |
display clock self-test-result |
System Managment |
4-15 |
display clock source |
System Managment |
4-14 |
display clock ssm-level |
System Managment |
4-17 |
display clock ssm-output |
System Managment |
4-18 |
display clock version |
System Managment |
4-12 |
display clock work-mode |
System Managment |
4-19 |
display connection |
Security |
2-5 |
display counters |
Port |
1-4 |
display cpu |
System Managment |
3-3 |
display current-configuration |
System Managment |
1-12 |
display debugging |
System Managment |
4-21 |
display debugging ospf |
Routing Protocol |
3-11 |
display device |
System Managment |
3-4 |
display dhcp relay address |
Network Protocol |
4-35 |
display dhcp server conflict |
Network Protocol |
4-14 |
display dhcp server expired |
Network Protocol |
4-15 |
display dhcp server forbidden-ip |
Network Protocol |
4-4 |
display dhcp server free-ip |
Network Protocol |
4-16 |
display dhcp server ip-in-use |
Network Protocol |
4-17 |
display dhcp server statistics |
Network Protocol |
4-18 |
display dhcp server tree |
Network Protocol |
4-20 |
display dhcprelay-security |
Network Protocol |
4-36 |
display diagnostic-information |
System Managment |
4-28 |
display dns domain |
Network Protocol |
6-3 |
display dns dynamic-host |
Network Protocol |
6-4 |
display dns server |
Network Protocol |
6-5 |
display domain |
Security |
2-6 |
display dot1x |
Security |
1-1 |
display egress counter |
Port |
7-2 |
display environment |
System Managment |
3-5 |
display fan |
System Managment |
3-5 |
display fib |
Network Protocol |
7-1 |
display fib | |
Network Protocol |
7-4 |
display fib acl |
Network Protocol |
7-3 |
display fib ip-address |
Network Protocol |
7-2 |
display fib ip-prefix |
Network Protocol |
7-4 |
display fib statistics |
Network Protocol |
7-5 |
display fiber-module |
System Managment |
4-22 |
display flow-temlate |
QoS/ACL |
1-5 |
display ftp-server |
System Managment |
1-21 |
display ftp-user |
System Managment |
1-22 |
display garp statistics |
VLAN-QinQ |
2-1 |
display garp timer |
VLAN-QinQ |
2-1 |
display gvrp statistics |
VLAN-QinQ |
2-5 |
display gvrp status |
VLAN-QinQ |
2-6 |
display hgmpserver |
NAT-URPF-VPLS |
1-5 |
display history-command |
Getting Started |
1-4 |
display hwtacacs |
Security |
2-51 |
display icmp statistics |
Network Protocol |
7-5 |
display ids |
Port |
5-1 |
display igmp group |
4-1 |
display igmp interface |
4-2 |
display igmp-snooping configuration |
1-2 |
display igmp-snooping group |
1-2 |
display igmp-snooping statistics |
1-3 |
display info-center |
System Managment |
4-33 |
display interface |
Port |
1-5 |
display interface |
Port |
4-2 |
display interface pos |
Port |
3-3 |
display interface Vlan-interface |
VLAN-QinQ |
1-2 |
display ip host |
Network Protocol |
1-1 |
display ip host |
Network Protocol |
6-1 |
display ip interface |
Network Protocol |
1-1 |
display ip ip-prefix |
Routing Protocol |
6-7 |
display ip routing-table |
Routing Protocol |
1-1 |
display ip routing-table acl |
Routing Protocol |
1-2 |
display ip routing-table ip-address |
Routing Protocol |
1-6 |
display ip routing-table ip-address1 ip-address2 |
Routing Protocol |
1-8 |
display ip routing-table ip-prefix |
Routing Protocol |
1-9 |
display ip routing-table protocol |
Routing Protocol |
1-10 |
display ip routing-table radix |
Routing Protocol |
1-12 |
display ip routing-table statistics |
Routing Protocol |
1-13 |
display ip routing-table verbose |
Routing Protocol |
1-15 |
display ip routing-table vpn-instance |
Routing Protocol |
1-14 |
MPLS |
2-8 |
display ip socket |
Network Protocol |
7-7 |
display ip statistics |
Network Protocol |
7-8 |
display ip userlog export |
NAT-URPF-VPLS |
1-16 |
display ip vpn-instance |
MPLS |
2-8 |
display isis interface |
Routing Protocol |
4-5 |
display isis lsdb |
Routing Protocol |
4-6 |
display isis mesh-group |
Routing Protocol |
4-7 |
display isis peer |
Routing Protocol |
4-8 |
display isis route |
Routing Protocol |
4-9 |
display isis spf-log |
Routing Protocol |
4-10 |
display isolate-user-vlan |
VLAN-QinQ |
4-1 |
display jumboframe configuration |
Port |
1-8 |
display lacp system-id |
Port |
2-4 |
display lanswitch |
NAT-URPF-VPLS |
1-7 |
display link-aggregation interface |
Port |
2-7 |
display link-aggregation summary |
Port |
2-4 |
display link-aggregation verbose |
Port |
2-5 |
display local-server |
Security |
2-24 |
display local-user |
Security |
2-7 |
display logbuffer |
System Managment |
4-35 |
display logbuffer summary |
System Managment |
4-37 |
display mac-address |
System Managment |
2-1 |
display mac-address aging-time |
System Managment |
2-1 |
display mac-address vsi |
NAT-URPF-VPLS |
3-3 |
display memory |
System Managment |
3-6 |
display mirroring-group |
QoS/ACL |
2-1 |
display mpls interface |
MPLS |
1-2 |
display mpls l2vc |
MPLS |
3-6 |
display mpls l2vc |
NAT-URPF-VPLS |
3-4 |
display mpls l2vpn |
MPLS |
3-12 |
display mpls l3vpn-lsp |
MPLS |
2-9 |
display mpls ldp |
MPLS |
1-12 |
display mpls ldp buffer-info |
MPLS |
1-12 |
display mpls ldp interface |
MPLS |
1-13 |
display mpls ldp lsp |
MPLS |
1-15 |
display mpls ldp peer |
MPLS |
1-16 |
display mpls ldp remote |
MPLS |
1-18 |
display mpls ldp session |
MPLS |
1-19 |
display mpls lsp |
MPLS |
1-2 |
display mpls static-lsp |
MPLS |
1-3 |
display mpls statistics |
MPLS |
1-4 |
display mpm forwarding-table |
3-4 |
display mpm group |
3-5 |
display msdp brief |
6-2 |
display msdp peer-status |
6-3 |
display msdp sa-cache |
6-4 |
display msdp sa-count |
6-5 |
display multicast forwarding-table |
3-7 |
display multicast routing-table |
3-9 |
display nat address-group |
NAT-URPF-VPLS |
1-1 |
display nat aging-time |
NAT-URPF-VPLS |
1-1 |
display nat blacklist |
NAT-URPF-VPLS |
1-2 |
display nat outbound |
NAT-URPF-VPLS |
1-3 |
display nat server |
NAT-URPF-VPLS |
1-4 |
display nat statistics |
NAT-URPF-VPLS |
1-5 |
display ntp-service sessions |
System Managment |
7-2 |
display ntp-service status |
System Managment |
7-2 |
display ntp-service trace |
System Managment |
7-4 |
display ospf abr-asbr |
Routing Protocol |
3-11 |
display ospf abr-summary |
Routing Protocol |
3-28 |
display ospf asbr-summary |
Routing Protocol |
3-12 |
display ospf brief |
Routing Protocol |
3-13 |
display ospf cumulative |
Routing Protocol |
3-15 |
display ospf error |
Routing Protocol |
3-17 |
display ospf interface |
Routing Protocol |
3-19 |
display ospf lsdb |
Routing Protocol |
3-21 |
display ospf nexthop |
Routing Protocol |
3-23 |
display ospf peer |
Routing Protocol |
3-24 |
display ospf request-queue |
Routing Protocol |
3-25 |
display ospf retrans-queue |
Routing Protocol |
3-26 |
display ospf routing |
Routing Protocol |
3-27 |
display ospf vlink |
Routing Protocol |
3-29 |
display password-control |
Getting Started |
2-1 |
display password-control blacklist |
Getting Started |
2-2 |
display password-control super |
Getting Started |
2-2 |
display pim bsr-info |
5-8 |
display pim interface |
5-8 |
display pim neighbor |
5-10 |
display pim routing-table |
5-11 |
display pim rp-info |
5-12 |
display poe interface |
PoE |
1-1 |
display poe interface power |
PoE |
1-2 |
display poe pse |
PoE |
1-3 |
display poe slot |
PoE |
1-4 |
display poe-power ac-input state |
PoE |
2-1 |
display poe-power alarm |
PoE |
2-2 |
display poe-power dc-output state |
PoE |
2-3 |
display poe-power dc-output value |
PoE |
2-3 |
display poe-power switch state |
PoE |
2-4 |
display port |
Port |
1-8 |
display port vlan-vpn |
VLAN-QinQ |
5-1 |
display port-isolate group |
Port |
6-3 |
display power |
System Managment |
3-6 |
display protocol-vlan interface |
VLAN-QinQ |
1-9 |
display qos conform-level |
QoS/ACL |
2-2 |
display qos cos-drop-precedence-map |
QoS/ACL |
2-3 |
display qos cos-local-precedence-map |
QoS/ACL |
2-4 |
display qos-interface all |
QoS/ACL |
2-4 |
display qos-interface drop-mode |
QoS/ACL |
2-6 |
display qos-interface mirrored-to |
QoS/ACL |
2-6 |
display qos-interface queue-scheduler |
QoS/ACL |
2-7 |
display qos-interface traffic-limit |
QoS/ACL |
2-8 |
display qos-interface traffic-priority |
QoS/ACL |
2-9 |
display qos-interface traffic-redirect |
QoS/ACL |
2-9 |
display qos-interface traffic-shape |
QoS/ACL |
2-10 |
display qos-interface traffic-statistic |
QoS/ACL |
2-11 |
display qos-vlan all |
QoS/ACL |
2-11 |
display qos-vlan traffic-limit |
QoS/ACL |
2-12 |
display qos-vlan traffic-priority |
QoS/ACL |
2-13 |
display qos-vlan traffic-redirect |
QoS/ACL |
2-14 |
display radius |
Security |
2-25 |
display radius nas-ip |
Security |
2-27 |
display radius statistics |
Security |
2-27 |
display rip |
Routing Protocol |
2-2 |
display rip vpn-instance |
MPLS |
2-11 |
display rmon alarm |
System Managment |
6-1 |
display rmon event |
System Managment |
6-2 |
display rmon eventlog |
System Managment |
6-3 |
display rmon history |
System Managment |
6-4 |
display rmon prialarm |
System Managment |
6-5 |
display rmon statistics |
System Managment |
6-7 |
display route-policy |
Routing Protocol |
6-8 |
display rpr defect |
Port |
4-6 |
display rpr fairness |
Port |
4-7 |
display rpr protection |
Port |
4-9 |
display rpr rs-table |
Port |
4-11 |
display rpr statistics |
Port |
4-12 |
display rpr timers |
Port |
4-12 |
display rpr topology |
Port |
4-13 |
display rsa local-key-pair public |
System Managment |
8-2 |
display rsa peer-public-key |
System Managment |
8-3 |
display saved-configuration |
System Managment |
1-16 |
display schedule reboot |
System Managment |
3-7 |
display snmp-agent |
System Managment |
5-1 |
display snmp-agent community |
System Managment |
5-1 |
display snmp-agent group |
System Managment |
5-2 |
display snmp-agent mib-view |
System Managment |
5-3 |
display snmp-agent statistics |
System Managment |
5-5 |
display snmp-agent sys-info |
System Managment |
5-7 |
display snmp-agent usm-user |
System Managment |
5-8 |
display ssh server |
System Managment |
8-4 |
display ssh server-info |
System Managment |
8-16 |
display ssh user-information |
System Managment |
8-4 |
display startup |
System Managment |
1-18 |
display stop-accounting-buffer |
Security |
2-29 |
display stop-accounting-buffer hwtacacs-scheme |
Security |
2-52 |
display stp |
STP |
1-4 |
display stp region-configuration |
STP |
1-6 |
display stp tc |
STP |
1-7 |
display supervision-module information |
PoE |
2-4 |
display supervlan |
VLAN-QinQ |
3-1 |
display switchover state |
Reliability |
2-1 |
display tcp statistics |
Network Protocol |
7-10 |
display tcp status |
Network Protocol |
7-12 |
display this |
System Managment |
1-18 |
display time-range |
QoS/ACL |
1-6 |
display traffic-params |
QoS/ACL |
2-14 |
display trapbuffer |
System Managment |
4-38 |
display trap-to-cpu |
VLAN-QinQ |
1-1 |
display udp statistics |
Network Protocol |
7-13 |
display urpf |
NAT-URPF-VPLS |
2-1 |
display user-interface |
Getting Started |
1-7 |
display users |
Getting Started |
1-9 |
display users |
System Managment |
4-25 |
display version |
System Managment |
4-26 |
display vlan |
VLAN-QinQ |
1-3 |
display vlan-acl-member-ports |
QoS/ACL |
4-10 |
display vlan-protocol-vlan vlan |
VLAN-QinQ |
1-10 |
display vrrp |
Reliability |
1-1 |
display vrrp statistics |
Reliability |
1-3 |
display vrrp summary |
Reliability |
1-4 |
display vsi |
NAT-URPF-VPLS |
3-5 |
display xbar |
Reliability |
2-2 |
dns domain |
Network Protocol |
6-5 |
dns resolve |
Network Protocol |
6-6 |
dns server |
Network Protocol |
6-7 |
dns-list |
Network Protocol |
4-22 |
domain |
Security |
2-9 |
domain-authentication-mode |
Routing Protocol |
4-11 |
domain-id |
MPLS |
2-12 |
domain-name |
Network Protocol |
4-23 |
dot1x |
Security |
1-4 |
dot1x authentication-method |
Security |
1-5 |
dot1x dhcp-launch |
Security |
1-6 |
dot1x guest-vlan |
Security |
1-7 |
dot1x max-user |
Security |
1-8 |
dot1x port-control |
Security |
1-9 |
dot1x port-method |
Security |
1-10 |
dot1x quiet-period |
Security |
1-11 |
dot1x retry |
Security |
1-12 |
dot1x supp-proxy-check |
Security |
1-13 |
dot1x timer |
Security |
1-14 |
drop-mode |
QoS/ACL |
2-15 |
dscp |
QoS/ACL |
2-16 |
duplex |
Port |
1-9 |
duplex port |
NAT-URPF-VPLS |
1-30 |
enable snmp trap |
System Managment |
5-9 |
execute |
System Managment |
1-4 |
exit |
System Managment |
8-24 |
exp |
QoS/ACL |
2-18 |
expired |
Network Protocol |
4-23 |
file prompt |
System Managment |
1-5 |
filter-policy export |
Routing Protocol |
2-4 |
Routing Protocol |
3-30 |
Routing Protocol |
3-31 |
Routing Protocol |
4-12 |
Routing Protocol |
5-27 |
Routing Protocol |
6-9 |
7-10 |
MPLS |
2-13 |
filter-policy import |
Routing Protocol |
2-4 |
Routing Protocol |
3-32 |
Routing Protocol |
3-33 |
Routing Protocol |
4-13 |
Routing Protocol |
5-28 |
Routing Protocol |
6-10 |
7-11 |
MPLS |
2-14 |
fixdisk |
System Managment |
1-5 |
flag |
Port |
3-6 |
flag |
Port |
4-15 |
flow port |
NAT-URPF-VPLS |
1-30 |
flow-control |
Getting Started |
1-10 |
flow-control |
Port |
1-10 |
flow-template user-defined |
QoS/ACL |
1-8 |
flow-template user-defined template-info |
QoS/ACL |
1-8 |
format |
System Managment |
1-6 |
frame-format |
Port |
3-8 |
frame-format |
Port |
4-16 |
free user-interface |
Getting Started |
1-10 |
ftp |
System Managment |
1-33 |
ftp disconnect |
System Managment |
1-22 |
ftp server enable |
System Managment |
1-23 |
ftp timeout |
System Managment |
1-24 |
garp timer |
VLAN-QinQ |
2-2 |
garp timer leaveall |
VLAN-QinQ |
2-4 |
gateway-list |
Network Protocol |
4-24 |
get |
System Managment |
1-34 |
get |
System Managment |
8-24 |
gratuitous-arp-learning enable |
Network Protocol |
2-9 |
group |
Routing Protocol |
5-29 |
group |
MPLS |
2-15 |
gvrp |
VLAN-QinQ |
2-6 |
gvrp registration |
VLAN-QinQ |
2-7 |
header |
Getting Started |
1-11 |
help |
System Managment |
8-25 |
hgmpport |
NAT-URPF-VPLS |
1-8 |
hgmpserver |
NAT-URPF-VPLS |
1-8 |
history-command max-size |
Getting Started |
1-13 |
host-route |
Routing Protocol |
2-5 |
hwtacacs nas-ip |
Security |
2-53 |
hwtacacs scheme |
Security |
2-54 |
idle-cut |
Security |
2-10 |
idle-timeout |
Getting Started |
1-14 |
ids-acl |
Port |
5-1 |
if-match { acl | ip-prefix } |
Routing Protocol |
6-11 |
if-match as-path |
Routing Protocol |
6-12 |
if-match community |
Routing Protocol |
6-13 |
if-match cost |
Routing Protocol |
6-14 |
if-match interface |
Routing Protocol |
6-14 |
if-match ip next-hop |
Routing Protocol |
6-15 |
if-match mpls-label |
MPLS |
2-15 |
if-match tag |
Routing Protocol |
6-16 |
if-match vpn-target |
MPLS |
2-16 |
igmp enable |
4-4 |
igmp fast-leave |
4-5 |
igmp group-limit |
4-7 |
igmp group-policy |
4-8 |
igmp host-join port |
4-9 |
igmp host-join vlan |
4-9 |
igmp lastmember-queryinterval |
4-10 |
igmp max-response-time |
4-11 |
igmp proxy |
4-15 |
igmp robust-count |
4-12 |
igmp timer other-querier-present |
4-12 |
igmp timer query |
4-13 |
igmp version |
4-14 |
igmp-snooping |
1-4 |
igmp-snooping fast-leave |
1-6 |
igmp-snooping group-policy |
1-9 |
igmp-snooping host-aging-time |
1-10 |
igmp-snooping max-response-time |
1-10 |
igmp-snooping mrouter port |
1-13 |
igmp-snooping mrouter vlan |
1-14 |
igmp-snooping nonflooding-enable |
1-11 |
igmp-snooping router-aging-time |
1-12 |
ignore-lsp-checksum-error |
Routing Protocol |
4-13 |
import-route |
Routing Protocol |
2-6 |
import-route |
Routing Protocol |
3-34 |
import-route |
Routing Protocol |
4-14 |
import-route |
Routing Protocol |
5-29 |
import-route |
7-12 |
import-route |
MPLS |
2-17 |
import-route isis level-2 into level-1 |
Routing Protocol |
4-15 |
import-route-limit |
Routing Protocol |
3-35 |
import-source |
6-5 |
info-center channel name |
System Managment |
4-39 |
info-center console channel |
System Managment |
4-40 |
info-center enable |
System Managment |
4-41 |
info-center logbuffer |
System Managment |
4-41 |
info-center logfile |
System Managment |
4-42 |
info-center loghost |
System Managment |
4-43 |
info-center loghost source |
System Managment |
4-44 |
info-center monitor channel |
System Managment |
4-45 |
info-center snmp channel |
System Managment |
4-45 |
info-center source |
System Managment |
4-46 |
info-center timestamp |
System Managment |
4-52 |
info-center trapbuffer |
System Managment |
4-53 |
instance |
STP |
1-8 |
interface |
Port |
1-11 |
interface pos |
Port |
3-8 |
interface vlan-interface |
VLAN-QinQ |
1-4 |
ip address |
Network Protocol |
1-3 |
ip as-path-acl |
Routing Protocol |
6-16 |
ip binding vpn-instance |
MPLS |
2-18 |
ip community-list |
Routing Protocol |
6-17 |
ip host |
Network Protocol |
1-5 |
ip host |
Network Protocol |
6-1 |
ip ip-prefix |
Routing Protocol |
6-18 |
ip managed-multicast |
3-11 |
ip pool |
Security |
2-11 |
ip relay address |
Network Protocol |
4-37 |
ip route-static |
Routing Protocol |
1-17 |
ip route-static vpn-instance |
MPLS |
2-19 |
ip userlog nat |
NAT-URPF-VPLS |
1-16 |
ip userlog nat active-time |
NAT-URPF-VPLS |
1-17 |
ip userlog nat export host |
NAT-URPF-VPLS |
1-18 |
ip userlog nat export source-ip |
NAT-URPF-VPLS |
1-18 |
ip userlog nat export version |
NAT-URPF-VPLS |
1-19 |
ip userlog nat mode flow-begin |
NAT-URPF-VPLS |
1-19 |
ip vpn-instance |
MPLS |
2-20 |
ip-protect enable |
Network Protocol |
1-6 |
ipv4-family |
MPLS |
2-20 |
ipv4-family multicast |
7-13 |
isis |
Routing Protocol |
4-16 |
isis authentication-mode |
Routing Protocol |
4-17 |
isis circuit-level |
Routing Protocol |
4-18 |
isis cost |
Routing Protocol |
4-19 |
isis dis-priority |
Routing Protocol |
4-19 |
isis enable |
Routing Protocol |
4-20 |
isis mesh-group |
Routing Protocol |
4-21 |
isis timer csnp |
Routing Protocol |
4-22 |
isis timer hello |
Routing Protocol |
4-23 |
isis timer hello minimal |
Routing Protocol |
4-23 |
isis timer holding-multiplier |
Routing Protocol |
4-24 |
isis timer lsp |
Routing Protocol |
4-25 |
isis timer retransmit |
Routing Protocol |
4-27 |
is-level |
Routing Protocol |
4-28 |
isolate-user-vlan |
VLAN-QinQ |
4-3 |
isolate-user-vlan enable |
VLAN-QinQ |
4-4 |
jumboframe enable |
Port |
1-12 |
key |
Security |
2-30 |
key |
Security |
2-54 |
l2 binding vsi |
NAT-URPF-VPLS |
3-6 |
l2vpn-family |
MPLS |
3-14 |
lacp enable |
Port |
2-8 |
lacp port-priority |
Port |
2-9 |
lacp system-priority |
Port |
2-10 |
language-mode |
Getting Started |
1-14 |
lanswitch |
NAT-URPF-VPLS |
1-9 |
lcd |
System Managment |
1-35 |
level |
Security |
2-12 |
link-aggregation |
Port |
2-10 |
link-aggregation group agg-id description |
Port |
2-11 |
link-aggregation group agg-id mode |
Port |
2-12 |
link-status hold |
Port |
1-10 |
load lswprogram |
NAT-URPF-VPLS |
1-10 |
local-precedence |
QoS/ACL |
2-19 |
local-server |
Security |
2-31 |
local-user |
Security |
2-13 |
local-user |
System Managment |
1-24 |
local-user multicast |
3-11 |
local-user password-display-mode |
Security |
2-14 |
System Managment |
1-25 |
lock |
Getting Started |
1-15 |
Lock port |
NAT-URPF-VPLS |
1-31 |
log-peer-change |
Routing Protocol |
4-28 |
loop port |
NAT-URPF-VPLS |
1-21 |
loopback |
Port |
1-13 |
loopback |
Port |
3-9 |
ls |
System Managment |
1-35 |
ls |
System Managment |
8-25 |
lsp-trigger |
MPLS |
1-5 |
mac-address |
System Managment |
2-2 |
mac-address |
NAT-URPF-VPLS |
3-8 |
mac-address max-mac-count |
System Managment |
2-4 |
mac-address max-mac-count alarm |
System Managment |
2-5 |
mac-address max-mac-count enable forward |
System Managment |
2-6 |
mac-address max-mac-count max-mac-num |
System Managment |
2-7 |
mac-address timer |
System Managment |
2-8 |
mac-table limit |
NAT-URPF-VPLS |
3-9 |
md5-compatible |
Routing Protocol |
4-29 |
mdi |
Port |
1-13 |
mirrored-to |
QoS/ACL |
2-20 |
mirrored-to |
QoS/ACL |
4-1 |
mirroring-group |
QoS/ACL |
2-22 |
mkdir |
System Managment |
1-6 |
mkdir |
System Managment |
1-36 |
mkdir |
System Managment |
8-26 |
modem |
Getting Started |
1-15 |
modem auto-answer |
Getting Started |
1-16 |
modem timer answer |
Getting Started |
1-17 |
modify multiaddr |
NAT-URPF-VPLS |
1-32 |
modify uniaddr |
NAT-URPF-VPLS |
1-33 |
more |
System Managment |
1-7 |
move |
System Managment |
1-8 |
mpls |
MPLS |
1-6 |
mpls l2vc |
MPLS |
3-9 |
mpls l2vpn |
MPLS |
3-14 |
mpls l2vpn encapsulation |
MPLS |
3-15 |
mpls ldp |
MPLS |
1-20 |
mpls ldp enable |
MPLS |
1-20 |
mpls ldp hops-count |
MPLS |
1-21 |
mpls ldp loop-detect |
MPLS |
1-22 |
mpls ldp password |
MPLS |
1-23 |
mpls ldp path-vectors |
MPLS |
1-23 |
mpls ldp remote-peer |
MPLS |
1-24 |
mpls ldp reset-session |
MPLS |
1-25 |
mpls ldp timer |
MPLS |
1-25 |
mpls ldp transport-ip |
MPLS |
1-27 |
mpls lsr-id |
MPLS |
1-7 |
msdp |
6-6 |
msdp-tracert |
6-7 |
mtu |
Port |
3-10 |
mtu |
MPLS |
3-16 |
mtu |
NAT-URPF-VPLS |
3-9 |
multicast |
3-12 |
multicast route-limit |
3-13 |
multicast routing-enable |
3-14 |
multicast-suppression |
Port |
1-14 |
3-15 |
name |
VLAN-QinQ |
1-5 |
name |
Security |
2-14 |
nas-ip |
Security |
2-32 |
nas-ip |
Security |
2-55 |
nat address-group |
NAT-URPF-VPLS |
1-6 |
nat aging-time |
NAT-URPF-VPLS |
1-7 |
nat blacklist |
NAT-URPF-VPLS |
1-7 |
nat ftp server global |
NAT-URPF-VPLS |
1-10 |
nat outbound |
NAT-URPF-VPLS |
1-11 |
nat server |
NAT-URPF-VPLS |
1-13 |
nbns-list |
Network Protocol |
4-25 |
nesting-vpn |
MPLS |
2-22 |
netbios-type |
Network Protocol |
4-26 |
network |
Network Protocol |
4-27 |
network |
Routing Protocol |
2-7 |
network |
Routing Protocol |
3-36 |
network |
Routing Protocol |
5-30 |
network |
7-14 |
network |
MPLS |
2-22 |
network-entity |
Routing Protocol |
4-30 |
nssa |
Routing Protocol |
3-37 |
ntp-service access |
System Managment |
7-4 |
ntp-service authentication enable |
System Managment |
7-5 |
ntp-service authentication-keyid |
System Managment |
7-6 |
ntp-service broadcast-client |
System Managment |
7-6 |
ntp-service broadcast-server |
System Managment |
7-7 |
ntp-service max-dynamic-sessions |
System Managment |
7-8 |
ntp-service multicast-client |
System Managment |
7-9 |
ntp-service multicast-server |
System Managment |
7-10 |
ntp-service refclock-master |
System Managment |
7-11 |
ntp-service reliable authentication-keyid |
System Managment |
7-11 |
ntp-service source-interface |
System Managment |
7-12 |
ntp-service unicast-peer |
System Managment |
7-13 |
ntp-service unicast-server |
System Managment |
7-14 |
open |
System Managment |
1-36 |
option |
Network Protocol |
4-28 |
originating-rp |
6-9 |
ospf |
Routing Protocol |
3-37 |
ospf |
MPLS |
2-23 |
ospf authentication-mode |
Routing Protocol |
3-38 |
ospf cost |
Routing Protocol |
3-39 |
ospf dr-priority |
Routing Protocol |
3-40 |
ospf mib-binding |
Routing Protocol |
3-41 |
ospf mtu-enable |
Routing Protocol |
3-41 |
ospf network-type |
Routing Protocol |
3-42 |
ospf timer dead |
Routing Protocol |
3-43 |
ospf timer hello |
Routing Protocol |
3-44 |
ospf timer poll |
Routing Protocol |
3-45 |
ospf timer retransmit |
Routing Protocol |
3-46 |
ospf trans-delay |
Routing Protocol |
3-46 |
packet-filter |
QoS/ACL |
1-11 |
packet-filter |
QoS/ACL |
4-2 |
parity |
Getting Started |
1-17 |
passive |
System Managment |
1-37 |
password |
Getting Started |
2-3 |
password |
Security |
2-15 |
password |
System Managment |
1-26 |
password-control |
Getting Started |
2-4 |
password-control enable |
Getting Started |
2-6 |
Getting Started |
2-7 |
peer |
Routing Protocol |
2-8 |
peer |
6-10 |
peer |
NAT-URPF-VPLS |
3-10 |
peer advertise-community |
Routing Protocol |
5-31 |
7-14 |
MPLS |
2-25 |
peer allow-as-loop |
Routing Protocol |
5-31 |
7-15 |
MPLS |
2-26 |
peer as-number |
Routing Protocol |
5-32 |
peer as-number |
MPLS |
2-26 |
peer as-path-acl export |
Routing Protocol |
5-32 |
7-16 |
MPLS |
2-27 |
peer as-path-acl import |
Routing Protocol |
5-33 |
7-17 |
MPLS |
2-28 |
peer connect-interface |
Routing Protocol |
5-34 |
MPLS |
2-29 |
peer default-route-advertise |
Routing Protocol |
5-35 |
MPLS |
2-29 |
peer default-route-advertise vpn-instance |
MPLS |
2-30 |
peer description |
Routing Protocol |
5-35 |
peer description |
6-11 |
peer description |
MPLS |
2-31 |
peer ebgp-max-hop |
Routing Protocol |
5-36 |
peer ebgp-max-hop |
MPLS |
2-31 |
peer enable |
Routing Protocol |
5-37 |
peer enable |
7-17 |
peer enable |
MPLS |
2-32 |
peer enable |
MPLS |
3-16 |
peer filter-policy export |
Routing Protocol |
5-37 |
7-18 |
MPLS |
2-33 |
peer filter-policy import |
Routing Protocol |
5-38 |
7-19 |
MPLS |
2-33 |
peer graceful-restart |
Routing Protocol |
5-39 |
peer group |
Routing Protocol |
5-40 |
peer group |
7-20 |
peer group |
MPLS |
2-34 |
peer ip-prefix export |
Routing Protocol |
5-40 |
7-21 |
MPLS |
2-35 |
peer ip-prefix import |
Routing Protocol |
5-41 |
7-21 |
MPLS |
2-36 |
peer label-route-capability |
MPLS |
2-36 |
peer mesh-group |
6-11 |
peer minimum-ttl |
6-12 |
peer next-hop-local |
Routing Protocol |
5-42 |
7-22 |
MPLS |
2-37 |
peer password |
Routing Protocol |
5-43 |
peer password |
MPLS |
2-38 |
peer public-as-only |
Routing Protocol |
5-44 |
7-23 |
MPLS |
2-39 |
peer reflect-client |
Routing Protocol |
5-45 |
7-24 |
MPLS |
2-39 |
peer request-sa-enable |
6-13 |
peer restart-timer |
Routing Protocol |
5-44 |
peer route-policy export |
Routing Protocol |
5-46 |
7-24 |
MPLS |
2-40 |
peer route-policy import |
Routing Protocol |
5-46 |
7-25 |
MPLS |
2-41 |
peer route-update-interval |
Routing Protocol |
5-47 |
MPLS |
2-42 |
peer sa-cache-maximum |
6-13 |
peer sa-policy |
6-14 |
peer sa-request-policy |
6-15 |
peer shutdown |
Routing Protocol |
5-48 |
peer timer |
Routing Protocol |
5-48 |
peer timer |
MPLS |
2-42 |
peer upe |
MPLS |
2-43 |
peer vpn-instance enable |
MPLS |
2-44 |
peer vpn-instance group |
MPLS |
2-44 |
peer vpn-instance route-policy import |
MPLS |
2-45 |
peer vpn-instance substitute-as |
MPLS |
2-46 |
peer-public-key end |
System Managment |
8-5 |
pim |
5-13 |
pim bsr-boundary |
5-14 |
pim dm |
5-15 |
pim neighbor-limit |
5-16 |
pim neighbor-policy |
5-16 |
pim sm |
5-17 |
pim timer hello |
5-18 |
ping |
System Managment |
4-29 |
poe enable |
PoE |
1-5 |
poe max-power |
PoE |
1-5 |
poe max-power slot |
PoE |
1-6 |
poe mode |
PoE |
1-7 |
poe priority |
PoE |
1-7 |
poe-power input-thresh lower |
PoE |
2-6 |
poe-power input-thresh upper |
PoE |
2-6 |
poe-power output-thresh lower |
PoE |
2-7 |
poe-power output-thresh upper |
PoE |
2-7 |
policy vpn-target |
MPLS |
2-47 |
port |
VLAN-QinQ |
1-8 |
port access vlan |
Port |
1-15 |
port can-access vlan-acl |
QoS/ACL |
4-10 |
port hybrid protocol-vlan vlan |
VLAN-QinQ |
1-11 |
port hybrid pvid vlan |
Port |
1-16 |
port hybrid vlan |
Port |
1-17 |
port link-aggregation group |
Port |
2-13 |
port link-type |
Port |
1-18 |
port trunk mpls vlan |
MPLS |
2-47 |
port trunk permit vlan |
Port |
1-19 |
port trunk pvid vlan |
Port |
1-20 |
Port |
6-1 |
Port |
6-2 |
port-isolate uplink-port group |
Port |
6-1 |
port-mode |
Port |
1-18 |
port-type |
Port |
4-16 |
pos access vlan |
Port |
3-10 |
ppp timer negotiate |
Port |
3-11 |
preference |
Routing Protocol |
2-8 |
preference |
Routing Protocol |
3-47 |
preference |
Routing Protocol |
4-31 |
preference |
Routing Protocol |
5-49 |
preference |
7-26 |
preference |
MPLS |
2-48 |
primary accounting |
Security |
2-33 |
Security |
2-56 |
primary authentication |
Security |
2-34 |
Security |
2-57 |
primary authorization |
Security |
2-58 |
priority |
QoS/ACL |
2-24 |
protocol inbound |
Getting Started |
1-18 |
protocol inbound |
System Managment |
8-6 |
protocol-vlan |
VLAN-QinQ |
1-12 |
public-key-code begin |
System Managment |
8-7 |
public-key-code end |
System Managment |
8-8 |
put |
System Managment |
1-37 |
put |
System Managment |
8-26 |
pwd |
System Managment |
1-8 |
pwd |
System Managment |
1-38 |
pwd |
System Managment |
8-27 |
pwsignal |
NAT-URPF-VPLS |
3-11 |
qos |
NAT-URPF-VPLS |
3-11 |
qos conform-level |
QoS/ACL |
2-24 |
QoS/ACL |
2-25 |
QoS/ACL |
2-27 |
query active-configuration |
NAT-URPF-VPLS |
1-33 |
query address |
NAT-URPF-VPLS |
1-34 |
query gatewayip |
NAT-URPF-VPLS |
1-35 |
query hgmpport-mode |
NAT-URPF-VPLS |
1-11 |
query ip address |
NAT-URPF-VPLS |
1-22 |
query link-aggregation |
NAT-URPF-VPLS |
1-36 |
query manageip |
NAT-URPF-VPLS |
1-37 |
query mirror |
NAT-URPF-VPLS |
1-37 |
query multiaddr |
NAT-URPF-VPLS |
1-38 |
query port |
NAT-URPF-VPLS |
1-12 |
query port lockstate |
NAT-URPF-VPLS |
1-39 |
query rmon |
NAT-URPF-VPLS |
1-40 |
query saved-configuration |
NAT-URPF-VPLS |
1-42 |
query system |
NAT-URPF-VPLS |
1-43 |
query uniaddr port |
NAT-URPF-VPLS |
1-44 |
query used addrnum |
NAT-URPF-VPLS |
1-45 |
query vdsllink |
NAT-URPF-VPLS |
1-45 |
query vlan |
NAT-URPF-VPLS |
1-13 |
query vlanstate |
NAT-URPF-VPLS |
1-46 |
queue |
QoS/ACL |
2-29 |
queue-scheduler |
QoS/ACL |
2-30 |
quick-ping enable |
System Managment |
4-3 |
quit |
Getting Started |
1-19 |
quit |
System Managment |
1-38 |
quit |
System Managment |
8-16 |
quit |
System Managment |
8-27 |
radius nas-ip |
Security |
2-35 |
radius scheme |
Security |
2-36 |
radius-scheme |
Security |
2-17 |
reboot |
System Managment |
3-7 |
reflect between-clients |
Routing Protocol |
5-50 |
7-27 |
MPLS |
2-49 |
reflector cluster-id |
Routing Protocol |
5-51 |
7-28 |
MPLS |
2-49 |
refresh bgp |
Routing Protocol |
5-51 |
refresh bgp multicast |
7-27 |
region-name |
STP |
1-9 |
register-policy |
5-19 |
remotehelp |
System Managment |
1-39 |
remote-ip |
MPLS |
1-28 |
remove |
System Managment |
8-28 |
rename |
System Managment |
1-9 |
rename |
System Managment |
8-28 |
reset |
Routing Protocol |
2-9 |
reset acl counter |
QoS/ACL |
1-13 |
reset arp |
Network Protocol |
2-10 |
reset bgp |
Routing Protocol |
5-52 |
reset bgp flap-info |
Routing Protocol |
5-53 |
reset bgp group |
Routing Protocol |
5-53 |
reset counters interface |
Port |
1-21 |
Port |
4-17 |
reset counters interface pos |
Port |
3-12 |
reset dampening |
Routing Protocol |
5-54 |
reset dhcp server conflict |
Network Protocol |
4-28 |
reset dhcp server ip-in-use |
Network Protocol |
4-29 |
reset dhcp server statistics |
Network Protocol |
4-30 |
reset dns dynamic-host |
Network Protocol |
6-7 |
reset dot1x statistics |
Security |
1-16 |
reset garp statistics |
VLAN-QinQ |
2-4 |
reset hwtacacs statistics |
Security |
2-58 |
reset igmp group |
4-15 |
reset igmp-snooping statistics |
1-12 |
reset ip statistics |
Network Protocol |
7-14 |
reset isis all |
Routing Protocol |
4-31 |
reset isis peer |
Routing Protocol |
4-32 |
reset lacp statistics |
Port |
2-13 |
reset lanswitch |
NAT-URPF-VPLS |
1-16 |
reset logbuffer |
System Managment |
4-54 |
reset mac-address |
System Managment |
2-9 |
reset msdp peer |
6-16 |
reset msdp sa-cache |
6-17 |
reset msdp statistics |
6-17 |
reset multicast forwarding-table |
3-16 |
reset multicast routing-table |
3-17 |
reset nat |
NAT-URPF-VPLS |
1-15 |
reset ospf |
Routing Protocol |
3-48 |
reset password-control blacklist |
Getting Started |
2-9 |
reset password-control history-record |
Getting Started |
2-8 |
reset password-control history-record super |
Getting Started |
2-8 |
reset pim neighbor |
5-20 |
reset pim routing-table |
5-20 |
reset radius statistics |
Security |
2-37 |
reset recycle-bin |
System Managment |
1-9 |
reset saved-configuration |
System Managment |
1-19 |
reset stop-accounting-buffer |
Security |
2-37 |
Security |
2-59 |
reset stp |
STP |
1-10 |
reset tcp statistics |
Network Protocol |
7-15 |
reset traffic-statistic |
QoS/ACL |
2-32 |
reset trapbuffer |
System Managment |
4-54 |
reset udp statistics |
Network Protocol |
7-15 |
reset urpf statistic |
NAT-URPF-VPLS |
2-2 |
reset vrrp statistics |
Reliability |
1-5 |
retry |
Security |
2-39 |
retry realtime-accounting |
Security |
2-39 |
retry stop-accounting |
Security |
2-40 |
Security |
2-60 |
return |
Getting Started |
1-19 |
revision-level |
STP |
1-11 |
rip |
Routing Protocol |
2-10 |
rip authentication-mode |
Routing Protocol |
2-10 |
rip input |
Routing Protocol |
2-12 |
rip metricin |
Routing Protocol |
2-12 |
rip metricout |
Routing Protocol |
2-13 |
rip output |
Routing Protocol |
2-14 |
rip split-horizon |
Routing Protocol |
2-14 |
rip version |
Routing Protocol |
2-15 |
rip work |
Routing Protocol |
2-16 |
rmdir |
System Managment |
1-10 |
rmdir |
System Managment |
1-39 |
rmdir |
System Managment |
8-29 |
rmon alarm |
System Managment |
6-8 |
rmon event |
System Managment |
6-10 |
rmon history |
System Managment |
6-11 |
rmon prialarm |
System Managment |
6-11 |
rmon statistics |
System Managment |
6-14 |
route-distinguisher |
MPLS |
2-50 |
route-policy |
Routing Protocol |
6-19 |
router id |
Routing Protocol |
3-49 |
router route-limit |
Routing Protocol |
7-1 |
router VRF-limit |
Routing Protocol |
7-1 |
route-rely |
Routing Protocol |
8-1 |
route-tag |
MPLS |
2-51 |
routing-table limit |
MPLS |
2-54 |
rpr admin-request |
Port |
4-17 |
rpr cos-precedence-map |
Port |
4-20 |
rpr default-rs |
Port |
4-19 |
rpr echo |
Port |
4-18 |
rpr protect-mode |
Port |
4-21 |
rpr rate-limit |
Port |
4-21 |
rpr reversion-mode |
Port |
4-22 |
rpr static-rs |
Port |
4-23 |
rpr station-name |
Port |
4-24 |
rpr timer |
Port |
4-24 |
rpr weight |
Port |
4-25 |
rsa local-key-pair create |
System Managment |
8-9 |
rsa local-key-pair destroy |
System Managment |
8-10 |
System Managment |
8-11 |
rule |
QoS/ACL |
1-13 |
save |
System Managment |
1-20 |
save lanswitch |
NAT-URPF-VPLS |
1-17 |
schedule reboot at |
System Managment |
3-8 |
schedule reboot delay |
System Managment |
3-9 |
scheme |
Security |
2-16 |
scramble |
Port |
3-12 |
screen-length |
Getting Started |
1-20 |
sdh threshold |
Port |
4-26 |
search multiaddr |
NAT-URPF-VPLS |
1-47 |
search uniaddr |
NAT-URPF-VPLS |
1-48 |
secondary accounting |
Security |
2-41 |
Security |
2-60 |
secondary authentication |
Security |
2-42 |
Security |
2-61 |
secondary authorization |
Security |
2-62 |
self-service-url |
Security |
2-18 |
send |
Getting Started |
1-21 |
server-type |
Security |
2-43 |
service-type |
Security |
2-19 |
service-type |
System Managment |
1-27 |
service-type multicast |
2-1 |
service-type telnet |
Getting Started |
1-21 |
set address agedtime |
NAT-URPF-VPLS |
1-49 |
set authentication password |
Getting Started |
1-22 |
set config-flash |
NAT-URPF-VPLS |
1-50 |
set egress |
Port |
7-1 |
set gatewayip |
NAT-URPF-VPLS |
1-51 |
set ip address |
NAT-URPF-VPLS |
1-23 |
set lanswitch |
NAT-URPF-VPLS |
1-17 |
set link-aggregation |
NAT-URPF-VPLS |
1-51 |
set loop-test |
NAT-URPF-VPLS |
1-52 |
set lswconfig |
NAT-URPF-VPLS |
1-18 |
set lswname |
NAT-URPF-VPLS |
1-18 |
set mac |
NAT-URPF-VPLS |
1-23 |
set manageip |
NAT-URPF-VPLS |
1-53 |
set mirror monitor-port |
NAT-URPF-VPLS |
1-54 |
set port |
NAT-URPF-VPLS |
1-24 |
set port |
NAT-URPF-VPLS |
1-54 |
set priority |
NAT-URPF-VPLS |
1-55 |
set qos_weight |
NAT-URPF-VPLS |
1-56 |
set superview_password |
NAT-URPF-VPLS |
1-56 |
set sysname |
NAT-URPF-VPLS |
1-57 |
set vdsllink |
NAT-URPF-VPLS |
1-57 |
set vlan |
NAT-URPF-VPLS |
1-25 |
set vlanid |
NAT-URPF-VPLS |
1-58 |
set workmode |
NAT-URPF-VPLS |
1-26 |
set-overload |
Routing Protocol |
4-32 |
sftp |
System Managment |
8-29 |
sftp server enable |
System Managment |
8-20 |
sham-link |
Routing Protocol |
3-51 |
sham-link |
MPLS |
2-55 |
shell |
Getting Started |
1-23 |
shut |
NAT-URPF-VPLS |
3-13 |
shutdown |
Port |
1-21 |
shutdown |
Port |
3-13 |
shutdown |
Port |
4-27 |
shutdown |
VLAN-QinQ |
1-5 |
shutdown |
6-18 |
silent-interface |
Routing Protocol |
3-50 |
silent-interface |
Routing Protocol |
4-33 |
slave auto-update config |
Reliability |
2-2 |
slave restart |
Reliability |
2-3 |
slave switchover |
Reliability |
2-4 |
slave update configuration |
Reliability |
2-4 |
QoS/ACL |
3-2 |
System Managment |
5-10 |
snmp-agent group |
QoS/ACL |
3-3 |
snmp-agent group |
System Managment |
5-11 |
snmp-agent local-engineid |
System Managment |
5-12 |
System Managment |
5-12 |
snmp-agent packet max-size |
System Managment |
5-13 |
System Managment |
5-14 |
snmp-agent target-host |
System Managment |
5-15 |
snmp-agent trap enable |
System Managment |
5-16 |
snmp-agent trap enable ldp |
MPLS |
1-7 |
snmp-agent trap enable lsp |
MPLS |
1-8 |
snmp-agent trap enable ospf |
Routing Protocol |
3-51 |
snmp-agent trap life |
System Managment |
5-18 |
snmp-agent trap queue-size |
System Managment |
5-18 |
snmp-agent trap source |
System Managment |
5-19 |
QoS/ACL |
3-4 |
System Managment |
5-20 |
source-policy |
5-21 |
spanning-hub |
NAT-URPF-VPLS |
1-19 |
speed |
Getting Started |
1-24 |
speed |
Port |
1-22 |
speed port |
NAT-URPF-VPLS |
1-59 |
spf-delay-interval |
Routing Protocol |
4-34 |
spf-schedule-interval |
Routing Protocol |
3-52 |
spf-slice-size |
Routing Protocol |
4-34 |
ssh client assign rsa-key |
System Managment |
8-17 |
ssh client first-time enable |
System Managment |
8-17 |
ssh server authentication-retries |
System Managment |
8-11 |
ssh server compatible_ssh1x enable |
System Managment |
8-12 |
ssh server rekey-interval |
System Managment |
8-13 |
ssh server timeout |
System Managment |
8-13 |
ssh user assign rsa-key |
System Managment |
8-14 |
ssh user authentication-type |
System Managment |
8-15 |
ssh user service-type |
System Managment |
8-20 |
ssh2 |
System Managment |
8-18 |
startup saved-configuration |
System Managment |
1-21 |
state |
Security |
2-20 |
state |
Security |
2-44 |
static-bind ip-address |
Network Protocol |
4-30 |
static-bind mac-address |
Network Protocol |
4-31 |
static-lsp egress |
MPLS |
1-8 |
static-lsp egress l2vpn |
MPLS |
3-3 |
static-lsp ingress |
MPLS |
1-9 |
MPLS |
3-4 |
static-lsp transit |
MPLS |
1-10 |
static-lsp transit l2vpn |
MPLS |
3-5 |
static-rp |
5-22 |
static-rpf-peer |
6-18 |
stop-accounting-buffer enable |
Security |
2-45 |
stopbits |
Getting Started |
1-25 |
stp |
STP |
1-11 |
stp bpdu-protection |
STP |
1-12 |
stp bridge-diameter |
STP |
1-13 |
stp config-digest-snooping |
STP |
2-1 |
stp cost |
STP |
1-14 |
stp edged-port |
STP |
1-15 |
stp instance root primary |
STP |
1-17 |
stp instance root secondary |
STP |
1-36 |
stp interface |
STP |
1-18 |
stp interface edged-port |
STP |
1-20 |
stp interface instance cost |
STP |
1-19 |
stp interface instance port priority |
STP |
1-21 |
stp interface loop-protection |
STP |
1-22 |
stp interface mcheck |
STP |
1-24 |
stp interface point-to-point |
STP |
1-25 |
stp interface root-protection |
STP |
1-26 |
stp interface transmit-limit |
STP |
1-27 |
stp loop-protection |
STP |
1-28 |
stp max-hops |
STP |
1-29 |
stp mcheck |
STP |
1-30 |
stp mode |
STP |
1-31 |
stp non-flooding |
STP |
1-32 |
stp pathcost-standard |
STP |
1-33 |
stp point-to-point |
STP |
1-33 |
stp port priority |
STP |
1-34 |
STP |
1-35 |
stp root-protection |
STP |
1-37 |
stp tc-protection |
STP |
1-38 |
stp timer forward-delay |
STP |
1-39 |
stp timer hello |
STP |
1-40 |
stp timer max-age |
STP |
1-41 |
stp timer-factor |
STP |
1-42 |
stp transmit-limit |
STP |
1-43 |
stub |
Routing Protocol |
3-53 |
subvlan |
VLAN-QinQ |
3-2 |
summary |
Routing Protocol |
2-17 |
summary |
Routing Protocol |
4-35 |
summary |
Routing Protocol |
5-54 |
summary |
7-29 |
summary |
MPLS |
2-57 |
super |
Getting Started |
1-26 |
super password |
Getting Started |
1-26 |
supervlan |
VLAN-QinQ |
3-3 |
sysname |
Getting Started |
1-27 |
sysname |
System Managment |
4-4 |
system-view |
Getting Started |
1-28 |
tcp timer fin-timeout |
Network Protocol |
7-16 |
tcp timer syn-timeout |
Network Protocol |
7-16 |
tcp window |
Network Protocol |
7-17 |
telnet |
Getting Started |
1-28 |
temperature-limit |
System Managment |
3-10 |
terminal debugging |
System Managment |
4-55 |
terminal logging |
System Managment |
4-55 |
terminal monitor |
System Managment |
4-56 |
terminal trapping |
System Managment |
4-57 |
tftp get |
System Managment |
1-41 |
tftp put |
System Managment |
1-42 |
threshold |
Port |
3-13 |
timer |
Routing Protocol |
5-55 |
timer |
MPLS |
2-52 |
timer hold |
Port |
3-14 |
timer lsp-generation |
Routing Protocol |
4-26 |
timer lsp-max-age |
Routing Protocol |
4-36 |
timer lsp-refresh |
Routing Protocol |
4-37 |
timer quiet |
Security |
2-45 |
timer quiet |
Security |
2-63 |
timer realtime-accounting |
Security |
2-46 |
Security |
2-64 |
timer response-timeout |
Security |
2-47 |
Security |
2-65 |
timer retry |
6-19 |
timer spf |
Routing Protocol |
4-37 |
time-range |
QoS/ACL |
1-18 |
timers |
Routing Protocol |
2-18 |
tracert |
System Managment |
4-31 |
traffic-limit |
QoS/ACL |
2-33 |
traffic-limit |
QoS/ACL |
4-3 |
traffic-params |
QoS/ACL |
2-36 |
traffic-priority |
QoS/ACL |
2-37 |
traffic-priority |
QoS/ACL |
4-5 |
traffic-redirect |
QoS/ACL |
2-40 |
traffic-redirect |
QoS/ACL |
4-8 |
traffic-redirect |
MPLS |
2-53 |
traffic-redirect { nested-vlan | modified-vlan } |
VLAN-QinQ |
5-1 |
traffic-shape |
QoS/ACL |
2-44 |
traffic-statistic |
QoS/ACL |
2-44 |
traffic-statistic |
QoS/ACL |
4-9 |
trap-to-cpu disable |
VLAN-QinQ |
1-6 |
trap-to-cpu disable vlan |
VLAN-QinQ |
1-7 |
umount |
System Managment |
1-11 |
undelete |
System Managment |
1-11 |
undo snmp-agent |
System Managment |
5-21 |
undo synchronization |
Routing Protocol |
5-56 |
update l3plus |
System Managment |
3-11 |
upgrade lanswitch |
NAT-URPF-VPLS |
1-20 |
urpf enable |
NAT-URPF-VPLS |
2-2 |
user |
System Managment |
1-40 |
user privilege level |
Getting Started |
1-30 |
user-interface |
Getting Started |
1-29 |
user-name-format |
Security |
2-48 |
user-name-format |
Security |
2-65 |
verbose |
System Managment |
1-40 |
vlan |
VLAN-QinQ |
1-7 |
vlan-assignment-mode |
Security |
2-20 |
vlan-mapping modulo |
STP |
1-44 |
vlan-vpn enable |
Port |
1-23 |
vlan-vpn enable |
VLAN-QinQ |
5-3 |
vlan-vpn enable |
STP |
3-1 |
vlan-vpn tpid |
VLAN-QinQ |
5-4 |
vlan-vpn tunnel |
STP |
3-1 |
vlan-vpn uplink enable |
VLAN-QinQ |
5-5 |
vlink-peer |
Routing Protocol |
3-54 |
vpn-instance |
Security |
2-49 |
vpn-instance-capability simple |
MPLS |
2-58 |
vpn-target |
MPLS |
2-59 |
vrrp authentication-mode |
Reliability |
1-6 |
vrrp method |
Reliability |
1-7 |
vrrp ping-enable |
Reliability |
1-7 |
vrrp un-check ttl |
Reliability |
1-8 |
vrrp vrid preempt-mode |
Reliability |
1-9 |
vrrp vrid priority |
Reliability |
1-9 |
vrrp vrid timer |
Reliability |
1-10 |
vrrp vrid track |
Reliability |
1-11 |
vrrp vrid virtual-ip |
Reliability |
1-12 |
vsi |
NAT-URPF-VPLS |
3-13 |
vsi-id |
NAT-URPF-VPLS |
3-14 |
wred |
QoS/ACL |
2-46 |
xbar |
Reliability |
2-5 |
