- H3C S9500 Series Routing Switches Command Manual-(V1.01)
- 00-1Cover
- 01-Getting Started Command
- 02-Port Command
- 03-VLAN-QinQ Command
- 04-Network Protocol Command
- 05-Routing Protocol Command
- 06-Multicast Protocol Command
- 07-QACL Command
- 08-MPLS Command
- 09-STP Command
- 10-Security Command
- 11-Reliability Command
- 12-System Management Command
- 13-PoE Command
- 14-NAT-URPF-VPLS Command
- 15-Integrated Management Command
- 16-Appendix
12-System Management Command | 693 KB |
Table of Contents
Chapter 1 File System Management Commands
1.2 Configuration File Management Commands
1.2.1 display current-configuration
1.2.2 display saved-configuration
1.2.5 reset saved-configuration
1.2.7 startup saved-configuration
1.3 FTP Server Configuration Commands
1.3.7 local-user password-display-mode
1.5 TFTP Configuration Commands
Chapter 2 MAC Address Table Management Commands
2.1 MAC Address Table Management Commands
2.1.1 display mac-address aging-time
2.1.4 mac-address max-mac-count
2.1.5 mac-address max-mac-count alarm
2.1.6 mac-address max-mac-count enable forward
2.1.7 mac-address max-mac-count max-mac-num
Chapter 3 Device Management Commands
3.1.10 display schedule reboot
Chapter 4 System Maintenance Commands
4.1 Basic System Configuration and Management Commands
4.2.12 display clock basephase
4.2.15 display clock self-test-result
4.2.17 display clock ssm-level
4.2.18 display clock ssm-output
4.2.19 display clock phase-lock-state
4.2.20 display clock work-mode
4.3 System Status and System Information Query Commands
4.4.2 display diagnostic-information
4.5 Network Connection Test Commands
4.6.4 display logbuffer summary
4.6.6 info-center channel name
4.6.7 info-center console channel
4.6.12 info-center loghost source
4.6.13 info-center monitor channel
4.6.14 info-center snmp channel
Chapter 5 SNMP Configuration Commands
5.1 SNMP Configuration Commands
5.1.2 display snmp-agent community
5.1.3 display snmp-agent group
5.1.4 display snmp-agent mib-view
5.1.5 display snmp-agent statistics
5.1.6 display snmp-agent sys-info
5.1.7 display snmp-agent usm-user
5.1.11 snmp-agent local-engineid
5.1.13 snmp-agent packet max-size
5.1.18 snmp-agent trap queue-size
Chapter 6 RMON Configuration Commands
6.1 RMON Configuration Commands
Chapter 7 NTP Configuration Commands
7.1 NTP Configuration Commands
7.1.2 display ntp-service sessions
7.1.3 display ntp-service status
7.1.4 display ntp-service trace
7.1.6 ntp-service authentication enable
7.1.7 ntp-service authentication-keyid
7.1.8 ntp-service broadcast-client
7.1.9 ntp-service broadcast-server
7.1.10 ntp-service max-dynamic-sessions
7.1.11 ntp-service multicast-client
7.1.12 ntp-service multicast-server
7.1.13 ntp-service refclock-master
7.1.14 ntp-service reliable authentication-keyid
7.1.15 ntp-service source-interface
7.1.16 ntp-service unicast-peer
7.1.17 ntp-service unicast-server
Chapter 8 SSH Terminal Service Configuration Commands
8.1 SSH Server Configuration Commands
8.1.2 display rsa local-key-pair public
8.1.3 display rsa peer-public-key
8.1.5 display ssh user-information
8.1.10 rsa local-key-pair create
8.1.11 rsa local-key-pair destroy
8.1.13 ssh server authentication-retries
8.1.14 ssh server compatible_ssh1x enable
8.1.15 ssh server rekey-interval
8.1.17 ssh user assign rsa-key
8.1.18 ssh user authentication-type
8.2 SSH Client Configuration Commands
8.2.3 ssh client assign rsa-key
8.2.4 ssh client first-time enable
8.3 SFTP Server Configuration Commands
8.4 SFTP Client Configuration Commands
1.1 File System
& Note:
The limitation on the names of directories and files on switch are as follows:
l It is recommended that the name of a directory or file should not contain more than 64 characters; otherwise you will not be able to delete such a directory or file, even though the system supports directory or file names containing more than 64 characters.
l The total number of characters including device, directory and file names can be up to 136 characters long.
1.1.1 cd
cd directory
View
Parameter
directory: Destination directory; By default, the directory is the working path configured by the user when the system starts.
Use the cd command to change the current user configuration path on the Ethernet Switch.
Example
# Change the current working directory of the switch to flash.
<H3C> cd flash:
<H3C> pwd
flash:
1.1.2 copy
copy fileurl-source fileurl-dest
View
Parameter
fileurl-source: Source file name.
fileurl-dest: Destination file name.
Use the copy command to copy a file.
You can use this command to copy a file from current directory to another directory, or vise versa. Where, the source filename must be the name of a file that has already existed in the specified directory, and the destination filename can be changed as required. When the destination filename is the same as that of an existing file, the system will ask whether to overwrite it.
Example
# Copy the file test.txt and saves it as test.bak.
<H3C> copy test.txt test.bak
Copy flash:/test/test.txt to flash:/test/test.bak ? [Y/N]:
% Copyed file flash:/test/test.txt flash:/test/test.bak
1.1.3 delete
delete [ /unreserved ] file-url
View
Parameter
/unreserved: Delete the file completely.
file-url: path and name of the file you want to delete.
Use the delete command to cancel a specified file from the storage device of the Ethernet Switch.
This command supports wildcard characters. The deleted files are kept in the recycle bin and will not be displayed when you use the dir command. However they will be displayed, using the dir /all command. The files deleted by the delete command can be recovered with the undelete command or deleted permanently from the recycle bin, using the reset recycle-bin command.
Note that, if two files with the same name in a directory are deleted, only the latest deleted file will be kept in the recycle bin.
Example
# Delete the file flash:/test/test.txt
<H3C> delete flash:/test/test.txt
Delete flash:/test/test.txt?[Y/N]:
1.1.4 dir
dir [ /all ] [ file-url ]
View
Parameter
/all: Display all the files (including the deleted ones).
file-url: File or directory name to be displayed. The file-url parameter supports “*” matching. For example, using dir *.txt will display all the files with the extension txt in the current directory.
Use the dir command to view the information about the specified file or directory in storage device of Ethernet Switch. This command supports wildcard characters.
Example
# Display the information about the file flash:/test/test.txt
<H3C> dir flash:/test/test.txt
Directory of flash:/test/
-rwxrwxrwx 1 noone nogroup 971 Sep 20 2003 14:28:52 test.txt
7932928 bytes total (4966400 bytes free)
# Display the information about all the files (including the deleted ones) in the flash:/test/ directory.
<H3C> dir /all flash:/test/
1 -rw- 4 Apr 04 2005 20:13:47 [snmpboots]
31877 KB total (2182 KB free)
The files that have already been deleted and kept in the recycle bin are displayed with the [ ] prompt.
# Display the information about all the files (including the deleted ones) in the flash:/test/ directory whose names start with the t character.
<H3C> dir /all flash:/test/t*
0 -rw- 1 noone nogroup 971 Sep 20 2003 14:28:52 test.txt
1.1.5 execute
execute filename
View
Parameter
filename: Name of the batch file, ranging from 1 to 256, with a suffix of “.bat”.
Use the execute command to execute the specified batch file.
The batch command executes the command lines in the batch file one by one. There should be no invisible character in the batch file. If invisible characters are found, the batch command will quit the current execution without back off operation. The batch command does not guarantee the execution of each command, nor does it perform hot backup itself. The forms and contents of the commands are not restricted in the batch file.
Example
# Execute the batch file “test.bat” in the directory of “flash:/”.
<H3C> system-view
[H3C] execute test.bat
1.1.6 file prompt
file prompt { alert | quiet }
View
Parameter
alert: Performs interactive confirmation on dangerous file operations; The default value is alert, which configures to perform interactive confirmation on dangerous file operations.
quiet: Does not prompt for the file operations.
Use the command to Using file prompt command, you can modify prompt modes of the file operation on the Ethernet switch.
If the prompt mode is set as quiet, that is, no prompt for file operations, some non-recoverable operations may lead to system damage.
Example
# Configure the prompt mode of file operation as quiet.
<H3C> system-view
[H3C] file prompt quiet
1.1.7 fixdisk
fixdisk device
View
Parameter
device: Device name.
Use the fixdisk command to restore the space of a storage device.
Some of the space of a storage device may be unavailable due to some reason (such as abnormal operations). In this case, you can use this command to restore the space.
Currently, the switch does not support this command on the compact flash (CF) card.
Example
# Restore the space of the storage device flash.
<H3C> fixdisk flash:
1.1.8 format
format filesystem
View
Parameter
filesystem: Device name.
Use the format command to format the storage device.
Format operation will cause non-recoverable loss of all the files on the device. Specially, configuration files will be lost after formatting the flash memory.
Example
# Format flash.
<H3C> format flash:
All data on Flash will be lost , proceed with format ? [Y/N] y
% Now begin to format flash, please wait for a while...
Format winc: completed
1.1.9 mkdir
mkdir directory
View
Parameter
directory: Directory name, in the range 1 to 136 characters.
Use the mkdir command to create directory in the specified directory on the storage device.
The directory to be created cannot have the same name as that of other directory or file in the specified directory.
Example
# Create the directory dd.
<H3C> mkdir dd
Created dir flash:/dd
1.1.10 more
more file-url
View
Parameter
file-url: File name.
Use the more command to view the contents of a specific file.
At present, the file system can display files in text format. This command can be used to display the contents of the files with .txt suffix or .cfg (configuration) suffix.
Example
# Display the contents of file test.txt.
<H3C> more test.txt
AppWizard has created this test application for you.
This file contains a summary of what you will find in each of the files that make up your test application.
Test.dsp
This file (the project file) contains information at the project level and is used to build a single project or subproject. Other users can share the project (.dsp) file, but they should export the makefiles locally.
1.1.11 move
move fileurl-source fileurl-dest
View
Parameter
Use the move command to move files.
Example
# Move flash:/test/sample.txt to flash:/sample.txt.
<H3C> move flash:/test/sample.txt flash:/sample.txt
Move flash:/test/sample.txt to flash:/sample.txt ?[Y/N]:y
%Moved file flash:/test/sample.txt to flash:/sample.txt
& Note:
The switch has the following limitation on directory name and filename:
l The maximum length of a directory name or filename is 64 characters.
l The maximum length of a full-path filename (including the device name, directory name, and filename) is 136 characters.
l The move command can be successfully executed only when the source file and the destination file are on the same device.
1.1.12 pwd
pwd
View
Parameter
None
Use the pwd command to view the current path.
Error may occur without setting the current path.
Example
# Display the current path.
<H3C> pwd
flash:
1.1.13 rename
rename fileurl-source fileurl-dest
View
Parameter
Use the rename command to rename a file.
If the destination file name is identical with that of an already existent directory or file, the rename operation fails and the system prompts that name has already been used or the file is being used.
Example
# Rename the file sample.txt to sample.bak.
<H3C> rename sample.txt sample.bak
Rename flash:/sample.txt to flash:/sample.bak ?[Y/N]:y
%Renamed file flash:/sample.txt to flash:/sample.bak
1.1.14 reset recycle-bin
reset recycle-bin [ file-url ]
View
Parameter
file-url: Name of the file to be deleted.
Use the reset recycle-bin command to permanently delete files from the recycle bin.
The file-url supports the wildcard character "*”.The delete command only puts the file into the recycle bin, but reset recycle-bin command will delete this file permanently.
Example
# Delete the file from the recycle bin.
<H3C> reset recycle-bin flash:/ config.vrrp
Squeeze flash:/ config.vrrp ? [Y/N]:
1.1.15 rmdir
rmdir directory
View
Parameter
directory: Directory name.
Use the rmdir command to cancel a directory.
The directory to be deleted must be empty, that is, all the files under the directory should be removed first.
& Note:
When you delete a directory using the rmdir command, the files that originally belonged to this direction, now in the Recycle Bin, will also be deleted.
Example
# Delete the directory test.
<H3C> rmdir test
Rmdir test?[Y/N]:y
% Removed directory test
1.1.16 umount
umount device
View
Parameter
device: Device name. Now, it can only be CF.
Use the umount command to unload the CF card from the file system.
Example
# Unload the CF card from the file system.
<H3C> umount cf:
1.1.17 undelete
undelete file-url
View
Parameter
file-url: Name of the file to be recovered.
Use the undelete command to recover the file that has not been deleted completely.
The file name to be recovered cannot be the same as an existing directory name. If the destination file name is the same as an existing file name, prompt whether to overwrite.
Example
# Recover the deleted file sample.bak.
<H3C> undelete sample.bak
Undelete flash:/sample.bak ?[Y/N]:y
%Undeleted file flash:/sample.bak
display current-configuration [ controller | interface interface-type interface-number | configuration [ configuration ] ] [ | { begin | exclude | include } regular-expression ]
View
Parameter
controller: Views the configuration information of controllers.
interface: Views the configuration information of interfaces.
interface-type: Type of the interface, including Aux, Ethernet, GigabitEthernet, NULL, Vlan-interface, M-Ethernet, LoopBack.
interface-number: Number of the interface.
configuration configuration: Views the pre-positive and post-positive configuration information. The value of configuration is the key word of the configuration, such as:
l system: Views the host name.
l timerange: Views the configuration information of time range.
|: Filters the configuration information to be output by regular expression.
begin: Begins with the line that matches the regular expression.
exclude: Excludes lines that match the regular expression.
include: Includes lines that match the regular expression.
regular-expression: Defines the regular expression.
Table 1-1 Special characters in the regular expression
Special characters |
Restriction |
_ |
Underscore, similar to a wildcard and can stand for these characters: (^|$|[,(){} ]) A space, the beginning of the input string, the end of the input string |
If the first character in the regular expression is not a underscore, then there is no restriction on the number of the underscore (but it is restricted by the command length). If the first character in the regular expression is an underscore, then there should be less than five consecutive underscores. If the underscores in a command are discrete, on the first group of underscores are filtered for the output information, but not the subsequent underscores. |
Left parenthesis, push flag in program |
It is recommended not to use this character in the regular expression. |
Use the display current-configuration command to display the currently effective configuration parameters of the switch.
If some running configuration parameters are the same with the default operational parameters, they will not be displayed.
If a user needs to authenticate whether the configurations are correct after finishing a set of configuration, the display current-configuration command can be used to display the running parameters. Although the user has configured some parameters, but the related functions are not effective, they are not displayed.
When there is much configuration information, you can use the regular expression to filter the output information. For specific rules about the regular expression, refer to the corresponding operation manual.
Related command: save, reset saved-configuration and display saved-configuration.
Example
# View the running configuration parameters of the switch.
<H3C> display current-configuration
sysname H3C
radius scheme system
server-type nec
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
domain system
radius-scheme system
access-limit disable
state active
idle-cut disable
domain default enable system
local-server nas-ip 127.0.0.1
router id 2.2.2.2
stp timer hello 500
vlan 1
vlan 2
interface Vlan-interface1
interface Vlan-interface2
interface Aux0/0
interface Aux0/0/1
interface M-Ethernet0/0/0
interface Ethernet4/1/1
interface Ethernet4/1/2
interface Ethernet4/1/3
interface Ethernet4/1/4
interface Ethernet4/1/5
interface Ethernet4/1/6
interface Ethernet4/1/7
interface NULL0
ospf
area 0.0.0.0
network 10.1.1.0 0.0.0.255
user-interface aux 0
user-interface vty 0 4
return
# View the lines containing the character string “10*.110” in the configuration information. The “*” indicates that the “0” before it can appear 0 times or multiple consecutive times.
<H3C> display current-configuration | include 10*.110
vlan 1
speed 1000
# View configuration information begin with “user”.
<H3C> display current-configuration | include ^user
# View the pre-positive and post-positive configuration information.
<H3C> display current-configuration configuration
sysname H3C
server-type nec
domain system
state active
idle-cut disable
router id 2.2.2.2
stp timer hello 500
ospf
area 0.0.0.0
return
View
Parameter
None
Use the display saved-configuration command to view the configuration files in the flash memory or CF card of Ethernet Switch.
If the Ethernet Switch works abnormally after electrified, execute the display saved-configuration command to view the startup configuration of the Ethernet Switch.
Related command: save, reset saved-configuration and display current-configuration.
Example
# Display configuration files in flash memory or CF card of Ethernet Switch.
<H3C> display saved-configuration
sysname H3C
local-user abc password simple abc
tcp window 8
interface Aux7/1/1
link-protocol ppp
interface Ethernet2/1/1
interface Ethernet2/1/2
interface Ethernet2/1/3
ip address 10.110.101.17 255.255.255.0
interface NULL0
ospf 1
ip route-static 10.12.0.0 255.255.0.0 Ethernet 12/1/0
user-interface con 0
authentication-mode none
return
The displayed information is global, port and user configurations.
1.2.3 display this
display this
View
Parameter
None
Use the display this command to display the running configuration of the current view. If you need to authenticate whether the configurations is correct after you have finished a set of configurations under a view, you can use the display this command to view the running parameters.
Some effective parameters are not displayed if they are the same with the default ones, while some parameters, though have been configured by the user, if their related functions are not effective, are not displayed either. For example, if X.25 is encapsulated at the data link layer on an interface, you can configure PPP parameter on the interface, but cannot view the configuration information when executing the display this command.
Associated configuration of the interface is displayed when executing the command in different interface views; related configuration of the protocol view is displayed when executing this command in different protocol views; and all the configuration of the protocol view is displayed when executing this command in protocol sub-views.
Related command: save, reset saved-configuration, display current-configuration, display saved-configuration.
Example
# Display the running configuration parameters for the current view of the switch system.
<H3C> display this
1.2.4 display startup
display startup
View
Parameter
None
Use the display startup command to display the related system software and configuration filenames used for the current and the next start-ups.
This command is used to display the following information: the filename of the system software for the current enabling configured by the user, the filename of the system software actually used for the current enabling, the filename of the system software configured for the next enabling, the configuration filename used for the current enabling, the configuration filename configured for the next enabling.
Related command: startup saved-configuration.
Example
# Display the filenames related to the current and the next enabling.
<H3C> display startup
MainBoard:
Startup saved-configuration file: flash:/9500.cfg
Next startup saved-configuration file: flash:/9500.cfg
View
Parameter
None
Use the reset saved-configuration command to erase configuration files from the flash memory of the Ethernet Switch.
Perform this command with cautious. It is suggested to consult technical support personnel first.
Generally, this command is used in the following situations:
l After upgrade of software, configuration files in flash memory may not match the new version's software. Perform the reset saved-configuration command to erase the old configuration files.
l If a used Ethernet Switch is applied to the new circumstance and the original configuration files cannot meet the new requirements, the Ethernet Switch should be configured again. Erase the original configuration files for reconfiguration.
If the configuration files do not exist in the flash memory when Ethernet Switch is electrified and initialized, it will enter setup switch view automatically.
Related command: save, display current-configuration, display saved-configuration.
Example
# Erase the configuration files from the flash memory of Ethernet Switch.
<H3C> reset saved-configuration
The saved configuration will be erased.
Are you sure?[Y/N]
1.2.6 save
save [ file-name ]
View
Parameter
file-name: Name of the configuration file with the extension .cfg. It is a character string of 5 to 56 characters.
Use the save command to save the current configuration files to Flash memory.
After finishing a group of configurations and achieving corresponding functions, user should remember to get the current configuration files stored in the flash memory.
Even if the problems like reboot and power-off occur during saving, the configuration can be still saved to Flash.
Related command: reset saved-configuration, display current-configuration, display saved-configuration.
Example
# Get the current configuration files stored in the flash memory.
<H3C> save
The configuration will be written to the device.
Are you sure?[Y/N]y
Now saving current configuration to the device.
Saving configuration flash:/9500.cfg. Please wait..
Configuration is saved to flash memory successfully.
startup saved-configuration cfgfile
View
Parameter
cfgfile: Name of the configuration file. It is a string with a length of 5 to 56 characters.
Use the startup saved-configuration command to configure the configuration file used for enabling the system for the next time.
The configuration file must have “.cfg” as its extension name and must be saved under the root directory of the Flash. By default, the configuration file will be saved under the root directory of Flash.
The extension of configuration file must be .cfg, and the startup configuration file must be saved under the directory where the memory resides. The memory is Flash.
Related command: display startup.
Example
# Configure the configuration file for the next start-up
<H3C> startup saved-configuration config.cfg
1.3.1 display ftp-server
display ftp-server
View
Parameter
None
Use the display ftp-server command to view the parameters of the current FTP Server. You can perform this command to verify the configuration after setting FTP parameters.
Example
# Display the configuration of FTP Server parameters.
<H3C> display ftp-server
FTP server is running
Max user number 5
User count 0
Timeout value(in minute) 30
1.3.2 display ftp-user
display ftp-user
View
Parameter
None
Use the display ftp-user command to view the parameters of current FTP user.
Example
# Show the configuration of FTP user parameters.
<H3C> display ftp-user
% No ftp user
1.3.3 ftp disconnect
ftp disconnect user-name
View
Parameter
user-name: user name of FTP that is to be disconnected.
Use the ftp disconnect command to disconnect an FTP user.
Example
# Disconnect the FTP user ftptest.
<H3C> system-view
[H3C] ftp disconnect ftptest
1.3.4 ftp server enable
ftp server enable
undo ftp server
View
Parameter
None
Use the ftp server enable command to start FTP Server and enable FTP user logon.
Use the undo ftp server command to close FTP Server and disable FTP user logon.
By default, FTP Server is shut down.
Perform this command to easily start or shut down FTP Server, preventing Ethernet Switch from being attacked by some unknown user.
Example
# Shut down FTP Server.
<H3C> system-view
[H3C] undo ftp server
% Close FTP server
1.3.5 ftp timeout
ftp timeout minute
undo ftp timeout
View
Parameter
minute: Connection timeouts (measured in minutes), ranging from 1 to 35791; By default, the connection timeout time is 30 minutes.
Use the ftp timeout command to configure connection timeout interval.
Use the undo ftp timeout command to restore the default connection timeout interval.
After a user logs on to an FTP Server and has established connection, if the connection is interrupted or cut abnormally by the user, FTP Server will still hold the connection. The connection timeout can avoid this problem. If the FTP server has no command interaction with a client for a specific period of time, it considers the connection to be failed and disconnect to the client.
Example
# Set the connection timeout to 36 minutes.
<H3C> system-view
[H3C] ftp timeout 36
1.3.6 local-user
local-user { username | multicast [ domain domain-name ] ipaddress | password-display-mode { auto | cipher-force } }
undo local-user { username | all [ service-type { ftp | lan-access | telnet | ppp | ssh | terminal } ] | multicast [ domain domain-name ] ipaddress | password-display-mode }
View
Parameter
username: User name.
all [ service-type { ftp | lan-access | telnet | ppp | ssh | terminal } ]: Deletes all local users. The keywords ftp, lan-access, telnet are used respectively to delete all the FTP, LAN access, Telnet local users. ppp is used to delete all the point-to-point access local views. The SSH parameter is used to delete all the SSH local views. And the terminal parameter is used to delete all the user terminals.
multicast [ domain domain-name ]: Adds or deletes multicast address.
ipaddress: Multicast IP address.
password-display-mode { auto | cipher-force }: Specifies the display mode of password. auto indicates the password will be displayed in the same mode as that used when the user configure the password. And cipher-force indicates the password will be displayed in forcible cipher mode.
Use the local-user command to configure a local user and enter the local user view.
Use the undo local-user command to cancel one or all the local users.
By default, no local user exists.
This configuration is required if you want to access FTP server through FTP from a client.
Example
# Create a local user, and enter the local user view.
<H3C> system-view
[H3C] local-user H3C
[H3C-luser-H3C]
local-user password-display-mode { auto | cipher-force }
undo local-user password-display-mode
View
Parameter
password-display-mode: Sets the display mode of user password when the switch displays the local user.
auto: Sets the display mode to what was used in configuring the password. That is, if the password was configured in cipher mode, it is also displayed in cipher mode, or else, it is displayed in plain mode.
cipher-force: Forcibly sets the display mode to cipher.
Use the local-user password-display-mode command to set the display mode of the user password when the switch displays the local user.
Use the undo local-user password-display-mode command to restore the default mode.
By default, this mode is auto.
Example
# Set the display mode of user password when the switch displays the local user to cipher-force.
<H3C> system-view
[H3C] local-user password-display-mode cipher-force
1.3.8 password
password [ simple | cipher ] password
undo password
View
Local user view
Parameter
simple: Specifies to display passwords in simple text, ranging from 1 to 63 characters.
cipher: Specifies to display passwords in cipher text, ranging from 1 to 88 characters.
password: Defines a password, which is a character string of up to 63 characters if it is in simple text and of up to 88 characters if it is in cipher text.
Use the password command to configure a password display mode for local users.
Use the undo password command to cancel the specified password display mode.
By default, a local user does not have a password.
If a client user wants to access FTP server through FTP, a password must be configured.
Example
# Configure the password for the local user H3C as 123456 (encrypted).
<H3C> system-view
[H3C]local-user H3C
New local user added.
[H3C-luser-H3C] password cipher 123456
Updating the password file, please wait...
1.3.9 service-type
service-type { ftp [ ftp-directory directory ] | lan-access | ppp [ call-number call-number | callback-nocheck | callback-number callback-number ] | ssh [ level level | telnet | terminal ] | telnet [ level level | ssh | temninal ] | terminal [ level level | ssh | telnet ] }
undo service-type { ftp [ ftp-directory directory ] | lan-access | ppp [ call-number call-number | callback-nocheck | callback-number callback-number ] | ssh [ level level | telnet | terminal ] | telnet [ level level | ssh | temninal ] | terminal [ level level | ssh | telnet] }
View
Local user view
Parameter
ftp: Specifies user type as FTP.
ftp-directory directory: Specifies the directory of FTP users, directory is a character string of up to 64 characters.
lan-access: Specifies user type to Lan-access, which mainly refers to Ethernet accessing users, 802.1x supplicants for example.
ppp: Specifies user type as PPP.
call number: Sets call number.
callback-nocheck: Sets callback-nocheck for modem.
ssh: Sets user type to SSH.
telnet: Sets user type to Telnet.
level level: Specifies the level of Telnet users. The argument level is an integer in the range of 0 to 3 and defaults to 0.
terminal: Sets user type to Terminal.
Use the service-type command to configure a service type for a particular user.
Use the undo service-type command to cancel the specified service type for the user.
Example
# Set user H3C as Lan-access user.
<H3C> system-view
[H3C]local-user H3C
[H3C-luser-H3C]
[H3C-luser-H3C] service-type lan-access
1.4 FTP Client Commands
1.4.1 ascii
ascii
View
FTP Client view
Parameter
None
Use the ascii command to configure data transmission mode as ASCII mode.
By default, the file transmission mode is ASCII mode.
Perform this command if the user needs to change the file transmission mode to default mode.
Example
# Configure to transmit data in the ASCII mode.
<H3C> ftp
[ftp] ascii
200 Type set to A.
1.4.2 binary
binary
View
FTP Client view
Parameter
None
Use the binary command to configure file transmission type as binary mode.
Example
# Configure to transmit data in the binary mode.
<H3C>ftp
[ftp] binary
200 Type set to I.
1.4.3 bye
bye
View
FTP Client view
Parameter
None
Use the bye command to disconnect with the remote FTP Server and return to user view.
After performing this command, you can terminate the control connection and data connection with the remote FTP Server.
Example
# Terminate connection with the remote FTP Server and return to user view.
<H3C> ftp
[ftp] bye
1.4.4 cd
cd pathname
View
FTP Client view
Parameter
pathname: Path name.
Use the cd command to change the working path on the remote FTP Server.
This command is used to access another directory on FTP Server. Note that the user can only access the directories authorized by the FTP server.
Example
# Change the working path to flash:/temp
<H3C> ftp
[ftp] cd flash:/temp
1.4.5 cdup
cdup
View
FTP Client view
Parameter
None
Use the cdup command to change working path to the upper level directory.
This command is used to exit the current directory and return to the upper level directory.
Example
# Change working path to the upper level directory.
<H3C> ftp
[ftp] cdup
1.4.6 close
close
View
FTP Client view
Parameter
None
Use the close command to disconnect FTP client side from FTP server side without exiting FTP client side view. That is to say, you can terminate the control connection and data connection with the remote FTP Server at the same time.
Example
# Terminate connection with the remote FTP Server and stays in FTP Client view.
<H3C> ftp
[ftp] close
1.4.7 debugging
debugging
undo debugging
View
FTP Client view
Parameter
None
Use the debugging command to enable the debugging for FTP Client commands.
Use the undo debugging command to disable the debugging for FTP Client commands.
By default, the debugging for FTP Client commands is disabled.
Example
# Enable the debugging for FTP Client commands.
<H3C> ftp
[ftp] debugging
1.4.8 delete
delete remotefile
View
FTP Client view
Parameter
remotefile: File name.
Use the delete command to cancel the specified file.
Example
# Delete the file temp.c
<H3C>ftp
[ftp] delete temp.c
1.4.9 dir
dir [ filename ] [ localfile ]
View
FTP Client view
Parameter
filename: File name to be queried.
localfile: Saved local file name.
Use the dir command to query a specified file.
If no parameter of this command is specified, then all the files in the directory will be displayed.
Example
# Query the file temp.c and saves the results in the file temp1.
<H3C> ftp
[ftp] dir temp.c temp1
1.4.10 disconnect
disconnect
View
FTP Client view
Parameter
None
Use the disconnect command to disconnect FTP Client side from FTP server side without exiting FTP client side view.
This command terminates the control connection and data connection with the remote FTP Server at the same time.
Example
<H3C> ftp
[ftp] disconnect
1.4.11 ftp
ftp [ ipaddress [ port ] ]
View
Parameter
ipaddress: IP address of the remote FTP Server.
port: Port number of remote FTP Server.
Use the ftp command to establish control connection with the remote FTP Server and enter FTP Client view.
Example
# Connect to FTP Server at the IP address 1.1.1.1
<H3C> ftp 1.1.1.1
1.4.12 get
get remotefile [ localfile ]
View
FTP Client view
Parameter
localfile: Local file name.
remotefile: Name of a file on the remote FTP Server.
Use the get command to download a remote file and save it locally.
If no local file name is specified, it will be considered the same as that on the remote FTP Server.
Example
# Download the file temp1.c and saves it as temp.c
<H3C> ftp
[ftp] get temp1.c temp.c
1.4.13 lcd
lcd
View
FTP Client view
Parameter
None
Use the lcd command to view local working path of FTP Client.
Example
# Show local working path.
<H3C> ftp
[ftp] lcd
% Local directory now flash:/temp
1.4.14 ls
ls [ remotefile ] [ localfile ]
View
FTP Client view
Parameter
remotefile: Remote file to be queried.
Use the ls command to query a specified file.
If no parameter is specified, all the files will be shown.
Note that, the ls command only displays the file names, while the dir command also displays other file-related information such as the file size and creation date.
Example
# Query file temp.c
<H3C>ftp
[ftp] ls temp.c
1.4.15 mkdir
mkdir pathname
View
FTP Client view
Parameter
pathname: Directory name.
Use the mkdir command to create a directory on the remote FTP Server.
User can perform this operation as long as the remote FTP server has authorized.
Example
# Create the directory flash:/lanswitch on the remote FTP Server.
<H3C>ftp
[ftp] mkdir flash:/lanswitch
1.4.16 open
open ipaddr [ port ]
View
FTP Client view
Parameter
ipaddr: IP address of the remote FTP server.
port: Port number of the remote server.
Use the open command to set up an FTP connection with a remote FTP server.
Example
# Set up a FTP connection with the FTP server with the IP address of 10.110.3.1.
<H3C> ftp
[ftp] open 10.110.3.1
1.4.17 passive
passive
undo passive
View
FTP Client view
Parameter
None
Use the passive command to configure the data transmission mode as passive mode.
Use the undo passive command to configure the data transmission mode as active mode.
By default, the data transmission mode is passive mode
Example
# Set the data transmission to passive mode.
<H3C> ftp
[ftp] passive
1.4.18 put
put localfile [ remotefile ]
View
FTP Client view
Parameter
remotefile: File name on the remote FTP Server.
Use the put command to upload a local file to the remote FTP Server.
If the user does not specify the filename on the remote server, the system will consider it the same as the local file name by default.
Example
# Upload the local file temp.c to the remote FTP Server and saves it as temp1.c.
<H3C> ftp
[ftp] put temp.c temp1.c
1.4.19 pwd
pwd
View
FTP Client view
Parameter
None
Use the pwd command to view the current directory on the remote FTP Server.
Example
# Show the current directory on the remote FTP Server.
<H3C> ftp
[ftp] pwd
"flash:/temp" is current directory.
1.4.20 quit
View
FTP Client view
Parameter
None
Use the quit command to terminate the connection with the remote FTP Server and return to user view.
Example
# Terminate connection with the remote FTP Server and returns to user view.
<H3C> ftp
[ftp] quit
<H3C>
1.4.21 remotehelp
remotehelp [ protocol-command ]
View
FTP Client view
Parameter
protocol-command: FTP protocol command.
Use the remotehelp command to view help information about the FTP protocol command. This command takes effects only when the FTP server provides the protocol command help. (S9500 series serving as servers provide this help service, but common FTP software do not provide this service).
Example
# Show the syntax of the protocol command user.
<H3C> ftp
[ftp] remotehelp user
214 Syntax: USER <sp> <username>
1.4.22 rmdir
rmdir pathname
View
FTP Client view
Parameter
pathname: Directory name of remote FTP Server.
Use the rmdir command to remove the specified directory from FTP Server. Note that, this command can be successfully executed only when the specified directory contains no files.
Example
# Delete the directory flash:/temp1 from FTP Server.
<H3C> ftp
[ftp] rmdir flash:/temp1
1.4.23 user
user username [ password ]
View
FTP Client view
Parameter
username: Logon username.
password: Logon password.
Use the user command to register an FTP user.
This command is available when you log in FTP server with a specified user account.
Example
# Log in the FTP Server with username tom and password bjhw.
<H3C> ftp
[ftp] user tom bjhw
1.4.24 verbose
verbose
undo verbose
View
FTP Client view
Parameter
None
Use the verbose command to enable the client to display the commands received from/sent to the server.
Use the undo verbose command to disable the client from display the commands received from/sent to the server
By default, the VERBOSE is enabled and the client displays the commands received from/sent to the server.
Example
# Enable VERBOSE.
<H3C> ftp
[ftp]verbose
1.5.1 tftp get
tftp tftp-server get source-file [ dest-file ]
View
Parameter
tftp-server: IP address or hostname of the TFTP server. The name of the TFTP server should be a string ranging from 1 to 20 characters.
source-file: Specifies the filename of the source file on the TFTP server.
dest-file: Specifies the filename of the destination file which will be saved on the switch.
Use the tftp get command to download a file from the specified directory of the TFTP server and saving it on the switch.
Related command: tftp put.
Example
# Download the file LANSwitch.app from the TFTP server at 1.1.3.214 and save it as vxWorks.app on the local switch.
<H3C> tftp 1.1.3.214 get LANSwitch.app vxWorks.app
1.5.2 tftp put
tftp tftp-server put source-file [ dest-file ]
View
Parameter
source-file: Specifies the filename of the source file which is saved on the switch.
dest-file: Name of the saved-as file uploaded to the specified directory on the TFTP server.
Use the tftp put command to upload a file from the switch to the specified directory on the TFTP server.
Related command: tftp get.
Example
# Upload the config.txt to the TFTP server at 1.1.3.214 and save it as temp.txt.
<H3C> tftp 1.1.3.214 put config.txt temp.txt
View
Parameter
None
Use the display mac-address aging-time command to view the aging time of the dynamic entry in the MAC address table.
Related command: mac-address, mac-address timer, display mac-address.
Example
# Display the aging time of the dynamic entry in the MAC address table.
<H3C> display mac-address aging-time
mac-address aging-time: 300s
The above information indicates that the aging time of the dynamic entry in the MAC address is 300s.
2.1.2 display mac-address
display mac-address [ mac-addr [ vlan vlan-id ] | [ static | dynamic ] [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
View
Parameter
mac-addr: Specifies the MAC address.
vlan-id: Specifies the VLAN ID.
static: Static table entry, that is no aging, If the configuration is saved, it can be restored after the switch is reset.
dynamic: Dynamic table entry, which will be aged.
interface-type: Specifies the interface type.
interface-number: Specifies the interface number.
count: the display information will only contain the sum number of MAC addresses in the MAC address table if user choice this parameter when using this command.
Use the display mac-address command to view MAC address table information.
When managing the Layer-2 addresses of the switch, the administrator can perform this command to view such information as the Layer-2 address table, address status (static or dynamic), Ethernet port of the MAC address, VLAN of the address, and system address aging time.
Related command: mac-address, mac-address timer.
Example
# Show the information of the entry with MAC address at 00e0-fc01-0101
<H3C> display mac-address 00e0-fc01-0101
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s)
00e0-fc01-0101 1 Learned Ethernet1/1/1 300
Table 2-1 Description on the fields of the display mac-address command on display
MAC ADDR |
The destination MAC address |
VLAN ID |
The VLAN of the MAC address |
STATE |
The state of the item, which can be Learned, Config static |
PORT INDEX |
The forwarding port |
AGING TIME(s) |
The aging time |
2.1.3 mac-address
mac-address { static | dynamic } mac-addr interface interface-type interface-number vlan vlan-id
undo mac-address [ static | dynamic ] [ mac-addr [ interface interface-type interface-number vlan vlan-id | interface interface-type interface-number | vlan vlan-id ]
View
Parameter
static: Static table entry, lost after resetting switch.
For detailed description on interface-type and interface-number see Port Configuration section of this manual.
Use the mac-address command to add/modify the MAC address table entry.
Use the undo mac-address command to cancel the MAC address table entry
If the input address has been existed in the address table, the original entry will be modified. That is, replace the interface pointed by this address with the new interface and the entry attribute with the new attribute (dynamic entry, static entry and permanent entry).
All the (MAC unicast) addresses on a certain interface can be deleted. User can choose to delete any of the following addresses: address learned by system automatically, dynamic address configured by user, static and permanent addresses configured by user.
Related command: display mac-address.
Example
# Configure the port number corresponding to the MAC address 00e0-fc01-0101 as Ethernet2/1/1 in the address table, and sets this entry as static entry.
<H3C> system-view
[H3C] mac-address static 00e0-fc01-0101 interface ethernet 2/1/1 vlan 2
undo mac-address max-mac-count
View
Ethernet port view
Parameter
count: Maximum number of MAC addresses learned by a port, ranging from 0 to 14,336, the value of 0 means that address learning is disabled.
Use the mac-address max-mac-count command to set the maximum number of MAC addresses learned by an Ethernet port.
Use the undo mac-address max-mac-count command to remove the limit on the maximum number of MAC addresses learned by an Ethernet port.
By default, a port can learn as many MAC addresses as a board can have. You can change the default value by using this command: if you set the value to count, and when the number of MAC addresses learned by the port reaches this value, this port will no longer learn any more MAC addresses; and you can use the undo mac-address max-mac-count command to remove the limit on the number.
& Note:
l The maximum number of MAC addresses of a board ranges from 12 K to 16 K depending on various software versions and board types.
l The aforementioned number of MAC addresses includes only the MAC addresses learned by the switch dynamically, and excludes those configured by the user.
l When executing the mac-address max-mac-count command, if the current number of MAC addresses exceeds the threshold value, the switch neither delete the present MAC address entries nor learn new MAC address until the number of entries less than the threshold value after some entries are aged out.
Related command: mac-address and mac-address timer.
Example
Set the maximum number of MAC addresses learned by Ethernet port Ethernet3/1/3 to 600.
<H3C> system-view
[H3C] interface Ethernet3/1/3
[H3C-Ethernet3/1/3] mac-address max-mac-count 600
mac-address max-mac-count enable { alarm | forward }*
undo mac-address max-mac-count enable { alarm | forward }*
View
Ethernet port view
Parameter
alarm: when the current number of MAC addresses exceeds the threshold value, whether the switch gives the network administrator an alarm or not. By default, the switch doesn’t give an alarm.
Use the mac-address max-mac-count enable { alarm | forward }* command to enable the switch to send alarms to network administrator.
Use the undo mac-address max-mac-count enable { alarm | forward }* command to disable the function.
After the mac-address max-mac-count enable { alarm | forward }* command is executed, if the MAC addresses learned by a port reach the maximum number of MAC addresses that the port can learned, the port will send an alarm to network administrator to prompt that the port will no longer learn any MAC addresses.
Related commands: mac-address, mac-address timer.
& Note:
Example
# Set the maximum number of MAC addresses learned by Ethernet port Ethernet3/1/3 to 600, and the switch will give an alarm to the network administrator and forward the packets when the number of MAC addresses learned exceeds 600.
<H3C> system-view
[H3C-Ethernet3/1/3] mac-address max-mac-count enable forward alarm
# Cancel the alarm function
[H3C-Ethernet3/1/3] undo mac-address max-mac-count enable alarm
undo mac-address max-mac-count enable forward
View
Ethernet port view
Parameter
None
Use the mac-address max-mac-count enable forward command to enable the switch to forward the packets whose source MAC addresses have not been learned by ports when the number of automatically learned MAC addresses of a specified port exceeds maximum number of learned MAC addresses.
Use the undo mac-address max-mac-count enable forward command to discard the packets whose source MAC addresses have not been learned by ports when the number of automatically learned MAC addresses of a specified port exceeds maximum number of learned MAC addresses.
By default, the switch forwards the packets whose source MAC addresses have not been learned by ports when the number of automatically learned MAC addresses of a specified port exceeds maximum number of learned MAC addresses.
Example
# Set the maximum number of learned MAC addresses of Ethernet port Ethernet3/1/3 to 600, so that the switch discards the packets whose source addresses have not been learned by ports when the number of automatically learned MAC addresses exceeds 600.
<H3C> system-view
[H3C-Ethernet3/1/3] undo mac-address max-mac-count enable forward
View
VLAN view
Parameter
max-mac-num: Maximum number of MAC addresses that can be learned in a VLAN. This argument ranges from 0 to 4,294,967,295. Value of 0 disables MAC address learning.
Use the mac-address max-mac-count command to set the maximum number of MAC addresses that can be learned in VLAN.
Use the undo mac-address max-mac-count command to cancel the configuration.
If you have set the maximum number, MAC addresses will not be learned in the VLAN when the maximum number is reached..
By default, the number of learned MAC addresses is not limited in a VLAN.
& Note:
If you execute this command with the max-mac-num argument less than the current number of MAC addresses learned, the switch does not remove the existing MAC address entries, neither does it learns new MAC addresses. The switch resumes MAC address learning when the number of MAC addresses learned is less than the value specified by the max-mac-num argument.
Example
# Set the maximum number of learned MAC addresses in a VLAN 100 to 600.
<H3C> system-view
[H3C] vlan 100
[H3C-vlan100] mac-address max-mac-count 600
2.1.8 mac-address timer
mac-address timer { aging age | no-aging }
undo mac-address timer aging
View
Parameter
aging age: Specifies the aging time (measured in seconds) of the Layer-2 dynamic address table entry, ranging from 10 to 630. By default, the aging time is 300 seconds.
no-aging : No aging time.
Use the mac-address timer command to configure the aging time of the Layer-2 dynamic address table entry.
Use the undo mac-address timer command to restore the default value.
If aging time is too short, the MAC address might be deleted before the Ethernet switch gets the address information. That way the switch broadcasts the received packets to all the ports within the VLAN. This will affect the switch operation performance.
If aging time is too long, the Ethernet switch will store a great number of out-of-date MAC address tables. This will consume MAC address table resources and the switch will not be able to update MAC address table according to the network change.
Caution:
The aging of dynamic MAC address is completed during the second aging cycle that has been configured.
Example
# Configure the entry aging time of Layer-2 dynamic address table to be 500 seconds.
<H3C> system-view
[H3C] mac-address timer aging 500
2.1.9 reset mac-address
reset mac-address { all | dynamic | static | interface { interface-type interface-number} | vlan vlan-id }
View
Parameter
all: Clears all of the MAC address entries.
dynamic: Clears all dynamic MAC address entries.
static: Cleasr all static MAC address entries.
interface-type is the type of the port, and interface-number is the number of the interface.
Vlan vlan-id: Clears all of the MAC address entries in the specified VLAN.
Use the reset mac-address command to clear corresponding MAC address entries.
Related commands: mac-address, display mac-address.
Example
# Clear all MAC address entries.
<H3C> reset mac-address all
3.1.1 boot boot-loader
boot boot-loader { primary | backup } file-url [ slot slot-number ]
View
Parameter
file-url: ARP program path + program name
slot-number: Slot number of the active or standby SRPC.
primary: Specifies this program to be the primary bootstrap program.
backup: Specifies this program to be the backup bootstrap program.
Use the boot boot-loader primary command to specify the primary bootstrap program to be the bootstrap program.
Use the boot boot-loader backup command to specify the backup bootstrap program to be the bootstrap program.
If the switch cannot be started through specified bootstrap program, a program will be selected from the Flash or CF card as bootstrap program. If the switch still cannot be started normally, the switch fails to boot up.
& Note:
An S9500 series routing switch supports system switchover, both its active and standby SRPCs have an application program system. You can operate on the programs on both SRPCs. But when you specify a bootstrap program on the standby SRPC, the URL of the program must begin with "slot[No.]#[flash: | cf:]/", where, [No.] is the slot number of the standby SRPC and [flash: | cf:] is the name of the equipment, flash card or CF card. For example, if the slot number of the standby SRPC is 1, the URL of the 9500.app program under the root directory on the standby SRPC must be "slot1#flash:/9500.app".
Example
# Specify flash:/s9500-cmw310-r1262.app as the current primary bootstrap program of the active SRPC.
<H3C> boot boot-loader primary flash:/s9500-cmw310-r1262.app
The specified file will be booted next time!.
# Specify slot1#flash:/s9500-cmw310-r1262.app as the current primary bootstrap program on the standby SRPC in slot 1.
<H3C> boot boot-loader primary slot1#flash:/s9500-cmw310-r1262.app slot 1
3.1.2 boot bootrom
boot bootrom file-url slot slot-num-list
View
Parameter
file-url: Path and name of Bootrom file in the storage device.
slot slot-num-list: Specifies the slot number list of switch. The formula is slot-num-list={ slot-num [ to slot-num ] }&<1-n>. &<1-n> indicates that the prior parameter can be input for n times. For S9505, n is 7; for S9512, n is 14.
Use the boot bootrom command to upgrade Bootrom.
Example
# Upgrade bootrom of No.1slot.
<H3C> boot bootrom PLATV100R002B09D002.app slot 1
3.1.3 display boot-loader
display boot-loader
View
Parameter
None
Use the display boot-loader command to view APP file used this time and next time.
Example
<H3C> display boot-loader
The primary app to boot of board 0 at the next time is: flash:/switch.app
The backup app to boot of board 0 at the next time is: flash:/switch.app
The app to boot of board 0 at this time is: flash:/switch.app
Table 3-1 Description on the display boot-loader command
The app to boot of board 0 at the next time is: flash:/Switch.app |
Startup file used on startup next time |
The app to boot of board 0 at this time is: flash:/PLAT.APP |
Startup file used on startup this time |
3.1.4 display cpu
display cpu [slot slot-no ]
View
Parameter
slot slot-no: Specifies the board number.
Use the display cpu command to display CPU occupancy.
Example
# Display CPU occupancy on slot 0.
<H3C> display cpu slot 0
Board 0 CPU busy status:
6% in last 5 seconds
7% in last 1 minute
12% in last 5 minutes
Table 3-2 Description on display information
Board 0 CPU busy status: |
CPU usage of switch |
6% in last 5 seconds 7% in last 1 minute 12% in last 5 minutes |
CPU usage in last 5 seconds is 6%. CPU usage in last 1 minute is 7%. CPU usage in last 5 minutes is 12%. |
3.1.5 display device
display device [ detail | [ shelf shelf-no ] [ frame frame-no ] [ slot slot-no ] ]
View
Parameter
detail: displays all slot detail information.
shelf-no: Shelf number.
frame-no: Frame number.
slot-no: Slot number.
Use the display device command to display the module type and working status information of a card, including physical card number, physical daughter card number, number of ports, hardware version number, FPGA version number, version number of BOOTROM software, application version number, address learning mode, interface card type and interface card type description, and so on.
Example
# Show device information.
<H3C> display device
Slot No. Brd Type Brd Status Subslot Num Sft Ver
0 LSB1SRPB Master 0 9500-0004
1 NONE Absent Absent None
2 NONE Absent Absent None
3 NONE Absent Absent None
4 NONE Absent Absent None
5 NONE Absent Absent None
6 NONE Absent Absent None
7 NONE Absent Absent None
3.1.6 display environment
display environment
View
Parameter
None
Use the display environment command to view environment information.
Example
# Display the environment information.
<H3C> display environment
System temperature information (degree centigrade):
Board Temperature Lower limit Upper limit
0 33 10 45
2 35 10 65
4 34 10 65
3.1.7 display fan
display fan [ fan-id ]
View
Parameter
fan-id: the fan ID.
Use the display fan command to view the working state of the built-in fans. User can perform this command to see if they work normally.
Example
# Display the working state of the fans.
<H3C> display fan
Fan 1 State: Normal
3.1.8 display memory
display memory [ slot slot-no ]
View
Parameter
slot-no: Specifies slot number
Use the display memory command to display memory situation.
Example
# Display memory situation.
<H3C> display memory slot 0
System Total Memory(bytes): 197932416
Total Used Memory(bytes): 65234704
Used Rate: 32%
Table 3-3 Description on the fields of the display memory command
System Total Memory(bytes) |
The Total Memory of switch, unit in byte |
Total Used Memory(bytes) |
The Total used Memory of switch, unit in byte |
Used Rate |
The memory used rate |
3.1.9 display power
display power [ power-ID ]
View
Parameter
power-ID: Power ID.
Use the display power command to view the working state of the built-in power supply.
Example
# Show power state.
<H3C> display power
Power 1 State: Absent
Power 2 State: Normal
Power 3 State: Absent
View
Parameter
None
Use the display schedule reboot command to check the configuration of related parameters of the switch schedule reboot terminal service.
Related command: reboot, schedule reboot at.
Example
# Display the configuration of the schedule reboot terminal service parameters of the current switch.
<H3C> display schedule reboot
System will reboot at 16:00:00 2004/11/1 (in 2 hours and 5 minutes).
3.1.11 reboot
View
Parameter
slot slot-no: Specifies the physical card number.
Use the reboot command to reboot to restart the Ethernet switch or the specified card. Example
# Reset the Ethernet switch.
<H3C> reboot
3.1.12 schedule reboot at
schedule reboot at hh:mm [ yyyy/mm/dd ]
undo schedule reboot
View
Parameter
hh:mm: Reboot time of the switch, in the format of "hour: minute" The hh ranges from 0 to 23, and the mm ranges from 0 to 59.
yyyy/mm/dd: Reboot date of the switch, in the format of "year/month/day. The yyyy ranges from 2000 to 2099, the mm ranges from 1 to 12, and the value of dd is related to the specific month.
Use the schedule reboot at command to enable the timing reboot function of the switch and set the specific reboot time and date.
Use the undo schedule reboot command to disable the timing reboot function.
By default, the timing reboot switch function is disabled.
& Note:
The precision of switch timer is 1 minute. The switch will reboot in one minute when time comes to the specified rebooting point.
If the schedule reboot at command sets specified date parameters, which represents a data in the future, the switch will be restarted in specified time, with error not more than 1 minute.
If no specified date parameters are configured, two cases are involved: If the configured time is after the current time, the switch will be restarted at the time point of that day; if the configured time is before the current time, the switch will be restarted at the time point of the next day.
It should be noted that the configured date should not exceed the current date more than 30 days. In addition, after the command is configured, the system will prompt you to input confirmation information. Only after the "Y" or the "y" is entered can the configuration be valid. If there is related configuration before, it will be covered directly.
Moreover, after the schedule reboot at command is configured and the system time is adjusted by the clock command, the former configured schedule reboot at parameter will go invalid.
Related command: reboot, display schedule reboot.
Example
# Set the switch to be restarted at 22:00 that night (the current time is 15:50).
<H3C> schedule reboot at 22:00
Reboot system at 22:00:00 UTC 2003/11/18 (in 6 hours and 10 minutes)
confirm?[Y/N]:y
aux0: schedule reboot parameters at 15:50:00 UTC 2003/11/18. And system will reboot at 22:00:00 UTC 2003/11/18
Proceed with reboot? [Y/N]:y
3.1.13 schedule reboot delay
schedule reboot delay { hhh:mm | mmm }
View
Parameter
hhh:mm: Waiting time for rebooting a switch, in the format of "hour: minute" The hhh ranges from 0 to 720, and the mm ranges from 0 to 59.
mmm: Waiting delay for rebooting a switch, in the format of "absolute minutes" . Ranging from 0 to 43200,
Use the schedule reboot delay command to enable the timing reboot switch function and set the waiting time.
& Note:
Two formats can be used to set the waiting delay of timing reboot switch, namely the format of "hour: minute" and the format of "absolute minutes". But the total minutes should be no more than 30×24×60 minutes, or 30 days.
After this command is configured, the system will prompt you to input confirmation information. Only after the "Y" or the "y" is entered can the configuration be valid. If there is related configuration before, it will be covered directly.
Moreover, after the schedule reboot at command is configured, and the system time is adjusted by the clock command, the original schedule reboot at parameter will become invalid.
Related command: reboot, schedule reboot at, undo schedule reboot, display schedule reboot.
Example
# Configure the switch to be restarted after 88 minutes (the current time is 21:32).
<H3C> schedule reboot delay 88
Reboot system for 23:00:00 UTC 2002/11/1 (in 1 hours and 28 minutes)
Confirm? [Y/N]:y
3.1.14 temperature-limit
temperature-limit slot down-value up-value
undo temperature-limit slot
View
Parameter
slot: Physical card number.
down-value: Lower temperature limit, in the range 0 to 70 °C.
up-value: Upper temperature limit, in the range 20 to 90 °C.
Use the temperature-limit command to configure temperature limit.
Use the undo temperature-limit command to restore temperature limit to default value.
Example
# Set the lower and upper temperature limit of card 0.
<H3C> temperature-limit 0 10 75
3.1.15 update l3plus
update l3plus slot slot-no filename file-name ftpserver server-name username user-name password password [ port port-num ]
View
Parameter
slot-no: Slot for the service processing board to be updated.
file-name: Name of upgrading file to be downloaded. The file suffix is .app.
server-name: IP address or host name of FTP Server where the file to be updated locates.
user-name: User name for file transfer protocol (FTP) login.
password: User password for FTP login.
port-num: FTP port number, in the range 0 to 65,535. By default, it is 21.
Use the update l3plus command to update service processing boards. After the command is executed, the system logs into an FTP Server with the host name, user name and user password provided. The system downloads the host software containing load program of service processing board to the system’s synchronous dynamic random access memory (SDRAM), and uses the file to enable service processing boards.
Example
# Update the service processing board in slot 2. The file to be downloaded is place in the host with the IP address 192.168.1.100, and its name is L3PLUS.app. The user name and password for FTP login are 654321 and 123456 respectively.
<H3C> system-view
[H3C] update l3plus slot 2 filename L3PLUS.app ftpserver 192.168.1.100 username 654321 password 123456
Chapter 4 System Maintenance Commands
4.1 Basic System Configuration and Management Commands
4.1.1 clock datetime
clock datetime HH:MM:SS YYYY/MM/DD
View
Parameter
HH:MM:SS: Current clock. HH ranges from 0 to 23. MM and SS range from 0 to 59.
YYYY/MM/DD: Specifies the current year, month and date. YYYY ranges from 2000 to 2100. MM ranges from 1 to 12 and DD ranges from 1 to 31.
Use the clock datetime command to configure the current date and clock of Ethernet Switch.
By default, the date and clock of Ethernet Switch is set as 0:0:0, 2000/1/1.
The current date and clock of Ethernet Switch must be set in the circumstance that absolute time is strictly required.
Related command: display clock.
Example
# Set the current date of Ethernet Switch to 0:0:0, 2001/01/1.
<H3C> clock datetime 0:0:0 2001/01/01
4.1.2 clock summer-time
clock summer-time zone-name { one-off | repeating } start-time start-date end-time end-date offset-time
undo clock summer-time
View
Parameter
zone-name: Name of the summer time, which is a string with the length ranging 1 to 32 characters.
one-off: Only set the summer time of a certain year.
repeating: Set the summer time of every year starting from a certain year.
start-time: Set start time of the summer time, input like HH:MM:SS (hour/minute/second).
start-date: Set start date of the summer time, input like YYYY/MM/DD (year/month/day).
end-time: Set end time of the summer time, input like HH:MM:SS (hour/minute/second).
end-date: Set end date of the summer time, input like YYYY/MM/DD (year/month/day).
offset-time: Set offset time of the summer time, input like HH:MM:SS (hour/minute/second).
Use the clock summer-time command to set the name, starting and ending time of the summer time.
Use the undo clock summer-time command to remove the configuration of the summer time.
After the configuration takes effect, the display clock command can be used to check it. Besides, the time of the log or Debugging information uses the local time after the adjustment of the time zone and summer time.
Related command: clock timezone.
Example
# Set the summer time for z2 that starts at 06:00:00 on 08/06/2002 and ends at 06:00:00 on 01/09/2002 with the time adding 1 hour.
<H3C> clock summer-time z2 one-off 06:00:00 2002/06/08 06:00:00 2002/09/01 01:00:00
# Set the summer time for z2 that starts at 06:00:00 on 08/06 and ends at 06:00:00 on 01/09 in each year from 2002 on with the time adding 1 hour.
<H3C> clock summer-time z2 repeating 06:00:00 2002/06/08 06:00:00 2002/09/01 01:00:00
4.1.3 clock timezone
clock timezone zone-name { add | minus } HH:MM:SS
undo clock timezone
View
Parameter
zone-name: Name of the time zone, which is a character with the length ranging from 1 to 32.
add: Tme is adding compared with the UTC.
minus: Time is minus compared with the UTC.
HH:MM:SS: Time (hour/minute/second).
Use the clock timezone command to set the information of the local time zone.
Use the undo clock timezone command to restore to the default Universal Time Coordinated (UTC) time zone.
After the configuration takes effect, the display clock command can be used to check it. Besides, the time of the log or debug information uses the local time after the adjustment of the time zone and summer time.
Related command: clock summer-time.
Example
# Set the name of the local time zone as Z5 with the time adding 5 hours compared with the UTC.
<H3C> clock timezone z5 add 05:00:00
4.1.4 quick-ping enable
quick-ping enable
undo quick-ping enable
View
Parameter
None
Use the quick-ping enable command to enable the PING distribution function.
Use the undo quick-ping enable command to disable the PING distribution function.
By default, the PING distribution function is enabled.
Example
# Enable the ping distribution function.
<H3C> system-view
[H3C] quick-ping enable
4.1.5 sysname
sysname sysname
undo sysname
View
Parameter
sysname: Specifies the hostname with a character string with the length ranging from1 to 30 characters. The name of the Ethernet switch defaults to H3C.
Use the sysname command to configure the hostname of Ethernet Switch.
By default, the hostname of Ethernet Switch is H3C.
Changing the hostname name of Ethernet Switch will affect the prompt of command line interface. E.g. the host name of Ethernet Switch is H3C, and the prompt in user view is <H3C>.
Example
# Set the hostname of the Ethernet Switch as H3CLANSwitch.
<H3C> system-view
[H3C] sysname H3CLANSwitch
[H3CLANSwitch]
4.2 Clock Module Commands
4.2.1 clock
clock { auto | manual source source }
View
Parameter
auto: The clock works in the auto mode.
manual: The clock works in the manual mode.
source: Sets the primary clock source in manual mode.
source: The index of clock source, ranging from 1 to 18.
Use the clock command to set the work mode of the clock module on the main processing card (SRPU), namely, the mode of clock selecting clock source, including auto mode and manual mode.
If it is necessary to set the clock source, you need to query the state of the clock source first. Only the clock source working normally can be selected.
1) In the manual mode, the clock module does not switch the clock source actively; it only traces the specified primary clock source. The set clock source priority and SSM level are not involved in control. If the primary clock source is lost, the phase lock mode of the clock module switches into Hold.
2) In auto mode
l If SSM is not involved in control, the set SSM level will be neglected, and the clock module will select a clock source by priority. If two clock sources have the same priority, they will be selected in the high-to-low order from clock source 1 to clock source 18. If the available clock source with the highest priority is lost, it will be switched to the next available clock source with the highest priority automatically. When the original clock source recovers, the clock module will switch to the original clock source. In this case, the manually set primary clock source will not work.
l If SSM is engaged in control, the clock module will select a clock source by SSM level first. If two clock sources have the same SSM level, they will be selected by the priority. If their have the same priority, they will be selected in high-to-low order from clock source 1 to clock source 18. If the available clock source with highest SSM level is lost, it will be switched to the next available clock source with the highest SSM level automatically. When the original clock source recovers, the clock module will switch back to the original clock source. In this case, the manually set primary clock source will not work.
3) Clock sources not engaged in switching
The following clock sources are neglected during clock source selection (when SSM is engaged in control):
l Clock sources whose signal is lost are unavailable clock sources, and are not engaged in switching.
l Clock sources with the priority of 0xFF are unconfigured clock sources, and are not engaged in switching.
l Clock sources with the SSM level being DNU should not be used for synchronization, and are not engaged in switching.
Example
# Set the work mode of clock module on the SRPU to auto.
<H3C> system-view
[H3C] clock auto
4.2.2 clock forcessm
clock forcessm { on | off } source source
View
Parameter
on: SSM is not extracted from clock source, namely, SSM is manually configured.
off: SSM is extracted from the clock source, and the configured SSM is invalid.
source: The number of the clock source, ranging from 1 to 18.
Use the clock sa-bit command to configure whether to use extracted or manually configured SSM.
Refer to the clock ssm command for SSM configuration.
Example
# Use SSM extracted from clock source 10.
<H3C> system-view
[H3C]clock forcessm off source 10
4.2.3 clock lpuport
clock lpuport slot slotid card cardid port portid
View
Parameter
slotid: The slot ID of interface card.
cardid: Card ID of ATM or POS interface card.
portid: Port ID.
Use the clock lpuport command to select the output port of the line clock source of the interface card.
Example
# Set the output port of the line clock source of the interface card 3 to port 1.
<H3C> system-view
[H3C] clock lpuport slot 3 card 1 port 1
4.2.4 clock priority
clock priority value source source
View
Parameter
value: Priority level, ranging from 1 to 18 or 255.
Use the clock priority command to set the priority level of the clock source of the clock module. The value is 255 by default.
Example
# Set the priority level of clock source 2 to 2.
<H3C> system-view
[H3C]clock priority 2 source 2
4.2.5 clock sa-bit
clock sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 } source source
View
Parameter
source: Numer of the Bits clock source, ranging from 1 to 2.
sa4: Time slot of sa4 bit.
sa5: Time slot of sa5 bit.
sa6: Time slot of sa6 bit.
sa7: Time slot of sa7 bit.
sa8: Time slot of sa8 bit.
Use the clock sa-bit command to set the time slot of a Bits clock source. sa4 through sa8 refer to the five bits, sa4 through sa8, of CRC4 CRC4 multiple-frame even-frame slot 0, one of which can be selected by the carrier to carry the SSM information according to ITU-T G.704.
Example
# Set the time slot of Bits clock source 1 to SA4.
<H3C> system-view
[H3C] clock sa-bit sa4 source 1
4.2.6 clock ssm
clock ssm { dnu | lnc | prc | sets | tnc | unknown } source source
View
Parameter
dnu: Should be used for synchronization (DNU).
lnc: G.812 local node clock signal (LNC).
prc:G.811 clock signal (PRC).
sets: Clock source signal of SDH equipment (SETS).
tnc: G.812 transfer node clock signal (TNC).
unknown: The quality of synchronization is unknown.
source: The number of clock source, ranging from 1 to 18.
Use the clock ssm command to set the SSM level of each clock source:
l For line clock source, the set SSM level is the SSM level of the clock source.
l For Bits clock source, if the input signal is 2048kbit/s (E1) and SSM is engaged in control, the SSM level of the clock source is the SSM level extracted from the input signal, and the set SSM level is neglected.
l For Bits clock source, if the input signal is 2048kHz signal, or the input signal is 2048kbits/s signal but SSM is not engaged in control, the set SSM level is the SSM level of the clock source.
SSM means Synchronization Status Marker, which is also referred to as synchronous quality information. It is used to indicate the level of synchronous timing signal in synchronous timing transfer link. For line clock sources, SSM is extracted by the interface card and reported to the SRPU, and then the SRPU sets the SSM of the line clock source for the clock module.
When the clock module is powered on, the clock level of all clock sources is unknown. From high to low, the order of SSM levels is: PRC > TNC > LNC > SETS > unknown > DNU. If the SSM level of a clock source is DNU and SSM is engaged in control, the clock source will not be selected during clock source switching.
The SRPU will notify the corresponding interface card about theSSM level after setting the SSM level. If the SSM level of the line clock source can be extracted, the set SSM level will be invalidated. Otherwise, the set SSM level will apply.
Example
# Set the SSM level of clock source 1 to DNU.
<H3C> system-view
[H3C] clock ssm dnu source 1
4.2.7 clock ssmcontrol
clock ssmcontrol { on | off }
View
Parameter
on: Enable SSM to be engaged in control.
off: Disable SSM from being engaged in control.
Use the clock ssmcontrol command to set whether the SSM function of the clock module is engaged in control.
l SSM is engaged in control: The level of the clock source is first determined by its SSM level during automatic clock source switching.
l SSM is not engaged in control: The SSM level can be set and queried, but the SSM level of the clock source is neglected during automatic clock source switching.
The SSM function of the clock module is not engaged in control by default.
Example
# Enable the SSM function to get engaged in control,
<H3C> system-view
[H3C] clock ssmcontrol on
4.2.8 clock stop warm-up
clock stop warm-up
View
Parameter
None
Use the clock stop warm-up command to force the clock module to stop warming up the local oscillator and switch into normal work.
Example
# Force the clock module to stop warming up the local oscillator and switch into normal work.
<H3C> system-view
[H3C] clock stop warm-up
4.2.9 display clock device
View
Parameter
None
Use the display clock device command to query the detailed information of the clock device.
Example
# Query the detailed information of the clock device.
<H3C> display clock device
Clock module detail information:
Clock module state is OK
SRAM state: OK
Output 38.88Mhz signal state: OK
PLL tru050 state: OK
PLL 88915 state: OK
OSC state: OK
I2C bus state: OK
EPLD state: OK
HDLC state: OK
E1 A state: OK
E1 B state: OK
Reference state
Work mode : auto
Traced reference : 0
Lock mode : freerun
OSC state : normal
SSM output level : LNC
SSM participate in control : No
reference state Priority SSM-level Forcessm Sa-bit lpu port
1 lost 255 UNKNOWN No 4 N/A
2 lost 255 UNKNOWN No 4 N/A
3 lost 255 UNKNOWN No N/A -
4 lost 255 UNKNOWN No N/A -
5 lost 255 UNKNOWN No N/A -
6 normal 255 UNKNOWN No N/A 0/1/1
7 lost 255 UNKNOWN No N/A -
8 lost 255 UNKNOWN No N/A -
9 lost 255 UNKNOWN No N/A -
10 lost 255 UNKNOWN No N/A -
11 lost 255 UNKNOWN No N/A -
12 lost 255 UNKNOWN No N/A -
13 lost 255 UNKNOWN No N/A -
14 lost 255 UNKNOWN No N/A -
15 lost 255 UNKNOWN No N/A -
16 lost 255 UNKNOWN No N/A -
17 lost 255 UNKNOWN No N/A -
18 lost 255 UNKNOWN No N/A -
4.2.10 display clock version
View
Parameter
None
Use the display clock version command to query the version information of the clock device.
Example
# Query version information of the clock device.
<H3C> display clock version
Clock module version
Software version: v010
Hardware version: Rev.A
CPLD version: v009
Release date: 2002.02.26
4.2.11 display clock d/a
display clock d/a
View
Parameter
None
Use the display clock d/a command to query the D/A value of the clock device.
Example
# Query the D/A value of the clock device.
<H3C> display clock d/a
DAC Voltage : 2048
4.2.12 display clock basephase
View
Parameter
None
Use the display clock basephase command to query base phase of the clock.
Example
# Query the base phase of the clock.
<H3C> display clock basephase
clock base phase : 0x0
4.2.13 display clock lpuport
View
Parameter
None
Use the display clock lpuport command to query the LPU port to output the clock reference source.
Example
# Query the LPU port to output the clock reference source.
<H3C> display clock lpuport
the LPU port which output clock reference:
reference lpu port(slot-card-port)
4 CPOS2/1/1
4.2.14 display clock source
View
Parameter
None
Use the display clock source command to query the status of the 18 clock sources.
Example
# Query the status of the 18 clock sources.
<H3C> display clock source
No primary reference is traced
reference state lpu port(slot-card-port)
1 lost N/A
2 lost N/A
3 lost -
4 normal 2/1/1
5 lost -
6 lost -
7 lost -
8 lost -
9 lost -
10 lost -
11 lost -
12 lost -
13 lost -
14 lost -
15 lost -
16 lost -
17 lost -
18 lost -
4.2.15 display clock self-test-result
View
Parameter
None
Use the display clock self-test-result command to query the clock self test result.
Example
# Query the clock self test result.
<H3C> display clock self-test-result
Clock module work mode: normal
Detail test report:
SRAM : normal
Output 38.88MHz signal: normal
PLL TRU050 : normal
PLL 88915 : normal
OSC : normal
I2C bus : normal
EPLD : normal
HDLC : normal
E1a : normal
E1b : normal
4.2.16 display clock priority
View
Parameter
None
Use the display clock priority command to query the priority levels of the 18 clock sources.
Example
# Query the priority levels of the 18 clock sources.
<H3C> display clock priority
reference priority
1 255
2 4
3 255
4 255
5 255
6 255
7 255
8 255
9 255
10 255
11 255
12 255
13 255
14 255
15 255
16 255
17 255
18 255
4.2.17 display clock ssm-level
View
Parameter
None
Use the display clock ssm-level command to query the SSM levels of the 18 clock sources.
Example
# Query the SSM levels of the 18 clock sources.
<H3C> display clock ssm-level
reference SSM level
1 LNC
2 UNKNOWN
3 UNKNOWN
4 LNC
5 UNKNOWN
6 UNKNOWN
7 UNKNOWN
8 UNKNOWN
9 UNKNOWN
10 UNKNOWN
11 UNKNOWN
12 UNKNOWN
13 UNKNOWN
14 UNKNOWN
15 UNKNOWN
16 UNKNOWN
17 UNKNOWN
18 UNKNOWN
4.2.18 display clock ssm-output
View
Parameter
None
Use the display clock ssm-output command to query the SSM output level of the clock.
Example
# Query the SSM output level of the clock.
<H3C> display clock ssm-output
SSM output level is LNC.
4.2.19 display clock phase-lock-state
View
Parameter
None
Use the display clock phase-lock-state command to query the phase lock status of the clock.
Example
# Query the phase lock status of the clock.
<H3C> display clock phase-lock-state
phase lock state: hold
osc state: noamal, finished warm-up
4.2.20 display clock work-mode
View
Parameter
None
Use the display clock work-mode command to query the clock work mode.
Example
# Query the clock work mode.
<H3C> display clock work-mode
clock work in auto mode.
4.2.21 display clock config
View
Parameter
None
Use the display clock config command to query the current configuration of the clock module.
Example
# Query the current configuration of the clock module.
<H3C> display clock config
Clock moduke current configuration:
work mode : AUTO
SSM participate in control: No
reference Priority SSM level Forcessm Sa-bit lpu port
1 255 LNC No 4 N/A
2 4 UNKNOWN No 5 N/A
3 255 UNKNOWN No N/A -
4 255 LNC No N/A -
5 255 UNKNOWN No N/A -
6 255 UNKNOWN No N/A -
7 255 UNKNOWN No N/A -
8 255 UNKNOWN No N/A -
9 255 UNKNOWN No N/A -
10 255 UNKNOWN No N/A -
11 255 UNKNOWN No N/A -
12 255 UNKNOWN No N/A -
13 255 UNKNOWN No N/A -
14 255 UNKNOWN No N/A -
15 255 UNKNOWN No N/A -
16 255 UNKNOWN No N/A -
17 255 UNKNOWN No N/A -
18 255 UNKNOWN No N/A -
4.3 System Status and System Information Query Commands
4.3.1 display clock
display clock
View
Parameter
None
Use the display clock command to display the system date and time information, so that you make timely changes if the system time is incorrect.
The maximum time value supported by this command is 23:59:59 9999/12/31.
Related command: clock datetime.
Example
# View the current system date and time.
<H3C> display clock
18:36:31 beijing Sat 2002/02/02
Time Zone : beijing add 01:00:00
Summer-Time : bj one-off 01:00:00 2003/01/01 01:00:00 2003/08/08 01:00:00
Table 4-1 Description of the output information of the display clock command
18:36:31 beijing Sat 2002/02/02 |
Current system time |
Time Zone : beijing add 01:00:00 |
Configured time zone information |
Summer-Time : bj one-off 01:00:00 2003/01/01 01:00:00 2003/08/08 01:00:00 |
Configured summer time information |
4.3.2 display debugging
display debugging [ interface interface-type interface-number ] [ module-name ]
View
Parameter
interface-type: The interface type supported by the switch. The value can be Ethernet, GigabitEthernet, AUX, Vlan-interface and so on.
interface-number: Interface number.
module-name: Module name.
Use the display debugging command to display debugging switches that have been turned on.
You can execute the display debugging to view which debugging switches have been turned on. If the command is executed without any parameter, the system will display all debugging switches that have been turned on.
Related command: debugging.
Example:
# Display all debugging switches that have been turned on.
<H3C> display debugging
Multicast packet forwarding debugging switch is on
4.3.3 display fiber-module
display fiber-module [ interface-type interface-number ]
View
Parameter
interface-type: The interface type supported by switch. the value can be Ethernet, GigabitEthernet and so on.
Use the display fiber-module command to display the information of the optical modules connected with all the optical interfaces in position on the current shelf, including module information, optical module type, connector type, vendor name, manufacturer part number, single mode or multi-mode, wave length, transmission distance and so on.
Use the display fiber-module [ interface-type interface-number | interface-name ] command to display optical module information of the specified port.
Example
# Display the optical module information of all optical interfaces in position on the current shelf.
<H3C> display fiber-module
Pos3/1/1:
Card info: 10G-XFP
Fiber connect: LC
VendorName: Intel Corp
PartNumber: TXN181072013X07
Mode: SingleMode
WaveLength: 1310nm
Length for 9um: 10km
Pos4/1/1:
Card info: 100BASE-SFP
Fiber connect: LC
VendorName: AGILENT
PartNumber: HFBR-5760LP
Mode: MultiMode
WaveLength: Unknown
Length for 50/125um: 0m
Length for 62.5/125um: 2000m
Warning: This Port Use Wrong Optical Module !
Pos4/1/2:
Card info: 1000BASE-SFP
Fiber connect: LC
VendorName: Hitachi Cable
PartNumber: HTR6511R
Mode: SingleMode
WaveLength: 1310nm
Pos4/1/3:
Card info: 2.5G-SFP
Fiber connect: LC
VendorName: FIBERXON INC
PartNumber: FTM-3125C-L2
Mode: SingleMode
WaveLength: 1310nm
Length for 9um: 2km
Pos4/1/4:
Fiber connect: LC
VendorName: AGILENT
PartNumber: HFBR-5710L
Mode: MultiMode
WaveLength: 950nm
Length for 50/125um: 550m
Length for 62.5/125um: 270m
GigabitEthernet6/1/1:
Card info: 10G-XFP
Fiber connect: LC
VendorName: JDS Uniphase
PartNumber: 64P0215
Mode: SingleMode
WaveLength: 1310nm
GigabitEthernet6/1/3:
Card info: 10G-XFP
Fiber connect: LC
PartNumber: 64P0215
Mode: SingleMode
WaveLength: 1310nm
Please refer to the following table for the information above.
Table 4-2 Description of the display fiber-module command information on display
Card info |
Card information |
Fiber connect |
Fiber connector type |
VendorName |
Vendor name |
PartNumber |
Manufacturer part number |
Mode |
Single mode or multi-mode |
WaveLength |
Wave length |
Length for X um: Y km/m |
The transmission distance of X-um sized fiber is Y km/h |
Length for A / B um: Y km/m |
The transmission diatance of the fiber with an inner diameter of um and outer diameter of is B um is Y km/m. |
4.3.4 display users
display users [ all ]
View
Parameter
all: display all users connected to the switch.
Use the display users command to view information about users connected to the switch.
Example
# Display the information about all the active users on the console.
<H3C> display users
UI Delay Type Ipaddress Username
+ 0 CON 0 00:00:00
130 VTY 0 00:00:05 TEL 192.168.1.253 tb
# Display the information about all the users on the console.
<H3C> display users all
+ 0 CON 0 00:00:00
129 AUX 0
+ 130 VTY 0 00:00:16 TEL 192.168.1.253 tb
131 VTY 1
132 VTY 2
133 VTY 3
134 VTY 4
Table 4-3 Description on the fields of the display users command
Information about an active user |
UI |
The first number is the absolute number of the UI (user interface), and the second number is the relative number of the UI. |
Delay |
The time elapsed after the last user input, in the format of hh:mm:ss |
Type |
User type, such as Telnet, SSH, PAD |
Ipaddress |
Initial connection location, that is, the IP address of the incoming host |
Username |
Name of the user who uses this UI, that is, the login username of this user. If the current terminal line is in anonymous login mode (AAA authentication is enabled on it), this field is null |
4.3.5 display version
display version
View
Parameter
e
Use the display version command to view such information as software version, issue date and the basic hardware configurations.
Example
# Display the information about the system version.
<H3C> display version
H3C COMWARE Platform Software
COMWARE software, Version 3.10, Alpha 1323
Copyright (c) 2004-2007 Hangzhou H3C Technologies Co.,Ltd. All rights reserved.
H3C S9500 uptime is 0 week, 0 day, 0 hour, 6 minutes
SRPC 1: uptime is 0 week,0 day,0 hour,6 minutes
H3CS9500 with 1 MPC755 Processor
512M bytes SDRAM
16384K bytes Flash Memory
512K bytes NVRAM Memory
PCB Version : Ver.C
BootROM Version : 201
CPLD Version : 005
Software Version : S9500-CMW310-A1323
LSB1FT48B0 5: uptime is 0 week,0 day,0 hour,4 minutes
H3CS9500 LPU with 1 MPC8245 Processor
128M bytes SDRAM
0K bytes NVRAM Memory
PCB Version : Ver.D
BootROM Version : 103
CPLD Version : 002
CPUCard 1
PCB Ver : .4
CPLD Ver : 001
SubCard 1
PCB Ver : REV.0
CPLD Ver : NONE
4.4 System Debug Commands
4.4.1 debugging
debugging { all | timeout interval | module-name [ debugging-option ] }
undo debugging { all | module-name [ debugging-option ] }
View
Parameter
all: Enables or disables all the debugging.
timeout interval: Specifies the interval during which the debugging all switch is on. The value ranges from 1 to 1440, in minutes. With this configuration, all debugging take the time at which they are enabled as the start time, and take effect during the predefined time. And after that, all debuggings are disabled.
module-name: Specifies the module name.
debugging-option: Debugging option.
Use the debugging command to enable the system debugging.
Use the undo debugging command to disable the system debugging.
By default, all the debugging processes are disabled.
Ethernet Switch provides various kinds of debugging functions for technical support personnel and experienced maintenance staff to troubleshoot the network.
Enabling the debugging will generate a large amount of debugging information and decrease the system efficiency. Specially, network system may collapse after all the debugging is enabled by debugging all command. So it is not suggested to use the debugging all command. It is convenient for the user to disable all the debugging with undo debugging all command.
Related command: display debugging.
Example
# Enable IP Packet debugging.
<H3C> debugging ip packet
IP packet debugging switch is on.
The above output shows that the IP packet debugging is enabled.
4.4.2 display diagnostic-information
View
Parameter
None
Use the display diagnostic-information command to view the current configuration information about all running modules. You can use all these information to help diagnose and troubleshoot the Ethernet switch.
When the Ethernet switch does not run well, you can collect all sorts of information about the switch to locate the source of fault. However, each module has its corresponding display command, which make it difficult for you to collect all the information needed. In this case, you can use display diagnostic-information command.
Example
# Display all system configuration information.
<H3C> display diagnostic-information
This operation may take a few minutes, continue?[Y/N]y
-------------------- display version --------------------
H3C Comware Routing Platform Software
COMWARE(R) Software, Version COMWAREHZV300R001B08D018, Release 0001
COMWARE(tm) Lanswitch Platform Software Version COMWAREHZV300R001B08D018
S9500 Software Version V100R002B02D018
S9500 Product Version S9500-COMWARE310-r1266
Compiled Sep 29 2005 03:43:00, RELEASE SOFTWARE
H3C S9500 uptime is 0 week, 2 days, 5 hours, 31 minutes
This device is H3C S9505
4.5 Network Connection Test Commands
4.5.1 ping
ping [ ip ] [ -a ip-address | -c count | -d | - f | -h ttl | -i interface-type interface-number | -n | - p pattern | -q | -r | -s packetsize | -t timeout | -tos tos | -v | -vpn-instance vpn-instance-name ]* host
View
Parameter
-a ip-address: Specifies the source IP address to transmit ICMP ECHO-REQUEST.
-c: count Specifies how many times the ICMP ECHO-REQUEST packet will be transmitted, ranging from 1 to 4,294,967,295. The default value is five.
-d: Configures the socket to be in DEBUGGING mode.
-f: Configures the packet to be dropped instead of being fragmented when the packet length is larger than interface MTU.
-h ttl: Configures TTL value for echo requests to be sent, range from 1 to 255. The default value is 255.
-i: Configures to choose packet sent on the interface.
-n: Configures to take the host parameter as IP address without domain name resolution.
-p: pattern is the hexadecimal padding of ICMP echo-request, for example -p ff pads the packet completely with ff. By default, the starting padding is 0x01, crescent, and the ending padding is 0x09, and then repeat.
-q: Configures not to display any other detailed information except statistics.
-r: Record route. By default, the system does not record route.
-s packetsize: Specifies the length of ECHO-REQUEST (excluding IP and ICMP packet header) in bytes. The length of the echo-request packet defaults to 56 bytes.
-t timeout: Maximum waiting time after sending the echo-request (measured in ms). The time defaults to 2000 ms.
-tos tos: Specifies TOS value for echo requests to be sent, range from 0 to 255. The default value is 0.
-v: Displays other received ICMP packets (non echo-response). By default, no other non echo-response ICMP packets is displayed.
-vpn-instance vpn-instance-nam: VPN instance name.
host: Destination host domain name or IP address of the destination host.
ip: Chooses IP ICMP packet.
Use the ping command to check the IP network connection and the reachability of the host.
The ping command sends ICMP ECHO-REQUEST message to the destination. If the network to the destination works well, then the destination host will send ICMP ECHO-REPLY to the source host after receiving ICMP ECHO-REQUEST.
Perform ping command to troubleshoot the network connection and line quality. The output information includes:
l Responses to each of the ECHO-REQUEST messages. If the response message is not received until timeout, output "Request time out". Or display response message bytes, packet sequence number, TTL and response time.
l The final statistics, including number of sent packets, number of response packets received, percentage of non-response packets and minimal/maximum/average value of response time.
If the network transmission rate is too low, you can increase the response message timeout.
Related command: tracert.
Example
# Check whether the host 202.38.160.244 is reachable.
<H3C> ping 202.38.160.244
ping 202.38.160.244 : 56 data bytes
Reply from 202.38.160.244 : bytes=56 sequence=1 ttl=255 time = 1ms
Reply from 202.38.160.244 : bytes=56 sequence=2 ttl=255 time = 2ms
Reply from 202.38.160.244 : bytes=56 sequence=3 ttl=255 time = 1ms
Reply from 202.38.160.244 : bytes=56 sequence=4 ttl=255 time = 3ms
Reply from 202.38.160.244 : bytes=56 sequence=5 ttl=255 time = 2ms
--202.38.160.244 ping statistics--
5 packets transmitted
5 packets received
0% packet loss
round-trip min/avg/max = 1/2/3 ms
4.5.2 tracert
tracert [ -a source-IP | -f first-TTL | -m max-TTL | -p port | -q num-packet | -vpn-instance vpn-instance-name | -w timeout ] string
View
Parameter
-a source-IP: Configures the source IP address used by tracert command;
-f: Configures to verify the -f switch, first-TTL specifies an initial TTL, ranging from 0 to the maximum TTL.first-TTL defaults to 1;
-m: Configures to verify the -m switch, max-TTL specifies a maximum TTL larger than the initial TTL. max-TTL defaults to 30;
-p: Configures to verify the -p switch, port is an integer host port number. Generally, user need not modify this option. port defaults to 33434;
-q: Configures to verify the -q switch, nqueries is an integer specifying the number of query packets sent, larger than 0. num-packet defaults to 3;
-vpn-instance vpn-instance-name: VPN instance name;
-w: Configures to verify the -wf switch, timeout is an integer specifying IP packet timeout in seconds, larger than 0.timeout defaults to 5s;
string: IP address of the destination host or the hostname of the remote system.
Use the command to Using tracert command, you can check the reachability of network connection and troubleshoot the network. User can test gateways passed by the packets transmitted from the host to the destination.
By default, when the parameters are not specified,
The tracert command sends a packet with TTL 1, and the first hop will send an ICMP error message back to indicate this packet cannot be transmitted (because of TTL timeout). Then this packet will be sent again with TTL 2, and the second hop will indicate a TTL timeout error. Perform this operation repeatedly till reaching the destination. These processes are operated to record the source address of each ICMP TTL timeout so as to provide a path to the destination for an IP packet.
After ping command finds some error on the network, perform tracert to locate the error.
The output of tracert command includes IP address of all the gateways to the destination. If a certain gateway times out, output "***".
Example
# Test the gateways passed by the packets to the destination host at 18.26.0.115.
<H3C> tracert 18.26.0.115
tracert to allspice.lcs.mit.edu (18.26.0.115), 30 hops max
1 helios.ee.lbl.gov (128.3.112.1) 0 ms 0 ms 0 ms
2 lilac-dmc.Berkeley.EDU (128.32.216.1) 19 ms 19 ms 19 ms
3 lilac-dmc.Berkeley.EDU (128.32.216.1) 39 ms 19 ms 19 ms
4 ccngw-ner-cc.Berkeley.EDU (128.32.136.23) 19 ms 39 ms 39 ms
5 ccn-nerif22.Berkeley.EDU (128.32.168.22) 20 ms 39 ms 39 ms
6 128.32.197.4 (128.32.197.4) 59 ms 119 ms 39 ms
7 131.119.2.5 (131.119.2.5) 59 ms 59 ms 39 ms
8 129.140.70.13 (129.140.70.13) 80 ms 79 ms 99 ms
9 129.140.71.6 (129.140.71.6) 139 ms 139 ms 159 ms
10 129.140.81.7 (129.140.81.7) 199 ms 180 ms 300 ms
11 129.140.72.17 (129.140.72.17) 300 ms 239 ms 239 ms
12 * * *
13 128.121.54.72 (128.121.54.72) 259 ms 499 ms 279 ms
14 * * *
15 * * *
16 * * *
17 * * *
18 ALLSPICE.LCS.MIT.EDU (18.26.0.115) 339 ms 279 ms 279 ms
4.6 Log Commands
4.6.1 display channel
display channel [ channel-number | channel-name ]
View
Parameter
channel-number: Channel number, ranging from 0 to 9, that is, the system has ten channels.
channel-name: Specifies the channel name. the name can be channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile.
Use the display channel command to view the details about the information channel.
Without parameter, display channel command shows the configurations of all the channels.
Example
# Show details about the information channel 0.
<H3C> display channel 0
channel number:0, channel name:console
MODU_ID NAME ENABLE LOG LEVEL ENABLE TRAP LEVEL ENABLE DEBUGGING LEVEL
0xffff0000 default Y warning Y debugging Y debugging
4.6.2 display info-center
display info-center
View
Parameter
None
Use the display info-center command to view the configuration of system log and the information recorded in the memory buffer.
If the information in the current log/trap buffer is less than the size of buffer, display the actual log/trap information.
Related command: info-center enable,info-center loghost,info-center logbuffer,info-center console channel,info-center monitor channel.
Example
# Show the system log information.
<H3C> display info-center
Information Center:enabled
Log host:
Console:
Monitor:
channel number:1, channel name:monitor
SNMP Agent:
channel number:5, channel name:snmpagent
Log buffer:
enabled, max buffer size:1024, current buffer size:256
current messages:6, channel number:4, channel name:logbuffer
dropped messages:0, overwrote messages:0
Trap buffer:
current messages:0, channel number:3, channel name:trapbuffer
Log file :
enabled,max file buffer size 32KB, current file buffer size 7KB,
channel number : 6, channel name : logfile
max log file number : 5, max length of each log file : 2MB
log file directory : cf:/logfile
Information timestamp setting:
log - date, trap - date, debug - boot
Table 4-4 Description on the fields of the display info-center command
Information Center: |
The status of the information center |
Log host: |
The status of the log host, including its IP address, occupied channel number, channel name, language and the priority level of the log host. |
Console: |
The status of the console port, including the occupied channel name and channel number. |
Monitor: |
The status of the monitoring port, including the occupied channel number and channel name. |
SNMP Agent: |
The status of the SNMP agent, including the occupied channel number and channel name. |
Log buffer: |
The status of the log buffer, including enable status, maximum size, current size, number of current messages, channel name, channel number, number of dropped messages, number of the overwritten messages. |
Trap buffer: |
The status of the trap buffer, including enable status, maximum size, current size, number of current messages, channel name, channel number, number of dropped messages, number of the overwritten messages. |
Log file |
The status of the log file, including enable status, maximum file buffer size, channel number, channel name, maximum number of log files, maximum size of the log file, storage path of log files. |
Information timestamp setting: |
Information timestamp settings, including the timestamp type of log messages, trap messages and debugging messages. |
4.6.3 display logbuffer
display logbuffer [ summary ] [ level [ levelnum | emergencies | alerts | critical | debugging | errors | informational | notifications | warnings ] ] [ | [ begin | exclude | include text ] [ size sizenum ]
View
Parameter
level: level.
levelnum: Information level value, ranging from 1 to 8.
emergencies, alerts, critical, debugging, errors, informational, notifications, warnings are the names of the eight log severity levels. You can type the values or names of the desired severity levels, which are equivalent, in commands. Table 4-5 gives the details.
Table 4-5 Severity levels defined in the information center
Severity |
Value |
emergencies |
1 |
Emergent errors |
alerts |
2 |
Errors you must correct immediately |
critical |
3 |
Critical errors |
errors |
4 |
Errors requiring your attention but not critical |
warnings |
5 |
Warning, an error may occur |
notifications |
6 |
Information requiring your attention |
informational |
7 |
General prompt information |
debugging |
8 |
Debugging information |
size: Configures the size of buffer.
sizenum: Size of buffer (number of messages which can be kept); ranging from 1 to 1024. By default, the size of the buffer is 256.
|: Filters the configuration information to be output by regular expression.
begin: Begins with the line that matches the regular expression.
exclude: Excludes lines that match the regular expression.
include: Includes lines that match the regular expression.
text: Defines the regular expression.
Table 4-6 Special characters in the regular expression
Special characters |
Restriction |
_ |
Underscore, similar to a wildcard and can stand for these characters: (^|$|[,(){} ]) A space, the beginning of the input string, the end of the input string |
If the first character in the regular expression is not a underscore, then there is no restriction on the number of the underscore (but it is restricted by the command length) If the first character in the regular expression is an underscore, then there should be less than five consecutive underscores. If the underscores in a command are discrete, on the first group of underscores are filtered for the output information, but not the subsequent underscores. |
Left parenthesis, push flag in program |
It is recommended not to use this character in the regular expression. |
Use the display logbuffer command to view the attribute of logbuffer and the information recorded in logbuffer.
Example
# Show the system logbuffer attribute and the log information in logbuffer.
<H3C> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 0
Current messages : 91
4.6.4 display logbuffer summary
display logbuffer summary [ level severity ]
View
Parameter
level: Information level.
severity: Information level, do not output information below this level. Information at different levels is as the following table:
Table 4-7 Severity levels defined in the information center
Severity |
Value |
emergencies |
1 |
Emergent errors |
alerts |
2 |
critical |
3 |
Critical errors |
errors |
4 |
warnings |
5 |
notifications |
6 |
informational |
7 |
debugging |
8 |
Use the display logbuffer summary command to view the summary information recorded in logbuffer.
Example
# Show the summary information recorded in logbuffer.
<H3C> display logbuffer summary
EMERG ALERT CRIT ERROR WARN NOTIF INFO DEBUG
0 0 0 0 94 0 1 0
4.6.5 display trapbuffer
display trapbuffer [ summary ] [ level [ levelnum | emergencies | alerts | critical | debugging | errors | informational | notifications | warnings ] ] [size sizenum]
View
Parameter
summary: Number of statistical logs.
sizenum: Size of buffer (number of messages which can be kept), ranging from 1 to 1024. By default, the size of the buffer is 256.
level: level.
Use the display trapbuffer command to view the attribute of trapbuffer and the information recorded in trapbuffer.
Example
# Show the system trapbuffer attribute and the log information in trapbuffer.
<H3C> display trapbuffer
Trapping Buffer Configuration and contents:
enabled
allowed max buffer size : 1024
actual buffer size : 256
channel number : 3 , channel name : trapbuffer
dropped messages : 0
overwrote messages : 0
current messages : 6
#Dec 31 14:01:25 2004 H3C DEV/2/LOAD FINISHED:
Trap 1.3.6.1.4.1.2011.2.23.1.12.1.20: frameIndex is 0, slotIndex 0.4
#Dec 31 14:01:33 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
Trap 1.3.6.1.4.1.2011.2.23.1.12.1.11: frameIndex is 0, slotIndex 0.2
#Dec 31 14:01:40 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
4.6.6 info-center channel name
info-center channel channel-number name channel-name
undo info-center channel channel-number
View
Parameter
channel-number: Channel number, ranging from 0 to 9, that is, system has ten channels.
channel-name: Specifies the channel name with a character string not exceeding 30 characters, excluding digit, "-", "/" or "\". .
Use the info-center channel name command to rename a channel specified by the channel-number as channel-name.
Use the undo info-center channel command to restore the channel name.
The system assigns a channel in each output direction by default. See the table below.
Table 4-8 Numbers and names of the channels for log output
Output direction |
Channel number |
Default channel name |
Console |
0 |
console |
Monitor |
1 |
monitor |
Info-center loghost |
2 |
loghost |
Trap buffer |
3 |
trapbuf |
Logging buffer |
4 |
logbuf |
snmp |
5 |
snmpagent |
Log file |
6 |
Logfile |
Note that the channel name cannot be duplicated.
Example
# Rename the channel 0 as execconsole.
<H3C> system-view
[H3C] info-center channel 0 name execconsole
4.6.7 info-center console channel
info-center console channel { channel-number | channel-name }
undo info-center console channel
View
Parameter
channel-name: Specifies the channel name. The name can be channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile.
Use the info-center console channel command to configure the channel through which the log information is output to the console.
By default, Ethernet switches do not output log information to the console.
This command takes effect only after system logging is started.
Related command: info-center enable, display info-center.
Example
# Configure to output log information to the console through channel 0.
<H3C> system-view
[H3C] info-center console channel 0
4.6.8 info-center enable
info-center enable
undo info-center enable
View
Parameter
None
Use the info-center enable command to enable the system log function.
Use the undo info-center enable command to disable system log function.
By default, system log function is enabled.
Only after the system log function is enabled can the system output the log information to the info-center loghost and console, and so on.
Related command: info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel, display info-center.
Example
# Enable the system log function.
<H3C> system-view
[H3C] info-center enable
4.6.9 info-center logbuffer
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ]*
undo info-center logbuffer [ channel | size ]
View
Parameter
channel: Configures the channel to output information to buffer.
buffersize: Size of buffer (number of messages which can be kept).
Use the info-center logbuffer command to configure to output information to the memory buffer.
Use the undo info-center logbuffer command to cancel the information output to buffer.
By default, the switch outputs information to the memory buffer whose size is 512.
This command takes effect only after the system logging is enabled.
Example
# Send log information to buffer and sets the size of buffer as 50.
<H3C> system-view
[H3C] info-center logbuffer size 50
4.6.10 info-center logfile
info-center logfile
undo info-center logfile
View
Parameter
None
Use the info-center logfile command to configure to output information to the logfile.
Use the undo info-center logfile command to cancel the information output to logfile.
Example
# Send log information to logfile.
<H3C> system-view
[H3C] info-center logfile
4.6.11 info-center loghost
info-center loghost host-ip-addr [ channel { channel-number | channel-name } | facility local-number | language { chinese | english } ]*
undo info-center loghost host-ip-addr
View
Parameter
host-ip-addr: IP address of info-center loghost.
channel: Configures information channel of the info-center loghost.
facility: Configures the recording tool of info-center loghost.
local-number: Record tool of info-center loghost, ranging from local0 to local7.
language: Sets the logging language.
chinese,english: Language used in log file.
Use the info-center loghost command to configure the system to output information to the log host.
Use the undo info-center loghost command to cancel output to info-center loghost.
By default, Ethernet switches do not output information to info-center loghost.
& Note:
You must input the correct IP address when configuring the IP address for the log host by using the info-center loghost command. If you input a loopback address, you are prompted for invalid address.
Example
# Configure to send log information to the UNIX workstation at 202.38.160.1.
<H3C> system-view
[H3C] info-center loghost 202.38.160.1
4.6.12 info-center loghost source
undo info-center loghost source
View
Parameter
interface-type interface-number: Layer 3 interface on the switch.
Use the command to Using info-center loghost source command, you can set source address of the packets sent to loghost as the address of the interface specified by the interface-name.
Use the command to Using undo info-center loghost source command, you can cancel the setting source address of the packets sent to loghost.
Example
# Set source address of the packets sent to loghost as the address of the VLAN interface 1.
<H3C> system-view
[H3C] info-center loghost source vlan-interface 1
4.6.13 info-center monitor channel
info-center monitor channel { channel-number | channel-name }
undo info-center monitor channel
View
Parameter
Use the info-center monitor channel command to configure the channel to output the log information to the user terminal.
Use the undo info-center monitor channel command to restore the channel to output the log information to the user terminal to default value.
By default, Ethernet switches do not output log information to user terminal.
Example
# Configure channel 0 to output log information to user terminal.
<H3C> system-view
[H3C] info-center monitor channel 0
4.6.14 info-center snmp channel
info-center snmp channel { channel-number | channel-name }
undo info-center snmp channel
View
Parameter
channel-number: Channel number, ranging from 0 to 9, that is, the system has ten channels. By default, channel 5 is used.
Use the info-center snmp channel command to configure new channel for transmitting the SNMP information.
Use the undo info-center snmp channel command to restore the default channel for transmitting the SNMP information.
The default channel for transmitting the SNMP information is channel 5.
Related command: display snmp.
Example
# Configure channel 6 as the SNMP information channel.
<H3C> system-view
[H3C] info-center snmp channel 6
4.6.15 info-center source
info-center source { modu-name | default } channel { channel-number | channel-name } [ debug { level severity | state state }* | log { level severity | state state }* | trap { level severity | state state }* ]*
undo info-center source { modu-name | default | all } channel { channel-number | channel-name }
View
Parameter
modu-name: Module name.
Table 4-9 gives the details.
Table 4-9 The module name field
Module name |
8021X |
802.1X module |
ACL |
ACL (access control list) module |
ADBM |
MAC address management module |
ARP |
ARP (address resolution protocol) module |
BGP |
BGP (border gateway protocol) module |
CFM |
Configuration file management module |
CMD |
Command module |
default |
Default setting of all modules |
DEV |
Device management module |
DHCP |
Dynamic host configuration protocol module |
DIAGCLI |
Diagnosis module |
DNS |
Domain name server module |
DRVMPLS |
MPLS (multiprotocol label switching) drive module |
DRV_L2 |
Layer 2 drive module |
DRV_L3 |
Layer 3 drive module |
DRV_L3MC |
Layer 3 multicast module |
MPLS |
DRVPOS |
POS drive module |
DRVQACL |
QACL drive module |
DRVVPLS |
VPLS (virtual private LAN service) drive module |
ETH |
Ethernet module |
FTPS |
FTP server module |
HA |
High availability module |
HABP |
HABP (Huawei authentication bypass protocol) module |
HGMPS |
HGMPS (Huawei group management protocol service) module |
HWCM |
Huawei configuration management MIB module |
IFNET |
Interface management module |
IGSP |
IGMP snooping module |
IP |
IP (internet protocol) module |
ISIS |
IS-IS (intermediate system-to-intermediate system intradomain routing protocol) module |
L2INF |
L2 interface management module |
L2V |
L2 VPN module |
LACL |
LAN switch ACL module |
LDP |
LDP (label distribution protocol) module |
LINKAGG |
LINKAGG module |
LQOS |
LAN switch QoS module |
LS |
Local server module |
LSPAGENT |
LSP (label switched path) agent module |
LSPM |
LSPM (label switch path management) module |
MIX |
Dual system management module |
MMC |
MMC module |
MODEM |
Modem module |
MPLSFW |
MPLS forward module |
MPM |
Multicast port management module |
MSDP |
MSDP (multicast source discovery protocol) module |
MSTP |
MSTP (multiple spanning tree protocol) module |
NAT |
NAT (network address translation) module |
NTP |
NTP (network time protocol) module |
OSPF |
OSPF (open shortest path first) module |
PHY |
Physical sublayer & physical layer module |
POS_SNMP |
POS SNMP (simple network management protocol) module |
PPP |
PPP (point to point protocol) module |
PSSINIT |
PSSINIT module |
RDS |
RADIUS module |
RM |
Routing management module |
RMON |
Remote monitor module |
RPR |
Resilent packet ring module |
RSA |
RSA (Revest, Shamir and Adleman) encryption module |
RTPRO |
Routing protocol module |
SHELL |
User interface module |
SNMP |
SOCKET |
Socket module |
SSH |
Secure Shell module |
SYSM |
System manage veneer module |
SYSMIB |
System MIB module |
TELNET |
Telnet module |
VFS |
VFS (virtual file system) module |
VLAN |
VLAN (virtual local area network) module |
VRRP |
VRRP (virtual router redundancy protocol) module |
VTY |
VTY (virtual type terminal) module |
default: All the modules.
log: Log information.
trap: Trap information.
all: Clears all the information filtering configuration on the channelnum channel except the default one.
debugging: Debugging information.
level: Level.
Table 4-10 gives detailed severity information:
Table 4-10 Severity levels defined in the information center
Severity |
Value |
emergencies |
1 |
Emergent errors |
alerts |
2 |
critical |
3 |
Critical errors |
errors |
4 |
warnings |
5 |
notifications |
6 |
informational |
7 |
debugging |
8 |
By default, the information level of each channel is as follows:
Table 4-11 Default information level of each channel
channel |
Log information level |
Trap information level |
Debugging information level |
Console |
warning |
debugging |
debugging |
Terminal |
warning |
debugging |
debugging |
Log host |
informational |
debugging |
debugging |
Trapbuffer |
informational |
warning |
debugging |
Logbuffer |
warning |
debugging |
debugging |
SNMPagent |
debugging |
warning |
debugging |
Logfile |
warning |
debugging |
debugging |
Channel7 |
debugging |
debugging |
debugging |
Channel8 |
debugging |
debugging |
debugging |
Channel9 |
debugging |
debugging |
debugging |
By default, the information switch state of each channel is shown in Table 4-12:
Table 4-12 Default information switch state of each channel
Channel |
Log information switch |
Trap information switch |
Debug information switch |
Console |
Enable |
Disable |
Enable |
Terminal |
Enable |
Disable |
Enable |
Log host |
Enable |
Enable |
Disable |
Trapbuffer |
Disable |
Enable |
Disable |
Logbuffer |
Enable |
Disable |
Disable |
SNMPagent |
Disable |
Enable |
Disable |
Logfile |
Enable |
Disable |
Disable |
Channel7 |
Enable |
Enable |
Disable |
Channel8 |
Enable |
Enable |
Disable |
Channel9 |
Enable |
Enable |
Disable |
& Note:
If you only specify the level for one/two of the three types of information, the level(s) of the unspecified two/one return(s) to the default. For example, if you only define the level of the log information, then the levels of the trap and debugging information return to the defaults.
channel-number: Channel number to be set.
channel-name: Channel name to be set. The name can be channel7, channel8, channel9, console, logbuffer, loghost, monitor, snmpagent, trapbuffer, logfile.
state: Sets the state of the information.
state: Specifies the state as on or off.
Use the info-center source command to add/delete a record to the information channel.
Use the undo info-center source command to cancel the contents of the information channel.
Use this command to configure the information of log/trap/debugging type. For example, for the filter of IP module log output, you can configure to output the logs at a level higher than warnings to the log host and output those higher than informational to the log buffer. You can also configure to output the trap information on the IP module to a specified trap host, and so on.
The channels for filtering in all the directions are specified by this configuration command. All the information will be sent to the corresponding directions through the specified channels. You can configure the channels in the output direction, channel filter information, filtering and redirecting of all kinds of information.
At present, the system distributes an information channel in each output direction by default, shown as follows:
Table 4-13 Default information channel in each output direction
Output direction |
Information channel name |
Console |
console |
Monitor |
monitor |
loghost |
Log buffer |
logbuffer |
Trap buffer |
trapbuffer |
snmp |
snmpagent |
Log file |
logfile |
In addition, each information channel has a default record with the module name “default” and module number as 0xffff0000. However, for different information channel, the default log, trap and debugging settings in the records may be different with one another. Use default configuration record if a module does not have any specific configuration record in the channel.
Example
# Configure to enable the log information of VLAN module in SNMP channel and allows the output of the information with a level higher than emergencies.
<H3C> system-view
[H3C] info-center source vlan channel snmp log level emergencies
4.6.16 info-center timestamp
info-center timestamp { log | trap | debugging } { boot | date | none }
undo info-center timestamp { log | trap | debugging }
View
Parameter
boot: Time elapsing after system starts. Format: xxxxxx.yyyyyy, xxxxxx is the high 32 bits of the elapsed time (in milliseconds) after system starts, and yyyyyy is the low 32 bits.
date: Current system date and time. It shows as yyyy/mm/dd-hh:mm:ss in Chinese environment and mm dd hh:mm:ss yyyy in Western language environment.
none: No timestamp format.
Use the info-center timestamp command to configure the timestamp output format in debugging/trap information.
Use the undo info-center timestamp command to disable the output of timestamp field.
By default, date stamp is used.
Example
# Configure the debugging information timestamp format as boot.
<H3C> system-view
[H3C] info-center timestamp debugging boot
4.6.17 info-center trapbuffer
info-center trapbuffer [ size buffersize | channel { channel-number | channel-name } ]*
undo info-center trapbuffer [ channel | size ]
View
Parameter
size: Configures the size of the trap buffer.
buffersize: Size of trap buffer (numbers of messages).
channel: Configures the channel to output information to trap buffer.
Use the info-center trapbuffer command to output information to the trap buffer.
Use the undo info-center trapbuffer command to cancel output information to trap buffer.
By default, output information is transmitted to trap buffer and size of trap buffer is 256.
The information can be output to the trap buffer by configuring the size of the buffer.
Example
# Send information to the trap buffer and sets the size of buffer as 30.
<H3C> system-view
[H3C] info-center trapbuffer size 30
4.6.18 reset logbuffer
reset logbuffer
View
Parameter
None
Use the reset logbuffer command to reset information in log buffer.
Example
# Clear information in log buffer.
<H3C> reset logbuffer
4.6.19 reset trapbuffer
reset trapbuffer
View
Parameter
None
Use the reset trapbuffer command to reset information in trap buffer.
Example
# Clear information in trap buffer.
<H3C> reset trapbuffer
4.6.20 terminal debugging
terminal debugging
undo terminal debugging
View
Parameter
None
Use the terminal debugging command to configure to display the debugging information on the terminal.
Use the undo terminal debugging command to configure not to display the debugging information on the terminal.
By default, the displaying function is disabled.
Example
# Enable the terminal display debugging.
<H3C> terminal debugging
4.6.21 terminal logging
terminal logging
undo terminal logging
View
Parameter
None
Use the terminal logging command to enable terminal log information display.
Use the undo terminal logging command to disable terminal log information display.
By default, the log information display is enabled on the console and disabled on the terminal.
Example
# Disable the terminal log display.
<H3C> undo terminal logging
4.6.22 terminal monitor
terminal monitor
undo terminal monitor
View
Parameter
None
Use the terminal monitor command to enable the log debugging/log/trap on the terminal monitor.
Use the undo terminal monitor command to disable these functions.
By default, enable these functions for the console user and disable them for the terminal user.
This command only takes effect on the current terminal where the commands are input. The debugging/log/trap information can be output to the current terminal, beginning in user view. When the terminal monitor is shut down, no debugging/log/trap information will be displayed in local terminal, which is equals to having performed undo terminal debugging, undo terminal logging, undo terminal trapping commands. When the terminal monitor is enabled, you can use terminal debugging / undo terminal debugging, terminal logging / terminal logging and terminal trapping / undo terminal trapping respectively to enable or disable the corresponding functions.
Example
# Disable the terminal monitor.
<H3C> undo terminal monitor
4.6.23 terminal trapping
terminal trapping
View
Parameter
None
Use the terminal trapping command to enable terminal trap information display.
Use the undo terminal trapping command to disable this function.
By default, this function is enabled.
Example
# Enable trap information display.
<H3C> terminal trapping
Chapter 5 SNMP Configuration Commands
5.1 SNMP Configuration Commands
5.1.1 display snmp-agent
display snmp-agent { local-engineid | remote-engineid }
View
Parameter
local-engineid: Local engine ID.
remote-engineid: Remote engine ID.
Use the display snmp-agent { local-engineid | remote-engineid } command to view engine ID of current device.
SNMP engine is the core of SNMP entity. It performs the function of sending, receiving and authenticating SNMP message, extracting PDU, packet encapsulation and the communication with SNMP application, and so on.
Example
# Display the engine ID of current device.
<H3C> display snmp-agent local-engineid
SNMP local EngineID: 800007DB00E0FC0000FF6877
The above displayed information ”SNMP local engine ID” represents local SNMP engine ID.
5.1.2 display snmp-agent community
View
Parameter
read: Displays read-only community information.
write: Displays read-write community information.
Use the display snmp-agent community command to view the currently configured community names.
Example
# Display the currently configured community names.
<H3C> display snmp-agent community
Group name:public
Storage-type: nonVolatile
Community name:private
Group name:private
Table 5-1 Description on the fields of the display snmp-agent community command
community name |
Community name |
Group name |
Group name |
storage-type |
Storage mode |
5.1.3 display snmp-agent group
display snmp-agent group [ group-name ]
View
Parameter
groupname: Group name.
Use the display snmp-agent group command to view group name, security mode, state of various views and storage modes.
Example
# Display SNMP group name and safe mode.
<H3C> display snmp-agent group
Group name: test
Security model: v2c noAuthnoPriv
Readview: ViewDefault
Writeview: <no specified>
Notifyview :<no specified>
The following table describes the output fields.
Table 5-2 Description on the fields of the display snmp-agent group command
groupname |
SNMP Group name |
Security model |
The security mode adopted by SNMP |
readview |
Read-only MIB view name corresponding to that group |
writeview |
Writable MIB view corresponding to that group |
notifyview |
The name of the notify MIB view corresponding to that group |
storage-type |
Storage mode |
5.1.4 display snmp-agent mib-view
display snmp-agent mib-view [ exclude | include | { viewname mib-view } ]
View
Parameter
exclude: Displays the SNMP MIB view excluded.
Include: Displays the SNMP MIB view included.
viewname: Displays the SNMP MIB view according to the mib view name.
mib-view: Specifies the MIB view name.
Use the display snmp-agent mib-view command to view the MIB view configuration information of the Ethernet switch.
Example
# Display the information about the currently configured MIB view.
<H3C> display snmp-agent mib-view
View name:ViewDefault
MIB Subtree:internet
Subtree mask:
View Type:included
View status:active
MIB Subtree:snmpUsmMIB
Subtree mask:
View Type:excluded
View status:active
MIB Subtree:snmpVacmMIB
Subtree mask:
View Type:excluded
View status:active
Table 5-3 Description on the fields of the display snmp-agent mib-view command
View name |
View name |
MIB Subtree |
MIB subtree |
Subtree mask |
Subtree mask |
storage-type |
Storage type |
View Type |
Permit or forbid access to an MIB object |
View status |
Indicate the line state in the table |
Caution:
If the SNMP Agent is disabled, "Snmp Agent disabled" will be displayed after you execute the above display commands.
5.1.5 display snmp-agent statistics
View
Parameter
None
Use the display snmp-agent statistics command to view current state of SNMP communication.
This command provides a counter for SNMP operations.
Example
# Display the current state of SNMP communication.
<H3C> display snmp-agent statistics
0 Messages delivered to the SNMP entity
0 Messages which were for an unsupported version
0 Messages which used a SNMP community name not known
0 Messages which represented an illegal operation for the community supplied
0 ASN.1 or BER errors in the process of decoding
9 Messages passed from the SNMP entity
0 SNMP PDUs which had badValue error-status
0 SNMP PDUs which had genErr error-status
0 SNMP PDUs which had noSuchName error-status
0 SNMP PDUs which had tooBig error-status (Maximum packet size 2000)
9 MIB objects retrieved successfully
0 MIB objects altered successfully
0 GetRequest-PDU accepted and processed
9 GetNextRequest-PDU accepted and processed
0 GetBulkRequest-PDU accepted and processed
9 GetResponse-PDU accepted and processed
0 SetRequest-PDU accepted and processed
0 Trap PDUs accepted and processed
0 Alternate Response Class PDUs droped silently
0 Forwarded Confirmed Class PDUs droped silently
Table 5-4 Description on the fields of the display snmp-agent statistics command
9 Get-next PDUs accepted and processed |
Total number of the input SNMP packets |
0 GetBulkRequest-PDU accepted and processed |
Number of packets with version information error |
0 GetResponse PDUs accepted and processed |
Number of packets with community name error |
0 Set-request PDU accepted and processed |
Number of packets with authority error corresponding to the community name |
0 Trap PDUs accepted and processed |
Number of SNMP packets with encoding error |
0 Alternate Response Class PDUs droped silently |
Number of SNMP data packets output |
0 Forwarded Confirmed Class PDUs droped silently |
Number of SNMP packets with erroneous values |
Number of SNMP packets with general error |
Number or packets request for nonexistent MIB objects |
Number of too long SNMP packets |
Number of variables requested by NMS |
Number of variables sent by NMS |
Number of the received packets requested by get |
Number of the received packets requested by get-next |
Number of the received packets requested by getBulk |
Number of the response packets sent |
Number of the Trap packets sent |
Number of the response packets dropped |
Number of the Trap packets dropped |
5.1.6 display snmp-agent sys-info
display snmp-agent sys-info [ contact | location | version ]*
View
Parameter
None
Use the display snmp-agent sys-info command to view the character string sysContact (system contact), character string describing the system location and the version information about the running SMNMP in the system.
Example
# Display the character string sysContact.
<H3C> display snmp-agent sys-info contact
The contact person for this managed node:
The above information represents that the contact person for this machine is Hangzhou H3C Technologies Co.,Ltd.
# Display the character string describing the system location.
<H3C> display snmp-agent sys-info location
The physical location of this node:
Hangzhou ,China
The above information represents that the physical location of this machine is: Hangzhou ,China.
# Display the version information of running SNMP
<H3C> display snmp-agent sys-info version
SNMP version running in the system:
SNMPv3
The above information represents that the SNMP version running in the system is: SNMPv3.
5.1.7 display snmp-agent usm-user
display snmp-agent usm-user [ engineid engineid | group groupname | username username ]*
View
Parameter
engineid: Displays user information with specified engine ID.
username: Displays user information with specified user name.
groupname: Displays user information of specified group.
Use the display snmp-agent usm-user command to view information of all the SNMP usernames in the group username list.
SNMP user is the remote user executing SNMP administrative operation. You can use the snmp-agent usm-user command to specify the SNMP user.
Example
# Display the information of all the current users.
<H3C> display snmp-agent usm-user
Group name: NotifyGroup
Authencation Mode: sha
Privacy Mode: des
Engine ID: 800007DB00E0FC2085026877 active
User name: publicV3
Group name: groupV3
Authencation Mode: no
Privacy Mode: no
Acl:2000
Table 5-5 Description on the fields of the display snmp-agent usm-user command
User name |
Character string identifying the SNMP user |
Group name |
Character string identifying the group the user belongs to |
Authencation Mode |
Authentication code |
Privacy Mode |
Personal code |
Engine ID |
Character string identifying the SNMP device |
Acl |
Character string identifying the access control list |
5.1.8 enable snmp trap
enable snmp trap updown
undo enable snmp trap updown
View
Ethernet port view / VLAN interface view
Parameter
None
Use the enable snmp trap updown command to enable current port or VLAN interface to transmit the LINK UP and LINK DOWN trap messages.
Use the undo enable snmp trap updown command to disable current port or VLAN interface to transmit the LINK UP and LINK DOWN trap messages.
The enable snmp trap command should be used in cooperation with the snmp-agent trap enable and the snmp-agent target-host commands. The snmp-agent target-host command is used to specify which hosts can receive the trap messages. To enable the transmitting of trap messages, you must execute the snmp-agent target-host command at least once.
Example
# Enable current port Ethernet6/1/1 to transmit the LINK UP and LINK DOWN trap information with the community name public
<H3C> system-view
[H3C-Ethernet6/1/1] snmp trap updown enable
[H3C] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[H3C] interface ethernet6/1/1
[H3C-Ethernet6/1/1] enable snmp trap updown
5.1.9 snmp-agent community
snmp-agent community { read | write } community-name [ [ mib-view view-name ] [ acl acl-list ] ]
undo snmp-agent community community-name
View
Parameter
read: Indicates that MIB object can only be read.
write: Indicates that MIB object can be read and written.
community-name: Community name character string.
view-name: MIB view name.
acl acl-list: sets access control list for specified community.
Use the snmp-agent community command to configure community access name and enable the access to SNMP.
Use the undo snmp-agent community command to cancel the settings of community access name.
Example
# Configure community name as comaccess and permits read-only access by this community name.
<H3C> system-view
[H3C] snmp-agent community read comaccess
# Configure community name as mgr and permits read-write access.
[H3C] snmp-agent community write mgr
# Delete the community name comaccess.
[H3C] undo snmp-agent community comaccess
5.1.10 snmp-agent group
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-list ]
undo snmp-agent group { v1 | v2c } group-name
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [notify-view notify-view ] [ acl acl-list ]
undo snmp-agent group v3 group-name [ authentication | privacy ]
View
Parameter
v1: V1 security mode.
v2c: V2C security mode.
v3: V3 security mode.
group-name: Group name, ranging from 1 to 32 bytes.
authentication: Configures to authenticate the packet without encryption.
privacy: Configures to authenticate and encrypt the packet.
read-view: Configures to allow read-only view settings.
read-view: Read-only view name, ranging from 1 to 32 bytes.
write-view: Configures to allow read-write view settings.
write-view: Name of read-write view, ranging from 1 to 32 bytes.
notify-view: Configures to allow notify view settings.
notify-view: Specifies the notify view name, ranging from 1 to 32 bytes.
acl Sets access control list for this group name.
acl-list: access control list
Use the snmp-agent group command to configure a new SNMP group, that is, to map SNMP user to SNMP view.
Use the undo snmp-agent group command to cancel a specified SNMP group.
By default, the SNMP group configured using the snmp-agent group v3 command is in none authentication mode.
Related command: snmp-agent mib-view and snmp-agent usm-user.
Example
# Create an SNMP group named test.
<H3C> system-view
[H3C] snmp-agent group v3 test.
5.1.11 snmp-agent local-engineid
undo snmp-agent local-engineid
View
Parameter
engineid: Specifies the engine ID with a character string, only composed of hexadecimal numbers between 5 and 32 including.
Use the snmp-agent local-engineid command to configure a name for a local or remote SNMP engine on the Ethernet Switch.
Use the command to Using undo snmp-agent local-engineid command, you can restore the default setting of engine ID.
By default, the engine ID is corporation number + device information. Device information is determined according to different products. It can be IP address, MAC address or user defined text. However, you must use numbers in hexadecimal form.
Example
# Configure the ID of a local or remote device as 1234512345.
<H3C> system-view
[H3C] snmp-agent local-engineid 1234512345
5.1.12 snmp-agent mib-view
snmp-agent mib-view { included | excluded } view-name oid-tree
undo snmp-agent mib-view view-name
View
Parameter
included: Includes this MIB subtree.
excluded: Excludes this MIB subtree.
view-name: Specifies the view name, with a character string, ranging from 1 to 32 characters.
oid-tree: MIB object subtree. It can be a character string of the variable OID, or a variable name, ranging from 1 to 255 characters. By default, OID is 1.3.6.1.
Use the snmp-agent mib-view command to create or update the view information.
Use the undo snmp-agent mib-view command to cancel the view information
By default, the view name is ViewDefault. OID is 1.3.6.1.
This command supports the parameter input of both OID and node name.
Related command: snmp-agent group.
Example
# Create a view that consists of all the objects of MIB-II.
<H3C> system-view
[H3C] snmp-agent mib-view included mib2 1.3.6.1.2.1
5.1.13 snmp-agent packet max-size
undo snmp-agent packet max-size
View
Parameter
byte-count: Specifies the size of SNMP packet (measured in bytes), ranging from 484 to 17940. By default, the size is 2000 bytes.
Use the snmp-agent packet max-size command to configure the size of SNMP packet that the Agent can send/receive.
Use the undo snmp-agent packet max-size command to restore the default size of SNMP packet.
The sizes of the SNMP packets received/sent by the Agent are different in different network environment.
Example
# Set the size of SNMP packet to 1042 bytes.
<H3C> system-view
[H3C] snmp-agent packet max-size 1042
5.1.14 snmp-agent sys-info
snmp-agent sys-info { contact sysContact | location syslocation | version { { v1 | v2c | v3 } * | all } }
undo snmp-agent sys-info { { contact | location }* | version { { v1 | v2c | v3 } * | all } }
View
Parameter
contact: The contact information for system maintenance.
sysContact: Characters describe the contact information for system maintenance.
location: Sets the geographical location of the device.
sysLocation: Geographical location of the device.
version: version of running SNMP.
v1: SNMP V1.
v2c: SNMP V2C.
v3: SNMP V3.
*: Indicates that you can select more than one item from the three options v1, v2c, and v3. Here, you must select at least one option, and you can select all the three options.
all: all SNMP version (includes SNMP V1, SNMP V2C, SNMP V3).
Use the snmp-agent sys-info command to configure system information such as geographical location of the device, contact information for system maintenance and version information of running SNMP.
Use the undo snmp-agent sys-info location command to restore the default value.
By default, the contact information for system maintenance is " Hangzhou H3C Technologies Co., Ltd.", the system information about geographical location is "Hangzhou ,China", and the version information is " SNMPv3".
Related command: display snmp-agent sys-info.
Example
# Set the system maintenance information to "Dial System Operator at beeper # 27345".
<H3C> system-view
[H3C] snmp-agent sys-info contact Dial System Operator at beeper # 27345
5.1.15 snmp-agent target-host
snmp-agent target-host trap address udp-domain host-addr [ udp-port udp-port-number ] params securityname securityname [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host host-addr securityname securityname
View
Parameter
address: Specifies the address of the host which receives SNMP messages.
host-addr: IP address of the host.
udp-port udp-port-number: Specifies the UDP port number of the host to receive the SNMP notification.
v1: Represent the version of SNMPV1.
v2c: Represent the version of SNMPV2C.
v3: Represent the version of SNMPV3.
securityname: Specifies the community name, ranging 1 to 32 bytes. It can be the community name of SNMPv1/v2c or the user name of SNMPv3.
Use the snmp-agent target-host command to configure destination of SNMP notification.
Use the undo snmp-agent target-host command to cancel the host that receives SNMP notification.
The snmp-agent target-host command and the snmp-agent trap enable command should be used at the same time. Use the snmp-agent trap enable command to enable the device to transmit Trap packets. The snmp-agent trap enable command and snmp-agent target-host command should be used at the same time on the host to enable notify message sending.
& Note:
If the version of SNMP message is v3, the packet authentication encryption mode specified by the command must be consistent with configuration for SNMP group to which the securityname belongs.
Related command: snmp-agent trap enable, snmp-agent trap source and snmp-agent trap life, snmp-agent group, snmp-agent usm-user.
Example
# Enable sending Trap message to 10.1.1.1 with community name public.
<H3C> system-view
[H3C] snmp-agent trap enable
5.1.16 snmp-agent trap enable
snmp-agent trap enable [ bgp [ backwardtransition | established ]* | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | ldp | lsp | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
undo snmp-agent trap enable [ bgp [ backwardtransition | established ]* | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | ldp | lsp | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
View
Parameter
standard [ authentication ] [ coldstart ] [ linkdown ] [ linkup ]: Enables the sending of standard Trap messages.
authentication: Enables the sending of SNMP authentication Trap messages.
coldstart: Enables the sending of SNMP cold start Trap messages.
linkdown: Enables the sending of SNMP link down Trap messages.
linkup: Enables the sending of SNMP link up Trap messages.
warmstart: Enables the sending of SNMP hot start Trap messages.
bgp [ backwardtransition ] [ established ] : Enables the sending of BGP Trap messages.
configuration: Enables the sending of configuration management Trap messages.
flash: Enables the sending of FLASH Trap messages.
System: Enables the sending of system management MIB Trap messages.
vrrp [ authfailure | newmaster ]: Enables the sending of VRRP Trap messages.
ldp: Enables the sending of LDP Trap messages.
lsp: Enables the sending of LSP Trap messages.
Use the snmp-agent trap enable command to enable the sending of Trap messages.
Use the undo snmp-agent trap enable command to disable the sending of Trap messages.
By default, Trap message sending is disabled.
The snmp-agent trap enable command and snmp-agent target-host command should be used at the same time. The snmp-agent target-host command specifies which hosts can receive Trap message. However, to send Trap message, at least one the snmp-agent target-host command should be configured.
Example
# Enable to send the trap packet of SNMP authentication failure to 10.1.1.1. The community name is public.
<H3C> system-view
[H3C] snmp-agent trap enable standard authentication
5.1.17 snmp-agent trap life
snmp-agent trap life seconds
undo snmp-agent trap life
View
Parameter
seconds: Specifies the timeouts, ranging from 1 to 2,592,000 seconds; By default, the timeout interval is 120 seconds.
Use the snmp-agent trap life command to configure the timeout of Trap packets.
Use the undo snmp-agent trap life command to restore the default value.
The set timeout of Trap packet is represented by seconds. If time exceeds seconds, this Trap packet will be discarded.
Related command: snmp-agent trap enable, snmp-agent target-host .
Example
# Configure the timeout interval of Trap packet as 60 seconds.
<H3C> system-view
[H3C] snmp-agent trap life 60
5.1.18 snmp-agent trap queue-size
snmp-agent trap queue-size length
undo snmp-agent trap queue-size
View
Parameter
length: Length of queue, ranging from 1 to 1,000. By default, the length is 100.
Use the snmp-agent trap queue-size command to configure the information queue length of Trap packet sent to Destination Host.
Use the undo snmp-agent trap queue-size command to restore the default value.
Related command: snmp-agent trap enable, snmp-agent target-host, snmp-agent trap life.
Example
# Configure the queue length to 200.
<H3C> system-view
[H3C] snmp-agent trap queue-size 200
5.1.19 snmp-agent trap source
snmp-agent trap source vlan-interface vlan-id
undo snmp-agent trap source
View
Parameter
vlan-id: Specifies the VLAN interface ID, ranging from 1 to 4094.
Use the snmp-agent trap source command to configure the source address for sending Trap.
Use the undo snmp-agent trap source command to cancel the source address for sending Trap.
You can use this command to configure to track specific event by using the trap address.
Example
# Configure the IP address of the VLAN interface 1 as the source address for transmitting the Trap packets.
<H3C> system-view
[H3C] snmp-agent trap source vlan-interface 1
5.1.20 snmp-agent usm-user
snmp-agent usm-user { v1 | v2c } username groupname [ acl acl-list ]
undo snmp-agent usm-user { v1 | v2c } username groupname
snmp-agent usm-user v3 username groupname [ authentication-mode { md5 | sha } authpassstring [ privacy-mode { des56 privpassstring } ] ] [ acl acl-list ]
undo snmp-agent usm-user v3 username groupname { local | engineid engine-id }
View
Parameter
v1: Configures to use V1 safe mode.
v2c: Configures to use V2c safe mode.
v3: Configures to use V3 safe mode.
username: Specifies the user name, ranging from 1 to 32 bytes.
groupname: Specifies the group name corresponding to that user, a character string at the length ranging from 1 to 32 bytes.
authentication-mode: Specifies the safety level as authentication required.
md5: MD5 algorithm is adopted in authentication. MD5 authentication uses the 128-digit password. Computation speed of MD5 is faster than that of SHA
sha: SHA algorithm is adopted in authentication. SHA authentication uses the 160-digit password. Computation speed of SHA is slower than that of MD5, but with higher security.
authpasstring: Specifies the authentication password with a character string, ranging from 1 to 64 bytes.
privacy-mode: Specifies the safety level as encrypted.
des56: Specifies the authentication protocol as DES.
privpassword: Specifies the encryption password with a character string, ranging from 1 to 64 bytes.
acl acl-list: Sets access control list for this user based on USM name
engineid engine-id: SNMP engineID.
Use the snmp-agent usm-user command to add a new user to an SNMP group.
Use the undo snmp-agent usm-user command to cancel a user from SNMP group.
SNMP engineID (for authentication) is required when configuring remote user for an agent. This command will not be effective without engineID configured.
For V1 and V2C, this command will add a new community name. For V3, it will add a new user for an SNMP group.
Example
# Add a user wang for test (an SNMP group), configures to authenticate with MD5 and sets authentication password as pass.
<H3C> system-view
[H3C] snmp-agent usm-user v3 wang test authentication-mode md5 pass
5.1.21 undo snmp-agent
undo snmp-agent
View
Parameter
None
Use the undo snmp-agent command to disable all versions of SNMP running on the server.
Perform any command of snmp-agent will enable SNMP Agent.
Example
# Disable the running SNMP agents of all SNMP versions.
<H3C> system-view
Chapter 6 RMON Configuration Commands
6.1 RMON Configuration Commands
6.1.1 display rmon alarm
display rmon alarm [ alarm-table-entry ]
View
Parameter
alarm-table-entry: Alarm table entry index.
Use the display rmon alarm command to view RMON alarm information.
Related command: rmon alarm.
Example
# Display the RMON alarm information.
<H3C> display rmon alarm
Alarm table 1 owned by monitor is VALID.
Samples type : delta
Variable formula : 1.3.6.1.2.1.16.1.1.1.3.1<etherStatsDropEvents.1>
Description : Ethernet5/1/1
Sampling interval : 10(sec)
Rising threshold : 10(linked with event 1)
Falling threshold : 2(linked with event 1)
When startup enables : risingOrFallingAlarm
Latest value : 0
Table 6-1 Description on the fields of the display rmon alarm command
Alarm table 1 |
Index 1 in alarm table |
monitor |
Owner |
VALID |
The alarm entry corresponding to this index is valid. |
Samples type |
Type of sampling |
Variable formula |
Variable parameters |
Description information |
Sampling interval |
Time interval for sampling |
Rising threshold is 1000 |
The rising threshold is 1000. |
Falling threshold is 100 |
The falling threshold is 100. |
startup |
First triggering |
When startup enables : risingOrFallingAlarm |
Type of the first alarm. The startup may trigger rising threshold alarm, falling threshold alarm, or both. |
Latest value |
Last sample value |
6.1.2 display rmon event
display rmon event [ event-table-entry ]
View
Parameter
event-table-entry: Entry index of event table.
Use the display rmon event command to view RMON events.
The display includes event index in event table, owner of the event, description to the event, action caused by event (log or alarm information), and occurrence time of the latest event (counted on system initiate/boot time in centiseconds).
Related command: rmon event.
Example
# Show the RMON event.
<H3C> display rmon event
Event table 1 owned by null is VALID.
Description: null.
Will cause log-trap when triggered, last triggered at 0days 00h:02m:27s.
Table 6-2 Description on the fields of the display rmon event command
Event table 1 |
Index 1 in event table |
VALID |
The entry corresponding to the index is valid |
Event description |
Cause log-trap when triggered, |
When the event is triggered, it will cause the log-trap. |
Last triggered at 0days 00h:02m:27s |
The last triggered time is 00h:02m:27s |
6.1.3 display rmon eventlog
display rmon eventlog [ event-number ]
View
Parameter
event-number: Entry index of event table.
Use the display rmon eventlog command to view RMON event log.
The display includes event index in the event table, the status of the event, the time at which the event log is generated (this time starts from the system initialization or booting and counted in milliseconds), and event description.
Example
# Show event log of RMON.
<H3C> display rmon eventlog 1
Generates eventLog 1.1 at 0days 00h:01m:39s.
Description: The 1.3.6.1.2.1.16.1.1.1.4.1 defined in alarm table 1,
less than(or =) 100 with alarm value 0. Alarm sample type is absolute.
Generates eventLog 1.2 at 0days 00h:02m:27s.
Description: The alarm formula defined in private alarm table 1,
Table 6-3 Description on the fields of the display rmon eventlog command
Event table 1 |
VALID |
Event description |
less than(or =) 100 with alarm value 0 |
The alarm sample value is less than or equal to 100 |
Alarm sample type is absolute |
The type of alarm sampling is absolute |
Generates eventLog 1.2 at 0days 00h:02m:27s |
The eventlog corresponding to the index 1.2 is generated at 0days 00h:02m:27s. |
6.1.4 display rmon history
display rmon history [ port-num ]
View
Parameter
port-num: Ethernet port name.
Use the display rmon history command to view latest RMON history sampling information (including utility, error number and total packet number).
Related command: rmon history.
Example
# Show the RMON history information.
<H3C> display rmon history ethernet 2/1/1
History control entry 1 owned by null is VALID
Samples interface : Ethernet2/1/1<ifEntry.642>
Sampling interval : 10(sec) with 10 buckets max
Latest sampled values :
Dropevents :0 , octets :0
packets :0 , broadcast packets :0
multicast packets :0 , CRC alignment errors :0
undersize packets :0 , oversize packets :0
fragments :0 , jabbers :0
collisions :0 , utilization :0
Table 6-4 Description on the fields of the display rmon history command
Samples interface |
The sampled interface |
History control entry |
Index number in history control table |
VALID |
Sampling interval |
Sampling interval |
buckets |
Records in history control table |
Latest sampled values |
The latest sample information |
dropevents |
Dropping packet events |
octets |
Sent/Received octets in sampling time |
packets |
Packets sent/received in sampling time |
broadcast packets |
Number of broadcast packets |
multicast packets |
Number of multicast packets |
CRC alignment errors |
Number of CRC error packets |
undersized packets |
Number of undersized packets |
oversized packets |
Number of oversized packets |
fragments |
Number of undersized and CRC error packets |
jabbers |
Number of oversized and CRC error packets |
collisions |
Number of collision packets |
utilization |
Utilization |
6.1.5 display rmon prialarm
display rmon prialarm [ prialarm-table-entry ]
View
Parameter
prialarm-table-entry: Entry index of extended RMON alarm table.
Use the display rmon prialarm command to view information about extended RMON alarm table.
Related command: rmon prialarm.
Example
# Display the information about extended RMON alarm table.
<H3C> display rmon prialarm
Prialarm table 1 owned by monitor is UNDERCREATION.
Samples type : changeratio
Variable formula : (.1.3.6.1.2.1.2.2.1.10.201326601+.1.3.6.1.2.1.2.2.1.16
.201326601)*8*100/.1.3.6.1.2.1.2.2.1.5.201326601
Description : ifUtilization.Ethernet5/1/1
Rising threshold : 50(linked with event 1)
Falling threshold : 5(linked with event 1)
This entry will exist : forever.
Latest value : 0
Table 6-5 Description on the fields of the display rmon prialarm command
Prialarm table 1 |
Index of extended alarm entry. |
owned by monitor |
Creator of the extended alarm entry. |
UNDERCREATION |
Status of expansion alarms |
Samples type |
Type of sampling |
Variable formula |
Formula for expansion alarms |
Sampling interval : 10(sec) |
Sampling interval |
Rising threshold |
Rising threshold. When sampling value rises from normal value to this threshold, rising threshold alarm will be triggered. |
Falling threshold |
Falling threshold. When sampling value decreases from normal value to this threshold, falling threshold alarm will be triggered. |
linked with event 1 |
Corresponding event index of ring and falling threshold alarm. |
When startup enables: risingOrFallingAlarm |
Kind of first alarm. It may trigger rising threshold alarm or falling threshold alarm or both. |
This entry will exist forever |
The lifespan of this alarm entry which can be forever or a specified period of time. |
Latest value : 0 |
The value of the latest sampling. |
6.1.6 display rmon statistics
display rmon statistics [ port-num ]
View
Parameter
port-num: Ethernet port number.
Use the display rmon statistics command to view RMON statistics.
The displayed information includes collision, CRC (Cyclic Redundancy Check) and queue, undersized or oversized packet, timeout, fragment, broadcast, multicast, unicast, and bandwidth utility.
Related command: rmon statistics.
Example
# Show RMON statistics.
<H3C> display rmon statistics Ethernet 2/1/1
Statistics entry 1 owned by aaa is VALID.
Interface : Ethernet2/1/1<ifIndex.872418178>
etherStatsOctets : 756 , etherStatsPkts : 9
etherStatsBroadcastPkts : 9 , etherStatsMulticastPkts : 0
etherStatsUndersizePkts : 0 , etherStatsOversizePkts : 0
etherStatsFragments : 0 , etherStatsJabbers : 0
etherStatsCRCAlignErrors : 0 , etherStatsCollisions : 0
etherStatsDropEvents (insufficient resources): 0
Packets received according to length (etherStatsPktsXXXtoYYYOctets):
64 : 0 , 65-127 : 444 , 128-255 : 0
256-511: 0 , 512-1023: 0 , 1024-max : 0
6.1.7 rmon alarm
rmon alarm entry-number alarm-variable sampling-time { delta | absolute } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 [ owner text ]
undo rmon alarm entry-number
View
Parameter
entry-number: Number of the entry to be added/deleted, ranging from 1 to 65535.
alarm-variable: Specifies the alarm variable with a character string, ranging from 1 to 256, in the OID dotted format, like 1.3.6.1.2.1.2.1.10.1 (or ifInOctets.1).
sampling-time: Specifies the sampling interval, ranging from 5 to 65535 (measured in seconds).
delta: Sampling type is delta.
absolute: Sampling type is absolute.
rising-threshold threshold-value1: Rising threshold, ranging from 0 to 2147483647.
event-entry1: Event number corresponding to the upper limit of threshold, ranging from 0 to 65535.
falling-threshold threshold-value2: Falling threshold, ranging from 0 to 2147483647.
event-entry2: Event number corresponding to the falling threshold, ranging from 0 to 65535.
owner text: Specifies the creator of the alarm. Length of the character string ranges from 1 to 127.
Use the rmon alarm command to add an entry to the alarm table.
Use the undo rmon alarm command to cancel an entry from this table.
In this way, the alarm event can be triggered in the abnormal situations and then decides to log and send trap to the NM station.
& Note:
Before adding an alarm entry, you need first to define the event to be referenced in the alarm entry using the rmon event command.
The system takes these actions on the defined alarm entries:
l Sampling the defined alarm variables at a specified time interval.
l Comparing the sample values against the predefined threshold and take further actions (see Table 6-6).
Table 6-6 Handling alarm entries
Item |
Handling |
The sample value is greater than the upper limit threshold-value1. |
Triggers the defined event event-entry1 |
The sample value is less than the lower limit threshold-value2. |
Triggers the defined event event-entry2 |
Example
# Create alarm group
l Configure an event before configuring “alarm” and “prialarm”.
[H3C]rmon event 1 log owner test-rmon
l View configuration information.
[H3C]display rmon event 1
Event table 1 owned by test-rmon is VALID.
Description: null.
Will cause log when triggered, last triggered at 1days 01h:42m:09s.
l Configure alarm group.
# Add the first line in the alarm table. Sample the nodes 1.3.6.1.2.1.16.1.1.1.4.1 every 10 seconds. Trigger event 1 when the sampling value exceeds the upper threshold 50, and trigger event 2 when the sampling value gets below the lower threshold 5. The owner is user1.
<H3C> system-view
[H3C]rmon alarm 1 1.3.6.1.2.1.16.1.1.1.4.1 10 absolute rising_threshold 50 1 falling_threshold 5 2 owner user1
# Delete the information of entry 15 from the alarm table.
<H3C> system-view
[H3C] undo rmon alarm 15
6.1.8 rmon event
rmon event event-entry [ description string ] { log | trap trap-community | log-trap log-trapcommunity | none } [ owner text ]
undo rmon event event-entry
View
Parameter
event-entry: Number of the entry to be added/deleted, ranging from 1 to 65535.
description string: Event description. Length of the character string ranges from 1 to 127.
log-trap log-trapcommunity: Defines the event as log and trap event, and specifies the community name of the NMS which receives the messages triggered by the event.
log: Log event.
trap trap-community: Defines the event as trap event, and specifies the community name of the NMS which receives the messages triggered by the event.
none: Neither log nor trap event.
owner text: Creator for this entry. The length of the character string ranges from 1 to 127.
Use the rmon event command to add an entry to the event table.
Use the undo rmon event command to cancel an entry from this table.
RMON event management defines the event ID and the handling of the event.
You can handle the event in the following ways:
l Keeping logs
l Sending the trap messages to NMS
l Keeping logs and sending the trap messages to NMS
Example
# Add the entry 10 to the event table and marks it as log event.
<H3C> system-view
[H3C] rmon event 10 log
6.1.9 rmon history
rmon history entry-number buckets number interval sampling-interval [ owner text-string ]
undo rmon history entry-number
View
Ethernet port view
Parameter
entry-number: Number of the entry to be added/deleted, ranging from 1 to 65,535.
buckets number: Capacity of the history table corresponding to the control line.
interval sampling-interval: Sampling interval, ranging from 5 to 3600 (measured in seconds).
owner text-string: Creator of this entry. Length of the character string ranges from 1 to127.
Use the rmon history command to add an entry to the history control table.
Use the undo rmon history command to cancel an entry from history control table.
Perform this command to sample, set sample parameter (sample time interval) and storage amounts for a port. RMON will periodically perform data collection and save for query on this port. Sample information includes utility, error number and total packet number.
Related command: display rmon history.
Example
# Create a history control table entry with the index number of 15, capacity of 100 and sampling interval of 10 seconds. The owner is tester.
<H3C> system-view
[H3C]interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] rmon history 15 buckets 100 interval 10 owner tester
6.1.10 rmon prialarm
rmon prialarm entry-number prialarm-formula prialarm-des sampling-timer { delta | absolute | changeratio } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 entrytype { forever | cycle cycle-period } [ owner text ]
undo rmon prialarm entry-number
View
Parameter
entry-number: Specifies the entry number, ranging from 1 to 65535.
prialarm-formula: Variables in the formula must be represented by OID, for example, (1.3.6.1.2.1.2.1.10.1)*8. The operation results are in long integers. Every operation result must be within the range of the long integer; otherwise, errors may be prompted.
prialarm-des : Specifies the alarm description with a length ranging from 1 to 256;
sampling-timer: Sets the sampling interval, ranging from 10 to 65535 and measured in seconds.
delta | absolute | changeratio: Specifies the sampling type as delta ratio, absolute ratio or change ratio.
threshold-value1: Rising threshold value, specified with a number greater than 0.
event-entry1: Corresponding event number to the upper limit threshold value, ranging from 0 to 65535.
threshold-value2: Falling threshold value, specified with a number greater than 0.
forever | cycle cycle-period: Specifies the type of the alarm instance line.
cycle-period specifies the functional cycle of the instance.
owner text: Creator of this entry. Length of the character string ranges from 1 to 127.
Use the rmon prialarm command to add an entry to the extended RMON alarm table.
Use the undo rmon prialarm command to cancel an entry from the extended RMON alarm table.
The number of instances can be created in the table depends on the hardware resource of the product.
& Note:
Before adding an extended alarm entry, you need first to define the event to be referenced in the extended alarm entry using the rmon event command.
You can define up to 50 prialarm entries.
The system takes these actions on the extended alarm entries you defined:
l Sampling the alarm variables in the defined extended alarm formula at a specified time interval.
l Calculating the sample value using the defined extended alarm formula.
l Comparing the sample values against the predefined threshold and take further actions (see Table 6-7).
Table 6-7 Handling extended alarm entries
Item |
Handling |
The calculated sample value is greater than the upper limit threshold-value1. |
The calculated sample value is less than the lower limit threshold-value2. |
Example
# Add an extended alarm entry in the fifth line of the extended alarm table. Perform operation on the corresponding variant by means of the formular ((.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1-.1.3.6.1.4.1.43.45.1.6.1.2.1.1.3.1)*100/.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1) to get the port utilization of Gigabit Ethernet interface 1/1/1. Monitor the operation results at the sampling interval of 10 seconds. When the variation rate exceeds the upper threshold 50, trigger event 1; when the variation rate gets below the lower threshold 2, trigger event 2. Set the alarm instance sampling type to “forever”, and set the owner of the extended alarm table to “user1”.
<H3C> system-view
[H3C] rmon prialarm 5 ((.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1-.1.3.6.1.4.1.43.45.1.6.1.2.1.1.3.1)*100/.1.3.6.1.4.1.43.45.1.6.1.2.1.1.2.1) ifUtilization.GigabitEthernet1/1/1 10 changeratio rising_threshold 50 1 falling_threshold 5 2 entrytype forever owner user1
# Delete line 10 from the extended RMON alarm table.
<H3C> system-view
[H3C] undo rmon prialarm 10
6.1.11 rmon statistics
rmon statistics entry-number [ owner text-string ]
undo rmon statistics entry-number
View
Ethernet port view
Parameter
Use the rmon statistics command to add an entry to the statistic table.
Use the undo rmon statistics command to cancel an entry from statistic table.
RMON statistic management concerns the statistics and monitoring of the usage and error on a port. Statistics includes collision, undersized or oversized packet, timeout, fragment, broadcast, multicast, unicast, and bandwidth utility.
You can use the display rmon statistics command to view information about statistics table entry.
Example
# Add statistics of Ethernet2/1/1 to the entry 20.
<H3C> system-view
[H3C-Ethernet2/1/1] rmon statistic 20
Chapter 7 NTP Configuration Commands
7.1 NTP Configuration Commands
7.1.1 debugging ntp-service
debugging ntp-service { access | adjustment | authentication | event | filter | packet | parameter | refclock | selection | synchronization | validity | all }
undo debugging ntp-service { access | adjustment | authentication | event | filter | packet | parameter | refclock | selection | synchronization | validity | all }
View
Parameter
access: NTP access control debugging.
adjustment: NTP clock adjustment debugging.
all: All NTP debugging functions.
authentication: NTP authentication debugging.
event: NTP event debugging.
filter: NTP filter information debugging.
packet: NTP packet debugging.
parameter: NTP clock parameter debugging.
refclock: NTP reference clock debugging.
selection: NTP clock selection information debugging.
synchronization: NTP clock synchronization information debugging.
validity: NTP remote host validity debugging.
Use the debugging ntp-service command to debug different NTP services.
Use the undo debugging ntp-service command to disable corresponding debugging function.
By default, no debugging function is enabled.
Example
# Enable NTP access control debugging.
<H3C> debugging ntp-service access
7.1.2 display ntp-service sessions
display ntp-service sessions [ verbose ]
View
Parameter
verbose: Indicates to display the detail information about the SESSIONS.
Use the display ntp-service sessions command to display the status of all the SESSIONS maintained by NTP service provided by the local equipment.
By default, the status of all the SESSIONS maintained by NTP service provided by the local equipment will be displayed.
When you configure this command without the verbose parameter, the Ethernet switch will display the brief information about all the SESSIONS it maintains.
With the verbose parameter configured, Ethernet switch will display the detail information about all the SESSIONS it maintains.
Example
# Display status of all SESSIONS maintained by the local device NTP service.
<H3C> display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]127.127.1.0 LOCAL(0) 7 377 64 16 0.0 0.0 0.9
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
7.1.3 display ntp-service status
View
Parameter
None
Use the display ntp-service status command to display the NTP service status.
Example
# Display the NTP service status.
<H3C> display ntp-service status
clock status: unsynchronized
clock stratum: 16
reference clock ID: none
nominal frequency: 100.0000 Hz
actual frequency: 100.0000 Hz
clock precision: 2^17
clock offset: 0.0000 ms
root delay: 0.00 ms
root dispersion: 0.00 ms
peer dispersion: 0.00 ms
reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
The following table describes the outputs:
Table 7-1 Description on the fields of the display ntp-service status command
clock status: unsynchronized |
Local clock status: do not synchronize to any remote NTP server. |
clock stratum: 16 |
Indicates the NTP stratum of local clock. |
reference clock ID |
nominal frequency |
Nominal frequency of the local system hardware clock |
actual frequency |
Actual frequency of the local system hardware clock |
clock precision |
Precision of local system clock |
clock offset |
Offset of the local clock to the NTP server clock |
root delay |
Root delay from local equipment to the master reference clock. |
root dispersion |
Dispersion of the local clock relative to the NTP server clock |
peer dispersion |
Dispersion of the remote NTP server |
reference time |
Reference timestamp |
7.1.4 display ntp-service trace
View
Parameter
None
Use the display ntp-service trace command to display the brief information about every NTP server on the way from the local device to the reference clock source.
With this command, the system synchronizes the NTP server link from the local device along time till the reference clock source, and displays brief information about every NTP server.
Example
# Display brief information about every NTP server on the way from the local device to the reference clock source.
<H3C> display ntp-service trace
server 127.0.0.1,stratum 8, offset 0.000000, synch distance 0.00000
refid 127.127.1.0
7.1.5 ntp-service access
ntp-service access { query | synchronization | server | peer } acl-number
undo ntp-service access { query | synchronization | server | peer }
View
Parameter
query: Allows to control query authority.
synchronization: Only allows the server to access.
server: Allows query to server and access.
peer: Full access authority.
acl-number: IP address list number.
Use the ntp-service access command to set the authority to access the local equipment.
Use the undo ntp-service access command to cancel the access authority settings.
By default, there is no limit to the access.
Set authority to access the NTP services on a local Ethernet Switch. This is a basic and brief security measure, compared to authentication. An access request will be matched with peer, server, synchronization, and query in an ascending order of the limitation. The first matched authority will be given.
Example
# Give the authority of time request, query control and synchronization with the local equipment to the peer in ACL 2000.
<H3C> system-view
[H3C] ntp-service access peer 2000
# Give the authority of time request and query control of the local equipment to the peer in ACL 2000.
[H3C] ntp-service access synchronization 2000
7.1.6 ntp-service authentication enable
undo ntp-service authentication enable
View
Parameter
None
Use the ntp-service authentication enable command to enable the NTP-service authentication function.
Use the undo ntp-service authentication enable command to disable this function.
By default, the authentication is disabled.
Example
# Enable NTP authentication function.
<H3C> system-view
[H3C] ntp-service authentication enable
7.1.7 ntp-service authentication-keyid
ntp-service authentication-keyid number authentication-mode md5 value
undo ntp-service authentication-keyid number
View
Parameter
number: Key number, ranging from 1 to 4,294,967,295.
value: Value of the key with 1 to 32 ASCII characters.
Use the ntp-service authentication-keyid command to set NTP authentication key.
Use the undo ntp-service authentication-keyid command to cancel the NTP authentication key.
By default, there is no authentication key.
Only MD5 authentication is supported for the NTP authentication key settings.
Example
# Set MD5 authentication key 10 as test.
<H3C> system-view
[H3C] ntp-service authentication-keyid 10 authentication-mode md5 test
7.1.8 ntp-service broadcast-client
undo ntp-service broadcast-client
View
VLAN interface view
Parameter
None
Use the ntp-service broadcast-client command to configure NTP broadcast client mode.
Use the undo ntp-service broadcast-client command to disable the NTP broadcast client mode.
By default, the NTP broadcast client mode is disabled.
Designate an interface on the local Ethernet Switch to receive NTP broadcast messages and operate in broadcast client mode. The local Ethernet Switch listens to the broadcast from the server. When it receives the first broadcast packet, it starts a brief Client/Server mode to switch messages with a remote server for estimating the network delay. Thereafter, the local Ethernet Switch enters Broadcast Client mode and continues listening to the broadcast and synchronizes the local clock according to the arrived broadcast message.
Example
# Configure to receive NTP broadcast packets through Vlan-Interface1.
<H3C> system-view
[H3C] interface vlan-interface1
[H3C-Vlan-interface1] ntp-service broadcast-client
7.1.9 ntp-service broadcast-server
ntp-service broadcast-server [ authentication-keyid keyid version number ]
undo ntp-service broadcast-server
View
VLAN interface view
Parameter
authentication-keyid: Specifies the authentication key.
keyid: Key ID used in broadcast, ranging from 0 to 4294967295.
version: Defines NTP version number.
number: NTP version number, ranging from 1 to 3.
Use the ntp-service broadcast-server command to configure NTP broadcast server mode.
Use the undo ntp-service broadcast-server command to disable the NTP broadcast server mode.
By default, the broadcast service is disabled and number defaults to 3.
Designate an interface on the local equipment to broadcast NTP packets. The local equipment runs in broadcast-server mode and regularly broadcasts packets to its clients.
Example
# Configure to broadcast NTP packets through Vlan-Interface1, encrypt them with Key 4, and set the NTP version number as 3.
<H3C> system-view
[H3C-Vlan-interface1] ntp-service broadcast-server authentication-key 4 version 3
7.1.10 ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Parameter
number: The maximum SESSIONS can be created locally, ranging from 0 to 100.
Use the ntp-service max-dynamic-sessions command to set how many SESSIONS can be created locally.
Use the undo ntp-service max-dynamic-sessions command to resume the default maximum SESSIONS number
By default, a local device allows up to 100 SESSIONS.
Example
# Set the local equipment to allow up to 50 SESSIONS.
<H3C> system-view
[H3C] ntp-service max-dynamic-sessions 50
7.1.11 ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
VLAN interface view
Parameter
ip-address: Specifies an multicast IP address of Class D. By default, the ip-address is set to 224.0.1.1. Actually, for the S9500 series, you can set 224.0.1.1 as the multicast IP address only.
Use the ntp-service multicast-client command to configure the NTP multicast client mode.
Use the undo ntp-service multicast-client command to disable the NTP multicast client mode.
By default, the multicast client service is disabled. ip-address defaults to 224.0.1.1.
Designate an interface on the local Ethernet Switch to receive NTP multicast messages and operate in Multicast Client mode. The local Ethernet Switch listens to the multicast packets from the server. When it receives the first multicast packet, it starts a brief Client/Server mode to switch messages with a remote server for estimating the network delay. Thereafter, the local Ethernet Switch enters Multicast Client mode and continues listening to the multicast packets and synchronizes the local clock according to the arrived multicast packets.
Example
# Configure to receive NTP multicast packet through Vlan-Interface1 and the multicast group corresponding to these packets located at 224.0.1.1.
<H3C> system-view
[H3C] interface vlan-interface 1
[H3C-Vlan-interface1] ntp-service multicast-client 224.0.1.1
7.1.12 ntp-service multicast-server
ntp-service multicast-server [ ip-address ] [ authentication-keyid keyid ] [ ttl ttl-number ] [ version number ]*
undo ntp-service multicast-server [ ip-address ]
View
VLAN interface view
Parameter
ip-address: Specifies a multicast IP address of Class D and default to 224.0.1.1. Actually, for the S9500 series, you can set 224.0.1.1 as the multicast IP address only.
authentication-keyid: Specifies authentication key.
keyid: Key ID used in multicast, ranging from 1 to 4294967295.
ttl: Time to live of a multicast packet.
ttl-number: ttl of a multicast packet, ranging from 1 to 255.
version: NTP version number.
number: NTP version number and range from 1 to 3.
Use the ntp-service multicast-server command to configure NTP multicast server mode, if no IP address is specified, switch automatically choice the 224.0.1.1 as the multicast IP address.
Use the undo ntp-service multicast-server command to disable NTP multicast server mode, if no IP address is specified, the switch will disable the configuration of the multicast IP address 224.0.1.1.
By default, the multicast service is disabled. IP address defaults to 224.0.1.1 and the version number defaults to 3.
Designate an interface on the local equipment to transmit NTP multicast packet. The local equipment operates in multicast-server mode and multicasts packets regularly to its clients.
Example
# Configure to transmit NTP multicast packets encrypted with Key 4 through Vlan-Interface1 at 224.0.1.1 and use NTP version 3.
<H3C> system-view
[H3C-Vlan-interface1] ntp-service multicast-server 224.0.1.1 authentication-keyid 4 version 3
7.1.13 ntp-service refclock-master
undo ntp-service refclock-master [ ip-address ]
View
Parameter
ip-address: Specifies the reference clock IP address as 127.127.u, where u ranges from 0 to 3.
stratum: Specifies which stratum the local clock is located at and range from 1 to 15.
Use the ntp-service refclock-master command to configure an external reference clock or the local clock as an NTP master clock.
Use the undo ntp-service refclock-master command to cancel the NTP master clock settings.
By default, ip-address is 127.127.1.0 and stratum defaults to 8.
You can use this command to designate an NTP external reference clock or the local clock as an NTP master clock to provide synchronized time for other equipment. ip-address specifies the IP address of an external clock as 127.127.u. If no IP address is specified, the local clock is set as the NTP master clock by default. You can also specify the stratum of the NTP master clock.
Example
# Set the local clock as the NTP master clock to provide synchronized time for its peers and locate it at stratum 3.
<H3C> system-view
[H3C] ntp-service refclock-master 3
7.1.14 ntp-service reliable authentication-keyid
ntp-service reliable authentication-keyid number
undo ntp-service reliable authentication-keyid number
View
Parameter
number: Specifies the key number, ranging from 1 to 4294967295.
Use the ntp-service reliable authentication-keyid command to configure the key as reliable.
Use the undo ntp-service reliable authentication-keyid command to cancel the current setting.
By default, no key is configured as reliable.
When you enable the authentication, you can use this command to configure one or more than one keys as reliable. In this case, a Client will only get synchronized by a server whichever can provide a reliable key.
Example
# Enable NTP authentication, adopt MD5 encryption, and designate Key 37 BetterKey and configure it as reliable.
<H3C> system-view
[H3C] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
[H3C] ntp-service reliable authentication-keyid 37
7.1.15 ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Parameter
interface-type: Specifies the interface type and determine an interface with the interface-number parameter. The interface can be VLAN interface and Loopback interface currently.
interface-number: Specifies the interface number and determine an interface with the interface-type parameter.
Use the ntp-service source-interface command to designate an interface to transmit NTP message.
Use the undo ntp-service source-interface command to cancel the current setting.
By default, the source address specifies where the packets are transmitted from.
You can use this command to designate an interface to transmit all the NTP packets and take the source address of these packets from its IP address. If you do not want any other interface to receive the acknowledgement packets, use this command to specify one interface to send all the NTP packets.
Example
# Configure all the outgoing NTP packets to use the IP address of Vlan-Interface1 as their source IP address.
<H3C> system-view
[H3C] ntp-service source-interface Vlan-Interface 1
7.1.16 ntp-service unicast-peer
ntp-service unicast-peer ip-address [ version number ] [ authentication-key keyid ] [ source-interface interface-type interface-number ] [ priority ]*
undo ntp-service unicast-peer ip-address
View
Parameter
ip-address: Specifies the IP address of a remote server.
authentication-keyid: Defines authentication key.
keyid: Key ID used for transmitting messages to a remote server, ranging from 1 to 4294967295.
source-interface: Specifies the name of an interface, the interface can be VLAN interface and Loopback interface currently.
interface-type: Specifies the interface type and determine an interface together with the interface-number parameter.
interface-number: Specifies the interface number and determine an interface together with the interface-type parameter.
priority: Designates a server as the first choice.
Use the ntp-service unicast-peer command to configure NTP peer mode.
Use the undo ntp-service unicast-peer command to cancel NTP peer mode.
By default, version number number defaults to 3, the authentication is disabled, and the local server is not the first choice.
This command sets the remote server at ip-address as a peer of the local equipment, which operates in symmetric active mode. ip-address specifies a host address other than an IP address of broadcast, multicast, or reference clock. By operating in this mode, a local device can synchronize and be synchronized by a remote server.
Example
# Configure the local equipment to synchronize or synchronized by a peer at 128.108.22.44. Set the NTP version to 3. The IP address of the NTP packets are taken from that of Vlan-Interface1.
<H3C> system-view
[H3C] ntp-service unicast-peer 131.108.22.33 version 3 source-interface Vlan-Interface 1
7.1.17 ntp-service unicast-server
ntp-service unicast-server ip-address [ version number ] [ authentication-keyid keyid ] [ source-interface interface-type interface-number ] [ priority ]*
undo ntp-service unicast-server ip-address
View
Parameter
source-interface: Specifies the name of an interface, the interface can be VLAN interface and Loopback interface.
Use the ntp-service unicast-server command to configure NTP server mode.
Use the undo ntp-service unicast-server command to disable NTP server mode.
The command announces to use the remote server at ip-address as the local time server. ip-address specifies a host address other than an IP address of broadcast, multicast, or reference clock. By operating in client mode, a local device can be synchronized by a remote server, but not synchronize any remote server.
Example
# Designate the server at 128.108.22.44 to synchronize the local device and use NTP version 3.
<H3C> system-view
[H3C] ntp-service unicast-server 128.108.22.44 version 3
Chapter 8 SSH Terminal Service Configuration Commands
8.1 SSH Server Configuration Commands
8.1.1 debugging ssh server
debugging ssh server { VTY index | all }
undo debugging ssh server { VTY index | all }
View
Parameter
index: SSH channel to be debugged, whose value is dictated by VTY numbers. The default VTY numbers are 0 to 4.
all: All the SSH channels.
Use the debugging ssh server command to send information regulated by the SSH2.0 protocol, such as the negotiation procedure, to the information center in the format of Debugging information. You can also use it to debug a user interface individually.
Use the undo debugging ssh server command to disable the debugging.
By default, the debugging is disabled.
Related command: ssh server authentication-retries, ssh server rekey-interval, ssh server timeout.
Example
# Print the Debugging information when the SSH is running.
<H3C> debugging ssh server vty 0
00:23:20: SSH0: starting SSH control process
00:23:20: SSH0: sent protocol version id SSH-1.5-H3C-1.25
00:23:20: SSH0: protocol version id is - SSH-1.5-1.2.26
00:23:20: SSH0: SSH_SMSG_PUBLIC_KEY msg
00:23:21: SSH0: SSH_CMSG_SESSION_KEY msg - length 112, type 0x03
00:23:21: SSH: RSA decrypt started
00:23:21: SSH: RSA decrypt finished
8.1.2 display rsa local-key-pair public
View
Parameter
None
Use the display rsa local-key-pair public command to display the public key of the server’s host key pair and server key pair. If no key has been created, you will see a prompt like this: RSA keys not found.
Related command: rsa local-key-pair create.
Example
# Display the public key of the server’s host key pair and server key pair.
<H3C> display rsa local-key-pair public
% Key pair was generated at: 12:26:33 UTC 2002/4/4
Key name: rtvrp_Host
Usage: Encryption Key
Key Data:
30470240 AF7DB1D0 DA78944F 53B7B59B 40D425D0 DC9C57D2 A60916C2 1F165807 08B84DDB 5F4DB8E7 A115B74E 2D41D96C AC61D276 AA027E41 DD48DE64 696E0934 EB872805 02030100 01
% Key pair was generated at: 12:26:45 UTC 2002/4/4
Key name: rtvrp_Server
Key Data:
30670260 C05280D9 BA0D56C8 7BE43379 8634CDE7 83ABA9A2 3F36280E 25995487 4FF6AD7A 0E57871C 761E6D92 9914D8C5 CC577388 5B580B94 C2172C8F 36039EED 160A0478 651DED3A 9CCF1AAD D800AAF2 DF7FBEC4 A13ADA59 9E738319 AF366B8B 519D39F5 02030100 01
8.1.3 display rsa peer-public-key
display rsa peer-public-key [ brief | name keyname ]
View
Parameter
brief: Displays the brief information about all client public keys.
keyname: Specifies the public key name of the client to be displayed. The key name is a consecutive string whose length ranges from 1 to 64 characters.
Use the display rsa peer-public-key command to display the public key of RSA key pair specified by the client. If you do not specify the keyname argument, all public keys will be displayed.
Example
# Display the public key of the specified RSA key pair of the client.
<H3C> display rsa peer-public-key
Address Bits Name
1023 abcd
1024 hq
1024 wn1
1024 hq_all
# Display the public key of the specified RSA key pair named abcd of the client.
<H3C> display rsa peer-public-key name abcd
Key name:abcd
Key address:
Data:
30818602 8180739A 291ABDA7 04F5D93D C8FDF84C 42746319 91C164B0 DF178C55 FA833591 C7D47D53 81D09CE8 2913D7ED F9C08511 D83CA4ED 2B30B809 808EB0D1 F52D045D E40861B7 4A0E1355 23CCD74C AC61F8E5 8C452B2F 3F2DA0DC C48E3306 367FE187 BDD94401 8B3B69F3 CBB0A573 202C16BB 2FC1ACF3 EC8F828D 55A36F1C DDC4BB45 504F0201 25
8.1.4 display ssh server
display ssh server { status | session }
View
Parameter
status: Displays the SSH status information.
session: Displays the SSH session information.
Use the display ssh server command to display the status information or session information of an SSH server.
Example
# Display the status information of the SSH server.
<H3C> display ssh server status
SSH - version 2.0
SSH connection timeout: 60 seconds
SSH Authentication retries: 3 times
SFTP Server state: Disable
# Display the session information of the SSH server.
[H3C] display ssh server session
Connection Version Encryption State Username
VTY0 2.0 3DES Session started H3C
VTY3 1.5 DES Session started switch
8.1.5 display ssh user-information
View
Parameter
username: Valid SSH username.
Use the display ssh user-information command to display information about the current SSH user, including username, peer key name, authentication mode and the types of authorized services. If you specify the argument username in the command, the user information about the specified username will be displayed.
Related command: ssh user username assign rsa-key, ssh user username authentication-type, ssh user username service-type, display local-user, display rsa peer-public-key.
Example
# Display the current SSH user information.
<H3C> display ssh user-information
Username Authentication-type User-public-key-name Service-type
sshuser2 rsa sshuser2 stelnet
sshuser1 password sshuser1 stelnet
If the Username and User-key-name are too long, the result of the dispaly ssh user-information is displayed with wildcard ” ...”. An example is given below:
# Display current SSH user information.
admin password aaaaaaaaaabbbbbbb... sftp
aaaaaaaaaabbbbbb... all aaaaaaaaaabbbbbbb... stelnet
fxdfxdfxdfxdfxdf... null null stelnet|sftp
You can use the display local-user command and the display rsa peer-public-key command respectively to view Username and User-public-key-name which are too long.
8.1.6 peer-public-key end
peer-public-key end
View
Public key view
Parameter
None
Use the peer-public-key end command to exit from the public key view and return to the system view.
Related command: rsa peer-public-key, public-key-code begin.
Example
# Exit the public key view and save the configuration.
<H3C> system-view
[H3C] rsa peer-public-key H3C003
RSA public key view: return to System View with "peer-public-key end".
[H3C-rsa-public-key] peer-public-key end
[H3C]
8.1.7 protocol inbound
protocol inbound { all | pad | ssh | telnet }
View
VTY user interface view
Parameter
all: Supports all protocols, including Telnet and SSH.
ssh: Supports the SSH protocol only, and does not support the Telnet protocol.
telnet: Supports the Telnet protocol only, and does not support the SSH protocol.
Use the protocol inbound command to specify the protocol supported by the current user interface.
By default, all protocols are supported.
This configuration takes effect at the next login. Note that after enabling SSH by this command, you still cannot log in through SSH if the client RSA key is not configured.
Caution:
l If the supported protocol configured in the user interface is SSH, make sure to configure the corresponding authentication mode to authentication-mode scheme (using AAA authentication mode).
l If the authentication mode is configured as authentication-mode password or authentication-mode none, the configuration of protocol inbound ssh will fail; contrarily, if a user interface is configured to support the SSH protocol, you will fail to configure authentication-mode password and authentication-mode none.
Related command: user-interface vty.
Example
# Set VTY 0 to 4 to support the SSH protocol only.
<H3C> system-view
[H3C] user-interface vty 0 4
[H3C-ui-vty0-4] protocol inbound ssh
# Disable the Telnet function of VTY 0 and make it support SSH only.
<H3C> system-view
[H3C-ui-vty0] protocol inbound ssh
8.1.8 public-key-code begin
View
Public key view
Parameter
None
Use the public-key-code begin command to enter the public key edit view and input the public key of the client. Note that you must use the rsa peer-public-key command to specify a client key name before performing this command.
When inputting the public key, you may type spaces between the characters (the system will delete the spaces automatically), or press <Enter> and then continue to input the key. Note that the public key must be a hexadecimal string coded in the public key format and is randomly generated by the SSH 2.0-enabled client software or the client switch.
Related command: rsa peer-public-key, public-key-code end.
Example
# Enter the public key edit view and input the key.
<H3C> system-view
[H3C-rsa-public-key] public-key-code begin
RSA key code view: return to last view with "public-key-code end".
[H3C-key-code] 308186028180739A291ABDA704F5D93DC8FDF84C427463
[H3C-key-code] 1991C164B0DF178C55FA833591C7D47D5381D09CE82913
[H3C-key-code] D7EDF9C08511D83CA4ED2B30B809808EB0D1F52D045DE4
[H3C-key-code] 0861B74A0E135523CCD74CAC61F8E58C452B2F3F2DA0DC
[H3C-key-code] C48E3306367FE187BDD944018B3B69F3CBB0A573202C16
[H3C-key-code] BB2FC1ACF3EC8F828D55A36F1CDDC4BB45504F020125
[H3C-key-code] public-key-code end
8.1.9 public-key-code end
public-key-code end
View
Public key edit view
Parameter
None
Use the public-key-code end command to return from the public key edit view to the public key view and save the public key entered.
After this command is performed to end the public key edit procedure, the system will check the validity of the key before saving the input public key. If the public key string contains any illegal character, the system will prompt the failure of the configuration and the configured key will be discarded; otherwise, the key is valid and will be saved to the user public key list.
Example
# Exit the public key edit view and save the configured public key.
<H3C> system-view
[H3C-rsa-key-code] public-key-code end
8.1.10 rsa local-key-pair create
View
Parameter
None
Use the rsa local-key-pair create command to generate the RSA key pair (including the host key and server key) of the server. The naming conventions for the keys are switch name + host and switch name + server respectively, for example, H3C_host, H3C_server.
When configuring by this command, if the RSA key pair already exists, you will get a warning asking if you want to replace the existing one. Note that the host key and the server key must have a difference of 128 bits at least, and that the minimum and maximum lengths for the host key and the server key are 512 bits and 2048 bits .
Generating the RSA key pair of the server is the first step to perform after SSH login. It needs to be performed only once; you need not re-perform it after rebooting the switch.
Caution:
When you log in through SSH user, the key generated by the server must be longer than or equal to 768 bits. The RSA key genetated by the server is 512 bits by default.
Related command: rsa local-key-pair destroy.
Example
# Generate the local RSA key pair.
<H3C> system-view
[H3C] rsa local-key-pair create
The name for the keys will be: rtvrp_Host
% You already have RSA keys defined for rtvrp_Host
% Do you really want to replace them? [yes/no]:y
Choose the size of the key modulus in the range of 512 to 2048 for your Keys.
Choosing a key modulus greater than 512 may take a few minutes.
How many bits in the modulus [512]:512
Generating keys...
8.1.11 rsa local-key-pair destroy
View
Parameter
None
Use the rsa local-key-pair destroy command to destroy all the RSA key pairs of the server, including the host keys and server keys.
Example
# Destroy all the RSA keys of the server.
<H3C> system-view
[H3C] rsa local-key-pair destroy
% Keys to be removed are named rtvrp_Host .
% Do you really want to remove these keys? [yes/no]:y
8.1.12 rsa peer-public-key
rsa peer-public-key key-name
View
Parameter
key-name: Name of the public key of the client. It is a consecutive string whose length ranges from 1 to 64 characters.
Use the rsa peer-public-key command to enter the public key view.
Performing this command, you can enter the public key view. Then you can use the public-key-code begin command to configure the client public key on the server. The client public key is generated randomly by the SSH 2.0-enabled client software.
Related command: public-key-code begin, public-key-code end.
Example
# Enter the public key view named H3C002.
<H3C> system-view
[H3C] rsa peer-public-key H3C002
8.1.13 ssh server authentication-retries
ssh server authentication-retries times
undo ssh server authentication-retries
View
Parameter
times: Number of authentication retries, in the range from 1 to 5. By default, the value is 3.
Use the ssh server authentication-retries command to set the number of SSH connection authentication retries.
Use the ssh server authentication-retries command to restore the default number of SSH connection authentication retries.
Related command: display ssh server.
Example
# Specify the number of login authentication retries to 4.
<H3C> system-view
[H3C] ssh server authentication-retries 4
8.1.14 ssh server compatible_ssh1x enable
undo ssh server compatible_ssh1x
View
Parameter
None
Use the ssh server compatible_ssh1x enable command to make the server compatible with the SSH 1.x client.
Use the undo ssh server compatible_ssh1x command to make the server not compatible with an SSH 1.x client.
By default, the server is compatible with the SSH 1.x client.
Example
# Set the server to be compatible with the SSH 1.x client.
<H3C> system-view
[H3C] ssh server compatible_ssh1x enable
8.1.15 ssh server rekey-interval
ssh server rekey-interval hours
undo ssh server rekey-interval
View
Parameter
hours: Update interval of the server key, in range of 1 to 24 (hours). It cannot be 0.
Use the ssh server rekey-interval command to set update interval of the server key.
Use the undo ssh server rekey-interval command to remove the configuration.
By default, the system does not update the server key.
Example
# Set to update the server key every three hours.
<H3C> system-view
[H3C] ssh server rekey-interval 3
8.1.16 ssh server timeout
ssh server timeout seconds
undo ssh server timeout
View
Parameter
seconds: Specifies the login timeout (in seconds), in the range from 1 to 120. By default, the value is 60.
Use the ssh server timeout command to set the authentication timeout of SSH connections.
Use the undo ssh server timeout command to restore the default SSH authentication timeout.
The configuration takes effect at the next login.
Example
# Set the login timeout to 80 seconds.
<H3C> system-view
[H3C] ssh server timeout 80
8.1.17 ssh user assign rsa-key
ssh user username assign rsa-key keyname
undo ssh user username assign rsa-key
View
Parameter
keyname: Name of the client public key. It is a consecutive string whose length ranges from 1 to 64 characters.
username: Valid SSH username. It is a consecutive string whose length ranges from 1 to 80 characters.
Use the ssh user assign rsa-key command to assign an existing public key for the specified SSH user.
Use the undo ssh user assign rsa-key command to cancel the corresponding relationship between the user and the public key.
The new public key takes effect at the next login.
If a public key already exists before this command is performed, the newly configured key takes effect.
Related command: display ssh user-information.
Example
# Assign public key1 for user zhangsan.
<H3C> system-view
[H3C] ssh user zhangsan assign rsa-key key1
8.1.18 ssh user authentication-type
ssh user username authentication-type { password | rsa | password-publickey | all }
undo ssh user username authentication-type
View
Parameter
password: Forces the user’s authentication mode to password authentication.
rsa: Forces the user’s authentication mode to RSA public key authentication.
password-publickey: Forces the user’s authentication mode to password authentication plus RSA public key authentication.
all: Specifies that the user’s authentication mode can be either password authentication or public authentication.
Use the ssh user authentication-type command to specify an authentication mode for a user.
Use the undo ssh user authentication-type command to restore the default unable-to-login mode.
The new authentication mode takes effect at the next login.
By default, no login authentication mode is specified, that is, SSH users are unable to login.
For a new user, you must specify an authentication mode; otherwise, the new user will not be able to log in.
Example
# Specify the authentication mode of user zhangsan to password authentication.
<H3C> system-view
[H3C] ssh user zhangsan authentication-type password
8.2 SSH Client Configuration Commands
8.2.1 display ssh server-info
View
Parameter
None
Use the display ssh server-info command to view the corresponding relationship between the client’s servers and public keys.
Example
# Display the corresponding relationship between the client’s servers and public keys.
<H3C> display ssh server-info
Server Name(IP) Server public key name
192.168.0.1 test_key01
192.168.0.2 test_key02
8.2.2 quit
View
Parameter
None
Use the quit command to terminate the connection with the remote SSH server.
Example
# Terminate the connection with the remote SSH server.
<H3C> quit
8.2.3 ssh client assign rsa-key
ssh client server-ip assign rsa-key keyname
undo ssh client server-ip assign rsa-key
View
Parameter
server-ip: IP address of the server.
keyname: Public key name of the client.
Use the ssh client assign rsa-key command to specify the IP address and the corresponding public key name of the server on the client.
Use the undo ssh client assign rsa-key command to cancel the configuration.
Example
# Specify the public key of a server with IP address 192.168.0.1 on the client to serverkey01.
<H3C> system-view
[H3C] ssh client 192.168.0.1 assign rsa-key serverkey01
8.2.4 ssh client first-time enable
undo client ssh first-time
View
Parameter
None
Use the ssh client first-time enable command to set the SSH client to perform the first-time authentication of the SSH server to be accessed.
Use the undo ssh client first-time command to cancel the first-time authentication.
The first-time authentication means that when the SSH client accesses the server for the first time in the case that there is no local copy of the server’s public key, the user can proceed to access the server and save a local copy of the server’s public key; when the client accesses the server next time, it uses the saved public key to authenticate the server.
If the first-time authentication is not supported, when there is no local copy of the public key of the connected server, the client assumes that the server is illegal and will refuse to access the server. The user can save a copy of the server’s public key locally by other means beforehand.
By default, the client does not perform the first-time authentication.
Example
# Set the SSH client to perform the first-time authentication of the SSH server to be accessed.
<H3C> system-view
[H3C] ssh client first-time enable
8.2.5 ssh2
ssh2 { host-ip | host-name } [ port-num ] [ prefer_kex { dh_group1 | dh_exchange_group } ] [ prefer_ctos_cipher { des | 3des | aes128 } ] [ prefer_stoc_cipher { des | 3des | aes128 } ] [ prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } ] [ prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ]
View
Parameter
host-ip: IP address of the server.
host-name: Server name, a string with 1 to 20 characters.
port-num: Server port number, ranges from 0 to 65535, and defaults to 22.
prefer_kex: Preferred key exchange algorithm, which can be one of the two algorithms.
dh_group1: Key exchange algorithm diffie-hellman-group1-sha1, which is the default algorithm.
dh_exchange_group: Key exchange algorithm diffie-hellman-group-exchange-sha1.
prefer_ctos_cipher: Preferred encryption algorithm from the client to the server. The default algorithm is aes128.
prefer_stoc_cipher: Preferred encryption algorithm from the server to the client. The default algorithm is aes128.
des: Encryption algorithm des_cbc.
3des: Encryption algorithm 3des_cbc.
aes128: Encryption algorithm aes_128.
prefer_ctos_hmac: Preferred HMAC algorithm from the client to the server. The default algorithm is sha1_96.
prefer_stoc_hmac: Preferred HMAC algorithm from the server to the client. The default algorithm is sha1_96.
sha1: HMAC algorithm hmac-sha1.
sha1_96: HMAC algorithm hmac-sha1-96.
md5: HMAC algorithm hmac-md5.
md5_96: HMAC algorithm hmac-md5-96.
Use the ssh2 command to enable the connection between the SSH client and the server, and specify the preferred key exchange algorithm, encryption algorithm and HMAC algorithm of the client and the server.
Example
# Log in to remote SSH2 server with IP address 10.214.50.51, and configure encryption algorithms as follows:
l Preferred key exchange algorithm: dh_exchange_group
l Preferred encryption algorithm from the client to the server: 3DES-CBC
l Preferred HMAC algorithm from the client to the server: HMAC-MD5
l Preferred encryption algorithm from the server to the client: AES-128
l Preferred HMAC algorithm from the server to the client: HMAC-SHA1-96
The command is as follows:
<H3C> system-view
[H3C] ssh2 10.214.50.51 prefer_kex dh_exchange_group prefer_ctos_cipher 3des prefer_ctos_hmac md5
8.3 SFTP Server Configuration Commands
8.3.1 sftp server enable
sftp server enable
undo sftp server
View
Parameter
None
Use the sftp server enable command to start the SFTP server.
Use the undo sftp server enable command to shutdown the SFTP server.
By default, the SFTP server is shutdown.
Example
# Start the SFTP server.
<H3C> system-view
[H3C] sftp-server enable
# Shutdown the SFTP server.
[H3C] undo sftp-server enable
8.3.2 ssh user service-type
ssh user username service-type { stelnet | sftp | all }
undo ssh user username service-type
View
Parameter
username: Local username or username defined by the remote RADIUS server.
stelnet: Specifies the service type as stelnet.
sftp: Specifies the service type as SFTP.
all: Includes both Telnet and SFTP service types.
Use the ssh user service-type command to specify the service type for a particular user.
Use the undo ssh user service-type command to restore the default service type.
By default, the service type is stelnet.
Example
# Specify the service type to be SFTP for user zhangsan.
<H3C> system-view
[H3C] ssh user zhangsan service-type sftp
8.4 SFTP Client Configuration Commands
8.4.1 bye
bye
View
SFTP Client view
Parameter
None
Use the bye command to terminate the connection with the remote SFTP server and return to the user view.
This command has the same functionality as the exit and quit commands.
Example
# Terminate the connection with the remote SFTP server.
<H3C> system-view
sftp-client> bye
<H3C>
8.4.2 cd
cd [remote-path ]
View
SFTP Client view
Parameter
remote-path: Name of a path on the server.
Use the cd command to change the current path on the SFTP server. If you do not specify the remote-path argument, the current path will be displayed.
Example
# Change the current path to d:/temp.
sftp-client> cd d:/temp
8.4.3 cdup
cdup
View
SFTP Client view
Parameter
None
Use the cdup command to change the current path to its upper directory.
Example
# Change the current path to its upper directory.
sftp-client> cdup
8.4.4 delete
delete remote-file
View
SFTP Client view
Parameter
remote-file: Name of a file on the server.
Use the delete command to delete the specified file from the server.
This command has the same functionality as the remove command.
Example
# Delete file temp.c from the server.
sftp-client> delete temp.c
8.4.5 dir
dir [ remote-path ]
View
SFTP Client view
Parameter
remote-path: Name of the directory to view.
Use the dir command to view the files in the specified directory.
If the remote-path argument is not specified, the files in the current directory will be displayed.
This command has the same functionality as the ls command.
Example
# View directory flash:/
sftp-client> dir flash:/
-rwxrwxrwx 1 noone nogroup 1759 Aug 23 06:52 config.cfg
-rwxrwxrwx 1 noone nogroup 225 Aug 24 08:01 pubkey2
-rwxrwxrwx 1 noone nogroup 283 Aug 24 07:39 pubkey1
-rwxrwxrwx 1 noone nogroup 225 Sep 28 08:28 pub1
drwxrwxrwx 1 noone nogroup 0 Sep 28 08:24 new1
drwxrwxrwx 1 noone nogroup 0 Sep 28 08:18 new2
-rwxrwxrwx 1 noone nogroup 225 Sep 28 08:30 pub2
8.4.6 exit
exit
View
SFTP Client view
Parameter
None
Use the exit command to terminate the connection with the remote SFTP server and return to the user view.
This command has the same functionality as the bye and quit commands.
Example
sftp-client> exit
<H3C>
8.4.7 get
View
SFTP Client view
Parameter
remote-file: Name of a file on the remote SFTP server.
local-file: Name of a local file.
Use the get command to download a file from the remote server and save it locally.
By default, if no local file name is specified, it is assumed that the local file has the same name as the file on the SFTP server.
Example
# Download file temp1.c and save it with name temp.c.
sftp-client> get temp1.c temp.c
8.4.8 help
help [ command ]
View
SFTP Client view
Parameter
command: Name of a command.
Use the help command to view the help information for SFTP client commands.
If the command argument is not specified, all command names will be displayed.
Example
# View the help information for the get command.
sftp-client> help get
get remote-path [local-path] Download file
Default local-path is the same with remote-path
8.4.9 ls
ls [ remote-path ]
View
SFTP Client view
Parameter
Use the ls command to view the files in the specified directory.
This command has the same functionality as the dir command.
Example
# View directory flash:/.
sftp-client> ls flash:/
8.4.10 mkdir
mkdir remote-path
View
SFTP Client view
Parameter
remote-path: Name of a directory on the remote SFTP server.
Use the mkdir command to create a directory on the remote SFTP server.
Example
# Create directory test on the remote SFTP server.
sftp-client> mkdir test
8.4.11 put
View
SFTP Client view
Parameter
Use the put command to upload a local file to the remote SFTP server.
By default, if no name of the file on the remote server is specified, it is assumed that the file on the remote server has the same name as the local file.
Example
# Upload local file temp.c to the remote SFTP server and save it with the name temp1.c.
sftp-client> put temp.c temp1.c
8.4.12 pwd
pwd
View
SFTP Client view
Parameter
None
Use the pwd command to display the current directory on the SFTP server.
Example
# Display the current directory on the SFTP server.
sftp-client> pwd
flash:
8.4.13 quit
View
SFTP Client view
Parameter
None
Use the quit command to terminate the connection with the remote SFTP server and return to the user view.
This command has the same functionality as the bye and exit commands.
Example
sftp-client> quit
<H3C>
8.4.14 remove
remove remote-file
View
SFTP Client view
Parameter
Use the remove command to delete the specified file from the server.
This command has the same functionality as the delete command.
Example
# Delete the file temp.c from the server.
8.4.15 rename
rename oldname newname
View
SFTP Client view
Parameter
oldname: Original file name.
newname: New file name.
Use the rename command to change the name of the specified file on the SFTP server.
Example
# Change the name of the file temp1 on the SFTP server to temp2.
sftp-client> rename temp1 temp2
8.4.16 rmdir
rmdir remote-path
View
SFTP Client view
Parameter
Use the rmdir command to delete the specified directory from the SFTP server.
Example
# Delete the directory D:/temp1 from the SFTP server.
sftp-client> rmdir D:/temp1
8.4.17 sftp
sftp ipaddr [ prefer_kex { dh_group1 | dh_exchange_group } ] [ prefer_ctos_cipher { des | 3des | aes128 } ] [ prefer_stoc_cipher { des | 3des | aes128 } ] [ prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } ] [ prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ]
View
Parameter
ipaddr: IP address of the server.
prefer_key: Preferred key exchange algorithm, which can be either diffie-hellman-group1-sha1 or diffie-hellman-group-exchange-sha1.
dh_group1: Key exchange algorithm diffie-hellman-group1-sha1, which is default algorithm.
Use the sftp command to establish the connection with the remote SFTP server and enter the SFTP Client view.
Example
# Connect to the SFTP server with IP address 10.214.49.126 using the default encryption algorithm.
<H3C> system-view
[H3C] sftp 10.214.49.126
