- H3C S3610[5510] Series Ethernet Switches Operation Manual-Release 0001-(V1.02)
- 00-1Cover
- 00-2Product Overview
- 01-Login Operation
- 02-VLAN Operation
- 03-IP Address and Performance Operation
- 04-QinQ-BPDU Tunnel Operation
- 05-Port Correlation Configuration Operation
- 06-MAC Address Table Management Operation
- 07-MAC-IP-Port Binding Operation
- 08-MSTP Operation
- 09-Routing Overview Operation
- 10-IPv4 Routing Operation
- 11-IPv6 Routing Operation
- 12-IPv6 Configuration Operation
- 13-Multicast Protocol Operation
- 14-802.1x-HABP-MAC Authentication Operation
- 15-AAA-RADIUS-HWTACACS Operation
- 16-ARP Operation
- 17-DHCP Operation
- 18-ACL Operation
- 19-QoS Operation
- 20-Port Mirroring Operation
- 21-Cluster Management Operation
- 22-UDP Helper Operation
- 23-SNMP-RMON Operation
- 24-NTP Operation
- 25-DNS Operation
- 26-File System Management Operation
- 27-Information Center Operation
- 28-System Maintenance and Debugging Operation
- 29-NQA Operation
- 30-VRRP Operation
- 31-SSH Operation
- 32-Appendix
09-Routing Overview Operation | 70 KB |
Table of Contents
1.1.2 Routing Through a Routing Table
1.2.1 Static Routing and Dynamic Routing
1.2.2 Classification of Dynamic Routing Protocols
1.2.3 Routing Protocols and Routing Priority
1.2.4 Load Balancing and Route Backup
1.2.5 Sharing of Routing Information
1.3 Displaying and Maintaining a Routing Table
Chapter 1 Routing Overview
& Note:
l The term “router” in this document refers to a router in a generic sense or a Layer 3 switch running a routing protocol.
l Verify that the system already operates in IPv4/IPv6 dual-stack mode before configuring IPv6 routing. For dual-stack mode configuration, see the part covering dual-stack in the IPv6 Configuration module.
1.1 Routing and Routing Table
1.1.1 Routing
Routing in the Internet is achieved through routers. Upon receiving a packet, a router identifies an optimal route based on the destination address and forwards the packet to the next router in the path until the packet reaches the last router, which forwards the packet to the intended destination host.
I. Routing table
Routing table plays a key role in allowing routers to forward packets. Each router maintains a routing table, and each entry in the table specifies which physical interface a packet destined for a certain destination should go out to reach the next hop (the next router) or the directly connected destination.
Routes in a routing table can be divided into three categories by origin:
l Direct routes: Routes discovered by data link protocols, also known as interface routes.
l Static routes: Routes that are manually configured.
l Dynamic routes: Routes that are discovered dynamically by routing protocols.
II. Contents of a routing table
A routing table includes the following key items:
l Destination address: Indicates the destination address or destination network of an IP packet.
l Network mask: Specifies, in company with the destination address, the address of the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 129.102.8.10 and the mask 255.255.0.0, the address of the destination network is 129.102.0.0. A network mask is made of a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
l Outbound interface: Specifies the interface through which the IP packets are to be forwarded.
l IP address of the next hop: Specifies the address of the next router on the route.
l Priority for the route. Multiple routes may exist to the same destination, each of which has a different next hop and may be generated by various routing protocols or be manually configured. The optimal route is the one with the highest priority (with the smallest metric).
Routes can be divided into two categories by destination:
l Subnet routes: The destination is a subnet.
l Host routes: The destination is a host.
Based on whether the destination is directly connected to a given router, routes can be divided into:
l Direct routes: The destination is directly connected to the router.
l Indirect routes: The destination is not directly connected to the router.
To prevent the routing table from getting too large, you can configure a default route. All packets with no matching entry in the routing table will be forwarded through the default route.
In Figure 1-1, the IP address on each cloud represents the address of the network. Router R8 resides in three networks and therefore has three IP addresses for its three physical interfaces. Its routing table is shown on the right of the network topology.
Figure 1-1 A sample routing table
1.2 Routing Protocol Overview
Static routing is easy to configure and requires less system resources. It works well in small, stable networks with simple topologies. Its major drawback is that you must perform routing configuration again whenever the network topology changes; it cannot adjust to network changes by itself.
Dynamic routing, on the other hand, is based on dynamic routing protocols, which can detect network topology changes and recalculate the routes accordingly. Therefore, dynamic routing is suitable for large networks. Its disadvantages are that it is complicated to configure, and that it not only imposes higher requirements on the system, but also eats away a certain amount of network resources.
Dynamic routing protocols can be classified based on the following standards:
I. Operational scope
l Interior gateway protocols (IGPs): Work within an autonomous system, typically includes RIP, OSPF, and IS-IS.
l Exterior gateway protocols (EGPs): Work between autonomous systems. The most popular one is BGP.
& Note:
An autonomous system refers to a group of routers that share the same routing policy and work under the same administration.
II. Routing algorithm
l Distance-vector protocols: Includes mainly RIP and BGP. BGP is also considered a path-vector protocol.
l Link-state protocols: Includes mainly OSPF and IS-IS.
The main differences between the above two types of routing algorithms lie in the way routes are discovered and calculated.
III. Type of the destination address
l Unicast routing protocols: Includes RIP, OSPF, BGP, and IS-IS.
l Multicast routing protocols: Includes PIM-SM and PIM-DM.
This chapter focuses on unicast routing protocols. For information on multicast routing protocols, refer to Multicast Operation.
IV. Version of IP protocol
IPv4 routing protocols: RIP, OSPF, BGP and IS-IS.
IPv6 routing protocols: RIPng, OSPFv3, BGP4+, IPv6 IS-IS.
The following table lists some routing protocols and the default priorities for routes found by them:
Routing approach |
Priority |
DIRECT |
0 |
OSPF |
10 |
IS-IS |
15 |
STATIC |
60 |
RIP |
100 |
OSPF ASE |
150 |
OSPF NSSA |
150 |
IBGP |
255 |
EBGP |
255 |
UNKNOWN |
256 |
IPv4 and IPv6 routes have their own respective routing tables.
I. Load Balancing
In multi-route mode, a routing protocol can be configured with multiple equal-cost routes to the same destination. These routes have the same priority and will all be used to accomplish load balancing if there is no route with a higher priority available.
A given routing protocol may find several routes with the same metric to the same destination, and if this protocol has the highest priority among all the active protocols, these routes will be considered valid routes for load balancing.
II. Route backup
Route backup can help improve network reliability. With route backup, you can configure multiple routes to the same destination, expecting the one with the highest priority to be the main route and all the rest backup routes.
Under normal circumstances, packets are forwarded through the main route. When the main route goes down, the route with the highest priority among the backup routes is selected to forward packets. When the main route recovers, the route selection process is performed again and the main route is selected again to forward packets.
As different routing protocols use different algorithms to calculate routes, they may find different routes. In a large network with multiple routing protocols, it is required for routing protocols to share their routing information. Each routing protocol has its own route redistribution mechanism.
To do… |
Use the command… |
Remarks |
Display summary information about the active routes in the routing table |
display ip routing-table [ verbose | | { begin | exclude | include } regular-expression ] |
Available in any view |
Display information about routes to the specified destination |
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ] |
Display information about routes with destination addresses in the specified range |
display ip routing-table ip-address1 { mask-length1 | mask1 } ip-address2 { mask-length2 | mask2 } [ verbose ] |
Display information about routes permitted by a specified basic ACL |
display ip routing-table acl acl-number [ verbose ] |
Display information about routes selected by a specified prefix list |
display ip routing-table ip-prefix ip-prefix-name [ verbose ] |
Display protocol specific routes |
display ip routing-table protocol protocol [ inactive | verbose ] |
Display statistics about the routing table |
display ip routing-table statistics |
Clear statistics for the routing table |
reset ip routing-table statistics protocol { all | protocol } |
Available in user view |
Display brief IPv6 routing table information |
display ipv6 routing-table |
Display verbose IPv6 routing table information |
display ipv6 routing-table verbose |
Display routing information for a specified destination IPv6 address |
display ipv6 routing-table ipv6-address prefix-length [ longer-match ] [ verbose ] |
Display routing information permitted by an IPv6 ACL |
display ipv6 routing-table acl acl6-number [ verbose ] |
Display routing information permitted by an IPv6 prefix list |
display ipv6 routing-table ipv6-prefix ipv6-prefix-name [ verbose ] |
Display IPv6 routing information of a routing protocol |
display ipv6 routing-table protocol protocol [ inactive | verbose ] |
Display IPv6 routing statistics |
display ipv6 routing-table statistics |
Display IPv6 routing information for an IPv6 address range |
display ipv6 routing-table ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ] |
Clear specified IPv6 routing table statistics |
reset ipv6 routing-table statistics protocol { all | protocol } |
