H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
29-UDP Helper Operation
29-UDP Helper Operation 56 KB
Chapter 1  UDP Helper Configuration
When configuring UDP Helper, go to these sections for information you are interested in:
l           Introduction to UDP Helper
l           Configuring UDP Helper
l           Displaying and Maintaining UDP Helper
l           UDP Helper Configuration Example
&  Note:
l      By default, S5500-SI series Ethernet switches do not forward IP broadcast packets. So, to utilize the UDP Helper function, you need to execute the ip forward-broadcast command in system view first. For details, refer to the IP Address and Performance part of the manual.
l      Currently, interface-related configurations concerning the UDP Helper function can only be performed on VLAN interfaces.
1.1  Introduction to UDP Helper
UDP Helper makes the device to function as a relay that converts UDP broadcast packets into unicast packets and forwards them to a specified server.
With UDP Helper enabled, the device decides whether to forward a received UDP broadcast packet according to the UDP port number of the packet. If the packet needs to be forwarded, the device modifies the destination IP address in the IP header and then sends the packet to the specified destination server. Otherwise, the device passes the packet to the upper layer for the packet to be processed.
With UDP Helper enabled, the device relays broadcast packets of six default UDP ports by default. The default UDP ports are listed in Table 1-1.
Table 1-1 List of default UDP ports
Protocol
UDP port number
TFTP (trivial file transfer protocol)
69
DNS (domain name system)
53
Time service
37
NetBIOS-NS (NetBIOS name service)
137
NetBIOS-DS (NetBIOS datagram service)
138
TACACS (terminal access controller access control system)
49
1.2  Configuring UDP Helper
Table 1-2 Follow these steps to configure UDP Helper
To do…
Use the command…
Remarks
Enter system view
Enable UDP Helper
udp-helper enable
Required
Disabled by default
Specify a UDP port
Optional
By default, the UDP helper enabled device converts and forwards broadcast packets of ports 69, 53, 37, 137, 138, and 49.
Enter VLAN interface view
Configure the destination server to which the UDP broadcast packets are to be forwarded
udp-helper server ip-address
Required
No destination server is configured by default.
  Caution:
l      The dns, netbios-ds, netbios-ns, tacacs, tftp, and time keywords correspond to the six default ports. You can configure the default ports by specifying port numbers or the corresponding parameters. For example, udp-helper port 53 and udp-helper port dns specify the same port.
l      When you view the configuration information by using the display current-configuration command, the UDP Helper configuration on default UDP ports is not displayed. The UDP Helper configuration of a default UDP port is displayed only when UDP Helper is disabled on the port.
l      The configuration of all UDP ports (including the default ports) is removed if you disabled UDP Helper.
l      You can configure up to 256 UDP ports that require relaying and forwarding.
l      You can configure up to 20 destination servers at an interface.
l      If the destination server is configured on a VLAN interface, the broadcast packets from a VLAN port to a specific UDP port will be unicast to the destination server configured on that VLAN interface after UDP Helper is enabled.
1.3  Displaying and Maintaining UDP Helper
Table 1-3 Displaying and maintaining UDP Helper
To do…
Use the command…
Remarks
Display the information of the destination server and the number of packets forwarded by UDP relay
display udp-helper server [ interface interface-type interface-number ]
Available in any view
Clear statistics about packets forwarded by UDP relay
reset udp-helper packet
Available in user view
1.4  UDP Helper Configuration Example
I. Network requirements
The VLAN interface of a device has an IP address of 10.110.1.1/16, connecting to network segment 10.110.0.0/16. Specify to forward broadcast packets with destination UDP port 55 to destination server 202.38.1.2/24.
II. Network diagram
Figure 1-1 Network diagram for UDP Helper configuration
III. Configuration procedure
&  Note:
The following configuration assumes that the route between the device and the network segment 202.38.0.0/24 is reachable.
# Enable UDP Helper.
[Sysname] udp-helper enable
# Specify to forward the broadcast packets with destination UDP port being 55.
[Sysname] udp-helper port 55
# Specify the server with the IP address of 202.38.1.2 as the destination server to which UDP broadcast packets are to be forwarded.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 10.110.1.1 16
[Sysname-Vlan-interface1] udp-helper server 202.38.1.2
