H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
27-NQA Operation
27-NQA Operation 723 KB
Chapter 1  NQA Configuration
&  Note:
Descriptions and examples in this document apply to switches and routers that support the NQA feature, unless otherwise specified.
When configuring NQA, go to these sections for information you are interested in:
l           NQA Overview
l           Configuring NQA Tests
l           Configuring Optional Parameters for NQA Tests
l           Displaying and Maintaining NQA
1.1  NQA Overview
This section covers these topics:
l           Introduction to NQA
l           NQA Server and NQA Client
l           NQA Test Operation
1.1.1  Introduction to NQA
Ping can use only the Internet control message protocol (ICMP) to test the reachability of the destination host and the roundtrip time of a packet to the destination. NQA (network quality analyzer) is an enhanced Ping tool used for testing the performance of protocols running on networks. Besides the Ping functions, NQA can provide the following functions:
l           Detecting the availability and the response time of DHCP, FTP, HTTP, and SNMP services.
l           Testing the delay jitter of the network.
l           Verifying the availability of TCP, UDP, and DLSw packets.
Different from Ping, NQA does not display the roundtrip time or time-out time of each packet on the console terminal in a real-time way. In this case, you have to execute the display nqa results command to view NQA test results. In addition, NQA can help you to set parameters for various tests and start these tests through the network management system (NMS).
1.1.2  NQA Server and NQA Client
In most NQA test systems, you only need to configure an NQA client. However, when you perform a TCP, UDP, or jitter test, you need to configure an NQA server. Figure 1-1 shows the relationship between an NQA client and an NQA server.
Figure 1-1 Relationship between NQA client and NQA server
The NQA server listens to test requests originated by the NQA client and makes a response to these requests. The NQA server can respond to requests originated by the NQA client only when the NQA server is enabled and the corresponding destination address and port number are configured on the server. The IP address and port number specified for a listening service on the server must be consistent with those on the client.
You can create multiple TCP or UDP listening services on the NQA server, with each listening service corresponding to a specified destination address and port number.
1.1.3  NQA Test Operation
NQA can test multiple protocols. A test group must be created for each type of NQA test. Each test group can be related to only one type of NQA test. Each test group has an administrator name and an operation tag. The administrator name and the operation tag uniquely identify a test group.
After you create a test group and enter test group view, you can configure related test parameters. Test parameters vary with the test type. For details, see the configuration procedure below.
For optional parameters common to different types of tests, refer to section 1.3  "Configuring Optional Parameters for NQA Tests”.
To perform an HW test successfully, proceed as follows:
1)         Enable the NQA client.
2)         Create a test group and configure test parameters according to the test type.
3)         Perform the NQA test through the related enable command.
4)         Display the test results through the related display or debugging command.
&  Note:
After you enable the NQA client, you can create multiple test groups to perform tests. In this way, you do not need to enable the NQA client repeatedly.
1.2  Configuring NQA Tests
&  Note:
l      You need to configure the NQA client and NQA server for TCP, UDP, and jitter tests, while you need to configure only the NQA client for other tests.
l      You are not recommended to perform TCP, UDP, or jitter test on a known port. Otherwise, the NQA probes will fail or the corresponding services of this known port will be unavailable.
l           Configuring the ICMP Test
l           Configuring the DHCP Test
l           Configuring the FTP Test
l           Configuring the HTTP Test
l           Configuring the Jitter Test
l           Configuring SNMP Query Test
l           Configuring the TCP Test
l           Configuring the UDP Test
l           Configuring the DLSw Test
1.2.1  Configuring the ICMP Test
The ICMP test is mainly used to test whether an NQA client can send packets to a specified destination and test the roundtrip time of packets.
I. Configuration procedure
Follow these steps to configure the ICMP test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Create an NQA test group and enter its view
nqa admin-name operation-tag
Required
Set the test type to ICMP
test-type icmp
Optional
ICMP by default.
Configure a destination address for a test
destination-ip ip-address
Required
Configure the size of test packets sent
datasize size
Optional
56 bytes by default.
Configure a string of fill characters of a test packet
datafill text
Optional
By default, the fill string for ICMP test packets is the string corresponding to ASCII codes 00 to 09; starting from the second byte, the fill string for UDP test packets is the string corresponding to ASCII codes 00 to FF, with the first byte used for control.
Specify the IP address of an interface as the source IP address of an ICMP test request packet
source-interface interface-type interface-number
Optional
The interface specified by this command can only be a VLAN interface. In addition, the interface must be up. Otherwise, the test will fail.
Configure common optional parameters
Refer to section 1.3   “Configuring Optional Parameters for NQA Tests".
Optional
Enable the NQA test
test-enable
Required
display nqa results [ admin-name operation-tag ]
Required
You can execute the command in any view.
II. Configuration example
1)         Network requirements
Use the NQA ICMP function to test whether the NQA client (SwitchA) can send packets to the specified destination (SwitchB) and test the roundtrip time of packets.
l           SwitchA serves as the NQA client and the IP address is 10.1.1.1/16.
l           SwitchB serves as the object that is to be pinged from Device 1 and the IP address is 10.2.2.2/16.
2)         Network diagram
Figure 1-2 Network diagram for the ICMP test
3)         Configuration procedure
Perform the following configurations on SwitchA:
# Enable the NQA client, create an ICMP test group, and configure related test parameters.
[Sysname] nqa-agent enable
[Sysname] nqa admin icmp
[Sysname-nqa-admin-icmp] test-type icmp
[Sysname-nqa-admin-icmp] destination-ip 10.2.2.2
# Configure optional parameters.
[Sysname-nqa-admin-icmp] count 10
[Sysname-nqa-admin-icmp] timeout 5
# Enable the ICMP test.
[Sysname-nqa-admin-icmp] test-enable
You can view the configuration result using the display nqa results command.
1.2.2  Configuring the DHCP Test
The DHCP test is mainly used to test the existence of a DHCP server on the network as well as the time necessary for the DHCP server to respond to a client request and assign an IP address to the client.
I. Configuration prerequisites
The interface specified by the source-interface command must be up.
Before the DHCP test, you need to perform some configurations on the DHCP server. For example, you need to enable the DHCP service and configure an address pool. If the NQA (DHCP) client and the DHCP server are not in the same network segment, you need to configure a DHCP relay. For detailed configurations, refer to DHCP Operation Manual.
II. Configuration procedure
Follow these steps to configure the DHCP test
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to DHCP
test-type dhcp
Required
Specify an interface for a DHCP test
Required
The interface in the command must be a VLAN interface.
Refer to section 1.3  Configuring Optional Parameters for NQA Tests
Optional
Enable the NQA test
test-enable
Required
Required
III. Configuration example
SwitchB is configured as the DHCP server. The time it takes for SwitchA to obtain an IP address from SwitchB is tested with the NQA DHCP function.
l           SwitchB serves as the DHCP server and the IP address is 10.2.2.2/16
2)         Network diagram
Figure 1-3 Network diagram for the DHCP test
Perform the following configurations on the SwitchA:
# Enable the NQA client, create a DHCP test group, and configure related test parameters.
[Sysname] nqa admin dhcp
[Sysname-nqa-admin-dhcp] test-type dhcp
[Sysname-nqa-admin-dhcp] source-interface Vlan-interface 3
# Enable the DHCP test.
[Sysname-nqa-admin-dhcp] test-enable
1.2.3  Configuring the FTP Test
The FTP test is mainly used to test the connection with a specified FTP server and the time necessary for the FTP client to transfer a file to the FTP server.
Before the FTP test, you need to perform some configurations on the FTP server. For example, you need to configure the username and password used to log in to the FTP server. For the FTP server configurations, refer to File System Management Operation Manual.
Follow these steps to configure the FTP test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to FTP
test-type ftp
Required
Required
Here it is the IP address of the FTP server.
Configure the source IP address of a test request packet
source-ip ip-address
Required
The source IP address must be that of an interface on the device and the interface must be up. Otherwise, the test will fail.
Configure the operation type
ftp-operation { get | put }
Optional
get by default, meaning to get files from the FTP server.
Configure a login username
username name
Required
Configure a login password
password password
Optional
Specify a file to be transferred between the FTP server and the FTP client.
filename file-name
Required
Optional
Enable the NQA test
test-enable
Required
Required
&  Note:
l      When you perform a put operation, a file-name file with a fixed size and contents will be created on the FTP server; it is not a local file specified with the file-name argument.
l      Transfer a small file for the FTP test. If the file is too large, the test may fail because of time-out.
l      When you perform a get operation, the file obtained from the FTP server will not be saved on the device, either. If there is no such file-name file on the FTP server, the FTP test will fail.
Use the NQA FTP function to test the connection with a specified FTP server and the time necessary for the FTP client to upload a file to the FTP server. The login username is admin, the login password is nqa, and the file to be transferred to the FTP server is config.txt.
2)         Network diagram
Figure 1-4 Network diagram for the FTP test
# Enable the NQA client, create an FTP test group, and configure related test parameters.
[Sysname] nqa admin ftp
[Sysname-nqa-admin-ftp] test-type ftp
[Sysname-nqa-admin-ftp] destination-ip 10.2.2.2
[Sysname-nqa-admin-ftp] source-ip 10.1.1.1
[Sysname-nqa-admin-ftp] ftp-operation put
[Sysname-nqa-admin-ftp] username admin
[Sysname-nqa-admin-ftp] password nqa
[Sysname-nqa-admin-ftp] filename config.txt
# Enable the FTP test.
[Sysname-nqa-admin-ftp] test-enable
1.2.4  Configuring the HTTP Test
The HTTP test is mainly used to test the connection with a specified HTTP server and the time required to obtain data from the HTTP server.
Follow these steps to configure the HTTP test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to HTTP
test-type http
Required
Required
Here it is the IP address of the HTTP server.
Configure the HTTP operation type
http-operation { get | post }
Optional
get by default, meaning to get data from the HTTP server.
Configure an HTTP operation string
http-string string version
Required
Optional
Enable the NQA test
test-enable
Required
Required
Use the HTTP function to test the connection with a specified HTTP server and the time required to obtain data from the HTTP server.
2)         Network diagram
Figure 1-5 Network diagram for the HTTP test
# Enable the NQA client, create an HTTP test group, and configure related test parameters.
[Sysname] nqa admin http
[Sysname-nqa-admin-http] test-type http
[Sysname-nqa-admin-http] destination-ip 10.2.2.2
[Sysname-nqa-admin-http] http-operation get
[Sysname-nqa-admin-http] http-string /index.htm HTTP/1.0
# Enable the HTTP test.
[Sysname-nqa-admin-http] test-enable
1.2.5  Configuring the Jitter Test
&  Note:
You are not recommended to perform an NQA jitter test on a known port. Otherwise, the NQA test will fail or the corresponding services of this port will be unavailable.
The jitter test is used to take statistics of delay jitter of UDP packet transmission. Delay jitter refers to the difference between the interval of receiving two packets consecutively and the interval of sending these two packets. During the test, the source port sends data packets to the destination port at regular intervals. The destination port affixes a time stamp to each packet that it receives and then sends it back to the source port. After the source port receives the data packet, the delay jitter can be calculated.
To improve the accuracy of the statistics results, you must send multiple test packets when you perform a test. The more test packets are sent, the more accurate the statistics results are. However, it takes a longer time to complete the test. You can quicken a jitter test by reducing the interval of sending test packets. However, doing so will cause an impact on the network.
The error in the statistics results of a jitter test is big since there is a delay in both sending and receiving data packets.
A jitter test requires cooperation between the NQA server and the NQA client. You must configure the UDP listening function on the NQA server, and a destination address and a destination port on the NQA client, and ensure that the destination address and destination port on the NQA client are respectively the listening IP address and port on the NQA server.
1)         Configure the NQA server.
Follow these steps to configure the NQA server for a jitter test.
To do...
Use the command...
Remarks
Enter system view
Enable the NQA server
nqa-server enable
Required
Disabled by default
Configure the UDP listening function on the NQA server
nqa-server udpecho ip-address port-number
Required
The listening IP address and port number must be the destination IP address and port on the NQA client.
2)         Configure the NQA client.
Follow these steps to configure the NQA client for a jitter test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to jitter
test-type jitter
Required
Required
The destination address is the listening IP address on the NQA server.
Configure a destination port
destination-port port-number
Required
The destination port is the listening port on the NQA server.
Configure the number of jitter test packets sent in a probe
jitter-packetnum number
Optional
10 by default.
Configure the interval for sending jitter test packets
jitter-interval interval
Optional
20 ms by default.
Refer to section 1.3  Configuring Optional Parameters for NQA Tests”.
Optional
Enable the NQA test
test-enable
Required
Required
Display the recorded delay jitter of UDP packet transmission in the last NQA jitter test
display nqa jitter [ admin-name operation-tag ]
Optional
&  Note:
The number of probes made in a jitter test depends on the count command, while the number of test packets sent in each probe depends on the jitter-packetnum command.
Use the NQA jitter function to test the delay jitter of packet transmission between the local port (SwitchA) and the specified destination port (SwitchB).
2)         Network diagram
Figure 1-6 Network diagram for the jitter test
l           Configuration on SwitchB
# Enable the NQA server and configure the listening IP address and port number.
[Sysname] nqa-server enable
[Sysname] nqa-server udpecho 10.2.2.2 9000
l           Configuration on SwitchA
# Enable the NQA client, create a jitter test group, and configure related test parameters.
[Sysname] nqa admin jitter
[Sysname-nqa-admin-jitter] test-type jitter
[Sysname-nqa-admin-jitter] destination-ip 10.2.2.2
[Sysname-nqa-admin-jitter] destination-port 9000
# Enable the jitter test.
[Sysname-nqa-admin-jitter] test-enable
You can view the configuration result using the display nqa results and display nqa jitter command.
1.2.6  Configuring SNMP Query Test
The SNMP query test is mainly used to test the time the NQA client takes to send an SNMP query packet to the SNMP agent and then receive a response packet.
The SNMP agent function must be enabled on the device serving as an SNMP agent.
Follow these steps to configure the SNMP query test.
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Create an NQA test group and enter test group view
Required
Set the test type to SNMP query
test-type snmpquery
Required
Required
Optional
Enable the NQA test
test-enable
Required
Required
Use the NQA SNMP query function to test the time it takes the SwitchA to send an SNMP query packet to the SwitchB (SNMP agent) and receive a response packet.
2)         Network diagram
Figure 1-7 Network diagram for the SNMP query test
l           Perform the following configurations on SNMP agent.
# Enable the SNMP agent service and set the SNMP version to V2C, the read community to public, and the write community to private.
[Sysname] snmp-agent sys-info version v2c
[Sysname] snmp-agent community read public
[Sysname] snmp-agent community write private
&  Note:
l      SNMP must be enabled on the SNMP agent. Otherwise, no response packet will be received.
l      In this example, the configuration is based on the SNMP V2C. If the SNMP of other versions is enabled, the configuration may be different. For details, refer to SNMP - RMON Operation Manual.
# Enable the NQA client, create an SNMP query test group, and configure related test parameters.
[Sysname] nqa admin snmp
[Sysname-nqa-admin-snmp] test-type snmpquery
[Sysname-nqa-admin-snmp] destination-ip 10.2.2.2
# Enable the SNMP query test.
[Sysname-nqa-admin-snmp] test-enable
1.2.7  Configuring the TCP Test
&  Note:
You are not recommended to perform an NQA TCP test on a known port. Otherwise, the NQA test will fail or the corresponding services of this port will be unavailable.
The TCP test is mainly used to test the TCP connection between the client and the specified server and the setup time for the connection.
The TCP test includes TCP-Public test and TCP-Private test.
l           For the TCP-Public test, a connection setup request is permanently initiated to TCP port 7 of the destination address, no destination port needs to be configured on the client, but TCP port 7 used for listening needs to be configured on the server. Even if a port is configured on the client, the port does not take effect.
l           For the TCP-Private test, a connection setup request is initiated to the specified port of the destination address.
Follow these steps to configure the NQA server for the TCP test:
To do...
Use the command...
Remarks
Enter system view
nqa-server enable
Required
Disabled by default
Configure the TCP listening function on the NQA server
nqa-server tcpconnect ip-address port-number
Required
The listening IP address and port number must be the destination IP address and port on the NQA client. If the test type is TCP-Public, the port number must be set to 7.
Follow these steps to configure NQA client for the TCP test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to TCP
test-type { tcpprivate | tcppublic }
Required
Required
The destination address must be the listening IP address on the NQA server.
If the test type is TCP-Public, no port needs to be configured. If the test type is TCP-Private, a port must be configured and it must be the listening port configured on the NQA server.
Optional
Enable the NQA test
test-enable
Required
Required
Use the NQA TCP-Private function to test the time for setting up a TCP connection between the local port (SwitchA) and the specified destination port (SwitchB). The port number used is 9000.
2)         Network diagram
Figure 1-8 Network diagram for the TCP-Private test
[Sysname] nqa-server tcpconnect 10.2.2.2 9000
# Enable the NQA client, create a TCP test group, and configure related test parameters.
[Sysname] nqa admin tcpprivate
[Sysname-nqa-admin-tcpprivate] test-type tcpprivate
[Sysname-nqa-admin-tcpprivate] destination-ip 10.2.2.2
[Sysname-nqa-admin-tcpprivate] destination-port 9000
# Enable the TCP test.
[Sysname-nqa-admin-tcpprivate] test-enable
# Display the test results.
[Sysname-nqa-admin-tcpprivate] display nqa results admin tcpprivate
1.2.8  Configuring the UDP Test
&  Note:
You are not recommended to perform an NQA UDP test on a known port. Otherwise, the NQA test will fail or the corresponding services of this port will be unavailable.
The UDP test is mainly used to test the roundtrip time of a UDP packet from the client to the specified server.
The UDP test includes UDP-Public test and TCP-Private test.
l           For the UDP-Public test, a connection setup request is permanently initiated to UDP port 7 of a destination address, no port needs to be configured on the client, but port 7 for listening needs to be configured on the server. Even if a port is configured on the client, the port does not take effect.
l           For the UDP-Private test, a connection setup request is initiated to the specified port of the destination address.
Follow these steps to configure the NQA server for the UDP test:
To do...
Use the command...
Remarks
Enter system view
nqa-server enable
Required
Disabled by default
Required
The listening IP address and port number must be the destination IP address and port on the NQA client. If the test type is UDP-Public, the port number must be set to 7.
Follow these steps to configure the NQA client for the UDP test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to UDP
test-type { udpprivate | udppublic }
Required
Required
Equivalent to a destination address in the Ping command. The destination address must be the listening IP address configured on the NQA server.
If the test type is UDP-Public, no port needs to be configured. If the test type is UDP-Private, a port must be configured and it must be the listening port configured on the NQA server.
datasize size
Optional
100 bytes by default.
datafill text
Optional
Optional
Enable the NQA test
test-enable
Required
Required
Use the NQA UDP-Private function to test the setup time for the UDP connection between the local port (SwitchA) and the specified destination port (SwitchB). The port number used is 9000.
2)         Network diagram
Figure 1-9 Network diagram for the UDP-Private test
# Enable the NQA client, create a UDP test group, and configure related test parameters.
[Sysname] nqa admin udpprivate
[Sysname-nqa-admin-udpprivate] test-type udpprivate
[Sysname-nqa-admin-udpprivate] destination-ip 10.2.2.2
[Sysname-nqa-admin-udpprivate] destination-port 9000
[Sysname-nqa-admin-udpprivate] test-enable
1.2.9  Configuring the DLSw Test
The DLSw test is mainly used to test the response time of the DLSw device.
Before the DLSw test, a TCP connection can be set up between the NQA client and the specified device and the DLSw function must be enabled on the specified device.
Follow these steps to configure the DLSw test:
To do...
Use the command...
Remarks
Enter system view
nqa-agent enable
Required
Required
Set the test type to DLSw
test-type dlsw
Required
Required
Optional
Enable the NQA test
test-enable
Required
Required
Use the NQA DLSw function to test the response time of the DLSw device.
2)         Network diagram
Figure 1-10 Network diagram for the DLSw test
Perform the following configurations on the device:
# Enable the NQA client, create a DLSw test group, and configure related test parameters.
[Sysname] nqa administrator dlsw
[Sysname-nqa-administrator-dlsw] test-type dlsw
[Sysname-nqa-administrator-dlsw] destination-ip 10.2.2.2
# Enable the DLSw test.
[Sysname-nqa-administrator-dlsw] test-enable
Unless otherwise specified, the following parameters are applicable to all test types and they can be configured according to the actual conditions. Optional parameters common to NQA are valid for all NQA tests, while those common to an NQA test group are valid only for tests in this test group.
l           Configuring Optional Parameters Common to NQA
l           Configuring Optional Parameters Common to an NQA Test Group
l           Configuring Trap Delivery
1.3.1  Configuring Optional Parameters Common to NQA
Follow these steps to configure optional parameters common to NQA:
To do...
Use the command...
Remarks
Enter system view
Configure the maximum number of tests that the NQA client can simultaneously perform
nqa-agent max-requests number
Optional
5 by default
1.3.2  Configuring Optional Parameters Common to an NQA Test Group
Follow these steps to configure the optional parameters common to an NQA test group:
To do...
Use the command...
Remarks
Enter system view
Enter NQA test group view
Required
Configure a descriptive string for a test group
Optional
No descriptive string by default.
Configure the interval of performing a cyclic test
frequency interval
Optional
No cyclic test is performed by default.
This command is invalid for the DHCP test.
Configure the number of probes in a test
count times
Optional
1 by default. For the TCP test, a probe means a connection. For the jitter test, the number of test packets sent in a probe is determined by the jitter-packetnum command. For the SNMP protocol, three test packets are sent in a probe. For the other tests, one test packet is sent in a probe.
Configure the NQA probe time-out time
timeout time
Optional
Three seconds by default. If no response packet is received within the time-out time of a request packet, the probe fails.
Configure the maximum number of history records that can be saved in a test group
history-records number
Optional
50 by default If the number of history records exceeds this value, the earliest test results are discarded.
Configure the maximum number of hops a test request packet traverses in the network
ttl number
Optional
20 by default.
Configure the ToS field in an IP packet header
tos value
Optional
0 by default.
source-ip ipaddress
This command is required for the FTP test but optional for other tests.
You can specify an IP address as the source IP address of a test request packet. Otherwise, the IP address of the interface sending packets serves as the source IP address of the test request packet.
The source IP address in the command must be the IP address of an interface on the device and the interface must be up. Otherwise, the test will fail.
Configure the source port of a test request packet
source-port port-number
Optional
You can specify a port as the source port of a test request packet. Otherwise, the system automatically assigns a port to serve as the source port of the test request packet.
This command is only valid for jitter, UDP, and SNMP tests.
Enable the routing table bypass function
sendpacket passroute
Optional
Disabled by default. If you want to test the connectivity between the local address and the destination address, you can enable this function. After this function is enabled, the routing table will not be searched, and the packet is directly sent to the destination in the directly connected network. If the destination is not in the directly connected network, an error will be prompted.
1.3.3  Configuring Trap Delivery
Before configuring Trap delivery, make sure you configure an IP address of the network management server that will receive Trap messages on the device. For detailed configurations, refer to SNMP-RMON Operation Manual.
II. Configuring Trap delivery
A trap message is generated no matter whether an NQA test succeeds or fails. You can set a switch to control the delivery of the trap message to the network management server.
Follow these steps to configure Trap
To do...
Use the command...
Remarks
Enter system view
Required
Enable trap debugging to send a trap message to the network management server
send-trap { all | { probefailure | testcomplete | testfailure }* }
Optional
No trap message is sent to the network management server by default.
Configure the minimum number of probe failures in an NQA test before a test failure trap message is sent
test-failtimes times
Optional
1 by default.
Configure the number of consecutive probe failures in an NQA test before a trap message is sent to indicate a probe failure
probe-failtimes times
Optional
1 by default.
1.4  Displaying and Maintaining NQA
To do…
Use the command…
Remarks
Display history information of tests.
display nqa history [ admin-name operation-tag ]
Available in any view
Display the results of the last NQA jitter test.
Display the results of the last test.
