H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
26-Information Center Operation
26-Information Center Operation 198 KB
Chapter 1  Information Center Configuration
1.1  Information Center Overview
1.1.1  Introduction to Information Center
Acting as the system information hub, information center classifies and manages system information. Together with the debugging functionality, information center offers a powerful support to the network administrators and developers in monitoring network performance and diagnosing network problems.
1.1.2  System Information Format
System information has the following format:
<priority>timestamp sysname module/level/digest:content
&  Note:
l      The closing set of angel brackets < >, the space, the forward slash /, and the colon are all required in the above format.
l      Before the <priority> may have %, “#, or * followed with a space, indicating log, alarm, or debug information respectively.
Below is the format of log information to be output to a log host:
% <188>Sep 28 15:33:46:235 2005 Sysname SHELL/5/LOGIN: Console login from con0
What follows is a detailed explanation of the fields involved:
I. Priority
The priority is calculated using the following formula: facility*8+severity-1, in which facility is local7 by default and the range of severity is 0 to 7. Table 1-2 details the value and meaning associated with each severity.
Note that there is no space between the priority and timestamp fields and that the priority only takes effect when the information has been sent to the log host.
II. Timestamp
Timestamp records the time when system information is generated to allow users check and identify system events.
Note that there is a space between the timestamp and sysname (host name) fields.
III. Sysname
Sysname is the system name of the current host. Users can use the sysname command to modify the sysname.
Note that there is a space between the sysname and module fields.
IV. Module
The module field represents the name of the module that generates system information. Some modules are shown below:
Table 1-1 Module name list
Module name
8021X
802.1X module
ACL
Access Control List module
ARP
Address Resolution Protocol module
CFM
Configuration File Management module
CLST
Cluster module
CMD
Command line module
COMMONSY
Common System MIB module
DEV
Device management module
DHCP
Dynamic Host Configuration Protocol module
DNS
Domain Name System module
ETH
Ethernet module
FTPS
FTP Server module
GARP
Generic Attribute Registration Protocol module
HABP
Huawei Authentication Bypass Protocol module
HWCM
Huawei Configuration Management proprietary MIB module
LAGG
Link Aggregation module
LINE
Terminal line module
MSTP
Multiple Spanning Tree Protocol module
NAT
Network Address Translation module
NTP
Network Time Protocol module
PKI
Public Key Infrastructure module
POE
Power over Ethernet module
QoS
Quality of Service module
RDS
Radius module
RM
Routing Management module
RMON
Remote monitor module
RSA
Revest, Shamir and Adleman module
SHELL
User interface module
SNMP
Simple Network Management Protocol module
SOCKET
Socket module
SSH
Secure Shell module
SYSMIB
System MIB module
TAC
HWTACACS module
TELNET
Telnet module
UDPH
UDP Helper module
VFS
Virtual File module
VLAN
Virtual Local Area Network module
VTY
Virtual Type Terminal module
default
Default setting of all modules
Between “module” and “level” is a “/”.
V. Level (Severity)
System information falls into three categories: log information, debug information, and trap information. Each kind of information can be further divided into eight levels based on its severity, as detailed in Table 1-2. Note that the smaller the severity value, the higher the severity.
Table 1-2 Severity description
Severity
Severity Value
emergencies
0
The most emergent errors
alerts
1
Errors that demand prompt correction
critical
2
Critical errors
errors
3
Errors that are not critical but demand attention
warnings
4
Warnings that suggest possible errors
notifications
5
Normal errors with important prompts
informational
6
Normal prompts
debugging
7
Debugging prompts
Information filtering by severity works this way: information with severity value greater than the configured threshold will not be output during the filtering.
l           If the threshold is set to 0, only information with the severity being emergencies will be output;
l           If the threshold is set to 7, information of all severities will be output.
Note that there is a forward slash between the levels (severity) and digest fields.
VI. Digest
The digest field is a string of up to 32 characters, outlining the system information.
Note that there is a colon between the digest and content fields.
VII. Content
This field provides the content of the system information.
1.2  Configuring Information Center
Information center has the following characteristics:
l           Supports information output to the console, the monitor, the log host, the trap buffer, the log buffer, and the SNMP agent (snmpagent). A default channel is allocated to each individual output direction, as illustrated in the following table.
l           System information is classified into eight categories according to severity and filtered by severity;
l           System information is categorized and filtered by source module;
l           The output information can be in English or Chinese.
Table 1-3 Information channels for different output directions
Output direction
Information channel No.
Default channel name
Console
0
console
Monitor terminal
1
monitor
Log host
2
loghost
Trap buffer
3
trapbuffer
Log buffer
4
logbuffer
SNMP NMS
5
snmpagent
Note:
NMS = Network Management Station
&  Note:
Configurations for the six output directions function independently and take effect only after the information center has been enabled.
1.2.1  Configuring to Output System Information to the Console
I. Configuring to output system information to the console
Follow these steps to configure to output system information to the console:
To do…
Use the command…
Remarks
Enter system view
Enable information center
info-center enable
Optional
Enabled by default
Name the channel with a specified channel number
info-center channel channel-number name channel-name
Optional
Refer to Table 1-3 for default channel names
Configure the channel through which system information can be output to the console
info-center console channel { channel-number | channel-name }
Optional
System information is output to the console by default with channel 0 as the default channel
Configure the source of the output information
info-center source { modu-name | default } channel { channel-number | channel-name } [ debug { level severity | state state }* | log { level severity | state state }* | trap { level severity | state state }* ]*
Required
Configure the format of the time stamp
info-center timestamp { log | trap | debugging } { boot | date | none }
Optional
By default, the time stamp for log and trap information is date, and that for debugging information is boot.
II. Enabling the display of system information on the console
After configuring to output system information to the console, you need to enable the associated display function in order to display the output information on the console.
Perform the following configurations in user view to enable the display of system information on the console:
To do…
Use the command…
Remarks
Enable the monitoring of system information on the console
terminal monitor
Required
The monitoring of system information on the console is enabled default.
Enable the display of debug information on the console
terminal debugging
Required
Disabled by default
Enable the display of log information on the console
terminal logging
Optional
Enabled by default
Enable the display of trap information on the console
terminal trapping
Optional
Enabled by default
1.2.2  Configuring to Output System Information to a Monitor Terminal
System information can also be output to a monitor terminal, which is a user terminal that has login connections through the AUX, VTY, or TTY user interface.
I. Configuring to output system information to a monitor terminal
Follow these steps to configure to output system information to a monitor terminal:
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure the channel through which system information can be output to a monitor terminal
info-center monitor channel { channel-number | channel-name }
Optional
System information is output to the monitor terminal by default with channel 1 as the default channel
Required
Optional
II. Enabling the display of system information on a monitor terminal
After configuring to output system information to a monitor terminal, you need to enable the associated display function in order to display the output information on the monitor terminal.
Perform the following configurations to enable the display of system information on a monitor terminal:
To do…
Use the command…
Remarks
Enable the monitoring of system information on a monitor terminal
terminal monitor
Required
The monitoring of system information on the monitoring terminal is disabled.
Enable the display of debug information on a monitor terminal
terminal debugging
Required
Disabled by default
Enable the display of log information on a monitor terminal
terminal logging
Optional
Enabled by default
Enable the display of trap information on a monitor terminal
terminal trapping
Optional
Enabled by default
1.2.3  Configuring to Output System Information to a Log Host
Follow these steps to configure to output system information to a log host:
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Specify a log host and configure the parameters when system information is output to the log host
info-center loghost host-ip [ channel { channel-number | channel-name } ] [ facility local-number ] [ language { chinese | english } ]*
Required
Disabled by default with channel 2 as the default channel when enabled
Configure the source interface through which log information can be output to a log host
Optional
By default, no source interface is configured, the system selects an interface as the source interface
Required
Configure the format of the time stamp for log information
info-center timestamp loghost { date | no-year-date | none }
Optional
By default, the time stamp for log, information is date.
1.2.4  Configuring to Output System Information to the Trap Buffer
Follow these steps to configure to output system information to the trap buffer:
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure system information to be output to a trap buffer and configure the associated parameters
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] *
Optional
System information is output to the trap buffer by default with channel 3 (known as trapbuffer) as the default channel and a default buffer size of 256
Required
Optional
By default, the time stamp for log and trap information is date and that for debugging information is boot.
1.2.5  Configuring to Output System Information to the Log Buffer
Follow these steps to configure to output system information to the log buffer:
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure the channel through which system information can be output to the log buffer and specify the buffer size
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ]*
Optional
System information is output to the log buffer by default with channel 4 (known as logbuffer) as the default channel and a default buffer size of 512.
Required
Configure the format of the timestamp
Optional
1.2.6  Configuring to Output System Information to the SNMP NMS
Follow these steps to configure to output system information to the SNMP NMS:
To do…
Use the command…
Remarks
Enter system view
info-center enable
Optional
Enabled by default
Optional
Configure the channel through which system information can be output to the SNMP NMS
info-center snmp channel { channel-number | channel-name }
Optional
System information is output to the SNMP NMS by default with channel 5 (known as snmpagent) as the default channel
Required
Optional
&  Note:
To ensure that system information can be output to the SNMP NMS, you need to make the necessary configurations on the SNMP agent and the NMS. For detailed information on SNMP, refer to SNMP-RMON part of the manual.
1.2.7  Configuring Synchronous Information Output
Synchronous information output refers to the feature that if the user’s input is interrupted by system output such as log, trap, or debug information, then after the completion of system output the system will display a command line prompt (in command editing mode a prompt, or a [Y/N] string in interaction mode) and the user’s input so far.
This command is intended for the scenarios when the user’s input is interrupted by a large amount of system output. With this feature enabled, the user can continue their operations from where they were stopped.
Follow these steps to enable synchronous information output:
To do…
Use the command…
Remarks
Enter system view
Enable synchronous information output
info-center synchronous
Required
Disabled by default
&  Note:
l      If no information is input from the user following the current command line prompt, the system will not display any command line prompt after system information output.
l      In the interaction mode, the user is prompted for some information input. If the input is interrupted by system output, no system prompt will be made, rather only the user’s input will be displayed in a new line.
1.3  Displaying and Maintaining Information Center
To do…
Use the command…
Remarks
Display channel information for a specified channel
display channel [ channel-number | channel-name ]
Available in any view
Display the configurations for all information channels except channel 6 to 8.
display info-center
Display the state of the log buffer and the log information recorded
display logbuffer [ level severity | size buffersize ]* [ | { begin | exclude | include } text ]
Display a summary of the log buffer
display logbuffer summary [ level severity ]
Display the state of the trap buffer and the trap information recorded
display trapbuffer [ size buffersize ]
Reset the log buffer
reset logbuffer
Reset the trap buffer
reset trapbuffer
1.4  Information Center Configuration Example
1.4.1  Outputting Log Information to a Unix Log Host
I. Network requirements
l           Send log information to a Unix log host;
l           The log host has an IP address of 1.2.0.1/16;
l           Log information with severity higher than informational will be output to the log host;
l           The log information is in English and the source modules are ARP and CMD.
II. Network diagram
Figure 1-1 Network diagram for outputting log information to a Unix log host
III. Configuration procedure
1)         Configuring the device
# Enable information center.
[Sysname] info-center enable
# Specify the channel to output log information to the loghost.
[Sysname] info-center loghost channel loghost
# Disable the output of log, trap, and debug information of all modules to the log host.
[Sysname] info-center source default channel loghost debug state off log state off trap state off
  Caution:
l      As the default system configurations for different channels vary, ensure that the outputting of log, trap, and debug information for the specified channel (loghost in this example) of all modules is disabled before the system information can be output to meet the current network requirements.
l      Use the display channel command to display the state of a channel.
# Set the host with an IP address of 1.2.0.1/16 to be the log host, set the severity to informational, the output language to English, and the source modules to ARP and CMD.
[Sysname] info-center loghost 1.2.0.1 facility local4 language english
[Sysname] info-center source arp channel loghost log level informational
[Sysname] info-center source cmd channel loghost log level informational
2)         Configuring the log host
The following configurations were made on SunOS 4.0 which has similar configurations to the Unix operating systems implemented by other vendors.
Step 1: issue the following commands as a root user.
# mkdir /var/log/H3C
# touch /var/log/H3C/information
Step 2: Edit the file /etc/syslog.conf as a root user and add the following selector/action pair.
# H3C configuration messages
local4.info    /var/log/H3C/information
&  Note:
Be aware of the following issues while editing the /etc/syslog.conf file:
l      Comments must be on a separate line and must begin with the # sign.
l      The selector/action pair must be separated with a tab key, rather than a space.
l      No redundant spaces are allowed in the file name.
l      The device name and the accepted severity of log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost or info-center source command; otherwise the log information may not be output properly to the log host.
Step three: after the log file information has been created and the configuration file /etc/syslog.conf has been modified, ensure that the configuration file /etc/syslog.conf is reread:
# ps -ae | grep syslogd
147
# kill -HUP 147
After the above configurations, system will be able to keep log information in the related file.
1.4.2  Outputting Log Information to a Linux Log Host
l           Send log information to a Linux log host; the log host has an IP address of 1.2.0.1/16;
l           The log information is in English and all modules can output information.
II. Network diagram
Figure 1-2 Network diagram for outputting log information to a Linux log host
[Sysname] info-center loghost 1.2.0.1 channel loghost
  Caution:
l      As the default system configurations for different channels vary, ensure that the output of log, trap, and debug information for the specified channel (loghost in this example) of all modules is disabled before the system information can be output to meet the current network requirements.
# Set the host with an IP address of 1.2.0.1/16 to be the log host, set the severity to informational, the output language to English, and the source modules to be all modules.
[Sysname] info-center loghost 1.2.0.1 facility local7 language english
[Sysname] info-center source default channel loghost log level informational
local7.info    /var/log/H3C/information
&  Note:
l      The facility name and the accepted severity of the log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost or info-center source command; otherwise the log information may not be output properly to the log host.
Step three: after the log file information has been created and the /etc/syslog.conf file has been modified, issue the following commands to display the process ID of syslogd, terminate a syslogd process, and to restart syslogd using the –r option.
147
# kill -9 147
# syslogd -r &
&  Note:
Ensure that the syslogd process is started with the –r option on a Linux log host.
1.4.3  Outputting Log Information to the Console
l           Log information with a severity higher than informational will be output to the console;
l           The source modules are ARP and CMD.
II. Network diagram
Figure 1-3 Network diagram for sending log information to the console
# Specify the channel to output log information to the console.
[Sysname] info-center console channel console
[Sysname] info-center source default channel console debug state off log state off trap state off
  Caution:
l      As the default system configurations for different channels vary, ensure that the output of log, trap, and debug information for the specified channel (console in this example) of all modules is disabled before the system information can be output to meet the current network requirements.
# Enable system information output for the ARP and CMD modules, with information severity ranging from emergencies to informational.
[Sysname] info-center source arp channel console log level informational
[Sysname] info-center source cmd channel console log level informational
[Sysname] quit
# Enable the display of log information on a monitor terminal.
<Sysname> terminal monitor
% Current terminal monitor is on
<Sysname> terminal logging
% Current terminal logging is on
