22-VXLAN命令参考
01-VXLAN命令
本章节下载 01-VXLAN命令  (516.54 KB)
01-VXLAN命令
目
1 VXLAN
1.1 VXLAN基础配置命令
1.1.1 arp suppression enable
1.1.2 description
1.1.3 display arp suppression vsi
1.1.4 display l2vpn interface
1.1.5 display l2vpn mac-address
1.1.6 display l2vpn vsi
1.1.7 display vxlan tunnel
1.1.8 flooding disable
1.1.9 l2vpn enable
1.1.10 l2vpn rewrite inbound tag
1.1.11 mac-address static
1.1.12 mtu
1.1.13 reset arp suppression vsi
1.1.14 reset l2vpn mac-address
1.1.15 selective-flooding mac-address
1.1.16 shutdown
1.1.17 tunnel
1.1.18 tunnel global source-address
1.1.19 vsi
1.1.20 vxlan
1.1.21 vxlan invalid-udp-checksum discard
1.1.22 vxlan invalid-vlan-tag discard
1.1.23 vxlan local-mac report
1.1.24 vxlan tunnel mac-learning disable
1.1.25 vxlan udp-port
1.1.26 xconnect vsi
1.2 VXLAN IP网关配置命令
1.2.1 bandwidth
1.2.2 default
1.2.3 description
1.2.4 display interface vsi-interface
1.2.5 distributed-gateway local
1.2.6 gateway subnet
1.2.7 gateway vsi-interface
1.2.8 interface vsi-interface
1.2.9 mac-address
1.2.10 mtu
1.2.11 reset counters interface vsi-interface
1.2.12 shutdown
1.2.13 vtep group member local
1.2.14 vtep group member remote
1.2.15 vxlan tunnel arp-learning disable
1.3 ENDP配置命令
1.3.1 display vxlan neighbor-discovery client member
1.3.2 display vxlan neighbor-discovery client statistics
1.3.3 display vxlan neighbor-discovery client summary
1.3.4 display vxlan neighbor-discovery server member
1.3.5 display vxlan neighbor-discovery server statistics
1.3.6 display vxlan neighbor-discovery server summary
1.3.7 network-id
1.3.8 vxlan neighbor-discovery authentication
1.3.9 vxlan neighbor-discovery client enable
1.3.10 vxlan neighbor-discovery client register-interval
1.3.11 vxlan neighbor-discovery server enable
1.4 VXLAN IS-IS配置命令
1.4.1 display vxlan isis brief
1.4.2 display vxlan isis graceful-restart status
1.4.3 display vxlan isis local-host
1.4.4 display vxlan isis local-mac
1.4.5 display vxlan isis lsdb
1.4.6 display vxlan isis peer
1.4.7 display vxlan isis remote-host
1.4.8 display vxlan isis remote-mac
1.4.9 display vxlan isis remote-vxlan
1.4.10 display vxlan isis tunnel
1.4.11 graceful-restart
1.4.12 graceful-restart interval
1.4.13 host-mac-learning enable
1.4.14 host-synchronization enable
1.4.15 local-host proxy enable
1.4.16 log-peer-change enable
1.4.17 mac-synchronization enable
1.4.18 negotiate-vni enable
1.4.19 overlay isis ded-priority
1.4.20 overlay isis timer csnp
1.4.21 overlay isis timer hello
1.4.22 overlay isis timer holding-multiplier
1.4.23 overlay isis timer lsp
1.4.24 reserved vxlan
1.4.25 reset vxlan isis
1.4.26 timer lsp-max-age
1.4.27 timer lsp-refresh
1.4.28 virtual-system
1.4.29 vxlan-isis
1 VXLAN
ICG2000D/3000S/3000F/3000F-DP/5000G/5000T路由器使用集中式命令行,ICG 6000路由器使用分布式命令行。
1.1  VXLAN基础配置命令
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
ARP泛洪抑制功能处于关闭状态。
VSI视图
为了避免广播发送的ARP请求报文过多占用核心网络带宽,VTEP从本地站点、VXLAN隧道接收到ARP请求和ARP应答报文后,根据该报文在本地建立ARP泛洪抑制表项。后续当VTEP收到本站点内虚拟机请求其它虚拟机MAC地址的ARP请求时,优先根据ARP泛洪抑制表项进行代答。如果没有对应的表项,则将ARP请求泛洪到核心网。ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
# 在VSI vsi1下开启ARP泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
·     display arp suppression vsi
·     reset arp suppression vsi
1.1.2  description
description命令用来配置VSI的描述信息。
undo description命令用来恢复缺省情况。
未配置VSI的描述信息。
VSI视图
text:VSI的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn1的VSI的描述信息为“vsi for vpn1”。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
·     display l2vpn vsi
display arp suppression vsi命令用来显示VSI的ARP泛洪抑制表项信息。
集中式设备-独立运行模式:
display arp suppression vsi [ name vsi-name ] [ count ]
分布式设备-独立运行模式/集中式设备-IRF模式:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
分布式设备-IRF模式:
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
slot slot-number:显示指定单板的ARP泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的ARP泛洪抑制表项。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP泛洪抑制表项。slot-number表示设备在IRF中的成员编号。如果不指定本参数,将显示主设备上的ARP泛洪抑制表项。(集中式设备-IRF模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的ARP泛洪抑制表项。(分布式设备-IRF模式)
count:显示ARP泛洪抑制表项的个数。
# 显示所有VSI的ARP泛洪抑制表项信息。(集中式设备-独立运行模式)
<Sysname> display arp suppression vsi
IP address      MAC address    Vsi Name                        Link ID    Aging
1.1.1.2         000f-e201-0101 vsi1                            0x70000    14
1.1.1.3         000f-e201-0202 vsi1                            0x80000    18
1.1.1.4         000f-e201-0203 vsi2                            0x90000    10
# 显示所有VSI的ARP泛洪抑制表项个数。(集中式设备-独立运行模式)
<Sysname> display arp suppression vsi count
Total entries: 3
# 显示主用主控板上的ARP泛洪抑制表项信息。(分布式设备-独立运行模式)
# 显示主用主控板上的ARP泛洪抑制表项个数。(分布式设备-独立运行模式)
Total entries: 3
# 显示主设备上的ARP泛洪抑制表项信息。(集中式设备-IRF模式)
# 显示主设备上的ARP泛洪抑制表项个数。(集中式设备-IRF模式)
Total entries: 3
# 显示全局主用主控板上的ARP泛洪抑制表项信息。(分布式设备-IRF模式)
# 显示全局主用主控板上的ARP泛洪抑制表项个数。(分布式设备-IRF模式)
Total entries: 3
表1-1 display arp suppression vsi命令显示信息描述表
IP address
ARP泛洪抑制表项的IP地址
MAC address
ARP泛洪抑制表项的MAC地址
Vsi Name
VSI名称
Link ID
MAC表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging
ARP泛洪抑制表项的老化时间,单位为分钟
Total entries
ARP泛洪抑制表项的数目
·     arp suppression enable
display l2vpn interface命令用来显示与VSI关联的三层接口的L2VPN信息。
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name:显示与指定VSI关联的三层接口的L2VPN信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
interface-type interface-number:显示指定接口的L2VPN信息。interface-type interface-number为接口类型和接口编号。
verbose:显示详细信息。如果未指定本参数,则显示简要信息。
执行本命令时,如果未指定任何参数,则显示所有与VSI关联的三层接口的L2VPN信息。
# 显示所有与VSI关联的三层接口的L2VPN简要信息。
<Sysname> display l2vpn interface
Total number of interfaces: 2, 1 up, 1 down
Interface                Owner                           Link ID   State    Type
GE1/0/1                  vxlan3                          1         Up       VSI
GE1/0/2                  vxlan4                          2         Down     VSI
表1-2 display l2vpn interface命令显示信息描述表
与VSI关联的三层接口的总数,及处于up和down状态的接口数目
与VSI关联的三层接口的名称
Owner
VSI名称
Link ID
接口对应AC在VSI内的链路标识符
接口的物理状态,取值包括Up和Down
接口对应的L2VPN类型,在VXLAN中取值为VSI
# 显示所有与VSI关联的三层接口的L2VPN详细信息。
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
    Owner         : vsi1
    Link ID       : 0
    State         : Up
    Type          : VSI
Interface: GE1/0/2
    Owner         : vsi2
    Link ID       : 0
    State         : Down
    Type          : VSI
表1-3 display l2vpn interface verbose命令显示信息描述表
接口名称
Owner
与接口关联的VSI名称
Link ID
接口对应AC在VSI内的链路标识符
接口的物理状态,取值包括Up和Down
display l2vpn mac-address命令用来显示VSI的MAC地址表信息。
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址表信息。
dynamic:显示通过源MAC地址动态学习的MAC地址表项。如果不指定本参数,则显示所有类型的MAC地址表项,包括通过源MAC地址动态学习的本地和远端MAC地址表项、通过IS-IS协议学习的远端MAC地址表项、通过BGP EVPN协议学习的远端MAC地址表项、静态配置的远端MAC地址表项和通过OpenFlow下发的远端MAC地址表项。VXLAN不支持静态配置本地MAC地址表项。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址表项的具体信息。
# 显示所有VSI的MAC地址表信息。
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000a   Dynamic  vpn1                            1             Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 4 mac address(es) found  ---
# 显示所有VSI的MAC地址表项总数。
<Sysname> display l2vpn mac-address count
表1-4 display l2vpn mac-address命令显示信息描述表
MAC Address
MAC地址
MAC地址的状态,取值包括:
·     Dynamic:表示通过源MAC地址动态学习的本地或远端MAC地址表项
·     Static:表示静态配置的远端MAC地址表项
·     IS-IS:表示通过IS-IS协议学习的远端MAC地址表项
·     EVPN:表示通过BGP EVPN协议学习的远端MAC地址表项
·     OpenFlow:表示通过OpenFlow下发的远端MAC地址表项
VSI Name
VSI名称
Link ID/Name
对于本端MAC地址,为MAC地址的出链路标识符,即AC在VSI内的链路标识符;对于远端MAC地址,为MAC地址对应的隧道接口名称
Aging
MAC地址表项是否老化,取值包括Aging和NotAging
XX mac address(es) found
VSI的MAC地址表项的总数
·     reset l2vpn mac-address
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示所有VSI的简要信息。
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
表1-5 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·     Up:up状态。只有VXLAN关联了处于up状态的隧道和AC,VSI才会处于up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭VSI
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : Unlimited
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : Disabled
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
  ACs:
    AC                               Link ID    State
    GE1/0/1                          0          Up
表1-6 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括:
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
VSI的已知单播流量的最大带宽值,单位为kbps
Broadcast Restrain
VSI的广播抑制带宽值,单位为kbps
Multicast Restrain
VSI的组播抑制带宽值,单位为kbps
VSI的未知单播抑制带宽值,单位为kbps
MAC Learning
是否使能了MAC地址学习功能
MAC Table Limit
VSI内MAC地址表项的最大数目
Drop Unknown
当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
Flooding
是否使能VSI的泛洪功能,取值包括:
·     Enabled:表示使能了VSI的泛洪功能,即VTEP会将目的MAC地址未知的单播数据帧发送给所有本地和远端站点
·     Disabled:表示禁止VSI的泛洪功能,即VTEP只将目的MAC地址未知的单播数据帧发送给所有本地站点
Gateway Interface
VSI网关虚接口编号
VXLAN ID
VXLAN编号
Tunnels
与VXLAN关联的隧道信息
Tunnel Name
隧道名称
Link ID
隧道在VSI内的链路标识符
隧道状态,取值包括:
·     Up:Tunnel接口状态Up,隧道可正常转发数据
·     Blocked:该隧道为备用代理隧道,不进行数据转发,Tunnel接口状态Up
·     Down:Tunnel接口状态Down,隧道停止数据转发
VXLAN和VXLAN隧道的关联方式:
·     Auto:表示自动关联,分为以下两种:
¡     通过VXLAN ISIS协商VXLAN ID后,自动将VXLAN和VXLAN隧道关联
¡     通过EVPN自动将VXLAN和VXLAN隧道关联
¡     在组播路由方式下,自动创建用于转发泛洪流量的组播VXLAN隧道(MTunnel),并将其与VXLAN关联
·     Manual:表示手动关联VXLAN和VXLAN隧道
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能,即VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     Disabled:关闭隧道的泛洪代理功能
ACs
VSI的AC列表
AC
接入电路
Link ID
AC在VSI内的链路标识符
AC的状态,取值包括Up和Down
display vxlan tunnel命令用来显示与VXLAN关联的VXLAN隧道的信息。
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id:显示与指定VXLAN关联的隧道的信息。vxlan-id为VXLAN的编号,取值范围为0~16777215。不指定此参数,则显示所有与VXLAN关联的隧道的信息。
# 显示所有与VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3(3up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
Tunnel0              0x5000000  Up     Manual       Disabled
# 显示与编号为10的VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel vxlan-id 10
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
表1-7 display vxlan tunnel命令显示信息描述表
已创建的VXLAN的总数
VXLAN ID
VXLAN ID
VSI name
VXLAN所属的VSI名称
Total tunnels
与VXLAN关联的隧道的总数,包括处于Up和Down状态的隧道总数
Tunnel name
隧道名称
Link ID
隧道在VXLAN内的链路标识符
隧道的状态,取值包括:
VXLAN和VXLAN隧道的关联方式:
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能。即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     tunnel
·     vxlan
flooding disable命令用来关闭VSI的泛洪功能。
undo flooding disable命令用来开启VSI的泛洪功能。
flooding disable
VSI的泛洪功能处于开启状态。
VSI视图
缺省情况下,VTEP从本地站点内接收到目的MAC地址未知的单播数据帧后,会在该VXLAN内除接收接口外的所有本地接口和VXLAN隧道上泛洪该数据帧,将该数据帧发送给VXLAN内的所有站点。如果用户希望把该类数据帧限制在本地站点内,不通过VXLAN隧道将其转发到远端站点,则可以通过本命令手工禁止VXLAN对应VSI的泛洪功能。
# 关闭名称为vsi1的VSI的泛洪功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable
1.1.9  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn rewrite inbound tag命令用来配置入方向报文的VLAN标签处理规则。
undo l2vpn rewrite inbound命令用来恢复缺省情况。
l2vpn rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark 1-to-2 s-vid vlan-id c-vid vlan-id } [ symmetric ]
不对入方向报文的VLAN标签进行处理。
三层以太网接口视图
三层聚合接口视图
nest:表示添加标签。
c-vid:表示内层标签。
vlan-id:表示VLAN的编号,取值范围为1~4094。
s-vid:表示外层标签。
remark:表示映射标签。
1-to-2:表示1:2标签映射,即将原有报文中的一层标签映射为两层标签。
symmetric:表示对出方向报文进行相反的标签操作,即为报文剥离一层标签。如果不指定本参数,则表示不对出方向报文的VLAN标签进行处理。
不能通过重复执行本命令修改入方向报文的VLAN标签处理规则。如需修改,请先通过undo l2vpn rewrite inbound命令删除入方向报文的VLAN标签处理规则,再执行l2vpn rewrite inbound tag命令。
执行本命令时,需要注意:
·     l2vpn rewrite inbound tag nest s-vid vlan-id c-vid vlan-id命令只对不携带VLAN tag的报文生效。
·     l2vpn rewrite inbound tag remark 1-to-2命令只对携带一层VLAN tag的报文生效。
# 在三层以太网接口上配置为入方向报文添加外层VLAN标签100,并剥离出方向报文的外层VLAN标签。
[Sysname] interface
[Sysname-] l2vpn rewrite inbound tag nest s-vid 100 symmetric
mac-address static命令用来添加静态远端MAC地址表项。
undo mac-address static命令用来删除指定的静态远端MAC地址表项。
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ] vsi vsi-name
不存在静态的远端MAC地址表项。
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址、全F和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
interface tunnel tunnel-number:指定远端MAC地址对应的VXLAN隧道接口。tunnel-number为VXLAN隧道接口的编号,取值范围为0~10239。指定的隧道接口必须已经创建。
vsi vsi-name:指定远端MAC地址所属的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址、BGP EVPN协议等学习。
对于远端MAC地址表项,interface tunnel interface-number参数指定的隧道接口必须与vsi vsi-name参数指定的VSI对应的VXLAN关联,否则配置将失败。
执行undo mac-address static vsi命令时如果没有指定任何参数,则删除该VSI下的所有静态MAC地址表项。
建议不要将ENDP动态创建的隧道接口指定为远端MAC地址对应的VXLAN隧道接口。否则,配置恢复时,ENDP会重新创建隧道,隧道接口的编号可能发生变化,从而导致静态远端MAC地址表项的配置无法恢复。
# 添加一条静态远端MAC地址表项:MAC地址为000f-e201-0101,VXLAN隧道接口为Tunnel1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
·     vxlan tunnel mac-learning disable
1.1.12  mtu
mtu命令用来配置VSI的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VSI的MTU值为1500字节。
VSI视图
VSI下创建VXLAN后,该VSI的MTU值是指从AC上接收且通过VXLAN隧道转发的用户报文的最大长度。VSI内的其他报文不受该MTU值的限制。
如果MTU为缺省值1500或者用户报文长度小于等于MTU值,则不需要对报文进行分片;如果用户报文长度大于MTU值,则需要分片。
# 配置名为vxlan1的VSI的MTU值为1400字节。
[Sysname] vsi vxlan1
[Sysname-vsi-vxlan1] mtu 1400
·     display l2vpn vsi
reset arp suppression vsi命令用来清除VSI的ARP泛洪抑制表项。
reset arp suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ARP泛洪抑制表项。
# 清除所有VSI的ARP泛洪抑制表项。
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
reset l2vpn mac-address命令用来清除通过源MAC地址动态学习的MAC地址表项。
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name:清除指定VSI动态学习的MAC地址表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI动态学习的MAC地址表项。
VSI通过源MAC地址学习到错误的MAC地址表项,或学习的MAC地址表项数目达到最大值时,可以执行本命令,以便重新学习MAC地址表项。
# 清除名为vpn1的VSI通过源MAC地址动态学习的MAC地址表项。
<Sysname> reset l2vpn mac-address vsi vpn1
·     display l2vpn mac-address vsi
selective-flooding mac-addres命令用来配置VSI选择性泛洪的MAC地址。
undo selective-flooding mac-addres命令用来删除VSI的选择性泛洪MAC地址。
selective-flooding mac-addres mac-addres
undo selective-flooding mac-addres mac-addres
不存在VSI选择性泛洪MAC地址。
VSI视图
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
通过flooding disable命令关闭VSI的泛洪功能后,为了将某些MAC地址的数据帧泛洪到远端站点以保证某些业务的流量在站点间互通,可以配置选择性泛洪的MAC地址。当数据帧的目的MAC地址匹配选择性泛洪的MAC地址时,该数据帧可以泛洪到远端站点。
# 在VSI vsi1下配置选择性泛洪的MAC地址为000f-e201-0101。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
·     flooding disable
1.1.16  shutdown
shutdown命令用来关闭当前的VSI。
undo shutdown命令用来开启当前的VSI。
shutdown
VSI处于开启状态。
VSI视图
关闭VSI后,该VSI将不能提供二层交换服务。
关闭VSI功能通常用于暂时禁用二层交换服务,但还需要再次启用该服务的场景。关闭VSI后,该VSI所有已存在的配置保持不变。在关闭状态下还可以对VSI进行配置。VSI再次被开启后,基于最新的配置提供二层交换服务。
# 关闭名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
·     display l2vpn vsi
1.1.17  tunnel
tunnel命令用来配置VXLAN与指定的隧道关联。
undo tunnel命令用来取消VXLAN与指定隧道的关联。
tunnel tunnel-number [ flooding-proxy ]
undo tunnel tunnel-number
VXLAN未关联VXLAN隧道。
VXLAN视图
tunnel-number:隧道接口的编号。指定的隧道必须是VXLAN模式的隧道。
flooding-proxy:开启隧道的泛洪代理功能,即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP。如果未指定本参数,则表示关闭隧道的泛洪代理功能。
在VXLAN组网中,用户可以手工将VXLAN与VXLAN隧道关联。VTEP接收到某个VXLAN的泛洪流量后,如果采用单播路由泛洪方式,则VTEP将在与该VXLAN关联的所有VXLAN隧道上发送该流量,以便将流量转发给所有的远端VTEP。
一个VXLAN可以关联32条VXLAN隧道;一条VXLAN隧道可以关联多个VXLAN。
不能通过重复执行本命令开启或关闭VXLAN隧道的泛洪代理功能。如需修改隧道的泛洪代理功能状态,请先通过undo tunnel命令取消VXLAN与指定隧道的关联,再执行tunnel命令。
一个VSI下可以配置多条开启泛洪代理功能的VXLAN隧道,第一个创建的VXLAN隧道作为主代理隧道,负责转发该VXLAN内的广播、组播和未知单播流量,其他隧道作为备用代理隧道,不转发流量。
# 配置VXLAN隧道Tunne0和Tunnel1与VXLAN 10000关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 0
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
·     display vxlan tunnel
tunnel global source-address命令用来配置VXLAN隧道的全局源地址。
undo tunnel global source-address命令用来恢复缺省情况。
tunnel global source-address ip-address
未配置VXLAN隧道的全局源地址。
ip-address:隧道的全局源IP地址。
如果隧道下未配置源地址或源接口,则隧道会使用全局源地址作为隧道的源地址。
目前仅VXLAN隧道支持全局源地址,其它类型的隧道不支持全局源地址。
# 配置VXLAN隧道的全局源地址为1.1.1.1。
[Sysname] tunnel global source-address 1.1.1.1
1.1.19  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
不存在VSI。
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
VSI是VTEP上为一个VXLAN提供二层交换服务的虚拟交换实例。VSI可以看做是VTEP上的一台基于VXLAN进行二层转发的虚拟交换机,它具有传统以太网交换机的所有功能,包括源MAC地址学习、MAC地址老化、泛洪等。VSI与VXLAN一一对应。
# 创建名为vxlan10的VSI,并进入VSI视图。
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
·     display l2vpn vsi
1.1.20  vxlan
vxlan命令用来创建VXLAN,并进入VXLAN视图。如果指定的VXLAN已经存在,则直接进入VXLAN视图。
undo vxlan命令用来恢复缺省情况。
vxlan vxlan-id
undo vxlan
不存在VXLAN。
VSI视图
vxlan-id:VXLAN ID,取值范围为0~16777215。
在一个VSI下只能创建一个VXLAN。不同VSI下创建的VXLAN,其VXLAN ID不能相同。
# 在名称为vpna的VSI下创建编号为10000的VXLAN,并进入VXLAN视图。
[Sysname] vsi vpna
·     vsi
vxlan invalid-udp-checksum discard命令用来配置丢弃UDP校验和检查失败的VXLAN报文。
undo vxlan invalid-udp-checksum discard命令用来恢复缺省情况。
不会检查VXLAN报文的UDP校验和。
VTEP对二层数据帧进行封装时,将UDP校验和设置为0。缺省情况下,VTEP接收到VXLAN报文后,不会检查报文的UDP校验和。如果在VTEP上执行了本命令,则该VTEP会对接收的VXLAN报文的UDP校验和进行检查,校验和检查失败的报文将被丢弃。
为了兼容其他厂商的设备,UDP校验和为0和UDP校验和正确的报文均能通过VTEP的检查,被VTEP接收。
# 配置丢弃UDP校验和检查失败的VXLAN报文。
[Sysname] vxlan invalid-udp-checksum discard
·     vxlan invalid-vlan-tag discard
vxlan invalid-vlan-tag discard命令用来配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
undo vxlan invalid-vlan-tag discard命令用来恢复缺省情况。
不会检查VXLAN报文内层封装的以太网数据帧是否携带VLAN tag。
如果在VTEP上执行了本命令,则VTEP接收到VXLAN报文并对其解封装后,若内层以太网数据帧带有VLAN tag,则丢弃该VXLAN报文。
远端VTEP上通过xconnect vsi命令的access-mode参数配置接入模式为ethernet时,VXLAN报文可能携带VLAN tag。这种情况下建议不要在本端VTEP上执行vxlan invalid-vlan-tag discard命令,以免错误地丢弃报文。
# 配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
[Sysname] vxlan invalid-vlan-tag discard
·     vxlan invalid-udp-checksum discard
·     xconnect vsi
vxlan local-mac report命令用来开启本地MAC地址的日志记录功能。
undo vxlan local-mac report命令用来关闭本地MAC地址的日志记录功能。
本地MAC地址的日志记录功能处于关闭状态。
执行vxlan local-mac report命令后,VXLAN会立即根据已经学习到的本地MAC地址表项生成日志信息,之后在增加或删除本地MAC地址时也将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 开启本地MAC地址的日志记录功能。
[Sysname] vxlan local-mac report
vxlan tunnel mac-learning disable命令用来关闭远端MAC地址自动学习功能。
undo vxlan tunnel mac-learning disable命令用来开启远端MAC地址自动学习功能。
远端MAC地址自动学习功能处于开启状态。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址可以通过报文中的源MAC地址动态学习。
缺省情况下,设备可以自动学习远端MAC地址。如果网络中存在攻击,为了避免学习到错误的远端MAC地址,可以通过本命令手工关闭远端MAC地址自动学习功能。
# 关闭远端MAC地址自动学习功能。
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port命令用来配置VXLAN报文的目的UDP端口号。
undo vxlan udp-port命令用来恢复缺省情况。
vxlan udp-port port-number
undo vxlan udp-port
VXLAN报文的目的UDP端口号为4789。
port-number:VXLAN报文的目的UDP端口号,取值范围为1~65535。
属于同一个VXLAN的VTEP设备上需要配置相同的UDP端口号。
建议不要将VXLAN报文的目的UDP端口号配置为知名端口,即1~1023之间的端口。
# 配置VXLAN报文的目的UDP端口号为6666。
[Sysname] vxlan udp-port 6666
1.1.26  xconnect vsi
xconnect vsi命令用来将AC与VSI关联。
undo xconnect vsi命令用来恢复缺省情况。
xconnect vsi vsi-name [ track track-entry-number&<1-3> ]
undo xconnect vsi
AC未关联VSI。
track track-entry-number&<1-3>:配置AC与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在接口视图下执行本命令后,从接口接收到的报文将通过查找关联VSI的MAC地址表进行转发。
# 在接口GigabitEthernet1/0/1下关联名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
·     display l2vpn interface
·     vsi
1.2  VXLAN IP网关配置命令
1.2.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VSI虚接口视图
bandwidth-value:接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口VSI-interface100的期望带宽为10000kbps。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
1.2.2  default
default命令用来恢复当前接口的缺省配置。
default
VSI虚接口视图
# 将接口VSI-interface100恢复为缺省配置。
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
1.2.3  description
description命令用来配置当前接口的描述信息。
接口的描述信息为“接口名 Interface”,例如:Vsi-interface100 Interface。
VSI虚接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
当设备上存在多个接口时,可以根据接口的连接信息或用途来配置接口的描述信息,以便区别和管理各接口。
本命令仅用于标识某接口,并无特别的功能。使用display interface等命令可以看到设置的描述信息。
# 配置接口VSI-interface100的描述信息为“gateway for VXLAN 10”。
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface命令用来显示VSI虚接口的相关信息。
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface-id:VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则不会根据接口物理状态来过滤显示信息。
如果不指定接口类型(vsi-interface),将显示设备支持的所有接口的相关信息。
如果指定接口类型,不指定接口编号(vsi-interface-id),则显示所有VSI虚接口的信息。
如果同时指定接口类型和接口编号,则显示指定VSI虚接口的信息。
# 显示接口VSI-interface100的相关信息。
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
表1-8 display interface vsi-interface命令显示信息描述表
Vsi-interface100
Current state
接口的物理状态和管理状态,取值包括:
·     DOWN:该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·     UP:表示该接口的链路层协议状态为开启
·     UP(spoofing):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
·     DOWN:表示该接口的链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口当前不能处理IP报文
Internet address
接口的主IP地址
IP报文发送帧格式
hardware address
硬件地址
IPv6报文发送帧格式
Physical
接口的物理类型,取值为Unknown
baudrate
接口的波特率,单位为kbps
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直未执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数,总计输出的字节,总计丢弃的输出报文数
# 显示所有VSI虚接口的概要信息。
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# 显示接口VSI-interface100的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface vsi-interface 100 brief description
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# 显示当前状态为down的接口的信息以及DOWN的原因。
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
表1-9 display interface vsi-interface brief命令显示信息描述表
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口。
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值包括:
·     UP:表示本链路物理上是连通的
·     DOWN:表示本链路物理上是不通的
·     ADM:表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
·     Stby:表示该接口是一个备份接口。
Protocol
接口的链路层协议状态,取值包括:
·     UP (s):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有VSI关联该接口,或者关联该接口的VSI内没有AC或PW.
·     reset counters interface
distributed-gateway local命令用来配置VSI虚接口为分布式网关接口。
undo distributed-gateway local命令用来恢复缺省情况。
VSI虚接口不是分布式网关接口。
VSI虚接口视图
在分布式VXLAN IP网关组网中,多个网关上同一VXLAN的VSI虚接口需要配置相同的IP地址。为了避免IP地址冲突,需要在VSI虚接口上执行本命令,以防止VSI虚接口上报地址冲突,导致VSI虚接口不可用。
# 配置接口Vsi-interface100为分布式网关接口。
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet命令用来配置VSI所属的子网网段。
undo gateway subnet命令用来删除VSI所属的子网网段。
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
未指定VSI所属的子网网段。
VSI视图
ipv4-address:IPv4子网网段地址,为点分十进制格式。
wildcard-mask:IPv4地址掩码的反码,即将IPv4地址的掩码取反(0变1,1变0)。例如:子网掩码255.0.0.0的反码为0.255.255.255。其中,反码中的“1”表示忽略IPv4地址中对应的位,“0”表示必须保留此位。
ipv6-address prefix-length:IPv6地址及前缀长度。prefix-length为IPv6前缀长度,取值范围为1~128。
为了节省分布式VXLAN IP网关设备上的三层接口资源,在网关设备上多个VXLAN可以共用一个VSI虚接口,为VSI虚接口配置一个主IPv4地址和多个从IPv4地址、或多个IPv6地址,分别作为不同VXLAN内虚拟机的网关地址。
多个VXLAN共用一个VSI虚接口时,网关设备无法判断从VSI虚接口接收到的报文属于哪个VXLAN。为了解决该问题,需要在VSI视图下通过本命令指定VSI所属的子网网段,通过子网网段判断报文所属的VSI,并在该VSI内转发报文,从而限制广播报文范围,有效地节省带宽资源。但是每个VXLAN都有各自的IP地址子网网段以及网关IP,因此需要VSI虚接口支持按VXLAN设置子网网段。
一个VSI视图下最多可以配置8个子网网段,包括IPv4子网和IPv6子网。
在VSI视图下配置子网网段前,必须先为该VSI指定网关接口。取消为VSI指定网关接口时,会自动删除为该VSI指定的子网网段。
不能为指定了相同网关接口的不同VSI配置相同的子网网段。
# 配置名称为vxlan的VSI所属的子网网段为100.0.10.0/24。
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface命令用来为VSI指定网关接口。
undo gateway vsi-interface命令用来恢复缺省情况。
gateway vsi-interface vsi-interface-id
未指定VSI的网关接口。
VSI视图
vsi-interface-id:VSI网关虚接口的编号,接口编号的取值范围为0~8191。
一个VSI只能指定一个网关接口。
不同的VSI可以指定相同的网关接口。
# 为VSI指定网关接口为Vsi-interface100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
·     interface vsi-interface
interface vsi-interface命令用来创建VSI虚接口,并进入VSI虚接口视图。如果指定的VSI虚接口已经存在,则直接进入VSI虚接口视图。
undo interface vsi-interface命令用来删除指定的VSI虚接口。
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
不存在VSI虚接口。
vsi-interface-id:VSI虚接口的编号。
设备各款型对于本节所描述的参数的支持情况有所不同,详细差异信息如下:
型号
参数
ICG2000D
vsi-interface-id
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
ICG 3000S
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
ICG3000F/3000F-DP
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
ICG 5000G/5000T
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
ICG 6000
接口编号的取值范围为0~8191;
最多支持创建1024个VSI虚接口
# 创建VSI虚接口100,并进入VSI虚接口视图。
·     gateway vsi-interface
1.2.9  mac-address
mac-address命令用来配置VSI虚接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
缺省情况下,VSI虚接口未指定MAC地址。
VSI虚接口视图
mac-address:MAC地址,形式为H-H-H。
# 配置VSI虚接口100的MAC地址为0001-0001-0001。
[Sysname-Vsi-interface100] mac-address 1-1-1
1.2.10  mtu
mtu命令用来配置接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
缺省情况下,接口的MTU值为1500字节。
VSI虚接口视图
# 配置接口VSI-interface100的MTU值为1430字节。
[Sysname-Vsi-interface100] mtu 1430
reset counters interface vsi-interface命令用来清除VSI虚接口的统计信息。
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
如果不指定接口类型(vsi-interface),则清除所有接口的统计信息;
如果指定接口类型,不指定接口编号(vsi-interface-id),则清除所有VSI虚接口的统计信息;
如果同时指定接口类型和接口编号,则清除指定VSI虚接口的统计信息。
# 清除接口VSI-interface100的统计信息。
<Sysname> reset counters interface vsi-interface 100
·     display interface
1.2.12  shutdown
shutdown命令用来关闭当前接口。
undo shutdown命令用来开启当前接口。
shutdown
VSI虚接口均处于开启状态。
VSI虚接口视图
# 关闭接口VSI-interface100。
[Sysname-Vsi-interface100] shutdown
vtep group member local命令用来将本设备加入VXLAN IP网关保护组,并配置本设备的成员地址。
undo vtep group member local命令用来取消本设备加入指定的VXLAN IP网关保护组。
vtep group group-ip member local member-ip
undo vtep group group-ip member local
设备未加入VXLAN IP网关保护组。
group-ip:VXLAN IP网关保护组的VTEP IP地址,该地址必须是本设备上已经存在的地址。
member-ip:本设备在VXLAN IP网关保护组内的成员地址,该地址必须是设备上已经配置的地址。
成员地址不能和保护组的VTEP IP相同;同一个保护组中不同成员的成员地址也不能相同。
# 配置本设备加入VXLAN IP保护组,保护组的VTEP IP地址是1.1.1.1,本设备的成员地址为2.2.2.2。
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
·     vtep group member remote
vtep group member remote命令用来配置VXLAN IP网关保护组的成员地址列表。
undo vtep group member remote命令用来删除指定VXLAN IP网关保护组的成员地址列表。
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
未配置VXLAN IP网关保护组的成员地址列表。
group-ip:VXLAN IP网关保护组的VTEP IP地址。
member-ip&<1-8>:VXLAN IP网关保护组成员IP地址列表。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
# 配置VXLAN IP网关保护组1.1.1.1包含的成员设备为2.2.2.2、3.3.3.3和4.4.4.4。
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
·     vtep group member local
vxlan tunnel arp-learning disable命令用来关闭远端ARP自动学习功能。
undo vxlan tunnel arp-learning disable命令用来开启远端ARP自动学习功能。
远端ARP自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ARP信息,即远端ARP信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel arp-learning disable命令暂时关闭远端ARP自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel arp-learning disable命令开启远端ARP自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel arp-learning disable命令。
# 关闭远端ARP自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
1.3  ENDP配置命令
display vxlan neighbor-discovery client member命令用来在ENDC上显示ENDC学到的邻居信息。
display vxlan neighbor-discovery client member [ interface tunnel interface-number | local local-ip remote client-ip | server server-ip ]
interface tunnel interface-number:显示通过指定NVE隧道接口学到的邻居信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
local local-ip:显示通过源端地址为指定IP地址的NVE隧道接口学到的邻居信息。local-ip表示NVE隧道接口的源端地址,即本地ENDC的IP地址。
remote client-ip:显示设备学到的指定邻居ENDC的信息。client-ip表示邻居ENDC的IP地址。
server server-ip:显示通过指定ENDS学到的邻居信息。server-ip表示ENDS的IP地址。
通过本命令可以查看ENDC学到的邻居信息,包括邻居的IP地址、桥MAC地址、创建时间、老化时间、邻居之间的VXLAN隧道状态等信息。
如果不指定任何参数,将显示ENDC学到的所有邻居信息。
# 显示ENDC学到的所有邻居的信息。
<Sysname> display vxlan neighbor-discovery client member
Interface: Tunnel0    Network ID: 1    Vpn-instance: [No Vrf]
Local Address: 1.1.1.1
Server Address: 1.1.1.1
Neighbor        System ID         Created Time           Expire    Status
2.2.2.2         0002-0000-0000    2014/08/01 03:39:38    71        Up
3.3.3.3         0003-0000-0000    2014/08/01 03:42:38    71        Up
表1-10 display vxlan neighbor-discovery client member命令显示信息描述表
启动ENDC功能的接口名称
Network ID
隧道的Network ID
Vpn-instance
VPN实例
Local Address
NVE隧道接口的源端地址
Server Address
ENDS的IP地址,NA表示ENDS未知
Neighbor
通过ENDS学到的邻居IP地址
System ID
邻居的桥MAC地址,NA表示桥MAC地址未知
Created Time
邻居创建的时间
Expire
邻居的老化时间,单位为秒
Status
与邻居之间VXLAN 隧道的状态:
·     Up:表示可以通过VXLAN隧道进行传输
·     Down:表示不可以通过VXLAN隧道进行传输
·     NA:表示尚未创建VXLAN隧道
display vxlan neighbor-discovery client statistics命令用来在ENDC上显示ENDC的统计信息。
display vxlan neighbor-discovery client statistics interface tunnel interface-number
interface tunnel interface-number:显示指定NVE隧道接口对应的ENDC的统计信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
通过本命令可以查看开启ENDC功能后,接口收到和发送ENDP报文的统计信息。
# 显示NVE隧道接口Tunnel0对应的ENDC的统计信息。
<Sysname> display vxlan neighbor-discovery client statistics interface tunnel 0
Server Address: 10.0.0.1    Vpn-instance: [No Vrf]
Received packets:
  Reply:        170              Error:      1
Sent packets:
  Register:     170              Purge:      0
Server Address: 10.0.0.2
Received packets:
  Reply:        99               Error:      1
Sent packets:
  Register:     100              Purge:      0
表1-11 display vxlan neighbor-discovery client statistics命令显示信息描述表
Server Address
ENDC对应的ENDS的IP地址
Vpn-instance
VPN实例
Received packets
ENDC收到的报文统计信息:
·     Reply:表示注册应答报文
·     Error:表示错误指示报文
Sent packets
ENDC发送的报文统计信息:
·     Register:表示注册报文
·     Purge:表示注销报文
display vxlan neighbor-discovery client summary命令用来在ENDC上显示ENDC的运行信息。
通过本命令可以查看ENDC的运行信息,包括ENDC的配置信息、ENDC与ENDS的连接状态。
# 显示ENDC的运行信息。
<Sysname> display vxlan neighbor-discovery client summary
                         Status: I-Init  E-Establish  P-Probe
Interface    Local Address   Server Address  Network ID  Reg  Auth      Status   VPN Instance
Tunnel0      20.0.0.2        20.0.0.1        1           15   enabled   E   [No Vrf]
Tunnel0      20.0.0.2        20.0.0.3        1           15   enabled   P   [No Vrf]
Tunnel1      21.0.0.2        21.0.0.1        2           15   disabled  P   [No Vrf]
表1-12 display vxlan neighbor-discovery client summary命令显示信息描述表
启动ENDC功能的接口名称
Local Address
本地NVE隧道接口的源端地址,NA表示未配置
Server Address
ENDS的IP地址
Network ID
隧道的Network ID,NA表示未配置
Reg
注册时间间隔,单位为秒
Auth
是否开启认证功能:
·     enabled:表示已开启
·     disabled:表示未开启
Status
ENDC与ENDS的连接状态:
·     I:表示初始状态
·     E:表示已建立连接
·     P:表示未建立连接正在探测
Vpn-instance
VPN实例
·     vxlan neighbor-discovery authentication
·     vxlan neighbor-discovery client enable
·     vxlan neighbor-discovery client register-interval
display vxlan neighbor-discovery server member命令用来在ENDS上显示ENDS学到的成员信息。
display vxlan neighbor-discovery server member [ interface tunnel interface-number | local local-ip | remote client-ip ]
interface tunnel interface-number:显示通过指定NVE隧道接口学到的成员信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
local local-ip:显示指定ENDS学到的成员信息。local-ip表示本地ENDS的IP地址。
remote client-ip:显示ENDS学到的指定IP地址的成员信息。client-ip表示ENDC的IP地址。
通过本命令可以查看ENDS学到的成员信息,包括成员的IP地址、桥MAC地址、创建时间、老化时间等信息。
如果不指定任何参数,将显示ENDS学到的所有成员信息。
# 显示ENDS学到的所有成员的信息。
<Sysname> display vxlan neighbor-discovery server member
IP Address: 1.1.1.1
Client Address  System ID         Expire    Created Time
1.1.1.1         0001-0000-0000    72        2014/08/01 03:34:22
2.2.2.2         0002-0000-0000    66        2014/08/01 03:39:24
3.3.3.3         0003-0000-0000    72        2014/08/01 03:42:34
表1-13 display vxlan neighbor-discovery server member命令显示信息描述表
启动ENDS功能的接口名称
Network ID
隧道的Network ID
Vpn-instance
VPN实例
IP Address
ENDS的IP地址
Client Address
学到的成员的IP地址
System ID
学到的成员的桥MAC地址
Expire
成员的剩余老化时间,单位为秒
Created Time
成员的创建时间
display vxlan neighbor-discovery server statistics命令用来在ENDS上显示ENDS的统计信息。
display vxlan neighbor-discovery server statistics interface tunnel interface-number
interface tunnel interface-number:显示指定NVE隧道接口对应的ENDS的统计信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
通过本命令可以查看开启ENDS功能后,接口收到和发送报文的统计信息。
# 显示NVE隧道接口Tunnel0对应的ENDS的统计信息。
<Sysname> display vxlan neighbor-discovery server statistics interface tunnel 0
Received packets:
  Register:     170              Purge:      13
Sent packets:
  Reply:        170              Error:      1
表1-14 display vxlan neighbor-discovery server statistics命令显示信息描述表
Received packets
ENDS收到的报文统计信息:
·     Register:表示注册报文
·     Purge:表示注销报文
Sent packets
ENDS发送的报文统计信息:
·     Reply:表示注册应答报文
·     Error:表示错误指示报文
display vxlan neighbor-discovery server summary命令用来在ENDS上显示ENDS的运行信息。
通过本命令可以查看ENDS的运行信息,包括ENDS的配置信息、通过该ENDS学习到的ENDC个数。
# 显示ENDS的运行信息。
<Sysname> display vxlan neighbor-discovery server summary
Interface      Local Address   Network ID    Auth        Members   VPN Instance
Tunnel0        20.0.0.1        1             enabled     10        [No Vrf]
Tunnel2        21.0.0.1        2             disabled    20        [No Vrf]
Tunnel3        22.0.0.1        NA            disabled    0         [No Vrf]
表1-15 display vxlan neighbor-discovery server summary命令显示信息描述表
启动ENDS功能的接口名称
Local Address
接口的源端地址,NA表示未配置
Network ID
Auth
是否开启认证功能:
·     enabled:表示已开启
·     disabled:表示未开启
Members
通过该ENDS学习到的ENDC个数
Vpn-instance
VPN实例
·     vxlan neighbor-discovery server enable
1.3.7  network-id
network-id命令用来配置隧道的Network ID。
Undo network-id命令用来恢复缺省情况。
network-id network-id
undo network-id
未配置隧道的Network ID。
NVE模式Tunnel接口视图
number:Network ID值,取值范围为1~16777215。
VXLAN通过ENDP来自动发现远端VTEP。ENDP可以划分为多个实例,通过Network ID来标识ENDP实例。只有属于同一个ENDP实例的VTEP之间可以互相发现。
同一台设备的不同Tunnel接口下必须配置不同的Network ID。
# 配置NVE隧道Tunnel0的Network ID为123。
[Sysname] interface tunnel 0 mode nve
[Sysname-Tunnel0] network-id 123
vxlan neighbor-discovery authentication命令用来开启ENDP认证功能。
Undo vxlan neighbor-discovery authentication命令用来关闭ENDP认证功能。
vxlan neighbor-discovery authentication { cipher | simple } string
undo vxlan neighbor-discovery authentication
ENDP认证功能处于关闭状态。
NVE模式Tunnel接口视图
cipher:表示以密文方式设置密钥。
Simple:表示以明文方式设置密钥,该密钥将以密文形式存储。
String:密钥字符串,区分大小写。明文密钥为1~24个字符的字符串,密文密钥为1~65个字符的字符串。
为了安全起见,可以配置ENDP认证功能来防止恶意的节点注册到VXLAN网络。只有本端与对端设备上都未配置ENDP认证功能,或者都配置了认证功能且密钥相同,才能在二者之间成功建立VXLAN隧道。
开启ENDP认证功能后,发送ENDP报文的设备会使用配置的密钥和MD5算法对报文进行摘要运算,然后把运算结果放到报文的认证字段。对端设备收到ENDP报文后,利用本端配置的密钥和MD5算法对报文进行摘要运算,然后比较运算结果与报文认证字段携带的信息是否一致,如果一致则认为报文合法,如果不一致则认为报文非法。
在一个安全的网络中,可以不配置ENDP认证功能。
同一个VXLAN网络中所有的ENDS与ENDC必须配置相同的密钥。
# 开启ENDP认证功能,并以明文方式设置密钥为vxlan-a。
[Sysname-Tunnel0] vxlan neighbor-discovery authentication simple vxlan-a
·     display vxlan neighbor-discovery client summary
·     display vxlan neighbor-discovery server summary
vxlan neighbor-discovery client enable命令用来开启接口的ENDC功能,并指定ENDS地址。
Undo vxlan neighbor-discovery client enable命令用来关闭接口的ENDC功能。
vxlan neighbor-discovery client enable server-ip
undo vxlan neighbor-discovery client enable server-ip
ENDC功能处于关闭状态。
NVE模式Tunnel接口视图
server-ip:ENDC要连接的ENDS的IP地址。
为了防止ENDS异常导致ENDC不能加入VXLAN网络,用户可以通过重复执行本命令为每个ENDC指定两个ENDS。ENDC同时向两个ENDS注册和获取ENDC信息。
建议为地址相同、Network ID不同的ENDC指定不同的ENDS。
# 开启ENDC功能,并指定ENDS地址为11.0.0.1。
[Sysname-Tunnel0] vxlan neighbor-discovery client enable 11.0.0.1
vxlan neighbor-discovery client register-interval命令用来配置ENDC向ENDS注册的时间间隔。
Undo vxlan neighbor-discovery client register-interval命令用来恢复缺省情况。
vxlan neighbor-discovery client register-interval interval
undo vxlan neighbor-discovery client register-interval
ENDC向ENDS注册的时间间隔为15秒。
NVE模式Tunnel接口视图
interval:注册时间间隔,取值范围为5~120,单位为秒。
ENDP协议中定义了3个定时器:探测定时器、注册定时器、老化定时器。
·     探测定时器
ENDC请求加入VXLAN网络时会启用探测定时器,该定时器以5秒的时间间隔定时向ENDS发送注册报文,收到ENDS应答报文后会停止探测定时器。
·     注册定时器
ENDC加入VXLAN网络后,为了通告自己工作正常,会定时向ENDS发送注册报文,该定时器的默认时间间隔为15秒,用户可以通过配置vxlan neighbor-discovery client register-interval命令来调整该时间间隔。
如果ENDC连续发送5个注册报文,都未能收到ENDS的应答报文,则认为网络故障,此时需要清除之前学到的邻居信息,同时重新启用探测定时器。
·     老化定时器
ENDC向ENDS发送的注册报文中携带注册时间间隔,ENDS会记录该时间间隔。
ENDC加入VXLAN网络后,如果ENDS在5倍的注册时间内未收到ENDC的注册报文则认为ENDC出现故障,此时需要把ENDC从VXLAN网络中删除。
# 配置ENDC向ENDS注册的时间间隔为30秒。
[Sysname-Tunnel0] vxlan neighbor-discovery client register-interval 30
vxlan neighbor-discovery server enable命令用来开启接口的ENDS功能。
Undo vxlan neighbor-discovery server enable命令用来关闭接口的ENDS功能。
undo vxlan neighbor-discovery server enable
ENDS功能处于关闭状态。
NVE模式Tunnel接口视图
开启接口的ENDS功能时,会同时开启该接口的ENDC功能(该ENDC对应的ENDS地址为该接口的源地址)。
# 开启ENDS功能。
[Sysname-Tunnel0] vxlan neighbor-discovery server enable
1.4  VXLAN IS-IS配置命令
display vxlan isis brief命令用来显示VXLAN IS-IS进程的摘要信息。
# 显示VXLAN IS-IS进程的摘要信息。
<Sysname> display vxlan isis brief
Network-entity: 00.0011.2200.0001.00
LSP-length receive: 1400
LSP-length originate: 1400
Timers:
  LSP-max-age: 1200s
  LSP-refresh: 900s
State: Enabled
表1-16 display vxlan isis brief命令显示信息描述表
Network-entity
网络实体名称
LSP-length receive
可以接收LSP的最大长度
生成的LSP的最大长度
Timers
LSP相关定时器
LSP-max-age
LSP的最大生存时间,单位为秒
LSP-refresh
LSP的刷新周期,单位为秒
VXLAN IS-IS进程的运行状态,取值包括:
·     Enabled:表示VXLAN IS-IS进程处于开启状态,即已经开启VXLAN IS-IS的MAC地址同步功能或VXLAN自动协商功能
·     Disabled:表示VXLAN IS-IS进程处于关闭状态,即尚未开启VXLAN IS-IS的MAC地址同步功能和VXLAN自动协商功能
display vxlan isis graceful-restart status命令用来显示VXLAN IS-IS协议的GR状态。
# 显示VXLAN IS-IS协议的GR状态。
<Sysname> display vxlan isis graceful-restart status
Restart status: RESTARTING
Restart phase: LSDB synchronization
Restart interval: 300s
T3 remaining time: 65531s
Total number of interfaces: 1
Number of waiting LSPs: 0
T2 remaining time: 56s
  Interface: Tunnel0
    T1 remaining time: 2
    RA received: N
    CSNP received: N
    T1 expired number: 3
表1-17 display vxlan isis graceful-restart status命令显示信息描述表
Restart status
重启状态,取值包括:
·     COMPLETE:重启完成
·     STARTING:重启开始
·     RESTARTING:重启中
·     UNKNOWN:未知状态
Restart phase
重启阶段,取值包括:
·     Initialization:初始阶段
·     LSDB synchronization:LSDB同步阶段
·     MAC receiving:接收本地MAC地址上报的阶段
·     LSP stable:LSP生成的阶段
·     LSP generation:LSP刷新和泛洪的阶段
·     Finish:GR完成的阶段
·     Unknown:未知阶段
Restart interval
重启间隔时间,单位为秒
重启间隔时间即T2定时器的值,用来控制LSDB同步时间。如果在GR重启间隔时间内未完成LSDB同步,则GR失败,退出GR过程
该值可以通过graceful-restart interval命令设置
T3 remaining time
定时器T3的剩余时间,单位为秒
在T3定时器内邻居不会断掉与重启设备的邻接关系。如果T3定时器超时后GR还未完成,则GR失败
T3定时器的值不可配置
VXLAN IS-IS进程下的接口数
GR Restarter与GR Helper进行LSDB同步时,未完成同步的LSP数目
T2 remaining time
定时器T2的剩余时间,单位为秒
T2定时器用来控制LSDB的同步时间
指定接口下VXLAN IS-IS协议的GR状态
T1 remaining time
定时器T1的剩余时间,单位为秒
T1定时器用来控制带RR(Restart Request,Restart请求)标志位的Hello报文的重传时间。如果在T1定时器内未接收到对端回复的带有RA(Restart Acknowledgement,Restart应答)标志的Hello报文,则重传带RR标志位的Hello报文
T1定时器的值不可配置
RA received
接口上是否收到邻居发送的带RA标志位的Hello报文
CSNP received
接口上是否收到完整的CSNP报文,即是否完成与GR Helper的LSDB同步
T1 expired number
定时器T1的超时次数,超时达到10次后,不会再进行带RR标志位的Hello报文的重传
display vxlan isis local-host命令用来显示VXLAN IS-IS的本地主机路由信息。
display vxlan isis local-host [ ipv6 ] [ vxlan-id vxlan-id ] [ count ]
ipv6:显示本地Ipv6主机路由信息。如果不指定本参数,将显示本地Ipv4主机路由信息。
Vxlan-id vxlan-id:显示指定VXLAN的本地主机路由信息。Vxlan-id表示VXLAN编号,取值范围为0~16777215。如果不指定本参数,将显示所有VXLAN的本地主机路由信息。
Count:显示本地主机路由信息的数目。
# 显示所有VXLAN的VXLAN IS-IS本地Ipv4主机路由信息。
<Sysname> display vxlan isis local-host
VXLAN ID  IP address                MAC address
1         192.168.56.1              0800-2700-249b
2         192.168.56.2              0800-2700-249c
# 显示所有VXLAN的VXLAN IS-IS本地Ipv6主机路由信息。
<Sysname> display vxlan isis local-host ipv6
1         200:200::100:200          0000-0000-0001
2         200:200::100:300          0000-0000-0002
# 显示所有VXLAN的本地Ipv4主机路由的数目。
<Sysname> display vxlan isis local-host count
5 entries found.
# 显示所有VXLAN的本地Ipv6主机路由的数目。
<Sysname> display vxlan isis local-host ipv6 count
5 entries found.
表1-18 display vxlan isis local-host显示信息描述表
VXLAN ID
VXLAN编号
IP address
主机的Ipv4地址或Ipv6地址
MAC address
主机的MAC地址
5 entries found
本地主机路由的数目,本例中本地主机路由的数目为5
display vxlan isis local-mac命令用来显示VXLAN IS-IS的本地MAC地址信息。
display vxlan isis local-mac dynamic [ [ vxlan-id vxlan-id ] [ count ] ]
dynamic:显示本地动态MAC地址信息。
Vxlan-id vxlan-id:显示指定VXLAN的本地MAC地址信息。Vxlan-id表示VXLAN编号,取值范围为0~16777215。如果不指定本参数,将显示所有VXLAN的本地MAC地址信息。
Count:显示本地MAC地址的数目。
# 显示所有VXLAN IS-IS的本地动态MAC地址信息。
<Sysname> display vxlan isis local-mac dynamic
  VXLAN ID: 100
    MAC address: 00aa-00bb-00cc
    MAC address: 00aa-00cc-00bb
    MAC address: 00cc-00aa-00bb
  VXLAN ID: 50
    MAC address: 00bb-00aa-00cc
    MAC address: 00bb-00cc-00aa
# 显示VXLAN IS-IS的本地动态MAC地址的数目。
<Sysname> display vxlan isis local-mac dynamic count
5 MAC addresses found.
表1-19 display vxlan isis local-mac命令显示信息描述表
VXLAN ID
VXLAN编号
MAC address
MAC地址
本地MAC地址的数目,本例中本地MAC地址的数目为5
display vxlan isis lsdb命令用来显示VXLAN IS-IS的链路状态数据库。
display vxlan isis lsdb [ local | lsp-id lsp-id | verbose ] * [ tunnel tunnel-number ]
local:显示当前设备产生的LSP的信息。
Lsp-id lsp-id:显示指定LSP的信息。Lsp-id为LSP标识,形式为SYSID.Pseudonode ID-fragment num,其中,SYSID是产生该LSP的节点或伪节点的System ID,Pseudonode ID是伪节点ID,fragment num是该LSP的分片号。
Verbose:显示链路状态数据库中的LSP的详细信息。如果不指定本参数,将显示链路状态数据库中的LSP的摘要信息。
Tunnel tunnel-number:显示指定Tunnel接口下的LSP信息。Tunnel-number为隧道接口的编号,取值范围为0~10239。
# 显示VXLAN IS-IS链路状态数据库的摘要信息。
<Sysname> display vxlan isis lsdb
          Link state database information for VXLAN ISIS (Tunnel 0)
LSP ID                   Seq num     Checksum  Holdtime  Length    Overload
0011.2200.0201.0000-00   0x00000063  0x1bc2    1104      74        0
0011.2200.0401.0000-00*  0x00000060  0x7f76    1089      55        0
0011.2200.0401.0001-00*  0x0000005f  0xf77     1175      57        0
Flags: *-Self LSP, +-Self LSP(Extended)
# 显示VXLAN IS-IS链路状态数据库的详细信息。
<Sysname> display vxlan isis lsdb verbose
LSP ID: 0011.2200.0201.0000-00
Sequence number: 0x00000063
Checksum: 0x1bc2
Holdtime: 745s
Length: 74
Overload: 0
Source: 0011.2200.0201.0000
Neighbour
    ID: 0011.2200.0401.0001, Cost: 10
VXLANs:
    VXLAN ID: 100
    VXLAN ID: 10
MAC addresses:
  VXLAN ID: 10   Confidence: 1
    0001-0001-0001
LSP ID: 0011.2200.0401.0000-00*
Sequence number: 0x00000060
Checksum: 0x7f76
Holdtime: 730s
Length: 55
Overload: 0
Source: 0011.2200.0401.0000
Neighbour
VXLANs:
    VXLAN ID: 10
LSP ID: 0011.2200.0401.0001-00*
Sequence number: 0x0000005f
Checksum: 0xf77
Holdtime: 816s
Length: 57
Overload: 0
Source: 0011.2200.0401.0001
Neighbour
    ID: 0011.2200.0201.0000, Cost: 0
    ID: 0011.2200.0401.0000, Cost: 0
表1-20 display vxlan isis lsdb命令显示信息描述表
Link state database information for VXLAN IS-IS (Tunnel 1)
Tunnel1上VXLAN IS-IS的链路状态数据库信息
LSP ID
链路状态报文ID
·     带*号表示是本地生成的、原始系统LSP
·     带+号表示是本地生成的、虚拟系统LSP(LSP扩展分片)
Sequence number
LSP序列号
Checksum
LSP校验和
Holdtime
LSP生存时间,随着时间推移递减,单位为秒
Length
LSP长度
Overload
LSP中Overload bit的置位情况。1表示置位,0表示未置位
Source
LSP生成路由器的System ID
Neighbour
LSP生成路由器的邻居信息
ID
邻居的System ID
Cost
LSP生成路由器和邻居之间链路的开销值
VXLANs
LSP中包含的VXLAN信息
VXLAN ID
通过LSP发布的VXLAN的编号
MAC addresses
LSP中包含的MAC地址信息
VXLAN ID
MAC地址所属的VXLAN的编号
Confidence
可信度,取值为0表示可信,取值为1表示不可信。当MAC地址出现冲突时,优选可信度为0的MAC地址
display vxlan isis peer命令用来显示VXLAN IS-IS的邻居信息。
# 显示VXLAN IS-IS的邻居信息。
<Sysname> display vxlan isis peer
System ID: 0011.2200.0201
Link interface: Tunnel1
Circuit ID: 0011.2200.0401.0001
State: Up
Hold time: 26s
Neighbour DED priority: 64
Uptime: 00:01:24
表1-21 display vxlan isis peer命令显示信息描述表
System ID
邻居的系统ID
Link interface
与对端相连的本地Tunnel接口
Circuit ID
链路ID
邻居状态,取值包括:
·     Init:邻居初始化
·     Up:邻接关系建立
·     Down:邻接关系断开
Hold time
存活时间,随着时间推移递减,单位为秒
如果在存活时间内还未收到邻居发送的Hello报文,则认为邻居已经失效,如果收到了Hello报文,则存活时间将重置为初始值
Neighbour DED Priority
邻居接口DED优先级,DED优先级数值高的设备被选为DED
Uptime
邻居关系保持的时间
display vxlan isis remote-host命令用来显示通过VXLAN IS-IS学习到的远端主机路由信息。
display vxlan isis remote-host [ ipv6 ] [ vxlan-id vxlan-id ] [ count ]
ipv6:显示远端IPv6主机路由信息。如果不指定本参数,将显示远端IPv4主机路由信息。
vxlan-id vxlan-id:显示指定VXLAN的远端主机路由信息。vxlan-id表示VXLAN编号,取值范围为0~16777215。如果不指定本参数,将显示所有VXLAN的远端主机路由信息。
count:显示远端主机路由信息的数目。
# 显示通过VXLAN IS-IS学习到的所有远端IPv4主机路由信息。
<Sysname> display vxlan isis remote-host
Host Flags: A-Received on an active tunnel interface.
            C-In conflict with a local host route.
            F-Flushed to the remote host route table.
VXLAN  IP address          MAC address    Tunnel  Interface    Flag
1       6.6.6.1            0000-0000-0001 Tunnel1 Vsi1         AF
1       6.6.6.2            0000-0000-0002 Tunnel1 Vsi1         AF
# 显示通过VXLAN IS-IS学习到的所有远端IPv4主机路由的数目。
<Sysname> display vxlan isis remote-host count
1 entries found.
表1-22 display vxlan isis remote-host命令显示信息描述表
VXLAN
VXLAN编号
IP address
远端主机的IPv4地址或IPv6地址
MAC address
远端主机的MAC地址
Tunnel
远端主机路由信息对应的Tunnel接口
远端主机路由信息所属VSI绑定的VSI虚接口
Flags
VXLAN IS-IS远端主机路由信息的标记,取值包括:
·     A:该主机路由信息从有效的Tunnel接口接收到
·     C:该主机路由信息与VXLAN IS-IS本地主机路由信息冲突
·     F:该主机路由信息已经下发到远端主机路由信息表
1 entries found
远端主机路由信息的数目,本例中远端主机路由的数目为1
display vxlan isis remote-mac命令用来显示通过VXLAN IS-IS学习到的远端MAC地址信息。
display vxlan isis remote-mac [ [ vxlan-id vxlan-id ] [ count ] ]
vxlan-id vxlan-id:显示指定VXLAN的远端MAC地址信息。vxlan-id表示VXLAN编号,取值范围为0~16777215。如果不指定本参数,将显示所有VXLAN的远端MAC地址信息。
count:显示远端MAC地址的数目。
# 显示通过VXLAN IS-IS学习到的所有远端MAC地址信息。
<Sysname> display vxlan isis remote-mac
MAC Flags: A-MAC received on an active tunnel interface.
           C-MAC conflict with local dynamic MAC.
           F-MAC has been flushed to the remote MAC address table.
  VXLAN ID: 10
    MAC address: 0001-0001-0001
      Interface: Tunnel1
          Flags: AF
# 显示通过VXLAN IS-IS学习到的所有远端MAC地址的数目。
<Sysname> display vxlan isis remote-mac count
1 MAC addresses found.
表1-23 display vxlan isis remote-mac命令显示信息描述表
VXLAN ID
VXLAN的编号
MAC address
远端MAC地址对应的Tunnel接口
Flags
VXLAN IS-IS远端MAC地址标记,取值包括:
·     A:该MAC地址从有效的Tunnel接口接收到
·     C:该MAC地址与VXLAN IS-IS本地动态MAC地址冲突
·     F:该MAC地址已经下发到远端MAC地址表
1 MAC address(es) found
远端MAC地址的数目,本例中远端MAC地址的数目为1
display vxlan isis remote-vxlan命令用来显示通过VXLAN IS-IS学习到的远端VXLAN信息。
display vxlan isis remote-vxlan [ vxlan-id | count ]
vxlan-id:显示指定远端VXLAN的信息。vxlan-id表示VXLAN编号,取值范围为0~16777215。如果不指定本参数,将显示所有VXLAN的信息。
count:显示远端VXLAN的数目。
# 显示通过VXLAN IS-IS学习到的所有远端VXLAN的信息。
<Sysname> display vxlan isis remote-vxlan
VXLAN Flags: S-VXLAN supported at the local end
             F-Association between VXLAN and Tunnels has been flushed to L2VPN
  VXLAN ID: 1000
     Flags: FS
    Tunnel: 1
  VXLAN ID: 1001
     Flags: FS
    Tunnel: 1
<Sysname> display vxlan isis remote-vxlan count
2 VXLANs found.
表1-24 display vxlan isis remote-mac命令显示信息描述表
VXLAN ID
Flags
远端VXLAN标记,取值包括:
·     S:本地支持该远端VXLAN
·     F:该VXLAN与隧道的关联关系已经通知给L2VPN
Tunnels
远端VXLAN关联的VXLAN隧道
2 VXLANs found
远端VXLAN的数目
display vxlan isis tunnel命令用来显示Tunnel接口的VXLAN IS-IS信息。
display vxlan isis tunnel [ tunnel-number ]
tunnel-number:显示指定Tunnel接口的VXLAN IS-IS信息。如果不指定本参数,将显示所有Tunnel接口上的VXLAN IS-IS信息。
# 显示Tunnel接口101的VXLAN IS-IS信息。
<Sysname> display vxlan isis tunnel 101
Tunnel101
MTU: 1400
DED: Yes
DED priority: 80
Hello timer: 10s
Hello multiplier: 3
CSNP timer: 10s
LSP timer: 100ms
Max LSP transmit number: 5
VXLANs:
  1,50,100
表1-25 display vxlan isis tunnel命令显示信息描述表
Tunnel
VXLAN隧道接口编号
MTU
链路MTU值
DED
是否被选举为DED:Yes表示是;No表示否
DED priority
DED优先级
Hello timer
Hello报文发送时间间隔,单位为秒
Hello multiplier
Hello报文失效数目
CSNP timer
CSNP报文发送时间间隔,单位为秒
LSP timer
LSP的最小发送时间间隔,单位为毫秒
一次最多可以发送的LSP数目
VXLANs
与Tunnel接口关联的VXLAN
graceful-restart命令用来使能VXLAN IS-IS的GR能力。
undo graceful-restart命令用来关闭VXLAN IS-IS的GR能力。
graceful-restart
VXLAN IS-IS的GR能力处于关闭状态。
VXLAN IS-IS视图
GR(Graceful Restart,平滑重启)是一种在协议重启或主备倒换时保证转发业务不中断的机制。需要协议重启或主备倒换的设备将重启状态通知给邻居,允许邻居重新建立邻接关系而不终止连接。
GR有两个角色:
GR Restarter和GR Helper上都需要使能VXLAN IS-IS的GR能力。
# 使能VXLAN IS-IS的GR能力。
[Sysname] vxlan-isis
[Sysname-vxlan-isis] graceful-restart
·     display vxlan isis graceful-restart status
graceful-restart interval命令用来配置VXLAN IS-IS协议的GR重启间隔时间。
VXLAN IS-IS协议的GR重启间隔时间为300秒。
VXLAN IS-IS视图
interval:VXLAN IS-IS协议的GR重启间隔时间,取值范围为30~1800,单位为秒。
本命令配置的GR重启间隔时间作为T2定时器的值,用来控制LSDB同步时间。如果在GR重启间隔时间内未完成LSDB同步,则GR失败,退出GR过程。
# 配置VXLAN IS-IS的GR重启间隔时间为120秒。
[Sysname-vxlan-isis] graceful-restart interval 120
host-mac-learning enable命令用来开启主机路由中携带的MAC地址的学习功能。
undo host-mac-learning enable命令用来关闭主机路由中携带的MAC地址的学习功能。
主机路由中携带的MAC地址的学习功能处于关闭状态。
VXLAN IS-IS视图
如果开启了本功能,则设备接收到主机路由信息后,会将其中携带的MAC地址学习到MAC地址表项中。
为了避免重复学习MAC地址,建议不要同时开启本功能和MAC地址同步功能。
# 开启主机路由中携带的MAC的学习功能。
[Sysname] vxlan isis
[Sysname-vxlan-isis] host-mac-learning enable
host-synchronization enable命令用来开启VXLAN IS-IS的主机路由信息同步功能。
undo host-synchronization enable命令用来关闭VXLAN IS-IS的主机路由信息同步功能。
VXLAN IS-IS的主机路由信息同步功能处于关闭状态。
VXLAN IS-IS视图
开启本功能后,ARP模块或ND模块将本地主机路由信息(即IP地址和MAC地址的对应关系)通告给VXLAN ISIS,再由VXLAN IS-IS将该信息发布出去。VXLAN IS-IS发布的主机路由信息包括IP地址、MAC地址和VXLAN ID信息等。同时,VTEP还能够接收其他VTEP发布的远端主机路由信息。
MAC地址信息和主机路由信息可能会有部分重复,因此在复杂组网中或网络流量较大的情况下,建议不要同时开启MAC地址信息同步功能和主机路由信息同步功能。
# 开启VXLAN IS-IS的主机路由信息同步功能。
[Sysname-vxlan-isis] host-synchronization enable
local-host proxy enable命令用来开启本地主机路由信息的代理功能。
undo local-host proxy enable命令用来关闭本地主机路由信息的代理功能。
本地主机路由信息的代理功能处于关闭状态。
VXLAN IS-IS视图
开启本功能后,VXLAN IS-IS会将需要发布的主机路由信息中的MAC地址替换成本地VSI虚接口的MAC地址。在对端VTEP上,多个IP地址将对应同一个MAC地址,从而减少占用对端VTEP设备的MAC地址资源。
# 开启本地主机路由信息的代理功能。
[Sysname-vxlan-isis] local-host proxy enable
log-peer-change enable命令用来打开邻接状态变化的输出开关。
undo log-peer-change enable命令用来关闭邻接状态变化的输出开关。
邻接状态变化的输出开关处于打开状态。
VXLAN IS-IS视图
打开邻接状态变化的输出开关后,VXLAN IS-IS邻接状态变化时会生成日志信息发送到设备的信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 打开邻接状态变化的输出开关。
[Sysname-vxlan-isis] log-peer-change enable
mac-synchronization enable命令用来开启VXLAN IS-IS的MAC地址同步功能。
undo mac-synchronization enable命令用来关闭VXLAN IS-IS的MAC地址同步功能。
VXLAN IS-IS的MAC地址同步功能处于关闭状态。
VXLAN IS-IS视图
开启本功能后,VTEP可以通过VXLAN IS-IS协议发布本地的MAC地址信息,并能够接收其他VTEP发布的远端MAC地址信息。
# 开启VXLAN IS-IS的MAC地址同步功能。
[Sysname-vxlan-isis] mac-synchronization enable
negotiate-vni enable命令用来开启VXLAN IS-IS的VXLAN自动协商功能。
undo negotiate-vni enable命令用来关闭VXLAN IS-IS的VXLAN自动协商功能。
VXLAN IS-IS的VXLAN自动协商功能处于关闭状态。
VXLAN IS-IS视图
本功能用来实现VXLAN隧道与VXLAN的自动关联。
开启本功能后,VTEP在所有VXLAN隧道上通过VXLAN IS-IS将本地存在的VXLAN的ID通告给远端VTEP。远端VTEP将其与本地的VXLAN进行比较,如果存在相同的VXLAN,则将该VXLAN与接收该信息的VXLAN隧道关联。
# 开启VXLAN IS-IS的VXLAN隧道自动协商功能。
[Sysname-vxlan-isis] negotiate-vni enable
overlay isis ded-priority命令用来配置Tunnel接口的DED(Designated Edge Device,指定边缘设备)优先级。
undo overlay isis ded-priority命令用来恢复缺省情况。
overlay isis ded-priority priority
Tunnel接口的DED优先级为64。
VXLAN模式Tunnel接口视图
NVE模式Tunnel接口视图
priority:Tunnel接口的DED优先级,取值范围为0~127。
每个VXLAN隧道两端的VTEP设备通过交互VXLAN IS-IS Hello报文选举出一个DED。选举出的DED周期性发布CSNP报文来进行LSDB同步。
DED优先级数值高的设备被选为DED;如果两台设备的DED优先级相同,则MAC地址较大的设备会被选中。
# 配置Tunnel接口101的DED优先级为2。
[Sysname] interface tunnel 101
[Sysname-tunnel101] overlay isis ded-priority 2
·     display vxlan isis tunnel
overlay isis timer csnp命令用来配置DED发送CSNP报文的时间间隔。
undo overlay isis timer csnp命令用来恢复缺省情况。
overlay isis timer csnp interval
DED发送CSNP报文的时间间隔为10秒。
VXLAN模式Tunnel接口视图
NVE模式Tunnel接口视图
interval:DED发送CSNP报文的时间间隔,取值范围为1~600,单位为秒。
DED使用CSNP报文来进行LSDB同步。因此,只有在被选举为DED的设备上进行该项配置才有效。
# 配置Tunnel接口101上CSNP报文的发送时间间隔为15秒。
[Sysname-tunnel101] overlay isis timer csnp 15
overlay isis timer hello命令用来配置VXLAN IS-IS Hello报文的发送时间间隔。
undo overlay isis timer hello命令用来恢复缺省情况。
overlay isis timer hello interval
VXLAN IS-IS Hello报文的发送时间间隔为10秒。
VXLAN模式Tunnel接口视图
NVE模式Tunnel接口视图
interval:VXLAN IS-IS Hello报文的发送时间间隔,取值范围为3~255,单位为秒。
发送时间间隔越短,网络收敛越快,但也需要占用更多的系统资源。因此,需要根据实际情况合理配置VXLAN IS-IS Hello报文的发送时间间隔。
DED发送VXLAN IS-IS Hello报文的时间间隔是本命令设置的时间间隔的1/3。
# 配置Tunnel接口101上VXLAN IS-IS Hello报文的发送时间间隔为6秒。
[Sysname-tunnel101] overlay isis timer hello 6
overlay isis timer holding-multiplier命令用来配置VXLAN IS-IS Hello报文失效数目。
undo overlay isis timer holding-multiplier命令用来恢复缺省情况。
overlay isis timer holding-multiplier value
VXLAN IS-IS Hello报文失效数目为3。
VXLAN模式Tunnel接口视图
NVE模式Tunnel接口视图
value:VXLAN IS-IS Hello报文失效数目,取值范围为3~1000。
当前VTEP通过VXLAN IS-IS Hello报文将邻接关系保持时间通知给远端VTEP。如果远端VTEP在邻接关系保持时间内未收到来自当前VTEP的VXLAN IS-IS Hello报文,将宣告邻接关系失效。
邻接关系保持时间的计算方法为:
·     没有使能GR能力时,为VXLAN IS-IS Hello报文失效数目与VXLAN IS-IS Hello报文发送时间间隔的乘积。
·     使能GR能力时,取以下二者间的较大值:VXLAN IS-IS Hello报文失效数目与VXLAN IS-IS Hello报文发送时间间隔的乘积(如果是DED,该乘积还要除以3)、GR重启间隔时间。
邻接关系保持时间最大不能超过65535秒,超过65535秒时,算作65535秒。
# 配置Tunnel接口101上VXLAN IS-IS Hello报文失效数目为6。
[Sysname-tunnel101] overlay isis timer holding-multiplier 6
·     overlay isis timer hello
overlay isis timer lsp命令用来配置VXLAN IS-IS在接口上发送LSP报文的最小时间间隔以及一次可以最多发送的LSP报文数目。
undo overlay isis timer lsp命令用来恢复缺省情况。
overlay isis timer lsp interval [ count count ]
发送LSP报文的最小时间间隔为100毫秒,一次最多可以发送的LSP报文数目为5。
VXLAN模式Tunnel接口视图
NVE模式Tunnel接口视图
interval:发送LSP报文的最小时间间隔,取值范围为100~1000,为100的整数倍,单位为毫秒。
count count:一次最多可以发送的LSP报文数目,取值范围为1~1000,缺省值为5。
当LSDB的内容发生变化(如添加、删除MAC地址表项)时,VXLAN IS-IS将把发生变化的LSP扩散出去。
用户可以通过本命令调整VTEP发送的LSP报文的数目。增大LSP报文的最小发送时间间隔、减少一次最多可以发送的LSP报文数目,可以减少VTEP发送的LSP报文数目,避免出现LSP风暴。
# 配置发送LSP报文的最小时间间隔为500毫秒。
[Sysname-tunnel101] overlay isis timer lsp 500
·     display vxlan isis brief
reserved vxlan命令用来配置IS-IS协议使用的保留VXLAN。
undo reserved vxlan命令用来恢复缺省情况。
reserved vxlan vxlan-id
undo reserved vxlan
未指定IS-IS协议使用的保留VXLAN。
vxlan-id:保留VXLAN的ID,取值范围为0~16777215。
保留VXLAN用来接收和发送VXLAN IS-IS报文。属于同一个VXLAN的VTEP上只有配置了相同的保留VXLAN,VTEP之间才能够正常收发VXLAN IS-IS报文。
只能在系统视图下配置一个全局保留VXLAN,该VXLAN不能与VSI下创建的VXLAN相同。
# 配置IS-IS协议使用的保留VXLAN为VXLAN 10000。
[Sysname] reserved vxlan 10000
reset vxlan isis命令用来清除VXLAN IS-IS进程下所有的动态数据,包括VXLAN IS-IS的邻居、本地MAC地址、远端MAC地址、VXLAN ID、链路状态数据库等信息。
reset vxlan isis
# 清除VXLAN IS-IS进程下所有的动态数据。
<Sysname> reset vxlan isis
timer lsp-max-age命令用来配置当前VTEP生成的LSP在LSDB里的最大生存时间。
undo timer lsp-max-age命令用来恢复缺省情况。
timer lsp-max-age seconds
当前VTEP生成的LSP在LSDB里的最大生存时间为1200秒。
VXLAN IS-IS视图
seconds:LSP在LSDB里的最大生存时间,取值范围是3~65535,单位为秒。
每个LSP都有一个最大生存时间,随着时间的推移LSP的生存时间将逐渐减小,当LSP的生存时间为0时,VXLAN IS-IS将清除该LSP。用户可根据网络的实际情况调整LSP的最大生存时间。
# 配置生成的LSP的最大生存时间为25分钟,即1500秒。
[Sysname-vxlan-isis] timer lsp-max-age 1500
timer lsp-refresh命令用来配置LSP刷新周期。
undo timer lsp-refresh命令用来恢复缺省情况。
timer lsp-refresh seconds
LSP刷新周期为900秒。
VXLAN IS-IS视图
seconds:LSP刷新周期,取值范围为1~65534,单位为秒。
timer lsp-refresh命令配置的时间必须小于timer lsp-max-age命令配置的时间,以保证在LSP失效前进行刷新。
# 配置LSP刷新周期为1500秒。
[Sysname-vxlan-isis] timer lsp-refresh 1500
·     timer lsp-max-age
virtual-system命令用来创建一个VXLAN IS-IS虚拟系统。
undo virtual-system命令用来删除指定的VXLAN IS-IS虚拟系统。
virtual-system system-id
undo virtual-system system-id
不存在VXLAN IS-IS虚拟系统。
VXLAN IS-IS视图
system-id:虚拟系统的系统ID,用来标识虚拟系统,格式为XXXX.XXXX.XXXX,X表示十六进制数字。
当本地MAC地址数超过系统的LSP分片集所能携带的MAC地址数时,可以配置VXLAN IS-IS虚拟系统来扩展LSP的分片数量,以增加系统所能发布的MAC地址数量。
创建虚拟系统前,系统最多可以发送约55×210的MAC地址信息,每创建一个虚拟系统,最多可以多发送55×210的MAC地址信息。用户可以根据本地MAC地址表的规模,来决定创建的虚拟系统的个数。
创建虚拟系统时,用户需要保证所配置的虚拟系统的系统ID在网络中是唯一的。
# 创建一个系统ID为0001.0001.0001的虚拟系统。
[Sysname-vxlan-isis] virtual-system 0001.0001.0001
1.4.29  vxlan-isis
vxlan-isis命令用来创建VXLAN IS-IS进程,并进入VXLAN IS-IS视图。如果VXLAN IS-IS进程已经存在,则直接进入VXLAN IS-IS视图。
undo vxlan-isis命令用来删除VXLAN IS-IS进程,并清除VXLAN IS-IS进程下的配置数据。
vxlan-isis
undo vxlan-isis
不存在VXLAN IS-IS进程。
# 创建VXLAN IS-IS进程,并进入VXLAN IS-IS视图。
