- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-Crypto engine commands
- 23-FIPS commands
- 24-MACsec commands
- 25-Microsegmentation commands
- 26-Object group commands
- 27-SAVI commands
- 28-SAVA commands
28-SAVA commands | 63.72 KB |
Content
display ipv6 sava packet-drop statistics
ipv6 sava log enable spoofing-packet
SAVA commands
SAVA is supported only in Release 6635 and later.
display ipv6 sava
Use display ipv6 sava to display SAVA entries.
display ipv6 sava [ interface interface-type interface-number ] [ slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SAVA entries for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays SAVA entries on the master device.
# Display SAVA entries.
<Sysname> display ipv6 sava
IPv6 SAVA entry count: 2
Destination: 2011:: Prefix length: 64
Interface: Vlan-int10 Flags: L
Destination: 2012:: Prefix length: 64
Interface: Vlan-int20 Flags: L
IPv6 SAVA entry count |
Number of SAVA entries. |
Destination |
Destination IPv6 address. |
Prefix length |
Prefix length of the IPv6 address. |
Interface name. |
Flag |
Flag of the SAVA entry: · L—Local entry. · R—Remote entry. · G—Access group entry. |
Use display ipv6 sava packet-drop statistics to display SAVA packet drop statistics.
display ipv6 sava packet-drop statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SAVA packet drop statistics for all interfaces.
# Display SAVA packet drop statistics.
<Sysname> display ipv6 sava packet-drop statistics
Vlan-interface10:
Packets:0 Bytes: 0
Vlan-interface20:
Packets:10 Bytes: 1500
Packets |
Number of packets dropped by SAVA. |
Bytes |
Number of bytes dropped by SAVA. |
reset ipv6 sava packet-drop statistics
ipv6 sava access-group
Use ipv6 sava access-group to add an interface to an access group.
Use undo ipv6 sava access-group to remove an interface from an access group.
ipv6 sava access-group group-name
An interface does not belong to any access group.
group-name: Specifies an access group by its name, a case-sensitive string of 1 to 255 characters.
All interfaces in a SAVA access group must belong to the public network or the same VPN instance.
A SAVA access group can contain a maximum of eight interfaces.
# Add VLAN-interface 10 to SAVA access group aaa.
[Sysname-Vlan-interface10] ipv6 sava access-group aaa
ipv6 sava enable
Use ipv6 sava enable to enable SAVA.
Use undo ipv6 sava enable to disable SAVA.
If the device has a large number of routing entries, it might take a long time for the device to complete SAVA entry creation. Before SAVA entry creation completes, valid IPv6 packets might be dropped.
# Enable SAVA on VLAN-interface 10.
[Sysname-Vlan-interface10] ipv6 sava enable
Use ipv6 sava log enable spoofing-packet to enable SAVA logging.
Use undo ipv6 sava log enable spoofing-packet to disable SAVA logging.
ipv6 sava log enable spoofing-packet [ interval interval | number number ]*
interval interval: Specifies the interval at which the device outputs SAVA logs, in seconds. The value can be 0 or in the range of 5 to 3600, and the default is 60. If you set the interval to 0 seconds, the device outputs a SAVA log immediately after detecting an IPv6 source address spoofing packet.
number number: Specifies the maximum number of SAVA logs that can be outputted each time, in the range of 1 to 128. The default is 128.
To identify and troubleshoot issues, enable SAVA logging.
This feature enables the device to output SAVA logs when SAVA detects spoofing packets.
An IRF member device can output a maximum of 128 SAVA logs each time.
[Sysname] ipv6 sava log enable spoofing-packet
ipv6 sava import remote-route-tag
Use ipv6 sava import remote-route-tag to enable an interface to create SAVA entries based on synchronized remote routes.
Use undo ipv6 sava import remote-route-tag to restore the default.
ipv6 sava import remote-route-tag tag
An interface does not create SAVA entries based on synchronized remote routes.
tag: Specifies a tag of synchronized remote routes, in the range of 1 to 4294967295.
[Sysname-Vlan-interface10] ipv6 sava import remote-route-tag 100
Use reset ipv6 sava packet-drop statistics to clear SAVA packet drop statistics.
reset ipv6 sava packet-drop statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears SAVA packet drop statistics for all interfaces.
# Clear SAVA packet drop statistics.
<Sysname> reset ipv6 sava packet-drop statistics
