- 20-Network Management and Monitoring Configuration Guide
- 01-Ping and tracert configuration
- 02-System debugging configuration
- 03-NQA configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-NETCONF configuration
- 07-Process monitoring and maintenance configuration
- 08-Mirroring configuration
- 09-UCC configuration
- 10-SQA configuration
- 11-Packet capture configuration
- 12-Email Notification Service Configuration
07-Process monitoring and maintenance configuration | 103.31 KB |
Monitoring and maintaining processes
About monitoring and maintaining processes
Process monitoring and maintenance tasks at a glance
Monitoring and maintaining user processes and kernel threads
About monitoring and maintaining user processes and kernel threads
Displaying memory usage of processes
Displaying CPU usage of processes
Locating user process memory usage exceptions
Displaying log information for user processes
Displaying context information for process exceptions
Clearing context information for process exceptions
Monitoring and maintaining kernel threads
About monitoring and maintaining kernel threads
Detecting kernel thread deadloops
Detecting kernel thread starvation
Displaying kernel thread exception information
Displaying kernel thread reboot information
Clearing kernel thread exception information
Clearing kernel thread reboot information
The system software of the device is a full-featured, modular, and scalable network operating system based on the Linux kernel. The system software features run the following types of independent processes:
· User process—Runs in user space. Most system software features run user processes. Each process runs in an independent space so the failure of a process does not affect other processes. The system automatically monitors user processes. The system supports preemptive multithreading. A process can run multiple threads to support multiple activities. Whether a process supports multithreading depends on the software implementation.
· Kernel thread—Runs in kernel space. A kernel thread executes kernel code. It has a higher security level than a user process. If a kernel thread fails, the system breaks down. You can monitor the running status of kernel threads.
To monitor and maintain processes, perform the following tasks:
· Monitoring and maintaining user processes and kernel threads
The commands in this section apply to both user processes and kernel threads.
The commands in this section apply only to user processes.
· Monitoring and maintaining kernel threads
The commands in this section apply only to kernel threads.
The commands in this section apply to both user processes and kernel threads. You can use the commands for the following purposes:
· Display the overall memory usage.
· Display the running processes and their memory and CPU usage.
· Locate abnormal processes.
If a process consumes excessive memory or CPU resources, the system identifies the process as an abnormal process.
· If an abnormal process is a user process, troubleshoot the process as described in "Monitoring and maintaining user processes."
· If an abnormal process is a kernel thread, troubleshoot the process as described in "Monitoring and maintaining kernel threads."
· To display memory usage of processes, execute the following command in any view:
For information about this command, see System Management Command Reference.
· To display free memory block information for a user process, execute the following command in any view:
display process memory fragment free job job-id [ slot slot-number [ cpu cpu-number ] ]
· To display used memory block information for a user process, execute the following command in any view:
display process memory fragment used used-block job job-id [ slot slot-number [ cpu cpu-number ] ]
To display CPU usage of processes, execute the following command in any view:
display process cpu [ slot slot-number [ cpu cpu-number ] ]
Monitoring process status
Execute the following commands in any view.
· Display process status information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
· Monitor process running status.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
· Monitor thread running status.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
Use this feature to monitor the operating status of user processes. If a user process is excessively busy or consumes excessive resources, use this feature to locate problems.
Configuring core dump
The core dump feature enables the system to generate a core dump file each time a process crashes until the maximum number of core dump files is reached. A core dump file stores information about the process. You can send the core dump files to H3C technical support staff to troubleshoot the problems.
Core dump files consume storage resources. Enable core dump only for processes that might have problems.
Execute the following commands in user view:
1. (Optional.) Specify the directory for saving core dump files.
exception filepath directory
By default, the directory for saving core dump files is the root directory of the default file system. For more information about the default file system, see file system management in Fundamentals Configuration Guide.
2. Enable core dump for a process and specify the maximum number of core dump files, or disable core dump for a process.
process core { maxcore value | off } { job job-id | name process-name }
By default, a process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
To display the core dump file directory, execute the following command in user view:
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
Execute display commands in any view and other commands in user view.
· Display memory usage for all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
· Display heap memory usage for a user process.
display process memory heap job job-id [ tag [ tag-id ] | verbose ] [ slot slot-number [ cpu cpu-number ] ]
· Display memory content starting from a specified memory block for a user process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
· Display the addresses of memory blocks with a specified size used by a user process.
display process memory heap job job-id [ tag tag-id ] size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
· Display umem memory statistics for a user process.
display process memory umem job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
To display log information for user processes, execute the following command in any view:
display process log [ slot slot-number [ cpu cpu-number ] ]
To display context information for process exceptions, execute the following command in any view:
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
To clear context information for process exceptions, execute the following command in user view:
reset exception context [ slot slot-number [ cpu cpu-number ] ]
Use this feature to monitor the operating status of kernel threads. If a kernel thread is excessively busy or consumes excessive resources, use this feature to locate problems.
Kernel threads share resources. If a kernel thread monopolizes the CPU, other threads cannot run, resulting in a deadloop.
This feature enables the device to detect deadloops. If a thread occupies the CPU for a specific interval, the device determines that a deadloop has occurred and generates a deadloop message.
Change kernel thread deadloop detection settings only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
Configuring kernel thread deadloop detection
1. Enter system view.
2. Enable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ]
By default, kernel thread deadloop detection is enabled.
3. (Optional.) Set the threshold for identifying a kernel thread deadloop.
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
By default, the threshold for identifying a kernel thread deadloop is 25 seconds.
4. (Optional.) Exclude a kernel thread from kernel thread deadloop detection.
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
When enabled, kernel thread deadloop detection monitors all kernel threads by default.
You can exclude up to 128 kernel threads from kernel thread deadloop detection. If you execute this command multiple times, do not specify the same value for the tid argument. If you specify the same value for the tid argument, the command execution will fail.
Displaying kernel thread deadloop detection information
· Display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
· Display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
Clearing kernel thread deadloop information
To clear kernel thread deadloop information, execute the following command in user view:.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
Starvation occurs when a thread is unable to access shared resources.
Kernel thread starvation detection enables the system to detect and report thread starvation. If a thread is not executed within a specific interval, the system determines that a starvation has occurred and generates a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
CAUTION: Configure kernel thread starvation detection only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. |
Configuring kernel thread starvation detection
2. Enable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
By default, kernel thread starvation detection is disabled.
3. (Optional.) Set the threshold for identifying a kernel thread starvation.
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
By default, the threshold for identifying a kernel thread starvation is 120 seconds.
4. (Optional.) Exclude a kernel thread from kernel thread starvation detection.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
When enabled, kernel thread starvation detection monitors all kernel threads by default.
Displaying kernel thread starvation information
· Display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
· Display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Clearing kernel thread starvation information
To clear kernel thread starvation information, execute the following command in user view:.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
To display kernel thread exception information, execute the following command in any view:
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
To display kernel thread reboot information, execute the following command in any view:
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
To clear kernel thread exception information, execute the following command in user view:
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
To clear kernel thread reboot information, execute the following command in user view:
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
