- H3C Wi-Fi7 Indoor Access Points Installation Guide-5W102
- 01-Installing the device
- 02-Logging in to the device
- 03-Appendix A AP views and technical specifications
- 04-Appendix B LEDs and buttons
- 05-Appendix C Optional transceiver modules
- 06-Appendix D Connecting the hybrid copper-fiber cable
- 07-Appendix E Cabling recommendations
03-Appendix A AP views and technical specifications | 719.32 KB |
3 Appendix A AP views and technical specifications
WA7539
AP views
Figure3-1 WA7539
Ports
Figure3-2 Ports on the WA7539 AP
(1) Power port |
(2) 10GE1/PoE++ port |
(3) GE/PSE port |
(4) USB port |
(5) 10GE2/P++SFP port |
(6) Console port |
(7) Reset button |
(8) Security slot |
Technical specifications
Table3-1 Technical specifications
Item |
Dimensions (H × W × D) (without the mounting bracket) |
40 × 225 × 225 mm (1.57 × 8.86 × 8.86 in) |
Weight |
1.5 kg (3.31 lb) |
Power consumption |
≤ 54 W |
Antenna |
Built-in antenna |
Standard compliance |
· IEEE802.11a/b/g/n/ac/ax/be · IEEE802.3at/bt |
Powering option |
IEEE802.3at/bt powering standard-compliant: · Power adapter · PoE · PoE optical transceiver module |
Operating temperature |
0°C to 50°C (32°F to 122°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5%RH to 95%RH, non-condensing |
Storage humidity |
Operating altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
Console port |
Control port, used for debugging by the maintenance personnel |
10GE2/P++SFP port |
1000M/2.5G/5G/10G photoelectric hybrid port |
10GE1/PoE++ port |
100M/1000M/2.5G/5G/10G Ethernet copper port When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/1 in the MAP file and Ten-GigabitEthernet 1 for configuration on the AC. |
GE/PSE port |
100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
USB port |
USB-compliant USB port. NOTE: By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view. |
Power port (54VDC) |
Used for receiving power from a local power source. |
Reset button |
For more information, see "Appendix B LEDs and buttons." |
WA7638
AP views
Figure3-3 WA7638
Ports
Figure3-4 Ports on the WA7638 AP
(1) Power port |
(3) GE1/PoE++ port |
(4) GE2/PSE port |
(6) USB port |
(7) Console port |
(8) Reset button |
(9) Security slot |
Table3-2 Technical specifications
Item |
48 × 265 × 265 mm (1.89 × 10.43 × 10.43 in) |
Power consumption |
≤ 58 W |
Antenna |
Built-in antenna |
Powering option |
Storage humidity |
Console port |
10GE2/P++SFP |
GE1/PoE++ |
100M/1000M Ethernet copper port, which can act as the uplink interface to connect the device to Internet or the MAN or act as the standard PoE interface. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 for configuration on the AC. |
10GE1/PoE++ |
GE2/PSE |
100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/2 in the MAP file and GigabitEthernet 2 for configuration on the AC. |
USB port |
Reset button |
