06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10106-Layer 2 - LAN Switching
21-HH3C-LAG-MIB
21-HH3C-LAG-MIB 47.09 KB
HH3C-LAG-MIB
About this MIB
This MIB contains information in ieee8023-lag.mib and hh3c-lag.mib.
MIB file name
hh3c-lag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cLAG(25)
Scalar objects
hh3cAggResourceAllocationValue
Object (OID)
Access
Value range
Implementation
hh3cAggResourceAllocationValue (1.3.6.1.4.1.25506.8.25.1.3)
read-only
Octets
OCTET STRING (1)
Whether link aggregation is implemented by Huawei or H3C.
As per the MIB.
Tabular objects
hh3cAggLinkTable
About this table
This table contains aggregation group information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cAggLinkNumber.
Object (OID)
Access
Value range
Implementation
hh3cAggLinkNumber (1.3.6.1.4.1.25506.8.25.1.1.1.1)
not-accessible
Integer32
Standard MIB values.
Aggregation group ID.
As per the MIB.
hh3cAggLinkName (1.3.6.1.4.1.25506.8.25.1.1.1.2)
read-create
DisplayString
SIZE (0..32)
Aggregation group name.
Not supported
hh3cAggLinkMode (1.3.6.1.4.1.25506.8.25.1.1.1.3)
read-create
INTEGER
manual(1)
static(2)
dynamic(3)
Aggregation mode.
Supports only 2 and 3.
hh3cAggLinkPortList (1.3.6.1.4.1.25506.8.25.1.1.1.4)
read-create
PortList
OCTET STRING (0..255)
Aggregation member ports.
As per the MIB.
hh3cAggLinkState (1.3.6.1.4.1.25506.8.25.1.1.1.5)
read-create
RowStatus
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cAggPortListSelectedPorts (1.3.6.1.4.1.25506.8.25.1.1.1.6)
read-only
PortList
Selected member ports.
As per the MIB.
hh3cAggPortListSamePartnerPorts (1.3.6.1.4.1.25506.8.25.1.1.1.7)
read-only
PortList
Member ports attached to the same peer.
As per the MIB.
A value of the PortList type specifies a list of ports in the format of an octet string. Each octet specifies eight ports. Within each octet, the most significant bit represents the lowest-numbered port, and the least significate bit represents the highest-numbered port. Thus, each port of the device is represented by a single bit within the value of this object. If that bit has a value of 1, then that port is included in the set of ports. The port is not included if its bit has a value of 0.
Example:
hh3cAggLinkPortList.1 (PortList) 00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.34 (hex)
Hexadecimal string 00 indicates that no ports are included in an octet. The last octet is 34 in hexadecimal format and 00110100 in binary format. Therefore, the following ports are included in the list:
Port 307 (38 × 8 + 3 = 307, where 38 is the number of times that hexadecimal string 00 appears.)
Port 308 (38 × 8 + 4 = 308)
Port 310 (38 × 8 + 6 = 310)
hh3cAggPortTable
About this table
This table contains aggregation member port information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cAggPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cAggPortIndex (1.3.6.1.4.1.25506.8.25.1.2.1.1)
not-accessible
Gauge32
Member port index.
As per the MIB.
hh3cAggPortNotAttachedReason (1.3.6.1.4.1.25506.8.25.1.2.1.2)
read-write
Integer32
0..10
Why the port is unselected.
Read-only.
hh3cAggPortLacpState (1.3.6.1.4.1.25506.8.25.1.2.1.3)
read-write
TruthValue
true(1)
false(2)
Status of LACP.
Read-only.
hh3cAggPortNotAttachedString (1.3.6.1.4.1.25506.8.25.1.2.1.4)
read-write
DisplayString
SIZE (0..255)
Detailed cause for the unselected state of the member port.
Read-only.
