- 06-Layer 2 - LAN Switching
- 01-HH3C-LswMAM-MIB
- 02-HH3C-LswMSTP-MIB
- 03-HH3C-LswVLAN-MIB
- 04-HH3C-MAC-INFORMATION-MIB
- 05-HH3C-MLAG-MIB
- 06-HH3C-PROTOCOL-VLAN-MIB
- 07-HH3C-PVST-MIB
- 08-HH3C-QINQV2-MIB
- 09-HH3C-SUBNET-VLAN-MIB
- 10-HH3C-VMAP-MIB
- 11-IEEE8023-LAG-MIB
- 12-LLDP-EXT-DOT1-MIB
- 13-LLDP-EXT-DOT1-V2-MIB
- 14-LLDP-EXT-DOT3-MIB
- 15-LLDP-EXT-DOT3-V2-MIB
- 16-LLDP-EXT-MED-MIB
- 17-LLDP-MIB
- 18-LLDP-V2-MIB
- 19-BRIDGE-MIB
- 20-EtherLike-MIB
- 21-HH3C-LAG-MIB
- 22-HH3C-LLDP-EXT-MIB
- 23-HH3C-LPBKDT-MIB
15-LLDP-EXT-DOT3-V2-MIB | 81.77 KB |
About this MIB
This MIB is the LLDP management information base extension module for discovery information defined by the IEEE 802.3 organization.
LLDP facilitates network management to discover and use network physical topology in a standard way, and enables network management to discover configuration inconsistencies or errors that affect the upper-layer applications. Although H3C products support the LLDP 2009 version, they still use the MIBs of the LLDP 2005 version.
The MIB of the LLDP 2009 version is also referred to as LLDP-V2-MIB. This MIB is a standard public MIB, which contains LLDP configuration, LLDP statistics, local LLDP information, neighboring LLDP information, and IEEE 802.1 extended configuration, DCBX extended configuration, and IEEE 802.3 extended configuration. The CNP extended configuration is not supported in Comware V700R001.
MIB file name
lldp-ext-dot3-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot3MIB(4623)
Tabular objects
lldpV2Xdot3PortConfigTable
About this table
This table controls selection of LLDP TLVs to be transmitted on individual ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3PortConfigTLVsTxEnable (1.3.111.2.802.1.1.13.1.5.4623.1.1.1.1.1) |
read-write |
BITS |
BITS{macPhyConfigStatus(0), powerViaMDI(1), unused(2), maxFrameSize(3)} |
IEEE 802.3 organizationally specific optional TLVs whose transmission is enabled on the ports. |
By default, each bit is set to 1 on the nearest bridge agents of Layer 2 and Layer 3 Ethernet ports. It indicates that all IEEE 802.3 organizationally specific TLVs can be transmitted on a given port. Link aggregation TLVs no longer belong to the 802.3 organizationally specific TLV set, and the bit for unused(2) will not be set for these TLVs. |
lldpV2Xdot3LocPortTable
About this table
This table contains 802.3 extended information on the local ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpV2LocPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3LocPortAutoNegSupported (1.3.111.2.802.1.1.13.1.5.4623.1.2.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given local port supports autonegotiation. |
As per the MIB. |
lldpV2Xdot3LocPortAutoNegEnabled (1.3.111.2.802.1.1.13.1.5.4623.1.2.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether autonegotiation is enabled on the given local port. |
As per the MIB. |
lldpV2Xdot3LocPortAutoNegAdvertisedCap (1.3.111.2.802.1.1.13.1.5.4623.1.2.1.1.3) |
read-only |
OCTET STRING |
OCTET STRING (2) |
Autonegotiation capability on the given local port. |
As per the MIB. |
lldpV2Xdot3LocPortOperMauType(1.3.111.2.802.1.1.13.1.5.4623.1.2.1.1.4) |
read-only |
Unsigned32 |
Unsigned32(0~2147483647) |
Operational MAU type of the given local port. |
As per the MIB. |
lldpV2Xdot3LocPowerTable
About this table
This table contains information about power supply capabilities of the local ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3LocPowerPortClass (1.3.111.2.802.1.1.13.1.5.4623.1.2.2.1.1) |
read-only |
LldpV2PowerPortClass |
Standard MIB values. |
Port class (PSE or PD) of the given local port. |
As per the MIB. |
lldpV2Xdot3LocPowerMDISupported (1.3.111.2.802.1.1.13.1.5.4623.1.2.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the MDI power is supported on the given local port. |
As per the MIB. |
lldpV2Xdot3LocPowerMDIEnabled(1.3.111.2.802.1.1.13.1.5.4623.1.2.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the MDI power is enabled on the given local port. |
As per the MIB. |
lldpV2Xdot3LocPowerPairControlable (1.3.111.2.802.1.1.13.1.5.4623.1.2.2.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the pair selection can be controlled on the given local port. |
As per the MIB. |
lldpV2Xdot3LocPowerPairs (1.3.111.2.802.1.1.13.1.5.4623.1.2.2.1.5) |
read-only |
Unsigned32 |
Unsigned32(1|2) |
Current pair on the given local port. |
As per the MIB. |
lldpV2Xdot3LocPowerClass (1.3.111.2.802.1.1.13.1.5.4623.1.2.2.1.6) |
read-only |
Unsigned32 |
Unsigned32(1|2|3|4|5) |
Power supply capability or power consumption on the given local port. |
As per the MIB. |
lldpV2Xdot3LocMaxFrameSizeTable
About this table
This table contains one row per port of maximum frame size information on the local device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3LocMaxFrameSize (1.3.111.2.802.1.1.13.1.5.4623.1.2.3.1.1) |
read-only |
Unsigned32 |
Unsigned32(0..65535) |
The maximum supported frame size on the given local port. |
As per the MIB. |
lldpV2Xdot3RemPortTable
About this table
This table contains port information on the given port of a neighboring device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3RemPortAutoNegSupported (1.3.111.2.802.1.1.13.1.5.4623.1.3.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given port on the neighboring device supports autonegotiation. |
As per the MIB. |
lldpV2Xdot3RemPortAutoNegEnabled (1.3.111.2.802.1.1.13.1.5.4623.1.3.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether autonegotiation is enabled on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPortAutoNegAdvertisedCap (1.3.111.2.802.1.1.13.1.5.4623.1.3.1.1.3) |
read-only |
OCTET STRING |
OCTET STRING (2) |
Autonegotiation capability on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPortOperMauType (1.3.111.2.802.1.1.13.1.5.4623.1.3.1.1.4) |
read-only |
Unsigned32 |
Unsigned32(0..2147483647) |
Operational MAU type of the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPowerTable
About this table
This table contains information about power supply capabilities of the ports on the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3RemPowerPortClass (1.3.111.2.802.1.1.13.1.5.4623.1.3.2.1.1) |
read-only |
Port class (PSE or PD) of the given port of a neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPowerMDISupported (1.3.111.2.802.1.1.13.1.5.4623.1.3.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given port on the neighboring device supports the MDI power. |
As per the MIB. |
lldpV2Xdot3RemPowerMDIEnabled (1.3.111.2.802.1.1.13.1.5.4623.1.3.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the MDI power is enabled on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPowerPairControlable (1.3.111.2.802.1.1.13.1.5.4623.1.3.2.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the pair selection can be controlled on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPowerPairs (1.3.111.2.802.1.1.13.1.5.4623.1.3.2.1.5) |
read-only |
Unsigned32 |
Unsigned32(1|2) |
Current pair on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemPowerClass (1.3.111.2.802.1.1.13.1.5.4623.1.3.2.1.6) |
read-only |
Unsigned32 |
Power supply capability or power consumption on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot3RemMaxFrameSizeTable
About this table
This table contains one row per port of maximum frame size information on the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot3RemMaxFrameSize (1.3.111.2.802.1.1.13.1.5.4623.1.3.3.1.1) |
read-only |
Unsigned32 |
The maximum supported frame size on the given port of a neighboring device. |
As per the MIB. |
