07-HH3C-USER-MIB | 53.67 KB |
HH3C-USER-MIB
About this MIB
Use this MIB to manage local users.
MIB file name
hh3c-user.mib
Notifications
hh3cUserBlacklistLock
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.12.3.1.0.1 |
A user was locked to the password control blacklist. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when the number of login failures of a user reaches the upper limit. The user is added to the password control blacklist.
System impact
The system may be under login attacks.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-lock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-lock command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.12.1.1.1.1 (hh3cUserName) |
Username. |
hh3cUserIndex |
DisplayString |
OCTET STRING (1..255) |
1.3.6.1.4.1.25506.2.12.3.1.1.1 (hh3cUserIPAddressType) |
Address type of the user. |
hh3cUserIndex |
INTEGER |
unknown(0),, ipv4(1), , ipv6(2) |
1.3.6.1.4.1.25506.2.12.3.1.1.2 (hh3cUserIPAddress) |
IP address of the user. |
hh3cUserIndex |
InetAddress |
OCTET STRING(0..255) |
Recommended action
Use the display password-control blacklist command to view users in the password control blacklist and analyze whether login user attacks exist. If login user attacks exist, contact the administrator.
hh3cUserBlacklistUnlock
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.12.3.1.0.2 |
A user was unlocked from the password control blacklist. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when a user blacklisted due to login failures is removed from the blacklist because the administrator executed the reset password-control blacklist command or the user lockout timer expires.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-unlock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-unlock command.
Object
OID (object name) |
Index |
Type |
Value range |
Username. |
hh3cUserIndex |
DisplayString |
OCTET STRING (1.. 255) |
User address type. |
hh3cUserIndex |
INTEGER |
User IP address. |
hh3cUserIndex |
InetAddress |
OCTET STRING (0..255) |
Recommended action
No action is required.
hh3cUserGroupThresholdAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.12.4.0.1 |
Maximum number of user groups already reached. |
Error |
Major |
1.3.6.1.4.1.25506.2.12.4.0.2 (hh3cUserGroupThresholdResume) |
OFF |
This notification is generated when the number of user groups configured on the device reaches the upper limit.
System impact
New user groups cannot be created.
Status control
ON
CLI: Use the snmp-agent trap enable user-group max-count-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable user-group max-count-threshold command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.12.4.1.1 (hh3cUserGroupUsedNum) |
Current number of user groups. |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.12.4.1.2 (hh3cUserGroupNumThreshold) |
Maximum number of user groups. |
N/A |
Integer32 |
Recommended action
1.Use the display user-group command in any view to view local user group information and analyze whether unused user groups exist.
- If unused user groups exist, proceed to step 2.
- If no unused user group exists, proceed to step 3.
2.Use the undo user-group command in system view to deleted unused user groups.
3.Collect alarm, log, and configuration information, and contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.12.4.0.2 |
Number of user groups dropped to 90% of the maximum number. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of user groups configured on the device drops below 90% of the maximum value.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Integer32 |
Recommended action
