- H3C MSR Routers Configuration Examples(Web)-R6728-6W100
- 01-Web login Configuraiton Examples
- 02-Administrator Account Configuration Examples
- 03-Static Routing Configuration Examples
- 04-Cloud Connection Configuration Examples
- 05-Software Upgrade Examples
- 06-Port Mapping Configuration Examples
- 07-IPsec VPN Configuration Examples
- 08-L2TP VPN Configuration Examples
- 09-WLAN AC Configuration Examples
07-IPsec VPN Configuration Examples | 577.08 KB |
Introduction
The following information provides IPsec VPN configuration examples based on IKE exchange in the following modes:
· Main mode—Applicable in scenarios where both the WAN interfaces on the headquarters and branch gateway routers use fixed public addresses.
· Aggressive mode—Applicable in scenarios where the WAN interface on the headquarters or branch gateway router uses dynamic public addresses (for example, DHCP-assigned IP addresses).
Refer to the main mode or aggressive mode configuration example in this document to configure the IPsec VPN according to your actual network.
Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPsec VPN.
Software versions used
The configuration examples were created and verified on Release 6728P22 of the MSR830-10HI router and Release 6728P22 of the MSR3600-28-G-DP router.
Example: Configuring main mode IPsec VPN
As shown in Figure 1, the headquarters gateway Router A and branch gateway Router B each use a single WAN interface with a fixed public address to connect to the Internet. The headquarters and the branch communicate with each other over the Internet. To protect data flows between the headquarters and the branch, establish an IPsec tunnel between the gateway routers. Configure the network as follows:
· Configure Router A and Router B to use preshared key 123456TESTplat&! for authentication.
· Specify the encapsulation mode as tunnel and the security protocol as ESP.
· Specify the encryption algorithm as 3DES-CBC and the authentication algorithm as MD5.
Analysis
To configure IPsec VPN, complete the following configurations on Router A and Router B:
1. Configure basic WAN and LAN settings.
a. Specify the IP address and gateway of the WAN interface on each router.
b. Modify the default IP address of VLAN 1 on each router.
2. Add an IPsec policy.
Because the WAN interface on each router uses a fixed IP address to connect to the Internet, configure the IPsec policy to use the main mode for phase 1 IKE negotiation.
After you modify the default IP address of VLAN 1, the Web connection fails. You must use the modified IP address to log in to the Web interface again.
If your network uses dual-WAN or multiple-WAN access, configure a static route on each router to direct the traffic destined for the peer internal network to the WAN interface specified in the IPsec policy. In this example, the routers use single-WAN access. No static route configuration is needed. The routers will generate a default route to direct all traffic to the egress gateway.
Make sure both sides of the IPsec tunnel use the same preshared key, security protocol, encryption algorithm, authentication algorithm, and encapsulation mode.
Procedures
Configuring Router A
Modifying the IP address of VLAN 1
# Modify the VLAN interface IP address of VLAN 1 to 10.1.1.1/24.
1. Log in to the Web interface. From the navigation pane, select Network > LAN Settings.
2. Click the Edit icon in the Operation column for VLAN 1.
3. In the Interface IP address field, enter 10.1.1.1.
4. In the Subnet mask field, enter 255.255.255.0.
5. Use the default settings for other parameters, and then click Apply.
Figure 2 Modifying VLAN 1
Configuring the WAN interface (WAN0) to connect to the Internet
# Configure a single WAN interface using a fixed IP address.
1. From the navigation pane, select Network > WAN Settings.
2. On the Scene page that opens, select Single-WAN scenario, and then select WAN0(GE0) in the Line1 field.
3. Click Apply.
Figure 3 Configuring WAN scenario
4. Click the WAN Settings tab.
5. Click the Edit icon in the Operation column for WAN0(GE0).
6. In the Connection mode field, select Fixed IP.
7. In the IP address field, enter 2.2.2.1.
8. In the Subnet mask field, enter 255.255.255.0.
9. In the Gateway field, enter 2.2.2.254.
10. Use the default settings for other parameters, and then click Apply.
Figure 4 Modifying WAN settings
Configuring the IPsec policy
# Specify the network mode as the headquarters gateway and the IKE negotiation mode as the main mode.
1. From the navigation pane, select Virtual Network > IPsec VPN.
2. Click Add.
3. On the page that opens, configure the following parameters:
¡ Specify the name as map1.
¡ Select WAN0(GE0) in the Interface field.
¡ Select Headquarters gateway in the Network mode field.
¡ Enter 123456TESTplat&! in the Preshared key field.
Figure 5 Adding the IPsec policy
4. Click Show advanced settings. On the page that opens, configure the following parameters:
¡ In the Negotiation mode field, select Main mode.
¡ In the Local ID field, select IP address, and then enter 2.2.2.1.
¡ In the DPD field, select Enable, and specify the DPD try interval as 30.
This feature is disabled by default. To timely monitor the availability of the IPsec tunnel, enable this feature.
¡ In the Algorithm suite field, select Customize.
¡ In the Authentication algorithm field, select MD5.
¡ In the Encryption algorithm field, select 3DES-CBC.
¡ Use the default settings for other parameters.
Figure 6 Configuring advanced IKE settings
5. Click the IPsec settings tab, and then configure the following parameters:
¡ In the Algorithm combination field, select Customize.
¡ In the Security protocol field, select ESP.
¡ In the ESP authentication algorithm field, select MD5.
¡ In the ESP encryption algorithm field, select 3DES-CBC.
¡ In the Encapsulation mode field, select Tunnel.
Figure 7 Configuring advanced IPsec settings
6. Click Back to basic settings to go back to the Add IPsec Policy page.
7. Click Apply.
Configuring Router B
# Modify the VLAN interface IP address of VLAN 1 to 10.1.2.1/24.
2. From the navigation pane, select Network > LAN Settings.
3. Click the Edit icon in the Operation column for VLAN 1.
4. In the Interface IP address field, enter 10.1.2.1.
5. In the Subnet mask field, enter 255.255.255.0.
6. Use the default settings for other parameters, and then click Apply.
Figure 8 Modifying VLAN 1
Configuring the WAN interface (WAN3) to connect to the Internet
2. On the Scene page that opens, select Single-WAN scenario, and then select WAN3(GE1/0/3) in the Line1 field.
3. Click Apply.
Figure 9 Configuring WAN scenario
5. Click the Edit icon in the Operation column for WAN3(GE1/0/3).
7. In the IP address field, enter 2.2.3.1.
9. In the Gateway field, enter 2.2.3.254.
Figure 10 Modifying WAN settings
# Specify the network mode as the branch gateway and the IKE negotiation mode as the main mode.
2. Click Add.
¡ Select WAN3(GE1/0/3) in the Interface field.
¡ Select Branch gateway in the Network mode field and specify the peer gateway address as 2.2.2.1.
¡ In
the Protected data flows area, select IP as the protocol to be protected, enter 10.1.2.0/255.255.255.0 in
the Local subnet/mask filed and 10.1.1.0/255.255.255.0 in the Peer subnet/mask
field, and then click the icon.
Figure 11 Adding the IPsec policy
¡ In the Local ID field, select IP address, and then enter 2.2.3.1.
¡ In the Remote ID field, select IP address, and then enter 2.2.2.1.
Figure 12 Configuring advanced IKE settings
Figure 13 Configuring advanced IPsec settings
7. Click Apply.
1. Verify that Host A can ping Host B successfully.
C:\Users\abc>ping 10.1.2.2
Ping 10.1.2.2 (10.1.2.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.2.2: icmp_seq=0 ttl=254 time=2.137 ms
56 bytes from 10.1.2.2: icmp_seq=1 ttl=254 time=2.051 ms
56 bytes from 10.1.2.2: icmp_seq=2 ttl=254 time=1.996 ms
56 bytes from 10.1.2.2: icmp_seq=3 ttl=254 time=1.963 ms
56 bytes from 10.1.2.2: icmp_seq=4 ttl=254 time=1.991 ms
--- Ping statistics for 10.1.2.2 ---
round-trip min/avg/max/std-dev = 1.963/2.028/2.137/0.062 ms
C:\Users\abc>
2. Click Virtual Network > IPsec VPN > Monitor Information on the Web interface to verify that the IPsec tunnel is successfully established. Status Active indicates successful establishment of the IPsec tunnel.
Example: Configuring aggressive mode IPsec VPN
As shown in Figure 14, the headquarters gateway Router A uses a single WAN interface with a fixed public address to connect to the Internet. The branch gateway Router B uses a DHCP-assigned IP address to connect to the Internet. The headquarters and the branch communicate with each other over the Internet. To protect data flows between the headquarters and the branch, establish an IPsec tunnel between the routers. Configure the network as follows:
Analysis
Because one side of the IPsec tunnel (Router B) uses DHCP-assigned IP addresses, to successfully set up the IPsec tunnel, configure the IPsec policy to use aggressive mode for phase 1 IKE negotiation.
Procedures
Figure 15 Modifying VLAN 1
Configuring the WAN interface (WAN 0) to connect to the Internet
3. Click Apply.
Figure 16 Configuring WAN scenario
Figure 17 Modifying WAN settings
# Specify the network mode as the headquarters gateway and the IKE negotiation mode as the aggressive mode.
2. Click Add.
Figure 18 Adding the IPsec policy
¡ In the Negotiation mode field, select Aggressive mode.
¡ In the Local ID field, select FDQN, and then enter the FQDN name (for example, www.test.com).
Figure 19 Configuring advanced IKE settings
Figure 20 Configuring advanced IPsec settings
7. Click Apply.
Figure 21 Modifying VLAN 1
Configuring the WAN interface (WAN 3) to connect to the Internet
# Configure a single WAN interface using DHCP-assigned IP addresses.
3. Click Apply.
Figure 22 Configuring WAN scenario
6. In the Connection mode field, select DHCP.
7. Use the default settings for other parameters, and then click Apply.
Figure 23 Modifying WAN settings
# Specify the network mode as the branch gateway and the IKE negotiation mode as the aggressive mode.
2. Click Add.
¡ In
Figure 24 Adding the IPsec policy
¡ In the Local ID field, select FDQN, then enter the FQDN name (for example, www.test1.com).
¡ In the Remote ID field, select FDQN, and then enter FQDN name www.test.com.
¡ In the DPD field, select Enable, and specify the DPD retry interval as 30.
Figure 25 Configuring advanced IKE settings
Figure 26 Configuring advanced IPsec settings
7. Click Apply.
C:\Users\abc>
