00-Preface | 25.68 KB |
Preface
This guide describes the procedures for deploying host nodes on the simulation network and deploying the simulation service on the controller.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
