01-H3C Access Controllers Introduction | 52.21 KB |
New H3C Technologies Co., Ltd. http://www.h3c.com
Document version: 6W100-20220830 |
WX5800H Series Access Controllers
WX3800H Series Access Controllers
WX1800H Series Access Controllers
VAC1000 Series Access Controllers
Item |
WX5860H |
Operating system |
Comware 7 |
Interfaces |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 1000BASE-T autosensing Ethernet ports · 12 × 10GBASE-R SFP+ ports · 4 × 40GBase-R QSFP+ ports |
Supported APs by default |
0 |
Maximum number of supported APs |
3072 |
Supported AP license BOM codes |
· 3132A09W (1 AP) · 3130A1L9 (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) · 3130A1LE (1024 APs) |
Maximum number of wireless users |
32768 |
Maximum number of local users that can be configured |
32768 |
IRF |
Supported |
Item |
WX3820H |
WX3840H |
Operating system |
Comware 7 |
Comware 7 |
Interfaces |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 100/1000 BASE-T autosensing Ethernet copper ports · 8 × 100BASE-FX/1000BASE-X SFP ports · 2 × 10GBASE-R SFP+ ports |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 100/1000BASE-T autosensing Ethernet copper ports · 1 × 100/1000BASE-T management Ethernet port · 8 × 100BASE-FX/1000BASE-X SFP ports · 2 × 10GBASE-R SFP+ ports |
0 |
0 |
· 512 (Recommended for local forwarding) · 256 (Recommended for centralized forwarding) |
1024 |
· 3132A09W(1 AP) · 3130A1L9(1 AP) · 3130A2HB(4 AP) · 3130A1LA(8 AP) · 3130A1LB(16 AP) · 3130A1LC(32 AP) · 3130A2HC(64 AP) · 3130A1LD(128 AP) · 3130A1QM(512 AP) |
8192 |
20480 |
8192 |
20480 |
IRF |
Supported |
Supported |
Item |
WX1804H-PWR |
WX1810H-PWR |
WX1820H |
WX1840H |
Operating system |
Comware 7 |
Comware 7 |
Comware 7 |
Comware 7 |
Interfaces |
· One Console port, 9600 bps (default) to 115200 bps · 5 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port · LAN ports support PoE |
· One Console port, 9600 bps (default) to 115200 bps · 12 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port · LAN ports support PoE |
· One Console port, 9600 bps (default) to 115200 bps · 5 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port |
· One Console port, 9600 bps (default) to 115200 bps · 8 × 100/1000BASE-T autosensing Ethernet copper port, including six LAN ports and two WAN ports · 1000BASE-X SFP ports 5 and 6 form combo interfaces with 100/1000BASE-T autosensing Ethernet copper ports LAN 5 and LAN 6, respectively. |
4 |
10 |
20 |
20 |
4 |
10 |
20 |
· 128 (Recommended for local forwarding) · 64 (Recommended for centralized forwarding) |
Not supported |
Not supported |
Not supported |
· 3132A09W (1 AP) · 3130A1L9 (1 AP) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) |
128 |
320 |
640 |
1280 |
128 |
320 |
640 |
1280 |
IRF |
Not supported |
Not supported |
Not supported |
Not supported |
WBC Series Access Controllers
Item |
WBC580 G2 |
Operating system |
Comware 7 |
Interfaces |
· 2 × embedded 1000 Mbps Ethernet ports · 2 × 10 Gbps Ethernet fiber ports · 1 × HDM dedicated network port |
0 |
2048 |
· 3130A1L9 (1 APs) · 3130A2HB (4 APs) · 3130A1LA (8 APs) · 3130A1LB (16 APs) · 3130A1LC (32 APs) · 3130A2HC (64 APs) · 3130A1LD (128 APs) · 3130A1QM (512 APs) · 3130A1LE (1024 APs) |
32768 |
32768 |
IRF |
Not supported |
Item |
VAC1000 |
Operating system |
Comware 7 |
32 (180-day trial license) |
2048 |
· 3130A1Q9 (8 APs, 1-year) · 3130A1QA (8 APs, 3-year) · 3130A1QB (8 APs, permanent) · 3130A1QC (8 APs, 1-year) · 3130A1QD (8 APs, 3-year) · 3130A1QE (8 APs, permanent) · 3130A1QG (8 APs, 1-year) · 3130A1QH (8 APs, 3-year) · 3130A1QF (8 APs, permanent) |
32768 |
32768 |
IRF |
Not supported |
