03-H3C PoE Adapter Introduction | 96.23 KB |
New H3C Technologies Co., Ltd. http://www.h3c.com
Document version: 6W100-20220830 |
About the ADP060-55V-PoE-GL PoE adapter
H3C PoE adapter Introduction
CAUTION: The available H3C PoE adapter models vary by country and region. This document is for generic reference only. To avoid damages, contact the local H3C sales agent or engineers when using an H3C PoE adapter. |
This document provides the specifications and views for H3C PoE adapters.
ADP060-55V-PoE-GL
The ADP060-55V-PoE-GL (part number: 9801A1PJ) is a two-port PoE adapter. It delivers optimum performance over a wide range of temperatures and can be used indoors and outdoors (because it is not waterproof, waterproof measures must be taken for outdoor use). You can use it to provide PoE power to a network endpoint over a Category 5e cable on a 10/100/1000M network.
IMPORTANT: As a best practice, do not connect it to two APs simultaneously. |
Figure 1 ADP060-55V-PoE-GL PoE adapter views
(1) PoE ports |
(2) 10/100/1000M Ethernet ports |
(13) AC power input receptacle |
Table 1 ADP060-55V-PoE-GL PoE adapter ports description
Port type |
Compliant standards and protocols |
PoE1/PoE2 |
N/A |
Signal & power output port, used for connecting a PD such as AP. |
LAN1/LAN2 |
· IEEE802.3 · IEEE802.3u |
Signal input port, used for connecting an Ethernet switch. |
N/A |
Used for connecting the local power source. |
Technical specifications
Table 2 ADP060-55V-PoE-GL power adapter technical specifications
Item |
Specification |
Dimensions (H × W × D) |
46 × 208 × 85 mm (1.81 × 8.19 × 3.35 in) |
Weight |
0.437 kg (0.96 lb) |
Rated input voltage |
100 VAC to 240 VAC @ 50/60 Hz |
Max input current |
1.5 A (115 VAC, fully loaded) 0.75 A (230 VAC, fully loaded) |
Rated output voltage |
55 VDC |
Rated output current |
1.1 A |
Total output power |
≤ 60 W |
Temperature |
Operating: –30°C to +55°C (–22°F to +131°F) Storage: –30°C to +70°C (–22°F to +158°F) |
Ambient humidity |
Operating: 5% RH to 95% RH, noncondensing Storage: 10% RH to 90% RH, noncondensing |
Security compliance |
CE/CCC/UL |
AC power cord |
Removable, C14 connector Whether the power cord is provided with the PoE adapter varies by region. |
Connecting the PoE adapter
The signal input port works in conjunction with the signal & power output port numbered the same. LAN 1 must work in conjunction with PoE 1 and LAN 2 must work in conjunction with PoE 2.
To connect a signal & power output port to an AP, make sure you connect the signal input port numbered the same with the signal & power output port to the Ethernet switch.
Figure 2 Connecting the ADP060-55V-PoE-GL PoE adapter
