11-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Configuration Guides-R6615Pxx-6W10111-Network Management and Monitoring Configuration Guide
06-Network synchronization configuration
06-Network synchronization configuration 73.01 KB
Configuring synchronous Ethernet
About synchronous Ethernet
Synchronous Ethernet (SyncE) provides high-quality frequency synchronization on Ethernet at the physical layer. It can provide the same level of clock precision as SONET/SDH.
Transferring frequency signals at the physical layer, SyncE functions regardless of the network conditions such as congestion, packet loss, and delay.
Quality levels of clocks
SyncE devices use an Ethernet synchronization messaging channel (ESMC) to transmit the quality level (QL) of their system clocks. A SyncE device uses QL information to select the optimal clock reference from all available timing sources for its system clock.
The following are the QLs supported by the device, from the highest to the lowest:
·     PRC—G.811 primary reference clock.
·     SSU-A—G.812 primary-level SSU.
·     SSU-B—G.812 second-level SSU.
·     SEC—SDH equipment clock.
·     DNU—Do not use for synchronization.
·     UNK—Synchronization quality unknown.
DNU clock sources cannot participate in clock reference selection.
Clock reference selection
The system clock uses the clock reference selected with the highest QL from the following sources. If these sources have the same QL, the system clock selects the clock reference by priority, from the highest to the lowest:
·     External clock sources.
·     Line clock sources input from interfaces.
·     Internal clock sources.
The system clock uses the QL of the selected reference. Clock reference selection process starts each time the QL of a source is updated.
If QLs are the same on two interfaces, the clock source input from the lower-numbered interface has priority.
System clock QL distribution and SyncE port input QL updating
Distribution of the system clock QL
When distributing the QL of the system clock, the system uses the following rules:
·     If the clock reference is not from a SyncE port, the system distributes the QL out of all SyncE ports.
·     If the clock reference is from a SyncE port, the system distributes the QL out of all SyncE ports except for the reference input port. To prevent timing loops, the sent QL is DNU on the timing reference input port.
Input QL updating on SyncE ports
The default input QL is Unknown on a SyncE port. The port updates its input QL when it receives a quality level higher than Unknown. The Unknown level will be restored if the port does not receive ESMC packets within 5 seconds after the update.
Protocols and standards
·     ITU-T G.781, Synchronization Layer Functions
·     ITU-T G.813, Timing characteristics of SDH equipment slave clocks (SEC)
·     ITU-T G.823, The control of jitter and wander within digital networks which are based on the 2048 kbit/s hierarchy
·     ITU-T G.8261, Timing and Synchronization Aspects in Packet Networks
·     ITU-T G.8262, Timing Characteristics of a Synchronous Ethernet Equipment Slave Clock (EEC)
·     ITU-T G.8264/Y.1364, Distribution of Timing Information through Packet Networks
Configuring SyncE on an Ethernet interface
2.     Enter Layer 2 Ethernet interface view or Layer 3 Ethernet interface view.
3.     Enable the synchronous mode.
synchronous mode
By default, Ethernet interfaces are in the non-synchronous mode. An interface can participate in the clock reference selection only when it is in the synchronous mode.
4.     Enable ESMC to transmit QL information.
esmc enable
By default, ESMC is disabled on Ethernet interfaces.
Setting the clock mode on a copper SyncE GE port
‌About this task
Configure the clock mode for a copper SyncE GE port based on its time synchronization direction.
By default, a copper SyncE GE port automatically negotiates its clock mode with the remote end. To avoid a negotiation result that conflicts with your clock synchronization trail design, manually set the clock mode.
·     To derive timing from the upstream clock, set the clock mode to slave.
·     To provide timing for the downstream clock, set the clock mode to master.
3.     Set the clock mode.
synce state { master | slave }
By default, the clock mode of a copper SyncE GE port is automatically negotiated.
Display and maintenance commands for SyncE
Display ESMC information.
display esmc [ interface interface-type interface-number ]
Synchronous Ethernet configuration examples
Example: Configuring synchronous Ethernet
As shown in Figure 1, configure SyncE between the devices.
Figure 1 Network diagram
# On Device A, enable the synchronous mode and ESMC on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] synchronous mode
[DeviceA-Ten-GigabitEthernet1/0/1] esmc enable
# On Device B, enable the synchronous mode and ESMC on Ten-GigabitEthernet 1/0/1.
[DeviceB-Ten-GigabitEthernet1/0/1] synchronous mode
[DeviceB-Ten-GigabitEthernet1/0/1] esmc enable
# Verify that ESMC is enabled on both Device A and Device B when they are connected to their respective clock references. The clock QLs of Device A and Device B are QL-PRC and QL-SEC, respectively. Device A provides more precise timing than Device B.
[DeviceA] display esmc
Interface   : Ten-GigabitEthernet1/0/1
Mode        : Synchronous
ESMC status : Enable
Port status : Up
Duplex mode : Full
QL received : QL-SEC
QL sent     : QL-PRC
ESMC information packets received : 2195
ESMC information packets sent     : 6034
ESMC event packets received       : 1
ESMC event packets sent           : 1
ESMC information rate             : 1 packets/sec
ESMC expiration                   : 5 seconds
[DeviceB] display esmc
Mode        : Synchronous
Port status : Up
Duplex mode : Full
QL received : QL-PRC
QL sent     : QL-SEC
ESMC information packets received : 6034
ESMC information packets sent     : 2195
# Verify that QL information is exchanged correctly after synchronization between Device A and Device B. Ten-GigabitEthernet1/0/1 on Device B becomes a reference input port. The clock QL sent from Device B to Device A changes to QL-DNU.
Mode        : Synchronous
Port status : Up
Duplex mode : Full
QL received : QL-DNU
QL sent     : QL-PRC
ESMC information packets received : 2573
ESMC information packets sent     : 6412
Mode        : Synchronous
Port status : Up
Duplex mode : Full
QL sent     : QL-DNU
ESMC information packets received : 6412
ESMC information packets sent     : 2573
