H3C S6520X-SI Switch Series Installation Guide-6W106
HomeSupportSwitchesS6520X-SI SeriesInstall & UpgradeInstallation GuidesH3C S6520X-SI Switch Series Installation Guide-6W106
02-Hardware Information and Specifications docx
1 Product models and technical specifications· 1-1
Product models· 1-1
Technical specifications· 1-1
Non-PoE models· 1-1
PoE models· 1-4
2 Chassis views· 2-6
S6520X-16ST-SI 2-6
S6520X-24ST-SI 2-7
S6520X-10XT-SI 2-8
S6520X-16XT-SI 2-8
S6520X-18C-SI 2-9
S6520X-26C-SI 2-10
S6520X-26MC-SI 2-11
S6520X-26MC-UPWR-SI 2-12
S6520X-26XC-UPWR-SI 2-13
S6520X-54XC-UPWR-SI 2-14
3 Appendix B Removable components and compatibility matrixes· 3-1
Removable power supplies· 3-3
Removable fan trays· 3-4
Expansion modules· 3-4
Connecting cables to the copper ports on the interface cards· 3-6
4 Appendix C Ports and LEDs· 4-1
Ports· 4-1
Console port 4-1
Management Ethernet port 4-1
USB port 4-1
SFP port 4-2
SFP+ port 4-2
SFP28 port 4-6
QSFP+ port 4-8
10/100/1000BASE-T autosensing Ethernet port 4-10
1/10BASE-T autosensing Ethernet port 4-11
5G/2.5G/1000/100BASE-T autosensing Ethernet port 4-11
5G/2.5G/1000BASE-T autosensing Ethernet port 4-12
10G/5G/2.5G/1000BASE-T autosensing Ethernet port 4-12
10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port 4-12
Combo interface· 4-13
LEDs· 4-13
System status LED· 4-13
Power supply status LED· 4-13
Mode LED· 4-14
Management Ethernet port LED· 4-14
1/10GBASE-T autosensing Ethernet port LED· 4-14
5G/2.5G/1000/100BASE-T autosensing Ethernet port LED· 4-15
10G/5G/2.5G/1000BASE-T autosensing Ethernet port LED· 4-15
10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port LED· 4-16
SFP+ port LED· 4-16
Expansion module status LED· 4-17
Port status LED on an expansion module· 4-17
Fan tray status LED· 4-17
5 Appendix D Cooling system·· 5-1
Product models
The S6520X-SI switch series includes the following models:
·     S6520X-16ST-SI
·     S6520X-24ST-SI
·     S6520X-10XT-SI
·     S6520X-16XT-SI
·     S6520X-18C-SI
·     S6520X-26C-SI
·     S6520X-26MC-SI
·     S6520X-26MC-UPWR-SI
·     S6520X-26XC-UPWR-SI
·     S6520X-54XC-UPWR-SI
Non-PoE models
Table1-1 Technical specifications of non-PoE switches (1)
Item
S6520X-16ST-SI
S6520X-24ST-SI
S6520X-18C-SI
S6520X-26C-SI
S6520X-26MC-SI
Dimensions (H × W × D)
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in)
Weight
≤ 5 kg (11.02 lb)
≤ 5 kg (11.02 lb)
≤ 5 kg (11.02 lb)
≤ 5 kg (11.02 lb)
6 kg (13.23 lb)
Console port
·     1 × micro USB console port
·     1 × serial console port
·     Only the micro USB console port is available when you connect both ports.
USB port
1
1
1
1
1
1
1
1
1
1
SFP+ port
16 (The two highest-numbered SFP+ ports form combo interfaces with their corresponding 1/10GBASE-T autosensing Ethernet ports, respectively.)
24 (The two highest-numbered SFP+ ports form combo interfaces with their corresponding 1/10GBASE-T autosensing Ethernet ports, respectively.)
16
24
N/A
1/10G BASE-T autosensing Ethernet port
2
2
N/A
N/A
N/A
N/A
N/A
N/A
N/A
24
Expansion slot
N/A
N/A
1, on the rear panel
Power supply slot
2, on the rear panel
Input voltage
PSR75-12A (not supported on S6520X-26MC-SI):
·     AC input
¡     Rated voltage range: 100 to 240 VAC @ 50/60 Hz
¡     Max voltage range: 90 to 290 VAC @ 47 to 63 Hz
·     High-voltage DC input
¡     Rated voltage range: 240 VDC
¡     Max voltage range: 180 to 320 VDC
PSR150-A1:
·     Rated voltage range: 100 to 240 VAC @ 50/60 Hz
·     Max voltage range: 90 to 264 VAC @ 47 to 63 Hz
PSR150-D1:
You can use a –48 VDC power source in the equipment room or an H3C RPS (RPS800-A or RPS1600-A) for the PSR150-D1 power supply.
·     Rated voltage range: –48 VDC to –60 VDC
·     Max voltage range: –36 VDC to –72 VDC
Typical power consumption (30% flow, tested as required by CQC)
41 W
51 W
51 W
64 W
97 W
Maximum power consumption (100% flow, and fans at full speed)
59 W
73 W
97 W
113 W
134 W
Chassis leakage current compliance
UL60950-1/EN60950-1/IEC60950-1/GB4943.1
Melting current of power supply fuse
·     PSR75-12A: 3.15 A/250 V (not supported on S6520X-26MC-SI)
·     PSR150-A1: 6.3 A/250 V
·     PSR150-D1: 8 A/250 V
Operating temperature
–5°C to +45°C (23°F to 113°F)
Humidity
5% RH to 95% RH, noncondensing
Fire resistance compliance
Table1-2 Technical specifications of non-PoE switches (2)
Item
S6520X-10XT-SI
S6520X-16XT-SI
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
Weight
≤ 5 kg (11.02 lb)
≤ 5 kg (11.02 lb)
Console port
USB port
1
1
1
1
SFP+ port
2
2
8
14
Input voltage
Maximum power consumption (100% traffic, fan trays at full speed)
37.9 W
57.9 W
Typical power consumption (30% traffic, tested according to CQC)
N/A
N/A
Minimum power consumption
18 W
23 W
38 W
58 W
6.3 A/250 V
Operating humidity
PoE models
Table1-3 Technical specifications of PoE switches
Item
S6520X-26MC-UPWR-SI
S6520X-26XC-UPWR-SI
S6520X-54XC-UPWR-SI
43.6 × 440 × 460 mm (1.72 × 17.32 × 18.11 in)
Weight
≤ 8.7 kg (19.18 lb)
≤ 10 kg (22.05 lb)
Console port
USB port
1
1
QSFP+ port
N/A
N/A
4
24
N/A
N/A
N/A
24
48
Expansion slot
Power supply slot
Fan tray slot
N/A
2
3
Input voltage
PSR360-56A/PSR720-56A:
PSR1110-56A:
·     Rated voltage range: 115 to 240 VAC @ 50/60 Hz
·     Max voltage range: 102.5 to 264 VAC @ 47 to 63 Hz
PSR560-56D:
You can use a –48 VDC power source in the equipment room or an H3C RPS (RPS1600-A) for the PSR560-56D power supply.
97 W
90 W
165 W
Maximum power consumption (100% flow and fans at full speed)
Non-PoE: 126 W
PoE: 2428 W (including 2040 W for PoE)
Non-PoE: 148 W
PoE: 2385 W (including 2010 W for PoE)
Non-PoE: 232 W
PoE: 2333 W (including 1920 W for PoE)
·     PSR360-56A: 6.3 A/250 V
·     PSR720-56A: 15 A/250 V
·     PSR1110-56A: 15 A/250 V
·     PSR560-56D: 30 A/75 V
Humidity
Table1-4 PoE capabilities for S6520X-26MC-UPWR-SI/S6520X-26XC-UPWR-SI/S6520X-54XC-UPWR-SI
Power supply configuration
S6520X-26MC-UPWR-SI
S6520X-26XC-UPWR-SI
S6520X-54XC-UPWR-SI
Total power
Max. power by a single port
Total power
Total power
2 × PSR1110-56A
2040 W
90 W
2010 W
90 W
1920 W
90 W
1 × PSR1110-56A and 1 × PSR720-56A
1650 W
90 W
1620 W
90 W
1530 W
90 W
1 × PSR1110-56A and 1 × PSR560-56D
1500 W
90 W
1440 W
90 W
1350 W
90 W
1 × PSR1110-56A and 1 × PSR360-56A
1260 W
90 W
1260 W
90 W
1170 W
90 W
1 × PSR1110-56A
900 W
90 W
900 W
90 W
810 W
90 W
2 × PSR720-56A
1260 W
90 W
1230 W
90 W
1140 W
90 W
1 × PSR720-56A and 1 × PSR560-56D
1100 W
90 W
1050 W
90 W
960 W
90 W
1 × PSR720-56A and 1 × PSR360-56A
900 W
90 W
870 W
90 W
780 W
90 W
1 × PSR720-56A
540 W
90 W
510 W
90 W
420 W
90 W
2 × PSR560-56D
900 W
90 W
900 W
90 W
810 W
90 W
1 × PSR560-56D and 1 × PSR360-56A
750 W
90 W
690 W
90 W
600 W
90 W
1 × PSR560-56D
390 W
90 W
360 W
90 W
270 W
90 W
2 × PSR360-56A
540 W
90 W
510 W
90 W
420 W
90 W
1 × PSR360-56A
210 W
90 W
180 W
90 W
90 W
90 W
2 Chassis views
S6520X-16ST-SI
Figure2-1 Front panel
(1) SFP+ port
(2) SFP+ port LED
(3) Power supply 1 status LED (PWR1)
(4) Management Ethernet port LED (LINK/ACT)
(5) Management Ethernet port
(6) Console port (CONSOLE)
(7) Micro USB console port
(8) Mode button
(9) USB port
(10) 1/10GBASE-T autosensing Ethernet port
(11) Mode LED (MODE)
(12) System status LED (SYS)
(13) Power supply 2 status LED (PWR2)
(14) 1/10GBASE-T autosensing Ethernet port LED
Figure2-2 Rear panel
(1) Grounding screw
(2) Power supply 1 (PWR1)
(3) Power supply 2 (PWR2)
An S6520X-16ST-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-2, two PSR75-12A AC power supplies are installed in the power supply slots.
S6520X-24ST-SI
Figure2-3 Front panel
(1) SFP+ port
(2) SFP+ port LED
(8) Mode button
(9) USB port
Figure2-4 Rear panel
(1) Grounding screw
An S6520X-24ST-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two PSR75-12A AC power supplies are installed in the power supply slots.
S6520X-10XT-SI
Figure2-5 Front panel
(1) 10/5G/2.5G/1000BASE-T autosensing Ethernet port
(2) 10/5G/2.5G/1000BASE-T autosensing Ethernet port LED
(3) SFP+ port LED
(4) System status LED (SYS)
(5) Management Ethernet port LED (LINK/ACT)
(6) Management Ethernet port
(7) Console port
(8) Mode button
(9) USB port
(10) Micro USB console port
(12) SFP+ port
Figure2-6 Rear panel
(1) Grounding screw
(2) AC power receptacle
S6520X-16XT-SI
Figure2-7 Front panel
(3) SFP+ port LED
(7) Console port
(8) Mode button
(9) USB port
(12) SFP+ port
Figure2-8 Rear panel
(1) Grounding screw
S6520X-18C-SI
Figure2-9 Front panel
(1) SFP+ port
(2) SFP+ port LED
(7) Console port (CONSOLE)
(8) Micro USB console port
(9) Mode button
(10) USB port
(11) MODE LED
(12) Expansion module status LED (SLOT)
Figure2-10 Rear panel
(1) Grounding screw
(2) Expansion module
(3) Power supply 1 (PWR1)
(4) Power supply 2 (PWR2)
An S6520X-18C-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-10, two PSR75-12A AC power supplies are installed in the power supply slots.
An S6520X-18C-SI switch comes with a filler panel in the expansion slot. You can select an expansion module for the switch as required. In Figure2-10, an LSWM2SP2PM interface card is installed in the expansion slot.
S6520X-26C-SI
Figure2-11 Front panel
(1) SFP+ port
(2) SFP+ port LED
(9) Mode button
(10) USB port
Figure2-12 Rear panel
(1) Grounding screw
An S6520X-26C-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-12, two PSR75-12A AC power supplies are installed in the power supply slots.
An S6520X-26C-SI switch comes with a filler panel in the expansion slot. You can select an expansion module for the switch as required. In Figure2-12, an LSWM2SP2PM interface card is installed in the expansion slot.
S6520X-26MC-SI
Figure2-13 Front panel
(1) 5G/2.5G/1000/100BASE-T autosensing Ethernet port
(2) 5G/2.5G/1000/100BASE-T autosensing Ethernet port LED
(6) Mode LED (MODE)
(7) Expansion module status LED (SLOT)
(8) Power supply 2 status LED (PWR2)
(9) USB port
(10) Mode button
(11) Micro USB console port
(12) Console port (CONSOLE)
(13) Management Ethernet port
Figure2-14 Rear panel
(1) Grounding screw
(2) Expansion card
An S6520X-26MC-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-14, two PSR75-12A AC power supplies are installed in the power supply slots.
An S6520X-26MC-SI switch comes with a filler panel in the expansion slot. You can select an expansion module for the switch as required. In Figure2-14, an LSWM2SP2PM interface card is installed in the expansion slot.
S6520X-26MC-UPWR-SI
Figure2-15 Front panel
(6) Mode LED (MODE)
(9) USB port
(10) Mode button
Figure2-16 Rear panel
(1) Grounding screw
An S6520X-26MC-UPWR-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-16, two PSR720-56A AC power supplies are installed in the power supply slots.
An S6520X-26MC-UPWR-SI switch comes with a filler panel in the expansion slot. You can select an expansion module for the switch as required. In Figure2-16, an LSWM2SP2PM interface card is installed in the expansion slot.
S6520X-26XC-UPWR-SI
Figure2-17 Front panel
(1) 10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port
(2) 10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port LED
(3) Console port (CONSOLE)
(4) Mode button
(5) System status LED (SYS)
(6) Expansion module status LED (SLOT)
(7) Mode LED (MODE)
(9) USB port
(10) Management Ethernet port LED (LINK/ACT)
(11) Management Ethernet port
Figure2-18 Rear panel
(1) Grounding screw
(2) Serial label pull tab
(3) Fan tray 1 (FAN1)
(4) Expansion module
(5) Fan tray 2 (FAN2)
(6) Power supply 1 (PWR1)
(7) Power supply 2 (PWR2)
The ESN serial number and MAC address of the S6520X-26XC-UPWR-SI switch can be found on the serial label pull tab.
An S6520X-26XC-UPWR-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-18, two PSR720-56A AC power supplies are installed in the power supply slots.
The S6520X-26XC-UPWR-SI switch comes with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-18, two LSPM1FANSB fan trays are installed in the fan tray slots.
An S6520X-26XC-UPWR-SI switch comes with a filler panel in the expansion slot. You can select an expansion module for the switch as required. In Figure2-18, an LSWM2SP2PM interface card is installed in the expansion slot.
S6520X-54XC-UPWR-SI
Figure2-19 Front panel
(3) QSFP+ port LED
(4) Console port (CONSOLE)
(5) Mode button
(6) System status LED (SYS)
(8) Mode LED (MODE)
(9) Micro USB console port
(10) USB port
(11) Management Ethernet port LED (LINK/ACT)
(12) Management Ethernet port
(13) QSFP+ port
Figure2-20 Rear panel
(1) Grounding screw
(2) Fan tray 1 (FAN1)
(3) Expansion module
(4) Fan tray 2 (FAN2)
(5) Fan tray 3 (FAN3)
(8) Serial label pull tab
The ESN serial number and MAC address of the S6520X-54XC-UPWR-SI switch can be found on the serial label pull tab.
An S6520X-54XC-UPWR-SI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-20, two PSR720-56A AC power supplies are installed in the power supply slots.
The S6520X-54XC-UPWR-SI switch comes with the three fan tray slots empty. You must install three fan trays of the same model for the switch. In Figure2-20, three LSPM1FANSB fan trays are installed in the fan tray slots.
An S6520X-54XC-UPWR-SI switch comes with a filler panel in the expansion slot. You can select an expansion module for the switch as required. In Figure2-20, an LSWM2SP2PM interface card is installed in the expansion slot.
The S6520X-SI switches (except the S6520X-10XT-SI and S6520X-16XT-SI) use modular design and support removable components. Table3-1 and Table3-2 describe the removable components available for the switches and the compatibility between the removable components and the switches.
The S6520X-10XT-SI and S6520X-16XT-SI switches use one built-in power supply and two built-in fan trays and do not support removable components.
Table3-1 Removable components and their compatibility with the switches (1)
Removable component
S6520X-16ST-SI/S6520X-24ST-SI
S6520X-18C-SI/S6520X-18C-SI
S6520X-26MC-SI
PSR75-12A
Supported
Supported
Not supported
PSR150-A1
Supported
Supported
Supported
PSR150-D1
Supported
Supported
Supported
Expansion modules
LSWM2QP2P
Not supported
Supported
Supported
LSWM4SP8PM
Not supported
Supported
Supported
LSWM2SP8P
Not supported
Supported
Supported
LSWM2SP2PM
Not supported
Supported
Supported
LSWM2XGT2PM
Not supported
Supported
Supported
LSPM4G4T6P
Not supported
Supported
Supported
LSPM6FWD
Not supported
Supported
Supported
LSPM6FWD8
Not supported
Supported
Supported
LSWM2MGT8P
Not supported
Supported
Supported
LSWM2XMGT8P
Not supported
Supported
Supported
LSWM2ZSP2P
Not supported
Supported
Supported
LSWM2SP2PB
Not supported
Supported
Supported
LSWM2SP4PB
Not supported
Supported
Supported
Table3-2 Removable components and their compatibility with the switches (2)
Removable component
S6520X-26MC-UPWR-SI
S6520X-26XC-UPWR-SI
S6520X-54XC-UPWR-SI
PSR360-56A
Supported
Supported
Supported
PSR720-56A
Supported
Supported
Supported
PSR1110-56A
Supported
Supported
Supported
PSR560-56D
Supported
Supported
Supported
Removable fan trays
LSPM1FANSB
Not supported
Supported
Supported
Expansion modules
LSWM2QP2P
Supported
Supported
Supported
LSWM4SP8PM
Supported
Supported
Supported
LSWM2SP8P
Supported
Supported
Supported
LSWM2SP2PM
Supported
Supported
Not supported
LSWM2XGT2PM
Supported
Supported
Not supported
LSPM4G4T6P
Supported
Supported
Supported
LSPM6FWD
Supported
Supported
Supported
LSPM6FWD8
Supported
Supported
Supported
LSWM2MGT8P
Supported
Supported
Supported
LSWM2XMGT8P
Supported
Supported
Supported
LSWM2ZSP2P
Supported
Supported
Supported
LSWM2SP2PB
Supported
Supported
Supported
LSWM2SP4PB
Supported
Supported
Supported
说明: IMPORTANT
IMPORTANT:
·     An S6520X-18C-SI switch must use PSR150-A1 or PSR150-D1 power supplies for power supply when it is installed with an LSPM6FWD or LSPM6FWD8 firewall module.
·     An S6520X-26C-SI switch must use PSR150-A1 or PSR150-D1 power supplies for power supply when it is installed with an LSWM2SP8P, SWM4SP8PM, LSWM2XMGT8P, or LSWM2MGT8P interface card or an LSPM6FWD firewall module.
For an S6520X-16ST-SI, S6520X-24ST-SI, S6520X-18C-SI, S6520X-26C-SI, or S6520X-26MC-SI switch, you can install one power supply, or two power supplies for redundancy on the switch. AC and DC power supplies can be installed in the same chassis.
For an S6520X-26MC-UPWR-SI, S6520X-26XC-UPWR-SI, or S6520X-54XC-UPWR-SI switch, you can install one power supply, or two power supplies for redundancy on the switch. PoE capabilities vary by power supply configuration. When a power supply fails, PoE capabilities of the switch might decrease. For more information about PoE power, see Table1-4.
The S6520X-26XC-UPWR-SI and S6520X-54XC-UPWR-SI switches use removable fan trays. Before powering on the switch, make sure all fan tray slots have fan trays installed and the fan trays are the same model.
The removable components available for the switch are subject to change over time. For the most recent list of removable components available for the switch, see the release notes that come with the switch.
Table3-3 Removable power supplies
Power supply
Specifications
Reference
PSR75-12A
·     AC input
¡     Max output power: 75 W
·     High-voltage DC input:
H3C PSR75-12A Power Module User Manual
PSR150-A1
·     Rated input voltage range: 100 to 240 VAC @ 50/60 Hz
·     Max input voltage range: 90 to 264 VAC @ 47 to 63 Hz
·     Max output power: 150 W
H3C PSR150-A & PSR150-D Series Power Supplies User Manual
PSR150-D1
·     Rated input voltage range: –48 to –60 VDC
·     Max input voltage range: –36 to –72 VDC
PSR360-56A
·     Max output power: 360 W
H3C PSR360-56A Series Power Module User Manual
PSR720-56A
·     Max output power: 720 W
H3C PSR720-56A Series Power Module User Manual
PSR1110-56A
·     Rated input voltage range: 115 to 240 VAC @ 50/60 Hz
·     Max input voltage range: 102.5 to 264 VAC @ 47 to 63 Hz
·     Max output power: 1110 W
H3C PSR1110-56A Series Power Module User Manual
PSR560-56D
·     Max output power: 560 W
H3C PSR560-56D Series Power Module User Manual
The PSR1110-56A power supply, including the handle, adds 64 mm (2.52 in) to the chassis depth.
Removable fan trays
Table3-4 Fan tray specifications
Fan tray model
Item
Specifications
LSPM1FANSB (from the port side to the power supply side)
Fans
One 40 × 40 × 28 mm (1.57 × 1.57 × 1.10 in) fan
Fan speed
20000 R.P.M
Max airflow
20 CFM
Input voltage
12 V
9.8 W
Documentation reference
H3C LSPM1FANSA & LSPM1FANSB Fan Tray User Guide
Expansion modules
Table3-5 Expansion modules
Item
Specifications
LSWM2QP2P
2-port 40GE QSFP+ interface card
Port type and quantity
2 × 40 Gbps QSFP+ fiber ports
Available transceiver modules and cables
QSFP+ transceiver modules and cables described in Table4-10, Table4-11, and Table4-12, except the QSFP-40G-LR4-PSM1310
Reference
H3C LSWM2QP2P Interface Card User Manual
LSWM4SP8PM
8-port 10GE SFP+ interface module
8 × 10 Gbps SFP+ fiber ports
See Table4-5 and 0.
Reference
H3C LSWM4SP8PM Interface Card User Manual
LSWM2SP8P
8-port 10GE SFP+ interface card
See Table4-5 and 0.
Reference
H3C LSWM2SP8PM & LSWM2SP8P Interface Card User Manual
LSWM2SP2PM
2-port 10GE SFP+ interface card
2 × 1/10 Gbps SFP+ fiber ports
See Table4-5 and 0.
Reference
H3C LSWM2SP2PM Interface Card User Manual
LSWM2XGT2PM
2-port 1/10GBASE-T interface card
2 × 1/10GBASE-T autosensing Ethernet ports
Port specifications
See Table4-15.
Reference
H3C LSWM2XGT2PM & LSWM2XGT8PM Interface Cards User Manual
LSPM4G4T6P
4-port 10/100/1000BASE-T + 6-port SFP interface module
·     4 ×10/100/1000BASE-T autosensing Ethernet ports
·     6 × SFP fiber ports
SFP ports 5S and 6S form combo interfaces with 10/100/1000BASE-T autosensing Ethernet ports 5T and 6T, respectively.
The SFP ports support GE SFP transceiver modules in Table4-3 and GE SFP cables in Table4-4.
Reference
H3C LSPM4G4T6P Interface Card User Manual
LSPM6FWD
The module is a fourth-generation high performance firewall module. It provides features including firewall, VPN, content filtering, content identification, URL filtering, and NAT. By using this module on a switch, you can enhance the switch security capabilities without changing the network topology.
Reference
H3C LSPM6FWD Card Manual
LSPM6FWD8
Reference
H3C LSPM6FWD8 Card Manual
LSWM2MGT8P
8-port 5G/2.5G/1000BASE-T interface module
8 × 5G/2.5G/1000BASE-T autosensing Ethernet ports
Port specifications
See Table4-17.
Reference
H3C LSWM2MGT8P & LSWM2XMGT8P Interface Cards User Manual
LSWM2XMGT8P
8-port 10G/5G/2.5G/1000BASE-T interface module
8 × 10G/5G/2.5G/1000BASE-T autosensing Ethernet ports
Port specifications
See Table4-18.
Reference
LSWM2ZSP2P
2-port 25GE SFP28 interface module
2 × 25 Gbps SFP28 fiber ports
See Table4-8 and Table4-9.
Reference
H3C LSWM2ZSP2P Interface Card User Manual
LSWM2SP2PB
2-port 10GE SFP+ interface module
See Table4-3, Table4-4, Table4-5, and 0.
Reference
H3C LSWM2SP2PB & LSWM2SP4PB Interface Cards User Manual
LSWM2SP4PB
4-port 10GE SFP+ interface module
4 × 1/10 Gbps SFP+ fiber ports
Reference
说明: IMPORTANT
IMPORTANT:
The ports on the LSWM2SP2PM and LSWM2XGT2PM interface cards can operate only at 10 Gbps when the cards are installed on the switch.
An LSPM6FWD or LSPM6FWD8 firewall module (including its handle) adds 75 mm (2.95 in) to the chassis depth when installed on the switch.
An LSWM2XGT2PM interface card provides copper ports. To connect cables to the copper ports on an LSWM2XGT2PM interface card, follow these guidelines:
·     Use Category-6A or above cables and connectors. The max transmission distance varies by cable type:
¡     Category-6 UTP—55 m (180.45 ft).
¡     Category-6 STP—100 m (328.08 ft), no interference.
¡     Category-6 SFTP—100 m (328.08 ft).
¡     Category-6A or above twisted pair—100 m (328.08 ft).
·     Do not bundle cables in their first 20 m (65.62 ft).
·     Separate power cords and twisted pair cables at and around the distribution frame.
·     For ports adjacent to one another on the device, the peer ports on the distribution frame is preferably not adjacent, for example:
¡     If the device connects to one distribution frame, connect port 1 on the device to port 1 on the distribution frame and port 2 on the device to port 3 on the distribution frame.
¡     If the device connects to two distribution frames, connect port 1 on the device to port 1 on distribution frame 1 and port 2 on the device to port 1 on distribution frame 2.
·     Keep the device and twisted pair cables away from the interference source, such as a two-way radio and a high-power variable-frequency drive.
Ports
Console port
The switch has two console ports: a serial console port and a micro USB console port.
Table4-1 Console port specifications
Item
Serial console port
Connector type
RJ-45
Micro USB Type B
Compliant standard
EIA/TIA-232
USB 2.0
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
Provides connection to the USB port of a local PC running terminal emulation program.
The switch provides a management Ethernet port on the front panel. You can connect this port to a PC or management station for loading and debugging software or remote management.
Table4-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Connector quantity
1
Port transmission rate
·     10/100 Mbps, half/full duplex, MDI/MDI-X autosensing
·     1 Gbps, full duplex, MDI/MDI-X autosensing
Transmission medium and max transmission distance
100 m (328.08 ft) over category-5 twisted pair cable
Functions and services
Switch software and Boot ROM upgrade, network management
USB port
The switch has one OHC-compliant USB2.0 port that can upload and download data at a rate up to 480 Mbps. You can use this USB port to access the file system on the flash of the switch, for example, to upload or download application and configuration files.
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee the correct operation of USB devices from all vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
SFP port
An LSP4G4T6P interface module provides six SFP ports. You can install GE SFP transceiver modules in Table4-3 and GE SFP cables in Table4-4 in the SFP ports.
SFP+ port
The following switches provide fixed SFP+ ports on the front panel:
·     S6520X-16ST-SI
·     S6520X-24ST-SI
·     S6520X-18C-SI
·     S6520X-10XT-SI
·     S6520X-16XT-SI
·     S6520X-26C-SI
To connect peer SFP+ ports over a long distance, use SFP/SFP+ transceiver modules and fibers. To connect peer SFP+ ports over a short distance, use SFP/SFP+ cables. You can install GE SFP transceiver modules in Table4-3, GE SFP cables in Table4-4,10-GE SFP+ transceiver modules in Table4-5, and 10-GE SFP+ cables in 0 in the SFP+ ports.
Table4-3 GE SFP transceiver modules available for the SFP and SFP+ ports
Central wavelength (nm)
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
Max transmission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH20-SM1310-I
1310
LC
Single-mode, 9/125
N/A
20 km (12.43 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-I
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310 nm
RX: 1550 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550 nm
RX: 1310 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490 nm
RX: 1550 nm
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550 nm
RX: 1490 nm
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
说明: IMPORTANT
IMPORTANT:
The following transceiver modules must be used in pairs:
·     SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI
·     SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI
·     SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI
For example, if one end of a connection uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
Table4-4 GE SFP cables available for the SFP ports
GE SFP cable
Cable length
SFP-STACK-Kit
1.5 m (4.92 ft)
Table4-5 10-GE SFP+ transceiver modules available for the SFP+ ports
10-GE SFP+ module
Connector
Fiber diameter (µm)
Multimode fiber modal bandwidth (MHz × km)
SFP-XG-SX-MM850-A
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
·     TX: 1270
·     RX: 1330
LC
9/125 µm single-mode optical fiber
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
·     TX: 1330
·     RX: 1270
LC
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
·     TX: 1270
·     RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
·     TX: 1330
·     RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
·     TX: 1490
·     RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
·     TX: 1550
·     RX: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
说明: IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and the SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one ends uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table4-6 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table4-7 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure4-1 SFP+ cable
(1) Connector
(2) Pull latch
说明: IMPORTANT
IMPORTANT:
The S6520X-18C-SI and S6520X-26C-SI switches must use PSR150-A1 or PSR150-D1 power supplies for power supply when the switches are installed with SFP-XG-LH80-SM1550 transceiver modules.
·     As a best practice, use H3C SFP/SFP+ transceiver modules and cables for the SFP+ ports on the switch.
·     The H3C SFP/SFP+ transceiver modules and cables available for the SFP+ ports on the switch are subject to change over time. For the most recent list of SFP/SFP+ transceiver modules and cables available for the SFP+ ports, contact your H3C Support or marketing staff.
·     For more information about H3C SFP/SFP+ transceiver modules and cables, see H3C Transceiver Modules User Guide.
SFP28 port
The LSWM2ZSP2PM interface card provides the fixed SFP28 ports. To connect peer SFP28 ports over a long distance, use SFP28 transceiver modules and fibers. To connect peer SFP28 ports over a short distance, use SFP28 cables. You can install 25G SFP28 transceiver modules in Table4-8 and 25GE SFP28 cables in Table4-9.
Table4-8 25G SFP28 transceiver modules available for the SFP28 ports
Connector
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
·     FEC negotiation disabled—30 m (98.43 ft)
·     FEC negotiation enabled—70 m (229.66 ft)
4700
·     FEC negotiation disabled—40 m (131.23 ft)
·     FEC negotiation enabled—100 m (328.08 ft)
Table4-9 25G SFP28 cables available for the SFP28 ports
25G SFP28 cable
Cable length
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Figure4-2 SFP28 cable
(1) Connector
(2) Pull latch
·     As a best practice, use H3C SFP28 transceiver modules and cables for the SFP28 ports on the switch.
·     The H3C SFP28 transceiver modules and cables available for the SFP28 ports on the switch are subject to change over time. For the most recent list of SFP28 transceiver modules and cables available for the SFP28 ports, contact your H3C Support or marketing staff.
·     For more information about H3C SFP28 transceiver modules and cables, see H3C Transceiver Modules User Guide.
QSFP+ port
The S6520X-54XC-UPWR-SI switch provides fixed QSFP+ ports on the front panel and the LSWM2QP2P interface card provides QSFP+ ports. You can install QSFP+ transceiver modules in Table4-10, QSFP+ cables in Table4-11, and QSFP+ to SFP+ cables in Table4-12 in the QSFP+ ports.
Table4-10 QSFP+ transceiver modules available for the QSFP+ ports
Connector
QSFP-40G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-CSR4-MM850
850
MPO
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
1310
MPO
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-40G-BIDI-SR-MM850
850
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
Table4-11 QSFP+ cables available for the QSFP+ ports
QSFP+ network cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table4-12 QSFP+ to SFP+ cables available for the QSFP+ ports
QSFP+ to SFP+ cable
LSWM1QSTK3
1 m (3.28 ft)
LSWM1QSTK4
3 m (9.84 ft)
LSWM1QSTK5
5 m (16.40 ft)
Table4-13 QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Figure4-3 40G QSFP+ cable
(1) Connector
(2) Pull tab
Figure4-4 40G QSFP+ to SFP+ cable
(1) QSFP+ module
(2) QSFP+ side pull tab
(3) SFP+ side pull tab
(4) SFP+ module
说明: IMPORTANT
IMPORTANT:
The QSFP+ ports on an LSWM2QP2P interface card do not support the QSFP-40G-LR4-PSM1310 transceiver module.
You can use a QSFP-40G-SR4-MM850, QSFP-40G-CSR4-MM850, or QSFP-40G-LR4-PSM1310 transceiver module to connect a QSFP+ port to four SFP+ ports. The QSFP+ transceiver module and SFP+ transceiver modules to be connected must be the same in specifications, including central wavelength and fiber type.
·     As a best practice, use H3C QSFP+ transceiver modules, QSFP+ cables, or QSFP+ to SFP+ cables for the QSFP+ ports on the switch. The H3C QSFP+ transceiver modules, QSFP+ cables, and QSFP+ to SFP+ cables available for the QSFP+ ports are subject to change over time. For the most recent list of QSFP+ transceiver modules, QSFP+ cables, and QSFP+ to SFP+ cables available for the QSFP+ ports, contact H3C Support or marketing staff.
·     For more information about H3C QSFP+ transceiver modules, QSFP+ cables, and QSFP+ to SFP+ cables, see H3C Transceiver Modules User Guide.
An LSPM4G4T6P interface module provides 10/100/1000BASE-T autosensing Ethernet ports.
Table4-14 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Interface attributes
·     10/100 Mbps, full/half duplex, MDI/MDI-X, auto-sensing
·     1 Gbps, full duplex, MDI/MDI-X, auto-sensing
100 m (328.08 ft)
Transmission medium
Category-5 or above twisted pair cable
Standards
IEEE 802.3i, 802.3u, 802.3ab
The S6520X-16ST-SI and S6520X-24ST-SI switches each provide two 1/10BASE-T autosensing Ethernet ports on the front panel. An LSWM2XGT2PM interface card also provides 1/10BASE-T autosensing Ethernet ports.
Table4-15 1/10BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
1/10 Gbps, full duplex, MDI/MDI-X auto-sensing
·     Category-6 UTP—55 m (180.45 ft)
·     Category-6 STP—100 m (328.08 ft)
·     Category-6 SFTP—100 m (328.08 ft)
·     Category-6 or above twisted pair—100 m (328.08 ft)
Transmission medium
Category-6 or above twisted pair cable
Standards
IEEE 802.3ab, 802.3an
The S6520X-26MC-SI and S6520X-26MC-UPWR-SI switches each provide 24 5G/2.5G/1000/100BASE-T autosensing Ethernet ports on the front panel.
Table4-16 5G/2.5G/1000/100BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     100 Mbps, full/half duplex, MDI/MDI-X, auto-sensing
·     1/2.5/5 Gbps, full duplex, MDI/MDI-X, auto-sensing
·     5G mode: 100 m (328.08 ft) over Category-5e or above twisted pair
·     2.5G mode: 200 m (656.17 ft) over Category-5e or above twisted pair
·     1G mode: 200 m (656.17 ft) over Category-5e or above twisted pair
·     100M mode: 200 m (656.17 ft) over Category-5e or above twisted pair
Transmission medium
Category-5e or above twisted pair cable
Standards
IEEE 802.3ab, 802.3an, 802.3bz
An LSWM2MGT8P interface module provides 5G/2.5G/1000 BASE-T autosensing Ethernet ports.
Table4-17 5G/2.5G/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1G mode: 140 m (459.32 ft) over Category-5e or above twisted pair
Transmission medium
Standards
The S6520X-10XT-SI and S6520X-16XT-SI switches and the LSWM2XMGT8P interface module provide 10G/5G/2.5G/1000 BASE-T autosensing Ethernet ports.
Table4-18 10G/5G/2.5G/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
1/2.5/5/10 Gbps, full duplex, MDI/MDI-X, auto-sensing
·     10G mode:
¡     100 m (328.08 ft) over Category-6 or above S/FTP
¡     55 m (180.45 ft) over Category-5e twisted pair or Category-6 UTP
Transmission medium
Standards
The S6520X-26XC-UPWR-SI and S6520X-54XC-UPWR-SI switches provide 10G/5G/2.5G/1000/100 BASE-T autosensing Ethernet ports.
Table4-19 10G/5G/2.5G/1000/100 BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1/2.5/5/10 Gbps, full duplex, MDI/MDI-X, auto-sensing
·     10G mode:
Transmission medium
Standards
Combo interface
The S6520X-16ST-SI and S6520X-24ST-SI switches each provide two combo interfaces on the front panel. Each combo interface contains an SFP+ port and a 1/10GBASE-T autosensing Ethernet port. Only one of these two ports is active at a time.
An LSPM4G4T6P interface module provides two combo interfaces. Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports is active at a time.
LEDs
System status LED
The system status LED shows the operating state of the switch.
Table4-20 System status LED description
LED mark
Status
SYS
Steady green
The switch is operating correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed the POST or is faulty.
Off
The switch is powered off.
The S6520X-SI switches (except the S6520X-10XT-SI and S6520X-16XT-SI) each provide two power supply slots on the rear panel. The power status LEDs PWR1 and PWR2 on the front panel show the operating status of power supply 1 (PWR1) and power supply 2 (PWR2), respectively.
Table4-21 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply has failed or no power is input to the power supply.
Off
No power supply is installed in the power supply slot.
Mode LED
To show more information about the switch through the port LEDs, the switch provides a mode LED (MODE) to indicate the type of information that the port LEDs are showing.
You can use the mode button to change the indication of the mode LED.
Table4-22 Description for the mode LED
LED mark
Status
MODE
Steady green
The port LEDs indicate port rates.
Flashing yellow
The port LEDs indicates the IRF member ID of the switch. For example, if the LEDs for ports 1 to 5 are steady green and the other LEDs are off, the IRF member ID of the switch is 5.
Table4-23 Management Ethernet port LED description
Management Ethernet port LED (ACT/LINK) status
Steady green
A link is present on the port.
Flashing yellow
The port is sending or receiving data.
Off
No link is present on the port.
The S6520X-16ST-SI and S6520X-24ST-SI switches each provide a status LED for each 1/10GBASE-T autosensing Ethernet port to indicate their operating status.
Table4-24 1/10GBASE-T autosensing Ethernet port LED description
1/10GBASE-T autosensing Ethernet port LED status
Steady green
A link is present on the port and the port is operating at 10 Gbps.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A link is present on the port and the port is operating at 1 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps
Off
The S6520X-26MC-SI and S6520X-26MC-UPWR-SI switches each provide a status LED for each 5G/2.5G/1000/100GBASE-T autosensing Ethernet port to indicate their operating status.
Table4-25 5G/2.5G/1000/100BASE-T autosensing Ethernet port LED description
MODE LED status
5G/2.5G/1000/100BASE-T autosensing Ethernet port LED status
Steady green (rate mode)
Steady green
A link is present on the port and the port is operating at 5 Gbps.
Flashing green
The port is sending or receiving data at 5 Gbps.
Steady yellow
A link is present on the port and the port is operating at 1 or 2.5 Gbps, or 100 Mbps.
Flashing yellow
The port is sending or receiving data at 1 or 2.5 Gbps, or 100 Mbps.
Off
Flashing yellow (IRF mode)
Steady green
The port status LEDs on the switch indicate the IRF member IDs of the switch. For example, if the LEDs for ports 1 to 5 are steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
The S6520X-10XT-SI and S6520X-16XT-SI switches provide a status LED for each 10G/5G/2.5G/1000BASE-T autosensing Ethernet port to indicate their operating status.
Table4-26 10G/5G/2.5G/1000BASE-T autosensing Ethernet port LED description
MODE LED status
10G/5G/2.5G/1000BASE-T autosensing Ethernet port LED status
Steady green
Flashing green
Steady yellow
A link is present on the port and the port is operating at 1 Gbps, 2.5 Gbps, or 5 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps, 2.5 Gbps, or 5 Gbps.
Off
Steady green
The S6520X-26XC-UPWR-SI and S6520X-54XC-UPWR-SI switches provide a status LED for each 10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port to indicate their operating status.
Table4-27 10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port LED description
MODE LED status
10G/5G/2.5G/1000/100BASE-T autosensing Ethernet port LED status
Steady green
Flashing green
Steady yellow
A link is present on the port and the port is operating at 100 Mbps, 1 Gbps, 2.5 Gbps, or 5 Gbps.
Flashing yellow
The port is sending or receiving data at 100 Mbps, 1 Gbps, 2.5 Gbps, or 5 Gbps.
Off
Steady green
SFP+ port LED
The following switches provide a status LED for each SFP+ port to indicate their operating status:
·     S6520X-16ST-SI
·     S6520X-24ST-SI
·     S6520X-10XT-SI
·     S6520X-16XT-SI
·     S6520X-18C-SI
·     S6520X-26C-SI
Table4-28 SFP+ port LED description
MODE LED status
SFP+ port LED status
Steady green
Flashing green
Steady yellow
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
·     No link is present on the port.
·     The mode LED operates in IRF mode.
Steady green
说明: IMPORTANT
IMPORTANT:
·     In versions earlier than Release 6326 (not inclusive) or Release 65xx versions earlier than Release 6525 (not inclusive), the MODE LED changes in color and indication after you press the mode button and keeps that state until you press the mode button again.
·     In other versions, after you press the mode button, the MODE LED changes in color and indication and keeps that state for only 60 seconds and then turns steady green automatically.
The S6520X-18C-SI, S6520X-26C-SI, S6520X-26MC-SI, S6520X-26MC-UPWR-SI, S6520X-26XC-UPWR-SI, and S6520X-54XC-UPWR-SI switches each provide an expansion slot on the rear panel. The expansion module status LED on the front panel indicates the operating state of the expansion module.
Table4-29 Expansion module status LED description
LED mark
Status
SLOT
Steady green
The expansion module is present and is operating correctly.
Flashing yellow
The switch does not support the card model, or the card has failed.
Off
The expansion slot is empty.
An expansion module provides a port status LED for each port. For more information about the LEDs, see the manual for the expansion module.
Fan tray status LED
The LSPM1FANSB fan tray provides a status LED.
Table4-30 Fan tray status LED description
Status
On
The fan tray is operating correctly.
Flashing
The fan tray is operating incorrectly.
Off
The fan tray is installed incorrectly or not power is present on the fan tray.
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
·     S6520X-26MC-SI and S6520X-26MC-UPWR-SI switchesThe fan tray draws ambient air into the chassis from the left side and blows out air from the right side. Figure5-1 uses the S6520X-26MC-UPWR-SI switch as an example to show the airflow direction. (Left and right refer to the directions when you face the port side of the switch.)
·     S6520X-26XC-UPWR-SI and S6520X-54XC-UPWR-SIThe fan tray draws ambient air into the chassis from the left, right, and port sides, and blows out air from the power supply side. Figure5-2 uses the S6520X-26XC-UPWR-SI switch as an example to show the airflow direction. (Left and right refer to the directions when you face the port side of the switch.)
·     Other S6520X-SI switchesThe fan tray draws ambient air into the chassis from the left side and port side and blows out air from the right side. Figure5-3 uses the S6520X-26C-SI switch as an example to show the airflow direction.
Figure5-1 Airflow direction (S6520X-26MC-UPWR-SI)
Figure5-2 Airflow direction (S6520X-26XC-UPWR-SI)
Figure5-3 Airflow direction (S6520X-26C-SI)
  • Become a Partner
  • Partner Resources
