00-Preface | 100.41 KB |
Preface
H3C S6520X-SI Switch Series Installation Guide describes the appearance, installation, power-on, maintenance, and troubleshooting of the H3C S6520X-SI Switch Series.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6520X-SI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
