06-Traffic monitor | 33.60 KB |
This help contains the following topics:
¡ Traffic monitor user ranking widget
¡ Traffic monitor application ranking widget
¡ Realtime user ranking widget
¡ Realtime application ranking widget
¡ Source IP address ranking widget
¡ Virtual device ranking widget
Introduction
Traffic monitor displays traffic ranking statistics collected within the most recent monitoring interval through the following widgets:
· Traffic monitor user ranking.
· Traffic monitor application ranking.
· Realtime user ranking.
· Realtime application ranking.
· Source IP address ranking.
· Virtual device ranking.
To customize the widgets displayed on the Traffic Monitor page, click Select widgets and select the desired widgets from the list.
To enable automatic refresh for a widget:
1. Click the Set
icon in the top-right corner of the widget.
2. Select the Auto refresh option.
3. Enter the refresh interval in the Refresh interval field.
4. Click OK.
By default, the traffic monitor user ranking widget displays the top 10 users by bidirectional traffic volume observed within the past hour.
You can customize the widget to display the
top 10 users by the uplink or downlink traffic volume. To do so, click the Set icon in the
top-right corner of the widget, select Uplink, Downlink, or Total for Traffic type, and then click OK.
By default, the traffic monitor application ranking widget displays the top 10 applications by bidirectional traffic volume observed within the past hour.
top 10 applications by the uplink or downlink traffic volume. To do so, click the
Set icon in
the top-right corner of the widget, select Uplink, Downlink, or Total for Traffic type, and then click OK.
By default, the real-time user ranking widget displays the top 10 users by percentage of the user's traffic rate to the total traffic rate in a list.
The real-time user ranking list contains the following fields:
· User.
· Downlink traffic rate.
· Uplink traffic rate.
· Total rate.
· Percentage.
By default, the real-time application ranking widget displays the top 10 applications by percentage of the application's traffic rate to the total traffic rate in a list.
The real-time application ranking list contains the following fields:
· Application.
· Total rate.
· Percentage.
By default, the source IP address ranking widget displays the top 10 source IP addresses by total traffic rate observed within the past hour.
top 10 source IP addresses by bidirectional, uplink, or downlink traffic
volume. To do so, click the Set icon in the top-right corner of
and then click OK.
By default, the virtual device ranking widget displays the top 10 virtual devices (also known as contexts) by total traffic rate observed within the past hour.
top 10 virtual devices by bidirectional, uplink, or downlink traffic volume. To
and then click OK.
