- 12-High Availability Configuration Guide
- 01-Interface backup configuration
- 02-DLDP configuration
- 03-Monitor Link configuration
- 04-VRRP configuration
- 05-Load balancing configuration
- 06-Reth interface and redundancy group configuration
- 07-BFD configuration
- 08-Track configuration
- 09-Process placement configuration
- 10-Interface collaboration configuration
00-Preface | 80.64 KB |
Preface
This configuration guide describes the high availability fundamentals and configuration procedures. It covers the high availability features, such as interface backup, Track, VRRP, and BFD.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
